    4. [Aufruf] IKEA-Trådfri Adapter testen
      han_swurst last edited by
      Hallo AlCalzone,
      ich habe Deinen Adapter auch getestet (oder es versucht).
      Unter Node 4.7.3 und 4.8.3 kann ich den Adapter nach Deiner Anleitung installieren.
      Es kommt im Log aber leider die gleichen Meldungen wie bei @mctom :
      host.bla	2017-05-09 13:43:39.501	info	Restart adapter system.adapter.tradfri.0 because enabled
      host.bla	2017-05-09 13:43:39.501	error	instance system.adapter.tradfri.0 terminated with code null ()
      host.bla	2017-05-09 13:43:39.500	warn	instance system.adapter.tradfri.0 terminated due to SIGABRT
      host.bla	2017-05-09 13:43:37.914	info	instance system.adapter.tradfri.0 started with pid 117
      Unter Node 6.10.3 kann ich den Adapter nicht mal von git installieren.
      $ ./iobroker url "https://github.com/AlCalzone/ioBroker.tradfri" --debug
      install https://github.com/AlCalzone/ioBroker.tradfri/tarball/master
      npm install https://github.com/AlCalzone/ioBroker.tradfri/tarball/master --production --prefix "/opt/iobroker" (System call)
      npm
       WARN lifecycle node-mbed-dtls@2.4.4~preinstall: cannot run in wd %s %s (wd=%s) node-mbed-dtls@2.4.4 node downloadDeps.js /opt/iobroker/node_modules/.staging/node-mbed-dtls-8b868442
      > node-mbed-dtls@2.4.4 install /opt/iobroker/node_modules/coap-dtls/node_modules/node-mbed-dtls
      > node-gyp rebuild
      make: Entering directory '/opt/iobroker/node_modules/coap-dtls/node_modules/node-mbed-dtls/build'make: Leaving directory '/opt/iobroker/node_modules/coap-dtls/node_modules/node-mbed-dtls/build'
      make: *** No rule to make target 'Release/obj.target/mbedcrypto/mbedtls/library/aes.o', needed by 'Release/obj.target/mbedcrypto.a'.  Stop.
      gyp
       ERR! build error
      gyp
      ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
      gyp ERR! stack     at emitTwo (events.js:106:13)
      gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
      gyp
      ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)gyp ERR! System Linux 3.10.102
      gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/coap-dtls/node_modules/node-mbed-dtlsgyp ERR! node -v v6.10.3
      gyp ERR! node-gyp -v v3.4.0
      gyp ERR! not ok
      npm ERR! Linux 3.10.102npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "https://github.com/AlCalzone/ioBroker.tradfri/tarball/master" "--production" "--prefix" "/opt/iobroker"
      npm ERR! node v6.10.3
      npm ERR! npm
       v3.10.10npm ERR! code ELIFECYCLE
      npm ERR! node-mbed-dtls@2.4.4 install: `node-gyp rebuild`npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the node-mbed-dtls@2.4.4 install script 'node-gyp rebuild'.
      npm ERR! Make sure you have the latest version of node.js and npm installed.
      npm ERR! If you do, this is most likely a problem with the node-mbed-dtls package,
      npm ERR! not with npm itself.
      npm ERR! Tell the author that this fails on your system:
      npm ERR!     node-gyp rebuild
      npm ERR! You can get information on how to open an issue for this project with:
      npm ERR!     npm bugs node-mbed-dtls
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls node-mbed-dtls
      npm ERR! There is likely additional logging output above.
      npm ERR!
       Please include the following file with any support request:npm ERR!
           /opt/npm-debug.log
      ERROR: Cannot parse /opt/iobroker/node_modules/iobroker.js-controller/adapter/tradfri/io-package.json:Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/adapter/tradfri/io-package.json'
      process exited with code 0
      Kannst Du mir helfen? Achja, auch meine Mac-Adresse entspricht der Seriennummer.
      MfG
      Chris
        @han_swurst:
        Achja, auch meine Mac-Adresse entspricht der Seriennummer. `
        Das ist klar!
        Die ersten drei Paare heben den Hersteller an.
        Diese wollte alCalzone wissen.
        Rainer
        • AlCalzone
          Ja, halte dich an die Installationsanleitung auf Github:
          ` > Installation on Raspberry PI
          Make sure you have git installed. If not: sudo apt-get install git-core
          Install this adapter via the ioBroker GUI -> This will result in an error
          Open the console and navigate to /opt/iobroker/node_modules/iobroker.tradfri
          There, run sudo npm install –production --unsafe-perm, this will take a while.
