    3. Off Topic
    4. Proxmox
    5. Proxmox und iobroker
    • Marko1974
      Marko1974 @Homoran last edited by Marko1974
      @homoran dass er nach nem start aber nicht direkt verbindet ist normal?
      System successfully restored!
      openhabian@ioBroker:/opt/iobroker$ iobroker start
      openhabian@ioBroker:/opt/iobroker$ iob status
      Objects type: jsonl
      States  type: jsonl
      openhabian@ioBroker:/opt/iobroker$ iobroker list instances
      + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8111, bind: 0.0.0.0, run as: admin
        system.adapter.alarm.0                  : alarm                 : ioBroker                                 - disabled
        system.adapter.alexa2.0                 : alexa2                : ioBroker                                 - disabled
        system.adapter.amazon-dash.0            : amazon-dash           : ioBroker                                 - disabled
      + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
        system.adapter.cul.0                    : cul                   : ioBroker                                 - disabled, port: 23
        system.adapter.deconz.0                 : deconz                : ioBroker                                 - disabled, port: 80
        system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 - disabled
        system.adapter.device-reminder.1        : device-reminder       : ioBroker                                 - disabled
        system.adapter.eusec.0                  : eusec                 : ioBroker                                 - disabled
        system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker                                 - disabled
        system.adapter.fritzdect.0              : fritzdect             : ioBroker                                 - disabled
        system.adapter.habpanel.0               : habpanel              : ioBroker                                 - disabled
        system.adapter.harmony.0                : harmony               : ioBroker                                 - disabled
        system.adapter.history.0                : history               : ioBroker                                 - disabled
        system.adapter.hue-extended.0           : hue-extended          : ioBroker                                 - disabled
        system.adapter.hue.0                    : hue                   : ioBroker                                 - disabled, port: 443
        system.adapter.javascript.0             : javascript            : ioBroker                                 - disabled
        system.adapter.maxcube.0                : maxcube               : ioBroker                                 - disabled, port: 62910, bind: 0.0.0.0
        system.adapter.mihome.0                 : mihome                : ioBroker                                 - disabled, port: 9898, bind: 192.168.178.72
        system.adapter.node-red.0               : node-red              : ioBroker                                 - disabled, port: 1880, bind: 0.0.0.0
        system.adapter.shelly.0                 : shelly                : ioBroker                                 - disabled, port: 1882, bind: 0.0.0.0
        system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 - disabled
        system.adapter.telegram.0               : telegram              : ioBroker                                 - disabled, port: 8443, bind: 0.0.0.0
        system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 - disabled
        system.adapter.web.0                    : web                   : ioBroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.wled.0                   : wled                  : ioBroker                                 - disabled
        system.adapter.yahka.1                  : yahka                 : ioBroker                                 - disabled
        system.adapter.yahka.2                  : yahka                 : ioBroker                                 - disabled
      + instance is alive
      Ich war falsch....anderer port 🙂
      Marko1974 1 Reply Last reply Reply Quote 0
      • Marko1974
        Marko1974 @Marko1974 last edited by
        @marko1974 node red hat er aber nicht gemacht....oder dauert das?
        crunchip Homoran 2 Replies Last reply Reply Quote 0
          crunchip Forum Testing Most Active @Marko1974 last edited by
          @marko1974 das dauert ne Weile
          • Marko1974
            Marko1974 @crunchip last edited by
            @crunchip jetzt muss ich den raspberry abnabeln und dem neuen Teil die gleiche IP geben. da kann ich doch einfach nur den ip im container ändern, richtig?
              Homoran Global Moderator Administrators @Marko1974 last edited by
              @marko1974 sagte in Proxmox und iobroker:
              jetzt warte doch bis er fertig ist.
              kann bis zu einer Stunde dauern
              • Marko1974
                @homoran mit instanzen installieren ist er fertig...steht alles auf stop
                  Homoran Global Moderator Administrators @Marko1974 last edited by Homoran
                  und "hunderte" andere Instanzen auch noch nicht.
                  Die müssen jetzt alle erst neu für die geänderte Hardware und node-Version (?) gebaut werden
                  sicher?
                  oder nur das Einlesen der Konfigs
                    @marko1974
                    welche IP
                    • Marko1974
                      @homoran im protokoll ist er aber fertig
                      • Marko1974
                        @crunchip die vom alten raspberry....sonst muss ich jeden adapter manuell anpassen, oder?
                          Mann!!
                          Beweise! Keine Nacherzählungen!!
                          Sonst sind wir es nachher schuld.
                          Im Protokoll steht Restore fertig
                          Das heisst nur dass die Dateien zurückgeschrieben wurde
                          wieso jeden?
                          nur die paar wenigen, die eine Callback.- oder Adapteradresse drin haben
                            @marko1974 ich raffs immer noch nicht, dein Iobroker lief doch in einem ganz anderen Netz
                            Homoran Marko1974 2 Replies Last reply Reply Quote 0
                            • Marko1974
                              @homoran ich kann ihn auch einfach auf der ip lassen....ich dachte nur, wenn ich zu Geräten wie xiaomi connecte wäre es gut, wenn alles gleich wäre
                                Homoran Global Moderator Administrators @crunchip last edited by Homoran
                                @crunchip sagte in Proxmox und iobroker:
                                Ich glaube den Pi hat er auch kurz bei seinen Eltern installiert um ein neues Backup zu ziehen
                                kenne ich nicht, klingt aber wie MQTT, wo in den Geräten die MQTT-Broker-IP angegeben ist.
                                Dann kann es durchaus sinnvoll sein.
                                ABER erst, wenn wirklich alles fertig ist
                                • Marko1974
                                  Marko1974 @crunchip last edited by Marko1974
                                  @crunchip said in Proxmox und iobroker:
                                  NEIN! Der iobroker lief hier bei meinen Eltern. Auf nem Raspberry der jetzt aktuell auch läuft.
                                  Stand jetzt ist: Wir ziehen einfach nur um auf ein neues system.
                                  Genau das hatte ich versucht bei MIR ZUHAUSE vorzubereiten. In einem anderem Netz.
                                    per mihome?
                                    Instanzen die z.b. mqtt sprechen musst du die IP anpassen
                                      @marko1974 ach jetzt hats geklingelt
                                      • Marko1974
                                        @crunchip Eben...und ich dachte wenn ich jetzt den Raspberry ausmache und vom netz trenne....dann dem Container die IP des RPI gebe....der ja dann nicht mehr am Netz ist, wäre es einfacher
                                          @homoran sagte in Proxmox und iobroker:
                                          und???
                                          Marko1974 Homoran 2 Replies Last reply Reply Quote 0
                                          • Marko1974
                                            @homoran said in Proxmox und iobroker:
                                            und???
                                            na was ist besser?
                                            81.1k
                                            25537
