    4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
      TobiasF78 @Thomas Braun last edited by
      das log zum Start des Reinigungsvorgangs
      2022-04-07 20:11:03.686 - debug: mihome-vacuum.0 (17152) Receive <<< Helo <<< 21310020000000001317ff30624f2938ffffffffffffffffffffffffffffffff
      2022-04-07 20:11:03.687 - debug: mihome-vacuum.0 (17152) Time difference between Mihome Vacuum and ioBroker: 1 sec
      2022-04-07 20:11:13.690 - debug: mihome-vacuum.0 (17152) Receive <<< Helo <<< 21310020000000001317ff30624f2942ffffffffffffffffffffffffffffffff
      2022-04-07 20:11:13.691 - debug: mihome-vacuum.0 (17152) Time difference between Mihome Vacuum and ioBroker: 1 sec
      2022-04-07 20:11:17.217 - debug: mihome-vacuum.0 (17152) get params for stock Vacuum
      2022-04-07 20:11:17.219 - debug: mihome-vacuum.0 (17152) Message= {"id":69,"method":"get_status"}
      2022-04-07 20:11:17.228 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":3477,"state":18,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":101,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0}],"id":69}
      2022-04-07 20:11:17.233 - debug: mihome-vacuum.0 (17152) setGetStatus {"msg_ver":2,"msg_seq":3477,"state":18,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":101,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"error_text":"No error"}
      2022-04-07 20:11:17.237 - debug: mihome-vacuum.0 (17152) Message= {"id":70,"method":"get_map_v1"}
      2022-04-07 20:11:17.239 - debug: mihome-vacuum.0 (17152) Message= {"id":71,"method":"get_network_info"}
      2022-04-07 20:11:17.254 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":["retry"],"id":70}
      2022-04-07 20:11:17.266 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":{"ssid":"froehlich.unifi","ip":"192.168.229.31","mac":"64:90:c1:01:fb:13","bssid":"4a:d9:e7:fa:7f:d0","rssi":-49},"id":71}
      2022-04-07 20:11:17.382 - debug: mihome-vacuum.0 (17152) Message= {"id":72,"method":"get_sound_volume"}
      2022-04-07 20:11:17.388 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":[30],"id":72}
      2022-04-07 20:11:17.389 - debug: mihome-vacuum.0 (17152) Message= {"id":73,"method":"get_carpet_mode"}
      2022-04-07 20:11:17.395 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":73}
      2022-04-07 20:11:17.557 - debug: mihome-vacuum.0 (17152) Message= {"id":74,"method":"get_map_v1"}
      2022-04-07 20:11:17.563 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":["retry"],"id":74}
      2022-04-07 20:11:17.866 - debug: mihome-vacuum.0 (17152) Message= {"id":75,"method":"get_map_v1"}
      2022-04-07 20:11:17.871 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":["retry"],"id":75}
      2022-04-07 20:11:18.172 - debug: mihome-vacuum.0 (17152) Message= {"id":76,"method":"get_map_v1"}
      2022-04-07 20:11:18.179 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":["retry"],"id":76}
      2022-04-07 20:11:18.480 - debug: mihome-vacuum.0 (17152) Message= {"id":77,"method":"get_map_v1"}
      2022-04-07 20:11:18.488 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":["retry"],"id":77}
      2022-04-07 20:11:20.165 - info: javascript.0 (4683) script.js.Rollläden.Helligkeit_Durchschnittswert: [15,17,20,23,26,30,34,39,44,50,57,65,73,83,94,106,119,134,151,170,191,215,245,275,309,275,313,353,399,350]
      2022-04-07 20:11:20.189 - debug: shuttercontrol.0 (1726) Lightsensor changed: 0_userdata.0.Rollladen.Helligkeit_Durchschnitt Value: 143
      2022-04-07 20:11:20.791 - debug: mihome-vacuum.0 (17152) Get Mappointer while cleaning
      2022-04-07 20:11:20.792 - debug: mihome-vacuum.0 (17152) Message= {"id":78,"method":"get_map_v1"}
      2022-04-07 20:11:20.800 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":["rubyslite%2F320339760%2F0"],"id":78}
      2022-04-07 20:11:20.801 - debug: mihome-vacuum.0 (17152) Mappointer_updated
      2022-04-07 20:11:20.804 - debug: mihome-vacuum.0 (17152) update_Map Mimap enabled
      2022-04-07 20:11:20.805 - debug: mihome-vacuum.0 (17152) update_Map need new mapurl
      2022-04-07 20:11:21.030 - debug: mihome-vacuum.0 (17152) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320339760/0?Expires=1649356881000&GalaxyAccessKeyId=5271733786445&Signature=JkhvPTmkB1NFoq+B3JmwCidC99E=
      2022-04-07 20:11:21.030 - debug: mihome-vacuum.0 (17152) update_Map got new expires:1649356881
      2022-04-07 20:11:21.031 - debug: mihome-vacuum.0 (17152) update_Map got new time:1649355080
      2022-04-07 20:11:21.538 - debug: mihome-vacuum.0 (17152) 25609
      2022-04-07 20:11:23.696 - debug: mihome-vacuum.0 (17152) Receive <<< Helo <<< 21310020000000001317ff30624f294cffffffffffffffffffffffffffffffff
      2022-04-07 20:11:23.697 - debug: mihome-vacuum.0 (17152) Time difference between Mihome Vacuum and ioBroker: 1 sec
      2022-04-07 20:11:24.575 - debug: mihome-vacuum.0 (17152) Get Mappointer while cleaning
      2022-04-07 20:11:24.576 - debug: mihome-vacuum.0 (17152) Message= {"id":79,"method":"get_map_v1"}
      2022-04-07 20:11:24.583 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":["rubyslite%2F320339760%2F3"],"id":79}
      2022-04-07 20:11:24.584 - debug: mihome-vacuum.0 (17152) Mappointer_updated
      2022-04-07 20:11:24.584 - debug: mihome-vacuum.0 (17152) update_Map Mimap enabled
      2022-04-07 20:11:24.585 - debug: mihome-vacuum.0 (17152) update_Map need new mapurl
      2022-04-07 20:11:24.754 - debug: mihome-vacuum.0 (17152) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320339760/3?Expires=1649356884000&GalaxyAccessKeyId=5271733786445&Signature=JeC2mvYHId0bO95JgWd8AJHM5ig=
      2022-04-07 20:11:24.755 - debug: mihome-vacuum.0 (17152) update_Map got new expires:1649356884
      2022-04-07 20:11:24.757 - debug: mihome-vacuum.0 (17152) update_Map got new time:1649355084
      2022-04-07 20:11:25.368 - debug: mihome-vacuum.0 (17152) 25751
      2022-04-07 20:11:27.898 - debug: mihome-vacuum.0 (17152) Get Mappointer while cleaning
      2022-04-07 20:11:27.899 - debug: mihome-vacuum.0 (17152) Message= {"id":80,"method":"get_map_v1"}
      2022-04-07 20:11:27.906 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":["rubyslite%2F320339760%2F4"],"id":80}
      2022-04-07 20:11:27.907 - debug: mihome-vacuum.0 (17152) Mappointer_updated
      2022-04-07 20:11:27.907 - debug: mihome-vacuum.0 (17152) update_Map Mimap enabled
      2022-04-07 20:11:27.907 - debug: mihome-vacuum.0 (17152) update_Map need new mapurl
      2022-04-07 20:11:28.059 - debug: mihome-vacuum.0 (17152) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320339760/4?Expires=1649356888000&GalaxyAccessKeyId=5271733786445&Signature=pxITU76k0a7x/gZU3EzewZ3Akwo=
      2022-04-07 20:11:28.059 - debug: mihome-vacuum.0 (17152) update_Map got new expires:1649356888
      2022-04-07 20:11:28.060 - debug: mihome-vacuum.0 (17152) update_Map got new time:1649355087
      2022-04-07 20:11:28.629 - debug: mihome-vacuum.0 (17152) 25909
      2022-04-07 20:11:28.864 - warn: host.SmarthomeRaspi instance system.adapter.mihome-vacuum.0 terminated due to SIGSEGV
      2022-04-07 20:11:28.865 - info: host.SmarthomeRaspi instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
      2022-04-07 20:11:28.865 - info: host.SmarthomeRaspi Restart adapter system.adapter.mihome-vacuum.0 because enabled
      2022-04-07 20:11:40.493 - info: unifi.0 (2213) State value to set for "unifi.0.default.clients.ae:2d:74:9e:b6:86.noted" has to be type "boolean" but received type "string"
      2022-04-07 20:11:40.621 - info: unifi.0 (2213) State value to set for "unifi.0.default.clients.94:e7:0b:61:00:58.noted" has to be type "boolean" but received type "string"
      2022-04-07 20:11:51.834 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0019DA49A70E58:0,CONFIG_PENDING,false
      2022-04-07 20:11:51.834 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0019DA49A70E58:0","CONFIG_PENDING",false]
      2022-04-07 20:11:51.834 - debug: hm-rpc.1 (1169) hm-rpc.1.0019DA49A70E58.0.CONFIG_PENDING ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
      2022-04-07 20:11:51.835 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0019DA49A70E58:0,RSSI_DEVICE,-72
      2022-04-07 20:11:51.835 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0019DA49A70E58:0","RSSI_DEVICE",-72]
      2022-04-07 20:11:51.835 - debug: hm-rpc.1 (1169) hm-rpc.1.0019DA49A70E58.0.RSSI_DEVICE ==> UNIT: "undefined" (min: -128, max: 127) From "-72" => "-72"
      2022-04-07 20:11:51.835 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0019DA49A70E58:0,DUTY_CYCLE,false
      2022-04-07 20:11:51.835 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0019DA49A70E58:0","DUTY_CYCLE",false]
      2022-04-07 20:11:51.836 - debug: hm-rpc.1 (1169) hm-rpc.1.0019DA49A70E58.0.DUTY_CYCLE ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
      2022-04-07 20:11:51.836 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0019DA49A70E58:0,UNREACH,false
      2022-04-07 20:11:51.836 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0019DA49A70E58:0","UNREACH",false]
      2022-04-07 20:11:51.836 - debug: hm-rpc.1 (1169) hm-rpc.1.0019DA49A70E58.0.UNREACH ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