          If neccessary, add an adapter instance, then configure it by entering the IP/hostname of your gateway and the security code that can be found under that. `
          Die Installation erfordert git-core zum Nachladen von Paketen und erhöhte Rechte (–unsafe-perm) zur Kompilierung der Pakete. Beides kann ich für die automatische Installation leider nicht vorgeben (oder ich bin zu doof dafür).
          Ich vermute, dir fehlt git, da er die Datei aes.o nicht findet:
          Da du schon der zweite mit dem gleichen Problem auf Node 4.x bist, kann ich mich wohl doch nicht einfach auf Travis verlassen...
          Ich werde die Tage mal auf 4.x downgraden und schauen, ob ich die Ursache finde.
          Hast du ein paar Details für mich zu deiner Umgebung?
          Hardware / Software inkl. Versionen?
            wie ich schon geschrieben habe, bin ich nach Deiner Anleitung vorgegangen 😄
            git-core ist drauf.
            Beim Installieren unter 6.10.3 kommt er ja garnicht so weit das er unter iobroker/node_modules das Verzeichnis iobroker.tradfri erstellt.
            Das ganze läuft in nem Docker-Container auf einer Synology.
            iobroker und alle installierten Adapter sind aktuell.
            MfG
            Chris
              Hallo AlCalzone,
              muss es wirklich git-core sein?
              Ich hatte nur git installiert.
              Auf welcher von meinen Plattformen es gerade läuft weiß ich gerade nicht. Müsste aber mindestens nodejs v6 sein.
              Rainer
              • AlCalzone
                git-core ist ein subset von git, wenn man nicht alle Funktionen braucht. git sollte es also auch tun.
                • AlCalzone
                  @han_swurst:
                  git-core ist drauf.
                  Beim Installieren unter 6.10.3 kommt er ja garnicht so weit das er unter iobroker/node_modules das Verzeichnis iobroker.tradfri erstellt. `
                  Hmmm, probier mal anstatt der Installation per Admin-UI folgendes, dann kannst du dir auch Schritt 3/4 sparen:
                  cd /opt/iobroker
                  sudo npm install https://github.com/AlCalzone/ioBroker.tradfri/tarball/master --production --unsafe-perm
                  anschließend im Admin die Instanz hinzufügen oder
                  iobroker add tradfri
                    Hallo AlCalzone,
                    unter Node 6.10.3 ist der Adapter jetzt installiert, es kommt aber immer noch der gleiche Fehler:
                    host.bla 2017-05-10 16:58:42.165	error	instance system.adapter.tradfri.0 terminated with code null ()
                    host.bla 2017-05-10 16:58:42.165	warn	instance system.adapter.tradfri.0 terminated due to SIGABRT
                    MfG
                    Chris
                    • AlCalzone
                      Ok, um das mal zusammenzufassen:
                      han_swurst: Docker-Container (VM?) => läuft nicht
                      mctom: VM => läuft nicht
                      Homoran: Raspberry (?) => läuft
                      ich: Raspberry => läuft
                      Welches Betriebssystem hab ihr am Laufen? Und hat jemand ne Idee, wie ich euer Setup replizieren kann für Tests?
                        @AlCalzone:
                        Homoran: Raspberry (?) => läuft `
                        :lol: irgendwodrauf nur definitiv kein RasPi :lol:
                        Cubie, Tinker, pine64 oder nuc.
                        Ich muss nachsehen.
                        Edit:
                        Ist der nuc mit debian 9 netinstall "stretch" und nodejs 7.x
                        Installation habe ich allerdings schon mit der vorversion vom Adapter gemacht.
                        Rainer
                          Hallo AlCalzone,
                          ich habs jetzt mit nem frisch installierten Raspi 3 und iobroker unter node 6.10.3 versucht.
                          Gleicher Fehler.
                          MfG
                          Chris
                          • AlCalzone
                            okay… jetzt bin ich verwirrt.
                            Kannst du die Installationslogs mal in eine Datei umleiten und mir diese zukommen lassen?
                            sudo npm install [...]  2>&1 | tee log.txt
                            Aber gut, dass du auf nem frischen Pi3 testen konntest... das kann ich nämlich auch.
                            Ich habe ne Vermutung, die ich später mal überprüfen werde. Auf meinem Dev-Pi läuft auch der zwave- und fhem(-Adapter), beide wollten vorher zusätzliche Pakete installiert haben. Eventuell brauchen wir auch eins davon, und das scheint dir zu fehlen.
