    3. Einsteigerfragen
    4. Installation
    5. ubuntu jammy installation node 14 schlägt fehl
    • JohGre
      JohGre last edited by
      möchte mit meiner iobroker Installation auf node 14 wechseln. Der Server läuft in einer proxmox VM mit ubuntu 22.04 LTS. Beim installieren mittels
      curl -fsSL https://deb.nodesource.com/setup_14.x | sudo -E bash -
      kommt immer die Fehlermeldung
      oliver@iobroker:~$ curl -fsSL https://deb.nodesource.com/setup_14.x | sudo -E bash -
      [sudo] password for oliver:
      ## Installing the NodeSource Node.js 14.x repo...
      ## Populating apt-get cache...
      + apt-get update
      Holen:1 http://at.archive.ubuntu.com/ubuntu jammy InRelease [270 kB]
      OK:2 http://at.archive.ubuntu.com/ubuntu jammy-updates InRelease
      OK:3 http://at.archive.ubuntu.com/ubuntu jammy-backports InRelease
      OK:4 http://at.archive.ubuntu.com/ubuntu jammy-security InRelease
      Es wurden 270 kB in 1s geholt (283 kB/s).
      Reading package lists... Done
      ## Confirming "jammy" is supported...
      + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_14.x/dists/jammy/Release'
      ## Your distribution, identified as "jammy", is not currently supported, please contact NodeSource at https://github.com/nodesource/distributions/issues if you think this is incorrect or would like your distribution to be considered for support
      Wie bring ich node 14 sauber aufs System?
      crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
        crunchip Forum Testing Most Active @JohGre last edited by
        @johgre sagte in ubuntu jammy installation node 14 schlägt fehl:
        unabhängig von ubuntu 22.04, warum manuell installieren
        das macht eigentlich der ioBroker Installer
        JohGre 1 Reply Last reply Reply Quote 0
          Thomas Braun Most Active @JohGre last edited by Thomas Braun
          @johgre
          Supported Ubuntu versions:
          NodeSource will maintain Ubuntu distributions in active support by Canonical, including LTS and the intermediate releases.
          Ubuntu 16.04 LTS (Xenial Xerus)
          Ubuntu 18.04 LTS (Bionic Beaver)
          Ubuntu 18.10 (Cosmic Cuttlefish)
          Ubuntu 19.04 (Disco Dingo)
          Ubuntu 19.10 (Eoan Ermine)
          Ubuntu 20.04 LTS (Focal Fossa)
          Ubuntu 20.10 (Groovy Gorilla)
          Ubuntu 21.04 (Hirsute Hippo)
          Ubuntu 21.10 (Impish Indri)
          22.04 ist noch nicht dabei.
          Ob es unabhängig vom skript schon ein passendes Repo gibt müsste man mal schauen. Könnte sein.
          Edit: Das Repo ist (zumindest teilweise) gefüllt.
          Siehe:
          https://deb.nodesource.com/node_16.x/dists/jammy/Release
          Allerdings für node14 gibt es noch nix.
          Man könnte das jetzt manuell hinzufügen:
          https://github.com/nodesource/distributions#manual-installation
          Hier wird das auch diskutiert:
          https://github.com/nodesource/distributions/issues/1359
          joshxyzhimself created this issue in nodesource/distributions
          closed Ubuntu Budgie 22.04 LTS (Jammy Jellyfish) #1359
          JohGre 1 Reply Last reply Reply Quote -1
          • JohGre
            JohGre @crunchip last edited by
            @crunchip sagte in ubuntu jammy installation node 14 schlägt fehl:
            Ist halt schon installiert und läuft
            • JohGre
              JohGre @Thomas Braun last edited by
              @thomas-braun Danke, dann warte ich noch
                @johgre
                Mit dem nächsten Release von node14 füllt sich das nodesource-Repo dann. Die bauen offenbar nur neue Releases sobald die erscheinen.
                node 14 proxmox
