    • simatec
      simatec Developer Most Active @BanditFG last edited by
      @banditfg Sind die Astrodaten vorhanden? Was sagt denn der Debuglog vom Adapter?
      • simatec
        @banditfg Sind die States in shuttercontrol.0.shutters.autoSun auf true
        BanditFG 1 Reply Last reply Reply Quote 0
        • BanditFG
          BanditFG @simatec last edited by Homoran
          @simatec
          ich habe gerade nochmal alle Rollos per close All -> openAll bewegt...
          ![Bildschirmfoto 2022-05-11 um 15.34.50.png]
          MOD-EDIT: private Daten entfernt!
          Astrodaten stimmen!
          shuttercontrol.0
          2022-05-11 15:35:00.028	debug	Sun Elevation: 45.4°
          shuttercontrol.0
          2022-05-11 15:35:00.027	debug	Sun Azimut: 236.4°
          shuttercontrol.0
          2022-05-11 15:35:00.027	debug	calculate astrodata ...
          shuttercontrol.0
          2022-05-11 15:33:30.356	debug	insidetemperature changed: zigbee.0.00158d000273ce6b.temperature Value: 21.95
          shuttercontrol.0
          2022-05-11 15:31:51.812	debug	Shutter Rollladen Bad.LEVEL was moved manually to: 100% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:31:51.812	debug	save current height after State Check: 100% from Rollladen Bad.LEVEL
          shuttercontrol.0
          2022-05-11 15:31:50.807	debug	Rollladen Bad.LEVEL drived manually to 100. Old value = 0. New value = 100
          shuttercontrol.0
          2022-05-11 15:31:50.807	debug	Rollladen Bad.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:31:50.802	debug	Shutter state changed: Rollladen Bad.LEVEL old value = 0 new value = 100
          shuttercontrol.0
          2022-05-11 15:31:42.155	debug	outsidetemperature changed: hm-rpc.2.000EDD89AEC34D.1.ACTUAL_TEMPERATURE Value: 28.1
          shuttercontrol.0
          2022-05-11 15:31:41.665	debug	Shutter Rollladen Natalie.LEVEL was moved manually to: 100% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:31:41.665	debug	save current height after State Check: 100% from Rollladen Natalie.LEVEL
          shuttercontrol.0
          2022-05-11 15:31:40.660	debug	Rollladen Natalie.LEVEL drived manually to 100. Old value = 0. New value = 100
          shuttercontrol.0
          2022-05-11 15:31:40.659	debug	Rollladen Natalie.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:31:40.654	debug	Shutter state changed: Rollladen Natalie.LEVEL old value = 0 new value = 100
          shuttercontrol.0
          2022-05-11 15:31:36.524	debug	Shutter Rolladen Emilia.LEVEL was moved manually to: 100% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:31:36.524	debug	save current height after State Check: 100% from Rolladen Emilia.LEVEL
          shuttercontrol.0
          2022-05-11 15:31:35.519	debug	Rolladen Emilia.LEVEL drived manually to 100. Old value = 0. New value = 100
          shuttercontrol.0
          2022-05-11 15:31:35.519	debug	Rolladen Emilia.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:31:35.471	debug	Shutter state changed: Rolladen Emilia.LEVEL old value = 0 new value = 100
          shuttercontrol.0
          2022-05-11 15:31:25.960	debug	Shutter Rollladen Natalie klein.LEVEL was moved manually to: 0% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:31:25.960	debug	save current height after State Check: 0% from Rollladen Natalie klein.LEVEL
          shuttercontrol.0
          2022-05-11 15:31:24.955	debug	Rollladen Natalie klein.LEVEL drived manually to 0. Old value = 100. New value = 0
          shuttercontrol.0
          2022-05-11 15:31:24.955	debug	Rollladen Natalie klein.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:31:24.949	debug	Shutter state changed: Rollladen Natalie klein.LEVEL old value = 100 new value = 0
          shuttercontrol.0
          2022-05-11 15:31:21.199	debug	Shuttercontrol save all shutter states
          shuttercontrol.0
          2022-05-11 15:31:21.157	debug	Shutter Rollladen Terrassentür.LEVEL was moved manually to: 100% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:31:21.156	debug	save current height after State Check: 100% from Rollladen Terrassentür.LEVEL
          shuttercontrol.0
          2022-05-11 15:31:20.151	debug	Rollladen Terrassentür.LEVEL drived manually to 100. Old value = 0. New value = 100
          shuttercontrol.0
          2022-05-11 15:31:20.151	debug	Rollladen Terrassentür.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:31:20.102	debug	Shutter state changed: Rollladen Terrassentür.LEVEL old value = 0 new value = 100
          shuttercontrol.0
          2022-05-11 15:31:17.203	debug	Shutter Rollladen Bad.LEVEL was moved manually to: 0% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:31:17.203	debug	save current height after State Check: 0% from Rollladen Bad.LEVEL
          shuttercontrol.0
          2022-05-11 15:31:16.966	debug	Shutter Rollladen Ecke Links.LEVEL was moved manually to: 100% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:31:16.966	debug	save current height after State Check: 100% from Rollladen Ecke Links.LEVEL
          shuttercontrol.0
          2022-05-11 15:31:16.464	debug	Rollladen Bad.LEVEL drived manually to 0. Old value = 100. New value = 0
          shuttercontrol.0
          2022-05-11 15:31:16.464	debug	Rollladen Bad.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:31:16.457	debug	Shutter state changed: Rollladen Bad.LEVEL old value = 100 new value = 0
          shuttercontrol.0
          2022-05-11 15:31:16.290	debug	Rollladen Bad.LEVEL Old value = 100. New value = 100. automatic is active
          shuttercontrol.0
          2022-05-11 15:31:16.198	debug	shutterUpButton Rollladen Bad.LEVEL old height: 100% new height: 100%
          shuttercontrol.0
          2022-05-11 15:31:16.182	info	Button openAll Set ID: Rollladen Bad.LEVEL value: 100%
          shuttercontrol.0
          2022-05-11 15:31:15.960	debug	Rollladen Ecke Links.LEVEL drived manually to 100. Old value = 0. New value = 100
          shuttercontrol.0
          2022-05-11 15:31:15.960	debug	Rollladen Ecke Links.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:31:15.954	debug	Shutter state changed: Rollladen Ecke Links.LEVEL old value = 0 new value = 100
          shuttercontrol.0
          2022-05-11 15:31:12.185	debug	save current height after State Check: 100% from Rollladen Natalie klein.LEVEL
          shuttercontrol.0
          2022-05-11 15:31:11.797	debug	Shutter Rollladen Ecke Rechts.LEVEL was moved manually to: 100% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:31:11.797	debug	save current height after State Check: 100% from Rollladen Ecke Rechts.LEVEL
          shuttercontrol.0
          2022-05-11 15:31:11.274	debug	Rollladen Natalie klein.LEVEL Old value = 100. New value = 0. automatic is active
          shuttercontrol.0
          2022-05-11 15:31:11.273	debug	Shutter state changed: Rollladen Natalie klein.LEVEL old value = 100 new value = 0
          shuttercontrol.0
          2022-05-11 15:31:11.181	debug	shutterUpButton Rollladen Natalie klein.LEVEL old height: 100% new height: 0%
          shuttercontrol.0
          2022-05-11 15:31:11.168	info	Button openAll Set ID: Rollladen Natalie klein.LEVEL value: 0%
          shuttercontrol.0
          2022-05-11 15:31:10.791	debug	Rollladen Ecke Rechts.LEVEL drived manually to 100. Old value = 0. New value = 100
          shuttercontrol.0
          2022-05-11 15:31:10.791	debug	Rollladen Ecke Rechts.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:31:10.785	debug	Shutter state changed: Rollladen Ecke Rechts.LEVEL old value = 0 new value = 100
          shuttercontrol.0
          2022-05-11 15:31:09.592	debug	Shutter Rollladen Küche Links.LEVEL was moved manually to: 100% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:31:09.592	debug	save current height after State Check: 100% from Rollladen Küche Links.LEVEL
          shuttercontrol.0
          2022-05-11 15:31:08.586	debug	Rollladen Küche Links.LEVEL drived manually to 100. Old value = 0. New value = 100
          shuttercontrol.0
          2022-05-11 15:31:08.585	debug	Rollladen Küche Links.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:31:08.580	debug	Shutter state changed: Rollladen Küche Links.LEVEL old value = 0 new value = 100
          shuttercontrol.0
          2022-05-11 15:31:07.152	debug	Shutter Rollladen Natalie.LEVEL was moved manually to: 0% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:31:07.152	debug	save current height after State Check: 0% from Rollladen Natalie.LEVEL
          shuttercontrol.0
          2022-05-11 15:31:06.421	debug	Rollladen Natalie.LEVEL drived manually to 0. Old value = 100. New value = 0
          shuttercontrol.0
          2022-05-11 15:31:06.420	debug	Rollladen Natalie.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:31:06.413	debug	Shutter state changed: Rollladen Natalie.LEVEL old value = 100 new value = 0
          shuttercontrol.0
          2022-05-11 15:31:06.239	debug	Rollladen Natalie.LEVEL Old value = 100. New value = 100. automatic is active
          shuttercontrol.0
          2022-05-11 15:31:06.147	debug	shutterUpButton Rollladen Natalie.LEVEL old height: 100% new height: 100%
          shuttercontrol.0
          2022-05-11 15:31:06.134	info	Button openAll Set ID: Rollladen Natalie.LEVEL value: 100%
          shuttercontrol.0
          2022-05-11 15:31:04.796	debug	Shutter Rollladen Küche Rechts.LEVEL was moved manually to: 100% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:31:04.795	debug	save current height after State Check: 100% from Rollladen Küche Rechts.LEVEL
          shuttercontrol.0
          2022-05-11 15:31:03.787	debug	Rollladen Küche Rechts.LEVEL drived manually to 100. Old value = 0. New value = 100
          shuttercontrol.0
          2022-05-11 15:31:03.787	debug	Rollladen Küche Rechts.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:31:03.741	debug	Shutter state changed: Rollladen Küche Rechts.LEVEL old value = 0 new value = 100
          shuttercontrol.0
          2022-05-11 15:31:02.142	debug	Shutter Rolladen Emilia.LEVEL was moved manually to: 0% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:31:02.142	debug	save current height after State Check: 0% from Rolladen Emilia.LEVEL
          shuttercontrol.0
          2022-05-11 15:31:01.369	debug	Rolladen Emilia.LEVEL drived manually to 0. Old value = 100. New value = 0
          shuttercontrol.0
          2022-05-11 15:31:01.369	debug	Rolladen Emilia.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:31:01.362	debug	Shutter state changed: Rolladen Emilia.LEVEL old value = 100 new value = 0
          shuttercontrol.0
          2022-05-11 15:31:01.185	debug	Rolladen Emilia.LEVEL Old value = 100. New value = 100. automatic is active
          shuttercontrol.0
          2022-05-11 15:31:01.133	debug	shutterUpButton Rolladen Emilia.LEVEL old height: 100% new height: 100%
          shuttercontrol.0
          2022-05-11 15:31:01.028	info	Button openAll Set ID: Rolladen Emilia.LEVEL value: 100%
          shuttercontrol.0
          2022-05-11 15:30:56.981	debug	save current height after State Check: 0% from Rollladen Küche Links.LEVEL
          shuttercontrol.0
          2022-05-11 15:30:56.061	debug	Rollladen Küche Links.LEVEL Old value = 0. New value = 100. automatic is active
          shuttercontrol.0
          2022-05-11 15:30:56.061	debug	Shutter state changed: Rollladen Küche Links.LEVEL old value = 0 new value = 100
          shuttercontrol.0
          2022-05-11 15:30:55.968	debug	shutterUpButton Rollladen Küche Links.LEVEL old height: 0% new height: 100%
          shuttercontrol.0
          2022-05-11 15:30:55.956	info	Button openAll Set ID: Rollladen Küche Links.LEVEL value: 100%
          shuttercontrol.0
          2022-05-11 15:30:54.267	debug	Shutter Rollladen Arbeitszimmer.LEVEL was moved manually to: 100% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:30:54.267	debug	save current height after State Check: 100% from Rollladen Arbeitszimmer.LEVEL
          shuttercontrol.0
          2022-05-11 15:30:53.262	debug	Rollladen Arbeitszimmer.LEVEL drived manually to 100. Old value = 0. New value = 100
          shuttercontrol.0
          2022-05-11 15:30:53.261	debug	Rollladen Arbeitszimmer.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:30:53.256	debug	Shutter state changed: Rollladen Arbeitszimmer.LEVEL old value = 0 new value = 100
          shuttercontrol.0
          2022-05-11 15:30:51.972	debug	save current height after State Check: 0% from Rollladen Küche Rechts.LEVEL
          shuttercontrol.0
          2022-05-11 15:30:51.463	debug	insidetemperature changed: zigbee.0.00158d000247d478.temperature Value: 21.88
          shuttercontrol.0
          2022-05-11 15:30:51.045	debug	Rollladen Küche Rechts.LEVEL Old value = 0. New value = 100. automatic is active
          shuttercontrol.0
          2022-05-11 15:30:51.045	debug	Shutter state changed: Rollladen Küche Rechts.LEVEL old value = 0 new value = 100
          shuttercontrol.0
