    4. ZigBee Adapter nach Stromausfall nicht mehr Grün
    • Glasfaser
      Glasfaser @Creaven last edited by
      @creaven sagte in ZigBee Adapter nach Stromausfall nicht mehr Grün:
      Node, Nodejs, npm aktualisiert (siehe Versionen in der Systembeschreibung)
      Node-Version: 16.15.0
      Nodejs-Version: 10.24.1
      NPM-Version: 8.5.5
      Das ist alles krumm ..... gehe auf Node/Nodejs 14 und NPM auf 6
        arteck Developer Most Active @Creaven last edited by arteck
        @creaven adapter LOG direkt nach dem start bitte.. und zieh die nodejs grade
        • Creaven
          @arteck
          Versionen sind nun gerade zogen:
          Node: 14.19.3
          Nodejs: 14.19.3
          npm: 6.14.17
          zigbee.0
          1956	2022-05-19 13:52:36.561	info	Installed Version: iobroker.zigbee@1.6.18
          zigbee.0
          1956	2022-05-19 13:52:36.520	error	Error herdsman start
          zigbee.0
          1956	2022-05-19 13:52:36.519	error	Failed to start Zigbee
          zigbee.0
          1956	2022-05-19 13:52:36.517	error	Starting zigbee-herdsman problem : "Unexpected token \u0000 in JSON at position 0"
          zigbee.0
          1956	2022-05-19 13:52:36.501	info	Starting Zigbee npm ...
          zigbee.0
          1956	2022-05-19 13:52:36.499	info	Try to reconnect. 1 attempts left
          zigbee.0
          1956	2022-05-19 13:52:30.886	error	getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
          zigbee.0
          1956	2022-05-19 13:52:26.737	info	Installed Version: iobroker.zigbee@1.6.18
          zigbee.0
          1956	2022-05-19 13:52:26.496	error	Error herdsman start
          zigbee.0
          1956	2022-05-19 13:52:26.495	error	Failed to start Zigbee
          zigbee.0
          1956	2022-05-19 13:52:26.494	error	Starting zigbee-herdsman problem : "Unexpected token \u0000 in JSON at position 0"
          zigbee.0
          1956	2022-05-19 13:52:26.349	info	Starting Zigbee npm ...
          zigbee.0
          1956	2022-05-19 13:52:26.238	info	starting. Version 1.6.18 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23
          zigbee.0
          1035	2022-05-19 13:52:19.533	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          zigbee.0
          1035	2022-05-19 13:52:19.531	info	terminating
          zigbee.0
          1035	2022-05-19 13:52:19.529	warn	Failed to stop zigbee during startup
          zigbee.0
          1035	2022-05-19 13:52:19.436	info	cleaned everything up...
          zigbee.0
          1035	2022-05-19 13:52:19.431	info	Got terminate signal TERMINATE_YOURSELF
          zigbee.0
          1035	2022-05-19 13:51:48.270	error	getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
          • Creaven
            Interessanterweise geht die LED auf dem Stick nun aus, obwohl das im Adapter nicht angekreuzt ist.
            • Creaven
              @arteck @Glasfaser Habt ihr noch eine Idee was ich testen kann?
                @creaven klar mülltonne auf.. stick rein. tonne zu
                ich würde ehh auf was anderes wechseln.. der wird dir immer Probleme bereiten
                installier bitte den adapter mal neu aus GIT..
                da scheint was in den konfigs nicht zu stimmen ..
                Creaven 1 Reply Last reply Reply Quote 0
                • Creaven
                  Creaven @arteck last edited by
                  @arteck : Deshalb habe ich extra zwei neue bestellt um die Hardware ausschließen zu können.
                  Welchen alternativen Stick würdest du mir empfehlen?
                    @creaven
                    die frage kommt 1 die Woche auf...
                    schau im Marktplatz nach..da sind welche ..
                    ansonsten.. der SONOFF Zigbee 3.0 USB Dongle Plus
                    wenn du warten kannst such bei ali nach ansonsten amazon. kostet aber direkt das doppelte
                    • Creaven
                      @arteck
                      Neuer Stick ist bestellt (Amazon 29,99€, Ali 22,90€...).
                      Den Adapter habe ich über Git neu installiert (Katze ausgewählt, Git, Zigbee und installieren lassen). Installation hat sehr lange gedauert. Anschließend neue Instanz hinzugefügt und es kommt die gleiche Fehlermeldung:
                      zigbee.0
                      22421	2022-05-20 11:00:15.459	info	Installed Version: ioBroker/ioBroker.zigbee
                      zigbee.0
                      22421	2022-05-20 11:00:15.436	error	Error herdsman start
                      zigbee.0
                      22421	2022-05-20 11:00:15.435	error	Failed to start Zigbee
                      zigbee.0
                      22421	2022-05-20 11:00:15.433	error	Starting zigbee-herdsman problem : "Unexpected token \u0000 in JSON at position 0"
                      zigbee.0
                      22421	2022-05-20 11:00:15.419	info	Starting Zigbee npm ...
