    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. Tardfri LED treiber Zigbee Pairing undefined
      arteck Developer Most Active @Rushmed last edited by
      @rushmed zeigmal die Kachel
        Rushmed Most Active @arteck last edited by
        • Asgothian
          Asgothian Developer @Rushmed last edited by Asgothian
          @rushmed Zeig bitte auch mal die Expertenansicht von dem Objekt zigbee.x.b4e3f9fffea666ae (sofern dieses existiert - das x ist natürlich die Instanz id der betroffenen Instanz.)
          A.
            Rushmed Most Active @Asgothian last edited by
            @asgothian Etwa so?
              Rushmed Most Active @Rushmed last edited by
              Hilft das?
              • Asgothian
                @rushmed Nein, du müsstest auf den Stift rechts clicken und da dann die Expertenansicht zeigen.
                A.
                  Rushmed Most Active @Asgothian last edited by Rushmed
                  @asgothian Hier die Daten vom Stift, wie komme ich zur Expertenansicht?
                    "type": "device",
                    "common": {
                      "icon": "img/unknown.png"
                    "native": {
                      "id": "b4e3f9fffea666ae"
                    "from": "system.adapter.zigbee.0",
                    "user": "system.user.admin",
                    "ts": 1651522644892,
                    "_id": "zigbee.0.b4e3f9fffea666ae",
                    "acl": {
                      "object": 1636,
                      "owner": "system.user.admin",
                  Mit einem der beiden Controller hatte ich gerade einen kleinen Erfolg.
                  Hier das Log vom Pairing:
                  zigbee.0
                  2022-05-03 08:59:13.950	info	DeviceConfigure successful 0x5c0272fffe92177a TRADFRI Driver 30W
                  zigbee.0
                  2022-05-03 08:59:13.942	info	Configuring 0x5c0272fffe92177a TRADFRI Driver 30W
                  zigbee.0
                  2022-05-03 08:59:13.939	info	Device '0x5c0272fffe92177a' is supported, identified as: IKEA TRADFRI driver for wireless control (30 watt) (ICPSHC24-30EU-IL-1)
                  zigbee.0
                  2022-05-03 08:59:13.938	info	Successfully interviewed '0x5c0272fffe92177a', device has succesfully been paired
                  zigbee.0
                  2022-05-03 08:59:13.290	warn	This object will not be created in future versions. Please report this to the developer.
                  zigbee.0
                  2022-05-03 08:59:13.289	warn	Object zigbee.0.5c0272fffe92177a is invalid: obj.type has to exist
                  zigbee.0
                  2022-05-03 08:59:00.449	warn	Device '0x5c0272fffe92177a' announced itself
                  zigbee.0
                  2022-05-03 08:58:56.033	info	Zigbee: stop joining
                  zigbee.0
                  2022-05-03 08:58:05.832	info	Starting interview of '0x5c0272fffe92177a'
                  zigbee.0
                  2022-05-03 08:57:54.797	info	Zigbee: allowing new devices to join.
                  Lt. Log sieht das gut aus aber das Gerät ist wieder undefined.
                  Das Gerät hat jetzt funktionierende Objekte und lässt sich steuern. Bei dem anderen Controller ist mir das noch nicht gelungen.
                  • Asgothian
                    @rushmed auffällig ist das die internen Daten zur IEEE falsch zu sein scheinen: Da steht als ieee 0x0x...
                    kannst du bitte prüfen wie das auf den kalcheln von anderen Geräten ist ?
                    A.
                      @asgothian Was erwarten wir denn bei der ieee?
                      Alle meiner Geräte beginnen mit 0x0, mit 0x0x beginnen nur die beiden undefinierten.
                      • Asgothian
                        @rushmed Das ist eine Auffälligkeit - allerdings ist mir noch nicht zu 100% klar wo sie her kommt. Eine ieee sollte immer mit 0xabfd.... beginnen, nie mit 0x0x
                        Kannst du bitte mal das Log vom Start des Adapters zeigen ? Da werden alle Geräte aufgelistet.