      2022-04-07 20:11:53.009 - debug: hm-rpc.0 (1147) xml multicall : SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777,NEQ0862527:1,BOOT,false
      2022-04-07 20:11:53.010 - debug: hm-rpc.0 (1147) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777","NEQ0862527:1","BOOT",false]
      2022-04-07 20:11:53.011 - debug: hm-rpc.0 (1147) hm-rpc.0.NEQ0862527.1.BOOT ==> UNIT: "" (min: undefined, max: undefined) From "false" => "false"
      2022-04-07 20:11:53.012 - debug: hm-rpc.0 (1147) xml multicall : SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777,NEQ0862527:1,ENERGY_COUNTER,562640
      2022-04-07 20:11:53.013 - debug: hm-rpc.0 (1147) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777","NEQ0862527:1","ENERGY_COUNTER",562640]
      2022-04-07 20:11:53.013 - debug: hm-rpc.0 (1147) hm-rpc.0.NEQ0862527.1.ENERGY_COUNTER ==> UNIT: "Wh" (min: 0, max: 838860.7) From "562640" => "562640"
      2022-04-07 20:11:53.014 - debug: hm-rpc.0 (1147) xml multicall : SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777,NEQ0862527:1,POWER,252
      2022-04-07 20:11:53.015 - debug: hm-rpc.0 (1147) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777","NEQ0862527:1","POWER",252]
      2022-04-07 20:11:53.016 - debug: hm-rpc.0 (1147) hm-rpc.0.NEQ0862527.1.POWER ==> UNIT: "W" (min: 0, max: 167772.15) From "252" => "252"
      2022-04-07 20:11:59.312 - info: host.SmarthomeRaspi instance system.adapter.mihome-vacuum.0 started with pid 17390
      2022-04-07 20:12:00.918 - debug: mihome-vacuum.0 (17390) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2022-04-07 20:12:00.999 - debug: mihome-vacuum.0 (17390) Objects client ready ... initialize now
      2022-04-07 20:12:01.002 - debug: mihome-vacuum.0 (17390) Objects create System PubSub Client
      2022-04-07 20:12:01.003 - debug: mihome-vacuum.0 (17390) Objects create User PubSub Client
      2022-04-07 20:12:01.153 - debug: mihome-vacuum.0 (17390) Objects client initialize lua scripts
      2022-04-07 20:12:01.160 - debug: mihome-vacuum.0 (17390) Objects connected to redis: 127.0.0.1:9001
      2022-04-07 20:12:01.227 - debug: mihome-vacuum.0 (17390) Redis States: Use Redis connection: 127.0.0.1:9000
      2022-04-07 20:12:01.269 - debug: mihome-vacuum.0 (17390) States create System PubSub Client
      2022-04-07 20:12:01.271 - debug: mihome-vacuum.0 (17390) States create User PubSub Client
      2022-04-07 20:12:01.358 - debug: mihome-vacuum.0 (17390) States connected to redis: 127.0.0.1:9000
      2022-04-07 20:12:01.640 - debug: mihome-vacuum.0 (17390) Plugin sentry Initialize Plugin (enabled=true)
      2022-04-07 20:12:02.117 - info: mihome-vacuum.0 (17390) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.19.1, js-controller: 4.0.21
      2022-04-07 20:12:02.207 - debug: mihome-vacuum.0 (17390) load Map creator... true
      2022-04-07 20:12:02.240 - debug: mihome-vacuum.0 (17390) Create State for deviceInfo
      2022-04-07 20:12:02.241 - debug: mihome-vacuum.0 (17390) Create State for deviceInfomac
      2022-04-07 20:12:02.241 - debug: mihome-vacuum.0 (17390) Create State for deviceInfomodel
      2022-04-07 20:12:02.242 - debug: mihome-vacuum.0 (17390) Create State for deviceInfofw_ver
      2022-04-07 20:12:02.243 - debug: mihome-vacuum.0 (17390) Create State for deviceInfowifi_signal
      2022-04-07 20:12:02.244 - debug: mihome-vacuum.0 (17390) MIIO: Config: ip:192.168.229.31 token: 6a62485744456c466c766f6d45535473
      2022-04-07 20:12:02.248 - info: mihome-vacuum.0 (17390) IOT enabled, create state
      2022-04-07 20:12:02.253 - debug: mihome-vacuum.0 (17390) server started on 0.0.0.0:53421
      2022-04-07 20:12:02.262 - debug: mihome-vacuum.0 (17390) Receive <<< Helo <<< 21310020000000001317ff30624f2972ffffffffffffffffffffffffffffffff
      2022-04-07 20:12:02.263 - debug: mihome-vacuum.0 (17390) MAIN: Connected to device, try to get model..
      2022-04-07 20:12:02.270 - debug: mihome-vacuum.0 (17390) GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.s5e","ack":true,"ts":1649354893615,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1649165771511}
      2022-04-07 20:12:02.272 - debug: mihome-vacuum.0 (17390) Message= {"id":1,"method":"miIO.info"}
      2022-04-07 20:12:02.280 - debug: mihome-vacuum.0 (17390) MIIO RECIVE: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_1566","ap":{"ssid":"froehlich.unifi","bssid":"4a:d9:e7:fa:7f:d0","rssi":-48},"netif":{"localIp":"192.168.229.31","mask":"255.255.255.0","gw":"192.168.229.1"},"miio_ver":"miio-client 3.5.8","model":"roborock.vacuum.s5e","mac":"64:90:C1:01:FB:13","token":"6a62485744456c466c766f6d45535473","life":59894}}
      2022-04-07 20:12:02.281 - debug: mihome-vacuum.0 (17390) GETMODELFROMAPI:Data: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_1566","ap":{"ssid":"froehlich.unifi","bssid":"4a:d9:e7:fa:7f:d0","rssi":-48},"netif":{"localIp":"192.168.229.31","mask":"255.255.255.0","gw":"192.168.229.1"},"miio_ver":"miio-client 3.5.8","model":"roborock.vacuum.s5e","mac":"64:90:C1:01:FB:13","token":"6a62485744456c466c766f6d45535473","life":59894}}
      2022-04-07 20:12:02.281 - debug: mihome-vacuum.0 (17390) Get Device data..0
      2022-04-07 20:12:02.282 - debug: mihome-vacuum.0 (17390) Get Device data from robot..
      2022-04-07 20:12:02.356 - debug: mihome-vacuum.0 (17390) DeviceModel selected to: roborock.vacuum.s5e
      2022-04-07 20:12:02.358 - info: mihome-vacuum.0 (17390) select standard vacuum protocol....
      2022-04-07 20:12:02.364 - debug: mihome-vacuum.0 (17390) Xiaomi Cloud: Logging in
      2022-04-07 20:12:02.430 - debug: mihome-vacuum.0 (17390) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
      2022-04-07 20:12:02.671 - debug: mihome-vacuum.0 (17390) Login step1: &&&START&&&{"serviceParam":"{\"checkSafePhone\":false,\"checkSafeAddress\":false,\"lsrp_score\":0.0}","qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"description":"登录验证失败","securityStatus":0,"_sign":"0psXfr43eNI0IX6q9Suk3qWbRqU=","sid":"xiaomiio","result":"error","captchaUrl":null,"callback":"https://sts.api.io.mi.com/sts","location":"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=","pwd":0,"desc":"登录验证失败"}
      2022-04-07 20:12:02.948 - debug: mihome-vacuum.0 (17390) Login step2: &&&START&&&{"qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","ssecurity":"tE7q7k02rgKQ42yy2WalqA==","code":0,"passToken":"V1:DXmurwq2/R1BHTELu6obCXvd/vywyWq/UW16QZKE2LY36WsipSmLX8xvdc9l4OQkwWYESIe+Rc2goHwDTHdGYGBJKS+Vnufh9+l/x+Gdlr8m8Vzva4JSnhMtAcOnzTCXZnvZCqxjqLueX5qS0HeAtHdHLcIxgIMJquyX9PuPJCqYaIMpCRhCPzC7tLG5dMVoYGZBkjWt6p+HYlkkuPlDUrXZ/MQUNu3UFWFRjUm/zJj92wwKldCgRNOJTBTe+YhWPM/AhoND4EJ8vymQOkCnmFTdbvAfpe/yO+7FrM/0jyQ=","description":"成功","securityStatus":0,"nonce":5937468700529491968,"userId":8161011682,"cUserId":"d7BvRzpJp2fIp_BmYH4fXAU23E8","result":"ok","psecurity":"SLnzQYnjD1y92+AtNj1WIA==","captchaUrl":null,"location":"https://sts.api.io.mi.com/sts?d=hcvyd&ticket=0&pwd=1&p_ts=1649355122000&fid=0&p_lm=1&auth=EIZ7Zp2Kjae53RtQ1qPkDDdDyYz%2B%2B%2BLPCf35MeIhU%2BDPuJ7g3zbcoUrpIKZpX9Hb9XMNIDfW5LX45JH%2FUZLyO8POuYUg7x2Bn49fd6vuJkNR9pH9tdOwOEfsP9nOwaaA6fbAvQW8KUWnLcQSsOzopEdWXUBtT340qhGEWsuKdlw%3D&m=1&tsl=0&nonce=3aPnnH6vLo0Bo3Pk&_ssign=OvZlP59LAGWExkueSkOSI5HqXGU%3D","pwd":1,"desc":"成功"}
      2022-04-07 20:12:03.141 - info: mihome-vacuum.0 (17390) settest next timer: not available
      2022-04-07 20:12:03.279 - debug: mihome-vacuum.0 (17390) Login step3: [{"key":"userId","value":"8161011682","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-04-07T18:12:03.250Z","lastAccessed":"2022-04-07T18:12:03.278Z"},{"key":"cUserId","value":"d7BvRzpJp2fIp_BmYH4fXAU23E8","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-04-07T18:12:03.264Z","lastAccessed":"2022-04-07T18:12:03.278Z"},{"key":"serviceToken","value":"pE4bcLhDVytuM1iPXebrZ6dawOhvMI6QrHgeacnK/IrLVvbWt8PtRK2CBnZ/y6F6SctDx7G6lg2nN3V+ofLBhZdoyrAz0Li4CctGekhhu04aKOHlS5kzgukNiRolAoxADIopSqiTlcFY76PCK41ARVw1QrvNnrvajb9pGkRQTgo=","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-04-07T18:12:03.270Z","lastAccessed":"2022-04-07T18:12:03.278Z"}]
      2022-04-07 20:12:03.280 - debug: mihome-vacuum.0 (17390) Xiaomi Cloud: Login successful
      2022-04-07 20:12:03.301 - debug: mihome-vacuum.0 (17390) Create State for Queue: queue
      2022-04-07 20:12:03.302 - debug: mihome-vacuum.0 (17390) Create State for Queue: clearQueue
      2022-04-07 20:12:03.306 - info: mihome-vacuum.0 (17390) Map selected create states...
      2022-04-07 20:12:03.309 - debug: mihome-vacuum.0 (17390) Create State for map:
      2022-04-07 20:12:03.310 - debug: mihome-vacuum.0 (17390) Create State for map: map64
      2022-04-07 20:12:03.311 - debug: mihome-vacuum.0 (17390) Create State for map: actualMap
      2022-04-07 20:12:03.313 - debug: mihome-vacuum.0 (17390) Create State for map: mapStatus
      2022-04-07 20:12:03.314 - debug: mihome-vacuum.0 (17390) Create State for map: mapURL
      2022-04-07 20:12:03.315 - debug: mihome-vacuum.0 (17390) Create State for map: loadMap
      2022-04-07 20:12:03.315 - debug: mihome-vacuum.0 (17390) Create State done!
