[Linux Shell-Skript] WLAN-Wetterstation
@SBorg
Irgendwie hat die Statistik bei mir geklemmt...Daten sind da, aber er möchte halt lieber ein Object statt einen String
2022-05-01 01:03:00.016 - info: javascript.0 (27658) script.js.common.Wetterstation_Statistik: Auswertung durchgeführt... 2022-05-01 01:03:00.062 - info: javascript.0 (27658) script.js.common.Wetterstation_Statistik: Ausführung zum Monatsersten beendet... 2022-05-01 01:03:00.115 - warn: javascript.0 (27658) You are assigning a string to the state "0_userdata.0.Statistik.Wetter.Data.2022.04" which expects a object. Please fix your code to use a object or change the state type to string. This warning might become an error in future versions. 2022-05-01 01:03:00.121 - warn: javascript.0 (27658) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1965:33) 2022-05-01 01:03:00.121 - warn: javascript.0 (27658) at processImmediate (internal/timers.js:466:21) 2022-05-01 01:03:00.123 - warn: javascript.0 (27658) You are assigning a string to the state "0_userdata.0.Statistik.Wetter.Data.2022.04" which expects a object. Please fix your code to use a object or change the state type to string. This warning might become an error in future versions. 2022-05-01 01:03:00.124 - warn: javascript.0 (27658) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1437:20) 2022-05-01 01:03:00.124 - warn: javascript.0 (27658) at Object. (script.js.common.Wetterstation_Statistik:343:169) 2022-05-01 01:03:00.124 - warn: javascript.0 (27658) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:342:38) 2022-05-01 01:03:00.124 - warn: javascript.0 (27658) at processImmediate (internal/timers.js:466:21) 2022-05-01 01:03:00.125 - info: javascript.0 (27658) Could not parse value for id 0_userdata.0.Statistik.Wetter.Data.2022.04 into object: Unexpected end of JSON input 2022-05-01 01:03:00.126 - info: javascript.0 (27658) Could not parse value for id 0_userdata.0.Statistik.Wetter.Data.2022.04 into object: Unexpected end of JSON input -
Moin @SBorg
da ging aber heute Morgen die Post ab bei der Statistik2022-05-01 01:02:06.613 - info: host.ioBroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2022-05-01 01:02:06.648 - info: javascript.0 (785519) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by 'system.adapter.daswetter.0.alive' 2022-05-01 01:03:00.095 - warn: javascript.0 (785519) You are assigning a object to the state "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Tiefstwert" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions. 2022-05-01 01:03:00.104 - warn: javascript.0 (785519) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1437:20) 2022-05-01 01:03:00.104 - warn: javascript.0 (785519) at VorJahr (script.js.Wetter.Statistik-Wetterstation:364:9) 2022-05-01 01:03:00.104 - warn: javascript.0 (785519) at Object.main (script.js.Wetter.Statistik-Wetterstation:141:4) 2022-05-01 01:03:00.104 - warn: javascript.0 (785519) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1316:34) 2022-05-01 01:03:00.104 - warn: javascript.0 (785519) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:168:15) 2022-05-01 01:03:00.104 - warn: javascript.0 (785519) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28 2022-05-01 01:03:00.104 - warn: javascript.0 (785519) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7) 2022-05-01 01:03:00.104 - warn: javascript.0 (785519) at listOnTimeout (internal/timers.js:557:17) 2022-05-01 01:03:00.105 - warn: javascript.0 (785519) at processTimers (internal/timers.js:500:7) 2022-05-01 01:03:00.105 - warn: javascript.0 (785519) You are assigning a object to the state "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Hoechstwert" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions. 2022-05-01 01:03:00.105 - warn: javascript.0 (785519) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1437:20) 2022-05-01 01:03:00.105 - warn: javascript.0 (785519) at VorJahr (script.js.Wetter.Statistik-Wetterstation:365:9) 2022-05-01 01:03:00.105 - warn: javascript.0 (785519) at Object.main (script.js.Wetter.Statistik-Wetterstation:141:4) 2022-05-01 01:03:00.105 - warn: javascript.0 (785519) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1316:34) 2022-05-01 01:03:00.105 - warn: javascript.0 (785519) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:168:15) 2022-05-01 01:03:00.105 - warn: javascript.0 (785519) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28 2022-05-01 01:03:00.105 - warn: javascript.0 (785519) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7) 2022-05-01 01:03:00.105 - warn: javascript.0 (785519) at listOnTimeout (internal/timers.js:557:17) 2022-05-01 01:03:00.105 - warn: javascript.0 (785519) at processTimers (internal/timers.js:500:7) 2022-05-01 01:03:00.106 - warn: javascript.0 (785519) You are assigning a object to the state "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Temperatur_Durchschnitt" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions. 2022-05-01 01:03:00.106 - warn: javascript.0 (785519) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1437:20) 2022-05-01 01:03:00.106 - warn: javascript.0 (785519) at VorJahr (script.js.Wetter.Statistik-Wetterstation:366:9) 2022-05-01 01:03:00.106 - warn: javascript.0 (785519) at Object.main (script.js.Wetter.Statistik-Wetterstation:141:4) 2022-05-01 01:03:00.106 - warn: javascript.0 (785519) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1316:34) 2022-05-01 01:03:00.106 - warn: javascript.0 (785519) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:168:15) 2022-05-01 01:03:00.106 - warn: javascript.0 (785519) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28 2022-05-01 01:03:00.106 - warn: javascript.0 (785519) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7) 2022-05-01 01:03:00.106 - warn: javascript.0 (785519) at listOnTimeout (internal/timers.js:557:17) 2022-05-01 01:03:00.106 - warn: javascript.0 (785519) at processTimers (internal/timers.js:500:7) 2022-05-01 01:03:00.106 - warn: javascript.0 (785519) You are assigning a object to the state "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Max_Windboe" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions. 2022-05-01 01:03:00.107 - warn: javascript.0 (785519) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1437:20) 2022-05-01 01:03:00.107 - warn: javascript.0 (785519) at VorJahr (script.js.Wetter.Statistik-Wetterstation:367:9) 2022-05-01 01:03:00.107 - warn: javascript.0 (785519) at Object.main (script.js.Wetter.Statistik-Wetterstation:141:4) 2022-05-01 01:03:00.107 - warn: javascript.0 (785519) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1316:34) 2022-05-01 01:03:00.107 - warn: javascript.0 (785519) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:168:15) 2022-05-01 01:03:00.107 - warn: javascript.0 (785519) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28 2022-05-01 01:03:00.107 - warn: javascript.0 (785519) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7) 2022-05-01 01:03:00.107 - warn: javascript.0 (785519) at listOnTimeout (internal/timers.js:557:17) 2022-05-01 01:03:00.107 - warn: javascript.0 (785519) at processTimers (internal/timers.js:500:7) 2022-05-01 01:03:00.107 - warn: javascript.0 (785519) You are assigning a object to the state "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Max_Regenmenge" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions. 2022-05-01 01:03:00.107 - warn: javascript.0 (785519) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1437:20) 2022-05-01 