    4. js-controller 4.0.x jetzt für alle User im STABLE!
    • nukleuz
      nukleuz last edited by
      das Update des JS-Controllers hat auf dem Master super funktioniert.
      Beim Update des ersten Slaves kommt diese Meldung:
      pi@rpi3b-garten:~ $ iobroker upgrade self
      Update js-controller from @3.3.22 to @4.0.23
      NPM version: 6.14.16
      npm install iobroker.js-controller@4.0.23 --loglevel error --unsafe-perm --prefi        x "/opt/iobroker" (System call)
      In file included from ../../nan/nan.h:58,
                       from ../src/unix_dgram.cc:5:
      /home/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:793:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
             (node::addon_register_func) (regfunc),                          \
      /home/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
         NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
      ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
       NODE_MODULE(unix_dgram, Initialize)
      Ist das so OK?
      iobroker -v "sagt": 4.0.23
      Danke für Info...
        Thomas Braun Most Active @nukleuz last edited by
        @nukleuz sagte in js-controller 4.0.x jetzt für alle User im STABLE!:
        Ist das so OK?
        Ja.
        nukleuz 1 Reply Last reply Reply Quote 1
        • nukleuz
          nukleuz @Thomas Braun last edited by
          @thomas-braun THX 🙂
          • Negalein
            ich habe nun auch auf 4.0.23 upgedatet.
            Die Übersicht im Thread hab ich verloren. 😉
            Haben diese Meldungen was zu bedeuten?
            nega@ioBroker:~$ iob upgrade self
            npm install iobroker.js-controller@4.0.23 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
            In file included from ../../nan/nan.h:56,
            /home/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:793:43: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
              793 |       (node::addon_register_func) (regfunc),                          \
            /home/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:827:3: note: in expansion of macro 'NODE_MODULE_X'
              827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
            ../src/unix_dgram.cc:404:1: note: in expansion of macro 'NODE_MODULE'
              404 | NODE_MODULE(unix_dgram, Initialize)
            Server Objects 127.0.0.1:50326 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
            Server States 127.0.0.1:58060 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
            Server Objects 127.0.0.1:50326 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
            Server States 127.0.0.1:58062 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
            Server Objects 127.0.0.1:50326 Error from InMemDB: Error: Unknown LUA script load
            Server Objects 127.0.0.1:50326 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
            Could not migrate objects to corresponding sets: Error SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
            nega@ioBroker:~$ nega@ioBroker:~$ iob upgrade self
              crunchip Forum Testing Most Active last edited by crunchip
              @negalein sagte in js-controller 4.0.x jetzt für alle User im STABLE!:
              die Meldung steht im ersten Beitrag und da steht, alles ok😉
                Tomk81 @Thomas Braun last edited by Tomk81
                jetzt habe ich das update mehrmals versucht und es funktioniert leider nicht. nachdem das update abgelaufen ist (auch mit gemeldeten Fehlern) wird es garnicht mehr erkannt. Bin leider nur Anfänger der selten dazu kommt mit iobroker zu arbeiten. Deswegen brauche ich etwas hilfe von euch. Was muss ich euch zeigen damit ihr mir bei dem Update helfen könnt??
                Habe zurzeit den JS controller 2.2.10 und Node.js v12.21.0 drauf
                  Thomas Braun Most Active @Tomk81 last edited by Thomas Braun
                  @tomk81
                  sudo ln -s /usr/bin/node /usr/bin/nodejs
                  uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  iobroker update -i
                  Und die sind streng geheim?
                    @thomas-braun said in js-controller 4.0.x jetzt für alle User im STABLE!:
                    wie bekomme ich die für euch ersichtlich. drag and drop?
                      @tomk81
                      Aus der Konsole als Text per Copy & Paste. In </> CodeTags eingebettet.
                        @thomas-braun sorry bin zu dämlich. weis nicht wie du es meinst. Arbeite mit Putty und sobald ich die rechte Taste drücke, kopiert der nur. sorry ist echt peinlich
                          @tomk81
                          Text in der Konsole markieren und kopieren.
