    4. js-controller 4.0.x jetzt für alle User im STABLE!
      Tomk81 @Thomas Braun last edited by
      @thomas-braun said in js-controller 4.0.x jetzt für alle User im STABLE!:
      sudo ln -s /usr/bin/node /usr/bin/nodejs
      & apt policy nodejs
      armv7l
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v12.21.0
      v12.21.0
      6.14.11
      pi
      /opt/iobroker
        Thomas Braun Most Active @Tomk81 last edited by
        @tomk81
        sudo apt update
          Tomk81 @Thomas Braun last edited by Tomk81
          hab ich gemacht, und jetzt? Läuft leider noch nicht.
          lief vorhin erst wieder nach dem Befehl:
          sudo -H -u iobroker npm install iobroker.js-controller
          aber halt mit der alten Version
          sorry für die späte Antwort aber meine Frau und Kinder....
            @tomk81 sagte in js-controller 4.0.x jetzt für alle User im STABLE!:
            Du sollst die Ausgaben posten.
              pi@raspberrypi:/opt/iobroker $ sudo apt update
              Get:1 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
              Hit:2 https://deb.nodesource.com/node_12.x buster InRelease
              Hit:3 https://www.pivccu.de/piVCCU stable InRelease
              Get:4 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
              E: Repository 'http://archive.raspberrypi.org/debian buster InRelease' changed its 'Suite' value from 'testing' to 'oldstable'
              N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
              Do you want to accept these changes and continue updating from this repository? [y/N] y
              Get:5 http://archive.raspberrypi.org/debian buster/main armhf Packages [393 kB]
              E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
              Get:6 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
              Get:7 http://raspbian.raspberrypi.org/raspbian buster/contrib armhf Packages [58.8 kB]
              Get:8 http://raspbian.raspberrypi.org/raspbian buster/non-free armhf Packages [104 kB]
              Fetched 13.6 MB in 26s (523 kB/s)
              Reading package lists... Done
              Building dependency tree
              132 packages can be upgraded. Run 'apt list --upgradable' to see them.
                @tomk81
                Buster ist ja doch nicht so alt wie befürchtet.
                sudo apt full-upgrade
                sudo reboot
                Wenn das durch ist und der Server wieder auf die Beine gekommen ist bitte nochmal:
                uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  @tomk81
                  Dann:
                  iobroker update
                  iobroker upgrade
                  iobroker stop
                  cd /opt/iobroker
                  iobroker start
                    @tomk81
                    Dann:
                    iobroker update
                    iobroker upgrade
                    iobroker stop
                    cd /opt/iobroker
                    iobroker start
                    bei iobroker update kommt direkt das hier
                    pi@raspberrypi:/opt/iobroker $ iobroker update
                    internal/modules/cjs/loader.js:818
                      throw err;
                    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
                        at Function.Module._load (internal/modules/cjs/loader.js:667:27)
                        at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
                        at internal/main/run_main_module.js:17:47 {
                      code: 'MODULE_NOT_FOUND',
                      requireStack: []
                      Dann lass das update erstmal aus und versuch es so.
                      iobroker stop
                      cd /opt/iobroker
                      iobroker start
                        iobroker start
                        hat leider immer noch nicht funktioniert.
                        es ist immer noch die JS-controller Version 2.2.10
                        und nu?
                        Die CCU Version hat der aber aktualisiert komischerweise
                        crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
                          crunchip Forum Testing Most Active @Tomk81 last edited by
                          @tomk81 denke erst auf die v 3.3 manuell springen und danach auf die v4
                            und nu?
                            Konsolenoutput zeigen.
                              und nu?
                              pi@raspberrypi:/opt/iobroker $ uname -m && which nodejs node npm && nodejs -v &&                                    node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt                                    update && apt policy nodejs
                              armv7l
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              v12.22.12
                              v12.22.12
                              6.14.16
                              pi
                              /opt/iobroker
                              Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                              Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                              Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
                              Hit:4 https://www.pivccu.de/piVCCU stable InRelease
                              All packages are up to date.