      2022-04-07 20:12:03.316 - debug: mihome-vacuum.0 (17390) get params for stock Vacuum
      2022-04-07 20:12:03.317 - debug: mihome-vacuum.0 (17390) Message= {"id":2,"method":"get_status"}
      2022-04-07 20:12:03.326 - debug: mihome-vacuum.0 (17390) MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":3481,"state":18,"battery":100,"clean_time":51,"clean_area":1615000,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":101,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0}],"id":2}
      2022-04-07 20:12:03.327 - debug: mihome-vacuum.0 (17390) setGetStatus {"msg_ver":2,"msg_seq":3481,"state":18,"battery":100,"clean_time":51,"clean_area":1615000,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":101,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"error_text":"No error"}
      2022-04-07 20:12:03.328 - info: mihome-vacuum.0 (17390) change states from State control.fan_power
      2022-04-07 20:12:03.342 - info: mihome-vacuum.0 (17390) create states for water box
      2022-04-07 20:12:03.345 - info: mihome-vacuum.0 (17390) create states for water box mode
      2022-04-07 20:12:03.348 - info: mihome-vacuum.0 (17390) create states for mop
      2022-04-07 20:12:03.419 - debug: mihome-vacuum.0 (17390) Message= {"id":3,"method":"get_map_v1"}
      2022-04-07 20:12:03.426 - debug: mihome-vacuum.0 (17390) MIIO RECIVE: {"result":["retry"],"id":3}
      2022-04-07 20:12:03.728 - debug: mihome-vacuum.0 (17390) Message= {"id":4,"method":"get_map_v1"}
      2022-04-07 20:12:03.736 - debug: mihome-vacuum.0 (17390) MIIO RECIVE: {"result":["rubyslite%2F320339760%2F6"],"id":4}
      2022-04-07 20:12:03.738 - debug: mihome-vacuum.0 (17390) Mappointer_updated
      2022-04-07 20:12:03.740 - debug: mihome-vacuum.0 (17390) update_Map Mimap enabled
      2022-04-07 20:12:03.741 - debug: mihome-vacuum.0 (17390) update_Map need new mapurl
      2022-04-07 20:12:03.753 - debug: mihome-vacuum.0 (17390) Message= {"id":5,"method":"get_room_mapping"}
      2022-04-07 20:12:03.765 - debug: mihome-vacuum.0 (17390) MIIO RECIVE: {"result":[[20,"281001038309"],[16,"281001038371"],[17,"281001038308"],[18,"281001038310"],[19,"281001038295"]],"id":5}
      2022-04-07 20:12:03.769 - debug: mihome-vacuum.0 (17390) Message= {"id":6,"method":"get_map_v1"}
      2022-04-07 20:12:03.771 - debug: mihome-vacuum.0 (17390) Message= {"id":7,"method":"get_network_info"}
      2022-04-07 20:12:03.779 - debug: mihome-vacuum.0 (17390) MIIO RECIVE: {"result":["rubyslite%2F320339760%2F6"],"id":6}
      2022-04-07 20:12:03.780 - debug: mihome-vacuum.0 (17390) Mappointer_updated
      2022-04-07 20:12:03.782 - debug: mihome-vacuum.0 (17390) update_Map Mimap enabled
      2022-04-07 20:12:03.782 - debug: mihome-vacuum.0 (17390) update_Map need new mapurl
      2022-04-07 20:12:03.831 - debug: mihome-vacuum.0 (17390) MIIO RECIVE: {"result":{"ssid":"froehlich.unifi","ip":"192.168.229.31","mac":"64:90:c1:01:fb:13","bssid":"4a:d9:e7:fa:7f:d0","rssi":-49},"id":7}
      2022-04-07 20:12:03.911 - debug: mihome-vacuum.0 (17390) Message= {"id":8,"method":"get_sound_volume"}
      2022-04-07 20:12:03.917 - debug: mihome-vacuum.0 (17390) MIIO RECIVE: {"result":[30],"id":8}
      2022-04-07 20:12:03.918 - debug: mihome-vacuum.0 (17390) Message= {"id":9,"method":"get_multi_maps_list"}
      2022-04-07 20:12:03.925 - debug: mihome-vacuum.0 (17390) MIIO RECIVE: {"result":[{"max_multi_map":1,"max_bak_map":0,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1645100692,"length":0,"name":"","bak_maps":[]}]}],"id":9}
      2022-04-07 20:12:03.926 - debug: mihome-vacuum.0 (17390) States for 1 Map: [{"mapFlag":0,"add_time":1645100692,"length":0,"name":"","bak_maps":[]}]
      2022-04-07 20:12:03.927 - debug: mihome-vacuum.0 (17390) States for Map: {"0":"0"}
      2022-04-07 20:12:03.929 - debug: mihome-vacuum.0 (17390) Startup: getMultiMapsList Answer: true
      2022-04-07 20:12:03.930 - debug: mihome-vacuum.0 (17390) Startup: Delete getMultiMapsList
      2022-04-07 20:12:03.931 - debug: mihome-vacuum.0 (17390) Message= {"id":10,"method":"get_clean_summary"}
      2022-04-07 20:12:03.941 - error: mihome-vacuum.0 (17390) Error when receiving map url: ,q^QzuH \I87*XacZYDi&9_2@%ELks>]lIB H,QK`w\u_G?201k #r':="" mihome-vacuum.0="" (17390)="" map="" error:syntaxerror:="" unexpected="" token="" ,="" in="" json="" at="" position="" 0="" 20:12:03.944="" debug:="" xiaomi="" cloud:="" logging="" 20:12:03.949="" update_map="" got="" new="" url:https:="" awsde0.fds.api.xiaomi.com="" robomap="" rubyslite="" 320339760="" 6?expires="1649356923000&GalaxyAccessKeyId=5271733786445&Signature=ejbVApzz4Rfo8K+C66r9MfbH7FA=" 20:12:03.950="" expires:1649356923="" 20:12:03.951="" time:1649355123="" 20:12:03.969="" miio="" recive:="" {"result":[137508,2615415000,262,[1649354396,1649353781,1649347353,1649345161,1649344894,1649340240,1649247640,1649166646,1649165186,1649164160,1649163821,1649160739,1649159455,1649158426,1649154359,1649153775,1649152468,1649151540,1649148317,1649146933]],"id":10}="" 20:12:03.971="" message="{"id":11,"method":"get_clean_record","params":[1649354396]}" 20:12:03.979="" {"result":[[1649354396,1649354851,212,7417500,0,0,2,3,60]],"id":11}="" 20:12:03.981="" 20:12:03.991="" {"result":[[1649353781,1649353821,36,647500,0,0,2,3,60]],"id":12}="" 20:12:03.993="" 20:12:04.001="" {"result":[[1649347353,1649347937,580,12275000,0,0,2,3,60]],"id":13}="" 20:12:04.002="" 20:12:04.010="" {"result":[[1649345161,1649345243,10,0,0,0,2,3,60]],"id":14}="" 20:12:04.012="" 20:12:04.019="" {"result":[[1649344894,1649345083,10,0,0,0,2,3,60]],"id":15}="" 20:12:04.020="" 20:12:04.026="" {"result":[[1649340240,1649341269,1029,19720000,0,1,2,3,56]],"id":16}="" 20:12:04.027="" 20:12:04.033="" {"result":[[1649247640,1649248754,1114,20080000,0,1,2,3,56]],"id":17}="" 20:12:04.034="" 20:12:04.040="" {"result":[[1649166646,1649166833,183,5045000,0,0,2,3,60]],"id":18}="" 20:12:04.041="" 20:12:04.048="" {"result":[[1649165186,1649166304,89,1582500,0,0,2,3,60]],"id":19}="" 20:12:04.058="" {"result":[[1649164160,1649164352,188,5327500,0,0,2,3,60]],"id":20}="" 20:12:04.059="" 20:12:04.065="" {"result":[[1649163821,1649163939,118,1637500,0,1,2,3,56]],"id":21}="" 20:12:04.066="" 20:12:04.073="" {"result":[[1649160739,1649160785,42,910000,0,0,2,3,60]],"id":22}="" 20:12:04.075="" 20:12:04.083="" {"result":[[1649159455,1649159580,125,1657500,0,1,2,3,56]],"id":23}="" 20:12:04.084="" 20:12:04.093="" {"result":[[1649158426,1649158524,94,3512500,0,0,2,3,60]],"id":24}="" 20:12:04.094="" 20:12:04.100="" {"result":[[1649154359,1649154901,542,10960000,0,1,2,3,56]],"id":25}="" 20:12:04.101="" 20:12:04.110="" {"result":[[1649153775,1649153893,118,1577500,0,1,2,3,56]],"id":26}="" 20:12:04.111="" 20:12:04.116="" {"result":[[1649152468,1649152670,198,5975000,0,0,2,3,60]],"id":27}="" 20:12:04.118="" 20:12:04.124="" {"result":[[1649151540,1649151651,111,1605000,0,1,2,3,56]],"id":28}="" 20:12:04.125="" 20:12:04.131="" {"result":[[1649148317,1649148868,356,9850000,0,0,2,3,60]],"id":29}="" 20:12:04.132="" 20:12:04.138="" {"result":[[1649146933,1649147053,120,1755000,0,1,2,3,56]],"id":30}="" 20:12:04.139="" finish="" logs="" all="" [{"datum":"7.4","start":"19:59","saugzeit":"4="" min","fläche":"7.42="" m²","error":0,"ende":false},{"datum":"7.4","start":"19:49","saugzeit":"1="" min","fläche":"0.65="" m²","error":0,"ende":false},{"datum":"7.4","start":"18:02","saugzeit":"10="" min","fläche":"12.28="" m²","error":0,"ende":false},{"datum":"7.4","start":"17:26","saugzeit":"0="" min","fläche":"0="" m²","error":0,"ende":false},{"datum":"7.4","start":"17:21","saugzeit":"0="" m²","error":0,"ende":false},{"datum":"7.4","start":"16:04","saugzeit":"17="" min","fläche":"19.72="" m²","error":0,"ende":true},{"datum":"6.4","start":"14:20","saugzeit":"19="" min","fläche":"20.08="" m²","error":0,"ende":true},{"datum":"5.4","start":"15:50","saugzeit":"3="" min","fläche":"5.05="" m²","error":0,"ende":false},{"datum":"5.4","start":"15:26","saugzeit":"1="" min","fläche":"1.58="" m²","error":0,"ende":false},{"datum":"5.4","start":"15:09","saugzeit":"3="" min","fläche":"5.33="" m²","error":0,"ende":false},{"datum":"5.4","start":"15:03","saugzeit":"2="" min","fläche":"1.64="" m²","error":0,"ende":true},{"datum":"5.4","start":"14:12","saugzeit":"1="" min","fläche":"0.91="" m²","error":0,"ende":false},{"datum":"5.4","start":"13:50","saugzeit":"2="" min","fläche":"1.66="" m²","error":0,"ende":true},{"datum":"5.4","start":"13:33","saugzeit":"2="" min","fläche":"3.51="" m²","error":0,"ende":false},{"datum":"5.4","start":"12:25","saugzeit":"9="" min","fläche":"10.96="" m²","error":0,"ende":true},{"datum":"5.4","start":"12:16","saugzeit":"2="" m²","error":0,"ende":true},{"datum":"5.4","start":"11:54","saugzeit":"3="" min","fläche":"5.98="" m²","error":0,"ende":false},{"datum":"5.4","start":"11:39","saugzeit":"2="" min","fläche":"1.61="" m²","error":0,"ende":true},{"datum":"5.4","start":"10:45","saugzeit":"6="" min","fläche":"9.85="" m²","error":0,"ende":false},{"datum":"5.4","start":"10:22","saugzeit":"2="" min","fläche":"1.76="" m²","error":0,"ende":true}]="" 20:12:04.141="" startup:="" setgetcleansummary="" answer:="" true="" delete="" 20:12:04.142="" 20:12:04.150="" {"result":[{"main_brush_work_time":137508,"side_brush_work_time":137508,"filter_work_time":137508,"filter_element_work_time":11733,"sensor_dirty_time":28763}],"id":31}="" 20:12:04.152="" setgetconsumable="" 20:12:04.153="" 20:12:04.154="" 20:12:04.171="" {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":32}="" 20:12:04.172="" info:="" create="" state="" for="" carpet_mode="" 20:12:04.173="" 20:12:04.183="" login="" step1:="" &&&start&&&{"serviceparam":"{\"checksafephone\":false,\"checksafeaddress\":false,\"lsrp_score\":0.0}","qs":"%3fsid%3dxiaomiio%26_json%3dtrue","code":70016,"description":"登录验证失败","securitystatus":0,"_sign":"0psxfr43eni0ix6q9suk3qwbrqu="," sid":"xiaomiio","result":"error","captchaurl":null,"callback":"https:="" sts.api.io.mi.com="" sts","location":"https:="" account.xiaomi.com="" fe="" service="" login?_json="true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=","pwd":0,"desc":"登录验证失败"}" 20:12:04.187="" {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":33}="" 20:12:04.511="" 26984="" 20:12:04.679="" host.smarthomeraspi="" instance="" system.adapter.mihome-vacuum.0="" terminated="" due="" to="" sigsegv="" 20:12:04.680="" with="" code="" nan="" ()="" restart="" adapter="" because="" enabled="" 20:12:09.889="" javascript.0="" (4683)="" script.js.rollläden.helligkeit_durchschnittswert:="" [13,15,17,20,23,26,30,34,39,44,50,57,65,73,83,94,106,119,134,151,170,191,215,245,275,309,275,313,353,399]="" 20:12:09.898="" shuttercontrol.0="" (1726)="" lightsensor="" changed:="" 0_userdata.0.rollladen.helligkeit_durchschnitt="" value:="" 131="" 20:12:20.782="" hm-rpc.0="" (1147)="" [keepalive]="" check="" if="" connection="" is="" alive="" 20:12:20.783="" send="" ping...="" 20:12:20.806="" ping="" ok="" 20:12:20.810="" xml="" multicall="" : SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777,CENTRAL,PONG,SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777
      2022-04-07 20:12:20.811 - debug: hm-rpc.0 (1147) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777","CENTRAL","PONG","SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777"]
      2022-04-07 20:12:20.812 - debug: hm-rpc.0 (1147) xmlrpc <- event: hm-rpc.0.CENTRAL.PONG:SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777 discarded, no matching device
      2022-04-07 20:12:23.564 - debug: hm-rpc.1 (1169) [KEEPALIVE] Check if connection is alive
      2022-04-07 20:12:23.564 - debug: hm-rpc.1 (1169) Send PING...
