    4. Probleme von 4.0.21 auf 4.0.23
      crunchip Forum Testing Most Active @SMS last edited by crunchip
      @sms zeig mal das ganze
      bzw warum steht da bei dir
       "period": 7200000,
      da sollte eigentlich stehen
      "period": 120,
      SMS 1 Reply Last reply Reply Quote 0
      • SMS
        SMS @crunchip last edited by
        @crunchip
          "system": {
            "memoryLimitMB": 0,
            "hostname": "",
            "statisticsInterval": 15000,
            "statisticsIntervalComment": "Interval how often the counters for input/output in adapters and controller will be updated",
            "checkDiskInterval": 300000,
            "checkDiskIntervalComment": "Interval how often the disk size will be checked",
            "noChmod": false,
            "noChmodComment": "Flag to test new feature with no chmod call. Must be deleted later and noChmod must be mainline (2018.06.04)"
          "multihostService": {
            "enabled": false,
            "secure": true,
            "password": "$/aes-192-cbc:57baf591ede4a6503d9c6d7ec6fff138:48b6ff491fe7c14e844b06583acf7cb3",
            "persist": false
          "network": {
            "IPv4": true,
            "IPv6": true,
            "bindAddress": null
          "objects": {
            "type": "jsonl",
            "typeComment": "Possible values: 'file' - [port 9001], redis - [port 6379], couch - [port 5984].",
            "host": "0.0.0.0",
            "port": 9001,
            "user": "",
            "pass": "",
            "noFileCache": false,
            "connectTimeout": 2000,
            "backup": {
              "disabled": false,
              "files": 24,
              "filesComment": "Minimal number of backup files, after the deletion will be executed according to backupTime settings",
              "hours": 48,
              "hoursComment": "All backups older than 48 hours will be deleted. But only if the number of files is greater than of backupNumber",
              "period": 7200000,
              "periodComment": "by default backup every 2 hours. Time is in minutes. To disable backup set the value to 0",
              "path": "",
              "pathComment": "Absolute path to backup directory or empty to backup in data directory"
            "options": {
              "auth_pass": null,
              "enableReadyCheck": true,
              "host": "0.0.0.0",
              "port": 9001,
              "db": 0,
              "family": 0,
              "password": null,
              "autoResubscribe": false,
              "connectionName": "host.homee"
            "maxQueue": 1000,
            "dataDir": "../../iobroker-data/"
          "states": {
        "type": "jsonl",
            "typeComment": "Possible values: 'file' - [port 9000], 'redis' - [port 6379].",
            "host": "0.0.0.0",
            "port": 9000,
            "maxQueue": 1000,
            "options": {
              "auth_pass": null,
              "host": "0.0.0.0",
              "port": 9000,
              "db": 0,
              "family": 0,
              "password": null,
            "backup": {
              "disabled": false,
              "files": 24,
              "hours": 48,
              "period": 7200000,
              "path": "",
         "log": {
            "level": "info",
            "maxDays": 7,
            "noStdout": true,
            "transport": {
              "file1": {
                "type": "file",
                "enabled": true,
                "filename": "log/iobroker",
                "fileext": ".log",
                "maxsize": null,
                "maxFiles": null
              "syslog1": {
                "type": "syslog",
                "enabled": false,
                "host": "localhost",
                "host_comment": "The host running syslogd, defaults to localhost.",
                "port_comment": "The port on the host that syslog is running on, defaults to syslogd's default port(514/UDP).",
                "protocol": "udp4",
                "protocol_comment": "The network protocol to log over (e.g. tcp4, udp4, unix, unix-connect, etc).",
                "path_comment": "The path to the syslog dgram socket (i.e. /dev/log or /var/run/syslog for OS X).",
                "facility_comment": "Syslog facility to use (Default: local0).",
                "localhost": "iobroker",
                "localhost_comment": "Host to indicate that log messages are coming from (Default: localhost).",
                "sysLogType_comment": "The type of the syslog protocol to use (Default: BSD).",
                "app_name_comment": "The name of the application (Default: process.title).",
                "eol_comment": "The end of line character to be added to the end of the message (Default: Message without modifications)."