                              nodejs:
                                Installed: 12.22.12-deb-1nodesource1
                                Candidate: 12.22.12-deb-1nodesource1
                                Version table:
                               *** 12.22.12-deb-1nodesource1 500
                                      500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                                      100 /var/lib/dpkg/status
                                   10.24.0~dfsg-1~deb10u1 500
                              Thomas Braun T 2 Replies Last reply Reply Quote 0
                                @tomk81
                                Ich meinte von
                                cd /opt/iobroker
                                iobroker start
                                  Tomk81 @Tomk81 last edited by
                                  @tomk81 said in js-controller 4.0.x jetzt für alle User im STABLE!:
                                  und nu?
                                  armv7l
                                  /usr/bin/nodejs
                                  /usr/bin/node
                                  /usr/bin/npm
                                  v12.22.12
                                  v12.22.12
                                  6.14.16
                                  pi
                                  /opt/iobroker
                                  nodejs:
                                    Version table:
                                  war jetzt glaub ich das falsche. hab nochmal ein upgrade versucht und jetzt läuft es wieder ewig. sorry
                                    @tomk81
                                    Ich meinte von
                                    cd /opt/iobroker
                                    iobroker start
                                    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                                    > iobroker.js-controller@2.2.10 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                                    > node lib/preinstallCheck.js
                                    NPM version: 6.14.16
                                    > iobroker.js-controller@2.2.10 install /opt/iobroker/node_modules/iobroker.js-controller
                                    > node iobroker.js setup first
                                    The following notifications happened during sync:
                                    - Ignoring Directory "hm-rega" because officially not created as meta object. Please remove directory!
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/acme-v2/package.json'
                                    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/lie/package.json'
                                    + iobroker.js-controller@2.2.10
                                    updated 1 package in 29.975s
                                    111 packages are looking for funding
                                      run `npm fund` for details
                                    pi@raspberrypi:/opt/iobroker $ iobroker start
                                      Thomas Braun Most Active @Tomk81 last edited by Thomas Braun
                                      @tomk81
                                      npm ls --depth=0 | grep ERR
                                        pi@raspberrypi:/opt/iobroker $ npm ls --depth=0 | grep ERR
                                        npm ERR! missing: colors@^1.3.3, required by iobroker.inst@2.0.3
                                        npm ERR! missing: fs-extra@^7.0.1, required by iobroker.inst@2.0.3
                                        npm ERR! missing: iobroker@^2.0.3, required by iobroker.inst@2.0.3
                                        npm ERR! missing: iobroker.info@stable, required by iobroker.inst@2.0.3
                                        npm ERR! missing: semver@^5.6.0, required by iobroker.inst@2.0.3
                                        npm ERR! missing: yargs@^7.0.2, required by iobroker.inst@2.0.3
                                        npm ERR! extraneous: acme-v2 /opt/iobroker/node_modules/acme-v2
                                        npm ERR! error in /opt/iobroker/node_modules/acme-v2: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/acme-v2/package.json'
                                        npm ERR! extraneous: lie /opt/iobroker/node_modules/lie
                                        npm ERR! error in /opt/iobroker/node_modules/lie: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/lie/package.json'
                                        npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
                                          @tomk81
                                          Die Fehler müssten da eigentlich alle weg...
                                          Versuch mal
                                          cd /opt/iobroker
                                          sudo -H -u iobroker npm install iobroker.js-controller@4.0.23
                                            pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller@4.0.23
                                            > iobroker.js-controller@4.0.23 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                                            > iobroker.js-controller@4.0.23 install /opt/iobroker/node_modules/iobroker.js-controller
                                            /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
                                                    throw e;
                                            ReplyError: Error scan NOT SUPPORTED
                                                at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
                                                at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                                            Emitted 'error' event on ScanStream instance at:
                                                at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
                                                at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
                                                at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
                                                at processTicksAndRejections (internal/process/task_queues.js:97:5) {
                                              command: {
                                                args: [ '0', 'MATCH', 'cfg.o.system.host.*', 'COUNT', '250' ]
                                            npm ERR! code ELIFECYCLE
                                            npm ERR! errno 1
                                            npm ERR! iobroker.js-controller@4.0.23 install: `node iobroker.js setup first`
                                            npm ERR! Exit status 1
                                            npm ERR!
                                            npm ERR! Failed at the iobroker.js-controller@4.0.23 install script.
                                            npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                                            npm ERR!     /home/iobroker/.npm/_logs/2022-05-11T20_00_03_043Z-debug.log
                                            501
                                            123648