      2022-04-07 20:12:23.582 - debug: hm-rpc.1 (1169) PING ok
      2022-04-07 20:12:23.584 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","CENTRAL:0","PONG","SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31"]
      2022-04-07 20:12:23.585 - debug: hm-rpc.1 (1169) xmlrpc <- event: hm-rpc.1.CENTRAL.0.PONG:SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31 discarded, no matching device
      2022-04-07 20:12:35.263 - info: host.SmarthomeRaspi instance system.adapter.mihome-vacuum.0 started with pid 17461
      2022-04-07 20:12:36.815 - debug: mihome-vacuum.0 (17461) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2022-04-07 20:12:36.896 - debug: mihome-vacuum.0 (17461) Objects client ready ... initialize now
      2022-04-07 20:12:36.899 - debug: mihome-vacuum.0 (17461) Objects create System PubSub Client
      2022-04-07 20:12:36.900 - debug: mihome-vacuum.0 (17461) Objects create User PubSub Client
      2022-04-07 20:12:37.046 - debug: mihome-vacuum.0 (17461) Objects client initialize lua scripts
      2022-04-07 20:12:37.053 - debug: mihome-vacuum.0 (17461) Objects connected to redis: 127.0.0.1:9001
      2022-04-07 20:12:37.119 - debug: mihome-vacuum.0 (17461) Redis States: Use Redis connection: 127.0.0.1:9000
      2022-04-07 20:12:37.183 - debug: mihome-vacuum.0 (17461) States create System PubSub Client
      2022-04-07 20:12:37.185 - debug: mihome-vacuum.0 (17461) States create User PubSub Client
      2022-04-07 20:12:37.261 - debug: mihome-vacuum.0 (17461) States connected to redis: 127.0.0.1:9000
      2022-04-07 20:12:37.523 - debug: mihome-vacuum.0 (17461) Plugin sentry Initialize Plugin (enabled=true)
      2022-04-07 20:12:38.030 - info: mihome-vacuum.0 (17461) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.19.1, js-controller: 4.0.21
      2022-04-07 20:12:38.130 - debug: mihome-vacuum.0 (17461) load Map creator... true
      2022-04-07 20:12:38.167 - debug: mihome-vacuum.0 (17461) Create State for deviceInfo
      2022-04-07 20:12:38.168 - debug: mihome-vacuum.0 (17461) Create State for deviceInfomac
      2022-04-07 20:12:38.169 - debug: mihome-vacuum.0 (17461) Create State for deviceInfomodel
      2022-04-07 20:12:38.170 - debug: mihome-vacuum.0 (17461) Create State for deviceInfofw_ver
      2022-04-07 20:12:38.174 - debug: mihome-vacuum.0 (17461) Create State for deviceInfowifi_signal
      2022-04-07 20:12:38.176 - debug: mihome-vacuum.0 (17461) MIIO: Config: ip:192.168.229.31 token: 6a62485744456c466c766f6d45535473
      2022-04-07 20:12:38.183 - info: mihome-vacuum.0 (17461) IOT enabled, create state
      2022-04-07 20:12:38.189 - debug: mihome-vacuum.0 (17461) server started on 0.0.0.0:53421
      2022-04-07 20:12:38.197 - debug: mihome-vacuum.0 (17461) Receive <<< Helo <<< 21310020000000001317ff30624f2996ffffffffffffffffffffffffffffffff
      2022-04-07 20:12:38.199 - debug: mihome-vacuum.0 (17461) MAIN: Connected to device, try to get model..
      2022-04-07 20:12:38.227 - debug: mihome-vacuum.0 (17461) GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.s5e","ack":true,"ts":1649355122288,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1649165771511}
      2022-04-07 20:12:38.230 - debug: mihome-vacuum.0 (17461) Message= {"id":1,"method":"miIO.info"}
      2022-04-07 20:12:40.237 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "miIO.info" <<<
      2022-04-07 20:12:40.238 - debug: mihome-vacuum.0 (17461) Get Device data..0
      2022-04-07 20:12:40.238 - debug: mihome-vacuum.0 (17461) Message= {"id":2,"method":"miIO.info"}
      2022-04-07 20:12:40.589 - info: unifi.0 (2213) State value to set for "unifi.0.default.clients.ae:2d:74:9e:b6:86.noted" has to be type "boolean" but received type "string"
      2022-04-07 20:12:40.685 - info: unifi.0 (2213) State value to set for "unifi.0.default.clients.94:e7:0b:61:00:58.noted" has to be type "boolean" but received type "string"
      2022-04-07 20:12:42.240 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "miIO.info" <<<
      2022-04-07 20:12:42.241 - debug: mihome-vacuum.0 (17461) Get Device data..1
      2022-04-07 20:12:42.241 - debug: mihome-vacuum.0 (17461) Message= {"id":3,"method":"miIO.info"}
      2022-04-07 20:12:44.243 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "miIO.info" <<<
      2022-04-07 20:12:44.243 - debug: mihome-vacuum.0 (17461) Get Device data..2
      2022-04-07 20:12:44.244 - debug: mihome-vacuum.0 (17461) Message= {"id":4,"method":"miIO.info"}
      2022-04-07 20:12:46.246 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "miIO.info" <<<
      2022-04-07 20:12:46.247 - debug: mihome-vacuum.0 (17461) Get Device data..3
      2022-04-07 20:12:46.247 - debug: mihome-vacuum.0 (17461) Message= {"id":5,"method":"miIO.info"}
      2022-04-07 20:12:48.207 - debug: mihome-vacuum.0 (17461) Receive <<< Helo <<< 21310020000000001317ff30624f29a0ffffffffffffffffffffffffffffffff
      2022-04-07 20:12:48.249 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "miIO.info" <<<
      2022-04-07 20:12:48.251 - debug: mihome-vacuum.0 (17461) Get Device data..4
      2022-04-07 20:12:48.252 - warn: mihome-vacuum.0 (17461) YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER YET - CONNECTION CAN TAKE UP TO 10 MINUTES - PLEASE BE PATIENT AND DO NOT TURN THE ADAPTER OFF
      2022-04-07 20:12:48.253 - warn: mihome-vacuum.0 (17461) No Answer for DeviceModel use old one
      2022-04-07 20:12:48.254 - warn: mihome-vacuum.0 (17461) No Answer for DeviceModel use model from Config
      2022-04-07 20:12:48.286 - debug: mihome-vacuum.0 (17461) DeviceModel selected to: roborock.vacuum.s5e
      2022-04-07 20:12:48.289 - info: mihome-vacuum.0 (17461) select standard vacuum protocol....