                      zigbee.0
                      22421	2022-05-20 11:00:15.417	info	Try to reconnect. 1 attempts left
                      zigbee.0
                      22421	2022-05-20 11:00:05.662	info	Installed Version: ioBroker/ioBroker.zigbee
                      zigbee.0
                      22421	2022-05-20 11:00:05.412	error	Error herdsman start
                      zigbee.0
                      22421	2022-05-20 11:00:05.412	error	Failed to start Zigbee
                      zigbee.0
                      22421	2022-05-20 11:00:05.411	error	Starting zigbee-herdsman problem : "Unexpected token \u0000 in JSON at position 0"
                      zigbee.0
                      22421	2022-05-20 11:00:05.267	info	Starting Zigbee npm ...
                      zigbee.0
                      22421	2022-05-20 11:00:05.147	info	starting. Version 1.6.18 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23
                      zigbee.0
                      22356	2022-05-20 10:59:58.263	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      zigbee.0
                      22356	2022-05-20 10:59:58.262	info	terminating
                      zigbee.0
                      22356	2022-05-20 10:59:58.260	warn	Failed to stop zigbee during startup
                      zigbee.0
                      22356	2022-05-20 10:59:58.189	info	cleaned everything up...
                      zigbee.0
                      22356	2022-05-20 10:59:58.187	info	Got terminate signal TERMINATE_YOURSELF
                      zigbee.0
                      22356	2022-05-20 10:59:51.747	error	getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
                      zigbee.0
                      22356	2022-05-20 10:58:53.433	error	getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
                      zigbee.0
                      22356	2022-05-20 10:58:52.080	info	Installed Version: ioBroker/ioBroker.zigbee
                      zigbee.0
                      22356	2022-05-20 10:58:52.054	error	Error herdsman start
                      zigbee.0
                      22356	2022-05-20 10:58:52.053	error	Failed to start Zigbee
                      zigbee.0
                      22356	2022-05-20 10:58:52.050	error	Starting zigbee-herdsman problem : "Unexpected token \u0000 in JSON at position 0"
                      zigbee.0
                      22356	2022-05-20 10:58:52.036	info	Starting Zigbee npm ...
                      zigbee.0
                      22356	2022-05-20 10:58:52.034	info	Try to reconnect. 1 attempts left
                      zigbee.0
                      22356	2022-05-20 10:58:42.274	info	Installed Version: ioBroker/ioBroker.zigbee
                      zigbee.0
                      22356	2022-05-20 10:58:42.030	error	Error herdsman start
                      zigbee.0
                      22356	2022-05-20 10:58:42.030	error	Failed to start Zigbee
                      zigbee.0
                      22356	2022-05-20 10:58:42.029	error	Starting zigbee-herdsman problem : "Unexpected token \u0000 in JSON at position 0"
                      zigbee.0
                      22356	2022-05-20 10:58:41.903	info	Starting Zigbee npm ...
                      zigbee.0
                      22356	2022-05-20 10:58:41.567	error	Serial port not selected! Go to settings page.
                      zigbee.0
                      22356	2022-05-20 10:58:41.521	info	starting. Version 1.6.18 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23
                        Thomas Braun Most Active @Creaven last edited by
                        Was hast du denn da in den Einstellungen des Adapters stehen?
                        • Creaven
                          Creaven @Thomas Braun last edited by
                          Der Fehler kam da gerade kein Stick angeschlossen ist.
                          Normal nehme ich "ls -l /dev/serial/by-id" um den Port rauszufinden und wähle diesen dann in den Adaptereinstellungen aus.
                          • Creaven
                            @arteck Mit dem "SONOFF Zigbee 3.0 USB Dongle Plus" klappt es leider auch nicht.
                            Stick wird erkannt:
                            usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ae3fb13f0213ec11b31e21c7bd930c07-if00-port0 -> ../../ttyUSB0
                            Ich richte den Stick im Zigbee Interface ein:
                            Und es kommt erneut der selbe Fehler wie zuvor:
                            zigbee.0
                            2836	2022-05-23 15:30:02.997	info	Installed Version: ioBroker/ioBroker.zigbee
                            zigbee.0
                            2836	2022-05-23 15:30:02.971	error	Error herdsman start
                            zigbee.0
                            2836	2022-05-23 15:30:02.970	error	Failed to start Zigbee
                            zigbee.0
                            2836	2022-05-23 15:30:02.968	error	Starting zigbee-herdsman problem : "Unexpected token \u0000 in JSON at position 0"
                            zigbee.0
                            2836	2022-05-23 15:30:02.955	info	Starting Zigbee npm ...
                            zigbee.0
                            2836	2022-05-23 15:30:02.952	info	Try to reconnect. 1 attempts left
                            zigbee.0
                            2836	2022-05-23 15:29:53.170	info	Installed Version: ioBroker/ioBroker.zigbee
                            zigbee.0
                            2836	2022-05-23 15:29:52.947	error	Error herdsman start
                            zigbee.0
                            2836	2022-05-23 15:29:52.946	error	Failed to start Zigbee
                            zigbee.0
                            2836	2022-05-23 15:29:52.946	error	Starting zigbee-herdsman problem : "Unexpected token \u0000 in JSON at position 0"
                            zigbee.0
                            2836	2022-05-23 15:29:52.813	info	Starting Zigbee npm ...
