    4. [neuer Adapter] smartgarden adapter for Gardena smart system
      kekz @intruder7 last edited by kekz
      @jpgorganizer
      ich habe inzwischen leider auch Schwierigkeiten den Adapter am Laufen zu halten.
      Er hält maximal einen Tag durch, danach kommt "Error: request returned 429"
      Ich nutze die aktuelle Version 1.0.5 und habe auch schon die api.js getauscht, wie hier vorgeschlagen:
      https://github.com/jpgorganizer/ioBroker.smartgarden/issues/43#issuecomment-1098956841
      Aktuell muss ich täglich den API-Key neu erstellen.
      smartgarden.0
      2022-04-19 15:41:10.256	error	Error: request returned 429
      smartgarden.0
      2022-04-19 15:41:03.427	debug	Schedule restart: * */1 * * *
      smartgarden.0
      2022-04-19 15:41:03.396	info	starting. Version 1.0.5 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v12.22.9, js-controller: 4.0.21
      smartgarden.0
      2022-04-19 15:41:00.055	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      smartgarden.0
      2022-04-19 15:41:00.054	info	terminating
      smartgarden.0
      2022-04-19 15:41:00.027	info	Scheduled restart.
      smartgarden.0
      2022-04-19 15:40:53.396	error	Error: request returned 429
      smartgarden.0
      smartgarden.0
      2022-04-19 15:40:53.020	debug	Schedule restart: * */1 * * *
      smartgarden.0
      2022-04-19 15:40:52.987	info	starting. Version 1.0.5 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v12.22.9, js-controller: 4.0.21
      smartgarden.0
      2022-04-19 15:40:52.606	debug	States connected to redis: 0.0.0.0:9000
      smartgarden.0
      2022-04-19 15:40:52.402	debug	States create User PubSub Client
      smartgarden.0
      2022-04-19 15:40:52.401	debug	States create System PubSub Client
      smartgarden.0
      2022-04-19 15:40:52.263	debug	Redis States: Use Redis connection: 0.0.0.0:9000
      smartgarden.0
      2022-04-19 15:40:52.137	debug	Objects connected to redis: 0.0.0.0:9001
      smartgarden.0
      2022-04-19 15:40:52.096	debug	Objects client initialize lua scripts
      smartgarden.0
      2022-04-19 15:40:52.095	info	Sets unsupported
      smartgarden.0
      2022-04-19 15:40:51.942	debug	Objects create User PubSub Client
      smartgarden.0
      2022-04-19 15:40:51.941	debug	Objects create System PubSub Client
      smartgarden.0
      2022-04-19 15:40:51.940	debug	Objects client ready ... initialize now
      smartgarden.0
      2022-04-19 15:40:51.884	debug	Redis Objects: Use Redis connection: 0.0.0.0:9001
      Gibt es hier noch andere Lösungsvorschläge?
      Ich nutze den Adapter ausschließlich zur Bewässerung
      andre-bu created this issue in jpgorganizer/ioBroker.smartgarden
      closed Verbindungsprobleme #43
        stevie77 @kekz last edited by
        @kekz Das riecht aber eher danach, dass du dein Gardena-Budget an Abfragen aufgebraucht hast. Zumindest ist Fehler 429 als HTTP-Status der Code für zu viele Anfragen (https://developer.mozilla.org/en-US/docs/Web/HTTP/Status/429). Falls Gardena das so zurück gibt (lehne mich da mal aus dem Fenster). Würde aber dazu passen, dass du mit nem neuen API-Key weitermachen kannst.
        Ich hatte das Problem auch mal, weil ich bei der Programmierung nicht daran gedacht hatte...
          kekz @stevie77 last edited by
          @stevie77
          Danke für den Hinweis.
          Ich glaube nicht, dass das der Fall ist. Ich wüsste nicht, wie ich dieses Limit hätte erreichen sollen.
          Es gibt kein Skript, worin eine Abfrage getriggert wird.
          Der Adapter wird aktuell lediglich 1x pro Stunde neugestartet. Das war ein Versuch eine abgebrochene Verbindung zeitnah widerherzustellen.
          Die Adapter-Einstellungen sind auch die StandardeinstellungenScreenshot 2022-04-19 160624.png
            Thomas Braun Most Active @kekz last edited by
            @kekz sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
            Und dadurch wird die komplette Messe wieder eingelesen. Kann gut sein, dass das schon zu viel ist.
              kekz @Thomas Braun last edited by
              Hm ja, das klingt plausibel.
