    4. Probleme von 4.0.21 auf 4.0.23
      Thomas Braun Most Active @SMS last edited by Thomas Braun
      @sms
      Dann schau im log von gestern.
      zless -R /opt/iobroker/log/iobroker.2022-05-05.log.gz
      syslog liegt woanders, falls du das anschauen willst.
        apollon77 @SMS last edited by
        @sms Bzw bei Syslog heisst das syslog.1 bzw syslog.X.gz
        Thomas Braun SMS 3 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @apollon77 last edited by
          @apollon77 sagte in Probleme von 4.0.21 auf 4.0.23:
          Und ist nicht per Datum eindeutig gekennzeichnet. Das syslog läuft permanent seit boot.
          • SMS
            SMS @apollon77 last edited by
            2022-05-05 22:21:58.771  - info: host.homee instance system.adapter.mqtt.0 terminated with code null ()
            2022-05-05 22:21:58.870  - info: host.homee instance system.adapter.influxdb.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2022-05-05 22:21:58.870  - info: host.homee All instances are stopped.
            2022-05-05 22:22:07.702  - info: host.homee terminated
            2022-05-05 22:25:17.286  - info: host.homee iobroker.js-controller version 4.0.23 js-controller starting
            2022-05-05 22:25:17.293  - info: host.homee Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
            2022-05-05 22:25:17.294  - info: host.homee hostname: homee, node: v14.19.1
            2022-05-05 22:25:17.294  - info: host.homee ip addresses: 192.168.178.58 2001:16b8:24be:ce00:35fc:e4dd:2647:ec17 fe80::f3d:d27f:ef47:279
            2022-05-05 22:25:21.569  - info: host.homee connected to Objects and States
            2022-05-05 22:25:21.634  - info: host.homee added notifications configuration of host
            2022-05-05 22:25:22.777  - info: host.homee 55 instances found
            2022-05-05 22:25:22.874  - info: host.homee starting 23 instances
            2022-05-05 22:25:22.892  - warn: host.homee startInstance cannot find adapter "ds18b20@1.5.4". Try to install it... 1 attempt
            2022-05-05 22:25:22.893  - info: host.homee iobroker install ds18b20@1.5.4 using installedFrom
            2022-05-05 22:25:23.266  - info: host.homee instance system.adapter.admin.0 started with pid 2255
            2022-05-05 22:25:26.754  - info: host.homee iobroker npm-install: NPM version: 6.14.16
            2022-05-05 22:25:26.756  - info: host.homee iobroker npm-install: Installing iobroker.ds18b20@1.5.4... (System call)
            2022-05-05 22:25:26.924  - info: host.homee instance system.adapter.email.0 started with pid 2287
            2022-05-05 22:25:27.120  - info: admin.0 (2255) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v14.19.1, js-controller: 4.0.23
            2022-05-05 22:25:27.210  - info: admin.0 (2255) requesting all states
            2022-05-05 22:25:27.211  - info: admin.0 (2255) requesting all objects
            2022-05-05 22:25:29.417  - info: admin.0 (2255) received all objects
            2022-05-05 22:25:29.654  - info: admin.0 (2255) Request actual repository...
            2022-05-05 22:25:29.773  - info: admin.0 (2255) http server listening on port 7777
            2022-05-05 22:25:29.774  - info: admin.0 (2255) Use link "http://localhost:7777" to configure.
            2022-05-05 22:25:32.269  - info: host.homee instance system.adapter.influxdb.0 started with pid 2306
            2022-05-05 22:25:37.582  - info: host.homee instance system.adapter.javascript.0 started with pid 2317
            2022-05-05 22:25:39.354  - info: host.homee Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
            2022-05-05 22:25:41.855  - info: host.homee instance scheduled system.adapter.ical.0 0 */12 * * *
            2022-05-05 22:25:43.416  - info: admin.0 (2255) Repository received successfully.
