    4. js-controller 4.0.x jetzt für alle User im STABLE!
      Tomk81 @Thomas Braun last edited by
      @thomas-braun said in js-controller 4.0.x jetzt für alle User im STABLE!:
      sudo -H -u iobroker npm install iobroker.js-controller@4.0.23
      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller@4.0.23
      > iobroker.js-controller@4.0.23 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/preinstallCheck.js
      NPM version: 6.14.16
      > iobroker.js-controller@4.0.23 install /opt/iobroker/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
              throw e;
      ReplyError: Error scan NOT SUPPORTED
          at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
          at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
      Emitted 'error' event on ScanStream instance at:
          at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
          at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
          at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
          at processTicksAndRejections (internal/process/task_queues.js:97:5) {
        command: {
          args: [ '0', 'MATCH', 'cfg.o.system.host.*', 'COUNT', '250' ]
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/acme-v2/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/lie/package.json'
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! iobroker.js-controller@4.0.23 install: `node iobroker.js setup first`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@4.0.23 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /home/iobroker/.npm/_logs/2022-05-11T20_00_03_043Z-debug.log
        Thomas Braun Most Active @Tomk81 last edited by
        @tomk81
        Ich würde vermuten, das hast mit dem Datenbanktypen zu tun.
        Was setzt du denn bisher ein?
        file/file oder irgendwas mit redis?
          @tomk81
          was meinst du damit?
          Entschuldige die blöden Fragen
            apollon77 last edited by
            Ok, ist das ein Single-Host System oder Multi Host?
            Bitte mal "iob setup custom" Ausgabe zeigen.
            Der Fehle roben kann an sich nur passieren wenn die "neue" DB Klassen gehen eine alte auf neue DB connecten. Das darf nicht passieren.
            Ist halt schon krass von 2.0 auf die 4.0 zu gehen ... wäre über die 3.x in über ein paar Schritte einfacher gewesen.
            T Thomas Braun 3 Replies Last reply Reply Quote 0
              Tomk81 @apollon77 last edited by Tomk81
              @apollon77 said in js-controller 4.0.x jetzt für alle User im STABLE!:
              iob setup custom
              internal/modules/cjs/loader.js:818
                throw err;
              Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                  at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
                  at Function.Module._load (internal/modules/cjs/loader.js:667:27)
                  at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
                  at internal/main/run_main_module.js:17:47 {
                code: 'MODULE_NOT_FOUND',
                requireStack: []
              Single Host
              wenn ich wüsste wie ich die 3 drauf bekomme, dann würde ich es machen. Wäre über jede Hilfe dankbar
                Thomas Braun Most Active @apollon77 last edited by
                @apollon77 sagte in js-controller 4.0.x jetzt für alle User im STABLE!:
                So oft ist das auch noch nicht vorgekommen. Hatte auch überlegt einen Zwischenschritt über 3.x einzulegen. Aber im Eröffnungspost steht, dass man auch von 2 auf 4 springen könnte.
                  apollon77 @Tomk81 last edited by
                  @tomk81 Naja er ist jetzt gerade "kaputt" ... Das müssen wir zuerst fixen. Na dann versuchen wirs mal klein.
                  versuchen wir die 3.1.6
                  am Ende ists der npm befehl mit iobroker.js-controller@3.1.6
                  Geht das?
                    Was muss ich tun dass es überhaupt läuft. nach dem letzten Befehl geht nichts mehr
                      apollon77 @Thomas Braun last edited by
                      @thomas-braun Ja technisch spricht an sich nichts dagegen ... mich wundert der Fehler auch ... wie gesagt sollte das nur passieren wenn irgendwo was läuft ... strange
                        Geht das?
                        pi@raspberrypi:/opt/iobroker $ /opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller@3.1.6
                        -bash: /opt/iobroker: Is a directory
                        geht leider garnicht
                          @tomk81 Ja schau mal was Du geschrieben hasdt ... hast zuviel kopiert ... durchatmen und langsam machen
                            pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller@3.1.6
                            > iobroker.js-controller@3.1.6 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                            > iobroker.js-controller@3.1.6 install /opt/iobroker/node_modules/iobroker.js-controller
                            Existing earlier generated certificate is invalid (too old, validity longer then 345 days or keylength too short).                                                      Generating new Certificate!
                            object system.certificates updated
                            > acme-v2@1.8.6 postinstall /opt/iobroker/node_modules/acme/node_modules/acme-v2
                            > node scripts/postinstall
                            Greenlock and ACME.js v3 are on the way!
                            Watch for updates at https://indiegogo.com/at/greenlock
                            > acme-v2@1.8.6 postinstall /opt/iobroker/node_modules/greenlock/node_modules/acme-v2
                            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch"                                                     :"any"} (current: {"os":"linux","arch":"arm"})
                            + iobroker.js-controller@3.1.6
                            added 45 packages from 82 contributors in 33.785s
                            114 packages are looking for funding
                              run `npm fund` for details
                              @tomk81 Ok, besser. Was sagt "iob status" und "iob setup custom" jetzt?
                                pi@raspberrypi:/opt/iobroker $ iob status
                                At least one iobroker host is running.
                                Objects type: file
                                States  type: file
                                  @tomk81 Warum läuft der????
                                  ps auxww|grep io
                                    ps auxww|grep io
                                    hätte ich den vorher stoppen müssen?
                                    Wie auch immer es jetzt passiert ist, ich hab jetzt die 4. Version drauf
                                    iob setup custom läuft noch
                                      ÄÄÄÄHHMMM ... ja najk lar solltest DU ihn vorher stoppen ...
                                      Und was heisst "iob custom läuft noch"?
                                        ps auxww|grep io
                                        oder muss ich hier etwas auswählen?
                                        Current configuration:
                                        - Objects database:
                                          - Type: file
                                          - Host/Unix Socket: 127.0.0.1
                                          - Port: 9001
                                        - States database:
                                          - Type: file
                                          - Port: 9000
                                        - Data Directory: ../../iobroker-data/
                                        Type of objects DB [(f)ile, (r)edis], default [file]:
                                          @tomk81 nein CTRL-C und abbrechen. wollte nur die Daten sehen.
                                          DU hast es ja selbst gesagt ... Dein ganzer Fehler war die Anleitungen von Thomas von oben nicht zu machen ... da war übert all ein "iob stop" VOR dem upgrade ...
                                          Dann hättre auch der 4er upgrade direkt funktioniert
                                            da oben hab ich es noch gemacht. jetzt zum schluss hab ich nicht mehr dran gedacht. hab jetzt auf jeden fall die neuste version drauf obwohl ich doch die 3er zum schluss versucht habe. muss ich jetzt noch was machen?
                                            apollon77 Thomas Braun 2 Replies Last reply Reply Quote 0
                                            501
                                            123836
