    4. Adapter Hyundai (Bluelink) oder KIA (UVO)
    • Meister Mopper
      Meister Mopper @Gatam last edited by
      @gatam
      Nö bei mir nicht. Der Server ist nach meiner Beobachtung sehr fehlerhaft beim Zugang. Aktuell funktioniert es mal wieder gut.
        mmemme last edited by
        ich bekomme eine neuen Fehler beim Anmelden, kennt das bereits jemand?
        2022-04-24 11:13:58.302 - info: host.raspberrypi stopInstance system.adapter.bluelink.0 (force=false, process=true)
        2022-04-24 11:13:58.309 - info: bluelink.0 (28048) Got terminate signal TERMINATE_YOURSELF
        2022-04-24 11:13:58.309 - info: host.raspberrypi stopInstance system.adapter.bluelink.0 send kill signal
        2022-04-24 11:13:58.310 - info: bluelink.0 (28048) Adapter bluelink cleaned up everything...
        2022-04-24 11:13:58.311 - info: bluelink.0 (28048) terminating
        2022-04-24 11:13:58.313 - info: bluelink.0 (28048) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2022-04-24 11:13:58.962 - info: host.raspberrypi instance system.adapter.bluelink.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2022-04-24 11:14:01.396 - info: host.raspberrypi instance system.adapter.bluelink.0 started with pid 32534
        2022-04-24 11:14:03.195 - info: bluelink.0 (32534) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.bluelink, node: v10.24.0, js-controller: 3.2.16
        2022-04-24 11:14:03.230 - info: bluelink.0 (32534) Login to api
        2022-04-24 11:14:10.513 - info: bluelink.0 (32534) 1 Vehicles found
        2022-04-24 11:14:10.717 - info: bluelink.0 (32534) Error on API-Full-Status - Fallback GetNormalStatus
        2022-04-24 11:14:10.925 - error: bluelink.0 (32534) Error on API-Request Status
        2022-04-24 11:14:10.926 - error: bluelink.0 (32534) @EuropeController.pin: [400] Bad Request on [PUT] https://prd.eu-ccapi.kia.com:8080/api/v1/user/pin - {"errId":"5757072c-53e3-4a6b-b8f9-2fa778dc021d","errCode":"4003","errMsg":"Invalid values","errBody":{"remainCount":3,"remainTime":300}}
        Meister Mopper M 2 Replies Last reply Reply Quote 0
        • Meister Mopper
          Meister Mopper @mmemme last edited by
          @mmemme sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
          Das würde ich aber dringend mal auf den aktuellen Stand bringen.
            Michaelnorge @mmemme last edited by
            @mmemme said in Adapter Hyundai (Bluelink) oder KIA (UVO):
            So was habe ich in meinem log noch nie gesehen...
              mmemme @Meister Mopper last edited by
              @meister-mopper ist bereits erledigt, der Fehler besteht weiterhin.
              Newan 1 Reply Last reply Reply Quote 0
              • Newan
                Newan @mmemme last edited by
                @mmemme Mal in der App ausloggen und wieder einloggen, oft wird da nach einem neuen Password etc gefragt
                  mmemme @Newan last edited by
                  @newan vielen Dank, ich habe mein Kennwort und PIN zurueckgesetzt, bekomme jetzt einen neuen Fehler beim starten:
                  2022-05-08 12:09:53.343 - info: bluelink.0 (1682) Login to api
                  2022-05-08 12:10:00.244 - info: bluelink.0 (1682) 1 Vehicles found
                  2022-05-08 12:10:03.671 - info: bluelink.0 (1682) Error on API-Full-Status - Fallback GetNormalStatus
                  2022-05-08 12:10:04.013 - error: bluelink.0 (1682) Error on API-Request Status
                  2022-05-08 12:10:04.014 - error: bluelink.0 (1682) @EuropeVehicle.status: [400] Bad Request on [GET] https://prd.eu-ccapi.kia.com:8080/api/v2/spa/vehicles/2497512d-a0cb-4e8f-a07c-3c9a9d171e70/status - {"retCode":"F","resCode":"4004","resMsg":"Duplicate request - Duplicate request","msgId":"a16c2adb-38b8-4809-916c-f37e85ff2f0c"}
                    Aiouh @mmemme last edited by
                    @newan noch ne Frage...kann man den Adapter auch manuell zum Abholen der Werte anstossen?
                    Ich würde die Abfragen gerne nur dann machen wenn er angesteckt ist, denn ansonsten wird jedes mal das Fahrzeug aufgeweckt, was ich eigentlich vermeiden will. Notfalls mach ich das mit Stoppen und Starten des Adapters, ist halt nicht so elegant
                    • Meister Mopper
                      Meister Mopper @Aiouh last edited by Meister Mopper
                      @aiouh
                      Viermal in 24 Stunden ist ja ein Muss für den Erhalt aller Daten. Für die manuelle Aktualisierung ist der control button "force_refresh" zuständig.
                      • Meister Mopper
                        Meister Mopper @Meister Mopper last edited by
                        @meister-mopper
                        Hier mal ein anderes Phänomen:
                        Ich versuche auf verschiedene Weisen, den Ladevorgang abzubrechen und bekomme nur Fehlermeldungen:
                        bluelink.0
                        	2022-05-09 17:47:22.291	error	No command for Control found for: bluelink.0.KNACC81GFN5121414.control.charge_stop
                        bluelink.0
                        	2022-05-09 17:47:03.755	error	No command for Control found for: bluelink.0.KNACC81GFN5121414.control.charge_stop
                        bluelink.0
                        	2022-05-09 17:46:28.571	error	No command for Control found for: bluelink.0.KNACC81GFN5121414.control.charge_stop
                        bluelink.0
                        	2022-05-09 17:45:37.674	error	No command for Control found for: bluelink.0.KNACC81GFN5121414.control.charge_stop
                        1. zwei mal per widget =true
                        2. in den Objekten Button=true
                        3. in den Objekten Button=true (bestätigt)
                        Kann mir jemand sagen, was ich da falsch mache?