                            zigbee.0
                            2836	2022-05-23 15:29:52.700	info	starting. Version 1.6.18 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23
                            zigbee.0
                            2819	2022-05-23 15:29:46.035	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            zigbee.0
                            2819	2022-05-23 15:29:46.033	info	terminating
                            zigbee.0
                            2819	2022-05-23 15:29:46.032	warn	Failed to stop zigbee during startup
                            zigbee.0
                            2819	2022-05-23 15:29:45.921	info	cleaned everything up...
                            zigbee.0
                            2819	2022-05-23 15:29:45.918	info	Got terminate signal TERMINATE_YOURSELF
                            zigbee.0
                            2819	2022-05-23 15:29:42.919	info	Installed Version: ioBroker/ioBroker.zigbee
                            zigbee.0
                            2819	2022-05-23 15:29:42.894	error	Error herdsman start
                            zigbee.0
                            2819	2022-05-23 15:29:42.893	error	Failed to start Zigbee
                            zigbee.0
                            2819	2022-05-23 15:29:42.890	error	Starting zigbee-herdsman problem : "Unexpected token \u0000 in JSON at position 0"
                            zigbee.0
                            2819	2022-05-23 15:29:42.877	info	Starting Zigbee npm ...
                            zigbee.0
                            2819	2022-05-23 15:29:42.875	info	Try to reconnect. 1 attempts left
                            zigbee.0
                            2819	2022-05-23 15:29:36.331	error	getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
                            zigbee.0
                            2819	2022-05-23 15:29:33.094	info	Installed Version: ioBroker/ioBroker.zigbee
                            zigbee.0
                            2819	2022-05-23 15:29:32.872	error	Error herdsman start
                            zigbee.0
                            2819	2022-05-23 15:29:32.871	error	Failed to start Zigbee
                            zigbee.0
                            2819	2022-05-23 15:29:32.870	error	Starting zigbee-herdsman problem : "Unexpected token \u0000 in JSON at position 0"
                            zigbee.0
                            2819	2022-05-23 15:29:32.746	info	Starting Zigbee npm ...
                            zigbee.0
                            2819	2022-05-23 15:29:32.632	info	starting. Version 1.6.18 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23
                            zigbee.0
                            2293	2022-05-23 15:29:25.966	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            zigbee.0
                            2293	2022-05-23 15:29:25.964	info	terminating
                            zigbee.0
                            2293	2022-05-23 15:29:25.963	warn	Failed to stop zigbee during startup
                            zigbee.0
                            2293	2022-05-23 15:29:25.846	info	cleaned everything up...
                            zigbee.0
                            2293	2022-05-23 15:29:25.843	info	Got terminate signal TERMINATE_YOURSELF
                            zigbee.0
                            2293	2022-05-23 15:29:16.126	error	getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
                            zigbee.0
                            2293	2022-05-23 15:29:05.651	error	getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
                            zigbee.0
                            2293	2022-05-23 15:19:32.303	info	Installed Version: ioBroker/ioBroker.zigbee
                            zigbee.0
                            2293	2022-05-23 15:19:32.240	error	Error herdsman start
                            zigbee.0
                            2293	2022-05-23 15:19:32.239	error	Failed to start Zigbee
                            zigbee.0
                            2293	2022-05-23 15:19:32.236	error	Starting zigbee-herdsman problem : "Unexpected token \u0000 in JSON at position 0"
                            zigbee.0
                            2293	2022-05-23 15:19:32.220	info	Starting Zigbee npm ...
                            zigbee.0
                            2293	2022-05-23 15:19:32.218	info	Try to reconnect. 1 attempts left
                            zigbee.0
                            2293	2022-05-23 15:19:26.042	error	getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
                            zigbee.0
                            2293	2022-05-23 15:19:22.435	info	Installed Version: ioBroker/ioBroker.zigbee
                            zigbee.0
                            2293	2022-05-23 15:19:22.214	error	Error herdsman start
                            zigbee.0
                            2293	2022-05-23 15:19:22.214	error	Failed to start Zigbee
                            zigbee.0
                            2293	2022-05-23 15:19:22.213	error	Starting zigbee-herdsman problem : "Unexpected token \u0000 in JSON at position 0"
                            zigbee.0
                            2293	2022-05-23 15:19:22.084	info	Starting Zigbee npm ...
                            zigbee.0
                            2293	2022-05-23 15:19:21.969	info	starting. Version 1.6.18 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23
                            zigbee.0
                            2232	2022-05-23 15:19:15.319	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            zigbee.0
                            2232	2022-05-23 15:19:15.317	info	terminating
                            zigbee.0
                            2232	2022-05-23 15:19:15.316	warn	Failed to stop zigbee during startup
                            zigbee.0
                            2232	2022-05-23 15:19:15.226	info	cleaned everything up...
                            zigbee.0
                            2232	2022-05-23 15:19:15.223	info	Got terminate signal TERMINATE_YOURSELF
                            zigbee.0
                            2232	2022-05-23 15:19:07.464	error	getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
                            zigbee.0
                            2232	2022-05-23 15:18:22.250	info	Installed Version: ioBroker/ioBroker.zigbee
                            zigbee.0
                            2232	2022-05-23 15:18:22.231	error	Error herdsman start
                            zigbee.0
                            2232	2022-05-23 15:18:22.230	error	Failed to start Zigbee
                            zigbee.0
                            2232	2022-05-23 15:18:22.229	error	Starting zigbee-herdsman problem : "Unexpected token \u0000 in JSON at position 0"
                            zigbee.0
                            2232	2022-05-23 15:18:22.223	info	Starting Zigbee npm ...
