    3. Off Topic
    4. Proxmox
    5. Proxmox und iobroker
      Homoran Global Moderator Administrators @Marko1974 last edited by
      @marko1974 sagte in Proxmox und iobroker:
      ICH DREH DURCH
      was ist denn das für ein Dateiname?
      und warum mit restore 0 und nicht mit Dateinamen?
      Marko1974 1 Reply Last reply Reply Quote 0
      • Marko1974
        Marko1974 @Homoran last edited by
        The current version of js-controller differs from the version in the backup.
        The js-controller version of the backup can not be restored automatically.
        To restore the js-controller version of the backup, execute "npm i iobroker.js-controller@4.0.21 --production" inside your ioBroker directory
        If you really want to restore the backup with the current installed js-controller, execute the restore command with the --force flag
        openhabian@ioBroker:/opt/iobroker/backups$
          Homoran Global Moderator Administrators @Marko1974 last edited by Homoran
          was hattest du denn da?
          Also Neu-Installation
          Controller downgrade auf die Version im Backup
          dann restore
          EDIT:
          steht ja alles im log:
          To restore the js-controller version of the backup, execute "npm i iobroker.js-controller@4.0.21 --production" inside your ioBroker directory If you really want to restore the backup with the current installed js-controller, execute the restore command with the --force flag
          • Marko1974
            @homoran das lief aber gestern noch einfach durch und heute nicht mehr?
              Was hast du denn gestern ??? anders gemacht:
              github:	4.1.0
              latest:	4.0.23 for 11 days
              stable:	4.0.23 for 11 days
              • Marko1974
                Marko1974 @Homoran last edited by Marko1974
                @homoran hab mit dem npm befehl das downgrade gemacht....läuft jetzt
                host.ioBroker Processed 3000/6515 states
                host.ioBroker Processed 3200/6515 states
                host.ioBroker Processed 3400/6515 states
                host.ioBroker Processed 3600/6515 states
                host.ioBroker Processed 3800/6515 states
                host.ioBroker Processed 4000/6515 states
                host.ioBroker Processed 4200/6515 states
                host.ioBroker Processed 4400/6515 states
                host.ioBroker Processed 4600/6515 states
                host.ioBroker Processed 4800/6515 states
                host.ioBroker Processed 5000/6515 states
                host.ioBroker Processed 5200/6515 states
                host.ioBroker Processed 5400/6515 states
                host.ioBroker Processed 5600/6515 states
                host.ioBroker Processed 5800/6515 states
                host.ioBroker Processed 6000/6515 states
                host.ioBroker Processed 6200/6515 states
                host.ioBroker Processed 6400/6515 states
                6515 states restored.
                host.ioBroker Upload user file "vis/css/vis-common-user.css
                host.ioBroker Upload user file "vis.0/Heizungen/vis-user.css
                host.ioBroker Upload user file "vis.0/Heizungen/vis-views.json
                host.ioBroker Upload user file "vis.0/Test/vis-user.css
                host.ioBroker Upload user file "vis.0/Test/vis-views.json
                Reinstalling adapter "admin" from "iobroker.admin@5.3.8"
                + iobroker.admin@5.3.8
                added 71 packages from 89 contributors in 15.363s
                22 packages are looking for funding
                  run `npm fund` for details
                Reinstalling adapter "backitup" from "iobroker.backitup@2.4.6"
                + iobroker.backitup@2.4.6
                added 68 packages from 51 contributors in 8.773s
                26 packages are looking for funding
                System successfully restored!
                openhabian@ioBroker:/opt/iobroker$
                  siehste: lesen und befolgen
                  • Marko1974
                    @homoran dass er nach nem start aber nicht direkt verbindet ist normal?
