    4. Test Adapter Meteoalarm v2.0.x
      sigi234 Forum Testing Most Active @da_Woody last edited by
      @da_woody sagte in Test Adapter Meteoalarm v2.0.x:
      @sigi234 na das haste verschwiegen... 😉
      Jetzt kommt das schon wieder: V 2.0.10
      meteoalarm.5
      2021-12-28 20:54:05.320	error	Fehler: Error: Text data outside of root node.Line: 1Column: 1Char: 1
      meteoalarm.4
      2021-12-28 20:52:08.398	error	DB closed
      meteoalarm.4
      2021-12-28 20:52:08.398	error	Error: DB closed at Redis.sendCommand (C:\Program Files\iobroker\Home\node_modules\ioredis\built\redis\index.js:628:24) at Redis.get (C:\Program Files\iobroker\Home\node_modules\ioredis\built\commander.js:122:25) at StateRedisClient.setState (C:\Program Files\iobroker\Home\node_modules\@iobroker\db-states-redis\lib\states\statesInRedisClient.js:479:40) at Adapter.setState (C:\Program Files\iobroker\Home\node_modules\iobroker.js-controller\lib\adapter.js:6215:35)
      meteoalarm.4
      2021-12-28 20:52:08.388	error	unhandled promise rejection: DB closed
      meteoalarm.4
      2021-12-28 20:52:08.388	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      meteoalarm.4
      2021-12-28 20:52:07.749	error	Fehler: Error: Text data outside of root node.Line: 1Column: 1Char: 2
      meteoalarm.5
      2021-12-28 20:27:05.600	error	Fehler: Error: Text data outside of root node.Line: 1Column: 1Char: 1
      meteoalarm.4
      2021-12-28 20:26:05.370	error	Fehler: Error: Text data outside of root node.Line: 1Column: 1Char: 2
      meteoalarm.4
      2021-12-28 20:00:12.959	error	Fehler: Error: Text data outside of root node.Line: 1Column: 1Char: 2
      meteoalarm.5
      2021-12-28 20:00:12.233	error	Fehler: Error: Text data outside of root node.Line: 1Column: 1Char: 1
      jackblackson 1 Reply Last reply Reply Quote 0
      • jackblackson
        jackblackson @sigi234 last edited by
        @sigi234 Ok..seh da leider nichts im Sentry. Ist das nur einmal bei der Ausführung passiert, oder mehrmals?
          sigi234 Forum Testing Most Active @jackblackson last edited by sigi234
          @jackblackson sagte in Test Adapter Meteoalarm v2.0.x:
          Bei jeder Ausführung
          Habe kein Redis:
          meteoalarm.4
          • jackblackson
            @sigi234 Hast du Sentry aktiv, zumindest für diesen Adapter?
              Ja
              • jackblackson
                jackblackson last edited by jackblackson
                Für alle Anwender, die Alarme für die Schweiz laden möchten, die Version 2.1.0 ist in wenigen Stunden im Latest zu finden.
                Ich würde mich über ein Feedback freuen, wenn alles funktioniert.
                • jackblackson
                  jackblackson @da_Woody last edited by
                  @da_woody Es hat etwas gedauert, aber inzwischen gibt es (zumindest für Österreich) die Warnungen nicht mehr nur auf Bundesland, sondern feingliedriger - hilft dir vielleicht. Es ist auch grad eine Version im Latest (wird die nächsten Tage in die Stable kommen) -> 2.1.2 - die einen Fix beinhaltet, weil es Probleme mit dem Link gab.
                  • da_Woody
                    da_Woody @jackblackson last edited by da_Woody
                    @jackblackson oi! goil! schau ich mir an...
                    edith: hüstel... 351c6caa-95a5-4bbb-9784-abee0fdda94b-grafik.png hab aber nüscht vom l8est geupdatet...
                    verfeinerung ist da. allerdings doch noch grob. mal schauen. 👍
                    • jackblackson
                      @da_woody Ich glaub es sind nun die Bezirke - nicht perfekt, auch in Vorarlberg nicht, aber besser als vorher.
                      Wegen dem Update: wie meinst du das? im Stable ist noch die 2.1.1..
                      da_Woody Latzi 3 Replies Last reply Reply Quote 0
                      • da_Woody
                        das hab anscheinend ich missinterpretiert. hab geglaubt, die 2.1.2. ist frisch im latest. bin ja nur dort unterwegs.