                              Ich habe es gerade auf einem meiner beiden Tinker unter nodejs 6.2 versucht.
                              Die Installation über den admin mittels pfad von github endet mit error 25.
                              Anschließend existiert der Ordner iobroker.tradfri unter /opt/iobroker/node_modules/ NICHT!
                              Rainer
                                Auch nach versuch über die Konsole kein trådfri ordner
                                linaro@linaro-alip:/opt/iobroker$ npm install https://github.com/AlCalzone/ioBroker.tradfri --production
                                node-mbed-dtls@2.4.4 preinstall /opt/iobroker/node_modules/.staging/node-mbed-dtls-a5e9e04f
                                Cloning into 'mbedtls'...
                                bufferutil@1.1.0 install /opt/iobroker/node_modules/bufferutil
                                node-gyp rebuild
                                make: Entering directory '/opt/iobroker/node_modules/bufferutil/build'
                                CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
                                In file included from ../node_modules/nan/nan.h:82:0,
                                from ../src/bufferutil.cc:16:
                                ../node_modules/nan/nan_new.h: In function ‘v8::Local NanIntern::To(v8::Handlev8::integer) [with T = v8:
                                :Int32; v8::Handle v8::integer= v8::Localv8::integer]:
                                ../node_modules/nan/nan_new.h:34:64: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated
                                (declared at /home/linaro/.node-gyp/6.10.2/include/node/v8.h:8202): Use maybe version [-Wdeprecated-declarat
                                ions]
                                Tov8::int32(v8::Handle v8::integeri) { return i->ToInt32(); }
                                :Uint32; v8::Handle v8::integer= v8::Localv8::integer]’:
                                ../node_modules/nan/nan_new.h:39:65: warning: ‘v8::Local v8::uint32v8::Value::ToUint32() const’ is deprecat
                                ed (declared at /home/linaro/.node-gyp/6.10.2/include/node/v8.h:8196): Use maybe version [-Wdeprecated-declar
                                ations]
                                Tov8::uint32(v8::Handle v8::integeri) { return i->ToUint32(); }
                                In file included from ../node_modules/nan/nan_new.h:189:0,
                                from ../node_modules/nan/nan.h:82,
                                ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8: :booleanobject="">::return_t NanIntern::Factoryv8::booleanobject::New(bool)’:
                                ../node_modules/nan/nan_implementation_12_inl.h:49:38: warning: ‘static v8::Local v8::valuev8::BooleanObjec
                                t::New(bool)’ is deprecated (declared at /home/linaro/.node-gyp/6.10.2/include/node/v8.h:4008): Pass an isola
                                te [-Wdeprecated-declarations]
                                return v8::BooleanObject::New(value).Asv8::booleanobject();
                                ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8: :script="">::return_t NanIntern::Factoryv8::script::New(v8::Localv8::string)’:
                                ../node_modules/nan/nan_implementation_12_inl.h:166:69: warning: ‘static v8::Local v8::scriptv8::ScriptComp
                                iler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated (
                                declared at /home/linaro/.node-gyp/6.10.2/include/node/v8.h:1352): Use maybe version [-Wdeprecated-declaratio
                                ns]
                                return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);
                                ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8: :script="">::return_t NanIntern::Factoryv8::script::New(v8::Localv8::string, const v8::ScriptOrigin&)’:
                                ../node_modules/nan/nan_implementation_12_inl.h:173:69: warning: ‘static v8::Local v8::scriptv8::ScriptComp
                                ns]
                                ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8: :string="">::return_t NanIntern::Factoryv8::string::New(const uint8_t*, int)’:
                                ../node_modules/nan/nan_implementation_12_inl.h:206:42: warning: ‘static v8::Local v8::stringv8::String::Ne
                                wFromOneByte(v8::Isolate*, const uint8_t*, v8::String::NewStringType, int)’ is deprecated (declared at /home/
                                linaro/.node-gyp/6.10.2/include/node/v8.h:2332): Use maybe version [-Wdeprecated-declarations]
                                v8::String::kNormalString, length);
                                ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8: :string="">::return_t NanIntern::Factoryv8::string::New(v8::String::ExternalStringResource*)’:
                                ../node_modules/nan/nan_implementation_12_inl.h:217:66: warning: ‘static v8::Local v8::stringv8::String::Ne