          2022-05-11 15:30:50.953	debug	shutterUpButton Rollladen Küche Rechts.LEVEL old height: 0% new height: 100%
          shuttercontrol.0
          2022-05-11 15:30:50.935	info	Button openAll Set ID: Rollladen Küche Rechts.LEVEL value: 100%
          shuttercontrol.0
          2022-05-11 15:30:46.942	debug	Shutter Rollladen Terrassentür.LEVEL was moved manually to: 0% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:30:46.942	debug	save current height after State Check: 0% from Rollladen Terrassentür.LEVEL
          shuttercontrol.0
          2022-05-11 15:30:46.205	debug	Rollladen Terrassentür.LEVEL drived manually to 0. Old value = 100. New value = 0
          shuttercontrol.0
          2022-05-11 15:30:46.204	debug	Rollladen Terrassentür.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:30:46.199	debug	Shutter state changed: Rollladen Terrassentür.LEVEL old value = 100 new value = 0
          shuttercontrol.0
          2022-05-11 15:30:46.068	debug	Rollladen Terrassentür.LEVEL Old value = 100. New value = 100. automatic is active
          shuttercontrol.0
          2022-05-11 15:30:45.933	debug	shutterUpButton Rollladen Terrassentür.LEVEL old height: 100% new height: 100%
          shuttercontrol.0
          2022-05-11 15:30:45.919	info	Button openAll Set ID: Rollladen Terrassentür.LEVEL value: 100%
          shuttercontrol.0
          2022-05-11 15:30:41.922	debug	Shutter Rollladen Ecke Links.LEVEL was moved manually to: 0% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:30:41.921	debug	save current height after State Check: 0% from Rollladen Ecke Links.LEVEL
          shuttercontrol.0
          2022-05-11 15:30:41.183	debug	Rollladen Ecke Links.LEVEL drived manually to 0. Old value = 100. New value = 0
          shuttercontrol.0
          2022-05-11 15:30:41.183	debug	Rollladen Ecke Links.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:30:41.178	debug	Shutter state changed: Rollladen Ecke Links.LEVEL old value = 100 new value = 0
          shuttercontrol.0
          2022-05-11 15:30:41.008	debug	Rollladen Ecke Links.LEVEL Old value = 100. New value = 100. automatic is active
          shuttercontrol.0
          2022-05-11 15:30:40.916	debug	shutterUpButton Rollladen Ecke Links.LEVEL old height: 100% new height: 100%
          shuttercontrol.0
          2022-05-11 15:30:40.900	info	Button openAll Set ID: Rollladen Ecke Links.LEVEL value: 100%
          shuttercontrol.0
          2022-05-11 15:30:36.904	debug	Shutter Rollladen Ecke Rechts.LEVEL was moved manually to: 0% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:30:36.903	debug	save current height after State Check: 0% from Rollladen Ecke Rechts.LEVEL
          shuttercontrol.0
          2022-05-11 15:30:36.161	debug	Rollladen Ecke Rechts.LEVEL drived manually to 0. Old value = 100. New value = 0
          shuttercontrol.0
          2022-05-11 15:30:36.161	debug	Rollladen Ecke Rechts.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:30:36.156	debug	Shutter state changed: Rollladen Ecke Rechts.LEVEL old value = 100 new value = 0
          shuttercontrol.0
          2022-05-11 15:30:35.985	debug	Rollladen Ecke Rechts.LEVEL Old value = 100. New value = 100. automatic is active
          shuttercontrol.0
          2022-05-11 15:30:35.898	debug	shutterUpButton Rollladen Ecke Rechts.LEVEL old height: 100% new height: 100%
          shuttercontrol.0
          2022-05-11 15:30:35.876	info	Button openAll Set ID: Rollladen Ecke Rechts.LEVEL value: 100%
          shuttercontrol.0
          2022-05-11 15:30:31.880	debug	Shutter Rollladen Arbeitszimmer.LEVEL was moved manually to: 0% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:30:31.880	debug	save current height after State Check: 0% from Rollladen Arbeitszimmer.LEVEL
          shuttercontrol.0
          2022-05-11 15:30:31.143	debug	Rollladen Arbeitszimmer.LEVEL drived manually to 0. Old value = 100. New value = 0
          shuttercontrol.0
          2022-05-11 15:30:31.142	debug	Rollladen Arbeitszimmer.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:30:31.135	debug	Shutter state changed: Rollladen Arbeitszimmer.LEVEL old value = 100 new value = 0
          shuttercontrol.0
          2022-05-11 15:30:30.958	debug	Rollladen Arbeitszimmer.LEVEL Old value = 100. New value = 100. automatic is active
          shuttercontrol.0
          2022-05-11 15:30:30.874	debug	shutterUpButton Rollladen Arbeitszimmer.LEVEL old height: 100% new height: 100%
          shuttercontrol.0
          2022-05-11 15:30:30.848	info	Button openAll Set ID: Rollladen Arbeitszimmer.LEVEL value: 100%
          shuttercontrol.0
          2022-05-11 15:30:30.806	debug	start buttonAction
          shuttercontrol.0
          2022-05-11 15:30:03.878	debug	Shutter Rollladen Natalie klein.LEVEL was moved manually to: 100% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:30:03.878	debug	save current height after State Check: 100% from Rollladen Natalie klein.LEVEL
          shuttercontrol.0
          2022-05-11 15:30:02.872	debug	Rollladen Natalie klein.LEVEL drived manually to 100. Old value = . New value = 100
          shuttercontrol.0
          2022-05-11 15:30:02.872	debug	Rollladen Natalie klein.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:30:02.864	debug	Shutter state changed: Rollladen Natalie klein.LEVEL old value = new value = 100
          shuttercontrol.0
          2022-05-11 15:30:00.020	debug	Sun Elevation: 46°
          shuttercontrol.0
          2022-05-11 15:30:00.020	debug	Sun Azimut: 234.9°
          shuttercontrol.0
          2022-05-11 15:30:00.019	debug	calculate astrodata ...
          shuttercontrol.0
          2022-05-11 15:29:58.278	debug	Shuttercontrol save all shutter states
          shuttercontrol.0
          2022-05-11 15:29:54.305	debug	Shutter Rollladen Bad.LEVEL was moved manually to: 100% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:29:54.304	debug	save current height after State Check: 100% from Rollladen Bad.LEVEL
          shuttercontrol.0
          2022-05-11 15:29:53.546	debug	Rollladen Bad.LEVEL drived manually to 100. Old value = . New value = 100
          shuttercontrol.0
          2022-05-11 15:29:53.546	debug	Rollladen Bad.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:29:53.540	debug	Shutter state changed: Rollladen Bad.LEVEL old value = new value = 100
          shuttercontrol.0
          2022-05-11 15:29:53.369	debug	Rollladen Bad.LEVEL Old value = . New value = 0. automatic is active
          shuttercontrol.0
          2022-05-11 15:29:53.278	debug	shutterDownButton Rollladen Bad.LEVEL old height: % new height: 0%
          shuttercontrol.0
          2022-05-11 15:29:53.263	info	Button closeAll Set ID: Rollladen Bad.LEVEL value: 0%
          shuttercontrol.0
          2022-05-11 15:29:49.267	debug	save current height after State Check: 0% from Rollladen Natalie klein.LEVEL
          shuttercontrol.0
          2022-05-11 15:29:48.354	debug	Rollladen Natalie klein.LEVEL Old value = . New value = 100. automatic is active
          shuttercontrol.0
          2022-05-11 15:29:48.353	debug	Shutter state changed: Rollladen Natalie klein.LEVEL old value = new value = 100
          shuttercontrol.0
          2022-05-11 15:29:48.262	debug	shutterDownButton Rollladen Natalie klein.LEVEL old height: % new height: 100%
          shuttercontrol.0
          2022-05-11 15:29:48.247	info	Button closeAll Set ID: Rollladen Natalie klein.LEVEL value: 100%
          shuttercontrol.0
          2022-05-11 15:29:44.249	debug	Shutter Rollladen Natalie.LEVEL was moved manually to: 100% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:29:44.248	debug	save current height after State Check: 100% from Rollladen Natalie.LEVEL
          shuttercontrol.0
          2022-05-11 15:29:43.547	debug	Rollladen Natalie.LEVEL drived manually to 100. Old value = . New value = 100
          shuttercontrol.0
          2022-05-11 15:29:43.546	debug	Rollladen Natalie.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:29:43.536	debug	Shutter state changed: Rollladen Natalie.LEVEL old value = new value = 100
          shuttercontrol.0
          2022-05-11 15:29:43.337	debug	Rollladen Natalie.LEVEL Old value = . New value = 0. automatic is active
          shuttercontrol.0
          2022-05-11 15:29:43.244	debug	shutterDownButton Rollladen Natalie.LEVEL old height: % new height: 0%
          shuttercontrol.0
          2022-05-11 15:29:43.232	info	Button closeAll Set ID: Rollladen Natalie.LEVEL value: 0%
          shuttercontrol.0
          2022-05-11 15:29:39.248	debug	Shutter Rolladen Emilia.LEVEL was moved manually to: 100% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:29:39.248	debug	save current height after State Check: 100% from Rolladen Emilia.LEVEL
          shuttercontrol.0
          2022-05-11 15:29:38.500	debug	Rolladen Emilia.LEVEL drived manually to 100. Old value = . New value = 100
          shuttercontrol.0
          2022-05-11 15:29:38.499	debug	Rolladen Emilia.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:29:38.494	debug	Shutter state changed: Rolladen Emilia.LEVEL old value = new value = 100
          shuttercontrol.0
          2022-05-11 15:29:38.320	debug	Rolladen Emilia.LEVEL Old value = . New value = 0. automatic is active
          shuttercontrol.0
          2022-05-11 15:29:38.230	debug	shutterDownButton Rolladen Emilia.LEVEL old height: % new height: 0%
          shuttercontrol.0
          2022-05-11 15:29:38.212	info	Button closeAll Set ID: Rolladen Emilia.LEVEL value: 0%
          shuttercontrol.0
          2022-05-11 15:29:34.215	debug	Shutter Rollladen Küche Links.LEVEL was moved manually to: 100% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:29:34.214	debug	save current height after State Check: 100% from Rollladen Küche Links.LEVEL
          shuttercontrol.0
          2022-05-11 15:29:33.480	debug	Rollladen Küche Links.LEVEL drived manually to 100. Old value = . New value = 100
          shuttercontrol.0
          2022-05-11 15:29:33.480	debug	Rollladen Küche Links.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:29:33.471	debug	Shutter state changed: Rollladen Küche Links.LEVEL old value = new value = 100
          shuttercontrol.0
          2022-05-11 15:29:33.300	debug	Rollladen Küche Links.LEVEL Old value = . New value = 0. automatic is active
          shuttercontrol.0
          2022-05-11 15:29:33.209	debug	shutterDownButton Rollladen Küche Links.LEVEL old height: % new height: 0%
          shuttercontrol.0
          2022-05-11 15:29:33.187	info	Button closeAll Set ID: Rollladen Küche Links.LEVEL value: 0%
          shuttercontrol.0
          2022-05-11 15:29:29.194	debug	Shutter Rollladen Küche Rechts.LEVEL was moved manually to: 100% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:29:29.194	debug	save current height after State Check: 100% from Rollladen Küche Rechts.LEVEL
          shuttercontrol.0
          2022-05-11 15:29:28.461	debug	Rollladen Küche Rechts.LEVEL drived manually to 100. Old value = . New value = 100
          shuttercontrol.0
          2022-05-11 15:29:28.461	debug	Rollladen Küche Rechts.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:29:28.456	debug	Shutter state changed: Rollladen Küche Rechts.LEVEL old value = new value = 100
          shuttercontrol.0
          2022-05-11 15:29:28.279	debug	Rollladen Küche Rechts.LEVEL Old value = . New value = 0. automatic is active
          shuttercontrol.0
          2022-05-11 15:29:28.185	debug	shutterDownButton Rollladen Küche Rechts.LEVEL old height: % new height: 0%
          shuttercontrol.0
          2022-05-11 15:29:28.172	info	Button closeAll Set ID: Rollladen Küche Rechts.LEVEL value: 0%
          shuttercontrol.0
          2022-05-11 15:29:24.177	debug	Shutter Rollladen Terrassentür.LEVEL was moved manually to: 100% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:29:24.176	debug	save current height after State Check: 100% from Rollladen Terrassentür.LEVEL
          shuttercontrol.0
          2022-05-11 15:29:23.443	debug	Rollladen Terrassentür.LEVEL drived manually to 100. Old value = . New value = 100
          shuttercontrol.0
          2022-05-11 15:29:23.443	debug	Rollladen Terrassentür.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:29:23.437	debug	Shutter state changed: Rollladen Terrassentür.LEVEL old value = new value = 100
          shuttercontrol.0
          2022-05-11 15:29:23.261	debug	Rollladen Terrassentür.LEVEL Old value = . New value = 0. automatic is active
          shuttercontrol.0
          2022-05-11 15:29:23.170	debug	shutterDownButton Rollladen Terrassentür.LEVEL old height: % new height: 0%
          shuttercontrol.0
          2022-05-11 15:29:23.153	info	Button closeAll Set ID: Rollladen Terrassentür.LEVEL value: 0%
          shuttercontrol.0
          2022-05-11 15:29:19.236	debug	Shutter Rollladen Ecke Links.LEVEL was moved manually to: 100% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:29:19.236	debug	save current height after State Check: 100% from Rollladen Ecke Links.LEVEL
          shuttercontrol.0