            2022-05-05 22:25:41.898  - info: host.homee instance system.adapter.ical.0 started with pid 2336
            2022-05-05 22:25:46.687  - info: email.0 (2287) starting. Version 1.0.10 in /opt/iobroker/node_modules/iobroker.email, node: v14.19.1, js-controller: 4.0.23
            2022-05-05 22:25:46.945  - info: host.homee instance system.adapter.mqtt.0 started with pid 2351
            2022-05-05 22:25:47.568  - info: host.homee instance system.adapter.rpi2.0 started with pid 2358
            2022-05-05 22:25:50.630  - info: influxdb.0 (2306) starting. Version 2.6.3 in /opt/iobroker/node_modules/iobroker.influxdb, node: v14.19.1, js-controller: 4.0.23
            2022-05-05 22:25:50.697  - info: influxdb.0 (2306) No stored data from last exit found
            2022-05-05 22:25:50.699  - info: influxdb.0 (2306) Connecting http://192.168.178.58:8086 ...
            2022-05-05 22:25:50.700  - info: influxdb.0 (2306) Influx DB Version used: 1.x
            nix zu sehen
            • SMS
              May  5 22:25:16 homee systemd[1]: Started ioBroker Server.
              May  5 22:25:16 homee influxd-systemd-start.sh[496]: ts=2022-05-05T20:25:16.815776Z lvl=info msg="TSM compaction (end)" log_id=0aHT8Fol000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0aHUD9fG000 op_name=tsm1_compact_grou$
              May  5 22:25:17 homee influxd-systemd-start.sh[496]: ts=2022-05-05T20:25:17.385721Z lvl=info msg="TSM compaction (start)" log_id=0aHT8Fol000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0aHUDPIG000 op_name=tsm1_compact_gr$
              May  5 22:25:17 homee influxd-systemd-start.sh[496]: ts=2022-05-05T20:25:17.385781Z lvl=info msg="Beginning compaction" log_id=0aHT8Fol000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0aHUDPIG000 op_name=tsm1_compact_grou$
              May  5 22:25:17 homee influxd-systemd-start.sh[496]: ts=2022-05-05T20:25:17.385803Z lvl=info msg="Compacting file" log_id=0aHT8Fol000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0aHUDPIG000 op_name=tsm1_compact_group db_$
              May  5 22:25:17 homee influxd-systemd-start.sh[496]: ts=2022-05-05T20:25:17.385824Z lvl=info msg="Compacting file" log_id=0aHT8Fol000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0aHUDPIG000 op_name=tsm1_compact_group db_$
              May  5 22:25:19 homee influxd-systemd-start.sh[496]: ts=2022-05-05T20:25:19.698975Z lvl=warn msg="Error compacting TSM files" log_id=0aHT8Fol000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0aHUDPIG000 op_name=tsm1_compac$
              May  5 22:25:20 homee influxd-systemd-start.sh[496]: ts=2022-05-05T20:25:20.699205Z lvl=info msg="TSM compaction (end)" log_id=0aHT8Fol000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0aHUDPIG000 op_name=tsm1_compact_grou$
              May  5 22:25:21 homee influxd-systemd-start.sh[496]: ts=2022-05-05T20:25:21.385843Z lvl=info msg="TSM compaction (start)" log_id=0aHT8Fol000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0aHUDdvG000 op_name=tsm1_compact_gr$
              May  5 22:25:21 homee influxd-systemd-start.sh[496]: ts=2022-05-05T20:25:21.385901Z lvl=info msg="Beginning compaction" log_id=0aHT8Fol000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0aHUDdvG000 op_name=tsm1_compact_grou$
              May  5 22:25:21 homee influxd-systemd-start.sh[496]: ts=2022-05-05T20:25:21.385922Z lvl=info msg="Compacting file" log_id=0aHT8Fol000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0aHUDdvG000 op_name=tsm1_compact_group db_$
              May  5 22:25:21 homee influxd-systemd-start.sh[496]: ts=2022-05-05T20:25:21.385946Z lvl=info msg="Compacting file" log_id=0aHT8Fol000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0aHUDdvG000 op_name=tsm1_compact_group db_$
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.admin.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.admin.1" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.email.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.influxdb.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.javascript.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.whatsapp-cmb.0" for host "Gartenklo"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.ical.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.modbus.1" for host "kellerkind4GB"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.modbus.2" for host "kellerkind4GB"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.mqtt.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.rpi2.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.rpi2.1" for host "kellerkind4GB"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.rpi2.4" for host "Gartenklo"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.smartmeter.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.sonoff.