01:03:00.107 - warn: javascript.0 (785519) at VorJahr (script.js.Wetter.Statistik-Wetterstation:368:9) 2022-05-01 01:03:00.107 - warn: javascript.0 (785519) at Object.main (script.js.Wetter.Statistik-Wetterstation:141:4) 2022-05-01 01:03:00.107 - warn: javascript.0 (785519) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1316:34) 2022-05-01 01:03:00.107 - warn: javascript.0 (785519) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:168:15) 2022-05-01 01:03:00.108 - warn: javascript.0 (785519) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28 2022-05-01 01:03:00.108 - warn: javascript.0 (785519) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7) 2022-05-01 01:03:00.108 - warn: javascript.0 (785519) at listOnTimeout (internal/timers.js:557:17) 2022-05-01 01:03:00.108 - warn: javascript.0 (785519) at processTimers (internal/timers.js:500:7) 2022-05-01 01:03:00.108 - warn: javascript.0 (785519) You are assigning a object to the state "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Regenmenge_Monat" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions. 2022-05-01 01:03:00.108 - warn: javascript.0 (785519) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1437:20) 2022-05-01 01:03:00.108 - warn: javascript.0 (785519) at VorJahr (script.js.Wetter.Statistik-Wetterstation:369:9) 2022-05-01 01:03:00.108 - warn: javascript.0 (785519) at Object.main (script.js.Wetter.Statistik-Wetterstation:141:4) 2022-05-01 01:03:00.108 - warn: javascript.0 (785519) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1316:34) 2022-05-01 01:03:00.108 - warn: javascript.0 (785519) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:168:15) 2022-05-01 01:03:00.108 - warn: javascript.0 (785519) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28 2022-05-01 01:03:00.108 - warn: javascript.0 (785519) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7) 2022-05-01 01:03:00.108 - warn: javascript.0 (785519) at listOnTimeout (internal/timers.js:557:17) 2022-05-01 01:03:00.108 - warn: javascript.0 (785519) at processTimers (internal/timers.js:500:7) 2022-05-01 01:03:00.108 - warn: javascript.0 (785519) You are assigning a object to the state "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.warme_Tage" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions. 2022-05-01 01:03:00.109 - warn: javascript.0 (785519) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1437:20) 2022-05-01 01:03:00.109 - warn: javascript.0 (785519) at VorJahr (script.js.Wetter.Statistik-Wetterstation:370:9) 2022-05-01 01:03:00.109 - warn: javascript.0 (785519) at Object.main (script.js.Wetter.Statistik-Wetterstation:141:4) 2022-05-01 01:03:00.109 - warn: javascript.0 (785519) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1316:34) 2022-05-01 01:03:00.109 - warn: javascript.0 (785519) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:168:15) 2022-05-01 01:03:00.109 - warn: javascript.0 (785519) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28 2022-05-01 01:03:00.109 - warn: javascript.0 (785519) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7) 2022-05-01 01:03:00.109 - warn: javascript.0 (785519) at listOnTimeout (internal/timers.js:557:17) 2022-05-01 01:03:00.109 - warn: javascript.0 (785519) at processTimers (internal/timers.js:500:7) 2022-05-01 01:03:00.109 - warn: javascript.0 (785519) You are assigning a object to the state "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Sommertage" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions. 2022-05-01 01:03:00.109 - warn: javascript.0 (785519) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1437:20) 2022-05-01 01:03:00.109 - warn: javascript.0 (785519) at VorJahr (script.js.Wetter.Statistik-Wetterstation:371:9) 2022-05-01 01:03:00.109 - warn: javascript.0 (785519) at Object.main (script.js.Wetter.Statistik-Wetterstation:141:4) 2022-05-01 01:03:00.109 - warn: javascript.0 (785519) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1316:34) 2022-05-01 01:03:00.110 - warn: javascript.0 (785519) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:168:15) 2022-05-01 01:03:00.110 - warn: javascript.0 (785519) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28 2022-05-01 01:03:00.110 - warn: javascript.0 (785519) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7) 2022-05-01 01:03:00.110 - warn: javascript.0 (785519) at listOnTimeout (internal/timers.js:557:17) 2022-05-01 01:03:00.110 - warn: javascript.0 (785519) at processTimers (internal/timers.js:500:7) 2022-05-01 01:03:00.113 - warn: javascript.0 (785519) You are assigning a object to the state "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.heisse_Tage" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions. 2022-05-01 01:03:00.113 - warn: javascript.0 (785519) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1437:20) 2022-05-01 01:03:00.113 - warn: javascript.0 (785519) at VorJahr (script.js.Wetter.Statistik-Wetterstation:372:9) 2022-05-01 01:03:00.113 - warn: javascript.0 (785519) at Object.main (script.js.Wetter.Statistik-Wetterstation:141:4) 2022-05-01 01:03:00.113 - warn: javascript.0 (785519) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1316:34) 2022-05-01 01:03:00.113 - warn: javascript.0 (785519) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:168:15) 2022-05-01 01:03:00.113 - warn: javascript.0 (785519) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28 2022-05-01 01:03:00.113 - warn: javascript.0 (785519) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7) 2022-05-01 01:03:00.113 - warn: javascript.0 (785519) at listOnTimeout (internal/timers.js:557:17) 2022-05-01 01:03:00.113 - warn: javascript.0 (785519) at processTimers (internal/timers.js:500:7) 2022-05-01 01:03:00.114 - warn: javascript.0 (785519) You are assigning a object to the state "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Frost_Tage" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions. 2022-05-01 01:03:00.114 - warn: javascript.0 (785519) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1437:20) 2022-05-01 01:03:00.114 - warn: javascript.0 (785519) at VorJahr (script.js.Wetter.Statistik-Wetterstation:373:9) 2022-05-01 01:03:00.114 - warn: javascript.0 (785519) at Object.main (script.js.Wetter.Statistik-Wetterstation:141:4) 2022-05-01 01:03:00.114 - warn: javascript.0 (785519) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1316:34) 2022-05-01 01:03:00.114 - warn: javascript.0 (785519) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:168:15) 2022-05-01 01:03:00.114 - warn: javascript.0 (785519) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28 2022-05-01 01:03:00.114 - warn: javascript.0 (785519) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7) 2022-05-01 01:03:00.114 - warn: javascript.0 (785519) at listOnTimeout (internal/timers.js:557:17) 2022-05-01 01:03:00.114 - warn: javascript.0 (785519) at processTimers (internal/timers.js:500:7) 2022-05-01 01:03:00.114 - warn: javascript.0 (785519) You are assigning a object to the state "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.kalte_Tage" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions. 2022-05-01 01:03:00.115 - warn: javascript.0 (785519) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1437:20) 2022-05-01 01:03:00.115 - warn: javascript.0 (785519) at VorJahr (script.js.Wetter.Statistik-Wetterstation:374:9) 2022-05-01 01:03:00.115 - warn: javascript.0 (785519) at Object.main (script.js.Wetter.Statistik-Wetterstation:141:4) 2022-05-01 