    4. Zigbee Adapter Geräte alle Offline
      Cino last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: RPI4b
      Arbeitsspeicher: 4GB
      Festplattenart: SD-Karte 64 GB
      Betriebssystem: RpiOS
      Node-Version: 14
      Nodejs-Version: 14.9.1
      NPM-Version: 6.x.x
      Installationsart: Skript
      Image genutzt: Nein
      Ich habe mit dem Zigbee Adapter über Nacht ein Problem gehabt.
      2022-04-29 00:33:45.970 - error: zigbee.0 (2861136) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2022-04-29 00:33:45.971 - error: zigbee.0 (2861136) unhandled promise rejection: Cannot read property 'mapped' of undefined
      2022-04-29 00:33:45.973 - error: zigbee.0 (2861136) TypeError: Cannot read property 'mapped' of undefined
      at Zigbee.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:502:36)
      at runMicrotasks ()
      at processTicksAndRejections (internal/process/task_queues.js:95:5)
      2022-04-29 00:33:45.974 - error: zigbee.0 (2861136) Cannot read property 'mapped' of undefined
      2022-04-29 00:33:45.984 - info: zigbee.0 (2861136) cleaned everything up...
      2022-04-29 00:33:45.995 - info: zigbee.0 (2861136) Zigbee: disabling joining new devices.
      2022-04-29 00:33:46.092 - info: wled.0 (560779) WLED_Monitor connected
      2022-04-29 00:33:46.431 - info: zigbee.0 (2861136) terminating
      2022-04-29 00:33:46.433 - warn: zigbee.0 (2861136) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2022-04-29 00:33:47.106 - error: host.server Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2022-04-29 00:33:47.107 - error: host.server Caught by controller[0]: TypeError: Cannot read property 'mapped' of undefined
      2022-04-29 00:33:47.107 - error: host.server Caught by controller[0]: at Zigbee.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:502:36)
      2022-04-29 00:33:47.108 - error: host.server Caught by controller[0]: at runMicrotasks ()
      2022-04-29 00:33:47.108 - error: host.server Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:95:5)
      2022-04-29 00:33:47.108 - error: host.server instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      Nach einem Neustart wird nur ein einziges Gerät erkannt.
      zigbee.0
      2022-04-29 01:32:45.698	info	Zigbee started
      zigbee.0
      2022-04-29 01:32:45.696	info	0xec1bbdfffea3e3fd (addr 56970): HG06336 - Lidl Silvercrest smart window and door sensor (EndDevice)
      zigbee.0
      2022-04-29 01:32:45.672	info	Currently 1 devices are joined:
      zigbee.0
      2022-04-29 01:32:45.635	info	--> transmitPower : normal
      zigbee.0
      2022-04-29 01:32:45.583	info	Unable to disable LED, unsupported function.
      {1}
      zigbee.0
      2022-04-29 01:32:45.564	info	Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20201127}}
      zigbee.0
      2022-04-29 01:32:45.126	info	Installed Version: iobroker.zigbee@1.6.18
      zigbee.0
      2022-04-29 01:32:44.368	info	Starting Zigbee npm ...
      zigbee.0
      2022-04-29 01:32:44.145	info	starting. Version 1.6.18 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.1, js-controller: 4.0.23
      Alle anderen Geräte sind Offline.
      • Asgothian
        Asgothian Developer @Cino last edited by
        @cino
        anscheinend wurde die device Datenbank nicht sauber geschrieben.
        bitte die Dateien /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json und /opt/iobroker/iobroker-data/zigbee_0/shepherd.db durch das letzte backup ersetzen. In dem Verzeichnis sollten einige Kandidaten fürs Backup verfügbar sein (gzipped)
        A.
          Cino last edited by
          Habe ich gemacht. Danach kamen noch 2 Geräte online.
          Der Rest ist immer noch Offline. Leider. Habe jetzt einige Tage verstreichen lassen weil ich dachte das kommt schon. Ist aber leider nicht.
          • Asgothian
            @cino Die Frage ist weniger wie viele Geräte online kommen als wieviele Geräte bei Adapterstart als "verbunden" gemeldet sind.
            zigbee.0 2022-04-29 01:32:45.672	info	Currently 1 devices are joined:
            A.