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.rpi2.2" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.rpi2.3" for host "PapaHuette"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.backitup.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.binance.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.coronavirus-statistics.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.daswetter.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.ds18b20.1" for host "kellerkind4GB"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.ds18b20.2" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.dwd.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.ecovacs-deebot.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.fritzbox.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.growatt.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.nina.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.parser.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.pegelalarm.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.pollenflug.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.systeminfo.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.systeminfo.1" for host "kellerkind4GB"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.systeminfo.4" for host "Gartenklo"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.tankerkoenig.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.vis-bars.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.vis-canvas-gauges.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.vis-history.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.vis-hqwidgets.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.vis-jqui-mfd.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.vis-justgage.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.vis-metro.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.vis-plumb.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.vis-rgraph.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.vis-timeandweather.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.vis.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.web.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.worx.2" for host "PapaHuette"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.systeminfo.2" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.discovery.0" for host "homee"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.systeminfo.3" for host "PapaHuette"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.ds18b20.3" for host "PapaHuette"
              May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.pegelalarm.1" for host "homee"
              May  5 22:25:24 homee influxd-systemd-start.sh[496]: ts=2022-05-05T20:25:24.111574Z lvl=warn msg="Error compacting TSM files" log_id=0aHT8Fol000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0aHUDdvG000 op_name=tsm1_compac$
              May  5 22:25:24 homee kernel: [ 1137.087409] w1_master_driver w1_bus_master1: Attaching one wire slave 00.a80000000000 crc 6d
              May  5 22:25:24 homee kernel: [ 1137.094042] w1_master_driver w1_bus_master1: Family 0 for 00.a80000000000.6d is not registered.
              May  5 22:25:30 homee bash[2230]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
              May  5 22:25:38 homee bash[2230]: Send diag info: {"uuid":"552ef446-e4c5-844c-fb5b-c3c1844dd251","language":"de","country":"Germany","hosts":[{"version":"4.0.23","platform":"Javascript/Node.js","type":"linux"},{"version":"4.0.23","platf$
              May  5 22:26:55 homee bash[2230]: Send diag info: {"uuid":"552ef446-e4c5-844c-fb5b-c3c1844dd251","language":"de","country":"Germany","hosts":[{"version":"4.0.23","platform":"Javascript/Node.js","type":"linux"},{"version":"4.0.23","platf$
                @sms was steht da früher?im log sieht man klar das 22:22 iobroker gestoppt wurde und 22:25 gestartet. Also was steht so gegen 22:22 bis 25 im syslog???
                SMS 1 Reply Last reply Reply Quote 0
                • SMS
                  @apollon77
                  Leider nicht mehr rausfindbar. In den Dateien stehen nur Hyroglyphen.
                    @sms Wenn das so ist ............. SD Karte defekt?
                      @apollon77
                      Oder es wurde das gz-Archiv mir einem Editor geöffnet.
                      apollon77 SMS 2 Replies Last reply Reply Quote 0
                        apollon77 @Thomas Braun last edited by
                        @thomas-braun lol ... ja right .. Auch ne Option gg
                        • SMS
                          SMS @Thomas Braun last edited by
                          so:
                          nano /var/log/syslog.6.gz
                          Denke das wird dann wohl falsch sein ...
                            @sms sagte in Probleme von 4.0.21 auf 4.0.23:
                            Ich würde mir das in einem pager anschauen.