          2022-05-11 15:29:18.420	debug	Rollladen Ecke Links.LEVEL drived manually to 100. Old value = . New value = 100
          shuttercontrol.0
          2022-05-11 15:29:18.420	debug	Rollladen Ecke Links.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:29:18.415	debug	Shutter state changed: Rollladen Ecke Links.LEVEL old value = new value = 100
          shuttercontrol.0
          2022-05-11 15:29:18.242	debug	Rollladen Ecke Links.LEVEL Old value = . New value = 0. automatic is active
          shuttercontrol.0
          2022-05-11 15:29:18.151	debug	shutterDownButton Rollladen Ecke Links.LEVEL old height: % new height: 0%
          shuttercontrol.0
          2022-05-11 15:29:18.134	info	Button closeAll Set ID: Rollladen Ecke Links.LEVEL value: 0%
          shuttercontrol.0
          2022-05-11 15:29:14.137	debug	Shutter Rollladen Ecke Rechts.LEVEL was moved manually to: 100% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:29:14.136	debug	save current height after State Check: 100% from Rollladen Ecke Rechts.LEVEL
          shuttercontrol.0
          2022-05-11 15:29:13.398	debug	Rollladen Ecke Rechts.LEVEL drived manually to 100. Old value = . New value = 100
          shuttercontrol.0
          2022-05-11 15:29:13.398	debug	Rollladen Ecke Rechts.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:29:13.392	debug	Shutter state changed: Rollladen Ecke Rechts.LEVEL old value = new value = 100
          shuttercontrol.0
          2022-05-11 15:29:13.223	debug	Rollladen Ecke Rechts.LEVEL Old value = . New value = 0. automatic is active
          shuttercontrol.0
          2022-05-11 15:29:13.132	debug	shutterDownButton Rollladen Ecke Rechts.LEVEL old height: % new height: 0%
          shuttercontrol.0
          2022-05-11 15:29:13.113	info	Button closeAll Set ID: Rollladen Ecke Rechts.LEVEL value: 0%
          shuttercontrol.0
          2022-05-11 15:29:09.121	debug	Shutter Rollladen Arbeitszimmer.LEVEL was moved manually to: 100% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:29:09.120	debug	save current height after State Check: 100% from Rollladen Arbeitszimmer.LEVEL
          shuttercontrol.0
          2022-05-11 15:29:08.387	debug	Rollladen Arbeitszimmer.LEVEL drived manually to 100. Old value = . New value = 100
          shuttercontrol.0
          2022-05-11 15:29:08.386	debug	Rollladen Arbeitszimmer.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:29:08.379	debug	Shutter state changed: Rollladen Arbeitszimmer.LEVEL old value = new value = 100
          shuttercontrol.0
          2022-05-11 15:29:08.202	debug	Rollladen Arbeitszimmer.LEVEL Old value = . New value = 0. automatic is active
          shuttercontrol.0
          2022-05-11 15:29:08.111	debug	shutterDownButton Rollladen Arbeitszimmer.LEVEL old height: % new height: 0%
          shuttercontrol.0
          2022-05-11 15:29:08.096	info	Button closeAll Set ID: Rollladen Arbeitszimmer.LEVEL value: 0%
          shuttercontrol.0
          2022-05-11 15:29:08.053	debug	start buttonAction
          shuttercontrol.0
          2022-05-11 15:29:03.152	debug	outsidetemperature changed: hm-rpc.2.000EDD89AEC34D.1.ACTUAL_TEMPERATURE Value: 28.2
          shuttercontrol.0
          2022-05-11 15:28:36.975	debug	Create Object: shutters.autoLevel.Rollladen_Bad_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:36.968	debug	Create Object: shutters.autoState.Rollladen_Bad_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:36.952	debug	Create Object: shutters.autoSun.Rollladen_Bad_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:36.939	debug	Create Object: shutters.autoDown.Rollladen_Bad_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:36.925	debug	Create Object: shutters.autoUp.Rollladen_Bad_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:36.893	debug	Create Object: shutters.autoLevel.Rollladen_Natalie_klein_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:36.888	debug	Create Object: shutters.autoState.Rollladen_Natalie_klein_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:36.875	debug	Create Object: shutters.autoSun.Rollladen_Natalie_klein_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:36.857	debug	Create Object: shutters.autoDown.Rollladen_Natalie_klein_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:36.831	debug	Create Object: shutters.autoUp.Rollladen_Natalie_klein_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:36.814	debug	Create Object: shutters.autoLevel.Rollladen_Natalie_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:36.807	debug	Create Object: shutters.autoState.Rollladen_Natalie_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:36.795	debug	Create Object: shutters.autoSun.Rollladen_Natalie_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:36.780	debug	Create Object: shutters.autoDown.Rollladen_Natalie_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:36.764	debug	Create Object: shutters.autoUp.Rollladen_Natalie_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:36.743	debug	Create Object: shutters.autoLevel.Rolladen_Emilia_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:36.735	debug	Create Object: shutters.autoState.Rolladen_Emilia_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:36.723	debug	Create Object: shutters.autoSun.Rolladen_Emilia_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:36.708	debug	Create Object: shutters.autoDown.Rolladen_Emilia_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:36.699	debug	Create Object: shutters.autoUp.Rolladen_Emilia_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:36.276	debug	Create Object: shutters.autoLevel.Rollladen_Küche_Links_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:35.154	debug	Create Object: shutters.autoState.Rollladen_Küche_Links_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:35.136	debug	Create Object: shutters.autoSun.Rollladen_Küche_Links_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:35.121	debug	Create Object: shutters.autoDown.Rollladen_Küche_Links_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:35.108	debug	Create Object: shutters.autoUp.Rollladen_Küche_Links_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:35.059	debug	Create Object: shutters.autoLevel.Rollladen_Küche_Rechts_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:35.052	debug	Create Object: shutters.autoState.Rollladen_Küche_Rechts_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:35.038	debug	Create Object: shutters.autoSun.Rollladen_Küche_Rechts_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:35.023	debug	Create Object: shutters.autoDown.Rollladen_Küche_Rechts_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:35.009	debug	Create Object: shutters.autoUp.Rollladen_Küche_Rechts_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:34.993	debug	Create Object: shutters.autoLevel.Rollladen_Terrassentür_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:34.984	debug	Create Object: shutters.autoState.Rollladen_Terrassentür_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:34.958	debug	Create Object: shutters.autoSun.Rollladen_Terrassentür_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:34.947	debug	Create Object: shutters.autoDown.Rollladen_Terrassentür_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:34.935	debug	Create Object: shutters.autoUp.Rollladen_Terrassentür_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:34.914	debug	Create Object: shutters.autoLevel.Rollladen_Ecke_Links_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:34.907	debug	Create Object: shutters.autoState.Rollladen_Ecke_Links_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:34.895	debug	Create Object: shutters.autoSun.Rollladen_Ecke_Links_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:34.879	debug	Create Object: shutters.autoDown.Rollladen_Ecke_Links_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:34.866	debug	Create Object: shutters.autoUp.Rollladen_Ecke_Links_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:34.850	debug	Create Object: shutters.autoLevel.Rollladen_Ecke_Rechts_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:34.842	debug	Create Object: shutters.autoState.Rollladen_Ecke_Rechts_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:34.830	debug	Create Object: shutters.autoSun.Rollladen_Ecke_Rechts_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:34.818	debug	Create Object: shutters.autoDown.Rollladen_Ecke_Rechts_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:34.803	debug	Create Object: shutters.autoUp.Rollladen_Ecke_Rechts_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:34.785	debug	Create Object: shutters.autoLevel.Rollladen_Arbeitszimmer_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:34.779	debug	Create Object: shutters.autoState.Rollladen_Arbeitszimmer_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:34.764	debug	Create Object: shutters.autoSun.Rollladen_Arbeitszimmer_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:34.749	debug	Create Object: shutters.autoDown.Rollladen_Arbeitszimmer_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:34.736	debug	Create Object: shutters.autoUp.Rollladen_Arbeitszimmer_LEVEL
          shuttercontrol.0
          2022-05-11 15:28:34.626	debug	complete down at 22:00
          shuttercontrol.0
          2022-05-11 15:28:34.623	debug	Shutdown shutters sleep area: 19:30 debug 6
          shuttercontrol.0
          2022-05-11 15:28:34.616	debug	Shutdown shutters children area: 19:30 debug 6
          shuttercontrol.0
          2022-05-11 15:28:34.614	debug	shutterDownLiving
          shuttercontrol.0
          2022-05-11 15:28:34.613	debug	Shutdown shutters living area: 21:13 debug 7
          shuttercontrol.0
          2022-05-11 15:28:34.613	debug	yes, IsEarlier : 21:13 21:30
          shuttercontrol.0
          2022-05-11 15:28:34.613	debug	check IsEarlier : 21:13 21:30
          shuttercontrol.0
          2022-05-11 15:28:34.613	debug	check IsLater : 21:13 21:30
          shuttercontrol.0
          2022-05-11 15:28:34.610	debug	Starting up shutters children area: 07:00 debug 8
          shuttercontrol.0
          2022-05-11 15:28:34.610	debug	yes, IsEarlier : 05:24 07:00
          shuttercontrol.0
          2022-05-11 15:28:34.609	debug	check IsEarlier : 05:24 07:00
          shuttercontrol.0
          2022-05-11 15:28:34.609	debug	check IsEqual : 05:24 07:05
          shuttercontrol.0
          2022-05-11 15:28:34.609	debug	check IsEqual : 07:00 07:05
          shuttercontrol.0
          2022-05-11 15:28:34.609	debug	check IsLater : 05:24 07:00
          shuttercontrol.0
          2022-05-11 15:28:34.609	debug	check IsLater : 05:24 07:05
          shuttercontrol.0
          2022-05-11 15:28:34.598	debug	Starting up shutters sleep area: 07:15 debug 8
          shuttercontrol.0
          2022-05-11 15:28:34.598	debug	yes, IsEarlier : 05:24 07:15
          shuttercontrol.0
          2022-05-11 15:28:34.597	debug	check IsEarlier : 05:24 07:15
          shuttercontrol.0
          2022-05-11 15:28:34.597	debug	check IsEqual : 05:24 07:30
          shuttercontrol.0
          2022-05-11 15:28:34.597	debug	check IsEqual : 07:15 07:30
          shuttercontrol.0
          2022-05-11 15:28:34.596	debug	check IsLater : 05:24 07:15
          shuttercontrol.0
          2022-05-11 15:28:34.596	debug	check IsLater : 05:24 07:30
          shuttercontrol.0
          2022-05-11 15:28:34.585	debug	Starting up shutters living area: 07:05 debug 8
          shuttercontrol.0
          2022-05-11 15:28:34.585	debug	yes, IsEarlier : 05:24 07:05
          shuttercontrol.0
          2022-05-11 15:28:34.585	debug	check IsEarlier : 05:24 07:05
          shuttercontrol.0
          2022-05-11 15:28:34.585	debug	check IsEqual : 05:24 07:15
          shuttercontrol.0
          2022-05-11 15:28:34.584	debug	check IsEqual : 07:05 07:15
          shuttercontrol.0
          2022-05-11 15:28:34.584	debug	check IsLater : 05:24 07:05
          shuttercontrol.0
          2022-05-11 15:28:34.584	debug	check IsLater : 05:24 07:15
          shuttercontrol.0
          2022-05-11 15:28:34.571	debug	Shutdown shutters Sunset area: 21:13
          shuttercontrol.0
          2022-05-11 15:28:34.571	debug	Starting up shutters Sunrise area: 05:24
          shuttercontrol.0
          2022-05-11 15:28:34.571	debug	Shutdown shutters GoldenHour area: 20:25
          shuttercontrol.0
          2022-05-11 15:28:34.571	debug	Starting up shutters GoldenHour area: 06:12
          shuttercontrol.0
          2022-05-11 15:28:34.570	debug	Sunset today: 20:43
          shuttercontrol.0
          2022-05-11 15:28:34.570	debug	Sunrise today: 05:24
          shuttercontrol.0
          2022-05-11 15:28:34.570	debug	current day: 3
          shuttercontrol.0
          2022-05-11 15:28:34.570	debug	goldenHour today: 19:55
          shuttercontrol.0
          2022-05-11 15:28:34.569	debug	goldenHourEnd today: 06:12
          shuttercontrol.0
          2022-05-11 15:28:34.569	debug	calculate astrodata ...