01:03:00.115 - warn: javascript.0 (785519) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1316:34) 2022-05-01 01:03:00.115 - warn: javascript.0 (785519) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:168:15) 2022-05-01 01:03:00.115 - warn: javascript.0 (785519) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28 2022-05-01 01:03:00.115 - warn: javascript.0 (785519) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7) 2022-05-01 01:03:00.115 - warn: javascript.0 (785519) at listOnTimeout (internal/timers.js:557:17) 2022-05-01 01:03:00.115 - warn: javascript.0 (785519) at processTimers (internal/timers.js:500:7) 2022-05-01 01:03:00.115 - warn: javascript.0 (785519) You are assigning a object to the state "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Eistage" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions. 2022-05-01 01:03:00.115 - warn: javascript.0 (785519) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1437:20) 2022-05-01 01:03:00.115 - warn: javascript.0 (785519) at VorJahr (script.js.Wetter.Statistik-Wetterstation:375:9) 2022-05-01 01:03:00.115 - warn: javascript.0 (785519) at Object.main (script.js.Wetter.Statistik-Wetterstation:141:4) 2022-05-01 01:03:00.115 - warn: javascript.0 (785519) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1316:34) 2022-05-01 01:03:00.115 - warn: javascript.0 (785519) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:168:15) 2022-05-01 01:03:00.115 - warn: javascript.0 (785519) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28 2022-05-01 01:03:00.116 - warn: javascript.0 (785519) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7) 2022-05-01 01:03:00.116 - warn: javascript.0 (785519) at listOnTimeout (internal/timers.js:557:17) 2022-05-01 01:03:00.116 - warn: javascript.0 (785519) at processTimers (internal/timers.js:500:7) 2022-05-01 01:03:00.116 - warn: javascript.0 (785519) You are assigning a object to the state "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.sehr_kalte_Tage" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions. 2022-05-01 01:03:00.116 - warn: javascript.0 (785519) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1437:20) 2022-05-01 01:03:00.116 - warn: javascript.0 (785519) at VorJahr (script.js.Wetter.Statistik-Wetterstation:376:9) 2022-05-01 01:03:00.116 - warn: javascript.0 (785519) at Object.main (script.js.Wetter.Statistik-Wetterstation:141:4) 2022-05-01 01:03:00.116 - warn: javascript.0 (785519) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1316:34) 2022-05-01 01:03:00.116 - warn: javascript.0 (785519) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:168:15) 2022-05-01 01:03:00.116 - warn: javascript.0 (785519) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28 2022-05-01 01:03:00.116 - warn: javascript.0 (785519) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7) 2022-05-01 01:03:00.116 - warn: javascript.0 (785519) at listOnTimeout (internal/timers.js:557:17) 2022-05-01 01:03:00.116 - warn: javascript.0 (785519) at processTimers (internal/timers.js:500:7) 2022-05-01 01:03:00.117 - info: javascript.0 (785519) script.js.Wetter.Statistik-Wetterstation: Auswertung durchgeführt... 2022-05-01 01:03:00.144 - info: javascript.0 (785519) State value to set for "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Tiefstwert" has to be type "number" but received type "string" 2022-05-01 01:03:00.144 - info: javascript.0 (785519) State value to set for "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Hoechstwert" has to be type "number" but received type "string" 2022-05-01 01:03:00.144 - info: javascript.0 (785519) State value to set for "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Temperatur_Durchschnitt" has to be type "number" but received type "string" 2022-05-01 01:03:00.144 - info: javascript.0 (785519) State value to set for "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Max_Windboe" has to be type "number" but received type "string" 2022-05-01 01:03:00.145 - info: javascript.0 (785519) State value to set for "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Max_Regenmenge" has to be type "number" but received type "string" 2022-05-01 01:03:00.145 - info: javascript.0 (785519) State value to set for "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Regenmenge_Monat" has to be type "number" but received type "string" 2022-05-01 01:03:00.145 - info: javascript.0 (785519) State value to set for "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.warme_Tage" has to be type "number" but received type "string" 2022-05-01 01:03:00.145 - info: javascript.0 (785519) State value to set for "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Sommertage" has to be type "number" but received type "string" 2022-05-01 01:03:00.149 - info: javascript.0 (785519) State value to set for "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.heisse_Tage" has to be type "number" but received type "string" 2022-05-01 01:03:00.149 - info: javascript.0 (785519) State value to set for "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Frost_Tage" has to be type "number" but received type "string" 2022-05-01 01:03:00.149 - info: javascript.0 (785519) State value to set for "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.kalte_Tage" has to be type "number" but received type "string" 2022-05-01 01:03:00.150 - info: javascript.0 (785519) State value to set for "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Eistage" has to be type "number" but received type "string" 2022-05-01 01:03:00.150 - info: javascript.0 (785519) State value to set for "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.sehr_kalte_Tage" has to be type "number" but received type "string" 2022-05-01 01:03:00.190 - warn: javascript.0 (785519) You are assigning a string to the state "0_userdata.0.Statistik.Wetter.Data.2022.04" which expects a object. Please fix your code to use a object or change the state type to string. This warning might become an error in future versions. 2022-05-01 01:03:00.190 - warn: javascript.0 (785519) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1965:33) 2022-05-01 01:03:00.190 - warn: javascript.0 (785519) at processImmediate (internal/timers.js:466:21) 2022-05-01 01:03:00.196 - info: javascript.0 (785519) Could not parse value for id 0_userdata.0.Statistik.Wetter.Data.2022.04 into object: Unexpected end of JSON input 2022-05-01 01:03:00.196 - warn: javascript.0 (785519) You are assigning a string to the state "0_userdata.0.Statistik.Wetter.Data.2022.04" which expects a object. Please fix your code to use a object or change the state type to string. This warning might become an error in future versions. 2022-05-01 01:03:00.196 - warn: javascript.0 (785519) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1437:20) 2022-05-01 01:03:00.196 - warn: javascript.0 (785519) at Object. (script.js.Wetter.Statistik-Wetterstation:339:169) 2022-05-01 01:03:00.196 - warn: javascript.0 (785519) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:342:38) 2022-05-01 01:03:00.196 - warn: javascript.0 (785519) at processImmediate (internal/timers.js:466:21) 2022-05-01 01:03:00.271 - info: javascript.0 (785519) script.js.Wetter.Statistik-Wetterstation: Ausführung zum Monatsersten beendet... 2022-05-01 01:03:00.273 - info: javascript.0 (785519) Could not parse value for id 0_userdata.0.Statistik.Wetter.Data.2022.04 into object: Unexpected end of JSON inputWas möchte er denn jetzt, statt Number einen String.