                        A Newan 2 Replies Last reply Reply Quote 0
                          Aiouh @Meister Mopper last edited by Aiouh
                          .deleted
                          • Newan
                            Newan @Meister Mopper last edited by
                            @meister-mopper Steuer das doch eher über die wallbox. Welche hast den da?
                              Aiouh last edited by Aiouh
                              @Meister-Mopper Danke für den Hinweis
                              @newan Ich habe den force refresh mal auf true gesetzt, eine Aktualisierung der Daten ist nicht erfolgt.
                              Dann habe ich ins log geschaut und dort folg. Meldung gesehen
                              bluelink.0 2022-05-09 20:00:50.167	error	@EuropeController.pin: [400] Bad Request on [PUT] https://prd.eu-ccapi.kia.com:8080/api/v1/user/pin - {"errId":"8dd494b6-62b1-4d97-b9e7-e493b9f4b5ca","errCode":"4002","errMsg":"Invalid parameters"}
                              bluelink.0 2022-05-09 20:00:50.166	error	Error on API-Request Status
                              bluelink.0 2022-05-09 20:00:50.068	info	Error on API-Full-Status - Fallback GetNormalStatus
                              bluelink.0 2022-05-09 20:00:49.735	info	1 Vehicles found
                              bluelink.0 2022-05-09 20:00:44.085	info	Login to api
                              bluelink.0 2022-05-09 20:00:43.945	info	starting. Version 2.2.3 (non-npm: Newan/ioBroker.bluelink) in /opt/iobroker/node_modules/iobroker.bluelink, node: v14.19.1, js-controller: 4.0.23
                              Dann hab ich in den settings der instanz nachgeschaut und festgestellt, dass das Passwort leer war. Ist das immer so?
                              Jedenfalls habe ich es eingetragen, dasselbe Problem. Die PIN habe ich leer gelassen, wüsste nicht wo ich eine solche hätte.
                              Bis heute morgen lief es zuverlässig 😞
                                Michaelnorge @Aiouh last edited by
                                @aiouh said in Adapter Hyundai (Bluelink) oder KIA (UVO):
                                Die PIN ist die gleiche die Du eingibst wenn Du Bluelink bei Deinem Handy benutzt und da ne Abfrage startest.
                                • Meister Mopper
                                  Meister Mopper @Newan last edited by
                                  @newan sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                                  Ich habe eine EVBox und leider noch keine Möglichkeit gefunden, diese im ioBroker zu steuern.
                                    Aiouh @Michaelnorge last edited by Aiouh
                                    @michaelnorge Danke ! Da ich nur mit Fingerprint arbeite nutze ich schon ewig keine PIN mehr, konnte mich aber doch erinnern wie die "damals" war. Jetzt läuft der adapter wieder.
                                    Muss ich eigentlich zum refresh den force refresh auf true setzen und dann wieder auf false, z.B. mit 5 s. Verzögerung? Oder reicht es immer nur auf true zu setzen. Per script meine ich.
                                    Die Fehler bekomme ich noch, ignoriere ich aber, denn ich brauch die objekte eh nicht.
                                    bluelink.0 2022-05-10 20:56:55.581	info	State value to set for "bluelink.0.KNAJxxxx.vehicleStatus.steerWheelHeat" has to be type "boolean" but received type "number"
                                    bluelink.0 2022-05-10 20:56:55.504	info	State value to set for "bluelink.0.KNAJxxxx.vehicleStatus.doorOpen.backRight" has to be type "boolean" but received type "number"
                                    bluelink.0 2022-05-10 20:56:55.452	info	State value to set for "bluelink.0.KNAJxxxx.vehicleStatus.doorOpen.backLeft" has to be type "boolean" but received type "number"
                                    bluelink.0 2022-05-10 20:56:55.404	info	State value to set for "bluelink.0.KNAJxxxx.vehicleStatus.doorOpen.frontRight" has to be type "boolean" but received type "number"
                                    bluelink.0 2022-05-10 20:56:55.357	info	State value to set for "bluelink.0.KNAJxxxx.vehicleStatus.doorOpen.frontLeft" has to be type "boolean" but received type "number"
                                    • Meister Mopper
                                      @aiouh sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                                      Ist nicht erforderlich. Einfach mit true aktualisieren.
                                        THELOH @Meister Mopper last edited by
                                        @meister-mopper Per Modbus wäre doch eine Option
                                        • Meister Mopper
                                          Meister Mopper @THELOH last edited by
                                          @theloh
                                          Ich habe bis jetzt leider noch keine Möglichkeit gefunden, wie ich per Modbus die EVBox steuern kann.
                                            shipper @Meister Mopper last edited by
                                            mein Bluelinkadapter funktioniert, ich kann aber nur einstellen, wie oft täglich die tripinfos aktualisiert werden. Alles andere wird nur aktualisiert, wenn ich den Adapter restarte.
                                            Gibt es für die Aktualisierung z.B. des Akkuzustands eine Einstellmöglichkeit?
                                            1.2k
                                            81.1k
                                            2277
                                            851726