                        hab jetzt mal für burgenland auf eisenstadt-umgebung eingestellt, sind 13 km von mir und für niederösterreich wr.neustadt(land) aud der richtung kommen dann auch meist unwetter zu uns rüber. mal schauen... 🙂
                        hoffe, daß die truppe das noch weiter runterbricht andererseits hab ich ja eh meine wetterstation im garten und auch forecast7 im iQontrol.
                        • da_Woody
                          @jackblackson boah, heut gehts wieder ab mit den meldungen... 😄
                          strahlender sonnenschein. ich hau mich in den pool! 😉
                          • Latzi
                            Latzi @jackblackson last edited by
                            @jackblackson
                            mit der 2.1.4 bekomme ich stündlich folgende Meldung:
                            2022-05-31 17:28:01.139 - info: meteoalarm.0 (326580) starting. Version 2.1.4 in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v14.19.3, js-controller: 4.0.23
                            2022-05-31 17:28:01.206 - warn: host.ioBroker-Server Objects 127.0.0.1:41944 Error from InMemDB: Error: Not exists
                            2022-05-31 17:28:01.871 - info: meteoalarm.0 (326580) Updated Weather Alarms for Oberösterreich -> 0 warning(s) found
                            2022-05-31 17:28:01.873 - info: meteoalarm.0 (326580) Terminated (NO_ERROR): Without reason
                            2022-05-31 17:28:01.877 - info: meteoalarm.0 (326580) Updated Weather Alarms for Oberösterreich -> 0 warning(s) found
                            2022-05-31 17:28:02.393 - info: host.ioBroker instance system.adapter.meteoalarm.0 terminated with code 0 (NO_ERROR)
                            stelle ich zurück auf 2.1.3 ist die Meldung weg. Hast du eine Idee woran das liegen könnte? Brauchst du noch zusätzliche Informationen?
                            Vielen Dank!
                            • jackblackson
                              jackblackson @Latzi last edited by
                              @latzi Hallo! Danke für die Info..das ist komisch. Könntest du es mir mal mit "Debug" laufen lassen, damit ich das komplette Protokoll sehe?
                              Latzi 1 Reply Last reply Reply Quote 0
                              • jackblackson
                                @da_woody Bin jetzt vermutlich zu spät dran, aber ich seh nur noch eine Warnung..entweder haben sie es behoben, oder es sind schon zwei davon hinfällig. Wäre spannend, ob alle Drei für die selbe Zeit gewesen wären.
                                da_Woody liv-in-sky 3 Replies Last reply Reply Quote 0
                                • Latzi
                                  Bitte sehr:
                                  2022-05-31 22:28:00.030 - info: host.ioBroker instance system.adapter.meteoalarm.0 started with pid 910529
                                  2022-05-31 22:28:00.509 - debug: meteoalarm.0 (910529) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                  2022-05-31 22:28:00.557 - debug: meteoalarm.0 (910529) Objects client ready ... initialize now
                                  2022-05-31 22:28:00.558 - debug: meteoalarm.0 (910529) Objects create System PubSub Client
                                  2022-05-31 22:28:00.558 - debug: meteoalarm.0 (910529) Objects create User PubSub Client
                                  2022-05-31 22:28:00.624 - debug: meteoalarm.0 (910529) Objects client initialize lua scripts
                                  2022-05-31 22:28:00.626 - debug: meteoalarm.0 (910529) Objects connected to redis: 0.0.0.0:9001
                                  2022-05-31 22:28:00.655 - debug: meteoalarm.0 (910529) Redis States: Use Redis connection: 0.0.0.0:9000
                                  2022-05-31 22:28:00.679 - debug: meteoalarm.0 (910529) States create System PubSub Client
                                  2022-05-31 22:28:00.680 - debug: meteoalarm.0 (910529) States create User PubSub Client
                                  2022-05-31 22:28:00.721 - debug: meteoalarm.0 (910529) States connected to redis: 0.0.0.0:9000
                                  2022-05-31 22:28:00.909 - debug: meteoalarm.0 (910529) Plugin sentry Initialize Plugin (enabled=true)
                                  2022-05-31 22:28:01.142 - info: meteoalarm.0 (910529) starting. Version 2.1.4 in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v14.19.3, js-controller: 4.0.23
                                  2022-05-31 22:28:01.170 - debug: meteoalarm.0 (910529) Language: de