                            zigbee.0
                            2232	2022-05-23 15:18:22.222	info	Try to reconnect. 1 attempts left
                            zigbee.0
                            2232	2022-05-23 15:18:12.449	info	Installed Version: ioBroker/ioBroker.zigbee
                            zigbee.0
                            2232	2022-05-23 15:18:12.218	error	Error herdsman start
                            zigbee.0
                            2232	2022-05-23 15:18:12.218	error	Failed to start Zigbee
                            zigbee.0
                            2232	2022-05-23 15:18:12.217	error	Starting zigbee-herdsman problem : "Unexpected token \u0000 in JSON at position 0"
                            zigbee.0
                            2232	2022-05-23 15:18:12.073	info	Starting Zigbee npm ...
                            zigbee.0
                            2232	2022-05-23 15:18:11.954	info	starting. Version 1.6.18 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23
                            zigbee.0
                            974	2022-05-23 15:18:05.186	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            zigbee.0
                            974	2022-05-23 15:18:05.184	info	terminating
                            zigbee.0
                            974	2022-05-23 15:18:05.182	warn	Failed to stop zigbee during startup
                            zigbee.0
                            974	2022-05-23 15:18:05.079	info	cleaned everything up...
                            zigbee.0
                            974	2022-05-23 15:18:05.071	info	Got terminate signal TERMINATE_YOURSELF
                            Gibt es weitere Ideen?
                            • Asgothian
                              Asgothian Developer @Creaven last edited by
                              @creaven Du musst die shepherd.db und nvbackup.json Dateien im Verzeichnis /opt/iobroker/iobroker-data/zigbee_0 gegen welche aus dem an gleicher stelle liegenden Backup austauschen - die sind offensichtlich beim Stromausfall kaputt geschrieben worden.
                              A.
                              • Creaven
                                Creaven last edited by Creaven
                                @asgothian Danke für die Info. Ich habe im Ordner kein nvbackupo.json. Die shepherd.db existiert.
                                Reicht es wenn ich über den BackItUp Adapter ein Backup vor dem Stromausfall aufspiele? Wie geht es alternativ ohne den BackItUp Adapter? Die Backups sind ja gepackt und meine Kentnisse halten sich leider in Grenzen...
                                • Asgothian
                                  @creaven du kannst die gepackte shepherd.db via tar -xzf ./xxx entpacken, wobei an stelle von xxx der Dateiname der gepackten Datei stehen muss.
                                  A.
                                  • Creaven
                                    Creaven @Asgothian last edited by
                                    @asgothian
                                    Eine gepackte shepherd.db gibt es explizit nicht, sondern nur "backup_Datum". Ich habe folgendes in diesem Ordner:
                                    backup_2021_07_20-10_56_55.tar.gz  backup_2022_01_22-04_01_11.tar.gz
                                    backup_2021_07_20-11_25_40.tar.gz  backup_2022_01_23-04_01_09.tar.gz
                                    backup_2021_07_21-04_01_08.tar.gz  backup_2022_01_24-04_01_05.tar.gz
                                    backup_2021_07_22-04_01_06.tar.gz  backup_2022_01_25-04_01_16.tar.gz
                                    backup_2021_07_23-04_01_09.tar.gz  backup_2022_01_26-04_01_14.tar.gz
                                    backup_2021_07_24-04_01_07.tar.gz  backup_2022_01_27-04_01_08.tar.gz
                                    backup_2021_07_25-04_01_08.tar.gz  backup_2022_01_28-04_01_09.tar.gz
                                    backup_2021_07_26-04_01_08.tar.gz  backup_2022_01_29-04_01_15.tar.gz
                                    backup_2021_07_27-04_01_10.tar.gz  backup_2022_01_30-04_01_13.tar.gz
                                    backup_2021_07_28-04_01_15.tar.gz  backup_2022_01_31-04_01_18.tar.gz
                                    backup_2021_07_29-04_01_08.tar.gz  backup_2022_02_01-04_01_09.tar.gz
                                    backup_2021_07_30-04_01_03.tar.gz  backup_2022_02_02-04_00_56.tar.gz
                                    backup_2021_07_31-04_01_08.tar.gz  backup_2022_02_03-04_01_11.tar.gz
                                    backup_2021_08_01-04_00_52.tar.gz  backup_2022_02_04-04_01_11.tar.gz
                                    backup_2021_08_01-15_30_24.tar.gz  backup_2022_02_05-04_01_18.tar.gz
                                    backup_2021_08_02-04_01_06.tar.gz  backup_2022_02_06-04_01_08.tar.gz