hier auch.. die Daten stehen aber drin, leider hat er die vom VorjahresMonat nicht richtig gesetzt:
Hier der Log..endet mit unexpected Json end of Json input.. der Arme.. kam das erwartete nicht..
2022-05-01 01:03:00.040 - warn: javascript.0 (1199068) You are assigning a object to the state "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Tiefstwert" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions. 2022-05-01 01:03:00.043 - warn: javascript.0 (1199068) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1530:20) 2022-05-01 01:03:00.044 - warn: javascript.0 (1199068) at VorJahr (script.js.common.Klimatisierung.Wetterstation-Statistik:368:9) 2022-05-01 01:03:00.044 - warn: javascript.0 (1199068) at Object.main (script.js.common.Klimatisierung.Wetterstation-Statistik:145:4) 2022-05-01 01:03:00.044 - warn: javascript.0 (1199068) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1406:34) 2022-05-01 01:03:00.044 - warn: javascript.0 (1199068) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:171:15) 2022-05-01 01:03:00.044 - warn: javascript.0 (1199068) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28 2022-05-01 01:03:00.044 - warn: javascript.0 (1199068) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7) 2022-05-01 01:03:00.044 - warn: javascript.0 (1199068) at listOnTimeout (internal/timers.js:557:17) 2022-05-01 01:03:00.044 - warn: javascript.0 (1199068) at processTimers (internal/timers.js:500:7) 2022-05-01 01:03:00.045 - warn: javascript.0 (1199068) You are assigning a object to the state "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Hoechstwert" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions. 2022-05-01 01:03:00.045 - warn: javascript.0 (1199068) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1530:20) 2022-05-01 01:03:00.045 - warn: javascript.0 (1199068) at VorJahr (script.js.common.Klimatisierung.Wetterstation-Statistik:369:9) 2022-05-01 01:03:00.046 - warn: javascript.0 (1199068) at Object.main (script.js.common.Klimatisierung.Wetterstation-Statistik:145:4) 2022-05-01 01:03:00.046 - warn: javascript.0 (1199068) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1406:34) 2022-05-01 01:03:00.046 - warn: javascript.0 (1199068) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:171:15) 2022-05-01 01:03:00.046 - warn: javascript.0 (1199068) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28 2022-05-01 01:03:00.046 - warn: javascript.0 (1199068) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7) 2022-05-01 01:03:00.046 - warn: javascript.0 (1199068) at listOnTimeout (internal/timers.js:557:17) 2022-05-01 01:03:00.046 - warn: javascript.0 (1199068) at processTimers (internal/timers.js:500:7) 2022-05-01 01:03:00.046 - warn: javascript.0 (1199068) You are assigning a object to the state "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Temperatur_Durchschnitt" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions. 2022-05-01 01:03:00.046 - warn: javascript.0 (1199068) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1530:20) 2022-05-01 01:03:00.046 - warn: javascript.0 (1199068) at VorJahr (script.js.common.Klimatisierung.Wetterstation-Statistik:370:9) 2022-05-01 01:03:00.047 - warn: javascript.0 (1199068) at Object.main (script.js.common.Klimatisierung.Wetterstation-Statistik:145:4) 2022-05-01 01:03:00.047 - warn: javascript.0 (1199068) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1406:34) 2022-05-01 01:03:00.047 - warn: javascript.0 (1199068) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:171:15) 2022-05-01 01:03:00.047 - warn: javascript.0 (1199068) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28 2022-05-01 01:03:00.047 - warn: javascript.0 (1199068) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7) 2022-05-01 01:03:00.047 - warn: javascript.0 (1199068) at listOnTimeout (internal/timers.js:557:17) 2022-05-01 01:03:00.047 - warn: javascript.0 (1199068) at processTimers (internal/timers.js:500:7) 2022-05-01 01:03:00.047 - warn: javascript.0 (1199068) You are assigning a object to the state "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Max_Windboe" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions. 2022-05-01 01:03:00.047 - warn: javascript.0 (1199068) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1530:20) 2022-05-01 01:03:00.047 - warn: javascript.0 (1199068) at VorJahr (script.js.common.Klimatisierung.Wetterstation-Statistik:371:9) 2022-05-01 01:03:00.047 - warn: javascript.0 (1199068) at Object.main (script.js.common.Klimatisierung.Wetterstation-Statistik:145:4) 2022-05-01 01:03:00.047 - warn: javascript.0 (1199068) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1406:34) 2022-05-01 01:03:00.047 - warn: javascript.0 (1199068) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:171:15) 2022-05-01 01:03:00.047 - warn: javascript.0 (1199068) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28 2022-05-01 01:03:00.048 - warn: javascript.0 (1199068) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7) 2022-05-01 01:03:00.048 - warn: javascript.0 (1199068) at listOnTimeout (internal/timers.js:557:17) 2022-05-01 01:03:00.048 - warn: javascript.0 (1199068) at processTimers (internal/timers.js:500:7) 2022-05-01 01:03:00.048 - warn: javascript.0 (1199068) You are assigning a object to the state "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Max_Regenmenge" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions. 2022-05-01 01:03:00.048 - warn: javascript.0 (1199068) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1530:20) 2022-05-01 01:03:00.048 - warn: javascript.0 (1199068) at VorJahr (script.js.common.Klimatisierung.Wetterstation-Statistik:372:9) 2022-05-01 01:03:00.048 - warn: javascript.0 (1199068) at Object.main (script.js.common.Klimatisierung.Wetterstation-Statistik:145:4) 2022-05-01 01:03:00.048 - warn: javascript.0 (1199068) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1406:34) 2022-05-01 01:03:00.048 - warn: javascript.0 (1199068) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:171:15) 2022-05-01 01:03:00.048 - warn: javascript.0 (1199068) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28 2022-05-01 01:03:00.048 - warn: javascript.0 (1199068) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7) 2022-05-01 01:03:00.048 - warn: javascript.0 (1199068) at listOnTimeout (internal/timers.js:557:17) 2022-05-01 01:03:00.048 - warn: javascript.0 (1199068) at processTimers (internal/timers.js:500:7) 2022-05-01 01:03:00.048 - warn: javascript.0 (1199068) You are assigning a object to the state "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Regenmenge_Monat" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions. 2022-05-01 01:03:00.049 - warn: javascript.0 (1199068) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1530:20) 2022-05-01 01:03:00.049 - warn: javascript.0 (1199068) at VorJahr (script.js.common.Klimatisierung.Wetterstation-Statistik:373:9) 2022-05-01 01:03:00.049 - warn: javascript.0 (1199068) at Object.main (script.js.common.Klimatisierung.Wetterstation-Statistik:145:4) 2022-05-01 01:03:00.049 - warn: javascript.0 (1199068) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1406:34) 2022-05-01 01:03:00.049 - warn: javascript.0 (1199068) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:171:15) 2022-05-01 01:03:00.049 - warn: javascript.0 (1199068) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28 2022-05-01 01:03:00.049 - warn: javascript.0 (1199068) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7) 2022-05-01 01:03:00.049 - warn: javascript.0 (1199068) at listOnTimeout (internal/timers.js:557:17) 2022-05-01 01:03:00.049 - warn: javascript.0 (1199068) at processTimers (internal/timers.js:500:7) 2022-05-01 01:03:00.049 - warn: javascript.0 (1199068) You are assigning a object to the state "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.warme_Tage" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions. 2022-05-01 01:03:00.050 - warn: javascript.0 (1199068) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1530:20) 2022-05-01 01:03:00.050 - warn: javascript.0 (1199068) at VorJahr (script.js.common.Klimatisierung.Wetterstation-Statistik:374:9) 2022-05-01 01:03:00.050 - warn: javascript.0 (1199068) at Object.main (script.js.common.Klimatisierung.Wetterstation-Statistik:145:4) 2022-05-01 01:03:00.050 - warn: javascript.0 (1199068) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1406:34) 2022-05-01 01:03:00.050 - warn: javascript.0 (1199068) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:171:15) 2022-05-01 01:03:00.050 - warn: javascript.0 (1199068) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28 2022-05-01 01:03:00.050 - warn: javascript.0 (1199068) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7) 2022-05-01 01:03:00.051 - warn: javascript.0 (1199068) at listOnTimeout (internal/timers.js:557:17) 2022-05-01 01:03:00.051 - warn: javascript.0 (1199068) at processTimers (internal/timers.js:500:7) 2022-05-01 01:03:00.051 - warn: javascript.0 (1199068) You are assigning a object to the state "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Sommertage" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions. 2022-05-01 01:03:00.052 - warn: javascript.0 (1199068) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1530:20) 2022-05-01 01:03:00.052 - warn: javascript.0 (1199068) at VorJahr (script.js.common.Klimatisierung.Wetterstation-Statistik:375:9) 2022-05-01 01:03:00.052 - warn: javascript.0 (1199068) at Object.main (script.js.common.Klimatisierung.Wetterstation-Statistik:145:4) 2022-05-01 01:03:00.052 - warn: javascript.0 (1199068) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1406:34) 2022-05-01 01:03:00.052 - warn: javascript.0 (1199068) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:171:15) 2022-05-01 01:03:00.052 - warn: javascript.0 (1199068) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28 2022-05-01 01:03:00.052 - warn: javascript.0 (1199068) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7) 2022-05-01 01:03:00.052 - warn: javascript.0 (1199068) at listOnTimeout (internal/timers.js:557:17) 2022-05-01 01:03:00.052 - warn: javascript.0 (1199068) at processTimers (internal/timers.js:500:7) 2022-05-01 01:03:00.052 - warn: javascript.0 (1199068) You are assigning a object to the state "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.heisse_Tage" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions. 2022-05-01 01:03:00.053 - warn: javascript.0 (1199068) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1530:20) 2022-05-01 01:03:00.053 - warn: javascript.0 (1199068) at VorJahr (script.js.common.Klimatisierung.Wetterstation-Statistik:376:9) 2022-05-01 01:03:00.053 - warn: javascript.0 (1199068) at Object.main (script.js.common.Klimatisierung.Wetterstation-Statistik:145:4) 2022-05-01 01:03:00.053 - warn: javascript.0 (1199068) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1406:34) 2022-05-01 01:03:00.053 - warn: javascript.0 (1199068) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:171:15) 2022-05-01 01:03:00.054 - warn: javascript.0 (1199068) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28 2022-05-01 01:03:00.056 - warn: javascript.0 (1199068) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7) 2022-05-01 01:03:00.056 - warn: javascript.0 (1199068) at listOnTimeout (internal/timers.js:557:17) 2022-05-01 01:03:00.056 - warn: javascript.0 (1199068) at processTimers (internal/timers.js:500:7) 2022-05-01 01:03:00.056 - warn: javascript.0 (1199068) You are assigning a object to the state "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Frost_Tage" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions. 2022-05-01 01:03:00.057 - warn: javascript.0 (1199068) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1530:20) 2022-05-01 01:03:00.057 - warn: javascript.0 (1199068) at VorJahr (script.js.common.Klimatisierung.Wetterstation-Statistik:377:9) 2022-05-01 01:03:00.057 - warn: javascript.0 (1199068) at Object.main (script.js.common.Klimatisierung.Wetterstation-Statistik:145:4) 2022-05-01 01:03:00.058 - warn: javascript.0 (1199068) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1406:34) 2022-05-01 01:03:00.058 - warn: javascript.0 (1199068) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:171:15) 2022-05-01 01:03:00.058 - warn: javascript.0 (1199068) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28 2022-05-01 01:03:00.058 - warn: javascript.0 (1199068) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7) 2022-05-01 01:03:00.058 - warn: javascript.0 (1199068) at listOnTimeout (internal/timers.js:557:17) 2022-05-01 01:03:00.058 - warn: javascript.0 (1199068) at processTimers (internal/timers.js:500:7) 2022-05-01 01:03:00.058 - warn: javascript.0 (1199068) You are assigning a object to the state "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.kalte_Tage" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions. 2022-05-01 01:03:00.059 - warn: javascript.0 (1199068) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1530:20) 2022-05-01 01:03:00.059 - warn: javascript.0 (1199068) at VorJahr (script.js.common.Klimatisierung.Wetterstation-Statistik:378:9) 2022-05-01 01:03:00.059 - warn: javascript.0 (1199068) at Object.main (script.js.common.Klimatisierung.Wetterstation-Statistik:145:4) 2022-05-01 01:03:00.059 - warn: javascript.0 (1199068) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1406:34) 2022-05-01 01:03:00.059 - warn: javascript.0 (1199068) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:171:15) 2022-05-01 01:03:00.059 - warn: javascript.0 (1199068) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28 2022-05-01 01:03:00.059 - warn: javascript.0 (1199068) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7) 2022-05-01 01:03:00.059 - warn: javascript.0 (1199068) at listOnTimeout (internal/timers.js:557:17) 2022-05-01 01:03:00.060 - warn: javascript.0 (1199068) at processTimers (internal/timers.js:500:7) 2022-05-01 01:03:00.060 - warn: javascript.0 (1199068) You are