                                  2022-05-31 22:28:01.171 - debug: meteoalarm.0 (910529) Setup found: country AT and region AT007 - Oberösterreich
                                  2022-05-31 22:28:01.171 - debug: meteoalarm.0 (910529) Sentry aktiv - Breadcrumb gesetzt
                                  2022-05-31 22:28:01.172 - debug: meteoalarm.0 (910529) XML Language: de-DE
                                  2022-05-31 22:28:01.172 - debug: meteoalarm.0 (910529) 0: Delete Alarms
                                  2022-05-31 22:28:01.174 - debug: meteoalarm.0 (910529) Language: de
                                  2022-05-31 22:28:01.175 - debug: meteoalarm.0 (910529) Setup found: country AT and region AT007 - Oberösterreich
                                  2022-05-31 22:28:01.175 - debug: meteoalarm.0 (910529) Sentry aktiv - Breadcrumb gesetzt
                                  2022-05-31 22:28:01.175 - debug: meteoalarm.0 (910529) XML Language: de-DE
                                  2022-05-31 22:28:01.175 - debug: meteoalarm.0 (910529) 0: Delete Alarms
                                  2022-05-31 22:28:01.236 - warn: host.ioBroker-Server Objects 127.0.0.1:33394 Error from InMemDB: Error: Not exists
                                  2022-05-31 22:28:01.301 - debug: meteoalarm.0 (910529) 1: Parsed CSV File
                                  2022-05-31 22:28:01.301 - debug: meteoalarm.0 (910529) 2: Request Atom from https://feeds.meteoalarm.org/feeds/meteoalarm-legacy-atom-austria
                                  2022-05-31 22:28:01.414 - debug: meteoalarm.0 (910529) 1: Parsed CSV File
                                  2022-05-31 22:28:01.414 - debug: meteoalarm.0 (910529) 2: Request Atom from https://feeds.meteoalarm.org/feeds/meteoalarm-legacy-atom-austria
                                  2022-05-31 22:28:01.613 - debug: meteoalarm.0 (910529) 3: Received Atom
                                  2022-05-31 22:28:01.714 - debug: meteoalarm.0 (910529) 4: Process Atom
                                  2022-05-31 22:28:01.715 - debug: meteoalarm.0 (910529) 4.1.1: Check Entries
                                  2022-05-31 22:28:01.726 - debug: meteoalarm.0 (910529) 4.2: Checked relevance, found 0 relevant alarms
                                  2022-05-31 22:28:01.726 - debug: meteoalarm.0 (910529) 5: Processed Atom
                                  2022-05-31 22:28:01.727 - debug: meteoalarm.0 (910529) 5.1 Found 0 URLs
                                  2022-05-31 22:28:01.727 - debug: meteoalarm.0 (910529) 10: Creating HTML Widget
                                  2022-05-31 22:28:01.751 - debug: meteoalarm.0 (910529) 11: Set State for Widget
                                  2022-05-31 22:28:01.751 - debug: meteoalarm.0 (910529) 12: All Done
                                  2022-05-31 22:28:01.751 - info: meteoalarm.0 (910529) Updated Weather Alarms for Oberösterreich -> 0 warning(s) found
                                  2022-05-31 22:28:01.752 - debug: meteoalarm.0 (910529) Plugin sentry destroyed
                                  2022-05-31 22:28:01.752 - info: meteoalarm.0 (910529) Terminated (NO_ERROR): Without reason
                                  2022-05-31 22:28:01.872 - debug: meteoalarm.0 (910529) 3: Received Atom
                                  2022-05-31 22:28:01.989 - debug: meteoalarm.0 (910529) 4: Process Atom
                                  2022-05-31 22:28:01.989 - debug: meteoalarm.0 (910529) 4.1.1: Check Entries
                                  2022-05-31 22:28:01.996 - debug: meteoalarm.0 (910529) 4.2: Checked relevance, found 0 relevant alarms
                                  2022-05-31 22:28:02.019 - debug: meteoalarm.0 (910529) 5: Processed Atom
                                  2022-05-31 22:28:02.019 - debug: meteoalarm.0 (910529) 5.1 Found 0 URLs
                                  2022-05-31 22:28:02.019 - debug: meteoalarm.0 (910529) 10: Creating HTML Widget
                                  2022-05-31 22:28:02.083 - debug: meteoalarm.0 (910529) 11: Set State for Widget
                                  2022-05-31 22:28:02.083 - debug: meteoalarm.0 (910529) 12: All Done
                                  2022-05-31 22:28:02.083 - info: meteoalarm.0 (910529) Updated Weather Alarms for Oberösterreich -> 0 warning(s) found
                                  2022-05-31 22:28:02.267 - info: host.ioBroker instance system.adapter.meteoalarm.0 terminated with code 0 (NO_ERROR)
                                  • da_Woody
                                    @jackblackson jau, 2 l8... 😄 heute keine warnungen.