                                wExternal(v8::Isolate*, v8::String::ExternalStringResource*)’ is deprecated (declared at /home/linaro/.node-g
                                yp/6.10.2/include/node/v8.h:2371): Use maybe version [-Wdeprecated-declarations]
                                return v8::String::NewExternal(v8::Isolate::GetCurrent(), value);
                                ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8: :unboundscript="">::return_t NanIntern::Factoryv8::unboundscript::New(v8::Localv8::string)’:
                                ../node_modules/nan/nan_implementation_12_inl.h:237:76: warning: ‘static v8::Local v8::unboundscriptv8::Scr
                                iptCompiler::CompileUnbound(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ i
                                s deprecated (declared at /home/linaro/.node-gyp/6.10.2/include/node/v8.h:1333): Use maybe version [-Wdepreca
                                ted-declarations]
                                return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);
                                ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8: :unboundscript="">::return_t NanIntern::Factoryv8::unboundscript::New(v8::Localv8::string, const v8::ScriptO
                                rigin&)’:
                                ../node_modules/nan/nan_implementation_12_inl.h:244:76: warning: ‘static v8::Local v8::unboundscriptv8::Scr
                                ted-declarations]
                                In file included from ../src/bufferutil.cc:16:0:
                                ../node_modules/nan/nan.h: At global scope:
                                ../node_modules/nan/nan.h:261:25: error: redefinition of ‘template <class t="">v8::Local _NanEnsureLocal(v8::
                                Local)’
                                NAN_INLINE v8::Local _NanEnsureLocal(v8::Local val) {
                                ../node_modules/nan/nan.h:256:25: note: ‘template <class t="">v8::Local _NanEnsureLocal(v8::Handle)’ previ
                                ously declared here
                                NAN_INLINE v8::Local _NanEnsureLocal(v8::Handle val) {
                                ../node_modules/nan/nan.h: In function ‘bool NanIdleNotification(int)’:
                                ../node_modules/nan/nan.h:289:71: warning: ‘bool v8::Isolate::IdleNotification(int)’ is deprecated (declared
                                at /home/linaro/.node-gyp/6.10.2/include/node/v8.h:6114): use IdleNotificationDeadline() [-Wdeprecated-declar
                                ations]
                                return v8::Isolate::GetCurrent()->IdleNotification(idle_time_in_ms);
                                ../node_modules/nan/nan.h:473:20: error: variable or field ‘NanAddGCEpilogueCallback’ declared void
                                v8::Isolate::GCEpilogueCallback callback
                                ../node_modules/nan/nan.h:473:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’
                                ../node_modules/nan/nan.h:474:18: error: expected primary-expression before ‘gc_type_filter’
                                , v8::GCType gc_type_filter = v8::kGCTypeAll) {
                                ../node_modules/nan/nan.h:479:20: error: variable or field ‘NanRemoveGCEpilogueCallback’ declared void
                                v8::Isolate::GCEpilogueCallback callback) {
                                ../node_modules/nan/nan.h:479:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’
                                ../node_modules/nan/nan.h:484:20: error: variable or field ‘NanAddGCPrologueCallback’ declared void
                                v8::Isolate::GCPrologueCallback callback
                                ../node_modules/nan/nan.h:484:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’
                                ../node_modules/nan/nan.h:485:18: error: expected primary-expression before ‘gc_type_filter’
                                ../node_modules/nan/nan.h:490:20: error: variable or field ‘NanRemoveGCPrologueCallback’ declared void
                                v8::Isolate::GCPrologueCallback callback) {
                                ../node_modules/nan/nan.h:490:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’
                                ../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared
                                , node::smalloc::FreeCallback callback
                                ../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘...’ before ‘callback’
                                ../node_modules/nan/nan.h: In function ‘v8::Local v8::objectNanNewBufferHandle(char*, size_t, int)’:
                                ../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope
                                v8::Isolate::GetCurrent(), data, length, callback, hint);
                                ../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope
                                ../node_modules/nan/nan.h: In function ‘v8::Local v8::objectNanNewBufferHandle(const char*, uint32_t)’:
                                ../node_modules/nan/nan.h:672:67: error: invalid conversion from ‘const char*’ to ‘char*’ [-fpermissive]