          shuttercontrol.0
          2022-05-11 15:28:34.568	debug	Travel times of the shutters are calculated
          shuttercontrol.0
          2022-05-11 15:28:31.954	debug	Rollladen_Bad_LEVEL: settings added
          shuttercontrol.0
          2022-05-11 15:28:31.835	debug	Rollladen_Natalie_klein_LEVEL: settings added
          shuttercontrol.0
          2022-05-11 15:28:31.734	debug	Rollladen_Natalie_LEVEL: settings added
          shuttercontrol.0
          2022-05-11 15:28:31.632	debug	Rolladen_Emilia_LEVEL: settings added
          shuttercontrol.0
          2022-05-11 15:28:31.531	debug	Rollladen_Küche_Links_LEVEL: settings added
          shuttercontrol.0
          2022-05-11 15:28:31.431	debug	Rollladen_Küche_Rechts_LEVEL: settings added
          shuttercontrol.0
          2022-05-11 15:28:31.331	debug	Rollladen_Terrassentür_LEVEL: settings added
          shuttercontrol.0
          2022-05-11 15:28:31.230	debug	Rollladen_Ecke_Links_LEVEL: settings added
          shuttercontrol.0
          2022-05-11 15:28:31.128	debug	Rollladen_Ecke_Rechts_LEVEL: settings added
          shuttercontrol.0
          2022-05-11 15:28:31.025	debug	Rollladen_Arbeitszimmer_LEVEL: settings added
          shuttercontrol.0
          2022-05-11 15:28:31.006	debug	Shutter State: hm-rpc.0.OEQ1857255.1.LEVEL
          shuttercontrol.0
          2022-05-11 15:28:31.006	debug	Shutter State: hm-rpc.0.OEQ1299329.1.LEVEL
          shuttercontrol.0
          2022-05-11 15:28:31.005	debug	Shutter State: hm-rpc.0.OEQ1299312.1.LEVEL
          shuttercontrol.0
          2022-05-11 15:28:31.005	debug	Shutter State: hm-rpc.0.OEQ1299321.1.LEVEL
          shuttercontrol.0
          2022-05-11 15:28:31.005	debug	Shutter State: hm-rpc.0.OEQ1300082.1.LEVEL
          shuttercontrol.0
          2022-05-11 15:28:31.004	debug	Shutter State: hm-rpc.0.OEQ1302808.1.LEVEL
          shuttercontrol.0
          2022-05-11 15:28:31.003	debug	Shutter State: hm-rpc.0.OEQ1302889.1.LEVEL
          shuttercontrol.0
          2022-05-11 15:28:31.003	debug	Shutter State: hm-rpc.0.OEQ1302897.1.LEVEL
          shuttercontrol.0
          2022-05-11 15:28:31.003	debug	Shutter State: hm-rpc.0.OEQ1858638.1.LEVEL
          shuttercontrol.0
          2022-05-11 15:28:31.002	debug	Shutter State: hm-rpc.0.OEQ1299293.1.LEVEL
          shuttercontrol.0
          2022-05-11 15:28:31.001	debug	trigger for outside temperature: hm-rpc.2.000EDD89AEC34D.1.ACTUAL_TEMPERATURE
          shuttercontrol.0
          2022-05-11 15:28:31.000	debug	trigger for inside temperature: zigbee.0.00158d000273ce6b.temperature
          shuttercontrol.0
          2022-05-11 15:28:31.000	debug	trigger for inside temperature: zigbee.0.00158d0002321724.temperature
          shuttercontrol.0
          2022-05-11 15:28:30.999	debug	trigger for inside temperature: zigbee.0.00158d000249074a.temperature
          shuttercontrol.0
          2022-05-11 15:28:30.999	debug	trigger for inside temperature: zigbee.0.00158d0002288653.temperature
          shuttercontrol.0
          2022-05-11 15:28:30.998	debug	trigger for inside temperature: zigbee.0.00158d000247d478.temperature
          shuttercontrol.0
          2022-05-11 15:28:30.997	debug	trigger for shuttercontrol: zigbee.0.00158d0001d8715b.opened
          shuttercontrol.0
          2022-05-11 15:28:30.997	debug	trigger for shuttercontrol: zigbee.0.00158d000236fedd.opened
          shuttercontrol.0
          2022-05-11 15:28:30.997	debug	trigger for shuttercontrol: zigbee.0.00158d000232cc9b.opened
          shuttercontrol.0
          2022-05-11 15:28:30.996	debug	trigger for shuttercontrol: hm-rpc.2.0007D8A99FC127.1.STATE
          shuttercontrol.0
          2022-05-11 15:28:30.996	debug	trigger for shuttercontrol: zigbee.0.00158d000232a99f.opened
          shuttercontrol.0
          2022-05-11 15:28:30.990	debug	shutter Config Check successfully completed
          shuttercontrol.0
          2022-05-11 15:28:30.990	debug	shutter Config Check started
          shuttercontrol.0
          2022-05-11 15:28:30.957	info	starting. Version 1.4.12 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v14.17.5, js-controller: 4.0.23
          shuttercontrol.0
          2022-05-11 15:28:30.290	debug	Plugin sentry Initialize Plugin (enabled=true)
          shuttercontrol.0
          2022-05-11 15:28:26.779	info	Terminated (NO_ERROR): Without reason
          shuttercontrol.0
          2022-05-11 15:28:26.778	debug	Plugin sentry destroyed
          shuttercontrol.0
          2022-05-11 15:28:26.777	info	terminating
          shuttercontrol.0
          2022-05-11 15:28:26.774	info	Got terminate signal TERMINATE_YOURSELF
          shuttercontrol.0
          2022-05-11 15:28:26.591	info	cleaned everything up...
          shuttercontrol.0
          2022-05-11 15:28:26.590	info	Adapter is disabled => stop
          shuttercontrol.0
          2022-05-11 15:26:52.487	debug	complete down at 22:00
          shuttercontrol.0
          2022-05-11 15:26:52.482	debug	Shutdown shutters sleep area: 19:30 debug 6
          shuttercontrol.0
          2022-05-11 15:26:52.476	debug	Shutdown shutters children area: 19:30 debug 6
          shuttercontrol.0
          2022-05-11 15:26:52.474	debug	shutterDownLiving
          shuttercontrol.0
          2022-05-11 15:26:52.473	debug	Shutdown shutters living area: 21:13 debug 7
          shuttercontrol.0
          2022-05-11 15:26:52.473	debug	yes, IsEarlier : 21:13 21:30
          shuttercontrol.0
          2022-05-11 15:26:52.473	debug	check IsEarlier : 21:13 21:30
          shuttercontrol.0
          2022-05-11 15:26:52.472	debug	check IsLater : 21:13 21:30
          shuttercontrol.0
          2022-05-11 15:26:52.470	debug	Starting up shutters children area: 07:00 debug 8
          shuttercontrol.0
          2022-05-11 15:26:52.469	debug	yes, IsEarlier : 05:24 07:00
          shuttercontrol.0
          2022-05-11 15:26:52.469	debug	check IsEarlier : 05:24 07:00
          shuttercontrol.0
          2022-05-11 15:26:52.469	debug	check IsEqual : 05:24 07:05
          shuttercontrol.0
          2022-05-11 15:26:52.469	debug	check IsEqual : 07:00 07:05
          shuttercontrol.0
          2022-05-11 15:26:52.469	debug	check IsLater : 05:24 07:00
          shuttercontrol.0
          2022-05-11 15:26:52.468	debug	check IsLater : 05:24 07:05
          shuttercontrol.0
          2022-05-11 15:26:52.463	debug	Starting up shutters sleep area: 07:15 debug 8
          shuttercontrol.0
          2022-05-11 15:26:52.463	debug	yes, IsEarlier : 05:24 07:15
          shuttercontrol.0
          2022-05-11 15:26:52.463	debug	check IsEarlier : 05:24 07:15
          shuttercontrol.0
          2022-05-11 15:26:52.463	debug	check IsEqual : 05:24 07:30
          shuttercontrol.0
          2022-05-11 15:26:52.462	debug	check IsEqual : 07:15 07:30
          shuttercontrol.0
          2022-05-11 15:26:52.462	debug	check IsLater : 05:24 07:15
          shuttercontrol.0
          2022-05-11 15:26:52.462	debug	check IsLater : 05:24 07:30
          shuttercontrol.0
          2022-05-11 15:26:52.457	debug	Starting up shutters living area: 07:05 debug 8
          shuttercontrol.0
          2022-05-11 15:26:52.457	debug	yes, IsEarlier : 05:24 07:05
          shuttercontrol.0
          2022-05-11 15:26:52.456	debug	check IsEarlier : 05:24 07:05
          shuttercontrol.0
          2022-05-11 15:26:52.456	debug	check IsEqual : 05:24 07:15
          shuttercontrol.0
          2022-05-11 15:26:52.456	debug	check IsEqual : 07:05 07:15
          shuttercontrol.0
          2022-05-11 15:26:52.456	debug	check IsLater : 05:24 07:05
          shuttercontrol.0
          2022-05-11 15:26:52.455	debug	check IsLater : 05:24 07:15
          shuttercontrol.0
          2022-05-11 15:26:52.445	debug	Shutdown shutters Sunset area: 21:13
          shuttercontrol.0
          2022-05-11 15:26:52.445	debug	Starting up shutters Sunrise area: 05:24
          shuttercontrol.0
          2022-05-11 15:26:52.445	debug	Shutdown shutters GoldenHour area: 20:25
          shuttercontrol.0
          2022-05-11 15:26:52.444	debug	Starting up shutters GoldenHour area: 06:12
          shuttercontrol.0
          2022-05-11 15:26:52.444	debug	Sunset today: 20:43
          shuttercontrol.0
          2022-05-11 15:26:52.444	debug	Sunrise today: 05:24
          shuttercontrol.0
          2022-05-11 15:26:52.444	debug	current day: 3
          shuttercontrol.0
          2022-05-11 15:26:52.444	debug	goldenHour today: 19:55
          shuttercontrol.0
          2022-05-11 15:26:52.443	debug	goldenHourEnd today: 06:12
          shuttercontrol.0
          2022-05-11 15:26:52.443	debug	calculate astrodata ...
          shuttercontrol.0
          2022-05-11 15:26:52.442	debug	Travel times of the shutters are calculated
          shuttercontrol.0
          2022-05-11 15:26:49.830	debug	Rollladen_Bad_LEVEL: save settings
          shuttercontrol.0
          2022-05-11 15:26:49.730	debug	Rollladen_Natalie_klein_LEVEL: save settings
          shuttercontrol.0
          2022-05-11 15:26:49.629	debug	Rollladen_Natalie_LEVEL: save settings
          shuttercontrol.0
          2022-05-11 15:26:49.528	debug	Rolladen_Emilia_LEVEL: save settings
          shuttercontrol.0
          2022-05-11 15:26:49.428	debug	Rollladen_Küche_Links_LEVEL: save settings
          shuttercontrol.0
          2022-05-11 15:26:49.326	debug	Rollladen_Küche_Rechts_LEVEL: save settings
          shuttercontrol.0
          2022-05-11 15:26:49.226	debug	Rollladen_Terrassentür_LEVEL: save settings
          shuttercontrol.0
          2022-05-11 15:26:49.125	debug	Rollladen_Ecke_Links_LEVEL: save settings
          shuttercontrol.0
          2022-05-11 15:26:49.024	debug	Rollladen_Ecke_Rechts_LEVEL: save settings
          shuttercontrol.0
          2022-05-11 15:26:48.901	debug	Rollladen_Arbeitszimmer_LEVEL: save settings
          shuttercontrol.0
          2022-05-11 15:26:48.868	debug	Shutter State: hm-rpc.0.OEQ1857255.1.LEVEL
          shuttercontrol.0
          2022-05-11 15:26:48.868	debug	Shutter State: hm-rpc.0.OEQ1299329.1.LEVEL
          shuttercontrol.0
          2022-05-11 15:26:48.868	debug	Shutter State: hm-rpc.0.OEQ1299312.1.LEVEL
          shuttercontrol.0
          2022-05-11 15:26:48.868	debug	Shutter State: hm-rpc.0.OEQ1299321.1.LEVEL
          shuttercontrol.0
          2022-05-11 15:26:48.867	debug	Shutter State: hm-rpc.0.OEQ1300082.1.LEVEL
          shuttercontrol.0
          2022-05-11 15:26:48.867	debug	Shutter State: hm-rpc.0.OEQ1302808.1.LEVEL
          shuttercontrol.0
          2022-05-11 15:26:48.867	debug	Shutter State: hm-rpc.0.OEQ1302889.1.LEVEL
          shuttercontrol.0
          2022-05-11 15:26:48.867	debug	Shutter State: hm-rpc.0.OEQ1302897.1.LEVEL
          shuttercontrol.0
          2022-05-11 15:26:48.866	debug	Shutter State: hm-rpc.0.OEQ1858638.1.LEVEL
          shuttercontrol.0
          2022-05-11 15:26:48.866	debug	Shutter State: hm-rpc.0.OEQ1299293.1.LEVEL
          shuttercontrol.0
          2022-05-11 15:26:48.866	debug	trigger for outside temperature: hm-rpc.2.000EDD89AEC34D.1.ACTUAL_TEMPERATURE
          shuttercontrol.0
          2022-05-11 15:26:48.865	debug	trigger for inside temperature: zigbee.0.00158d000273ce6b.temperature
          shuttercontrol.0
          2022-05-11 15:26:48.865	debug	trigger for inside temperature: zigbee.0.00158d0002321724.temperature
          shuttercontrol.0
          2022-05-11 15:26:48.865	debug	trigger for inside temperature: zigbee.0.00158d000249074a.temperature
          shuttercontrol.0
          2022-05-11 15:26:48.864	debug	trigger for inside temperature: zigbee.0.00158d0002288653.temperature
          shuttercontrol.0
          2022-05-11 15:26:48.864	debug	trigger for inside temperature: zigbee.0.00158d000247d478.temperature
          shuttercontrol.0
          2022-05-11 15:26:48.864	debug	trigger for shuttercontrol: zigbee.0.00158d0001d8715b.opened
          shuttercontrol.0
          2022-05-11 15:26:48.863	debug	trigger for shuttercontrol: zigbee.0.00158d000236fedd.opened
          shuttercontrol.0
          2022-05-11 15:26:48.863	debug	trigger for shuttercontrol: zigbee.0.00158d000232cc9b.opened
          shuttercontrol.0
          2022-05-11 15:26:48.863	debug	trigger for shuttercontrol: hm-rpc.2.0007D8A99FC127.1.STATE
          shuttercontrol.0
          2022-05-11 15:26:48.862	debug	trigger for shuttercontrol: zigbee.0.00158d000232a99f.opened
          shuttercontrol.0
          2022-05-11 15:26:48.860	debug	shutter Config Check successfully completed
          shuttercontrol.0
          2022-05-11 15:26:48.859	debug	shutter Config Check started
          shuttercontrol.0
          2022-05-11 15:26:48.831	info	starting. Version 1.4.12 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v14.17.5, js-controller: 4.0.23
          shuttercontrol.0
          2022-05-11 15:26:48.439	debug	Plugin sentry Initialize Plugin (enabled=true)
          shuttercontrol.0
          2022-05-11 15:26:43.693	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          shuttercontrol.0
          2022-05-11 15:26:43.693	debug	Plugin sentry destroyed
          shuttercontrol.0
          2022-05-11 15:26:43.692	info	terminating
          shuttercontrol.0
          2022-05-11 15:26:43.692	info	cleaned everything up...