                                    backup_2021_08_03-04_01_08.tar.gz  backup_2022_02_07-04_01_08.tar.gz
                                    backup_2021_08_04-04_01_06.tar.gz  backup_2022_02_08-04_01_20.tar.gz
                                    backup_2021_08_05-04_01_03.tar.gz  backup_2022_02_09-04_01_11.tar.gz
                                    backup_2021_08_06-04_01_03.tar.gz  backup_2022_02_10-04_01_06.tar.gz
                                    backup_2021_08_07-04_01_03.tar.gz  backup_2022_02_11-04_01_07.tar.gz
                                    backup_2021_08_08-04_01_07.tar.gz  backup_2022_02_11-15_16_43.tar.gz
                                    backup_2021_08_09-04_01_11.tar.gz  backup_2022_02_12-04_01_18.tar.gz
                                    backup_2021_08_10-04_01_10.tar.gz  backup_2022_02_13-04_01_15.tar.gz
                                    backup_2021_08_11-04_01_10.tar.gz  backup_2022_02_14-04_01_10.tar.gz
                                    backup_2021_08_12-04_01_07.tar.gz  backup_2022_02_15-04_01_17.tar.gz
                                    backup_2021_08_13-04_01_04.tar.gz  backup_2022_02_16-04_01_15.tar.gz
                                    backup_2021_08_14-04_01_06.tar.gz  backup_2022_02_17-04_01_15.tar.gz
                                    backup_2021_08_15-04_01_08.tar.gz  backup_2022_02_18-04_01_12.tar.gz
                                    backup_2021_08_16-04_01_09.tar.gz  backup_2022_02_19-04_01_13.tar.gz
                                    backup_2021_08_17-04_01_08.tar.gz  backup_2022_02_20-04_01_09.tar.gz
                                    backup_2021_08_18-04_01_10.tar.gz  backup_2022_02_21-04_01_11.tar.gz
                                    backup_2021_08_19-04_01_10.tar.gz  backup_2022_02_22-04_01_11.tar.gz
                                    backup_2021_08_20-04_01_07.tar.gz  backup_2022_02_23-04_01_15.tar.gz
                                    backup_2021_08_21-04_01_09.tar.gz  backup_2022_02_24-04_01_13.tar.gz
                                    backup_2021_08_22-04_01_05.tar.gz  backup_2022_02_25-04_01_12.tar.gz
                                    backup_2021_08_23-04_01_05.tar.gz  backup_2022_02_26-04_01_12.tar.gz
                                    backup_2021_08_24-04_01_10.tar.gz  backup_2022_02_27-04_01_13.tar.gz
                                    backup_2021_08_25-04_01_11.tar.gz  backup_2022_02_28-04_01_14.tar.gz
                                    backup_2021_08_26-04_01_07.tar.gz  backup_2022_03_01-04_01_11.tar.gz
                                    backup_2021_08_27-04_01_11.tar.gz  backup_2022_03_02-04_01_12.tar.gz
                                    backup_2021_08_28-04_01_07.tar.gz  backup_2022_03_03-04_01_23.tar.gz
                                    backup_2021_08_29-04_01_01.tar.gz  backup_2022_03_04-04_01_11.tar.gz
                                    backup_2021_08_30-04_01_05.tar.gz  backup_2022_03_05-04_01_13.tar.gz
                                    backup_2021_08_31-04_01_05.tar.gz  backup_2022_03_06-04_01_13.tar.gz
                                    backup_2021_09_01-04_01_06.tar.gz  backup_2022_03_07-04_01_12.tar.gz
                                    backup_2021_09_02-04_01_06.tar.gz  backup_2022_03_08-04_01_11.tar.gz
                                    backup_2021_09_03-04_01_14.tar.gz  backup_2022_03_09-04_01_15.tar.gz
                                    backup_2021_09_04-04_01_07.tar.gz  backup_2022_03_10-04_01_11.tar.gz
                                    backup_2021_09_05-04_01_08.tar.gz  backup_2022_03_11-04_00_57.tar.gz
                                    backup_2021_09_06-04_01_07.tar.gz  backup_2022_03_12-04_01_10.tar.gz
                                    backup_2021_09_07-04_01_07.tar.gz  backup_2022_03_13-04_01_13.tar.gz
                                    backup_2021_09_08-04_01_10.tar.gz  backup_2022_03_14-04_01_16.tar.gz
                                    backup_2021_09_09-04_01_08.tar.gz  backup_2022_03_15-04_01_15.tar.gz
                                    backup_2021_09_10-04_01_05.tar.gz  backup_2022_03_16-04_00_54.tar.gz
                                    backup_2021_09_11-04_01_09.tar.gz  backup_2022_03_17-04_01_15.tar.gz
                                    backup_2021_09_12-04_01_17.tar.gz  backup_2022_03_18-04_01_26.tar.gz
                                    backup_2021_09_13-04_01_03.tar.gz  backup_2022_03_19-04_01_13.tar.gz
                                    backup_2021_09_14-04_01_05.tar.gz  backup_2022_03_20-04_01_16.tar.gz
                                    backup_2021_09_15-04_01_08.tar.gz  backup_2022_03_21-04_01_15.tar.gz
                                    backup_2021_09_16-04_01_08.tar.gz  backup_2022_03_22-04_01_11.tar.gz
                                    backup_2021_09_17-04_01_08.tar.gz  backup_2022_03_23-04_01_17.tar.gz
                                    backup_2021_09_18-04_01_08.tar.gz  backup_2022_03_24-04_01_11.tar.gz
