      Thomas Braun Most Active @qqolli last edited by
      @qqolli
      Ich würde es so machen:
      iobroker stop
      iobroker fix
      cd /opt/iobroker
      sudo -H -u iobroker npm install iobroker.js-controller
      cd ~
      iobroker start
      qqolli 1 Reply Last reply Reply Quote 0
      • qqolli
        qqolli @Thomas Braun last edited by
        Habe ich gemacht:
        Bei der Installation des JS-Controllers, was bedeutet da:
        156 packages are looking for funding
        Muss ich da nochwas machen?
        Linux ioBroker 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
        The programs included with the Debian GNU/Linux system are free software;
        the exact distribution terms for each program are described in the
        individual files in /usr/share/doc/*/copyright.
        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
        permitted by applicable law.
        Last login: Wed Apr 20 10:39:52 2022 from 192.168.178.49
        pi@ioBroker:~ $ iobroker stop
        pi@ioBroker:~ $ iobroker fix
        library: loaded
        Library version=2022-02-10
            Welcome to the ioBroker installation fixer!
            Script version: 2022-02-13
            You might need to enter your password a couple of times.
            Installing prerequisites (1/3)
        OK:1 http://phoscon.de/apt/deconz buster InRelease
        OK:2 http://archive.raspberrypi.org/debian buster InRelease
        OK:3 https://packages.grafana.com/oss/deb stable InRelease
        OK:4 https://repos.influxdata.com/debian buster InRelease
        OK:5 https://deb.nodesource.com/node_14.x buster InRelease
        OK:6 http://raspbian.raspberrypi.org/raspbian buster InRelease
        OK:7 https://archive.raspbian.org/raspbian buster InRelease
        Installed gcc-c++
            Checking ioBroker user and directory permissions (2/3)
        Created /etc/sudoers.d/iobroker
        Fixing directory permissions...
            Checking autostart (3/3)
        Enabling autostart...
        Autostart enabled!
            Your installation was fixed successfully
            Run iobroker start to start ioBroker again!
        pi@ioBroker:~ $ cd /opt/iobroker/
        pi@ioBroker:/opt/iobroker $
        pi@ioBroker:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
        > iobroker.js-controller@4.0.21 preinstall /opt/iobroker/node_modules/iobroker.js-controller
        > node lib/preinstallCheck.js
        NPM version: 6.14.16
        > iobroker.js-controller@4.0.21 install /opt/iobroker/node_modules/iobroker.js-controller
        > node iobroker.js setup first
        Successfully migrated 87608 objects to Redis Sets
        object _design/system updated
          "defaultPrivate": "-----BEGIN RSA PRIVATE KEY----------END RSA PRIVATE KEY-----\r\n",
          "defaultPublic": "-----BEGIN CERTIFICATE---------END CERTIFICATE-----\r\n"
        Update certificate defaultPrivate
        The object "system.certificates" was updated successfully.
        Update certificate defaultPublic
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm WARN crc@4.1.0 requires a peer of buffer@>=6.0.3 but none is installed. You must install peer dependencies yourself.
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        + iobroker.js-controller@4.0.21
        added 7 packages from 1 contributor, removed 7 packages, updated 25 packages and moved 1 package in 131.488s
          run `npm fund` for details
        pi@ioBroker:/opt/iobroker $ cd ~
        pi@ioBroker:~ $ iobroker start
        pi@ioBroker:~ $
        • simatec
          @qqolli sagte in Test Adapter Backitup v2.4.x:
          Kannst du ignorieren ...
            Nein. Das sind 156 Pakete, deren Maintainer sich über deine (finanzielle) Unterstützung freuen würden.
            • qqolli
              @thomas-braun @simatec
              Na, schau mal einer an:
              pi@ioBroker:~ $ iobroker backup
              host.ioBroker 67346 states saved
              host.ioBroker 87510 objects saved
              Backup created: /opt/iobroker/backups/2022_04_20-12_07_26_backupiobroker.tar.gz
              pi@ioBroker:~ $ ls -al /opt/iobroker/backups/
              insgesamt 38780
              drwxrwxr-x+  2 iobroker iobroker    12288 Apr 20 12:08 .
              drwxrwxr-x+ 10 iobroker iobroker     4096 Apr 20 11:50 ..
