    3. Einsteigerfragen
    4. iobroker läuft nicht mehr
      Thomas Braun Most Active @Emi 0 last edited by Thomas Braun
      @emi-0
      Eigentlich sollte das der Fixer machen.
      Hier sind ACLs gesetzt worden.
      Manuell ist das das etwas aufwändiger.
      Stefan Kania erklärt es hier:
      https://www.informatik-aktuell.de/betrieb/betriebssysteme/rechte-im-dateisystem-mehr-als-nur-rwx.html
        Emi 0 @Homoran last edited by
        Anscheinend macht der fixer bei mir nicht das Richtige
        micros02@smartmeter:~ $ iobroker fix
        library: loaded
        Library version=2022-02-10
            Welcome to the ioBroker installation fixer!
            Script version: 2022-02-13
            You might need to enter your password a couple of times.
            Installing prerequisites (1/3)
        Get:1 http://archive.raspberrypi.org/debian bullseye InRelease [23.7 kB]
        Get:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
        Get:3 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [282 kB]
        Fetched 321 kB in 4s (89.5 kB/s)
        Reading package lists... Done
        Installed gcc-c++
        Installed python-dev
            Checking ioBroker user and directory permissions (2/3)
        Created /etc/sudoers.d/iobroker
        Fixing directory permissions...
            Checking autostart (3/3)
        Enabling autostart...
        Autostart enabled!
            Your installation was fixed successfully
            Run iobroker start to start ioBroker again!
        micros02@smartmeter:~ $ iobroker start
        micros02@smartmeter:~ $ iobroker status
        No connection to databases possible ...
        micros02@smartmeter:~ $ getfacl /opt/iobroker/iobroker-data/objects.jsonl
        getfacl: Removing leading '/' from absolute path names
        # file: opt/iobroker/iobroker-data/objects.jsonl
        # owner: iobroker
        # group: iobroker
        user::rw-
        group::r--
        group:iobroker:rwx
        mask::rwx
        other::r--
          @emi-0
          systemctl status iobroker.service
          sagt?
            Emi 0 @Thomas Braun last edited by
            micros02@smartmeter:~ $ systemctl status iobroker.service
            ● iobroker.service - ioBroker Server
                 Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor pres>
                 Active: active (running) since Tue 2022-05-03 17:35:03 CEST; 40s ago
                   Docs: http://iobroker.net
               Main PID: 27228 (iobroker.js-con)
                  Tasks: 18 (limit: 415)
                    CPU: 40.513s
                 CGroup: /system.slice/iobroker.service
                         ├─27228 iobroker.js-controller
                         └─27241 node /opt/iobroker/node_modules/iobroker.js-controller/iob>
            May 03 17:35:03 smartmeter systemd[1]: Started ioBroker Server.
            May 03 17:35:44 smartmeter systemd[1]: iobroker.service: Main process exited, c>
            May 03 17:35:44 smartmeter systemd[1]: iobroker.service: Failed with result 'ex>
            May 03 17:35:44 smartmeter systemd[1]: iobroker.service: Consumed 40.716s CPU t>
            lines 1-15/15 (END)
              @emi-0
              Mach das Fenster mal breiter, damit man alles sieht.
                wie mache ich das?
                  Homoran Global Moderator Administrators @Emi 0 last edited by Homoran
                  @emi-0 sagte in iobroker läuft nicht mehr:
                  irgendwo muss da mehr stehen
                  Das Fenster der Konsole kannst du doch größer (breiter) ziehen, oder?
                    ja kann ich, aber die Zeile hört mit 'ex auf
                            CPU: 40.513s
                    lines 1-15/15 (END)
                      hast du jetzt nur das Fenster breiter gemacht oder auch den Befehl nochmal abgedrückt?
                        nach erneutem Abschicken des Befehls sieht das Ergebnis ganz anders aus, warum, was hat sich geändert??
                                CPU: 40.513s
                        lines 1-15/15 (END)
                        micros02@smartmeter:~ $ ^C
                             Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
                             Active: active (running) since Tue 2022-05-03 17:49:00 CEST; 38s ago
                           Main PID: 27626 (iobroker.js-con)
                              Tasks: 11 (limit: 415)
                                CPU: 38.168s
                                     └─27626 iobroker.js-controller
                        May 03 17:49:00 smartmeter systemd[1]: Started ioBroker Server.
                          Emi 0 @Emi 0 last edited by
                          @emi-0
                          vielleicht eine kurze Frage zwischendrin:
                          Warum läuft ein System einen Monat stabil und auf einmal ist es tot. Wie kann das sein?
                            Wie kann das sein?
                            Da gibt es mehrere Möglichkeiten.
                            Geänderte Software, geänderte URLs, Dateisystem hat 'nen Schuß, andere Hardware hat 'ne Macke... und noch zig andere.
                              @emi-0
                              Der zweite Output sieht doch relativ gesund aus. Laufen halt keine Instanzen.
                              iobroker status
                              iobroker list instances
                                und wenn ich nur die Daten vom host auf den PC kopiert aber sonst nichts geändert habe?
                                Wie können sich die genannten Dinge von alleine ändern und zwar so, dass wir jetzt schon tagelang herumdoktern und es nicht mehr zum Laufen bringen?
                                  Das ist eine große Fehlerquelle da die Rechte zu verbiegen.
                                  Vermutich ein Windows im Spiel? Das kennt die POSIX-Dateirechte nicht. Deswegen wird beim zurückkopieren ein harmloser Standard gesetzt, wenn man nicht aufpasst.
                                    ich kopiere mit WinSCP. Mir war nicht bewusst, dass ich damit Rechte verbiege. Vor allem war 30x alles in Ordnung und auf einmal sind die Rechte verbogen?
                                    Was passiert da?
                                      Da wirst du schon mal nicht als user iobroker aktiv sein - geht ja auch nicht.
                                      Aber hoffentlich nicht als root, das wäre worst case
                                        Das habe ich nicht verstanden.
                                        Was mache ich falsch?
                                          Ich versuche es mal anders:
                                          mit welchem User loggst du dich über WINSP auf dem ioBroker ein?
                                          das versuchen wir ja herauszubekommen
                                            micros02
                                            5787
