    4. Probleme von 4.0.21 auf 4.0.23
      Thomas Braun Most Active @SMS last edited by
      @sms
      npm cache mal löschen und nochmal den Download versuchen.
      • SMS
        SMS last edited by
        pi@homee:/ $ npm cache clean
        npm ERR! As of npm@5, the npm cache self-heals from corruption issues and data extracted from the cache is guaranteed to be valid. If you want to make sure everything is consistent, use 'npm cache verify' instead. On the other hand, if you're debugging an issue with the installer, you can use `npm install --cache /tmp/empty-cache` to use a temporary cache instead of nuking the actual one.
        npm ERR!
        npm ERR! If you're sure you want to delete the entire cache, rerun this command with --force.
        npm ERR!     /home/pi/.npm/_logs/2022-05-02T12_18_38_690Z-debug.log
        pi@homee:/ $
          @sms sagte in Probleme von 4.0.21 auf 4.0.23:
          sudo -H -u iobroker npm cache clean --force
          SMS 1 Reply Last reply Reply Quote 0
          • SMS
            SMS @Thomas Braun last edited by
            pi@homee:/opt/iobroker $ sudo -H -u iobroker npm cache clean --force
            npm WARN using --force I sure hope you know what you are doing.
              @sms
              iobroker update -u
              iobroker upgrade
              • SMS
                danach nochmal?
                iob stop
                iob update
                iob fix
                iob upgrade self
                iob start
                • SMS
                  SMS @SMS last edited by
                  @sms
                  pi@homee:/opt/iobroker $ iob upgrade self
                  Update js-controller from @4.0.21 to @4.0.23
                  Stopped Objects DB
                  Stopped States DB
                  NPM version: 6.14.16
                  Installing iobroker.js-controller@4.0.23... (System call)
                  > iobroker.js-controller@4.0.23 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                  > node lib/preinstallCheck.js
                  > iobroker.js-controller@4.0.23 install /opt/iobroker/node_modules/iobroker.js-controller
                  > node iobroker.js setup first
                  object _design/system updated
                    "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----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\r\n8c+yRUy82NcZpXaF02W9GpliRchYH815EJbHG6qgSu5qOhmoPWcJ\r\n-----END RSA PRIVATE KEY-----\r\n",
                    "defaultPublic": "-----BEGIN CERTIFICATE-----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\r\nDtENDH2XeedS+IRTE8uD/gGLjylBE6+5PJ1eKw==\r\n-----END CERTIFICATE-----\r\n"
                  Update certificate defaultPrivate
                  The object "system.certificates" was updated successfully.
                  Update certificate defaultPublic
                  ioBroker configuration updated
                  + iobroker.js-controller@4.0.23
                  removed 8 packages and updated 24 packages in 206.607s
                  47 packages are looking for funding
                    run `npm fund` for details
                  Jetzt hat es geklappt. Muss ich das bei den Slaves auch machen?
                    @sms
                    Du solltest ALLES auf Stand bringen. Alle Adapter auf Master und Slaves, alle js-controller auf Master und Slaves.
                    SMS 1 Reply Last reply Reply Quote 1
                    • SMS
                      Alles auf den aktuellen Stand gebracht.
                      Nun habe ich allerdings das Proble, das meine GPIO's nicht mehr schalten.
                      Hier springt es zwar von false auf true:
                      aber am Pi selbst passiert nichts. Woran kann das jetzt wieder liegen?
                        Keine Ahnung. Hört sich aber eher nach der Hardware an. Kann man im raspi-config nicht irgendwas diesbezüglich einstellen?
                        • SMS
                          SMS last edited by SMS
                          Ich habe dort ja nichts geändert. Oder kann das durch Updates's vorkommen?
                            Thomas Braun Most Active @SMS last edited by Thomas Braun
                            Oder kann das doch Updates's vorkommen?
                            Welche Adapter sind denn da jetzt aktualisiert worden? Und woher kommt der microfitzelskleine Screenshot?
                            Auch Betriebssystem auf Stand gebracht?
                            Mi GPIOs hab ich aber nix am Hut, da muss dir wer anders helfen.