                            less bzw. in Falle von gezippten Dateien zless
                            zless /var/log/syslog.6.gz
                            • SMS
                              @thomas-braun sagte in Probleme von 4.0.21 auf 4.0.23:
                              May  5 22:21:56 homee influxd-systemd-start.sh[496]: ts=2022-05-05T20:21:56.385873Z lvl=info msg="Compacting file" log_id=0aHT8Fol000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0aHU188G000 op_name=tsm1_compact_group db_s
                              hard_id=105 tsm1_index=1 tsm1_file=/var/lib/influxdb/data/iobroker/autogen/105/000000011-000000001.tsm
                              May  5 22:21:57 homee bash[861]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [Process stopped]
                              May  5 22:21:58 homee bash[861]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
                              May  5 22:21:58 homee bash[861]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
                              May  5 22:21:58 homee bash[861]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
                              May  5 22:25:21 homee influxd-systemd-start.sh[496]: ts=2022-05-05T20:25:21.385922Z lvl=info msg="Compacting file" log_id=0aHT8Fol000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0aHUDdvG000 op_name=tsm1_compact_group db_s
                              hard_id=105 tsm1_index=0 tsm1_file=/var/lib/influxdb/data/iobroker/autogen/105/000000010-000000002.tsm
                              May  5 22:25:21 homee influxd-systemd-start.sh[496]: ts=2022-05-05T20:25:21.385946Z lvl=info msg="Compacting file" log_id=0aHT8Fol000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0aHUDdvG000 op_name=tsm1_compact_group db_s
                              May  5 22:25:24 homee influxd-systemd-start.sh[496]: ts=2022-05-05T20:25:24.111574Z lvl=warn msg="Error compacting TSM files" log_id=0aHT8Fol000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0aHUDdvG000 op_name=tsm1_compact_group db_shard_id=105 error="BlockCount: error unpacking block: unpackBlock: not enough data for timestamp, BlockCount: error unpacking block: unpackBlock: not enough data for timestamp"
                              May  5 22:25:25 homee influxd-systemd-start.sh[496]: ts=2022-05-05T20:25:25.111857Z lvl=info msg="TSM compaction (end)" log_id=0aHT8Fol000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0aHUDdvG000 op_name=tsm1_compact_group db_shard_id=105 op_event=end op_elapsed=3725.999ms
                              May  5 22:25:38 homee bash[2230]: Send diag info: {"uuid":"552ef446-e4c5-844c-fb5b-c3c1844dd251","language":"de","country":"Germany","hosts":[{"version":"4.0.23","platform":"Javascript/Node.js","type":"linux"},{"version":"4.0.23","platform":"Javascript/Node.js","type":"linux"},{"version":"4.0.23","platform":"Javascript/Node.js","type":"linux"},{"version":"4.0.23","platform":"Javascript/Node.js","type":"linux"}],"node":"v14.19.1","arch":"arm","docker":false,"adapters":{"admin":{"version":"5.3.8","platform":"Javascript/Node.js"},"backitup":{"version":"2.4.6","platform":"Javascript/Node.js"},"binance":{"version":"1.1.3","platform":"Javascript/Node.js"},"coronavirus-statistics":{"version":"0.8.7","platform":"Javascript/Node.js"},"daswetter":{"version":"3.1.2","platform":"Javascript/Node.js"},"devices":{"version":"1.0.10","platform":"Javascript/Node.js"},"discovery":{"version":"3.0.3","platform":"Javascript/Node.js"},"ds18b20":{"version":"1.6.0","platform":"Javascript/Node.js"},"dwd":{"version":"2.8.3","platform":"Javascript/Node.js"},"ecovacs-deebot":{