                                return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);
                                In file included from ../src/bufferutil.cc:10:0:
                                /home/linaro/.node-gyp/6.10.2/include/node/node_buffer.h:46:40: note: initializing argument 2 of ‘v8::MaybeLo
                                cal v8::objectnode::Buffer::New(v8::Isolate*, char*, size_t)’
                                NODE_EXTERN v8::MaybeLocal v8::objectNew(v8::Isolate* isolate,
                                ../node_modules/nan/nan.h:672:67: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((ch
                                ar*)data), size)’ from ‘v8::MaybeLocalv8::object’ to ‘v8::Localv8::object’
                                ../node_modules/nan/nan.h: In function ‘v8::Local v8::objectNanNewBufferHandle(uint32_t)’:
                                ../node_modules/nan/nan.h:676:61: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), size
                                return node::Buffer::New(v8::Isolate::GetCurrent(), size);
                                ../node_modules/nan/nan.h: In function ‘v8::Local v8::objectNanBufferUse(char*, uint32_t)’:
                                ../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’
                                return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);
                                ../node_modules/nan/nan.h: In function ‘v8::Local v8::scriptNanCompileScript(v8::Localv8::string, const v
                                8::ScriptOrigin&)’:
                                ../node_modules/nan/nan.h:710:74: warning: ‘static v8::Local v8::scriptv8::ScriptCompiler::Compile(v8::Isol
                                ate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated (declared at /home/lina
                                ro/.node-gyp/6.10.2/include/node/v8.h:1352): Use maybe version [-Wdeprecated-declarations]
                                return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);
                                ../node_modules/nan/nan.h: In function ‘v8::Local v8::scriptNanCompileScript(v8::Localv8::string)’:
                                ../node_modules/nan/nan.h:717:74: warning: ‘static v8::Local v8::scriptv8::ScriptCompiler::Compile(v8::Isol
                                ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Initialize(v8::Handlev8::object)’:
                                ../src/bufferutil.cc:30:52: error: call of overloaded ‘NODE_SET_METHOD(v8::Localv8::functiontemplate&, cons
                                t char [7], void (&)(const v8::FunctionCallbackInfov8::value&))’ is ambiguous
                                NODE_SET_METHOD(t, "unmask", BufferUtil::Unmask);
                                ../src/bufferutil.cc:30:52: note: candidates are:
                                In file included from ../src/bufferutil.cc:8:0:
                                /home/linaro/.node-gyp/6.10.2/include/node/node.h:244:13: note: void node::NODE_SET_METHOD(v8::Local<v8::temp late="">, const char*, v8::FunctionCallback)
                                inline void NODE_SET_METHOD(v8::Local v8::templaterecv,
                                /home/linaro/.node-gyp/6.10.2/include/node/node.h:257:13: note: void node::NODE_SET_METHOD(v8::Local<v8::obje ct="">, const char*, v8::FunctionCallback)
                                inline void NODE_SET_METHOD(v8::Local v8::objectrecv,
                                ../src/bufferutil.cc:31:48: error: call of overloaded ‘NODE_SET_METHOD(v8::Localv8::functiontemplate&, cons
                                t char [5], void (&)(const v8::FunctionCallbackInfov8::value&))’ is ambiguous
                                NODE_SET_METHOD(t, "mask", BufferUtil::Mask);
                                ../src/bufferutil.cc:31:48: note: candidates are:
                                ../src/bufferutil.cc:32:50: error: call of overloaded ‘NODE_SET_METHOD(v8::Localv8::functiontemplate&, cons
                                t char [6], void (&)(const v8::FunctionCallbackInfov8::value&))’ is ambiguous
                                NODE_SET_METHOD(t, "merge", BufferUtil::Merge);
                                ../src/bufferutil.cc:32:50: note: candidates are:
                                bufferutil.target.mk:94: recipe for target 'Release/obj.target/bufferutil/src/bufferutil.o' failed
                                make: *** [Release/obj.target/bufferutil/src/bufferutil.o] Error 1
                                make: Leaving directory '/opt/iobroker/node_modules/bufferutil/build'
                                gyp ERR! build error
                                gyp ERR! stack Error: make failed with exit code: 2
                                3)
                                gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
                                gyp ERR! System Linux 4.4.16
                                gyp ERR! cwd /opt/iobroker/node_modules/bufferutil
                                gyp ERR! node -v v6.10.2
                                gyp ERR! not ok