                                    backup_2021_09_19-04_01_16.tar.gz  backup_2022_03_25-04_01_19.tar.gz
                                    backup_2021_09_20-04_01_15.tar.gz  backup_2022_03_26-04_01_17.tar.gz
                                    backup_2021_09_21-04_01_09.tar.gz  backup_2022_03_27-04_01_15.tar.gz
                                    backup_2021_09_22-04_01_10.tar.gz  backup_2022_03_28-04_01_13.tar.gz
                                    backup_2021_09_23-04_01_12.tar.gz  backup_2022_03_29-04_01_12.tar.gz
                                    backup_2021_09_24-04_01_08.tar.gz  backup_2022_03_30-04_01_19.tar.gz
                                    backup_2021_09_25-04_01_07.tar.gz  backup_2022_03_31-04_00_57.tar.gz
                                    backup_2021_09_26-04_01_06.tar.gz  backup_2022_04_01-04_01_16.tar.gz
                                    backup_2021_09_27-04_01_12.tar.gz  backup_2022_04_02-04_01_17.tar.gz
                                    backup_2021_09_28-04_01_17.tar.gz  backup_2022_04_03-04_01_12.tar.gz
                                    backup_2021_09_29-04_00_58.tar.gz  backup_2022_04_04-04_01_17.tar.gz
                                    backup_2021_09_30-04_01_07.tar.gz  backup_2022_04_05-04_01_12.tar.gz
                                    backup_2021_10_01-04_01_10.tar.gz  backup_2022_04_06-04_01_14.tar.gz
                                    backup_2021_10_02-04_01_09.tar.gz  backup_2022_04_07-04_01_11.tar.gz
                                    backup_2021_10_03-04_01_07.tar.gz  backup_2022_04_08-04_01_32.tar.gz
                                    backup_2021_10_04-04_01_08.tar.gz  backup_2022_04_09-04_01_12.tar.gz
                                    backup_2021_10_05-04_01_14.tar.gz  backup_2022_04_10-04_01_17.tar.gz
                                    backup_2021_10_06-04_01_12.tar.gz  backup_2022_04_11-04_01_13.tar.gz
                                    backup_2021_10_07-04_01_06.tar.gz  backup_2022_04_12-04_01_11.tar.gz
                                    backup_2021_10_08-04_01_16.tar.gz  backup_2022_04_13-04_01_12.tar.gz
                                    backup_2021_10_09-04_01_09.tar.gz  backup_2022_04_14-04_01_25.tar.gz
                                    backup_2021_10_10-04_01_10.tar.gz  backup_2022_04_15-04_01_10.tar.gz
                                    backup_2021_10_11-04_01_05.tar.gz  backup_2022_04_16-04_01_16.tar.gz
                                    backup_2021_10_12-04_01_11.tar.gz  backup_2022_04_17-04_01_13.tar.gz
                                    backup_2021_10_13-04_01_08.tar.gz  backup_2022_04_18-04_01_11.tar.gz
                                    backup_2021_10_14-04_01_11.tar.gz  backup_2022_04_19-04_01_14.tar.gz
                                    backup_2021_10_15-04_01_08.tar.gz  backup_2022_04_20-04_01_22.tar.gz
                                    backup_2021_10_16-04_01_11.tar.gz  backup_2022_04_21-04_01_13.tar.gz
                                    backup_2021_10_17-04_01_09.tar.gz  backup_2022_04_22-04_01_14.tar.gz
                                    backup_2021_10_18-04_01_11.tar.gz  backup_2022_04_23-04_01_11.tar.gz
                                    backup_2021_10_19-04_01_09.tar.gz  backup_2022_04_24-04_01_09.tar.gz
                                    backup_2021_10_20-04_01_10.tar.gz  backup_2022_04_25-04_01_13.tar.gz
                                    backup_2021_10_21-04_01_07.tar.gz  backup_2022_04_26-04_01_16.tar.gz
                                    backup_2021_10_22-04_01_07.tar.gz  backup_2022_04_27-04_01_09.tar.gz
                                    backup_2021_10_23-04_01_05.tar.gz  backup_2022_04_28-04_01_22.tar.gz
                                    backup_2021_10_24-04_01_07.tar.gz  backup_2022_04_29-04_01_17.tar.gz
                                    backup_2021_10_25-04_01_13.tar.gz  backup_2022_04_30-04_01_13.tar.gz
                                    backup_2021_10_26-04_01_02.tar.gz  backup_2022_05_01-04_01_16.tar.gz
                                    backup_2021_10_27-04_01_09.tar.gz  backup_2022_05_02-04_01_12.tar.gz
                                    backup_2021_10_28-04_01_05.tar.gz  backup_2022_05_03-04_01_12.tar.gz
                                    backup_2021_10_29-04_01_21.tar.gz  backup_2022_05_04-04_01_12.tar.gz
                                    backup_2021_10_30-04_01_15.tar.gz  backup_2022_05_05-04_01_12.tar.gz
                                    backup_2021_10_31-04_01_17.tar.gz  backup_2022_05_06-04_01_17.tar.gz
                                    backup_2021_11_01-04_01_07.tar.gz  backup_2022_05_07-04_01_25.tar.gz
                                    backup_2021_11_02-04_01_11.tar.gz  backup_2022_05_08-04_01_21.tar.gz
                                    backup_2021_11_03-04_01_10.tar.gz  backup_2022_05_09-04_01_10.tar.gz