          shuttercontrol.0
          2022-05-11 15:26:43.691	info	Got terminate signal TERMINATE_YOURSELF
          shuttercontrol.0
          2022-05-11 15:26:09.663	debug	outsidetemperature changed: hm-rpc.2.000EDD89AEC34D.1.ACTUAL_TEMPERATURE Value: 28.3
          shuttercontrol.0
          2022-05-11 15:25:00.018	debug	Sun Elevation: 46.7°
          shuttercontrol.0
          2022-05-11 15:25:00.017	debug	Sun Azimut: 233.5°
          shuttercontrol.0
          2022-05-11 15:25:00.016	debug	calculate astrodata ...
          shuttercontrol.0
          2022-05-11 15:24:39.353	debug	insidetemperature changed: zigbee.0.00158d000249074a.temperature Value: 21.84
          shuttercontrol.0
          2022-05-11 15:24:05.659	debug	outsidetemperature changed: hm-rpc.2.000EDD89AEC34D.1.ACTUAL_TEMPERATURE Value: 28.4
          shuttercontrol.0
          2022-05-11 15:20:00.031	debug	Sun Elevation: 47.3°
          shuttercontrol.0
          2022-05-11 15:20:00.031	debug	Sun Azimut: 232°
          shuttercontrol.0
          2022-05-11 15:20:00.030	debug	calculate astrodata ...
          shuttercontrol.0
          2022-05-11 15:19:14.408	debug	outsidetemperature changed: hm-rpc.2.000EDD89AEC34D.1.ACTUAL_TEMPERATURE Value: 28.5
          shuttercontrol.0
          2022-05-11 15:16:27.116	debug	outsidetemperature changed: hm-rpc.2.000EDD89AEC34D.1.ACTUAL_TEMPERATURE Value: 28.6
          shuttercontrol.0
          2022-05-11 15:15:00.028	debug	Sun Elevation: 47.9°
          shuttercontrol.0
          2022-05-11 15:15:00.027	debug	Sun Azimut: 230.5°
          shuttercontrol.0
          2022-05-11 15:15:00.027	debug	calculate astrodata ...
          shuttercontrol.0
          2022-05-11 15:11:13.384	debug	outsidetemperature changed: hm-rpc.2.000EDD89AEC34D.1.ACTUAL_TEMPERATURE Value: 28.8
          shuttercontrol.0
          2022-05-11 15:10:00.016	debug	Sun Elevation: 48.5°
          shuttercontrol.0
          2022-05-11 15:10:00.016	debug	Sun Azimut: 229°
          shuttercontrol.0
          2022-05-11 15:10:00.015	debug	calculate astrodata ...
          shuttercontrol.0
          2022-05-11 15:08:46.908	debug	outsidetemperature changed: hm-rpc.2.000EDD89AEC34D.1.ACTUAL_TEMPERATURE Value: 29
          shuttercontrol.0
          2022-05-11 15:08:15.790	debug	complete down at 22:00
          shuttercontrol.0
          2022-05-11 15:08:15.786	debug	Shutdown shutters sleep area: 19:30 debug 6
          shuttercontrol.0
          2022-05-11 15:08:15.782	debug	Shutdown shutters children area: 19:30 debug 6
          shuttercontrol.0
          2022-05-11 15:08:15.779	debug	shutterDownLiving
          shuttercontrol.0
          2022-05-11 15:08:15.779	debug	Shutdown shutters living area: 21:13 debug 7
          shuttercontrol.0
          2022-05-11 15:08:15.779	debug	yes, IsEarlier : 21:13 21:30
          shuttercontrol.0
          2022-05-11 15:08:15.779	debug	check IsEarlier : 21:13 21:30
          shuttercontrol.0
          2022-05-11 15:08:15.778	debug	check IsLater : 21:13 21:30
          shuttercontrol.0
          2022-05-11 15:08:15.777	debug	Starting up shutters children area: 07:00 debug 8
          shuttercontrol.0
          2022-05-11 15:08:15.776	debug	yes, IsEarlier : 05:24 07:00
          shuttercontrol.0
          2022-05-11 15:08:15.776	debug	check IsEarlier : 05:24 07:00
          shuttercontrol.0
          2022-05-11 15:08:15.776	debug	check IsEqual : 05:24 07:05
          shuttercontrol.0
          2022-05-11 15:08:15.776	debug	check IsEqual : 07:00 07:05
          shuttercontrol.0
          2022-05-11 15:08:15.776	debug	check IsLater : 05:24 07:00
          shuttercontrol.0
          2022-05-11 15:08:15.775	debug	check IsLater : 05:24 07:05
          shuttercontrol.0
          2022-05-11 15:08:15.772	debug	Starting up shutters sleep area: 07:15 debug 8
          shuttercontrol.0
          2022-05-11 15:08:15.772	debug	yes, IsEarlier : 05:24 07:15
          shuttercontrol.0
          2022-05-11 15:08:15.772	debug	check IsEarlier : 05:24 07:15
          shuttercontrol.0
          2022-05-11 15:08:15.772	debug	check IsEqual : 05:24 07:30
          shuttercontrol.0
          2022-05-11 15:08:15.772	debug	check IsEqual : 07:15 07:30
          shuttercontrol.0
          2022-05-11 15:08:15.771	debug	check IsLater : 05:24 07:15
          shuttercontrol.0
          2022-05-11 15:08:15.771	debug	check IsLater : 05:24 07:30
          shuttercontrol.0
          2022-05-11 15:08:15.767	debug	Starting up shutters living area: 07:05 debug 8
          shuttercontrol.0
          2022-05-11 15:08:15.766	debug	yes, IsEarlier : 05:24 07:05
          shuttercontrol.0
          2022-05-11 15:08:15.766	debug	check IsEarlier : 05:24 07:05
          shuttercontrol.0
          2022-05-11 15:08:15.766	debug	check IsEqual : 05:24 07:15
          shuttercontrol.0
          2022-05-11 15:08:15.766	debug	check IsEqual : 07:05 07:15
          shuttercontrol.0
          2022-05-11 15:08:15.766	debug	check IsLater : 05:24 07:05
          shuttercontrol.0
          2022-05-11 15:08:15.765	debug	check IsLater : 05:24 07:15
          shuttercontrol.0
          2022-05-11 15:08:15.750	debug	Shutdown shutters Sunset area: 21:13
          shuttercontrol.0
          2022-05-11 15:08:15.750	debug	Starting up shutters Sunrise area: 05:24
          shuttercontrol.0
          2022-05-11 15:08:15.750	debug	Shutdown shutters GoldenHour area: 20:25
          shuttercontrol.0
          2022-05-11 15:08:15.750	debug	Starting up shutters GoldenHour area: 06:12
          shuttercontrol.0
          2022-05-11 15:08:15.749	debug	Sunset today: 20:43
          shuttercontrol.0
          2022-05-11 15:08:15.749	debug	Sunrise today: 05:24
          shuttercontrol.0
          2022-05-11 15:08:15.748	debug	current day: 3
          shuttercontrol.0
          2022-05-11 15:08:15.748	debug	goldenHour today: 19:55
          shuttercontrol.0
          2022-05-11 15:08:15.748	debug	goldenHourEnd today: 06:12
          shuttercontrol.0
          2022-05-11 15:08:15.747	debug	calculate astrodata ...
          shuttercontrol.0
          2022-05-11 15:08:15.746	debug	Travel times of the shutters are calculated
          shuttercontrol.0
          2022-05-11 15:08:13.364	debug	Rollladen_Bad_LEVEL: save settings
          shuttercontrol.0
          2022-05-11 15:08:13.264	debug	Rollladen_Natalie_klein_LEVEL: save settings
          shuttercontrol.0
          2022-05-11 15:08:13.162	debug	Rollladen_Natalie_LEVEL: save settings
          shuttercontrol.0
          2022-05-11 15:08:13.062	debug	Rolladen_Emilia_LEVEL: save settings
          shuttercontrol.0
          2022-05-11 15:08:12.960	debug	Rollladen_Küche_Links_LEVEL: save settings
          shuttercontrol.0
          2022-05-11 15:08:12.860	debug	Rollladen_Küche_Rechts_LEVEL: save settings
          shuttercontrol.0
          2022-05-11 15:08:12.760	debug	Rollladen_Terrassentür_LEVEL: save settings
          shuttercontrol.0
          2022-05-11 15:08:12.658	debug	Rollladen_Ecke_Links_LEVEL: save settings
          shuttercontrol.0
          2022-05-11 15:08:12.557	debug	Rollladen_Ecke_Rechts_LEVEL: save settings
          shuttercontrol.0
          2022-05-11 15:08:12.439	debug	Rollladen_Arbeitszimmer_LEVEL: save settings
          shuttercontrol.0
          2022-05-11 15:08:12.420	debug	Shutter State: hm-rpc.0.OEQ1857255.1.LEVEL
          shuttercontrol.0
          2022-05-11 15:08:12.419	debug	Shutter State: hm-rpc.0.OEQ1299329.1.LEVEL
          shuttercontrol.0
          2022-05-11 15:08:12.419	debug	Shutter State: hm-rpc.0.OEQ1299312.1.LEVEL
          shuttercontrol.0
          2022-05-11 15:08:12.419	debug	Shutter State: hm-rpc.0.OEQ1299321.1.LEVEL
          shuttercontrol.0
          2022-05-11 15:08:12.419	debug	Shutter State: hm-rpc.0.OEQ1300082.1.LEVEL
          shuttercontrol.0
          2022-05-11 15:08:12.418	debug	Shutter State: hm-rpc.0.OEQ1302808.1.LEVEL
          shuttercontrol.0
          2022-05-11 15:08:12.418	debug	Shutter State: hm-rpc.0.OEQ1302889.1.LEVEL
          shuttercontrol.0
          2022-05-11 15:08:12.418	debug	Shutter State: hm-rpc.0.OEQ1302897.1.LEVEL
          shuttercontrol.0
          2022-05-11 15:08:12.417	debug	Shutter State: hm-rpc.0.OEQ1858638.1.LEVEL
          shuttercontrol.0
          2022-05-11 15:08:12.417	debug	Shutter State: hm-rpc.0.OEQ1299293.1.LEVEL
          shuttercontrol.0
          2022-05-11 15:08:12.416	debug	trigger for outside temperature: hm-rpc.2.000EDD89AEC34D.1.ACTUAL_TEMPERATURE
          shuttercontrol.0
          2022-05-11 15:08:12.416	debug	trigger for inside temperature: zigbee.0.00158d000273ce6b.temperature
          shuttercontrol.0
          2022-05-11 15:08:12.415	debug	trigger for inside temperature: zigbee.0.00158d0002321724.temperature
          shuttercontrol.0
          2022-05-11 15:08:12.415	debug	trigger for inside temperature: zigbee.0.00158d000249074a.temperature
          shuttercontrol.0
          2022-05-11 15:08:12.414	debug	trigger for inside temperature: zigbee.0.00158d0002288653.temperature
          shuttercontrol.0
          2022-05-11 15:08:12.414	debug	trigger for inside temperature: zigbee.0.00158d000247d478.temperature
          shuttercontrol.0
          2022-05-11 15:08:12.413	debug	trigger for shuttercontrol: zigbee.0.00158d0001d8715b.opened
          shuttercontrol.0
          2022-05-11 15:08:12.413	debug	trigger for shuttercontrol: zigbee.0.00158d000236fedd.opened
          shuttercontrol.0
          2022-05-11 15:08:12.413	debug	trigger for shuttercontrol: zigbee.0.00158d000232cc9b.opened
          shuttercontrol.0
          2022-05-11 15:08:12.413	debug	trigger for shuttercontrol: hm-rpc.2.0007D8A99FC127.1.STATE
          shuttercontrol.0
          2022-05-11 15:08:12.412	debug	trigger for shuttercontrol: zigbee.0.00158d000232a99f.opened
          shuttercontrol.0
          2022-05-11 15:08:12.409	debug	shutter Config Check successfully completed
          shuttercontrol.0
          2022-05-11 15:08:12.408	debug	shutter Config Check started
          shuttercontrol.0
          2022-05-11 15:08:12.383	info	starting. Version 1.4.12 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v14.17.5, js-controller: 4.0.23
          shuttercontrol.0
          2022-05-11 15:08:11.881	debug	Plugin sentry Initialize Plugin (enabled=true)
          shuttercontrol.0
          2022-05-11 15:08:07.379	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          shuttercontrol.0
          2022-05-11 15:08:07.377	debug	Plugin sentry destroyed
          shuttercontrol.0
          2022-05-11 15:08:07.375	info	terminating
          shuttercontrol.0
          2022-05-11 15:08:07.373	info	cleaned everything up...