                        A.
                          @asgothian Klaro:
                          zigbee.0
                          Zeit
                          debug
                          Nachricht
                          zigbee.0
                          2022-05-03 18:15:50.650	error	Device 0xb4e3f9fffea666ae "undefined" not described in statesMapping.
                          zigbee.0
                          2022-05-03 18:15:49.831	info	Zigbee started
                          zigbee.0
                          2022-05-03 18:15:49.829	info	0x5c0272fffe92177a (addr 38948): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
                          zigbee.0
                          2022-05-03 18:15:49.827	info	0x001788010823f75d (addr 52278): 8718699673147 - Philips Hue white A60 bulb E27 bluetooth (Router)
                          zigbee.0
                          2022-05-03 18:15:49.826	info	0xb4e3f9fffea666ae (addr 5806): Not supported (model undefined)(Unknown)
                          zigbee.0
                          2022-05-03 18:15:49.824	info	0x00158d0004abe765 (addr 23612): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                          zigbee.0
                          2022-05-03 18:15:49.822	info	0xec1bbdfffeb19154 (addr 51071): LED1836G9 - IKEA TRADFRI LED bulb E26/E27 806 lumen, dimmable, warm white (Router)
                          zigbee.0
                          2022-05-03 18:15:49.819	info	0xa4c138fa3a3f2312 (addr 31582): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
                          zigbee.0
                          2022-05-03 18:15:49.811	info	0x54ef4410001c5a2f (addr 45152): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                          zigbee.0
                          2022-05-03 18:15:49.808	info	0xcc86ecfffec898a1 (addr 18172): LCZ030 - TuYa Temperature & humidity & illuminance sensor with display (EndDevice)
                          zigbee.0
                          2022-05-03 18:15:49.805	info	0x0017880108f36335 (addr 18062): 324131092621 - Philips Hue dimmer switch (EndDevice)
                          zigbee.0
                          2022-05-03 18:15:49.804	info	0x842e14fffe471ae1 (addr 54998): E2001/E2002 - IKEA STYRBAR remote control N2 (EndDevice)
                          zigbee.0
                          2022-05-03 18:15:49.802	info	0x00158d000587059d (addr 62972): DJT11LM - Xiaomi Aqara vibration sensor (EndDevice)
                          zigbee.0
                          2022-05-03 18:15:49.794	info	0x680ae2fffe12f5b2 (addr 33493): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
                          zigbee.0
                          2022-05-03 18:15:49.793	info	0xec1bbdfffe94bbcb (addr 41642): LED1733G7 - IKEA TRADFRI LED bulb E14 600 lumen, dimmable, white spectrum, opal white (Router)
                          zigbee.0
                          2022-05-03 18:15:49.791	info	0x0017880108ff0d07 (addr 56348): 9290023349 - Philips Hue white A67 bulb E26 with Bluetooth (1600 Lumen) (Router)
                          zigbee.0
                          2022-05-03 18:15:49.790	info	0x00158d00040aa56f (addr 54984): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                          zigbee.0
                          2022-05-03 18:15:49.789	info	0x04cf8cdf3c7d89f6 (addr 4974): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                          zigbee.0
                          2022-05-03 18:15:49.787	info	0xec1bbdfffed4493f (addr 52282): LED1836G9 - IKEA TRADFRI LED bulb E26/E27 806 lumen, dimmable, warm white (Router)
                          zigbee.0
                          2022-05-03 18:15:49.786	info	0x00158d00045bd815 (addr 27339): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          zigbee.0
                          2022-05-03 18:15:49.784	info	0x90fd9ffffed895cf (addr 53319): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                          zigbee.0
                          2022-05-03 18:15:49.783	info	0xd0cf5efffe1dc9fc (addr 15941): LED1545G12 - IKEA TRADFRI LED bulb E26/E27 980 lumen, dimmable, white spectrum, opal white (Router)
                          zigbee.0