                                    backup_2021_11_04-04_01_07.tar.gz  backup_2022_05_10-04_01_14.tar.gz
                                    backup_2021_11_05-04_01_08.tar.gz  backup_2022_05_11-04_01_18.tar.gz
                                    backup_2021_11_06-04_01_11.tar.gz  backup_2022_05_12-04_01_15.tar.gz
                                    backup_2021_11_07-04_01_13.tar.gz  backup_2022_05_13-03_55_42.tar.gz
                                    backup_2021_11_08-04_01_10.tar.gz  backup_2022_05_13-04_01_02.tar.gz
                                    backup_2021_11_09-04_01_10.tar.gz  backup_2022_05_14-04_01_11.tar.gz
                                    backup_2021_11_10-04_01_12.tar.gz  backup_2022_05_14-23_32_32.tar.gz
                                    backup_2021_11_11-04_01_11.tar.gz  backup_2022_05_14-23_48_33.tar.gz
                                    backup_2021_11_12-04_01_10.tar.gz  backup_2022_05_14-23_56_37.tar.gz
                                    backup_2021_11_13-04_01_13.tar.gz  backup_2022_05_15-00_13_38.tar.gz
                                    backup_2021_11_14-04_01_11.tar.gz  backup_2022_05_15-00_17_58.tar.gz
                                    backup_2021_11_15-04_01_10.tar.gz  backup_2022_05_15-00_18_12.tar.gz
                                    backup_2021_11_16-04_01_10.tar.gz  backup_2022_05_15-00_19_19.tar.gz
                                    backup_2021_11_17-04_01_13.tar.gz  backup_2022_05_15-00_19_29.tar.gz
                                    backup_2021_11_18-04_01_19.tar.gz  backup_2022_05_15-04_01_09.tar.gz
                                    backup_2021_11_19-04_01_12.tar.gz  backup_2022_05_17-21_11_40.tar.gz
                                    backup_2021_11_20-04_01_13.tar.gz  backup_2022_05_17-21_13_23.tar.gz
                                    backup_2021_11_21-04_01_15.tar.gz  backup_2022_05_17-21_16_02.tar.gz
                                    backup_2021_11_22-04_01_07.tar.gz  backup_2022_05_17-21_16_30.tar.gz
                                    backup_2021_11_23-04_01_08.tar.gz  backup_2022_05_17-21_21_59.tar.gz
                                    backup_2021_11_24-04_01_10.tar.gz  backup_2022_05_17-21_23_38.tar.gz
                                    backup_2021_11_25-04_01_08.tar.gz  backup_2022_05_17-21_25_31.tar.gz
                                    backup_2021_11_26-04_01_10.tar.gz  backup_2022_05_17-21_25_45.tar.gz
                                    backup_2021_11_27-04_01_18.tar.gz  backup_2022_05_17-21_26_36.tar.gz
                                    backup_2021_11_28-04_01_08.tar.gz  backup_2022_05_17-21_29_31.tar.gz
                                    backup_2021_11_29-04_01_11.tar.gz  backup_2022_05_18-04_01_12.tar.gz
                                    backup_2021_11_30-04_01_17.tar.gz  backup_2022_05_18-11_43_11.tar.gz
                                    backup_2021_12_01-04_01_15.tar.gz  backup_2022_05_18-11_45_19.tar.gz
                                    backup_2021_12_02-04_01_18.tar.gz  backup_2022_05_18-11_48_00.tar.gz
                                    backup_2021_12_03-04_01_11.tar.gz  backup_2022_05_18-11_48_23.tar.gz
                                    backup_2021_12_04-04_01_17.tar.gz  backup_2022_05_18-11_49_20.tar.gz
                                    backup_2021_12_05-04_01_11.tar.gz  backup_2022_05_18-11_52_23.tar.gz
                                    backup_2021_12_06-04_01_08.tar.gz  backup_2022_05_18-11_53_14.tar.gz
                                    backup_2021_12_07-04_01_09.tar.gz  backup_2022_05_18-11_55_11.tar.gz
                                    backup_2021_12_08-04_01_07.tar.gz  backup_2022_05_18-12_02_57.tar.gz
                                    backup_2021_12_09-04_01_06.tar.gz  backup_2022_05_18-12_04_07.tar.gz
                                    backup_2021_12_10-04_00_55.tar.gz  backup_2022_05_18-12_15_26.tar.gz
                                    backup_2021_12_11-04_01_05.tar.gz  backup_2022_05_18-12_47_07.tar.gz
                                    backup_2021_12_12-04_01_06.tar.gz  backup_2022_05_18-12_47_40.tar.gz
                                    backup_2021_12_13-04_01_22.tar.gz  backup_2022_05_18-19_03_56.tar.gz
                                    backup_2021_12_14-04_01_15.tar.gz  backup_2022_05_18-19_05_02.tar.gz
                                    backup_2021_12_15-04_01_05.tar.gz  backup_2022_05_18-19_05_23.tar.gz
                                    backup_2021_12_16-04_01_07.tar.gz  backup_2022_05_18-19_06_08.tar.gz
                                    backup_2021_12_17-04_01_10.tar.gz  backup_2022_05_18-19_06_33.tar.gz
                                    backup_2021_12_18-04_01_12.tar.gz  backup_2022_05_18-19_08_28.tar.gz
                                    backup_2021_12_19-04_01_01.tar.gz  backup_2022_05_18-19_08_58.tar.gz