                                    das witzige, da waren keine zeiten dabei. aber im burgenland zufällig gesehn, daß eine der 3 warnungen für eisenstadt-umgebung verschwand und ca. 3 min später wieder angezeigt wurde.
                                    liegt ja nicht am adapter, wollts nur vermelden... 😉
                                    • da_Woody
                                      @jackblackson es ist wieder soweit!
                                      hab jetzt aus den objekten htmlToday rauskopiert.
                                      <table style="border-collapse: collapse; width: 100%;"><tbody><tr><td style="width: 1%; border-style: none; "></td><td style="width: 9%; border-style: none; "><img style="display:block;" width="35" height="35" alt="Warningimmage" src="/meteoalarm.admin/icons/white/t3.png"/></td><td style="width: 90%; border-style: none; "><h4 style = "margin-top: 5px;margin-bottom: 1px;">Gewitterwarnung: Heute 16:00 - Morgen 03:00</h4>Gewitter mit Sturmböen sind zu erwarten.</td></tr><tr><td style="width: 1%; border-style: none; "></td><td style="width: 9%; border-style: none; "><img style="display:block;" width="35" height="35" alt="Warningimmage" src="/meteoalarm.admin/icons/white/t3.png"/></td><td style="width: 90%; border-style: none; "><h4 style = "margin-top: 5px;margin-bottom: 1px;">Gewitterwarnung: Heute 16:00 - Morgen 03:00</h4>Gewitter mit Sturmböen sind zu erwarten.</td></tr><tr><td style="width: 1%; border-style: none; "></td><td style="width: 9%; border-style: none; "><img style="display:block;"</td><td style="width: 90%; border-style: none; "></td></tr></tbody></table>
                                      2x die selbe warnung. warum allerdings die zeit nicht mehr angezeigt wird...
                                      oha, beim testen auf einer testseite bin ich auf was draufgekommen. muss aber mit meinen einstellungen in iQontrol zu tun haben. hab jetzt mal screentogif mitlaufen lassen. kurzzeitig (ein aufblitzen) wird die zeit angezeigt.
                                      a4468160-711a-4c72-bf7d-a74527a9f6c1-grafik.png 934199f2-f767-4c52-99f9-75a2022cc28c-grafik.png a413fa1f-ae05-4dc0-a157-14b4aa370bb2-grafik.png
                                      um dann ausgeblendet zu werden...
                                      so, das auch hinbekommen! 😄
                                      inzwischen sinds 3 warnungen. 🤡 alle mit selber zeit.