assigning a object to the state "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Eistage" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions. 2022-05-01 01:03:00.060 - warn: javascript.0 (1199068) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1530:20) 2022-05-01 01:03:00.061 - warn: javascript.0 (1199068) at VorJahr (script.js.common.Klimatisierung.Wetterstation-Statistik:379:9) 2022-05-01 01:03:00.061 - warn: javascript.0 (1199068) at Object.main (script.js.common.Klimatisierung.Wetterstation-Statistik:145:4) 2022-05-01 01:03:00.061 - warn: javascript.0 (1199068) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1406:34) 2022-05-01 01:03:00.061 - warn: javascript.0 (1199068) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:171:15) 2022-05-01 01:03:00.061 - warn: javascript.0 (1199068) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28 2022-05-01 01:03:00.061 - warn: javascript.0 (1199068) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7) 2022-05-01 01:03:00.061 - warn: javascript.0 (1199068) at listOnTimeout (internal/timers.js:557:17) 2022-05-01 01:03:00.061 - warn: javascript.0 (1199068) at processTimers (internal/timers.js:500:7) 2022-05-01 01:03:00.061 - warn: javascript.0 (1199068) You are assigning a object to the state "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.sehr_kalte_Tage" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions. 2022-05-01 01:03:00.062 - warn: javascript.0 (1199068) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1530:20) 2022-05-01 01:03:00.062 - warn: javascript.0 (1199068) at VorJahr (script.js.common.Klimatisierung.Wetterstation-Statistik:380:9) 2022-05-01 01:03:00.062 - warn: javascript.0 (1199068) at Object.main (script.js.common.Klimatisierung.Wetterstation-Statistik:145:4) 2022-05-01 01:03:00.063 - warn: javascript.0 (1199068) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1406:34) 2022-05-01 01:03:00.063 - warn: javascript.0 (1199068) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:171:15) 2022-05-01 01:03:00.063 - warn: javascript.0 (1199068) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28 2022-05-01 01:03:00.063 - warn: javascript.0 (1199068) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7) 2022-05-01 01:03:00.063 - warn: javascript.0 (1199068) at listOnTimeout (internal/timers.js:557:17) 2022-05-01 01:03:00.063 - warn: javascript.0 (1199068) at processTimers (internal/timers.js:500:7) 2022-05-01 01:03:00.063 - info: javascript.0 (1199068) script.js.common.Klimatisierung.Wetterstation-Statistik: Auswertung durchgeführt... 2022-05-01 01:03:00.084 - info: javascript.0 (1199068) State value to set for "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Tiefstwert" has to be type "number" but received type "string" 2022-05-01 01:03:00.085 - info: javascript.0 (1199068) State value to set for "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Hoechstwert" has to be type "number" but received type "string" 2022-05-01 01:03:00.085 - info: javascript.0 (1199068) State value to set for "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Temperatur_Durchschnitt" has to be type "number" but received type "string" 2022-05-01 01:03:00.085 - info: javascript.0 (1199068) State value to set for "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Max_Windboe" has to be type "number" but received type "string" 2022-05-01 01:03:00.085 - info: javascript.0 (1199068) State value to set for "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Max_Regenmenge" has to be type "number" but received type "string" 2022-05-01 01:03:00.085 - info: javascript.0 (1199068) State value to set for "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Regenmenge_Monat" has to be type "number" but received type "string" 2022-05-01 01:03:00.085 - info: javascript.0 (1199068) State value to set for "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.warme_Tage" has to be type "number" but received type "string" 2022-05-01 01:03:00.085 - info: javascript.0 (1199068) State value to set for "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Sommertage" has to be type "number" but received type "string" 2022-05-01 01:03:00.085 - info: javascript.0 (1199068) State value to set for "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.heisse_Tage" has to be type "number" but received type "string" 2022-05-01 01:03:00.086 - info: javascript.0 (1199068) State value to set for "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Frost_Tage" has to be type "number" but received type "string" 2022-05-01 01:03:00.086 - info: javascript.0 (1199068) State value to set for "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.kalte_Tage" has to be type "number" but received type "string" 2022-05-01 01:03:00.086 - info: javascript.0 (1199068) State value to set for "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.Eistage" has to be type "number" but received type "string" 2022-05-01 01:03:00.086 - info: javascript.0 (1199068) State value to set for "0_userdata.0.Statistik.Wetter.Vorjahres_Monat.sehr_kalte_Tage" has to be type "number" but received type "string" 2022-05-01 01:03:00.119 - warn: javascript.0 (1199068) You are assigning a string to the state "0_userdata.0.Statistik.Wetter.Data.2022.04" which expects a object. Please fix your code to use a object or change the state type to string. This warning might become an error in future versions. 2022-05-01 01:03:00.121 - warn: javascript.0 (1199068) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2083:33) 2022-05-01 01:03:00.121 - warn: javascript.0 (1199068) at processImmediate (internal/timers.js:466:21) 2022-05-01 01:03:00.149 - info: javascript.0 (1199068) script.js.common.Klimatisierung.Wetterstation-Statistik: Ausführung zum Monatsersten beendet... 2022-05-01 01:03:00.334 - warn: javascript.0 (1199068) You are assigning a string to the state "0_userdata.0.Statistik.Wetter.Data.2022.04" which expects a object. Please fix your code to use a object or change the state type to string. This warning might become an error in future versions. 2022-05-01 01:03:00.335 - warn: javascript.0 (1199068) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1530:20) 2022-05-01 01:03:00.335 - warn: javascript.0 (1199068) at Object.<anonymous> (script.js.common.Klimatisierung.Wetterstation-Statistik:343:169) 2022-05-01 01:03:00.335 - warn: javascript.0 (1199068) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:436:42) 2022-05-01 01:03:00.335 - warn: javascript.0 (1199068) at processImmediate (internal/timers.js:464:21) 2022-05-01 01:03:00.335 - info: javascript.0 (1199068) Could not parse value for id 0_userdata.0.Statistik.Wetter.Data.2022.04 into object: Unexpected end of JSON input 2022-05-01 01:03:00.343 - info: javascript.0 (1199068) Could not parse value for id 0_userdata.0.Statistik.Wetter.Data.2022.04 into object: Unexpected end of JSON input -
@boronsbruder sagte in [Linux Shell-Skript] WLAN-Wetterstation:
Ich war's nicht, da steht ja "...fix your code..."