                          2022-05-03 18:15:49.780	info	0x00158d0002a3724b (addr 56788): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                          zigbee.0
                          2022-05-03 18:15:49.778	info	0x00158d000421184f (addr 43648): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                          zigbee.0
                          2022-05-03 18:15:49.777	info	0x680ae2fffe0a3127 (addr 54089): HG06335/HG07310 - Lidl Silvercrest smart motion sensor (EndDevice)
                          zigbee.0
                          2022-05-03 18:15:49.775	info	0x00158d000450d167 (addr 38723): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                          zigbee.0
                          2022-05-03 18:15:49.774	info	0xcc86ecfffed10c5f (addr 43457): LCZ030 - TuYa Temperature & humidity & illuminance sensor with display (EndDevice)
                          zigbee.0
                          2022-05-03 18:15:49.771	info	0x00158d00042657a1 (addr 16192): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
                          zigbee.0
                          2022-05-03 18:15:49.769	info	0xec1bbdfffea04dd2 (addr 35883): E1525/E1745 - IKEA TRADFRI motion sensor (EndDevice)
                          zigbee.0
                          2022-05-03 18:15:49.768	info	0x000b57fffe349293 (addr 13376): LED1623G12 - IKEA TRADFRI LED bulb E27 1000 lumen, dimmable, opal white (Router)
                          zigbee.0
                          2022-05-03 18:15:49.766	info	0xb4e3f9fffe0dcce7 (addr 27648): E1812 - IKEA TRADFRI shortcut button (EndDevice)
                          zigbee.0
                          2022-05-03 18:15:49.765	info	0x680ae2fffe0a50c2 (addr 33453): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
                          zigbee.0
                          2022-05-03 18:15:49.762	info	0x0017880108292185 (addr 49203): 8718699673147 - Philips Hue white A60 bulb E27 bluetooth (Router)
                          zigbee.0
                          2022-05-03 18:15:49.755	info	0x842e14fffe7b15e8 (addr 14776): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                          zigbee.0
                          2022-05-03 18:15:49.617	info	Currently 32 devices are joined:
                          zigbee.0
                          2022-05-03 18:15:49.606	info	--> transmitPower : high
                          zigbee.0
                          2022-05-03 18:15:49.591	info	Unable to disable LED, unsupported function.
                          zigbee.0
                          2022-05-03 18:15:49.589	info	Disable LED
                          zigbee.0
                          2022-05-03 18:15:49.585	info	Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20201010}}
                          zigbee.0
                          2022-05-03 18:15:49.452	info	Installed Version: ioBroker/ioBroker.zigbee
                          zigbee.0
                          2022-05-03 18:15:48.807	info	Starting Zigbee npm ...
                          zigbee.0
                          2022-05-03 18:15:48.696	info	starting. Version 1.6.18 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.1, js-controller: 4.0.23
                            Rushmed Most Active last edited by
                            Hilft das?
                            Was kann ich noch tun um die Dinger zu verbinden?
                            • Asgothian
                              @rushmed Bitte verifiziere ob die Geräte sich über die Objekte im Objektbaum schalten lassen. Soweit ich das im Moment einschätzen kann ist der Treiber korrekt eingebunden und es handelt sich nur um ein Darstellungsproblem auf dem Zigbee Tab.
                              A.
                                @asgothian Das Pairing gelang einmal wie oben beschrieben halb erfolgreich. Device konte trotz undefined gesteuert werden.
                                Habs versucht durch Löschen und neun Pairen zu reproduzieren aber jetzt geht trotz mehrmaliger Versuche wieder garnichts mehr.
                                Trotzdem konnte ich zwischenzeitlich andere Geräte erfolgreich anlernen.
                                1.5k
                                pairing tradfri undefined
                                839