                                    backup_2021_12_20-04_01_13.tar.gz  backup_2022_05_18-19_11_40.tar.gz
                                    backup_2021_12_21-04_01_16.tar.gz  backup_2022_05_18-19_12_12.tar.gz
                                    backup_2021_12_22-04_01_10.tar.gz  backup_2022_05_18-19_13_55.tar.gz
                                    backup_2021_12_23-04_01_11.tar.gz  backup_2022_05_18-19_21_28.tar.gz
                                    backup_2021_12_24-04_01_09.tar.gz  backup_2022_05_18-19_22_20.tar.gz
                                    backup_2021_12_25-04_01_22.tar.gz  backup_2022_05_18-19_26_23.tar.gz
                                    backup_2021_12_26-04_00_56.tar.gz  backup_2022_05_18-19_27_21.tar.gz
                                    backup_2021_12_27-04_01_08.tar.gz  backup_2022_05_18-20_06_49.tar.gz
                                    backup_2021_12_28-04_01_09.tar.gz  backup_2022_05_19-04_01_12.tar.gz
                                    backup_2021_12_29-04_01_17.tar.gz  backup_2022_05_19-12_47_00.tar.gz
                                    backup_2021_12_30-04_00_54.tar.gz  backup_2022_05_19-12_47_15.tar.gz
                                    backup_2021_12_31-04_01_14.tar.gz  backup_2022_05_19-12_47_34.tar.gz
                                    backup_2022_01_01-04_01_13.tar.gz  backup_2022_05_19-12_47_53.tar.gz
                                    backup_2022_01_02-04_01_10.tar.gz  backup_2022_05_19-13_02_48.tar.gz
                                    backup_2022_01_03-04_01_09.tar.gz  backup_2022_05_19-13_20_11.tar.gz
                                    backup_2022_01_04-04_01_13.tar.gz  backup_2022_05_19-13_46_50.tar.gz
                                    backup_2022_01_05-04_01_12.tar.gz  backup_2022_05_19-13_52_26.tar.gz
                                    backup_2022_01_06-04_01_15.tar.gz  backup_2022_05_19-13_59_21.tar.gz
                                    backup_2022_01_07-04_01_11.tar.gz  backup_2022_05_19-17_15_03.tar.gz
                                    backup_2022_01_08-04_01_09.tar.gz  backup_2022_05_19-17_15_33.tar.gz
                                    backup_2022_01_09-04_01_07.tar.gz  backup_2022_05_20-04_01_16.tar.gz
                                    backup_2022_01_10-04_01_11.tar.gz  backup_2022_05_20-10_36_13.tar.gz
                                    backup_2022_01_11-04_01_18.tar.gz  backup_2022_05_20-10_58_41.tar.gz
                                    backup_2022_01_12-04_01_06.tar.gz  backup_2022_05_20-11_00_05.tar.gz
                                    backup_2022_01_13-04_01_10.tar.gz  backup_2022_05_21-04_01_15.tar.gz
                                    backup_2022_01_14-04_01_11.tar.gz  backup_2022_05_22-04_01_17.tar.gz
                                    backup_2022_01_15-04_01_09.tar.gz  backup_2022_05_23-04_01_19.tar.gz
                                    backup_2022_01_16-04_01_09.tar.gz  backup_2022_05_23-15_18_12.tar.gz
                                    backup_2022_01_17-04_01_10.tar.gz  backup_2022_05_23-15_19_22.tar.gz
                                    backup_2022_01_18-04_01_11.tar.gz  backup_2022_05_23-15_29_32.tar.gz
                                    backup_2022_01_19-04_01_09.tar.gz  backup_2022_05_23-15_29_52.tar.gz
                                    backup_2022_01_20-04_01_11.tar.gz  backup_2022_05_23-15_33_29.tar.gz
                                    backup_2022_01_21-04_00_53.tar.gz  shepherd.db
                                    • Asgothian
                                      @creaven in diesen Dateien befindet sich die Shepherd.dB Datei. Du solltest eine Datei entpacken die von vor dem Absturz stammt..A.
                                      • Creaven
                                        @asgothian Danke. Ich hab die Datei entpackt, aber es macht keinen Unterschied.
                                        Mittlerweile kann ich den Adapter gar nicht mehr installieren (weder über Git noch über die Auswahl der Adapter).
                                        Bekomme den Fehlercode 25 angezeigt:
                                        host.iobrokerserver Cannot install iobroker.zigbee@1.6.18: 1
                                        ERROR: Process exited with code 25
                                        Asgothian Thomas Braun 2 Replies Last reply Reply Quote 0
                                        • Asgothian
                                          @creaven ich kann bei der Informationslage nicht nachvollziehen was du getan hast. Du solltest nur die gz Datei im angegebenen Verzeichnis entpacken und den adapter neu starten - nicht neu installieren.
                                          A.
                                          • Creaven
                                            Ich hatten den Adapter leider schon gestern deinstalliert. Leider zuviel rumprobiert anscheinend...
                                            1273