                                node-mbed-dtls@2.4.4 install /opt/iobroker/node_modules/node-mbed-dtls
                                node-gyp rebuild
                                make: Entering directory '/opt/iobroker/node_modules/node-mbed-dtls/build'
                                CC(target) Release/obj.target/mbedcrypto/mbedtls/library/aes.o
                                CC(target) Release/obj.target/mbedcrypto/mbedtls/library/aesni.o
                                CC(target) Release/obj.target/mbedcrypto/mbedtls/library/arc4.o
                                CC(target) Release/obj.target/mbedcrypto/mbedtls/library/asn1parse.o
                                CC(target) Release/obj.target/mbedcrypto/mbedtls/library/asn1write.o
                                CC(target) Release/obj.target/mbedcrypto/mbedtls/library/base64.o
                                CC(target) Release/obj.target/mbedcrypto/mbedtls/library/bignum.o
                                ../mbedtls/library/bignum.c: In function ‘mpi_mul_hlp’:
                                ../mbedtls/library/bignum.c:1168:1: error: r7 cannot be used in asm here
                                mbedcrypto.target.mk:144: recipe for target 'Release/obj.target/mbedcrypto/mbedtls/library/bignum.o' failed
                                make: *** [Release/obj.target/mbedcrypto/mbedtls/library/bignum.o] Error 1
                                make: Leaving directory '/opt/iobroker/node_modules/node-mbed-dtls/build'
                                3)
                                gyp ERR! cwd /opt/iobroker/node_modules/node-mbed-dtls
                                gyp ERR! not ok
                                iobroker@1.0.0 /opt/iobroker
                                ── (empty)
                                npm WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none was installed.
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 (node_modules/bufferutil):
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 install: node-gyp rebuild
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                                npm ERR! Linux 4.4.16
                                npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "https://github.com/AlCalzone/ioBroker.tradfri" "--p
                                roduction"
                                npm ERR! node v6.10.2
                                npm ERR! npm v3.10.10
                                npm ERR! node-mbed-dtls@2.4.4 install: node-gyp rebuild
                                npm ERR!
                                npm ERR! Please include the following file with any support request:
                                npm ERR! /opt/iobroker/npm-debug.log
                                npm ERR! code 1</v8::object></v8::obje></v8::template></v8::temp></v8::value></v8::functiontemplate></v8::object></v8::obje></v8::template></v8::temp></v8::value></v8::functiontemplate></v8::object></v8::obje></v8::template></v8::temp></v8::value></v8::functiontemplate></v8::object></v8::script></v8::string></v8::script></v8::script></v8::string></v8::script></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></class></class></v8::unboundscript></v8::string></v8::unboundscript></v8:></v8::unboundscript></v8::string></v8::unboundscript></v8:></v8::string></v8::string></v8:></v8::string></v8::string></v8:></v8::script></v8::string></v8::script></v8:></v8::script></v8::string></v8::script></v8:></v8::booleanobject></v8::value></v8::booleanobject></v8:></v8::integer></v8::uint32></v8::uint32></v8::integer></v8::integer></v8::integer></v8::integer></v8::int32></v8::int32></v8::integer></v8::integer></v8::integer>
                                Rainer
                                  han_swurst last edited by Jey Cee
                                  Hallo AlCalzone,
                                  ich hab den Pi nochmal frisch aufgesetzt um alles nochmal durchzuführen und meine Schritte zu dokumentieren.
                                  Also gestartet wird mit nem frischen Pi3, anschließend node und iobroker installieren:
                                  alten node Kram entfernen..
                                  sudo apt-get --purge remove node
                                  sudo apt-get --purge remove nodejs
                                  sudo apt-get autoremove
                                  sudo reboot
                                  Repos für node 6.x einrichten und node 6.10.3 installieren:
                                  curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -
                                  sudo apt-get install -y build-essentials python nodejs
                                  reboot
                                  Verzeichnis für iobroker erstellen und iobroker installieren:
                                  sudo mkdir /opt/iobroker
                                  sudo chmod 777 /opt/iobroker
                                  cd /opt/iobroker
                                  sudo npm install iobroker --unsafe-perm
                                  Beim installieren traten Fehler bei iobroker.discovery auf.
                                  Keine Ahnung ob das für Dein Adapter relevant ist.