Er hat es mal wieder nicht bei mir gespeichert... (ev. erinnert sich der ein oder andere an den Blocky/JS - speichert stellenweise nicht - Bug). Ich habe es nicht bemerkt und dann hochgeladen
Aber das laden/speichern von JSON hatte ich trotzdem falsch verstanden und jetzt (hoffentlich) korrigiert. Daraus dürften dann auch die unterschiedlichen Fehlermeldungen resultieren, denn an den Stellen habe ich nichts geändert. Das Positive: zumindest wieder paar Fehler beseitigt
V1.1.1 steht auf GitHub bereit (reines BugFix-Release; Update empfohlen)
...und pünktlich zum WE ist mal wieder wetter.com Offline...
habs gerade irgendwie verballert, als ich nochmal auf 2.13.0 geupdatet habe mit./ws_updater.shAuswahlmenü für WLAN-Wetterstation: _____________________________________ [1] im aktuellen Verzeichnis installieren [2] als Service einrichten [3] Konfigurationsdatei patchen [4] Update ausführen [E] Exit Ihre Auswahl: [1-4]: e pi@ioBroker:/home/iobroker/wetterstation $ sudo systemctl status wetterstation ● wetterstation.service - Service für ioBroker Wetterstation Loaded: loaded (/etc/systemd/system/wetterstation.service; enabled; vendor preset: enabled) Active: failed (Result: exit-code) since Mon 2022-05-02 16:48:42 CEST; 5min ago Process: 24479 ExecStart=/home/iobroker/wetterstation/wetterstation.sh (code=exited, status=203/EXEC) Main PID: 24479 (code=exited, status=203/EXEC) Mai 02 16:48:42 ioBroker systemd[1]: Started Service für ioBroker Wetterstation. Mai 02 16:48:42 ioBroker systemd[24479]: wetterstation.service: Failed to execute command: Permission denied Mai 02 16:48:42 ioBroker systemd[24479]: wetterstation.service: Failed at step EXEC spawning /home/iobroker/wetterstation/wetterstation.sh: Permission denied Mai 02 16:48:42 ioBroker systemd[1]: wetterstation.service: Main process exited, code=exited, status=203/EXEC Mai 02 16:48:42 ioBroker systemd[1]: wetterstation.service: Failed with result 'exit-code'. pi@ioBroker:/home/iobroker/wetterstation $Irgendwie will der Service nicht mehr starten
Add: Das Verzeichnis (wegen der Rechte):
pi@ioBroker:/home/iobroker/wetterstation $ ls -al insgesamt 160 drwxrwxr-x 2 iobroker iobroker 4096 Mai 2 16:29 . drwxr-xr-x 6 iobroker iobroker 4096 Dez 16 20:53 .. -rwxr--r-- 1 pi iobroker 6267 Mai 2 16:13 wetterstation.conf -rwxr--r-- 1 pi pi 6251 Mai 2 16:13 wetterstation.conf.backup -rw-r--r-- 1 pi pi 20564 Apr 8 13:21 wetterstation.js -rw-r--r-- 1 pi pi 16566 Apr 8 13:21 wetterstation.sh -rw-r--r-- 1 pi pi 66937 Apr 8 13:21 wetterstation.sub -rwxrw-r-- 1 pi pi 21741 Mai 2 16:41 ws_updater.sh pi@ioBroker:/home/iobroker/wetterstation $ -
@qqolli sagte in [Linux Shell-Skript] WLAN-Wetterstation:
Kleines Fehlerchen, da fehlt ein "x" (=ist nicht ausführbar).
Im Verzeichnis einfachsudo chmod +x wetterstation.sh, danach solltest du den Service wieder per Hand starten können
@sborg
Genau so war es
Vielen Dank. -
@martybr sagte in [Linux Shell-Skript] WLAN-Wetterstation:
Vielleicht kannst du das prüfen, wenn du deine Influx auf Version 2 gebracht hast und Zeit dafür findest.
Ich hab mich auch am Statistik-Script mit Influx 2.0 versucht und erhalte nun Tageswerte, ich habe folgende Änderung bei den result.result[..]-Einträgen vornehmen müssen:
Aus z.B.result.result[0][i].valuehabe ichresult.result[0][i]._value, also der_vorvalueist hinzugekommen.
Mal schauen, ob das so funktioniert. -
@latzi Hast du das in jeder Zeile im Statistik-Script eingesetzt?
Kannst du dein Script hier zeigen?
Ich habe die Version 1.1.1 laufen, aber wie schon im Readme beschrieben, gibt es weiterhin Fehler beim Einsatz von Influx 2.x -
@martybr ja, ist bei allen vorkommenden Stellen ersetzt (so viele sind´s ja nicht).