                    openhabian@ioBroker:/opt/iobroker$ iobroker start
                    openhabian@ioBroker:/opt/iobroker$ iob status
                    Objects type: jsonl
                    States  type: jsonl
                    openhabian@ioBroker:/opt/iobroker$ iobroker list instances
                    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8111, bind: 0.0.0.0, run as: admin
                      system.adapter.alarm.0                  : alarm                 : ioBroker                                 - disabled
                      system.adapter.alexa2.0                 : alexa2                : ioBroker                                 - disabled
                      system.adapter.amazon-dash.0            : amazon-dash           : ioBroker                                 - disabled
                    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                      system.adapter.cul.0                    : cul                   : ioBroker                                 - disabled, port: 23
                      system.adapter.deconz.0                 : deconz                : ioBroker                                 - disabled, port: 80
                      system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 - disabled
                      system.adapter.device-reminder.1        : device-reminder       : ioBroker                                 - disabled
                      system.adapter.eusec.0                  : eusec                 : ioBroker                                 - disabled
                      system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker                                 - disabled
                      system.adapter.fritzdect.0              : fritzdect             : ioBroker                                 - disabled
                      system.adapter.habpanel.0               : habpanel              : ioBroker                                 - disabled
                      system.adapter.harmony.0                : harmony               : ioBroker                                 - disabled
                      system.adapter.history.0                : history               : ioBroker                                 - disabled
                      system.adapter.hue-extended.0           : hue-extended          : ioBroker                                 - disabled
                      system.adapter.hue.0                    : hue                   : ioBroker                                 - disabled, port: 443
                      system.adapter.javascript.0             : javascript            : ioBroker                                 - disabled
                      system.adapter.maxcube.0                : maxcube               : ioBroker                                 - disabled, port: 62910, bind: 0.0.0.0
                      system.adapter.mihome.0                 : mihome                : ioBroker                                 - disabled, port: 9898, bind: 192.168.178.72
                      system.adapter.node-red.0               : node-red              : ioBroker                                 - disabled, port: 1880, bind: 0.0.0.0
                      system.adapter.shelly.0                 : shelly                : ioBroker                                 - disabled, port: 1882, bind: 0.0.0.0
                      system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 - disabled
                      system.adapter.telegram.0               : telegram              : ioBroker                                 - disabled, port: 8443, bind: 0.0.0.0
                      system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 - disabled
                      system.adapter.web.0                    : web                   : ioBroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                      system.adapter.wled.0                   : wled                  : ioBroker                                 - disabled
                      system.adapter.yahka.1                  : yahka                 : ioBroker                                 - disabled
                      system.adapter.yahka.2                  : yahka                 : ioBroker                                 - disabled
                    + instance is alive
                    Ich war falsch....anderer port 🙂
                    • Marko1974
                      Marko1974 @Marko1974 last edited by
                      @marko1974 node red hat er aber nicht gemacht....oder dauert das?
                      crunchip Homoran 2 Replies Last reply Reply Quote 0
                        crunchip Forum Testing Most Active @Marko1974 last edited by
                        @marko1974 das dauert ne Weile
                        • Marko1974
                          Marko1974 @crunchip last edited by
                          @crunchip jetzt muss ich den raspberry abnabeln und dem neuen Teil die gleiche IP geben. da kann ich doch einfach nur den ip im container ändern, richtig?
                            jetzt warte doch bis er fertig ist.
                            kann bis zu einer Stunde dauern
                            • Marko1974
                              @homoran mit instanzen installieren ist er fertig...steht alles auf stop
                                und "hunderte" andere Instanzen auch noch nicht.
                                Die müssen jetzt alle erst neu für die geänderte Hardware und node-Version (?) gebaut werden
                                sicher?
                                oder nur das Einlesen der Konfigs
                                  @marko1974
                                  welche IP
                                  • Marko1974
                                    @homoran im protokoll ist er aber fertig
                                    • Marko1974
                                      @crunchip die vom alten raspberry....sonst muss ich jeden adapter manuell anpassen, oder?
                                        Mann!!
                                        Beweise! Keine Nacherzählungen!!
                                        Sonst sind wir es nachher schuld.
                                        Im Protokoll steht Restore fertig
                                        Das heisst nur dass die Dateien zurückgeschrieben wurde
                                        wieso jeden?
                                        nur die paar wenigen, die eine Callback.- oder Adapteradresse drin haben
                                          @marko1974 ich raffs immer noch nicht, dein Iobroker lief doch in einem ganz anderen Netz
                                          Homoran Marko1974 2 Replies Last reply Reply Quote 0
                                          • Marko1974
                                            @homoran ich kann ihn auch einfach auf der ip lassen....ich dachte nur, wenn ich zu Geräten wie xiaomi connecte wäre es gut, wenn alles gleich wäre
                                            1.2k
                                            81.1k
                                            25560