                                  Hier mal das Log für die Installation von iobroker
                                  log.txt
                                  git-core und anschließend Deinen Adapter installieren:
                                  sudo npm install https://github.com/AlCalzone/ioBroker.tradfri/tarball/master --production --unsafe-perm 2>&1 | tee tradfri_inst.log
                                  Hier das Log der Installation
                                  log.txt
                                  Adapter instanzieren…
                                  Ausgabe:
                                   host.raspberrypi install adapter tradfri
                                   npm install –production (System call) in "/opt/iobroker/node_modules/iobroker.tradfri"
                                   got /opt/iobroker/node_modules/iobroker.tradfri/admin
                                   upload [2] tradfri.admin /opt/iobroker/node_modules/iobroker.tradfri/admin/words.js words.js application/javascript
                                   upload [1] tradfri.admin /opt/iobroker/node_modules/iobroker.tradfri/admin/tradfri.png tradfri.png image/png
                                   upload [0] tradfri.admin /opt/iobroker/node_modules/iobroker.tradfri/admin/index.html index.html text/html
                                   host.raspberrypi object system.adapter.tradfri created
                                   host.raspberrypi create instance tradfri
                                   host.raspberrypi object system.adapter.tradfri.0.outputCount created
                                   host.raspberrypi object system.adapter.tradfri.0.inputCount created
                                   host.raspberrypi object system.adapter.tradfri.0.uptime created
                                   host.raspberrypi object system.adapter.tradfri.0.memRss created
                                   host.raspberrypi object system.adapter.tradfri.0.memHeapTotal created
                                   host.raspberrypi object system.adapter.tradfri.0.memHeapUsed created
                                   host.raspberrypi object system.adapter.tradfri.0.connected created
                                   host.raspberrypi object system.adapter.tradfri.0.alive created
                                   host.raspberrypi object system.adapter.tradfri.0 created
                                  Eingabe von IP und SecurityCode…
                                  Und leider wieder derselbe Fehler im iobroker Log:
                                  host.raspberrypi	2017-05-11 22:11:28.803	info	Restart adapter system.adapter.tradfri.0 because enabled
                                  host.raspberrypi	2017-05-11 22:11:28.802	error	instance system.adapter.tradfri.0 terminated with code null ()
                                  host.raspberrypi	2017-05-11 22:11:28.802	warn	instance system.adapter.tradfri.0 terminated due to SIGABRT
                                  host.raspberrypi	2017-05-11 22:11:26.334	info	instance system.adapter.tradfri.0 started with pid 4488
                                  host.raspberrypi	2017-05-11 22:10:56.317	info	Restart adapter system.adapter.tradfri.0 because enabled
                                  host.raspberrypi	2017-05-11 22:10:56.316	error	instance system.adapter.tradfri.0 terminated with code null ()
                                  host.raspberrypi	2017-05-11 22:10:56.315	warn	instance system.adapter.tradfri.0 terminated due to SIGABRT
                                  host.raspberrypi	2017-05-11 22:10:53.745	info	instance system.adapter.tradfri.0 started with pid 4478
                                  host.raspberrypi	2017-05-11 22:10:51.290	info	instance system.adapter.tradfri.0 terminated with code 0 (OK)
                                  tradfri.0	2017-05-11 22:10:51.254	info	terminating
                                  host.raspberrypi	2017-05-11 22:10:51.223	info	stopInstance system.adapter.tradfri.0 killing pid 4467
                                  host.raspberrypi	2017-05-11 22:10:51.222	info	stopInstance system.adapter.tradfri.0
                                  host.raspberrypi	2017-05-11 22:10:51.217	info	object change system.adapter.tradfri.0
                                  tradfri.0	2017-05-11 22:06:41.889	info	requesting coap endpoint /15001
                                  tradfri.0	2017-05-11 22:06:41.837	info	starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.tradfri, node: v6.10.3
                                  host.raspberrypi	2017-05-11 22:06:39.392	info	instance system.adapter.tradfri.0 started with pid 4467
                                  host.raspberrypi	2017-05-11 22:06:39.358	info	object change system.adapter.tradfri.0
                                  Was mir noch aufgefallen ist, die Instanz des Adapters terminiert sich sobald sie eine IP konfiguriert hat. Im unkonfiguriertem Zustand, oder wenn die IP gelöscht wird, bleibt die Instanz gestartet.
                                  MfG
                                  Chris
                                  • AlCalzone
                                    @han_swurst:
                                    > mdns@2.3.3 install /opt/iobroker/node_modules/mdns
                                    > node-gyp rebuild
                                    make: Entering directory '/opt/iobroker/node_modules/mdns/build'
                                    CXX(target) Release/obj.target/dns_sd_bindings/src/dns_sd.o
                                    In file included from ../src/dns_sd.cpp:1:0:
                                    ../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
                                    #include <dns_sd.h>
                                    compilation terminated.