      2022-04-07 20:12:48.299 - debug: mihome-vacuum.0 (17461) Xiaomi Cloud: Logging in
      2022-04-07 20:12:48.395 - debug: mihome-vacuum.0 (17461) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
      2022-04-07 20:12:48.618 - debug: mihome-vacuum.0 (17461) Login step1: &&&START&&&{"serviceParam":"{\"checkSafePhone\":false,\"checkSafeAddress\":false,\"lsrp_score\":0.0}","qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"description":"登录验证失败","securityStatus":0,"_sign":"0psXfr43eNI0IX6q9Suk3qWbRqU=","sid":"xiaomiio","result":"error","captchaUrl":null,"callback":"https://sts.api.io.mi.com/sts","location":"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=","pwd":0,"desc":"登录验证失败"}
      2022-04-07 20:12:48.886 - debug: mihome-vacuum.0 (17461) Login step2: &&&START&&&{"qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","ssecurity":"SepRPCb5Gp3xHlMGTDMc6w==","code":0,"passToken":"V1:DXmurwq2/R1BHTELu6obCWKEFrEUGTARxOslPX6sxFF2Q8OlltPlCwT/UWqRgzdB0dLMMvcPG8AkDj4/+A82UV7DMirIabZ3FerW1PO6f5O67G9v0w978SPbJFPYfZjinxUAaHyGnjv7OHBePMBqVEB0h/QYglsEKHJGUbmzEm+3QgFc0wPvnjF6DZgahfTvBBA+TwZ/xrKw40MYUbsHcDnJwLuh6hNjmwkt6eMpLAoQE1NL261T6RVBpeWNH3pYqxwNZMZ9aeJRB71X8Ygj63GPXuM91zTS514w1SA2ppA=","description":"成功","securityStatus":0,"nonce":3032190925820327936,"userId":8161011682,"cUserId":"d7BvRzpJp2fIp_BmYH4fXAU23E8","result":"ok","psecurity":"qwnCZNR1XvS8GflT4azUJA==","captchaUrl":null,"location":"https://sts.api.io.mi.com/sts?d=gzwnnq&ticket=0&pwd=1&p_ts=1649355168000&fid=0&p_lm=1&auth=rCDOR5U3EDvAjqyhbqZTnqchvMFu25Yc5vxN1QIjYLOmFxvRocYln04TlM0e3aYti4XTfapSU4G5zEP4vKAvZqlP7brrRgLlQi0fbdpd2JSDH84sMRl6i8qWPjUuGj9X3OcRDhkm12XuDZT9pjbRYw64I7xfbnYGezBXSEJ8WwY%3D&m=1&tsl=0&nonce=lvi8eHbKkg8Bo3Pk&_ssign=U08FSkqWBO%2FhVOJXffR50pBC5SQ%3D","pwd":1,"desc":"成功"}
      2022-04-07 20:12:49.029 - info: mihome-vacuum.0 (17461) settest next timer: not available
      2022-04-07 20:12:49.251 - debug: mihome-vacuum.0 (17461) Login step3: [{"key":"userId","value":"8161011682","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-04-07T18:12:49.194Z","lastAccessed":"2022-04-07T18:12:49.248Z"},{"key":"cUserId","value":"d7BvRzpJp2fIp_BmYH4fXAU23E8","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-04-07T18:12:49.219Z","lastAccessed":"2022-04-07T18:12:49.248Z"},{"key":"serviceToken","value":"PlyQUW9q7aeZNtWORxesgsriRJJGvLPk3oTyMSaP2wG45oBiDVK6ZiHNX5KCwQup0RFhxEzTkYwbZWG1Nuquo7V9V0JKWRleagwbEJ1X/4JODW27+AVy+MHqsmjwE1fRxUmADb3JYCGd+g74Weydjv4ptbnbFL9QhR6BMLwNRHo=","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-04-07T18:12:49.233Z","lastAccessed":"2022-04-07T18:12:49.248Z"}]
      2022-04-07 20:12:49.266 - debug: mihome-vacuum.0 (17461) Xiaomi Cloud: Login successful
      2022-04-07 20:12:49.336 - debug: mihome-vacuum.0 (17461) Create State for Queue: queue
      2022-04-07 20:12:49.337 - debug: mihome-vacuum.0 (17461) Create State for Queue: clearQueue
      2022-04-07 20:12:49.341 - info: mihome-vacuum.0 (17461) Map selected create states...
      2022-04-07 20:12:49.344 - debug: mihome-vacuum.0 (17461) Create State for map:
      2022-04-07 20:12:49.345 - debug: mihome-vacuum.0 (17461) Create State for map: map64
      2022-04-07 20:12:49.346 - debug: mihome-vacuum.0 (17461) Create State for map: actualMap
      2022-04-07 20:12:49.348 - debug: mihome-vacuum.0 (17461) Create State for map: mapStatus
      2022-04-07 20:12:49.349 - debug: mihome-vacuum.0 (17461) Create State for map: mapURL
      2022-04-07 20:12:49.350 - debug: mihome-vacuum.0 (17461) Create State for map: loadMap
      2022-04-07 20:12:49.350 - debug: mihome-vacuum.0 (17461) Create State done!
      2022-04-07 20:12:49.351 - debug: mihome-vacuum.0 (17461) get params for stock Vacuum
      2022-04-07 20:12:49.352 - debug: mihome-vacuum.0 (17461) Message= {"id":6,"method":"get_status"}
      2022-04-07 20:12:51.353 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "get_status" <<<
      2022-04-07 20:12:51.354 - debug: mihome-vacuum.0 (17461) ERROR at setGetStatus: MESSAGE TIMEOUT
      2022-04-07 20:12:51.355 - debug: mihome-vacuum.0 (17461) Message= {"id":7,"method":"get_network_info"}
      2022-04-07 20:12:53.356 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "get_network_info" <<<
      2022-04-07 20:12:53.357 - debug: mihome-vacuum.0 (17461) Error at getSetNetwork: MESSAGE TIMEOUT
      2022-04-07 20:12:53.358 - debug: mihome-vacuum.0 (17461) Message= {"id":8,"method":"get_sound_volume"}
      2022-04-07 20:12:55.360 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "get_sound_volume" <<<
      2022-04-07 20:12:55.361 - debug: mihome-vacuum.0 (17461) ERROR at setGetSoundVolume: MESSAGE TIMEOUT
      2022-04-07 20:12:55.363 - debug: mihome-vacuum.0 (17461) Message= {"id":9,"method":"get_multi_maps_list"}
      2022-04-07 20:12:57.365 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "get_multi_maps_list" <<<
      2022-04-07 20:12:57.367 - debug: mihome-vacuum.0 (17461) Startup: getMultiMapsList Answer: false
      2022-04-07 20:12:57.368 - debug: mihome-vacuum.0 (17461) Message= {"id":10,"method":"get_clean_summary"}
      2022-04-07 20:12:58.212 - debug: mihome-vacuum.0 (17461) Receive <<< Helo <<< 21310020000000001317ff30624f29aaffffffffffffffffffffffffffffffff
      2022-04-07 20:12:59.370 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "get_clean_summary" <<<
      2022-04-07 20:12:59.371 - debug: mihome-vacuum.0 (17461) ERROR at setGetCleanSummary: MESSAGE TIMEOUT
      2022-04-07 20:12:59.372 - debug: mihome-vacuum.0 (17461) Startup: setGetCleanSummary Answer: false
      2022-04-07 20:12:59.373 - debug: mihome-vacuum.0 (17461) Message= {"id":11,"method":"get_consumable"}
      2022-04-07 20:13:01.374 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "get_consumable" <<<
      2022-04-07 20:13:01.377 - debug: mihome-vacuum.0 (17461) ERROR at setGetConsumable: MESSAGE TIMEOUT
      2022-04-07 20:13:01.378 - debug: mihome-vacuum.0 (17461) Startup: setGetConsumable Answer: false
      2022-04-07 20:13:01.380 - debug: mihome-vacuum.0 (17461) Message= {"id":12,"method":"get_map_v1"}
      2022-04-07 20:13:03.384 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "get_map_v1" <<<
        dieser Fehler kam noch
        2022-04-07 20:15:46.409 - debug: mihome-vacuum.0 (17698) Message= {"id":6,"method":"get_map_v1"}
        2022-04-07 20:15:46.413 - debug: mihome-vacuum.0 (17698) Message= {"id":7,"method":"get_network_info"}
        2022-04-07 20:15:46.424 - debug: mihome-vacuum.0 (17698) MIIO RECIVE: {"result":["rubyslite%2F320339760%2F14"],"id":6}
        2022-04-07 20:15:46.427 - debug: mihome-vacuum.0 (17698) Mappointer_updated
        2022-04-07 20:15:46.428 - debug: mihome-vacuum.0 (17698) update_Map Mimap enabled
        2022-04-07 20:15:46.429 - debug: mihome-vacuum.0 (17698) update_Map need new mapurl
        2022-04-07 20:15:46.441 - debug: mihome-vacuum.0 (17698) MIIO RECIVE: {"result":{"ssid":"froehlich.unifi","ip":"192.168.229.31","mac":"64:90:c1:01:fb:13","bssid":"4a:d9:e7:fa:7f:d0","rssi":-49},"id":7}
        2022-04-07 20:15:46.552 - error: mihome-vacuum.0 (17698) Error when receiving map url: V/=+yvYq
        )-1z9kI@z,qiI'
        eCu40Sr]NCGHyHz>BU'<,]=sQug-,pd"in$jnf /?L)+(L\JNSIx"k;{6Ou'8u(}KMq7OGoij >"/RvMr -nRvmR9+)5Nx\i pI9]i9d-y}^"<KK1h|t,`Yi\%j<N
        /Q|h=RGu( #h)Yv`'bk6iFsPDi_B+7EJIVkb"EaZ{;"
        2022-04-07 20:15:46.554 - warn: mihome-vacuum.0 (17698) map error:SyntaxError: Unexpected token V in JSON at position 0
        2022-04-07 20:15:46.555 - debug: mihome-vacuum.0 (17698) Xiaomi Cloud: Logging in
        2022-04-07 20:15:46.565 - debug: mihome-vacuum.0 (17698) Message= {"id":8,"method":"get_sound_volume"}
        2022-04-07 20:15:46.572 - debug: mihome-vacuum.0 (17698) MIIO RECIVE: {"result":[30],"id":8}
        2022-04-07 20:15:46.575 - debug: mihome-vacuum.0 (17698) Message= {"id":9,"method":"get_multi_maps_list"}
        2022-04-07 20:15:46.581 - debug: mihome-vacuum.0 (17698) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320339760/14?Expires=1649357146000&GalaxyAccessKeyId=5271733786445&Signature=opGVwS3duRFnQWWBtkrse3j7Kr0=
        2022-04-07 20:15:46.582 - debug: mihome-vacuum.0 (17698) update_Map got new expires:1649357146
        2022-04-07 20:15:46.583 - debug: mihome-vacuum.0 (17698) update_Map got new time:1649355346
        2022-04-07 20:15:46.592 - debug: mihome-vacuum.0 (17698) MIIO RECIVE: {"result":[{"max_multi_map":1,"max_bak_map":0,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1645100692,"length":0,"name":"","bak_maps":[]}]}],"id":9}
        2022-04-07 20:15:46.593 - debug: mihome-vacuum.0 (17698) States for 1 Map: [{"mapFlag":0,"add_time":1645100692,"length":0,"name":"","bak_maps":[]}]
        2022-04-07 20:15:46.593 - debug: mihome-vacuum.0 (17698) States for Map: {"0":"0"}
        2022-04-07 20:15:46.595 - debug: mihome-vacuum.0 (17698) Startup: getMultiMapsList Answer: true
        2022-04-07 20:15:46.595 - debug: mihome-vacuum.0 (17698) Startup: Delete getMultiMapsList
        2022-04-07 20:15:46.596 - debug: mihome-vacuum.0 (17698) Message= {"id":10,"method":"get_clean_summary"}
          22-04-07 20:15:46.795 - debug: mihome-vacuum.0 (17698) Login step1: &&&START&&&{"serviceParam":"{\"checkSafePhone\":false,\"checkSafeAddress\":false,\"lsrp_score\":0.0}","qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"description":"登录验证失败","securityStatus":0,"_sign":"0psXfr43eNI0IX6q9Suk3qWbRqU=","sid":"xiaomiio","result":"error","captchaUrl":null,"callback":"https://sts.api.io.mi.com/sts","location":"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=","pwd":0,"desc":"登录验证失败"}
          2022-04-07 20:15:46.798 - debug: mihome-vacuum.0 (17698) MIIO RECIVE: {"result":[{"main_brush_work_time":137508,"side_brush_work_time":137508,"filter_work_time":137508,"filter_element_work_time":11733,"sensor_dirty_time":28763}],"id":31}
          2022-04-07 20:15:46.799 - debug: mihome-vacuum.0 (17698) Startup: setGetConsumable Answer: true
          2022-04-07 20:15:46.799 - debug: mihome-vacuum.0 (17698) Startup: Delete setGetConsumable
          2022-04-07 20:15:46.800 - debug: mihome-vacuum.0 (17698) Message= {"id":32,"method":"get_carpet_mode"}
          2022-04-07 20:15:46.817 - debug: mihome-vacuum.0 (17698) MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":32}
          2022-04-07 20:15:46.818 - info: mihome-vacuum.0 (17698) create state for carpet_mode
          2022-04-07 20:15:46.819 - debug: mihome-vacuum.0 (17698) Message= {"id":33,"method":"get_carpet_mode"}
          2022-04-07 20:15:46.830 - debug: mihome-vacuum.0 (17698) MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":33}
          2022-04-07 20:15:47.111 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,CONFIG_PENDING,false
          2022-04-07 20:15:47.111 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","CONFIG_PENDING",false]
          2022-04-07 20:15:47.111 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.CONFIG_PENDING ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
          2022-04-07 20:15:47.112 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,DUTY_CYCLE,false
          2022-04-07 20:15:47.112 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","DUTY_CYCLE",false]
          2022-04-07 20:15:47.112 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.DUTY_CYCLE ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
          2022-04-07 20:15:47.112 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,LOW_BAT,false
          2022-04-07 20:15:47.112 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","LOW_BAT",false]
          2022-04-07 20:15:47.112 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.LOW_BAT ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
          2022-04-07 20:15:47.113 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,UNREACH,false
          2022-04-07 20:15:47.113 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","UNREACH",false]
          2022-04-07 20:15:47.113 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.UNREACH ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
          2022-04-07 20:15:47.113 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,RSSI_DEVICE,-79
          2022-04-07 20:15:47.113 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","RSSI_DEVICE",-79]
          2022-04-07 20:15:47.113 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.RSSI_DEVICE ==> UNIT: "undefined" (min: -128, max: 127) From "-79" => "-79"
          2022-04-07 20:15:47.113 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,OPERATING_VOLTAGE_STATUS,0