              -rw-rw-r--+  1 iobroker iobroker 39692317 Apr 20 12:08 2022_04_20-12_07_26_backupiobroker.tar.gz
              pi@ioBroker:~ $
              Und endlich auch:
              Started iobroker ...
              [DEBUG] [mount] - noserverino option: false
              [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=backup,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.178.23/backup/ioBroker /opt/iobroker/backups"
              [DEBUG] [mount] - mount successfully completed
              [DEBUG] [mount] - done
              [DEBUG] [iobroker] - host.ioBroker 67346 states saved
              [DEBUG] [iobroker] - host.ioBroker 87510 objects saved
              [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2022_04_20-12_10_45_backupiobroker.tar.gz
              [DEBUG] [iobroker] - done
              [DEBUG] [cifs] - done
              [DEBUG] [clean] - done
              [DEBUG] [pushover] - done
              [DEBUG] [historyHTML] - new history html values created
              [DEBUG] [historyHTML] - done
              [DEBUG] [historyJSON] - new history json values created
              [DEBUG] [historyJSON] - done
              [DEBUG] [umount] - mount activ, umount is started ...
              [DEBUG] [umount] - umount successfully completed
              [DEBUG] [umount] - done
              [EXIT] 0
              ist das Backup wieder auf der NAS!!!
              Vielen lieben dank an euch beide für die Hilfe und eure Zeit! Ihr seid die Besten 🙂
              qqolli G 2 Replies Last reply Reply Quote 0
                Gonzokalle @qqolli last edited by
                Hallo, der Backitup Adapter soll soll in eine bestimmten Telegram Chat benachrichtigen. Kann ich irgendwo die Chat id eintragen?
                • simatec
                  simatec Developer Most Active @Gonzokalle last edited by
                  @gonzokalle Diese Einstellungen machst du in der Telegram Instanz
                    Gonzokalle @simatec last edited by
                    @simatec
                    Okay
                    Wie/wo kann ich hier eine Chat id eintragen?
                    • simatec
                      @gonzokalle Über den Token in den Telegram Einstellungen der Instanz gibst du doch an, in welchen Chat die Telegram Instanz sendet.
                        @simatec
                        Wenn ich den Token (xxxxxxxxxx:yyyyyyyyyyyyyyyyyyyyyyy-zzzzzzzzzzz) eingebe schreibt mir der Bot unter seinen Namen.
                        Er soll mir aber in eine Chatgruppe (Chat id habe ich) schreiben.
                        Der Bot ist natürlich Admin der Chatgruppe.
                        • simatec
                          @gonzokalle
                          Da musst du beim Telegram Adapter nachfragen.
                          Mir ist da nix bekannt
                          • simatec
                            Ab sofort steht auf Github und in kürze auch im latest die Version 2.4.7 zur Verfügung.
                            Changelog
                            2.4.7 (2022-05-16)
                            • (simatec) dependencies updated
                            • (simatec) many small bugfixes
                            • (simatec) Fix Sentry Error Messages
                            • (simatec) Default SMB Version 3.1.1
                            • simatec
                              Ab sofort steht die Version 2.4.9 auf Github und in kürze auch im latest zur Verfügung.
                              Changelog
                              2.4.9 (2022-05-25)
                              • (simatec) German Wiki added
                              • (simatec) English Wiki added
                              • (simatec) ignore .tar.gz files for zigbee Backups
                              E 1 Reply Last reply Reply Quote 2
                                Einstein67 @simatec last edited by Einstein67
                                @simatec Hallo und vielen Dank für die neue Version und das Wiki.
                                Ich hab gestern meine InfluxDB auf zwei Instanzen (wegen unterschiedlicher Vorhaltezeiten) umgestellt.
                                Hat super funktioniert und nach Angabe der Datenbanken in BackitUp (Sicherung mehrer Systeme) werden sie auch (als 2 unterschiedliche Dateien) auf mein NAS gesichert.
