    4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
    • Chris76e
      Chris76e last edited by Chris76e
      Falls es jemand gebrauchen kann. Hier ein Blockly für die Anzahl der Pakete die noch nicht geliefert sind.
        <variables>
          <variable id="}F2;56%44aP~!d@Y@]3b">Anzahl</variable>
          <variable id="*HjG8z|]ap-#2C[pV%%1">obj</variable>
          <variable id="F8%`~CTzGQ?Jpye3WH(^">i</variable>
        </variables>
        <block type="on" id="h1eKY01J96$Fc-#0SB|-" x="-262" y="-285">
          <field name="OID">parcel.0.allProviderJson</field>
            <block type="variables_set" id=";;WIg+;5!ql2+@wEI*i%">
              <field name="VAR" id="}F2;56%44aP~!d@Y@]3b">Anzahl</field>
                <block type="math_number" id="5^h0OCMmV8-zOCI[6Ly;">
                  <field name="NUM">0</field>
                <block type="variables_set" id="$I-WeE.guW9.nyB$@8_r">
                  <field name="VAR" id="*HjG8z|]ap-#2C[pV%%1">obj</field>
                    <block type="convert_json2object" id="A#Qz!p+d#2U?Zn!{e;!Z">
                        <block type="get_value_var" id="=Rbt^6regB|.^*y5D7uR">
                          <value name="OID">
                            <shadow type="text" id="4GQsb#poQk1D$I9]WqG{">
                              <field name="TEXT"></field>
                            <block type="field_oid" id="(!-q[b/~TlS7S$s:h)5l">
                              <field name="oid">parcel.0.allProviderJson</field>
                    <block type="controls_forEach" id="!Iv{#X1M91u`z5wpQ7%h">
                      <field name="VAR" id="F8%`~CTzGQ?Jpye3WH(^">i</field>
                      <value name="LIST">
                        <block type="variables_get" id="Kq,93U]D02y`Q~Z#;G`7">
                      <statement name="DO">
                        <block type="controls_if" id="Bkz|?C`;*%*R%inUP|~:">
                            <block type="logic_compare" id="jV-/R6Akqz/L-CqrH=*4">
                              <field name="OP">GT</field>
                                <block type="get_attr" id="O^+JMhZ]aSz-a0jz3HZI">
                                  <value name="PATH">
                                    <shadow type="text" id="uNf*$V^`2hp+McwoT7Hv">
                                      <field name="TEXT">delivery_status</field>
                                  <value name="OBJECT">
                                    <block type="variables_get" id="Qb@Q3YVC_tW0e]@Ep4M2">
                                <block type="math_number" id="XVW.NUGKndr@C~~L*pPh">
                                  <field name="NUM">1</field>
                            <block type="math_change" id="T(sRkOw~D)|q0`wL}s9[">
                              <value name="DELTA">
                                <shadow type="math_number" id="A#jQE|k:C~q6U-K+Q)f!">
                        <block type="update" id="aZ=w^gHJ6;ipH9wgq[_c">
                          <field name="OID">0_userdata.0.Paketebestellt</field>
                            <block type="variables_get" id="s`gl_F8~Ob:f5XIkm0U{">
      Jetzt die richtige Version, Setze Anzahlauf 0 muss natürlich nach dem Trigger und nicht vor dem Trigger......
      D 1 Reply Last reply Reply Quote 3
        Dragon @Chris76e last edited by
        @chris76e Unter dem Block sonst steht nichts. Ist das ein Fehler oder so beabsichtigt?
        Chris76e 1 Reply Last reply Reply Quote 0
        • Chris76e
          Chris76e @Dragon last edited by
          @dragon
          hatte ich vergessen wieder rauszunehmen. Hatte vieles ausprobiert bis es endlich funktionierte.
          • DJMarc75
            DJMarc75 @Chris76e last edited by
            @tombox
            Servus, habe in letzter Zeit wieder viele Errors bzgl Hermes im LOG.
            Unabhängig davon wäre es super wenn man in der Instanz per Button die einzelnen Dienstleister de/aktivieren könnte.
            Wäre das umsetzbar und sinnvoll?
            • Nashra
              Moin, so langsam fange ich an zu zweifeln mit UPS.
              Versuche seit 2 Tagen mich bei denen zu registrieren, bei allen Eingaben ist der grüne Haken
              und wenn ich auf registrieren klicke kommt "Benutzername existiert bereits". Schön, dann
              nehmen wir einen anderen 😄 aber nix da, funktioniert einfach nicht.
              Hat das einer von euch auch mal gehabt und was könnte man sonst noch versuchen.
                A Former User @Nashra last edited by
                @nashra Registrieren ging bei mir letzte Woche, warte seitdem auf den Brief... da kam bisher nix.. 😞
                Du kannst dir den Benutzernamen ja zusenden lassen, geh einfach mal auf Password vergessen...
                Alle anderen Dienste funktionieren prima!
                • Nashra
                  Nashra Most Active Forum Testing @Guest last edited by
                  @ilovegym sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                  Ich muß mich doch erstmal registrieren und für Benutzernamen zusenden wollen die auch die ID.
                  Vllt ist auch im Moment der Wurm drin bei denen, versucher es die Tage nochmal.
                  • DJMarc75
                    DJMarc75 @Nashra last edited by
                    @nashra
                    Also wenn Du Dich erst bei UPS oder einem anderen Dienstleister registrieren musst, dann wollen die auch keine ID. Diese bekommst Du, wenn, dann vom Dienstleister (UPS).