                                        liv-in-sky @jackblackson last edited by
                                        @jackblackson
                                        ich habe diese meldung bzw. warning auch
                                        zeile 25-26
                                        meteoalarm.0
                                        2022-06-01 16:41:03.596	debug	4.2: Checked relevance, found 0 relevant alarms
                                        meteoalarm.0
                                        2022-06-01 16:41:03.544	debug	4.1.1: Check Entries
                                        meteoalarm.0
                                        2022-06-01 16:41:03.541	debug	4: Process Atom
                                        meteoalarm.0
                                        2022-06-01 16:41:03.089	debug	3: Received Atom
                                        meteoalarm.0
                                        2022-06-01 16:41:02.592	debug	2: Request Atom from https://feeds.meteoalarm.org/feeds/meteoalarm-legacy-atom-germany
                                        meteoalarm.0
                                        2022-06-01 16:41:02.592	debug	1: Parsed CSV File
                                        meteoalarm.0
                                        2022-06-01 16:41:02.453	debug	2: Request Atom from https://feeds.meteoalarm.org/feeds/meteoalarm-legacy-atom-germany
                                        meteoalarm.0
                                        2022-06-01 16:41:02.453	debug	1: Parsed CSV File
                                        host.iobroker59
                                        2022-06-01 16:41:02.317	warn	host.iobroker59-Server Objects 127.0.0.1:52978 Error from InMemDB: Error: Not exists
                                        meteoalarm.0
                                        2022-06-01 16:41:02.210	debug	0: Delete Alarms
                                        meteoalarm.0
                                        2022-06-01 16:41:02.210	debug	XML Language: de-DE
                                        meteoalarm.0
                                        2022-06-01 16:41:02.209	debug	Sentry aktiv - Breadcrumb gesetzt
                                        meteoalarm.0
                                        2022-06-01 16:41:02.209	debug	Setup found: country DE and region DE374 - Kreis Freising
                                        meteoalarm.0
                                        2022-06-01 16:41:02.208	debug	Language: de
                                        meteoalarm.0
                                        2022-06-01 16:41:02.194	debug	0: Delete Alarms
                                        meteoalarm.0
                                        2022-06-01 16:41:02.193	debug	XML Language: de-DE
                                        meteoalarm.0
                                        2022-06-01 16:41:02.192	debug	Sentry aktiv - Breadcrumb gesetzt
                                        meteoalarm.0
                                        2022-06-01 16:41:02.192	debug	Setup found: country DE and region DE374 - Kreis Freising
                                        meteoalarm.0
                                        2022-06-01 16:41:02.190	debug	Language: de
                                        meteoalarm.0
                                        2022-06-01 16:41:02.137	info	starting. Version 2.1.4 in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v14.19.0, js-controller: 4.0.23
                                        meteoalarm.0
                                        2022-06-01 16:41:01.714	debug	Plugin sentry Initialize Plugin (enabled=true)
                                        • da_Woody
                                          @jackblackson 😵 heute geht wirklich die post ab! da gehn sogar die icons aus... 😄
                                          <table style="border-collapse: collapse; width: 100%;"><tbody><tr><td style="width: 1%; border-style: none; "></td><td style="width: 9%; border-style: none; "><img style="display:block;" width="35" height="35" alt="Warningimmage" src="/meteoalarm.admin/icons/white/t5.png"/></td><td style="width: 90%; border-style: none; "><h4 style = "margin-top: 5px;margin-bottom: 1px;">Hitzewarnung: Morgen 00:00 - 23:59</h4>Es ist mit erhöhter Hitzebelastung zu rechnen.</td></tr><tr><td style="width: 1%; border-style: none; "></td><td style="width: 9%; border-style: none; "><img style="display:block;" width="35" height="35" alt="Warningimmage" src="/meteoalarm.admin/icons/white/t5.png"/></td><td style="width: 90%; border-style: none; "><h4 style = "margin-top: 5px;margin-bottom: 1px;">Hitzewarnung: Morgen 00:00 - 23:59</h4>Es ist mit erhöhter Hitzebelastung zu rechnen.