                            • SMS
                              SMS @Thomas Braun last edited by SMS
                              Ich lasse mal das hier durchlaufen:
                              pi@kellerkind4GB:~ $ iob stop
                              pi@kellerkind4GB:~ $ iobroker update -u
                              Used repository: Stable (default)
                              Adapter    "admin"        : 5.3.8    , installed 5.1.25 [Updatable]
                              Adapter    "backitup"     : 2.4.6    , installed 2.2.2  [Updatable]
                              Adapter    "discovery"    : 3.0.3    , installed 2.7.0  [Updatable]
                              Adapter    "growatt"      : 1.1.15   , installed 1.1.1  [Updatable]
                              Adapter    "info"         : 1.9.18   , installed 1.9.8  [Updatable]
                              Adapter    "modbus"       : 4.0.4    , installed 3.4.11 [Updatable]
                              Adapter    "rpi2"         : 1.3.2    , installed 1.3.1  [Updatable]
                              pi@kellerkind4GB:~ $ iobroker upgrade
                              Aktualisiert wird alles bis auf modbus, den brauch ich nicht mehr.
                              Der Screenshot ist aus den Objekten. Betriebssystem ist auf aktuellem Stand.
                              Es handelt sich hierbei um einen Slave!
                                Von welcher Instanz denn?
                                Und patch die Systeme durch. Danach kann man sich das dann anschauen.
                                Warum läuft auf dem kellerkind überhaupt ein Admin? Das ist doch ein slave-System, oder?
                                • SMS
                                  rpi2.
                                  Nun geht's wieder!
                                  worin liegt denn der Unterschied? iobroker upgrade und iob upgrade self
                                    iobroker upgrade
                                    zieht die Adapter aktuell,
                                    iobroker upgrade self
                                    dann danach den js-controller selber.
                                    Und
                                    iobroker update
                                    schaut nur, welche Updates anstehen.
                                    • SMS
                                      also immer upgrade und dann upgrade self?
                                        @sms
                                        Immer zuerst schauen:
                                        iobroker update -u
                                        iobroker upgrade
                                        Den js-controller upgraded man ja nicht sooo häufig. Jedenfalls nicht im 'stable'-Zweig.
                                        • SMS
                                          OK, Danke!!
                                          • SMS
                                            Hi!
                                            Sorry, ich nochmal!
                                            Seit dem Update wird es immer schlimmer! Die Auslastung meines Masters steigt mittlerweile dauerhaft über 4,5%. Wäre soweit nicht schlimm, aber es wird alles langsamer.
                                            Heute bemerkte ich,das ich erschwert bis gar nicht mehr auf die Seite mit den Skripten komme. Die Seite bleibt (in meinem Fall) dunkel.
                                            Hier mal ein Auszug vom LOG:
                                            rpi2.1
                                            2022-05-05 22:25:27.099	error	No Value found for cpu_frequency
                                            host.kellerkind4GB
                                            2022-05-05 22:25:16.144	error	States database error: connect ECONNREFUSED 192.168.178.58:9000
                                            host.kellerkind4GB
                                            2022-05-05 22:25:15.423	error	Objects database error: connect ECONNREFUSED 192.168.178.58:9001
                                            host.kellerkind4GB
                                            2022-05-05 22:24:05.464	error	States database error: write EPIPE
                                            host.kellerkind4GB
                                            2022-05-05 22:23:42.395	error	States database error: connect ECONNREFUSED 192.168.178.58:9000
                                            host.kellerkind4GB
                                            2022-05-05 22:23:37.478	error	Cannot find view "system" for search "instance" : Connection is closed.
                                            host.kellerkind4GB
                                            2022-05-05 22:23:37.474	error	Caught by controller[1]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Permission denied
                                            host.kellerkind4GB
                                            2022-05-05 22:23:37.473	error	Cannot find view "system" for search "instance" : Connection is closed.
                                            host.kellerkind4GB
                                            2022-05-05 22:23:37.468	error	Cannot find view "system" for search "instance" : Connection is closed.
                                            host.kellerkind4GB
                                            2022-05-05 22:23:37.389	error	States database error: connect ECONNREFUSED 192.168.178.58:9000
                                            systeminfo.1
                                            2022-05-05 22:23:11.061	error	Objects database error: connect ECONNREFUSED 192.168.178.58:9001
                                            host.kellerkind4GB
                                            2022-05-05 22:23:11.048	error	Objects database error: connect ECONNREFUSED 192.168.178.58:9001
                                            rpi2.1
                                            2022-05-05 22:23:11.034	error	Objects database error: connect ECONNREFUSED 192.168.178.58:9001
                                            ds18b20.1
                                            2022-05-05 22:23:32.394	error	States database error: connect ECONNREFUSED 192.168.178.58:9000
                                            Wenn ichmit meinem Handy auf vis zugreife und dort Trends mit Grafana anschauen möchte, funktioniert das auch nicht mehr.
                                            Woran könnte das alles liegen?
                                            (kellerkind4GB ist ein Slave)
                                            8917
