    4. Smartmeter: Instanz stürzt nach einer Zeit ab
      MatzeEscher @MatzeEscher last edited by
      @matzeescher said in Smartmeter: Instanz stürzt nach einer Zeit ab:
      @arteck
      Es ist wieder so weit. Die Instanz funktioniert nicht mehr.
      Hier mal die EInträge aus dem Log. Ich habe die Instanz mal auf Loglevel "Alles" gestellt:
      2022-05-13 09:17:41.133 - info: host.raspberrypi stopInstance system.adapter.smartmeter.1 (force=false, process=true)
      2022-05-13 09:17:41.197 - info: host.raspberrypi stopInstance system.adapter.smartmeter.1 send kill signal
      2022-05-13 09:17:41.874 - info: host.raspberrypi instance system.adapter.smartmeter.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-05-13 09:17:44.311 - info: host.raspberrypi instance system.adapter.smartmeter.1 started with pid 8296
      2022-05-13 09:17:48.805 - debug: smartmeter.1 (8296) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2022-05-13 09:17:48.931 - debug: smartmeter.1 (8296) Objects client ready ... initialize now
      2022-05-13 09:17:48.970 - debug: smartmeter.1 (8296) Objects create System PubSub Client
      2022-05-13 09:17:48.974 - debug: smartmeter.1 (8296) Objects create User PubSub Client
      2022-05-13 09:17:49.016 - debug: smartmeter.1 (8296) Objects client initialize lua scripts
      2022-05-13 09:17:49.034 - debug: smartmeter.1 (8296) Objects connected to redis: 127.0.0.1:9001
      2022-05-13 09:17:49.046 - silly: smartmeter.1 (8296) redis psubscribe cfg.o.system.user.*
      2022-05-13 09:17:49.069 - silly: smartmeter.1 (8296) redis psubscribe cfg.o.enum.*
      2022-05-13 09:17:49.084 - silly: smartmeter.1 (8296) objectDB connected
      2022-05-13 09:17:49.091 - debug: smartmeter.1 (8296) Redis States: Use Redis connection: 127.0.0.1:9000
      2022-05-13 09:17:49.112 - debug: smartmeter.1 (8296) States create System PubSub Client
      2022-05-13 09:17:49.115 - debug: smartmeter.1 (8296) States create User PubSub Client
      2022-05-13 09:17:49.136 - debug: smartmeter.1 (8296) States connected to redis: 127.0.0.1:9000
      2022-05-13 09:17:49.139 - silly: smartmeter.1 (8296) statesDB connected
      2022-05-13 09:17:49.212 - debug: smartmeter.1 (8296) Plugin sentry Initialize Plugin (enabled=true)
      2022-05-13 09:17:50.123 - info: smartmeter.1 (8296) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v12.22.5, js-controller: 4.0.23
      2022-05-13 09:17:50.223 - debug: smartmeter.1 (8296) SmartmeterObis options: {"debug":0,"protocol":"SmlProtocol","transport":"SerialResponseTransport","requestInterval":"3","anotherQueryDelay":"1000","transportSerialPort":"/dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_5405f62be38fec118435ad8043a0c072-if00-port0","transportSerialBaudrate":9600,"transportSerialDataBits":8,"transportSerialStopBits":1,"transportSerialParity":"none","transportSerialMessageTimeout":null,"protocolSmlIgnoreInvalidCRC":true}
      2022-05-13 09:17:50.269 - silly: smartmeter.1 (8296) States system redis pmessage system.adapter.smartmeter.1.logLevel/system.adapter.smartmeter.1.logLevel:{"val":"silly","ack":true,"ts":1652426270240,"q":0,"from":"system.adapter.smartmeter.1","lc":1652426270240}
      2022-05-13 09:17:50.317 - debug: smartmeter.1 (8296) connected set to false
      2022-05-13 09:19:50.256 - warn: smartmeter.1 (8296) No or too long answer from Serial Device after last request.
      2022-05-13 09:19:50.259 - debug: smartmeter.1 (8296) Error: No or too long answer from Serial Device after last request.
      Im iobroker Log steht weiterhin keine genauere Fehlermeldung drin, als diese hier, die ich bereits gepostet habe.
      Ich denke, aber dass es nicht am Smartmeter Adapter liegt, da ich auf Konsolen-Ebene auch nicht auf die Schnittstelle mit minicom zugreifen kann.
      Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @MatzeEscher last edited by
        @matzeescher sagte in Smartmeter: Instanz stürzt nach einer Zeit ab:
        Nein, die Meldungen kommen vom Kernel. Also eher Hardwarenah.
          Homoran Global Moderator Administrators @MatzeEscher last edited by
          der Zugang wird ja auch gesperrt sein, wenn der Adapter (noch) auf die Schnittstelle zugreift.
          Da kann (und darf) immer nur eine Verbindung existieren.
            MatzeEscher @Homoran last edited by
            Leider gibt es auch keine Möglichkeit auf die Schnittstelle zuzugreifen, wenn ich die Instanz im iobroker stoppe.
              schade, ich hatte deinen Post so verstanden, dass da jetzt etwas stünde
              als diese hier,
              das geht leider erst los, als die Instanz bereits abgeschossen war
                damit ist die Verbindung zur Schnittstelle nicht unbedingt beendet.
                  Auch nach einem iobroker stop bekommt man folgende Meldungen:
                  sudo minicom -D /dev/ttyUSB0 -b 9600 --displayhex --wrap
                  minicom: cannot open /dev/ttyUSB0: Cannot allocate memory
                    Passt zu den anderen Meldungen.
                      @matzeescher wieso sollte das einen eventuell nochh offenen Port schließen?
                        MatzeEscher @Thomas Braun last edited by
                        Also meinst du immer noch, dass es vermutlich an der Stromversorgung liegt?
                          @matzeescher
                          Ich vermute jedenfalls Trouble auf der Hardwareseite.
                            Also wenn ich den pi nun neu starte und dann die Smartmeter-Instanz läuft, dann kann ich minicom ausführen und minicom übernimmt die Schnittstelle und zeigt Daten an.
                            Also gehe ich davon aus, dass minicom eigentlich Daten liefen müsste, wenn alles richtig ist.
                              apollon77 @MatzeEscher last edited by
                              Könnte dann ein aktiver USB Hub was bringen?
                              Das wäre in jedem Fall mein erster Versuch!
                                Aber da dein minicom ja auch "probleme "hat wenn der Fehler auftritt wäre ich auch erstmal dabei "Systemseitig" zu suchen.
                                Versuch mal mit einem aktiven USB Hub ... oder ner "störkeren Stromversorgung" (aber denke aktiver Hub ist besser)
                                1469