          shuttercontrol.0
          2022-05-11 15:08:07.371	info	Got terminate signal TERMINATE_YOURSELF
          shuttercontrol.0
          2022-05-11 15:06:54.284	debug	insidetemperature changed: zigbee.0.00158d0002288653.temperature Value: 22.56
          shuttercontrol.0
          2022-05-11 15:06:51.040	debug	insidetemperature changed: zigbee.0.00158d0002321724.temperature Value: 22.01
          shuttercontrol.0
          2022-05-11 15:06:17.170	debug	Shutter Rollladen Natalie.LEVEL was moved manually to: 100% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:06:17.169	debug	save current height after State Check: 100% from Rollladen Natalie.LEVEL
          shuttercontrol.0
          2022-05-11 15:06:16.164	debug	Rollladen Natalie.LEVEL drived manually to 100. Old value = 0. New value = 100
          shuttercontrol.0
          2022-05-11 15:06:16.164	debug	Rollladen Natalie.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:06:16.110	debug	Shutter state changed: Rollladen Natalie.LEVEL old value = 0 new value = 100
          shuttercontrol.0
          2022-05-11 15:06:11.743	debug	Shutter Rolladen Emilia.LEVEL was moved manually to: 100% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:06:11.743	debug	save current height after State Check: 100% from Rolladen Emilia.LEVEL
          shuttercontrol.0
          2022-05-11 15:06:10.738	debug	Rolladen Emilia.LEVEL drived manually to 100. Old value = 0. New value = 100
          shuttercontrol.0
          2022-05-11 15:06:10.738	debug	Rolladen Emilia.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:06:10.732	debug	Shutter state changed: Rolladen Emilia.LEVEL old value = 0 new value = 100
          shuttercontrol.0
          2022-05-11 15:06:05.860	debug	outsidetemperature changed: hm-rpc.2.000EDD89AEC34D.1.ACTUAL_TEMPERATURE Value: 29.2
          shuttercontrol.0
          2022-05-11 15:05:56.692	debug	Shuttercontrol save all shutter states
          shuttercontrol.0
          2022-05-11 15:05:51.691	debug	shutterUpButton Rollladen Bad.LEVEL already up at: 100% - setting current action: up
          shuttercontrol.0
          2022-05-11 15:05:46.679	debug	shutterUpButton Rollladen Natalie klein.LEVEL already up at: 0% - setting current action: up
          shuttercontrol.0
          2022-05-11 15:05:42.675	debug	save current height after State Check: 0% from Rollladen Natalie.LEVEL
          shuttercontrol.0
          2022-05-11 15:05:41.766	debug	Rollladen Natalie.LEVEL Old value = 0. New value = 100. automatic is active
          shuttercontrol.0
          2022-05-11 15:05:41.766	debug	Shutter state changed: Rollladen Natalie.LEVEL old value = 0 new value = 100
          shuttercontrol.0
          2022-05-11 15:05:41.670	debug	shutterUpButton Rollladen Natalie.LEVEL old height: 0% new height: 100%
          shuttercontrol.0
          2022-05-11 15:05:41.655	info	Button openAll Set ID: Rollladen Natalie.LEVEL value: 100%
          shuttercontrol.0
          2022-05-11 15:05:39.947	debug	Shutter Rollladen Ecke Links.LEVEL was moved manually to: 100% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:05:39.947	debug	save current height after State Check: 100% from Rollladen Ecke Links.LEVEL
          shuttercontrol.0
          2022-05-11 15:05:38.939	debug	Rollladen Ecke Links.LEVEL drived manually to 100. Old value = 44. New value = 100
          shuttercontrol.0
          2022-05-11 15:05:38.938	debug	Rollladen Ecke Links.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:05:38.893	debug	Shutter state changed: Rollladen Ecke Links.LEVEL old value = 44 new value = 100
          shuttercontrol.0
          2022-05-11 15:05:37.659	debug	save current height after State Check: 0% from Rolladen Emilia.LEVEL
          shuttercontrol.0
          2022-05-11 15:05:36.745	debug	Rolladen Emilia.LEVEL Old value = 0. New value = 100. automatic is active
          shuttercontrol.0
          2022-05-11 15:05:36.745	debug	Shutter state changed: Rolladen Emilia.LEVEL old value = 0 new value = 100
          shuttercontrol.0
          2022-05-11 15:05:36.654	debug	shutterUpButton Rolladen Emilia.LEVEL old height: 0% new height: 100%
          shuttercontrol.0
          2022-05-11 15:05:36.640	info	Button openAll Set ID: Rolladen Emilia.LEVEL value: 100%
          shuttercontrol.0
          2022-05-11 15:05:35.977	debug	Shutter Rollladen Ecke Rechts.LEVEL was moved manually to: 100% while window was open - prevent trigger from driving back
          shuttercontrol.0
          2022-05-11 15:05:35.977	debug	save current height after State Check: 100% from Rollladen Ecke Rechts.LEVEL
          shuttercontrol.0
          2022-05-11 15:05:34.972	debug	Rollladen Ecke Rechts.LEVEL drived manually to 100. Old value = 41. New value = 100
          shuttercontrol.0
          2022-05-11 15:05:34.971	debug	Rollladen Ecke Rechts.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2022-05-11 15:05:34.922	debug	Shutter state changed: Rollladen Ecke Rechts.LEVEL old value = 41 new value = 100
          shuttercontrol.0
          2022-05-11 15:05:31.638	debug	shutterUpButton Rollladen Küche Links.LEVEL already up at: 100% - setting current action: up
          shuttercontrol.0
          2022-05-11 15:05:26.622	debug	shutterUpButton Rollladen Küche Rechts.LEVEL already up at: 100% - setting current action: up
          shuttercontrol.0
          2022-05-11 15:05:21.590	debug	shutterUpButton Rollladen Terrassentür.LEVEL already up at: 100% - setting current action: up
          shuttercontrol.0
          2022-05-11 15:05:17.583	debug	save current height after State Check: 44% from Rollladen Ecke Links.LEVEL
          shuttercontrol.0
          2022-05-11 15:05:16.663	debug	Rollladen Ecke Links.LEVEL Old value = 44. New value = 100. automatic is active
          shuttercontrol.0
          2022-05-11 15:05:16.663	debug	Shutter state changed: Rollladen Ecke Links.LEVEL old value = 44 new value = 100
          shuttercontrol.0
          2022-05-11 15:05:16.579	debug	shutterUpButton Rollladen Ecke Links.LEVEL old height: 44% new height: 100%
          shuttercontrol.0
          2022-05-11 15:05:16.558	info	Button openAll Set ID: Rollladen Ecke Links.LEVEL value: 100%
          shuttercontrol.0
          2022-05-11 15:05:12.561	debug	save current height after State Check: 41% from Rollladen Ecke Rechts.LEVEL
          shuttercontrol.0
          2022-05-11 15:05:11.648	debug	Rollladen Ecke Rechts.LEVEL Old value = 41. New value = 100. automatic is active
          shuttercontrol.0
          2022-05-11 15:05:11.648	debug	Shutter state changed: Rollladen Ecke Rechts.LEVEL old value = 41 new value = 100
          shuttercontrol.0
          2022-05-11 15:05:11.556	debug	shutterUpButton Rollladen Ecke Rechts.LEVEL old height: 41% new height: 100%
          shuttercontrol.0
          2022-05-11 15:05:11.537	info	Button openAll Set ID: Rollladen Ecke Rechts.LEVEL value: 100%
          shuttercontrol.0
          2022-05-11 15:05:06.525	debug	shutterUpButton Rollladen Arbeitszimmer.LEVEL already up at: 100% - setting current action: up
          shuttercontrol.0
          2022-05-11 15:05:06.463	debug	start buttonAction
          shuttercontrol.0
          2022-05-11 15:05:00.013	debug	Sun Elevation: 49.1°
          shuttercontrol.0
          2022-05-11 15:05:00.012	debug	Sun Azimut: 227.4°
          shuttercontrol.0
          2022-05-11 15:05:00.012	debug	calculate astrodata ...
          shuttercontrol.0
          2022-05-11 15:03:22.973	debug	insidetemperature changed: zigbee.0.00158d000273ce6b.temperature Value: 21.87
          shuttercontrol.0
          2022-05-11 15:03:10.609	debug	outsidetemperature changed: hm-rpc.2.000EDD89AEC34D.1.ACTUAL_TEMPERATURE Value: 29.6
          shuttercontrol.0
          2022-05-11 15:01:41.757	debug	insidetemperature changed: zigbee.0.00158d000273ce6b.temperature Value: 21.88
          shuttercontrol.0
          2022-05-11 15:01:04.858	debug	outsidetemperature changed: hm-rpc.2.000EDD89AEC34D.1.ACTUAL_TEMPERATURE Value: 29.8
          shuttercontrol.0
          2022-05-11 15:00:00.010	debug	Sun Elevation: 49.7°
          shuttercontrol.0
          2022-05-11 15:00:00.009	debug	Sun Azimut: 225.8°
          shuttercontrol.0
          2022-05-11 15:00:00.009	debug	calculate astrodata ...
          shuttercontrol.0
          2022-05-11 14:59:11.137	debug	insidetemperature changed: zigbee.0.00158d0002288653.temperature Value: 22.52
          shuttercontrol.0
          2022-05-11 14:58:44.650	debug	outsidetemperature changed: hm-rpc.2.000EDD89AEC34D.1.ACTUAL_TEMPERATURE Value: 30.2
          shuttercontrol.0
          2022-05-11 14:57:23.504	debug	insidetemperature changed: zigbee.0.00158d000247d478.temperature Value: 21.75
          shuttercontrol.0
          2022-05-11 14:56:10.155	debug	outsidetemperature changed: hm-rpc.2.000EDD89AEC34D.1.ACTUAL_TEMPERATURE Value: 30.7
          shuttercontrol.0
          2022-05-11 14:55:31.634	debug	insidetemperature changed: zigbee.0.00158d000249074a.temperature Value: 21.63
          shuttercontrol.0
          2022-05-11 14:55:00.019	debug	Sun Elevation: 50.2°
          shuttercontrol.0
          2022-05-11 14:55:00.019	debug	Sun Azimut: 224.1°
          shuttercontrol.0
          2022-05-11 14:55:00.018	debug	calculate astrodata ...
          shuttercontrol.0
          2022-05-11 14:53:21.174	debug	outsidetemperature changed: hm-rpc.2.000EDD89AEC34D.1.ACTUAL_TEMPERATURE Value: 31
          shuttercontrol.0
          2022-05-11 14:50:58.320	debug	insidetemperature changed: zigbee.0.00158d0002288653.temperature Value: 22.47
          shuttercontrol.0
          2022-05-11 14:50:17.603	debug	outsidetemperature changed: hm-rpc.2.000EDD89AEC34D.1.ACTUAL_TEMPERATURE Value: 31.8
          shuttercontrol.0
          2022-05-11 14:50:00.020	debug	Sun Elevation: 50.8°
          shuttercontrol.0
          2022-05-11 14:50:00.019	debug	Sun Azimut: 222.5°
          shuttercontrol.0
          2022-05-11 14:50:00.019	debug	calculate astrodata ...
          shuttercontrol.0
          2022-05-11 14:48:38.687	debug	insidetemperature changed: zigbee.0.00158d000249074a.temperature Value: 21.67
          shuttercontrol.0
          2022-05-11 14:48:03.607	debug	outsidetemperature changed: hm-rpc.2.000EDD89AEC34D.1.ACTUAL_TEMPERATURE Value: 32.1
          shuttercontrol.0
          2022-05-11 14:45:35.403	debug	outsidetemperature changed: hm-rpc.2.000EDD89AEC34D.1.ACTUAL_TEMPERATURE Value: 32.2
          shuttercontrol.0
          2022-05-11 14:45:03.963	debug	insidetemperature changed: zigbee.0.00158d0002321724.temperature Value: 21.91
          shuttercontrol.0
          2022-05-11 14:45:00.021	debug	Sun Elevation: 51.3°
          shuttercontrol.0
          2022-05-11 14:45:00.020	debug	Sun Azimut: 220.8°
          shuttercontrol.0
          2022-05-11 14:45:00.018	debug	calculate astrodata ...