          2022-04-07 20:15:47.114 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","OPERATING_VOLTAGE_STATUS",0]
          2022-04-07 20:15:47.114 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.OPERATING_VOLTAGE_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
          2022-04-07 20:15:47.114 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,OPERATING_VOLTAGE,3
          2022-04-07 20:15:47.114 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","OPERATING_VOLTAGE",3]
          2022-04-07 20:15:47.114 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.OPERATING_VOLTAGE ==> UNIT: "undefined" (min: 0, max: 25.2) From "3" => "3"
          2022-04-07 20:15:47.114 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,ERROR_CODE,0
          2022-04-07 20:15:47.114 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","ERROR_CODE",0]
          2022-04-07 20:15:47.115 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.ERROR_CODE ==> UNIT: "undefined" (min: 0, max: 255) From "0" => "0"
          2022-04-07 20:15:47.125 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:3,MOTION,true
          2022-04-07 20:15:47.125 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:3","MOTION",true]
          2022-04-07 20:15:47.125 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.3.MOTION ==> UNIT: "undefined" (min: undefined, max: undefined) From "true" => "true"
          2022-04-07 20:15:47.125 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:3,ILLUMINATION,1.7
          2022-04-07 20:15:47.125 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:3","ILLUMINATION",1.7]
          2022-04-07 20:15:47.126 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.3.ILLUMINATION ==> UNIT: "undefined" (min: 0, max: 163830) From "1.7" => "1.7"
          2022-04-07 20:15:47.126 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:3,ILLUMINATION_STATUS,0
          2022-04-07 20:15:47.126 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:3","ILLUMINATION_STATUS",0]
          2022-04-07 20:15:47.127 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.3.ILLUMINATION_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
          2022-04-07 20:15:47.127 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:3,MOTION_DETECTION_ACTIVE,true
          2022-04-07 20:15:47.127 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:3","MOTION_DETECTION_ACTIVE",true]
          2022-04-07 20:15:47.132 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.3.MOTION_DETECTION_ACTIVE ==> UNIT: "undefined" (min: undefined, max: undefined) From "true" => "true"
          2022-04-07 20:15:47.167 - debug: mihome-vacuum.0 (17698) 22595
          2022-04-07 20:15:47.356 - error: host.SmarthomeRaspi Caught by controller[0]: corrupted double-linked list
          2022-04-07 20:15:47.357 - warn: host.SmarthomeRaspi instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
          2022-04-07 20:15:47.357 - info: host.SmarthomeRaspi instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
          2022-04-07 20:15:47.357 - info: host.SmarthomeRaspi Restart adapter system.adapter.mihome-vacuum.0 because enabled
          2022-04-07 20:15:49.608 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:0,CONFIG_PENDING,false
          2022-04-07 20:15:49.608 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:0","CONFIG_PENDING",false]
          2022-04-07 20:15:49.608 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.0.CONFIG_PENDING ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
          2022-04-07 20:15:49.608 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:0,RSSI_DEVICE,-84
          2022-04-07 20:15:49.609 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:0","RSSI_DEVICE",-84]
          2022-04-07 20:15:49.609 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.0.RSSI_DEVICE ==> UNIT: "undefined" (min: -128, max: 127) From "-84" => "-84"
          2022-04-07 20:15:49.609 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:0,DUTY_CYCLE,false
          2022-04-07 20:15:49.609 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:0","DUTY_CYCLE",false]
          2022-04-07 20:15:49.609 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.0.DUTY_CYCLE ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
          2022-04-07 20:15:49.609 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:0,UNREACH,false
          2022-04-07 20:15:49.609 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:0","UNREACH",false]
          2022-04-07 20:15:49.610 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.0.UNREACH ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
          2022-04-07 20:15:49.619 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:3,LEVEL,0
          2022-04-07 20:15:49.619 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:3","LEVEL",0]
          2022-04-07 20:15:49.619 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.3.LEVEL ==> UNIT: "100%" (min: 0, max: 1) From "0" => "0"
          2022-04-07 20:15:49.620 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:3,LEVEL_STATUS,0
          2022-04-07 20:15:49.620 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:3","LEVEL_STATUS",0]
          2022-04-07 20:15:49.620 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.3.LEVEL_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
          2022-04-07 20:15:49.620 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:3,SECTION,15
          2022-04-07 20:15:49.620 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:3","SECTION",15]
          2022-04-07 20:15:49.621 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.3.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "15" => "15"
          2022-04-07 20:15:49.621 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:3,PROCESS,0
          2022-04-07 20:15:49.621 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:3","PROCESS",0]
          2022-04-07 20:15:49.621 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.3.PROCESS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
          2022-04-07 20:15:49.621 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:3,ACTIVITY_STATE,3
          2022-04-07 20:15:49.621 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:3","ACTIVITY_STATE",3]
          2022-04-07 20:15:49.621 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.3.ACTIVITY_STATE ==> UNIT: "undefined" (min: undefined, max: undefined) From "3" => "3"
          2022-04-07 20:15:49.630 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:4,LEVEL,0
          2022-04-07 20:15:49.630 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:4","LEVEL",0]
          2022-04-07 20:15:49.631 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.4.LEVEL ==> UNIT: "100%" (min: 0, max: 1) From "0" => "0"
          2022-04-07 20:15:49.631 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:4,LEVEL_STATUS,0
          2022-04-07 20:15:49.631 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:4","LEVEL_STATUS",0]
          2022-04-07 20:15:49.632 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.4.LEVEL_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
          2022-04-07 20:15:49.632 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:4,SECTION,0
          2022-04-07 20:15:49.633 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:4","SECTION",0]
          2022-04-07 20:15:49.633 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.4.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "0" => "0"
          2022-04-07 20:15:49.634 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:4,PROCESS,0
          2022-04-07 20:15:49.634 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:4","PROCESS",0]
          2022-04-07 20:15:49.634 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.4.PROCESS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
          2022-04-07 20:15:49.634 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:4,ACTIVITY_STATE,3
          2022-04-07 20:15:49.634 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:4","ACTIVITY_STATE",3]
          2022-04-07 20:15:49.635 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.4.ACTIVITY_STATE ==> UNIT: "undefined" (min: undefined, max: undefined) From "3" => "3"
          2022-04-07 20:15:49.644 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:5,LEVEL,0
          2022-04-07 20:15:49.645 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:5","LEVEL",0]
          2022-04-07 20:15:49.645 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.5.LEVEL ==> UNIT: "100%" (min: 0, max: 1) From "0" => "0"
          2022-04-07 20:15:49.645 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:5,LEVEL_STATUS,0
          2022-04-07 20:15:49.646 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:5","LEVEL_STATUS",0]
          2022-04-07 20:15:49.646 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.5.LEVEL_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
          2022-04-07 20:15:49.646 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:5,SECTION,0
          2022-04-07 20:15:49.647 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:5","SECTION",0]
          2022-04-07 20:15:49.647 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.5.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "0" => "0"
          2022-04-07 20:15:49.647 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:5,PROCESS,0
          2022-04-07 20:15:49.647 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:5","PROCESS",0]
          2022-04-07 20:15:49.648 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.5.PROCESS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
          2022-04-07 20:15:49.649 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:5,ACTIVITY_STATE,3
          2022-04-07 20:15:49.649 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:5","ACTIVITY_STATE",3]
          2022-04-07 20:15:49.649 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.5.ACTIVITY_STATE ==> UNIT: "undefined" (min: undefined, max: undefined) From "3" => "3"
          2022-04-07 20:15:49.676 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:6,LEVEL,0
          2022-04-07 20:15:49.677 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:6","LEVEL",0]
          2022-04-07 20:15:49.678 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.6.LEVEL ==> UNIT: "100%" (min: 0, max: 1) From "0" => "0"
          2022-04-07 20:15:49.678 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:6,LEVEL_STATUS,0
          2022-04-07 20:15:49.679 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:6","LEVEL_STATUS",0]
          2022-04-07 20:15:49.679 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.6.LEVEL_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
          2022-04-07 20:15:49.679 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:6,SECTION,0
          2022-04-07 20:15:49.681 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:6","SECTION",0]
          2022-04-07 20:15:49.681 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.6.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "0" => "0"
          2022-04-07 20:15:49.681 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:6,PROCESS,0
          2022-04-07 20:15:49.682 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:6","PROCESS",0]
          2022-04-07 20:15:49.682 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.6.PROCESS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
          2022-04-07 20:15:49.683 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:6,ACTIVITY_STATE,3
          2022-04-07 20:15:49.684 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:6","ACTIVITY_STATE",3]
          2022-04-07 20:15:49.684 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.6.ACTIVITY_STATE ==> UNIT: "undefined" (min: undefined, max: undefined) From "3" => "3"
          2022-04-07 20:15:59.561 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,00085D89B13FCC:0,CONFIG_PENDING,false
          2022-04-07 20:15:59.562 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","00085D89B13FCC:0","CONFIG_PENDING",false]
          2022-04-07 20:15:59.562 - debug: hm-rpc.1 (1169) hm-rpc.1.00085D89B13FCC.0.CONFIG_PENDING ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
          2022-04-07 20:15:59.562 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,00085D89B13FCC:0,UNREACH,false