                                Beim Restore werden aber beide DBs komischerweise mit dem selben Namen (iobroker) erstellt. Deshalb lässt sich nur die erste DB wiederherstellen. Die zweite scheitert dann weil die DB schon vorhanden ist, mit der Fehlermeldung:
                                Started restore ...
                                [DEBUG] [influxDB] - Created tmp directory
                                [DEBUG] [influxDB] - Start infuxDB Restore ...
                                [ERROR] [influxDB] - 2022/05/26 09:53:40 error updating meta: DB metadata not changed. database may already exist
                                restore: DB metadata not changed. database may already exist
                                [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
                                [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
                                [DEBUG] [influxDB] - infuxDB Restore completed successfully
                                [EXIT] influxDB restore done
                                Hab ich da einen Denkfehler .... und das geht so nicht?
                                Edit:
                                Datenbank der Instanz.0 heißt: iobroker
                                Datenbank der Instanz.1 heißt: tempdaten
                                Beim Wiederherstellen werden beide als iobroker erstellt.
                                EditEdit: Wenn man die erstellten Backups entpackt und das Restore über den Influxdb-Befehl manuell ausführt, dann werden die DBs unter dem richtigen Namen problemlos erstellt. Also kein großes Problem ... 😉
                                • simatec
                                  simatec Developer Most Active @Einstein67 last edited by
                                  @einstein67 danke gür den Hinweis. Könntest du hierzu bitte ein Issue aufmachen?
                                    Altersrentner @simatec last edited by
                                    @simatec
                                    Guten Morgen,
                                    Ich habe gerade festgestellt, dass meine v2.4.6 nicht wie gefordert regelmäßig sichert.
                                    Letzte Sicherung von ioBrokerist erfolgte auf GoogleDrive am 04.05.22
                                    [DEBUG] [iobroker] - host.raspberrypi 21952 states saved
                                    [DEBUG] [iobroker] - host.raspberrypi 24331 objects saved
                                    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2022_05_26-10_45_47_backupiobroker.tar.gz
                                    [DEBUG] [influxDB] - InfluxDB-Backup started ...
                                    [DEBUG] [influxDB] - Start InfluxDB Backup ...
                                    [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
                                    [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2022_05_26-10_46_10_backupiobroker.tar.gz
                                    [DEBUG] [influxDB] - InfluxDB-Backup for is finish
                                    [DEBUG] [influxDB] - done
                                    [DEBUG] [historyDB] - compress from historyDB started ...
                                    [ERROR] [historyDB] - Backitup cannot found source "undefined" for compress!
                                    GoogleDrive Zugriff ist vorhanden / wurde erneuert.
                                    Mit freundlichen Grüßen
                                    Michael
                                    • simatec
                                      simatec Developer Most Active @Altersrentner last edited by
                                      @altersrentner
                                      Prüfe in dem History Adapter den Speicherpfad und trage diesen auch im identisch im Backup Adapter ein
                                        @simatec said in Test Adapter ioBroker.backitup v2.4.x:
                                        Ja mach ich dann! Ich will vorher noch rausfinden obs eventuell doch nur an meinen Einstellungen liegt.
                                        DB-Benutzername: "iobroker"
                                        DB-Name: "iobroker"
                                        Vielleicht "beisst" sich da was in den Schwanz ... 🙂
                                        • simatec
                                          @einstein67 Ich schaue mal im Code, ob da eventuell ein Konflikt besteht.
                                          Eventuell muss ich bei den Multi Backups den DB Namen für den Restore mit in das Archiv legen
                                          Muss ich mir mal anschauen
                                            @simatec sagte in Test Adapter ioBroker.backitup v2.4.x:
                                            Danke für Deine Nachricht.
                                            Ist unverändert:
                                            [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2022_05_26-11_29_34_backupiobroker.tar.gz
                                            [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2022_05_26-11_29_56_backupiobroker.tar.gz
                                            MfG Michael
                                            170
                                            2780
                                            2378726