          shuttercontrol.0
          2022-05-11 14:42:52.824	debug	complete down at 22:00
          shuttercontrol.0
          2022-05-11 14:42:52.821	debug	Shutdown shutters sleep area: 19:30 debug 6
          shuttercontrol.0
          2022-05-11 14:42:52.817	debug	Shutdown shutters children area: 19:30 debug 6
          shuttercontrol.0
          2022-05-11 14:42:52.814	debug	shutterDownLiving
          shuttercontrol.0
          2022-05-11 14:42:52.814	debug	Shutdown shutters living area: 21:13 debug 7
          shuttercontrol.0
          2022-05-11 14:42:52.814	debug	yes, IsEarlier : 21:13 21:30
          shuttercontrol.0
          2022-05-11 14:42:52.814	debug	check IsEarlier : 21:13 21:30
          shuttercontrol.0
          2022-05-11 14:42:52.813	debug	check IsLater : 21:13 21:30
          shuttercontrol.0
          2022-05-11 14:42:52.811	debug	Starting up shutters children area: 07:00 debug 8
          shuttercontrol.0
          2022-05-11 14:42:52.811	debug	yes, IsEarlier : 05:24 07:00
          shuttercontrol.0
          2022-05-11 14:42:52.811	debug	check IsEarlier : 05:24 07:00
          shuttercontrol.0
          2022-05-11 14:42:52.811	debug	check IsEqual : 05:24 07:05
          shuttercontrol.0
          2022-05-11 14:42:52.811	debug	check IsEqual : 07:00 07:05
          shuttercontrol.0
          2022-05-11 14:42:52.810	debug	check IsLater : 05:24 07:00
          shuttercontrol.0
          2022-05-11 14:42:52.810	debug	check IsLater : 05:24 07:05
          shuttercontrol.0
          2022-05-11 14:42:52.806	debug	Starting up shutters sleep area: 07:15 debug 8
          shuttercontrol.0
          2022-05-11 14:42:52.805	debug	yes, IsEarlier : 05:24 07:15
          shuttercontrol.0
          2022-05-11 14:42:52.805	debug	check IsEarlier : 05:24 07:15
          shuttercontrol.0
          2022-05-11 14:42:52.805	debug	check IsEqual : 05:24 07:30
          shuttercontrol.0
          2022-05-11 14:42:52.805	debug	check IsEqual : 07:15 07:30
          shuttercontrol.0
          2022-05-11 14:42:52.805	debug	check IsLater : 05:24 07:15
          shuttercontrol.0
          2022-05-11 14:42:52.805	debug	check IsLater : 05:24 07:30
          shuttercontrol.0
          2022-05-11 14:42:52.800	debug	Starting up shutters living area: 07:05 debug 8
          shuttercontrol.0
          2022-05-11 14:42:52.799	debug	yes, IsEarlier : 05:24 07:05
          shuttercontrol.0
          2022-05-11 14:42:52.799	debug	check IsEarlier : 05:24 07:05
          shuttercontrol.0
          2022-05-11 14:42:52.799	debug	check IsEqual : 05:24 07:15
          shuttercontrol.0
          2022-05-11 14:42:52.799	debug	check IsEqual : 07:05 07:15
          shuttercontrol.0
          2022-05-11 14:42:52.798	debug	check IsLater : 05:24 07:05
          shuttercontrol.0
          2022-05-11 14:42:52.798	debug	check IsLater : 05:24 07:15
          shuttercontrol.0
          2022-05-11 14:42:52.788	debug	Shutdown shutters Sunset area: 21:13
          shuttercontrol.0
          2022-05-11 14:42:52.788	debug	Starting up shutters Sunrise area: 05:24
          shuttercontrol.0
          2022-05-11 14:42:52.788	debug	Shutdown shutters GoldenHour area: 20:25
          shuttercontrol.0
          2022-05-11 14:42:52.788	debug	Starting up shutters GoldenHour area: 06:12
          shuttercontrol.0
          2022-05-11 14:42:52.787	debug	Sunset today: 20:43
          shuttercontrol.0
          2022-05-11 14:42:52.787	debug	Sunrise today: 05:24
          shuttercontrol.0
          2022-05-11 14:42:52.787	debug	current day: 3
          shuttercontrol.0
          2022-05-11 14:42:52.787	debug	goldenHour today: 19:55
          shuttercontrol.0
          2022-05-11 14:42:52.787	debug	goldenHourEnd today: 06:12
          shuttercontrol.0
          2022-05-11 14:42:52.786	debug	calculate astrodata ...
          shuttercontrol.0
          2022-05-11 14:42:52.785	debug	Travel times of the shutters are calculated
          shuttercontrol.0
          2022-05-11 14:42:50.019	debug	Rollladen_Bad_LEVEL: save settings
          shuttercontrol.0
          2022-05-11 14:42:49.919	debug	Rollladen_Natalie_klein_LEVEL: save settings
          shuttercontrol.0
          2022-05-11 14:42:49.817	debug	Rollladen_Natalie_LEVEL: save settings
          shuttercontrol.0
          2022-05-11 14:42:49.717	debug	Rolladen_Emilia_LEVEL: save settings
          shuttercontrol.0
          2022-05-11 14:42:49.617	debug	Rollladen_Küche_Links_LEVEL: save settings
          shuttercontrol.0
          2022-05-11 14:42:49.515	debug	Rollladen_Küche_Rechts_LEVEL: save settings
          shuttercontrol.0
          2022-05-11 14:42:49.414	debug	Rollladen_Terrassentür_LEVEL: save settings
          shuttercontrol.0
          2022-05-11 14:42:49.313	debug	Rollladen_Ecke_Links_LEVEL: save settings
          shuttercontrol.0
          2022-05-11 14:42:49.212	debug	Rollladen_Ecke_Rechts_LEVEL: save settings
          shuttercontrol.0
          2022-05-11 14:42:49.110	debug	Rollladen_Arbeitszimmer_LEVEL: save settings
          shuttercontrol.0
          2022-05-11 14:42:49.089	debug	Shutter State: hm-rpc.0.OEQ1857255.1.LEVEL
          shuttercontrol.0
          2022-05-11 14:42:49.088	debug	Shutter State: hm-rpc.0.OEQ1299329.1.LEVEL
          shuttercontrol.0
          2022-05-11 14:42:49.088	debug	Shutter State: hm-rpc.0.OEQ1299312.1.LEVEL
          shuttercontrol.0
          2022-05-11 14:42:49.088	debug	Shutter State: hm-rpc.0.OEQ1299321.1.LEVEL
          shuttercontrol.0
          2022-05-11 14:42:49.088	debug	Shutter State: hm-rpc.0.OEQ1300082.1.LEVEL
          shuttercontrol.0
          2022-05-11 14:42:49.088	debug	Shutter State: hm-rpc.0.OEQ1302808.1.LEVEL
          shuttercontrol.0
          2022-05-11 14:42:49.087	debug	Shutter State: hm-rpc.0.OEQ1302889.1.LEVEL
          shuttercontrol.0
          2022-05-11 14:42:49.087	debug	Shutter State: hm-rpc.0.OEQ1302897.1.LEVEL
          shuttercontrol.0
          2022-05-11 14:42:49.087	debug	Shutter State: hm-rpc.0.OEQ1858638.1.LEVEL
          shuttercontrol.0
          2022-05-11 14:42:49.087	debug	Shutter State: hm-rpc.0.OEQ1299293.1.LEVEL
          shuttercontrol.0
          2022-05-11 14:42:49.086	debug	trigger for outside temperature: hm-rpc.2.000EDD89AEC34D.1.ACTUAL_TEMPERATURE
          shuttercontrol.0
          2022-05-11 14:42:49.086	debug	trigger for inside temperature: zigbee.0.00158d000273ce6b.temperature
          shuttercontrol.0
          2022-05-11 14:42:49.086	debug	trigger for inside temperature: zigbee.0.00158d0002321724.temperature
          shuttercontrol.0
          2022-05-11 14:42:49.085	debug	trigger for inside temperature: zigbee.0.00158d000249074a.temperature
          shuttercontrol.0
          2022-05-11 14:42:49.085	debug	trigger for inside temperature: zigbee.0.00158d0002288653.temperature
          shuttercontrol.0
          2022-05-11 14:42:49.085	debug	trigger for inside temperature: zigbee.0.00158d000247d478.temperature
          shuttercontrol.0
          2022-05-11 14:42:49.084	debug	trigger for shuttercontrol: zigbee.0.00158d0001d8715b.opened
          shuttercontrol.0
          2022-05-11 14:42:49.084	debug	trigger for shuttercontrol: zigbee.0.00158d000236fedd.opened
          shuttercontrol.0
          2022-05-11 14:42:49.084	debug	trigger for shuttercontrol: zigbee.0.00158d000232cc9b.opened
          shuttercontrol.0
          2022-05-11 14:42:49.083	debug	trigger for shuttercontrol: hm-rpc.2.0007D8A99FC127.1.STATE
          shuttercontrol.0
          2022-05-11 14:42:49.083	debug	trigger for shuttercontrol: zigbee.0.00158d000232a99f.opened
          shuttercontrol.0
          2022-05-11 14:42:49.081	debug	shutter Config Check successfully completed
          shuttercontrol.0
          2022-05-11 14:42:49.080	debug	shutter Config Check started
          shuttercontrol.0
          2022-05-11 14:42:49.047	info	starting. Version 1.4.12 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v14.17.5, js-controller: 4.0.23
          shuttercontrol.0
          2022-05-11 14:42:48.553	debug	Plugin sentry Initialize Plugin (enabled=true)
          shuttercontrol.0
          2022-05-11 14:42:43.696	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          shuttercontrol.0
          2022-05-11 14:42:43.696	debug	Plugin sentry destroyed
          shuttercontrol.0
          2022-05-11 14:42:43.695	info	terminating
          shuttercontrol.0
          2022-05-11 14:42:43.694	info	cleaned everything up...
          shuttercontrol.0
          2022-05-11 14:42:43.693	info	Got terminate signal TERMINATE_YOURSELF
          shuttercontrol.0
          2022-05-11 14:41:20.224	debug	insidetemperature changed: zigbee.0.00158d000273ce6b.temperature Value: 21.84
          shuttercontrol.0
          2022-05-11 14:40:00.022	debug	Sun Elevation: 51.8°
          shuttercontrol.0
          2022-05-11 14:40:00.021	debug	Sun Azimut: 219°
          shuttercontrol.0
          2022-05-11 14:40:00.018	debug	calculate astrodata ...
          shuttercontrol.0
          2022-05-11 14:39:55.371	debug	outsidetemperature changed: hm-rpc.2.000EDD89AEC34D.1.ACTUAL_TEMPERATURE Value: 32.1
          so sieht der Log aus...
          • simatec
            simatec Developer Most Active @BanditFG last edited by
            @banditfg Was hast du in den Sommer-Einstellungen für Zeiten konfiguriert?
            BanditFG 1 Reply Last reply Reply Quote 0
            • BanditFG
              BanditFG @simatec last edited by BanditFG
              @simatec
              könnte es eventuell damit zu tun haben das ich bei den einzelnen Rollos in den Haupteinstellungen Schlafbereich und NICHT Schlafbereich Automatik eingestellt habe?
              simatec 2 Replies Last reply Reply Quote 0
              • simatec
                @banditfg Deine Rollläden befinden sich alle im Manu_mode.
                Da fahren sie nicht in den Sonnenschutz
                • maduuto
                  maduuto @puppet1912 last edited by
                  @puppet1912 said in Test Adapter shuttercontrol v1.4.x:
                  @maduuto
                  Teste dein gewünschtes Verhalten bei der Heimkehr mal mit "OpenAll". Damit werden zwar erstmal alle Rolläden geöffnet, aber werden erstmal wieder "initialisiert" und sollten dann nach max. 5 Minuten auch in den Sonnenschutz fahren. Ein direktes Anfahren des Sonnenschutzes aus dem geschlossenen Zustand ist imho nicht möglich.
                  das funktioniert, wollten aber eigentlich unnötige Fahrten vermeiden. Manchmal funktioniert das komischerweise aber auch mit dem was ich gerade im Skript habe bzw in der Steuerung. kurios. Mich wundert nur, macht hier niemand die Rollläden bei Abwesenheit runter?
                    Homoran Global Moderator Administrators @maduuto last edited by
                    @maduuto sagte in Test Adapter shuttercontrol v1.4.x:
                    warum?
                    Bei Abwesenheit läuft alles so wie immer.
                    Soll doch unauffällig sein.
                    maduuto 1 Reply Last reply Reply Quote 3
                    • simatec
                      @banditfg Gerade nochmal Live getestet .. Mit identischen Einstellungen wie bei dir fahren die Rollläden in den Sonnenschutz.
                      Du solltest prüfen, warum deine Manu_Mode habe.