</td></tr><tr><td style="width: 1%; border-style: none; "></td><td style="width: 9%; border-style: none; "><img style="display:block;" width="35" height="35" alt="Warningimmage" src="/meteoalarm.admin/icons/white/t5.png"/></td><td style="width: 90%; border-style: none; "><h4 style = "margin-top: 5px;margin-bottom: 1px;">Hitzewarnung: Morgen 00:00 - 23:59</h4>Es ist mit erhöhter Hitzebelastung zu rechnen.</td></tr><tr><td style="width: 1%; border-style: none; "></td><td style="width: 9%; border-style: none; "><img style="display:block;" width="35" height="35" alt="Warningimmage" src="/meteoalarm.admin/icons/white/t5.png"/></td><td style="width: 90%; border-style: none; "><h4 style = "margin-top: 5px;margin-bottom: 1px;">Hitzewarnung: Morgen 00:00 - 23:59</h4>Es ist mit erhöhter Hitzebelastung zu rechnen.</td></tr><tr><td style="width: 1%; border-style: none; "></td><td style="width: 9%; border-style: none; "><img style="display:block;"</td><td style="width: 90%; border-style: none; "><h4 style = "margin-top: 5px;margin-bottom: 1px;">Hitzewarnung: Morgen 00:00 - 23:59</h4>Es ist mit erhöhter Hitzebelastung zu rechnen.</td></tr></tbody></table>
                                          <table style="border-collapse: collapse; width: 100%;"><tbody><tr><td style="width: 1%; border-style: none; "></td><td style="width: 9%; border-style: none; "><img style="display:block;" width="35" height="35" alt="Warningimmage" src="/meteoalarm.admin/icons/white/t3.png"/></td><td style="width: 90%; border-style: none; "><h4 style = "margin-top: 5px;margin-bottom: 1px;">Gewitterwarnung: Heute 18:00 - Morgen 00:00</h4>Gewitter mit Sturmböen sind zu erwarten.</td></tr><tr><td style="width: 1%; border-style: none; "></td><td style="width: 9%; border-style: none; "><img style="display:block;" width="35" height="35" alt="Warningimmage" src="/meteoalarm.admin/icons/white/t3.png"/></td><td style="width: 90%; border-style: none; "><h4 style = "margin-top: 5px;margin-bottom: 1px;">Gewitterwarnung: Heute 18:00 - Morgen 00:00</h4>Gewitter mit Sturmböen sind zu erwarten.</td></tr><tr><td style="width: 1%; border-style: none; "></td><td style="width: 9%; border-style: none; "><img style="display:block;" width="35" height="35" alt="Warningimmage" src="/meteoalarm.admin/icons/white/t3.png"/></td><td style="width: 90%; border-style: none; "><h4 style = "margin-top: 5px;margin-bottom: 1px;">Gewitterwarnung: Heute 18:00 - Morgen 00:00</h4>Gewitter mit Sturmböen sind zu erwarten.</td></tr><tr><td style="width: 1%; border-style: none; "></td><td style="width: 9%; border-style: none; "><img style="display:block;" width="35" height="35" alt="Warningimmage" src="/meteoalarm.admin/icons/white/t3.png"/></td><td style="width: 90%; border-style: none; "><h4 style = "margin-top: 5px;margin-bottom: 1px;">Gewitterwarnung: Heute 18:00 - Morgen 00:00</h4>Gewitter mit Sturmböen sind zu erwarten.</td></tr><tr><td style="width: 1%; border-style: none; "></td><td style="width: 9%; border-style: none; "><img style="display:block;" width="35" height="35" alt="Warningimmage" src="/meteoalarm.admin/icons/white/t5.png"/></td><td style="width: 90%; border-style: none; "><h4 style = "margin-top: 5px;margin-bottom: 1px;">Hitzewarnung: Morgen 00:00 - 23:59</h4>Es ist mit erhöhter Hitzebelastung zu rechnen.</td></tr><tr><td style="width: 1%; border-style: none; "></td><td style="width: 9%; border-style: none; "><img style="display:block;" width="35" height="35" alt="Warningimmage" src="/meteoalarm.admin/icons/white/t5.png"/></td><td style="width: 90%; border-style: none; "><h4 style = "margin-top: 5px;margin-bottom: 1px;">Hitzewarnung: Morgen 00:00 - 23:59</h4>Es ist mit erhöhter Hitzebelastung zu rechnen.</td></tr><tr><td style="width: 1%; border-style: none; "></td><td style="width: 9%; border-style: none; "><img style="display:block;"</td><td style="width: 90%; border-style: none; "><h4 style = "margin-top: 5px;margin-bottom: 1px;">Hitzewarnung: Morgen 00:00 - 23:59</h4>Es ist mit erhöhter Hitzebelastung zu rechnen.</td></tr></tbody></table>
                                          oder im klartext
                                          36f820f1-57ec-4ddd-9813-cdf157e21cc0-grafik.png b974d149-5295-4fcc-a252-3e28bcbc7a52-grafik.png
                                          • jackblackson
                                            @da_woody Wild...ich bin momentan unterwegs, aber werde versuchen, hier diese doppelten bzw. mehrfachen Einträge irgendwie rauszufiltern, so macht dass wirklich keinen Sinn
                                            412
                                            82185