              Ich habe den restart mal rausgenommen, eine neue API erstellt und schaue mal, wie es den Tag über läuft.
              • Q
                qwertz last edited by
                Hi !
                Hat jemand Erfahrungen ob das aktuell neu angebotene Firmwareupdate von Gardena für die RoboMäher mit dem Adapter läuft ?
                In der App gibts leider kein Changelog.
                Besten Gruß,
                Sebastian
                • Jörg Benthien
                  Jörg Benthien last edited by
                  @jpgorganizer
                  Für mich entspannend, für Dich sicher interessant: Ich habe heute das Update auf 1.0.6 gemacht und es läuft jetzt :-), direkt nach dem Update und Neustart des Adapters.
                  So oder so, besten Dank für Deine Unterstützung - die hat ja auf jeden Fall geholfen!
                  • jpgorganizer
                    jpgorganizer last edited by
                    neues Release v1.0.6 ist online
                    in ioBroker im latest (stable mach ich in ein paar Tagen)
                    und in npm
                    Changelog
                    1.0.6
                    • (jpgorganizer) 2022-May-04
                      • some minor changes in documentation, including Issue 41
                        and new limit for SERVICE_VALVE (just smart Irrigation Control)
                      • bug fix in error handling
                      • changes due to new Gardena API v1.1.0
                      • necessary changes due to changed behavior Gardena Service Issue 43
                      • tests against js-controller 4.x, Issue 40
                    Bitte testen / prüfen / Rückmeldung erwünscht
                    Ich hatte dies bereits gepostet und soeben bemerkt, dass ich das im falschen Thread geschrieben hatte. Deshalb hier nochmals. Sorry
                    Q T 2 Replies Last reply Reply Quote 0
                    • Flexer
                      Flexer last edited by
                      @jporganizer
                      Hatte heute wieder diesen Fehler im Log
                      smartgarden.0
                      2022-05-06 22:15:46.553	error	Error: request returned 500 Internal Server Error
                      Es kann sein dass es was mit meinem Netzwerk zu tun hat aber seit dem ersten erscheinen dieser Meldung verbindet sich der Adapter auch nicht mehr. Über die Gardena App kann ich aber alles steuern.
                      Viele Grüsse
                      • Q
                        qwertz @jpgorganizer last edited by
                        @jpgorganizer
                        V1.0.6. klappt bei mir einwandfrei. Bis jetzt keine Verbindungsabbrüche zur Cloud. Besten Dank !
                        P.S. Nach dem Garden Firmware Update 04/2022 der Mäher gabs keine Probleme
                          tp1de @jpgorganizer last edited by tp1de
                          @jpgorganizer Lief bisher schon stabil ... nun auch mit 1.0.6. 👍
                          Mir fehlt nur ein State / eine Funktion bei den Sileno-Mährobotern:
                          Wenn ich den Roboter starte (manuell oder automatisch per Zeit Programm) dann wird in der Gardena App das geplante Laufzeitende angezeigt. Ein entsprechender State fehlt mir. Z.B. bei Start mit 3600 Sekunden (1 Stunde) sehe ich zwar den Status OK_CUTTING_TIMER_OVERRIDDEN im activity value, aber nirgendwo wie lange.
                          Falls dieser Zeitstempel in der API nicht verfügbar ist, dann wäre es toll, wenn im Adapter dieser Zeitpunkt (Geplantes Mähende) gespeichert wird. Der State activity_mowingTime_remain_i beinhaltet diesen Zeitpunkt nicht.
                          jpgorganizer 1 Reply Last reply Reply Quote 0
                          • jpgorganizer
                            jpgorganizer @tp1de last edited by
                            @tp1de sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                            diesen State gibt es nicht - leider
                            das gibt bzw. man muss sagen gab es im Adapter von Beginn an. Nur liefert Gardena mittlerweile die erforderlichen Daten nicht mehr, bzw. zu selten.
                            Da kann ich nichts machen. Zumindest habe ich aktuell keine Idee dazu.
                            • N
                              netfriend last edited by
                              ich nutze den Smartgarden-Adapter 1.0.5 in Verbindung mit der Gardena-Bewässerungssteuerung. Hat letztes Jahr auch wunderbar geklappt. Nach der Winterpause habe ich nun das Problem, dass die Verbindung zu Gardena/Husqvarna immer nach wenigen Stunden Laufzeit abbricht.
                              "Verbunden mit Gerät oder Dienst" wird dann gelb, "verbunden mit Host" und "Lebenszeichen" bleiben grün.