          "dataDirComment": "Always relative to iobroker.js-controller/",
          @sms dann ruf es mal auf mit
          sudo nano  /opt/iobroker/iobroker-data/iobroker.json
          ändere die Zeile
          "period": 7200000,
          in
          "period": 120,
          abspeichern
          • SMS
            @crunchip
            kommt zweimal vor
              @sms ja einmal für objects und einmal für states, beides ändern
              • SMS
                SMS @crunchip last edited by SMS
                @crunchip
                Diesmal lief es ohne diese Meldung durch, doch bin ich immer noch bei 4.0.21 und nicht auf 4.0.23.
                pi@homee:/opt/iobroker $ iob upgrade self
                Update js-controller from @4.0.21 to @4.0.23
                Stopped Objects DB
                Stopped States DB
                NPM version: 6.14.16
                Installing iobroker.js-controller@4.0.23... (System call)
                pi@homee:/opt/iobroker $ iob start
                  @sms dann eventuell manuell installieren, im richtigen Verzeichnis /opt/iobroker
                  sudo -H -u iobroker npm install iobroker.js-controller
                  aber warte mal was @apollon77 dazu sagt
                    apollon77 last edited by apollon77
                    ääähhmm mal ganz Langsam ...
                    Die Meldung mit 120 ist eine Warnung. Die halt nichts zu sagen. Es gibt auch keinen Fehler der sagt das das Update nicht getan hat.
                    Aber ja die Meldung mach so keinen sinn (der Code setz den korrigierten Wert bevor es die Fehlemeldung schreibt - fixen wir in Zukunft), aber auch ja: das "period" ist das Problem. Aber wie gesagt es wird nur automatisch korrigiert.
                    Was ist denn genau das Problem?
                    SMS M 2 Replies Last reply Reply Quote 0
                    • SMS
                      SMS @apollon77 last edited by
                      @apollon77
                      es wird nicht upgedatet
                        Thomas Braun Most Active @SMS last edited by
                        @sms
                        iobroker upload all
                        mal versucht?
                        • SMS
                          SMS @Thomas Braun last edited by
                          läuft, aber die Adapter sind ja nicht das Problem
                            @sms
                            Ich weiß nicht, ob die js-controller Dateien nicht auch hochgeladen werden müssen. Im Zweifel schadet es aber auch nicht.
                              frage wäre auch was genau im Log steht wenn der Controller startet ... steht da im Log 4.0.21 oder 4.0.23? (bzwe auch im lgo sobald du nen adapter startest)
                              • SMS
                                @apollon77
                                im Log steht 4.0.21
                                  @sms was zeigt
                                  iob list instances
                                  führe es doch nochmal komplett aus nach der json Änderung.
                                  iob stop
                                  iob update
                                  iob fix
                                  iob upgrade self
                                  iob start
                                  Und zeige die jeweilige Ausgabe/Meldungen
                                    Naja dann komisch, aber dann versuch mal manuell.
                                    iob stoppen und so und dann cd /opt/iobroker und npm i iobroker.js-controller@4.0.23
                                    Dann schau mal was die Ausgabe ist
                                    • SMS
                                      @apollon77
                                      pi@homee:/opt/iobroker $ npm i iobroker.js-controller@4.0.23
                                      npm WARN registry Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning EINTEGRITY: sha512-yqtb2zJfC5wYJXUED8+Ddt6qQU/TfZskQQb6BQHa9mMW5zVtsH5FPAoW68ZxgpVnpGbdhxlHjJKGm+bBT61qfg== integrity checksum failed when using sha512: wanted sha512-yqtb2zJfC5wYJXUED8+Ddt6qQU/TfZskQQb6BQHa9mMW5zVtsH5FPAoW68ZxgpVnpGbdhxlHjJKGm+bBT61qfg== but got sha512-LkcflZM5A/cIdp/jEYw337AUa37YV6Cq5dU2KYTcEivEOJNT4djYhx6dnWYn5HOevf8bHI4RQQO+eV+ZUa17+Q==. (2075 bytes)
                                      npm WARN registry Using stale data from https://registry.npmjs.org/ due to a request error during revalidation.