          2022-04-07 20:15:59.562 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","00085D89B13FCC:0","UNREACH",false]
          2022-04-07 20:15:59.563 - debug: hm-rpc.1 (1169) hm-rpc.1.00085D89B13FCC.0.UNREACH ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
          2022-04-07 20:15:59.563 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,00085D89B13FCC:0,RSSI_DEVICE,-73
          2022-04-07 20:15:59.563 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","00085D89B13FCC:0","RSSI_DEVICE",-73]
          2022-04-07 20:15:59.563 - debug: hm-rpc.1 (1169) hm-rpc.1.00085D89B13FCC.0.RSSI_DEVICE ==> UNIT: "undefined" (min: -128, max: 127) From "-73" => "-73"
          2022-04-07 20:15:59.568 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","00085D89B13FCC:1","PRESS_SHORT",true]
          2022-04-07 20:15:59.569 - debug: hm-rpc.1 (1169) hm-rpc.1.00085D89B13FCC.1.PRESS_SHORT ==> UNIT: "undefined" (min: undefined, max: undefined) From "true" => "true"
          2022-04-07 20:16:00.552 - debug: hm-rpc.1 (1169) xmlrpc -> setValue 2 STATE: true
          2022-04-07 20:16:00.552 - debug: hm-rpc.1 (1169) setValue ["000895699E6B0E:2","STATE",true] BOOL
          2022-04-07 20:16:00.698 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:0,CONFIG_PENDING,false
          2022-04-07 20:16:00.698 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:0","CONFIG_PENDING",false]
          2022-04-07 20:16:00.698 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.0.CONFIG_PENDING ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
          2022-04-07 20:16:00.699 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:0,RSSI_DEVICE,-77
          2022-04-07 20:16:00.699 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:0","RSSI_DEVICE",-77]
          2022-04-07 20:16:00.699 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.0.RSSI_DEVICE ==> UNIT: "undefined" (min: -128, max: 127) From "-77" => "-77"
          2022-04-07 20:16:00.699 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:0,DUTY_CYCLE,false
          2022-04-07 20:16:00.699 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:0","DUTY_CYCLE",false]
          2022-04-07 20:16:00.699 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.0.DUTY_CYCLE ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
          2022-04-07 20:16:00.700 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:0,UNREACH,false
          2022-04-07 20:16:00.700 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:0","UNREACH",false]
          2022-04-07 20:16:00.700 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.0.UNREACH ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
          2022-04-07 20:16:00.700 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:0,RSSI_PEER,-74
          2022-04-07 20:16:00.700 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:0","RSSI_PEER",-74]
          2022-04-07 20:16:00.700 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.0.RSSI_PEER ==> UNIT: "undefined" (min: -128, max: 127) From "-74" => "-74"
          2022-04-07 20:16:00.708 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:2,SECTION_STATUS,0
          2022-04-07 20:16:00.708 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:2","SECTION_STATUS",0]
          2022-04-07 20:16:00.708 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.2.SECTION_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
          2022-04-07 20:16:00.709 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:2,STATE,true
          2022-04-07 20:16:00.709 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:2","STATE",true]
          2022-04-07 20:16:00.709 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.2.STATE ==> UNIT: "undefined" (min: undefined, max: undefined) From "true" => "true"
          2022-04-07 20:16:00.709 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:2,SECTION,2
          2022-04-07 20:16:00.710 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:2","SECTION",2]
          2022-04-07 20:16:00.710 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.2.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "2" => "2"
          2022-04-07 20:16:00.710 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:2,PROCESS,0
          2022-04-07 20:16:00.710 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:2","PROCESS",0]
          2022-04-07 20:16:00.710 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.2.PROCESS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
          2022-04-07 20:16:01.552 - debug: shuttercontrol.0 (1726) Shutter state changed: Rollladen Küche.LEVEL old value = 100 new value = 0
          2022-04-07 20:16:01.557 - debug: shuttercontrol.0 (1726) Rollladen Küche.LEVEL Old value = 100. New value = 0. automatic is active
          2022-04-07 20:16:04.227 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:0,CONFIG_PENDING,false
          2022-04-07 20:16:04.228 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:0","CONFIG_PENDING",false]
          2022-04-07 20:16:04.228 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.0.CONFIG_PENDING ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
          2022-04-07 20:16:04.228 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:0,RSSI_DEVICE,-84
          2022-04-07 20:16:04.228 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:0","RSSI_DEVICE",-84]
          2022-04-07 20:16:04.228 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.0.RSSI_DEVICE ==> UNIT: "undefined" (min: -128, max: 127) From "-84" => "-84"
          2022-04-07 20:16:04.228 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:0,DUTY_CYCLE,false
          2022-04-07 20:16:04.229 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:0","DUTY_CYCLE",false]
          2022-04-07 20:16:04.229 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.0.DUTY_CYCLE ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
          2022-04-07 20:16:04.231 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:0,UNREACH,false
          2022-04-07 20:16:04.231 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:0","UNREACH",false]
          2022-04-07 20:16:04.231 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.0.UNREACH ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
          2022-04-07 20:16:04.261 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:1,SECTION_STATUS,0
          2022-04-07 20:16:04.262 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:1","SECTION_STATUS",0]
          2022-04-07 20:16:04.262 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.1.SECTION_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
          2022-04-07 20:16:04.262 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:1,STATE,true
          2022-04-07 20:16:04.262 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:1","STATE",true]
          2022-04-07 20:16:04.262 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.1.STATE ==> UNIT: "undefined" (min: undefined, max: undefined) From "true" => "true"
          2022-04-07 20:16:04.262 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:1,SECTION,2
          2022-04-07 20:16:04.262 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:1","SECTION",2]
          2022-04-07 20:16:04.263 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.1.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "2" => "2"
          2022-04-07 20:16:04.263 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:1,PROCESS,0
          2022-04-07 20:16:04.263 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:1","PROCESS",0]
          2022-04-07 20:16:04.263 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.1.PROCESS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
          2022-04-07 20:16:04.274 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:2,SECTION_STATUS,0
          2022-04-07 20:16:04.274 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:2","SECTION_STATUS",0]
          2022-04-07 20:16:04.274 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.2.SECTION_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
          2022-04-07 20:16:04.275 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:2,STATE,true
          2022-04-07 20:16:04.275 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:2","STATE",true]
          2022-04-07 20:16:04.275 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.2.STATE ==> UNIT: "undefined" (min: undefined, max: undefined) From "true" => "true"
          2022-04-07 20:16:04.275 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:2,SECTION,2
          2022-04-07 20:16:04.275 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:2","SECTION",2]
          2022-04-07 20:16:04.275 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.2.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "2" => "2"
          2022-04-07 20:16:04.275 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:2,PROCESS,0
          2022-04-07 20:16:04.276 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:2","PROCESS",0]
          2022-04-07 20:16:04.276 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.2.PROCESS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
          2022-04-07 20:16:04.283 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:3,SECTION_STATUS,0
          2022-04-07 20:16:04.283 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:3","SECTION_STATUS",0]
          2022-04-07 20:16:04.283 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.3.SECTION_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
          2022-04-07 20:16:04.284 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:3,STATE,false
          2022-04-07 20:16:04.284 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:3","STATE",false]
          2022-04-07 20:16:04.284 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.3.STATE ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
          2022-04-07 20:16:04.285 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:3,SECTION,0
          2022-04-07 20:16:04.285 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:3","SECTION",0]
          2022-04-07 20:16:04.285 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.3.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "0" => "0"
          2022-04-07 20:16:04.285 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:3,PROCESS,0
          2022-04-07 20:16:04.285 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:3","PROCESS",0]
          2022-04-07 20:16:04.286 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.3.PROCESS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
          2022-04-07 20:16:04.294 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:4,SECTION_STATUS,0
          2022-04-07 20:16:04.294 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:4","SECTION_STATUS",0]
          2022-04-07 20:16:04.294 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.4.SECTION_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
          2022-04-07 20:16:04.295 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:4,STATE,false
          2022-04-07 20:16:04.295 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:4","STATE",false]
          2022-04-07 20:16:04.295 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.4.STATE ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
          2022-04-07 20:16:04.296 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:4,SECTION,0
          2022-04-07 20:16:04.296 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:4","SECTION",0]
          2022-04-07 20:16:04.297 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.4.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "0" => "0"
          2022-04-07 20:16:04.297 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:4,PROCESS,0
          2022-04-07 20:16:04.297 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:4","PROCESS",0]
          2022-04-07 20:16:04.298 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.4.PROCESS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
          2022-04-07 20:16:04.344 - debug: shuttercontrol.0 (1726) Shutter state changed: Rollladen Wohnzimmer Terrasse Schiebetür.LEVEL old value = 100 new value = 0
          2022-04-07 20:16:04.345 - debug: shuttercontrol.0 (1726) Rollladen Wohnzimmer Terrasse Schiebetür.LEVEL Old value = 100. New value = 0. automatic is active
          2022-04-07 20:16:05.303 - info: shelly.0 (1251) [CoAP] Device 192.168.229.68 (shellyrgbw2 / shellyrgbw2-1E035D / SHRGBW2#1E035D#1) connected! Polltime set to 5 sec.