Hier die 1.1.1_mod: ( @SBorg verletze ich damit dein copyright?)Ich hab in der InfluxDB-Adapter-Beschreibung auf github die Funktion
getHistorygefunden, damit werde ich mich bei Zeiten mal versuchen, scheint als ob damit die DB-Version unabhängig ist. @SBorg was hältst du davon (oder bin ich damit auf dem Holzweg)? -
@latzi Nö, es steht jedem frei, solange es nicht kommerziell ist, zu ändern, ergänzen oder damit anzufangen was er will. Die Lizenz legt lediglich fest, dass die Copyright-Vermerke so zu verbleiben haben. Also alles iO
Es sollte nur nicht über Hand nehmen, sonst sind dann zig Versionen im Umlauf und das "Geheule" (
) nachher groß wenn es keine adäquate Hilfe mehr gibt. Ich kann mir dann nicht jede Version ansehen und analysieren woran es denn hängt, gerade wenn ich dann wie hier auch keine Influx V2 nutze/habe.Wer würde denn keine Influx V2 nutzen wollen? Ich habe nur mal am Rande geschaut, aber beides gleichzeitig in den Skripten handeln zu wollen wird nicht zielführend sein (falls es nicht per getHistory funktioniert; ich habe es mir noch nicht angeschaut).
Ich habe mal mit der RestAPI angefangen, aber das ist ebenfalls eine Riesenbaustelle...
@latzi Danke. Teste ich direkt.
@sborg sagte in [Linux Shell-Skript] WLAN-Wetterstation:
Ich habe
getHistorygestestet (zwar nicht ins Skript eingebaut, aber die grundsätzliche Funktion getestet) und es funktioniert (zumindest für einen Wert, die Abfrage der 3 Werte hab ich nicht probiert).
Da es aktuell durch Ingo diverse Änderungen der History/SQL/InfluxDB-Adapter gibt, schaut es so aus, dass man zukünftig alle Speicherort mit der gleichen Syntax abfragen kann, somit wäre das Statistik-Skript nicht mehr "nur" an InfluxDB 1.0 gebunden, sondern könnte ohne groben Eingriff (nur beim getHistory-Aufruf muss die DB-Instanz angegeben werden) alle DB´s abdecken.Derzeit nutze ich noch den influxDB-Adapter in der Version 2.6.3, aktuell gibt es aber schon die Version 3.0.0, wobei hier die Vereinheitlichung mit den übrigen DB´s vollzogen ist - mit der Änderung in getHistory, dass die Start- und Endzeitpunkte in ms anzugeben sind.
Hier noch mein Testskript für
getHistorymit InfluxDB-Version 2.x, falls jemand mit InfluxDB-Version 1.x testen könnte wäre das hilfreich zur Bestätigung: -
@latzi
heute morgen hat das Statistik-Script den Status erfolgreich gemeldet.
Ich verfolge nun die Werte.
Vielen Dank für deine Unterstützung. -
@latzi Also
getHistory(danke an Ingo
) funktioniert auch mit der V1 und ist wesentlich angenehmer als das Query.
Es würde auch Sinn ergeben es in 3 Einzelabfragen aufzuteilen. So spart man noch bisserl RAM und die Latenz der Abfrage ist zu verschmerzen, da es nur ein Zeitraum von 24 Stunden mit ~ 2.800 Messwerten ist....und die Influx-Instanz musste auch vorher schon angegeben werden
Moin,
heute von 2.07 auf 2.13 aktualisiert...
Kleines "Problem" war das kein bevorzugter Editor definiert war ... also ggf vorher prüfen ob es die file gibt
Konfiguration nun öffnen? [J/N]: jcat: /home/iobroker/.selected_editor: No such file or directory /dev/fd/61: line 469: wetterstation.conf: command not foundBeim Teststart gab es dann jq Fehler
./wetterstation.sh Connection to <my ip port> port [tcp/*] succeeded! jq: error (at <stdin>:3): Cannot iterate over null (null) jq: error (at <stdin>:3): Cannot iterate over null (null)aber das Test Datenpaket wurde sauber empfangen und sieht so aus als tut alles...
Zu Influx v2 - wäre super wenn es irgendwann geht, habe immer Angst das mir ein iobroker cli/npm update das Paket einfach zwangsweise draufbügelt...
@rand sagte in [Linux Shell-Skript] WLAN-Wetterstation:
Das Paket heißt influxdb2 , die V1 von influx firmiert als influxdb.
echad@chet:~ $ apt policy influxdb influxdb2 influxdb: Installed: (none) Candidate: 1.8.10-1 Version table: 1.8.10-1 500 500 https://repos.influxdata.com/debian bullseye/stable arm64 Packages 100 /var/lib/dpkg/status 1.6.7~rc0-1+b5 500 500 http://deb.debian.org/debian bullseye/main arm64 Packages influxdb2: Installed: (none) Candidate: 2.2.0 Version table: 2.2.0 500 500 https://repos.influxdata.com/debian bullseye/stable arm64 Packages 2.1.1 -1 100 /var/lib/dpkg/statusDas Paket influxdb2 musst du schon explizit anfordern, das wird nicht zwangsweise draufgebügelt.
Das ist beruhigend zu wissen, vielen Dank
Danke und fixed (aktuell noch nicht auf GitHub)
./wetterstation.sh Connection to <my ip port> port [tcp/*] succeeded! jq: error (at <stdin>:3): Cannot iterate over null (null) jq: error (at <stdin>:3): Cannot iterate over null (null)Da muss ich mir noch mal Gedanken machen, weil es den ein oder anderen doch "erschreckt". Das kann mal vorkommen wenn man den ungünstigsten Augenblick erwischt, da dann keine Daten vorliegen (was dann beim laufenden Betrieb nicht mehr der Fall ist).
...und auf der ToDo-Liste steht nach wie vor Influx V2 - Support und die neue RestAPI.
Ich komme einfach nicht mehr weiter und bitte um Hilfe.
Ist Zustand:
2 x pi 4 mit 256 Gbyte SSD-platte
Debian Bullseye ohne Desktop Stand 04.04.22
Auf beiden einen neuen User eingerichtet, rebootet und danach nur noch mit dem neuen User eingeloggt und gearbeitet.
Auf beiden ioBroker installiert und als Master und Slave im Multihost gestartet.Auf dem Slave in /home/iobroker die nötigen Dateien für die Wlan-Wetterstation kopiert, Version 2.13.0
Auf dem Slave auch simple-api Adapter über Master installiert.Software für Wetterstation nach Anleitung eingerichtet.
Wenn ich dann „./wetterstation.sh –debug“ eingebe bekomme ich folgende Ausgabe:„walter@pi-iobroker-slave:/home/iobroker $ ./wetterstation.sh --debug -bash: ./wetterstation.sh: /bin/bash^M: Defekter Interpreter: Datei oder Verzeichnis nicht gefunden“Was zum Henker mache ich falsch?
MfG
Wastl