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: le-acme-core@^2.1.4 (node_modules/iobroker.js-controller/node_modules/le-acme-core):
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Invalid response body while trying to fetch https://registry.npmjs.org/le-acme-core: Integrity verification failed for sha512-1hQ1xw6Yvb2BAR9+PgJPFr38T8PNfG60qgsiUsV8OXv/OKT7w1Qg5T3yfON0XBCiPE44E3Mnlr7TA2Lgaq0PiQ== (/home/iobroker/.npm/_cacache/content-v2/sha512/d6/14/35c70e98bdbd81011f7e3e024f16bdfc4fc3cd7c6eb4aa0b2252c57c397bff38a4fbc35420e53df27ce3745c10a23c4e3813732796bed30362e06aad0f89)
                                      npm ERR! code EINTEGRITY
                                      npm ERR! errno EINTEGRITY
                                      npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/daemonize2: Integrity verification failed for sha512-yqtb2zJfC5wYJXUED8+Ddt6qQU/TfZskQQb6BQHa9mMW5zVtsH5FPAoW68ZxgpVnpGbdhxlHjJKGm+bBT61qfg== (/home/iobroker/.npm/_cacache/content-v2/sha512/ca/ab/5bdb325f0b9c182575040fcf8376deaa414fd37d9b244106fa0501daf66316e7356db07e453c0a16ebc671829567a466dd8719478c92869be6c14fad6a7e)
                                      npm ERR!     /home/iobroker/.npm/_logs/2022-05-02T12_09_16_620Z-debug.log
                                      • SMS
                                        @crunchip
                                        pi@homee:/opt/iobroker $ iob list instances
                                          system.adapter.admin.0                  : admin                 : homee                                    -  enabled, port: 7777, bind: 0.0.0.0, run as: admin
                                          system.adapter.admin.1                  : admin                 : MotionEye                                - disabled, port: 7777, bind: 0.0.0.0, run as: admin
                                          system.adapter.backitup.0               : backitup              : homee                                    -  enabled
                                          system.adapter.binance.0                : binance               : homee                                    - disabled
                                          system.adapter.coronavirus-statistics.0 : coronavirus-statistics: homee                                    -  enabled
                                          system.adapter.daswetter.0              : daswetter             : homee                                    -  enabled
                                          system.adapter.devices.0                : devices               : homee                                    - disabled
                                          system.adapter.discovery.0              : discovery             : homee                                    -  enabled
                                          system.adapter.ds18b20.1                : ds18b20               : kellerkind4GB                            -  enabled
                                          system.adapter.ds18b20.2                : ds18b20               : MotionEye                                - disabled
                                          system.adapter.ds18b20.3                : ds18b20               : PapaHuette                               -  enabled
                                          system.adapter.dwd.0                    : dwd                   : homee                                    -  enabled
                                          system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : homee                                    -  enabled
                                          system.adapter.email.0                  : email                 : homee                                    -  enabled
                                          system.adapter.fritzbox.0               : fritzbox              : homee                                    - disabled
                                          system.adapter.growatt.0                : growatt               : homee                                    -  enabled
                                          system.adapter.ical.0                   : ical                  : homee                                    -  enabled
                                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : homee                                    - disabled
                                          system.adapter.influxdb.0               : influxdb              : homee                                    -  enabled, port: 8086
                                          system.adapter.javascript.0             : javascript            : homee                                    -  enabled
                                          system.adapter.modbus.1                 : modbus                : kellerkind4GB                            - disabled
                                          system.adapter.modbus.2                 : modbus                : kellerkind4GB                            - disabled
                                          system.adapter.mqtt.0                   : mqtt                  : homee                                    -  enabled, port: 1886, bind: 0.0.0.0
                                          system.adapter.nina.0                   : nina                  : homee                                    -  enabled
                                          system.adapter.parser.0                 : parser                : homee                                    - disabled
                                          system.adapter.pegelalarm.0             : pegelalarm            : homee                                    -  enabled
                                          system.adapter.pegelalarm.1             : pegelalarm            : homee                                    -  enabled
                                          system.adapter.pollenflug.0             : pollenflug            : homee                                    -  enabled
                                          system.adapter.rpi2.0                   : rpi2                  : homee                                    -  enabled
                                          system.adapter.rpi2.1                   : rpi2                  : kellerkind4GB                            -  enabled
                                          system.adapter.rpi2.2                   : rpi2                  : MotionEye                                - disabled
                                          system.adapter.rpi2.3                   : rpi2                  : PapaHuette                               -  enabled
                                          system.adapter.rpi2.4                   : rpi2                  : Gartenklo                                -  enabled
                                          system.adapter.smartmeter.0             : smartmeter            : homee                                    -  enabled
                                          system.adapter.sonoff.0                 : sonoff                : homee                                    -  enabled, port: 1883, bind: 0.0.0.0
                                          system.adapter.systeminfo.0             : systeminfo            : homee                                    -  enabled
                                          system.adapter.systeminfo.1             : systeminfo            : kellerkind4GB                            -  enabled
                                          system.adapter.systeminfo.2             : systeminfo            : MotionEye                                - disabled
                                          system.adapter.systeminfo.3             : systeminfo            : PapaHuette                               -  enabled
                                          system.adapter.systeminfo.4             : systeminfo            : Gartenklo                                -  enabled
                                          system.adapter.tankerkoenig.0           : tankerkoenig          : homee                                    -  enabled
                                          system.adapter.vis-bars.0               : vis-bars              : homee                                    - disabled