          2022-04-07 20:16:10.433 - debug: shuttercontrol.0 (1726) Shutter state changed: Rollladen Wohnzimmer Seite vorn.LEVEL old value = 100 new value = 0
          2022-04-07 20:16:10.434 - debug: shuttercontrol.0 (1726) Rollladen Wohnzimmer Seite vorn.LEVEL Old value = 100. New value = 0. automatic is active
          2022-04-07 20:16:13.455 - debug: shuttercontrol.0 (1726) Shutter state changed: Rollladen Wohnzimmer Seite hinten.LEVEL old value = 100 new value = 0
          2022-04-07 20:16:13.455 - debug: shuttercontrol.0 (1726) Rollladen Wohnzimmer Seite hinten.LEVEL Old value = 100. New value = 0. automatic is active
          2022-04-07 20:16:16.720 - debug: shuttercontrol.0 (1726) Shutter state changed: Rollladen Büro.LEVEL old value = 100 new value = 0
          2022-04-07 20:16:16.720 - debug: shuttercontrol.0 (1726) Rollladen Büro.LEVEL Old value = 100. New value = 0. automatic is active
          2022-04-07 20:16:16.764 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,CONFIG_PENDING,false
          2022-04-07 20:16:16.765 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","CONFIG_PENDING",false]
          2022-04-07 20:16:16.765 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.CONFIG_PENDING ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
          2022-04-07 20:16:16.765 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,DUTY_CYCLE,false
          2022-04-07 20:16:16.766 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","DUTY_CYCLE",false]
          2022-04-07 20:16:16.766 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.DUTY_CYCLE ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
          2022-04-07 20:16:16.766 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,LOW_BAT,false
          2022-04-07 20:16:16.766 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","LOW_BAT",false]
          2022-04-07 20:16:16.766 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.LOW_BAT ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
          2022-04-07 20:16:16.767 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,UNREACH,false
          2022-04-07 20:16:16.767 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","UNREACH",false]
          2022-04-07 20:16:16.767 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.UNREACH ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
          2022-04-07 20:16:16.767 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,RSSI_DEVICE,-79
          2022-04-07 20:16:16.767 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","RSSI_DEVICE",-79]
          2022-04-07 20:16:16.768 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.RSSI_DEVICE ==> UNIT: "undefined" (min: -128, max: 127) From "-79" => "-79"
          2022-04-07 20:16:16.768 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,OPERATING_VOLTAGE_STATUS,0
          2022-04-07 20:16:16.768 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","OPERATING_VOLTAGE_STATUS",0]
          2022-04-07 20:16:16.769 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.OPERATING_VOLTAGE_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
          2022-04-07 20:16:16.769 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,OPERATING_VOLTAGE,3
          2022-04-07 20:16:16.769 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","OPERATING_VOLTAGE",3]
          2022-04-07 20:16:16.769 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.OPERATING_VOLTAGE ==> UNIT: "undefined" (min: 0, max: 25.2) From "3" => "3"
          2022-04-07 20:16:16.769 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,ERROR_CODE,0
          2022-04-07 20:16:16.770 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","ERROR_CODE",0]
          2022-04-07 20:16:16.770 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.ERROR_CODE ==> UNIT: "undefined" (min: 0, max: 255) From "0" => "0"
          2022-04-07 20:16:16.779 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:3,MOTION,false
          2022-04-07 20:16:16.780 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:3","MOTION",false]
          2022-04-07 20:16:16.780 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.3.MOTION ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
          2022-04-07 20:16:16.780 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:3,ILLUMINATION,0.1
          2022-04-07 20:16:16.781 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:3","ILLUMINATION",0.1]
          2022-04-07 20:16:16.781 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.3.ILLUMINATION ==> UNIT: "undefined" (min: 0, max: 163830) From "0.1" => "0.1"
          2022-04-07 20:16:16.781 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:3,ILLUMINATION_STATUS,0
          2022-04-07 20:16:16.781 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:3","ILLUMINATION_STATUS",0]
          2022-04-07 20:16:16.782 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.3.ILLUMINATION_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
          2022-04-07 20:16:16.782 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:3,MOTION_DETECTION_ACTIVE,true
          2022-04-07 20:16:16.782 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:3","MOTION_DETECTION_ACTIVE",true]
          2022-04-07 20:16:16.783 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.3.MOTION_DETECTION_ACTIVE ==> UNIT: "undefined" (min: undefined, max: undefined) From "true" => "true"
          2022-04-07 20:16:17.660 - info: host.SmarthomeRaspi instance system.adapter.mihome-vacuum.0 started with pid 17770
          2022-04-07 20:16:19.313 - debug: mihome-vacuum.0 (17770) Redis Objects: Use Redis connection: 127.0.0.1:9001
          2022-04-07 20:16:19.408 - debug: mihome-vacuum.0 (17770) Objects client ready ... initialize now
          2022-04-07 20:16:19.411 - debug: mihome-vacuum.0 (17770) Objects create System PubSub Client
          2022-04-07 20:16:19.414 - debug: mihome-vacuum.0 (17770) Objects create User PubSub Client
          2022-04-07 20:16:19.544 - debug: mihome-vacuum.0 (17770) Objects client initialize lua scripts
          2022-04-07 20:16:19.552 - debug: mihome-vacuum.0 (17770) Objects connected to redis: 127.0.0.1:9001
          2022-04-07 20:16:19.621 - debug: mihome-vacuum.0 (17770) Redis States: Use Redis connection: 127.0.0.1:9000
          2022-04-07 20:16:19.685 - debug: mihome-vacuum.0 (17770) States create System PubSub Client
          2022-04-07 20:16:19.687 - debug: mihome-vacuum.0 (17770) States create User PubSub Client
          2022-04-07 20:16:19.818 - debug: mihome-vacuum.0 (17770) States connected to redis: 127.0.0.1:9000
          2022-04-07 20:16:20.215 - debug: mihome-vacuum.0 (17770) Plugin sentry Initialize Plugin (enabled=true)
          2022-04-07 20:16:20.629 - info: mihome-vacuum.0 (17770) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.19.1, js-controller: 4.0.21
          2022-04-07 20:16:20.719 - debug: mihome-vacuum.0 (17770) load Map creator... true
          2022-04-07 20:16:20.754 - debug: mihome-vacuum.0 (17770) Create State for deviceInfo
          2022-04-07 20:16:20.755 - debug: mihome-vacuum.0 (17770) Create State for deviceInfomac
          2022-04-07 20:16:20.756 - debug: mihome-vacuum.0 (17770) Create State for deviceInfomodel
          2022-04-07 20:16:20.757 - debug: mihome-vacuum.0 (17770) Create State for deviceInfofw_ver
          2022-04-07 20:16:20.762 - debug: mihome-vacuum.0 (17770) Create State for deviceInfowifi_signal
          2022-04-07 20:16:20.764 - debug: mihome-vacuum.0 (17770) MIIO: Config: ip:192.168.229.31 token: 6a62485744456c466c766f6d45535473
          2022-04-07 20:16:20.771 - info: mihome-vacuum.0 (17770) IOT enabled, create state
          2022-04-07 20:16:20.779 - debug: mihome-vacuum.0 (17770) server started on 0.0.0.0:53421
          2022-04-07 20:16:20.789 - debug: mihome-vacuum.0 (17770) Receive <<< Helo <<< 21310020000000001317ff30624f2a75ffffffffffffffffffffffffffffffff
          2022-04-07 20:16:20.790 - debug: mihome-vacuum.0 (17770) MAIN: Connected to device, try to get model..
          2022-04-07 20:16:20.794 - debug: mihome-vacuum.0 (17770) Time difference between Mihome Vacuum and ioBroker: 1 sec
          2022-04-07 20:16:20.797 - debug: mihome-vacuum.0 (17770) GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.s5e","ack":true,"ts":1649355344903,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1649165771511}
          2022-04-07 20:16:20.799 - debug: mihome-vacuum.0 (17770) Message= {"id":1,"method":"miIO.info"}
          2022-04-07 20:16:22.803 - debug: mihome-vacuum.0 (17770) MIIO Receive Timeout for "miIO.info" <<<
          2022-04-07 20:16:22.804 - debug: mihome-vacuum.0 (17770) Get Device data..0
          • Diginix
            Diginix last edited by Diginix
            Funktioniert bei irgendwem mit 3.3.x noch spotclean?
            Wenn ich mihome-vacuum.0.control.spotclean auf true setze, bekomme ich nur folgende Logmeldung:
            2022-04-09 19:57:06.399 - warn: mihome-vacuum.0 (363741) Cant send command please try again "spotclean"
            Git issue: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/556
            Diginix created this issue in iobroker-community-adapters/ioBroker.mihome-vacuum
            closed Cant send command please try again "spotclean" #556
              saeft_2003 Most Active last edited by
              Hat schon jemand den S7 MaxV mit dem Adapter laufen?
              Meine Ultra ist heute gekommen 😬
              @Meistertr
              Kannst du sagen ob der Adapter den S7 MaxV und evtl. die Ultrastation unterstützt?!
                @Meistertr
                Der S7 MaxV läuft soweit mit dem Adapter.
                Bekommt man auch die rot markierten Infos der Ultra Station in den iobroker?
                  saeft_2003 Most Active last edited by saeft_2003
                  Hat irgendjemand von euch den S7 MaxV mit dem Adapter laufen? Geht bei euch der multiroomclean?
                  @Meistertr
                  Edit: Der Multiroomclean geht nur beim Saugen, wenn auch gewischt wird bringt die Ultra Station das ganze durcheinander. Ich habe es hier auf github beschrieben...
                  https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/570#issue-1221908175
                  saeft2003 created this issue in iobroker-community-adapters/ioBroker.mihome-vacuum
                  closed Multiroomclean S7 MaxV funktioniert zusammen mit der Ultra Station nicht! #570
                    dirkhe Developer @saeft_2003 last edited by
                    @saeft_2003 ich habe gestern mal reingeschaut, ich denke die erweiterten stati sollte man hinbekommen. Icn würde da jetzt auf guthub mit dir die lösung testen wollen und nicht hier, wenn es ok ist.
                      saeft_2003 Most Active @dirkhe last edited by
                      @dirkhe
                      Alles klar machen wir so 👍
                      • Diginix
                        @dirkhe Kannst du vllt auch was hier zu sagen bzw hast eine Idee? https://forum.iobroker.net/post/789063
                        Hier als issue mit debug Log: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/556
                        Das ging alles mal mit meinem Modell und dem Adapter. Entw. im Adapter ist was "verloren" gegangen oder die API hat sich geändert.
                          Spezialtrick last edited by
                          Besteht die Möglichkeit den Dream z10 Pro als neues Gerät im Adapter zu unterstützen? Ich habe bereits ein Issue im Github angelegt.
                          Der Dreame L10 Pro wird bereits unterstützt und ist im Grunde das gleiche Gerät wie der z10 Pro nur ohne Absaugstation. Möglicherweise ist die Einbindung daher einfach?
                            Ich brauche eure Hilfe. Und zwar will ich per custom command eine Raumreinigung starten. Der Befehl
                            cleansegments;[18,20]
                            Funktioniert leider nicht. Könnt ihr mir sagen wie genau der aussehen muss?
                            • Diginix
                              Diginix @saeft_2003 last edited by
                              @saeft_2003 Als ich das noch verwendet habe war es:
                              app_segment_clean;[20]
                              Die ID ist der mapindes des Raumes aus mihome-vacuum.0.rooms.*.mapIndex und es können kommasepariert mehrere ins Array.
                                saeft_2003 Most Active @Diginix last edited by
                                @diginix
                                Super das funktioniert 👍
                                  Rushmed Most Active last edited by
                                  Meine Instanz zeigt seit Neustem mehrmals täglich diese Fehlermeldung:
                                  mihome-vacuum.0
                                  2022-05-28 01:10:44.883	error	Error by saving of the map
                                  mihome-vacuum.0
                                  2022-05-28 01:10:44.882	error	Cannot write file actualMap_0.png: mihome-vacuum.admin is not an object of type "meta"
                                  Was kann ich dagegen tun?
                                    An alle Ultra Besitzer:
                                    Es gibt jetzt eine Version vom Adapter die anzeigt ob das Wasser von der Ultra Station leer ist oder nicht. Wurde von mir getestet und funktioniert 👍
                                    https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tree/584-ultra-station-meldung-wenn-wasser-leer
                                      dirkhe Developer last edited by
                                      @saeft_2003 ist schon released, 3.4.0
                                      S S 2 Replies Last reply Reply Quote 1
                                        Spezialtrick @dirkhe last edited by
                                        @dirkhe Hallo Dirk, besteht die Möglichkeit den Dream z10 Pro als neues Gerät im Adapter zu unterstützen? Ich habe bereits ein Issue im Github angelegt.
                                          dirkhe Developer @Spezialtrick last edited by
                                          @spezialtrick neue hardware hinzuzufügen, ohne sie selber zu besitzen, ust immer schwierig. Ich weiß auch nicht, wie meisterTr das immer gemacht hat. Funktioniert er den grundsätzlich mit dem adapter und es fehlen einzelne feature?
                                          Wenn ich mir den issue so ansehe, scheint der ja komplett neu zu sein.
                                            Spezialtrick @dirkhe last edited by Spezialtrick
                                            @dirkhe Ich bekomme die Meldung, dass das Gerät nicht unterstützt wird:
                                            Auf meinem Dreame läuft Valetudo.
                                            1.0k
                                            1198
                                            364333