                      Ggfs. die Prüfung der Rollläden aktivieren und je nach Fahrtzeit die Zeit dafür anpassen
                      • maduuto
                        maduuto @Homoran last edited by
                        @homoran ich finde eher nach unten fahren, um den Einbruchsschutz zu erhöhen.
                          Homoran Global Moderator Administrators @maduuto last edited by Homoran
                          war mir klar!
                          Hat aber immer schon Einbrecher angelockt, wenn während des Urlaubs tagelang die Rollläden unten waren
                          solange du keine selbstverriegelnde Stahlrollladen hast, ist ein Rollladen kein wirkliches Hindernis.
                          simatec 1 Reply Last reply Reply Quote 1
                          • simatec
                            @homoran Bin da ganz deiner Meinung. Eine Automatisierung und das regelmäßige fahren schreckt da mehr ab.
                            Dann noch das Licht automatisieren und die Einbrecher trauen sich nicht ran … so die Theorie 😊
                            • BanditFG
                              @simatec
                              guten Morgen. danke das du dir Zeit nimmst mein Problem zu lösen.
                              mir war schon aufgefallen das die Rollos alle auf Manu_Mode stehen, im EG hab ich mir das so erklärt das die Rollos hoch fahren sobald jemand nach 7:00 das Wohnzimmer betritt, dann wird über ein Skript welches durch einen BWM ausgelöst wird der Button open Living betätigt. das habe ich gestern nachmittag deaktiviert.
                              wie bekomme ich die Rollos wieder aus dem Manu_Mode???
                              und verstehe ich das richtig, das jedes betätigen eines Rollladenschalters das jeweilige Rollo in den Manu_Mode versetzt?
                                Homoran Global Moderator Administrators @BanditFG last edited by
                                @banditfg sagte in Test Adapter shuttercontrol v1.4.x:
                                mit dem Button Auto all
                                ja! und auch durch "all up"
                                  bishop last edited by
                                  da nun wieder die Sommerzeit beginnt, wird auch wieder der Sonnenschutz benötigt 🙂
                                  Habe gleich mal eine Frage dazu!
                                  shuttercontrol.0
                                  	2022-05-12 13:37:33.156	info	Sunprotect #414 Set ID: Schlafzimmer value: 3%
                                  shuttercontrol.0
                                  	2022-05-12 13:37:31.153	info	Sunprotect #414 Set ID: Kim value: 3%
                                  shuttercontrol.0
                                  	2022-05-12 13:37:27.145	info	Sunprotect #414 Set ID: Balkon value: 5%
                                  fahren wie sie sollen in den Sonnenschutz, aber in den DP´s autoState steht "Manu_mode" somit fahren sie nicht mehr aus dem Sonnenschutz raus.
                                  Warum steht der DP auf "Manu_mode" und nicht "Sunprotect"?
                                  Homoran 1 Reply Last reply Reply Quote -1
                                    Homoran Global Moderator Administrators @bishop last edited by
                                    @bishop sagte in Test Adapter shuttercontrol v1.4.x:
                                    mal genau beobachten wann der manu mode eingeschaltet wird.
                                    wahrscheinlich ein paar Sekundn nach Start der Beschattung im sunprotect.
                                    hast du "später Zustand prüfen" o.ä. aktiv?
                                      bishop @Homoran last edited by
                                      ich werde es beobachten, "Rollladenstatus prüfen" habe ich mal auf 10sec jetzt eingestellt.
                                      heute sieht es nicht nach Sonnenschutz aus 🙂
                                      vielen Dank schon mal
                                        musst du schnelle Rollläden haben!
                                        meine brauchen deutlich länger für eine Fahrt.
                                          ok 25sec sollten besser sein
                                            bommel_030 last edited by bommel_030
                                            Kann mir jemand sagen was "none" als Wert des Datenpunktes unter autoState bedeutet?
                                            Ich habe 4 DFF die momentan im Adapter vorhanden sind, aber nur über close / open all oder über den Sonnenschutz fahren sollen. Initialisiere ich den Adapter mit "open"all" und "open all" steht im Auto state richtigerweise "up".
                                            Täglich um 2:30 wird dieser Wert aber auf "none" geändert und mich interessiert was und warum der Adapter da Nachts den State ändert.
                                            Nachtrag Log
                                            2022-03-31 02:30:00.002 - debug: shuttercontrol.0 (237256) calculate astrodata ...
                                            2022-03-31 02:30:00.002 - debug: shuttercontrol.0 (237256) Sun Azimut: 22.8°
                                            2022-03-31 02:30:00.002 - debug: shuttercontrol.0 (237256) Sun Elevation: -31.1°
                                            2022-03-31 02:30:00.005 - debug: shuttercontrol.0 (237256) Travel times of the shutters are calculated
                                            2022-03-31 02:30:00.005 - debug: shuttercontrol.0 (237256) calculate astrodata ...
                                            2022-03-31 02:30:00.005 - debug: shuttercontrol.0 (237256) goldenHourEnd today: 07:30
                                            2022-03-31 02:30:00.005 - debug: shuttercontrol.0 (237256) goldenHour today: 18:54
                                            2022-03-31 02:30:00.005 - debug: shuttercontrol.0 (237256) current day: 4
                                            2022-03-31 02:30:00.005 - debug: shuttercontrol.0 (237256) Sunrise today: 06:45
                                            2022-03-31 02:30:00.005 - debug: shuttercontrol.0 (237256) Sunset today: 19:39
                                            2022-03-31 02:30:00.005 - debug: shuttercontrol.0 (237256) Starting up shutters GoldenHour area: 07:00
                                            2022-03-31 02:30:00.005 - debug: shuttercontrol.0 (237256) Shutdown shutters GoldenHour area: 19:24
                                            2022-03-31 02:30:00.005 - debug: shuttercontrol.0 (237256) Starting up shutters Sunrise area: 06:15
                                            2022-03-31 02:30:00.005 - debug: shuttercontrol.0 (237256) Shutdown shutters Sunset area: 20:09
                                            2022-03-31 02:30:00.007 - debug: shuttercontrol.0 (237256) check IsLater : 06:15 06:30
                                            2022-03-31 02:30:00.010 - debug: shuttercontrol.0 (237256) check IsLater : 06:15 06:00
                                            2022-03-31 02:30:00.010 - debug: shuttercontrol.0 (237256) yes, IsLater : 06:15 06:00
                                            2022-03-31 02:30:00.010 - debug: shuttercontrol.0 (237256) check IsEarlier : 06:15 06:30
                                            2022-03-31 02:30:00.010 - debug: shuttercontrol.0 (237256) yes, IsEarlier : 06:15 06:30
                                            2022-03-31 02:30:00.010 - debug: shuttercontrol.0 (237256) Starting up shutters living area: 06:15 debug 5
                                            2022-03-31 02:30:00.010 - debug: shuttercontrol.0 (237256) check IsLater : 06:15 06:30
                                            2022-03-31 02:30:00.010 - debug: shuttercontrol.0 (237256) Starting up shutters sleep area: 06:15 debug 5
                                            2022-03-31 02:30:00.011 - debug: shuttercontrol.0 (237256) check IsLater : 06:15 06:00
                                            2022-03-31 02:30:00.011 - debug: shuttercontrol.0 (237256) yes, IsLater : 06:15 06:00
                                            2022-03-31 02:30:00.011 - debug: shuttercontrol.0 (237256) Starting up shutters children area: 06:00 debug 4
                                            2022-03-31 02:30:00.011 - debug: shuttercontrol.0 (237256) check IsLater : 20:09 22:00
                                            2022-03-31 02:30:00.011 - debug: shuttercontrol.0 (237256) check IsEarlier : 20:09 22:00
                                            2022-03-31 02:30:00.011 - debug: shuttercontrol.0 (237256) yes, IsEarlier : 20:09 22:00
                                            2022-03-31 02:30:00.011 - debug: shuttercontrol.0 (237256) Shutdown shutters living area: 20:09 debug 7
                                            2022-03-31 02:30:00.011 - debug: shuttercontrol.0 (237256) shutterDownLiving
                                            2022-03-31 02:30:00.012 - debug: shuttercontrol.0 (237256) Shutdown shutters children area: 20:09 debug 7
                                            2022-03-31 02:30:00.013 - debug: shuttercontrol.0 (237256) Shutdown shutters sleep area: 20:00 debug 6
                                            2022-03-31 02:30:00.013 - debug: shuttercontrol.0 (237256) late down at 22:05
                                            2022-03-31 02:30:00.014 - debug: shuttercontrol.0 (237256) complete down at 19:00
                                            2022-03-31 02:30:00.280 - debug: shuttercontrol.0 (237256) HWR set currentHeight to 0
                                            2022-03-31 02:30:00.299 - debug: shuttercontrol.0 (237256) HWR level conversion is disabled ...
                                            2022-03-31 02:30:00.302 - debug: shuttercontrol.0 (237256) WC set currentHeight to 0
                                            2022-03-31 02:30:00.303 - debug: shuttercontrol.0 (237256) WC level conversion is disabled ...
                                            2022-03-31 02:30:00.305 - debug: shuttercontrol.0 (237256) Bad Vorne set currentHeight to 0
                                            2022-03-31 02:30:00.307 - debug: shuttercontrol.0 (237256) Bad Vorne level conversion is disabled ...
                                            2022-03-31 02:30:00.309 - debug: shuttercontrol.0 (237256) Galerie rechts set currentHeight to 100
                                            2022-03-31 02:30:00.353 - debug: shuttercontrol.0 (237256) Galerie rechts level conversion is disabled ...
                                            2022-03-31 02:30:00.355 - debug: shuttercontrol.0 (237256) Galerie links set currentHeight to 100
                                            2022-03-31 02:30:00.357 - debug: shuttercontrol.0 (237256) Galerie links level conversion is disabled ...
                                            2022-03-31 02:30:00.359 - debug: shuttercontrol.0 (237256) Arbeit links set currentHeight to 100
                                            2022-03-31 02:30:00.361 - debug: shuttercontrol.0 (237256) Arbeit links level conversion is disabled ...
                                            2022-03-31 02:30:00.363 - debug: shuttercontrol.0 (237256) Arbeit rechts set currentHeight to 100
                                            2022-03-31 02:30:00.366 - debug: shuttercontrol.0 (237256) Arbeit rechts level conversion is disabled ...
                                            2022-03-31 02:30:00.409 - debug: shuttercontrol.0 (237256) Garderobe set currentHeight to 0
                                            2022-03-31 02:30:00.412 - debug: shuttercontrol.0 (237256) Garderobe level conversion is disabled ...
                                            2022-03-31 02:30:00.414 - debug: shuttercontrol.0 (237256) Kitchen Strasse set currentHeight to 0
                                            2022-03-31 02:30:00.417 - debug: shuttercontrol.0 (237256) Kitchen Strasse level conversion is disabled ...
                                            2022-03-31 02:30:00.419 - debug: shuttercontrol.0 (237256) Kitchen Seite set currentHeight to 0
                                            2022-03-31 02:30:00.421 - debug: shuttercontrol.0 (237256) Kitchen Seite level conversion is disabled ...
                                            2022-03-31 02:30:00.465 - debug: shuttercontrol.0 (237256) Wohnzimmer Garten set currentHeight to 0
                                            2022-03-31 02:30:00.467 - debug: shuttercontrol.0 (237256) Wohnzimmer Garten level conversion is disabled ...
                                            2022-03-31 02:30:00.470 - debug: shuttercontrol.0 (237256) Wohnzimmer Terasse set currentHeight to 0
                                            2022-03-31 02:30:00.472 - debug: shuttercontrol.0 (237256) Wohnzimmer Terasse level conversion is disabled ...
                                            2022-03-31 02:30:00.474 - debug: shuttercontrol.0 (237256) Essen Terasse set currentHeight to 0
                                            2022-03-31 02:30:00.476 - debug: shuttercontrol.0 (237256) Essen Terasse level conversion is disabled ...
                                            2022-03-31 02:30:00.521 - debug: shuttercontrol.0 (237256) Essen Seite set currentHeight to 0
                                            2022-03-31 02:30:00.523 - debug: shuttercontrol.0 (237256) Essen Seite level conversion is disabled ...
                                            2022-03-31 02:30:00.525 - debug: shuttercontrol.0 (237256) Schlafzimmer set currentHeight to 0
                                            2022-03-31 02:30:00.527 - debug: shuttercontrol.0 (237256) Schlafzimmer level conversion is disabled ...
                                            2022-03-31 02:30:00.528 - debug: shuttercontrol.0 (237256) Noah set currentHeight to 0
                                            2022-03-31 02:30:00.601 - debug: shuttercontrol.0 (237256) Noah level conversion is disabled ...
                                            2022-03-31 02:30:00.655 - debug: shuttercontrol.0 (237256) Joel set currentHeight to 0
                                            2022-03-31 02:30:00.720 - debug: shuttercontrol.0 (237256) Joel level conversion is disabled ...
                                            2022-03-31 02:30:00.722 - debug: shuttercontrol.0 (237256) Gastezimmer set currentHeight to 0
                                            2022-03-31 02:30:00.724 - debug: shuttercontrol.0 (237256) Gastezimmer level conversion is disabled ...
                                            Homoran F 2 Replies Last reply Reply Quote 0
                                            1.0k
                                            331
                                            7376
                                            10264308