                              Im Log steht dann:
                              2022-05-09 22:17:48.809  - *[32minfo*[39m: smartgarden.0 (10107) 3/ on_close: ### closed ### close.code=1001 close.reason=Going away
                              2022-05-09 22:17:48.811  - *[32minfo*[39m: smartgarden.0 (10107) 3/ sgSetState: info.connection value=false ack=true
                              2022-05-09 22:17:48.825  - *[35msilly*[39m: smartgarden.0 (10107) States user redis pmessage smartgarden.0.*/smartgarden.0.info.connection:{"val":false,"ack":true,"ts":1652127468818,"q":0,"from":"system.adapter.smartgarden.0","user":"system.user.admin","lc":1652127468818}
                              2022-05-09 22:17:48.828  - *[32minfo*[39m: smartgarden.0 (10107) 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
                              Ich habe mich auch schon bei husqvarna eingeloggt und bei "MyApplications" -> "Renew API-Key" durchgeführt, den Key wieder im Adapter hinterlegt und gestartet. Hat aber keine Veränderung gebracht.
                              Kennt jemand dieses Problem oder kann helfen?
                              Danke!
                              • jpgorganizer
                                jpgorganizer @netfriend last edited by
                                @netfriend sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                Im Log steht dann:
                                2022-05-09 22:17:48.809 - [32minfo[39m: smartgarden.0 (10107) 3/ on_close: ### closed ### close.code=1001 close.reason=Going away
                                2022-05-09 22:17:48.811 - [32minfo[39m: smartgarden.0 (10107) 3/ sgSetState: info.connection value=false ack=true
                                2022-05-09 22:17:48.825 - [35msilly[39m: smartgarden.0 (10107) States user redis pmessage smartgarden.0.*/smartgarden.0.info.connection:{"val":false,"ack":true,"ts":1652127468818,"q":0,"from":"system.adapter.smartgarden.0","user":"system.user.admin","lc":1652127468818}
                                2022-05-09 22:17:48.828 - [32minfo[39m: smartgarden.0 (10107) 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
                                Danke!
                                du hast aber hier im Thread schon mal ein bisschen gelesen, oder?
                                • N
                                  Ja, mittels Suche habe ich mein Glück versucht. Da bin ich auf das Renew-API-Key gestoßen. Aber ich habe nicht alle 811 Beiträge gelesen.
                                    Thomas Braun Most Active @netfriend last edited by Thomas Braun
                                    @netfriend
                                    Einer der letzten hätte gereicht:
                                    Changelog
                                    1.0.6
                                    smartgarden
                                    github:	1.0.6
                                    latest:	1.0.6 for 5 days
                                    stable:	1.0.6 for 5 days
                                    Ergo: Bring dein System auf Stand. Nodejs inklusive.
                                    • N
                                      netfriend last edited by netfriend
                                      Ah, es gibt eine 1.0.6? Ich hatte bei meinem Adapter gesehen, dass dieser die 1.0.5. hat und aktuell ist. Von daher war das für mich ok. Wie komme ich zur 1.0.6?
                                        Der ist im Stable-Zweig.
                                        Normale Systempflege betreiben.
                                        iobroker update
                                        iobroker upgrade
                                          MrLee last edited by
                                          Moin!
                                          Nachdem mein sileno smart so super mit diesem Adapter funktioniert (komme von robonect) habe ich auch die Bewässerung smart upgegraded.
                                          Leider fehlt mir hier eine funktion:
                                          Ich möchte den Bewässerungszeitplan bos auf Widerruf aussetzen.
                                          Leider finde ich nur PAUSE_<number_of_seconds>
                                          Wie kann ich die Bewässerung ganz stoppen, in der App gibt es hier ein Haken...also scheint es einen Parameter zu geben...aber was muß ich übertragen?
                                          Vielen Dank
                                          Mr.Lee
                                          • jpgorganizer
                                            jpgorganizer @MrLee last edited by
                                            @mrlee sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                            Moin!
                                            Vielen Dank
                                            Mr.Lee
                                            siehe readme https://github.com/jpgorganizer/ioBroker.smartgarden
                                            unter SERVICE_VALVE bzw. SERVICE_VALVE_SET
                                            da sollte alles drin sein.
                                            Anmerkung: nur weil es was in der Gardena App gibt, gibt es das in der Public API noch lange nicht. Gardena hat eine eigene Schnittstelle für die eigene App
                                            gardena smart system smartgarden
                                            108
                                            1080
                                            288963