                                    dns_sd_bindings.target.mk:149: recipe for target 'Release/obj.target/dns_sd_bindings/src/dns_sd.o' failed
                                    make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
                                    make: Leaving directory '/opt/iobroker/node_modules/mdns/build'</dns_sd.h>
                                    Da haben wir's doch! Ich schau, wie man das beheben/verhindern kann.
                                    • AlCalzone
                                      @Homoran:
                                      Die DTLS-Library scheint hier nicht kompatibel zu sein 😞 Muss ich mal schauen, ob ich ein anderes Paket finde.
                                        ACE76 last edited by
                                        erst einmal vielen Dank an AlCalzone für die Entwicklung dieses Adapters!
                                        Nach stöbern im Thread habe ich es letztendlich geschafft den Tradfri Adapter zu installieren. Nun habe ich allerdings das Problem, dass sich der Adapter scheinbar nicht mit dem Gateway verbindet, obwohl die IP als auch Security Code stimmen. Ich finde einfach den Fehler nicht selbst.
                                        Das Log zeigt die folgende Schleife (IP anonymisiert):
                                        tradfri.0	2017-05-13 00:11:06.844	info	requesting coap endpoint 192.168.XXX.XX/15001
                                        tradfri.0	2017-05-13 00:11:06.820	info	starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.tradfri, node: v4.8.1
                                        tradfri.0	2017-05-13 00:11:06.774	debug	statesDB connected
                                        tradfri.0	2017-05-13 00:11:06.699	debug	objectDB connected
                                        tradfri.0	2017-05-13 00:10:52.588	info	requesting coap endpoint 192.168.XXX.XX/15001
                                        tradfri.0	2017-05-13 00:10:52.564	info	starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.tradfri, node: v4.8.1
                                        tradfri.0	2017-05-13 00:10:52.497	debug	statesDB connected
                                        tradfri.0	2017-05-13 00:10:52.423	debug	objectDB connected
                                        Unter den Objekten werden keine Datenpunkte für die Geräte angelegt. Lediglich eine Instanz.
                                        Hat jemand eine Idee woran dies liegen könnte? Falls ich noch etwas anderes beisteuern kann zur Fehlerfindung bitte ich um Hinweis.
                                        PS:
                                        @han_swurst:
                                        Was mir noch aufgefallen ist, die Instanz des Adapters terminiert sich sobald sie eine IP konfiguriert hat. Im unkonfiguriertem Zustand, oder wenn die IP gelöscht wird, bleibt die Instanz gestartet. `
                                        Gerade noch diesen Post gesehen und überprüft. Ist bei mir genau so. Ändert aber nichts daran, dass kein Ordner angelegt wird mit den Geräten.
                                          @AlCalzone:
                                          @han_swurst:
                                          > node-gyp rebuild
                                          #include <dns_sd.h>
                                          Da haben wir's doch! Ich schau, wie man das beheben/verhindern kann. `
                                          Das ist nicht das Problem. Da fehlen ein nur ein paar Abhängigkeiten für mdns.
                                          Ein apt-get install libavahi-compat-libdnssd-dev behebt den Fehler beim Installieren von mdns.
                                          Ich hab auch schon libcoap installiert bzw. kompiliert. Aber auch damit bringt der Adapter den bekannten Fehler.
                                          Nochwas:
                                          Ich weiß nicht obs Dir beim Fehler suchen hilft, aber der Adapter schmiert nur ab, wenn man die IP vom Ikea-Gateway eingibt.
                                          MfG
                                          Chris
                                          • AlCalzone
                                            Danke für die zahlreichen Infos. Ich kann noch nichts versprechen, da ich aktuell nicht viel Zeit habe, aber ich versuche im Laufe der Woche nachzuvollziehen, was da bei euch schief läuft.
                                            Dass keine Objekte angelegt werden, ist zu erwarten, da der Adapter keine Verbindung herstellt. Die Objekte sollten bei erfolgreicher Verbindung angelegt werden.
                                            Update: Ich kann euer Problem mittlerweile reproduzieren. Bei Ausführung über Konsole gibt es weitere Infos:
                                            io.tradfri.0: ../../nan/nan.h:704: Nan::MaybeLocal <v8::object>Nan::CopyBuffer(const char*, uint32_t): Assertion `size <= imp::kMaxLength && "too large buffer"' failed.</v8::object>
                                            Wenn ich jetzt noch wüsste, warum das vorher bei mir funktioniert hat…
                                            471
                                            103493