                                          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : homee                                    - disabled
                                          system.adapter.vis-history.0            : vis-history           : homee                                    - disabled
                                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : homee                                    - disabled
                                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : homee                                    - disabled
                                          system.adapter.vis-justgage.0           : vis-justgage          : homee                                    - disabled
                                          system.adapter.vis-metro.0              : vis-metro             : homee                                    - disabled
                                          system.adapter.vis-plumb.0              : vis-plumb             : homee                                    - disabled
                                          system.adapter.vis-rgraph.0             : vis-rgraph            : homee                                    - disabled
                                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : homee                                    - disabled
                                          system.adapter.vis.0                    : vis                   : homee                                    -  enabled
                                          system.adapter.web.0                    : web                   : homee                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                          system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : Gartenklo                                - disabled
                                          system.adapter.worx.2                   : worx                  : PapaHuette                               -  enabled
                                        + instance is alive
                                        pi@homee:/opt/iobroker $ iob update
                                        Used repository: Stable (default)
                                        Adapter    "admin"        : 5.3.8    , installed 5.3.1  [Updatable]
                                        Adapter    "backitup"     : 2.4.6    , installed 2.3.3  [Updatable]
                                        Adapter    "binance"      : 1.1.3    , installed 1.1.3
                                        Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                                        Adapter    "daswetter"    : 3.1.2    , installed 3.0.9  [Updatable]
                                        Adapter    "devices"      : 1.0.10   , installed 1.0.10
                                        Adapter    "discovery"    : 3.0.3    , installed 3.0.3
                                        Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                                        Adapter    "ecovacs-deebot": 1.3.3   , installed 1.3.3
                                        Adapter    "email"        : 1.0.10   , installed 1.0.10
                                        Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
                                        Adapter    "growatt"      : 1.1.15   , installed 1.1.13 [Updatable]
                                        Adapter    "ical"         : 1.12.1   , installed 1.12.1
                                        Adapter    "influxdb"     : 2.6.3    , installed 2.6.3
                                        Adapter    "javascript"   : 5.2.21   , installed 5.2.21
                                        Controller "js-controller": 4.0.23   , installed 4.0.21 [Updatable]
                                        Adapter    "mqtt"         : 2.7.4    , installed 2.4.1  [Updatable]
                                        Adapter    "nina"         : 0.0.25   , installed 0.0.25
                                        Adapter    "parser"       : 1.1.4    , installed 1.0.7  [Updatable]
                                        Adapter    "pegelalarm"   : 1.2.5    , installed 1.2.5
                                        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                                        Adapter    "simple-api"   : 2.6.4    , installed 2.6.4
                                        Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                                        Adapter    "sonoff"       : 2.5.0    , installed 2.5.0
                                        Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
                                        Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
                                        Adapter    "vis"          : 1.4.15   , installed 1.4.15
                                        Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
                                        Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
                                        Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                                        Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
                                        Adapter    "web"          : 4.2.3    , installed 4.2.0  [Updatable]
                                        Adapter    "ws"           : 1.2.0    , installed 1.3.0
                                        pi@homee:/opt/iobroker $ iob fix
                                        library: loaded
                                        Library version=2022-02-10
                                            Welcome to the ioBroker installation fixer!
                                            Script version: 2022-02-13
                                            You might need to enter your password a couple of times.
                                            Installing prerequisites (1/3)
                                        OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                        OK:2 http://archive.raspberrypi.org/debian buster InRelease
                                        OK:3 https://repos.influxdata.com/debian buster InRelease
                                        OK:4 https://deb.nodesource.com/node_14.x buster InRelease
                                        OK:5 https://archive.raspbian.org/raspbian buster InRelease
                                        Installed gcc-c++
                                            Checking ioBroker user and directory permissions (2/3)
                                        Created /etc/sudoers.d/iobroker
                                        Fixing directory permissions...
                                            Checking autostart (3/3)
                                        Enabling autostart...
                                        Autostart enabled!
                                            Your installation was fixed successfully
                                            Run iobroker start to start ioBroker again!
                                        Stopped Objects DB
                                        Stopped States DB
                                          @sms
                                          npm cache mal löschen und nochmal den Download versuchen.
                                          • SMS
                                            SMS last edited by
                                            pi@homee:/ $ npm cache clean
                                            npm ERR! As of npm@5, the npm cache self-heals from corruption issues and data extracted from the cache is guaranteed to be valid. If you want to make sure everything is consistent, use 'npm cache verify' instead. On the other hand, if you're debugging an issue with the installer, you can use `npm install --cache /tmp/empty-cache` to use a temporary cache instead of nuking the actual one.
                                            npm ERR!
                                            npm ERR! If you're sure you want to delete the entire cache, rerun this command with --force.
                                            npm ERR!     /home/pi/.npm/_logs/2022-05-02T12_18_38_690Z-debug.log
                                            pi@homee:/ $
                                            8903