              Cino @Asgothian last edited by Cino
              @asgothian
              zigbee.0
              895141	2022-05-06 14:03:46.308	error	Device 0xb4e3f9fffe67f677 "undefined" not described in statesMapping.
              zigbee.0
              895141	2022-05-06 14:03:46.301	error	Device 0xb4e3f9fffe68009f "undefined" not described in statesMapping.
              zigbee.0
              895141	2022-05-06 14:03:46.293	error	Device 0x00124b00250485db "undefined" not described in statesMapping.
              zigbee.0
              895141	2022-05-06 14:03:46.281	error	Device 0xb4e3f9fffe67b790 "undefined" not described in statesMapping.
              zigbee.0
              895141	2022-05-06 14:03:46.274	error	Device 0xb4e3f9fffe80caac "undefined" not described in statesMapping.
              zigbee.0
              895141	2022-05-06 14:03:45.822	info	Zigbee started
              zigbee.0
              895141	2022-05-06 14:03:45.821	info	0xec1bbdfffea3e3fd (addr 56970): HG06336 - Lidl Silvercrest smart window and door sensor (EndDevice)
              zigbee.0
              895141	2022-05-06 14:03:45.819	info	0xb4e3f9fffe67f677 (addr 55114): Not supported (model undefined)(EndDevice)
              zigbee.0
              895141	2022-05-06 14:03:45.819	info	0xb4e3f9fffe68009f (addr 36114): Not supported (model undefined)(Unknown)
              zigbee.0
              895141	2022-05-06 14:03:45.818	info	0x00124b00250485db (addr 37696): Not supported (model undefined)(Unknown)
              zigbee.0
              895141	2022-05-06 14:03:45.817	info	0xb4e3f9fffe67b790 (addr 9348): Not supported (model undefined)(Unknown)
              zigbee.0
              895141	2022-05-06 14:03:45.817	info	0xb4e3f9fffe80caac (addr 55852): Not supported (model undefined)(EndDevice)
              zigbee.0
              895141	2022-05-06 14:03:45.816	info	0xb4e3f9fffe6811c2 (addr 3852): E1812 - IKEA TRADFRI shortcut button (EndDevice)
              zigbee.0
              895141	2022-05-06 14:03:45.814	info	0xb4e3f9fffe680259 (addr 14071): E1525/E1745 - IKEA TRADFRI motion sensor (EndDevice)
              zigbee.0
              895141	2022-05-06 14:03:45.812	info	0x847127fffe53e6e8 (addr 42442): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
              zigbee.0
              895141	2022-05-06 14:03:45.810	info	0x5c0272fffecbe6b7 (addr 26390): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice)
              zigbee.0
              895141	2022-05-06 14:03:45.807	info	0xec1bbdfffea3e3a7 (addr 5980): HG06336 - Lidl Silvercrest smart window and door sensor (EndDevice)
              zigbee.0
              895141	2022-05-06 14:03:45.805	info	0xec1bbdfffe8d3cb3 (addr 46572): HG06336 - Lidl Silvercrest smart window and door sensor (EndDevice)
              zigbee.0
              895141	2022-05-06 14:03:45.796	info	0xec1bbdfffeb7354c (addr 256): HG06336 - Lidl Silvercrest smart window and door sensor (EndDevice)
              zigbee.0
              895141	2022-05-06 14:03:45.715	info	Currently 13 devices are joined:
              zigbee.0
              895141	2022-05-06 14:03:45.696	info	--> transmitPower : normal
              zigbee.0
              895141	2022-05-06 14:03:45.668	info	Unable to disable LED, unsupported function.
              zigbee.0
              895141	2022-05-06 14:03:45.666	info	Disable LED
              zigbee.0
              895141	2022-05-06 14:03:45.657	info	Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20201127}}
              zigbee.0
              895141	2022-05-06 14:03:45.210	info	Installed Version: iobroker.zigbee@1.6.18
              zigbee.0
              895141	2022-05-06 14:03:44.576	info	Starting Zigbee npm ...
              zigbee.0
              895141	2022-05-06 14:03:44.443	info	starting. Version 1.6.18 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.1, js-controller: 4.0.23
              zigbee.0
              807672	2022-05-06 14:03:37.492	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              zigbee.0
              807672	2022-05-06 14:03:37.491	info	terminating
              zigbee.0
              807672	2022-05-06 14:03:37.043	info	Zigbee: disabling joining new devices.
              zigbee.0
              807672	2022-05-06 14:03:36.994	info	cleaned everything up...
              zigbee.0
              807672	2022-05-06 14:03:36.992	info	Got terminate signal TERMINATE_YOURSELF
                Cino last edited by
                So sieht es nach einem Adapterneustart aus.