"version":"1.3.3","platform":"Javascript/Node.js"},"email":{"version":"1.0.10","platform":"Javascript/Node.js"},"flot":{"version":"1.10.6","platform":"javascript/Node.js"},"fritzbox":{"version":"0.2.1","platform":"Javascript/Node.js"},"growatt":{"version":"1.1.15","platform":"Javascript/Node.js"},"history":{"version":"1.9.13","platform":"Javascript/Node.js"},"ical":{"version":"1.12.1","platform":"Javascript/Node.js"},"icons-mfd-svg":{"version":"1.1.0","platform":"Javascript/Node.js"},"influxdb":{"version":"2.6.3","platform":"Javascript/Node.js"},"info":{"version":"1.9.18","platform":"Javascript/Node.js"},"javascript":{"version":"5.2.21","platform":"Javascript/Node.js"},"modbus":{"version":"3.4.11","platform":"Javascript/Node.js"},"mqtt":{"version":"2.7.4","platform":"Javascript/Node.js"},"nina":{"version":"0.0.25","platform":"Javascript/Node.js"},"node-red":{"version":"2.0.1","platform":"Javascript/Node.js"},"onvif":{"version":"0.4.4","platform":"Javascript/Node.js"},"parser":{"version":"1.1.4","platform":"Javascript/Node.js"},"pegelalarm":{"version":"1.2.5","platform":"Javascript/Node.js"},"pollenflug":{"version":"1.0.6","platform":"Javascript/Node.js"},"roomba":{"version":"1.1.4","platform":"Javascript/Node.js"},"rpi2":{"version":"1.3.2","platform":"Javascript/Node.js"},"simple-api":{"version":"2.6.4","platform":"Javascript/Node.js"},"smartmeter":{"version":"3.3.4","platform":"Javascript/Node.js"},"sonoff":{"version":"2.5.0","platform":"Javascript/Node.js"},"systeminfo":{"version":"0.3.1","platform":"Javascript/Node.js"},"tankerkoenig":{"version":"2.1.1","platform":"javascript/Node.js"},"tr-064":{"version":"4.2.14","platform":"Javascript/Node.js"},"upnp":{"version":"1.0.19","platform":"Javascript/Node.js"},"vis":{"version":"1.4.15","platform":"Javascript/Node.js"},"vis-bars":{"version":"0.1.4","platform":"Javascript/Node.js"},"vis-canvas-gauges":{"version":"0.1.5","platform":"Javascript/Node.js"},"vis-history":{"version":"1.0.0","platform":"Javascript/Node.js"},"vis-hqwidgets":{"version":"1.2.0","platform":"Javascript/Node.js"},"vis-jqui-mfd":{"version":"1.0.12","platform":"Javascript/Node.js"},"vis-justgage":{"version":"1.0.2","platform":"Javascript/Node.js"},"vis-metro":{"version":"1.2.0","platform":"Javascript/Node.js"},"vis-plumb":{"version":"1.0.2","platform":"Javascript/Node.js"},"vis-rgraph":{"version":"0.0.2","platform":"Javascript/Node.js"},"vis-timeandweather":{"version":"1.1.7","platform":"Javascript/Node.js"},"web":{"version":"4.2.3","platform":"Javascript/Node.js"},"whatsapp-cmb":{"version":"0.2.2","platform":"Javascript/Node.js"},"worx":{"version":"1.5.5","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":55,"noCompactInstances":0,"model":"ARMv7 Processor rev 3 (v7l)","cpus":4,"mem":8281378816,"ostype":"Linux","city":"Gernsbach","vis":728}
                              • SMS
                                SMS last edited by
                                Das erscheint seit kurzem auf dem Handy wenn ich Kurven von Grafana anschauen möchte:
                                Auf dem Laptop funktioniert es. Andere Browser habe ich es auf dem Handy auch schon ausprobiert. Ebenfalls anderes Handy.
                                Neustart Grafana auch schon probiert.
                                  apollon77 @SMS last edited by apollon77
                                  Naja die Preisfrage ist ja was dort passiert ist.
                                  Um 22:21 ist dein iobroker gestoppt worden. Um den grund zu sehen müsste man ein bissl mehr log von davor schauen.
                                  Und um 22:25 ist er quasi wieder gestartet.