                    Registrierung findet immer auf der jeweiligen HP statt. Hier kann man Dir ohne Registrierung beim jeweiligen Dienstleister nicht helfen bzgl. Einloggen im Adapter.
                    Falls da Probleme bei den Dienstleistern bestehen bitte erstmal diese kontaktieren.
                    Wenn alle Logindaten vorhanden sind und im Adapter was nicht grad läuft, dann wird auch hier geholfen.
                    • Nashra
                      Nashra Most Active Forum Testing @DJMarc75 last edited by
                      @djmarc75 sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                      @nashra
                      schon klar, von der Post kam ja auch ein Brief wegen Registriereung usw.
                      das habe ich doch geschrieben, auf der HP von UPS gibt es Probleme sich zu registrieren
                      Adapter läuft seit dem ersten Tag und Amazon, DHL, Hermes, DPD werden angezeigt wenn was unterwegs ist.
                      Werde es nochmal bei denen probieren und mich wenn, mit denen in Verbindung setzen.
                      • DJMarc75
                        @nashra said in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                        Sorry - gelesen.
                        UPS allgemein mach hier aber im Adapter auch oft Schwierigkeiten was die Erreichbarkeit angeht, geschätzt mittlerweile 10 mal am Tag.
                        • Nashra
                          Sorry - gelesen.
                          Hm, das lässt die Vermutung zu das an der HP was nicht stimmt und ich dadurch mich nicht registrieren kann.
                          Ist aber auch nicht so tragisch denn 95% der Pakete kommen über die anderen Versender.
                          DJMarc75 K 2 Replies Last reply Reply Quote 0
                          • DJMarc75
                            @nashra Heute spinnts bei DHL rum.
                              kgh @Nashra last edited by
                              @nashra falls Du diesen Brief von UPS bekommen hast und Probleme bei der Eingabe der PIN hast, dann versuche es nicht über die im Brief genannte URL zu machen. Die ging bei mir auch nicht. Erst als ich über die Einstellungen zu meinem Konto die richtige Stelle gefunden habe, konnte ich meine Adresse über die PIN bestätigen.
                              • Nashra
                                Nashra Most Active Forum Testing @kgh last edited by
                                @kgh sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                                Danke für den Hinweis, aber damit ich den Brief bekomme muß ich mich ja erstmal registrieren
                                und das ist zurzeit das Problem da UPS die Daten nicht akzeptiert die ich eingebe.
                                  liv-in-sky @Nashra last edited by
                                  @nashra
                                  hast du es mal mit einem anderen browser probiert ? oder hast pi-hole oder eine erweiterung, die da "reinfummelt"
                                  ich hatte auch ein problem und ich glaube, ich habe es mit handy, tablet oder einen anderen browser geschafft
                                  ist leider schon etwas her, dahe rkann ich nix näheres mehr sagen
                                  • Nashra
                                    Nashra Most Active Forum Testing @liv-in-sky last edited by
                                    @liv-in-sky sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                                    @nashra
                                    Moin, alles schon probiert und selbst mit dem Handy wenn ich im Mobilfunknetz bin klappt es nicht.
                                    Wie schon geschrieben, nicht so wichtig, über die kommen höchsten 2 oder 3 Pakete im Jahr.
                                      kimukao @Nashra last edited by
                                      Vielen Dank für die viele Arbeit bzgl. des Adapters! Toll! Ich versuche, bei Zustellung heute die Dauerschaltung meines Nuki Openers für mein Schiebetor an der Grundstückseinfahrt zu aktivieren, damit der Bote das Paket in der Garage deponieren kann. Allerdings zeigt der Datenpunkt "inDelivery" permanent "[]" an und der Datenpunkt "inDeliveryCount" "0", obwohl z.B. heute ein Amazon Paket in Zustellung ist. Im JSON wird die Zustellung angekündigt. Würde als Blockly Trigger inDelivery ungleich [] nutzen wollen. Habe ich was falsch konfiguriert, oder ist das ein Bug?
                                        Thomas Braun Most Active @kimukao last edited by Thomas Braun
                                        @kimukao
                                        Schau mal hier rein:
                                        https://forum.iobroker.net/topic/52861/ideen-zur-türöffnung/21
                                        Ich habe das genauso umgesetzt. Wenn ein Paket 'In Auslieferung' ist schaltet mein Opener in den Dauermodus. Hat gerade heute morgen bei mir funktioniert, auch mit Amazon.
                                          kimukao @Thomas Braun last edited by
                                          @thomas-braun Super, danke. Das Skript könnte ich dann so nachbauen. Allerdings zeigt der Adapter ja bei inDelivery immer [] an, egal, ob sich ein Paket in Zustellung befindet oder nicht. Der Trigger würde so bei mir also noch nicht funktionieren. Wenn das bei Dir funktioniert ist es also kein Adapter-Bug und ich muss den Fehler weiterhin in meiner Konfiguration suchen. Vielleicht hat jemand eine Idee? In den Objekten wird unter Amazon/Sendung 1 und in der JSON Datei die Zustellung angekündigt.
                                            tombox @kimukao last edited by
                                            @kimukao Schick mir mal per pn den inhalt von
                                            parcel.0.amazon.json
                                            17track amazon briefe dhl dpd gls ups
                                            122
                                            1534
                                            527530
