    3. Off Topic
    4. Proxmox
    5. Proxmox und iobroker
      Thomas Braun Most Active @Marko1974 last edited by
      @marko1974
      Weil es einfacher ist?
      Marko1974 1 Reply Last reply Reply Quote 0
      • Marko1974
        Marko1974 @Thomas Braun last edited by Marko1974
        was ist nun los?
        Komme auch nicht aufs Webif
            Installing ioBroker (3/4)
        gyp ERR! configure error
        gyp ERR! stack Error: getaddrinfo EAI_AGAIN nodejs.org
        gyp ERR! stack     at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:71:26)
        gyp ERR! System Linux 5.13.19-2-pve
        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        gyp ERR! cwd /opt/iobroker/node_modules/diskusage
        gyp ERR! node -v v14.19.1
        gyp ERR! node-gyp -v v5.1.0
        gyp ERR! not ok
        gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
        gyp ERR! not ok
            Finalizing installation (4/4)
        Enabling autostart...
        Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service -> /lib/systemd/system/iobroker.service.
        Autostart enabled!
        Fixing directory permissions...
        This system does not support setting default permissions.
        Do not use npm to manually install adapters unless you know what you are doing!
            ioBroker was installed successfully
            Open http://192.168.0.36:8081 in a browser and start configuring!
        You need to re-login before doing anything else on the console!
        openhabian@ioBroker:~$
        openhabian@ioBroker:/opt/iobroker$ iobroker status
        Objects type: jsonl
        States  type: jsonl
          @marko1974 sagte in Proxmox und iobroker:
          Hast du gemacht?
          • Marko1974
            Marko1974 @crunchip last edited by
            @crunchip yes. Sogar alles mal neu gestartet
            Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
              @Marko1974
              Kannst du nodejs.org aus der Kiste heraus erreichen?
                crunchip Forum Testing Most Active @Marko1974 last edited by crunchip
                @marko1974 denke, deine Netzwerkeinstellung ist falsch
                Ping mal google an von deinem iobroker aus
                  crunchip Forum Testing Most Active @Thomas Braun last edited by
                  @thomas-braun ich ziehe allerdings statisch bei Serverbetrieb vor
                    fertig habe quasi in ein anderes netzwerk mit dem Teil wande
                    Was heisst anderes Netzwerk?
                      Thomas Braun Most Active @crunchip last edited by
                      @crunchip
                      Schließt sich ja nicht aus.
                      Die IP bindet der DHCP-Server an die MAC-Adresse.
                        Homoran Global Moderator Administrators @Marko1974 last edited by
                        DNS Problem
                          crunchip Forum Testing Most Active @Thomas Braun last edited by crunchip
                          @thomas-braun und was machste dann bei einem vlan, Router wechsel etc
                          Gerätschaften, bei denen es nicht egal ist, welche ip Adresse sie haben, liegen bei mir im extra angelegten statischen Adressbereich, geordnet, alles andere, danach im dhcp Bereich
                          Das wäre mir zu umständlich, wenn z.b. eine neue Maschine, Grafana, influx oder iobroker, estellt werden muss, ein backup einspielen, aber dann müsste ich den ganzen Rattenschwanz mit anpassen, wie Scripte, hinterlegte Geräte/Maschinen in gewissen Adapter, ini Dateien...
                            Thomas Braun Most Active last edited by Thomas Braun
                            @crunchip hostnames, fertig. In meinem Netzwerk jedenfalls.
                              @thomas-braun auch dein Netzwerk kann das nicht, ohne alles anpassen zu müssen. Da nützt dir hostnames wenig
                                Thomas Braun Most Active @crunchip last edited by Thomas Braun
                                @crunchip
                                Ich hab auch kein VLAN, keine Geräte, denen es nicht egal ist welche IP sie haben, kein Grafana, kein influx, kein neues iobroker.
                                Alle Geräte haben hier einen hostname über den DHCP-Server der Fritte, gut ist. Da muss ich dann auch keine handschriftlichen Tabellen/Notizen mit fixen IPs führen. Das wäre mir nämlich alles zu umständlich und zu fehlerträchtig.
                                • Marko1974
                                  @crunchip said in Proxmox und iobroker:
                                  Das heißt, dass ich hier alles fertig machen möchte und das Ding dann mit zu meinen Eltern nehme.
                                  Bekommt also eine andere IP.
                                  Ich hab hier was mit 192.168.0.1
                                  Und die mit 178.1….wenn mir einer sagen kann wie ich das nachträglich anpasse wäre ich dankbar.
                                  Zu dem Ping an Node.js komme ich gleich. Ich schmeiß das Ding gleich mal an, wenn ich zuhause bin.
                                  crunchip 3 Replies Last reply Reply Quote 0
                                    dann erklär mal, was da jetzt überhaupt läuft
                                    Proxmox, VM, LXC?
                                    • Marko1974
                                      @crunchip
                                      Ich hab Proxmox laufen und hab nen Container angelegt. Aber eben auch nur nen Container. Da ich vorher einen Raspi hatte bin ich da noch nicht so sicher.
                                      Meine Frage ist auch: reicht es nur den Container zu erstellen oder braucht man grundsätzlich auch eine Installation der VM
                                        da hasst du dann wohl das Prinzip von Proxmox nicht verstanden. Solltes dich ein wenig einlesen zum Thema Proxmox.
                                        Kurz gefasst,
                                        du hast Proxmox als Virtualisierungs Software, darin kannst du VM und LXC anlegen.
                                        Eine VM ist wie ein Vollwertiger PC anzusehen.(isoliert und eigenständiger Kernel)
                                        Ein LXC ist ist eine "abgespeckte Version", dieser ist zwar ebenfalls isoliert, teilt sich jedoch den Kernel des Host's
                                        • Marko1974
                                          @crunchip Ja das habe ich auch so verstanden. War nur mal so gefragt, weil man ja im LXC auch noch die USB Geräte durchreichen muss. Da kam mir halt der Gedanke, ob da noch was anderes installiert sein muss - wegen dem Wort durchreichen. Durchreichen von wo denn?
                                          Also dann wohl von Proxmos zum LXC.
                                            @marko1974 du schliesst ja was auch immer, an den Rechner an(Proxmox) und daher musst du das entsprechende Gerät zur jeweiligen Maschine durchreichen, damit diese darauf zugreifen kann
                                            ist aber auch in der Anleitung sehr gut beschrieben
                                            81.1k
                                            25537