                                  Aber das wussten wir ja schon
                                  Leider bist Du gerade seeehr sparsam mit Logs ... Sowohl das obige ioBroker Log startet erst 22:21:58 wie auch das syslog 22:21:56 ... aber da ist ioBroker schon am runterfahren ... eeeeeergo ... Keine Ahnung
                                  • SMS
                                    @apollon77
                                    Es ist halt kompliziert das alles zu markieren, oder gibt es eine Möglichkeit? Davor steht meist was von Influx DB.
                                    Kann aber auch sein das ich iobroker selbst neu gestartet habe. Das weiß ich nicht mehr so genau.
                                    Aber warum bekomme ich Grafana nicht mehr auf dem Hand angezeigt bzw. warum steht im LOG soviel von I flux DB?
                                      mguenther @apollon77 last edited by mguenther
                                      ääähhmm mal ganz Langsam ...
                                      Die Meldung mit 120 ist eine Warnung. Die halt nichts zu sagen. Es gibt auch keinen Fehler der sagt das das Update nicht getan hat.
                                      Aber ja die Meldung mach so keinen sinn (der Code setz den korrigierten Wert bevor es die Fehlemeldung schreibt - fixen wir in Zukunft), aber auch ja: das "period" ist das Problem. Aber wie gesagt es wird nur automatisch korrigiert.
                                      Was ist denn genau das Problem?
                                      ich ziehe mal das alte Thema hoch. Ich habe nämlich jetzt auch (hatte ich vorher so nicht, zumindest hatte ich es nicht gesehen), diese Ausgabe beim update des Controllers von 4.0.24 auf 5.0.12:
                                      pi@raspberrypi:~ $ iob upgrade self
                                      Server Configured backup period 120 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
                                      Update js-controller from @4.0.24 to @5.0.12
                                      Stopped Objects DB
                                      Stopped States DB
                                      NPM version: 9.6.7
                                      Installing iobroker.js-controller@5.0.12... (System call)
                                      added 13 packages, removed 124 packages, and changed 28 packages in 43s
                                      251 packages are looking for funding
                                        run `npm fund` for details
                                      pi@raspberrypi:~ $
                                      vorher die Befehle wie folgt eingegeben.
                                      iob stop
                                      iob update
                                      iob fix
                                      iob upgrade self
                                      Das Update lief normal durch, aber muss ich jetzt noch etwas anpassen? Ich habe ein Multihost-System und die Meldung kam sowohl beim Master, als auch beim Slave
                                      danke für ne Rückinfo
                                      Marcus
                                      Edit: sehe gerade, dass der Threadtitel nun gar nicht mehr passt. Vielleicht kann den einer anpassen oder zumindest den Titel ignorieren. Es ging um das Update von 4.0.24 auf 5.0.12.
                                      mcm1957 apollon77 2 Replies Last reply Reply Quote 0
                                      • mcm1957
                                        mcm1957 @mguenther last edited by
                                        @mguenther said in Probleme von 4.0.21 auf 4.0.23:
                                        Lass doch die Leichen im Keller schlafen 🙂
                                        Für den Upgrade auf js-controller 5.0.x gibts einen passenden, eigenen und aktuellen Thread:
                                        https://forum.iobroker.net/topic/68290/js-controller-5-0-x-jetzt-für-alle-user-im-stable
                                        Stell deine Fragen sinnvoller Weise dort.
                                          mguenther @mcm1957 last edited by
                                          @mcm57 sagte in Probleme von 4.0.21 auf 4.0.23:
                                          stable
                                          hast ja eigentlich Recht, ich habs auch zu spät erst gemerkt - ich hab eigentlich ja auch keinen Fehler - das update lief ja durch. Appollon schrieb ja, dass der Bug in Zukunft behoben werden soll. Er tauchte jetzt bei mir das erste Mal auf - daher der Eintrag hier.
                                            apollon77 @mguenther last edited by
                                            @mguenther naja in deiner iobroker.json in der ost konfig steht beim Backup interval eine zu hohe zahl ... Wenn Du die meldung wegbekommen willst ändere das 🙂
                                            8900