                          Dann das Icon </>
                          anklicken, Text dahin kopieren, wo code_text steht:
                          Führt dann so so einem gut lesbaren Text, der so ähnlich wie deine Konsole ausschaut.
                          code_text
                            @tomk81 sagte in js-controller 4.0.x jetzt für alle User im STABLE!:
                            Arbeite mit Putty
                            Ich nicht. Aber da mit puTTY recht viele arbeiten wird das wohl da auch möglich sein.
                              Update js-controller from @2.2.10 to @4.0.23
                              NPM version: 6.14.11
                               Objects 127.0.0.1:38520 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
                               States 127.0.0.1:33132 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
                               Objects 127.0.0.1:38520 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
                               Objects 127.0.0.1:38520 Error from InMemDB: Error: scan NOT SUPPORTED
                              /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
                                      throw e;
                              ReplyError: Error scan NOT SUPPORTED
                                  at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
                                  at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                              Emitted 'error' event on ScanStream instance at:
                                  at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
                                  at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
                                  at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
                                  at processTicksAndRejections (internal/process/task_queues.js:97:5) {
                                command: {
                                  args: [ '0', 'MATCH', 'cfg.o.system.host.*', 'COUNT', '250' ]
                              npm ERR! code ELIFECYCLE
                              npm ERR! errno 1
                              npm ERR! iobroker.js-controller@4.0.23 install: `node iobroker.js setup first`
                              npm ERR! Exit status 1
                              npm ERR!
                              npm ERR! Failed at the iobroker.js-controller@4.0.23 install script.
                              npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                              npm ERR!     /home/iobroker/.npm/_logs/2022-05-11T16_53_19_849Z-debug.log
                              host.raspberrypi Cannot install iobroker.js-controller@4.0.23: 1
                                Achdujeh...
                                Das verwendete Betriebssystem ist vermutlich ähnlich alt.
                                Könnte man vielleicht sagen, wenn man wüsste was auf:
                                zurückkommt.
                                Ich würde es aber vermutlich alles von Grundauf neuinstallieren. Ist einfacher und schneller als da so riesige Lücken zu überbrücken.
                                  & apt policy nodejs
                                  armv7l
                                  /usr/bin/nodejs
                                  /usr/bin/node
                                  /usr/bin/npm
                                  v12.21.0
                                  v12.21.0
                                  6.14.11
                                  pi
                                  /opt/iobroker
                                    @tomk81
                                    sudo apt update
                                      hab ich gemacht, und jetzt? Läuft leider noch nicht.
                                      lief vorhin erst wieder nach dem Befehl:
                                      sudo -H -u iobroker npm install iobroker.js-controller
                                      aber halt mit der alten Version
                                      sorry für die späte Antwort aber meine Frau und Kinder....
                                        Du sollst die Ausgaben posten.
                                          pi@raspberrypi:/opt/iobroker $ sudo apt update
                                          Get:1 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
                                          Hit:2 https://deb.nodesource.com/node_12.x buster InRelease
                                          Hit:3 https://www.pivccu.de/piVCCU stable InRelease
                                          Get:4 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
                                          E: Repository 'http://archive.raspberrypi.org/debian buster InRelease' changed its 'Suite' value from 'testing' to 'oldstable'
                                          N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
                                          Do you want to accept these changes and continue updating from this repository? [y/N] y
                                          Get:5 http://archive.raspberrypi.org/debian buster/main armhf Packages [393 kB]
                                          E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
                                          Get:6 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
                                          Get:7 http://raspbian.raspberrypi.org/raspbian buster/contrib armhf Packages [58.8 kB]
                                          Get:8 http://raspbian.raspberrypi.org/raspbian buster/non-free armhf Packages [104 kB]
                                          Fetched 13.6 MB in 26s (523 kB/s)
                                          Reading package lists... Done
                                          Building dependency tree
                                          132 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                            @tomk81
                                            Buster ist ja doch nicht so alt wie befürchtet.
                                            sudo apt full-upgrade
                                            sudo reboot
                                            Wenn das durch ist und der Server wieder auf die Beine gekommen ist bitte nochmal:
                                            501
                                            123409
