    4. Test Adapter melcloud v2.0.x Latest
    • Black Thunder
      Black Thunder Developer @darkblu last edited by
      @darkblu
      Wenn du magst, kannst du die Logstufe des Adapters ja mal auf Debug stellen und den betreffenden Ausschnitt des Logs hier posten. Sollte in etwa so beim Start aussehen:
      Response from cloud: ...
      Received response from: https://app.melcloud.com/Mitsubishi.Wifi.Client/User/ListDevices (status code: 200 - OK)
      Fetching devices...
      Login successful. ContextKey: XXX
      Das, was an dieser Stelle nach "Response from cloud:" steht, bitte hier komplett posten (vorher evtl. personenbezogene Daten entfernen).
        darkblu @Black Thunder last edited by
        @black-thunder ,
        sodele, ich hoffe, ich habe mich ausreichend anonymisiert 🙂
        hier bitteschön:
        Response from cloud: [{"xxx,"District":null,"FPDefined":false,"FPEnabled":false,"FPMinTemperature":14,"FPMaxTemperature":16,"HMDefined":false,"HMEnabled":false,"HMStartDate":null,"HMEndDate":null,"BuildingType":1,"PropertyType":8,"DateBuilt":null,"HasGasSupply":true,"LocationLookupDate":"2021-06-01T13:35:02.59","Country":85,"TimeZoneContinent":3,"TimeZoneCity":49,"TimeZone":119,"Location":69559,"CoolingDisabled":false,"Expanded":true,"Structure":{"Floors":[{"ID":69902,"Name":"Studio","BuildingId":272436,"AccessLevel":4,"DirectAccess":false,"EndDate":"2500-01-01T00:00:00","Areas":[],"Devices":[{"DeviceID":19738509,"DeviceName":"Studio","BuildingID":272436,"BuildingName":null,"FloorID":69902,"FloorName":null,"AreaID":null,"AreaName":null,"ImageID":-10001,"InstallationDate":null,"LastServiceDate":null,"Presets":[{"SetTemperature":25,"Power":false,"OperationMode":3,"VaneHorizontal":3,"VaneVertical":1,"FanSpeed":0,"ID":187980,"Client":362739,"DeviceLocation":19738509,"Number":1,"Configuration":"<settings><st>25</st><pw>false</pw><om>3</om><vd>1</vd><hd>3</hd><fs>0</fs></settings>","NumberDescription":"Nachtmodus"}],"OwnerID":362739,"OwnerName":null,"OwnerEmail":null,"AccessLevel":4,"DirectAccess":false,"EndDate":"2500-01-01T00:00:00","Zone1Name":null,"Zone2Name":null,"MinTemperature":0,"MaxTemperature":40,"HideVaneControls":false,"HideDryModeControl":false,"HideRoomTemperature":false,"HideSupplyTemperature":false,"HideOutdoorTemperature":false,"BuildingCountry":null,"OwnerCountry":null,"AdaptorType":3,"LinkedDevice":null,"Type":0,"MacAddress":"2c:9f:fb:36:7e:bc","SerialNumber":"2045211213","Device":{"PCycleActual":0,"ErrorMessages":"","DeviceType":0,"CanCool":true,"CanHeat":true,"CanDry":true,"HasAutomaticFanSpeed":true,"AirDirectionFunction":true,"SwingFunction":true,"NumberOfFanSpeeds":5,"UseTemperatureA":true,"TemperatureIncrementOverride":0,"TemperatureIncrement":0.5,"MinTempCoolDry":16,"MaxTempCoolDry":31,"MinTempHeat":10,"MaxTempHeat":31,"MinTempAutomatic":16,"MaxTempAutomatic":31,"LegacyDevice":false,"UnitSupportsStandbyMode":true,"IsSplitSystem":false,"ModelIsAirCurtain":false,"ModelSupportsFanSpeed":true,"ModelSupportsAuto":true,"ModelSupportsHeat":true,"ModelSupportsDry":true,"ModelSupportsVaneVertical":true,"ModelSupportsVaneHorizontal":true,"ModelSupportsWideVane":true,"ModelDisableEnergyReport":false,"ModelSupportsStandbyMode":true,"ModelSupportsEnergyReporting":true,"ProhibitSetTemperature":false,"ProhibitOperationMode":false,"ProhibitPower":false,"Power":false,"RoomTemperature":20,"SetTemperature":24,"ActualFanSpeed":0,"FanSpeed":0,"AutomaticFanSpeed":true,"VaneVerticalDirection":2,"VaneVerticalSwing":false,"VaneHorizontalDirection":3,"VaneHorizontalSwing":false,"OperationMode":3,"EffectiveFlags":0,"LastEffectiveFlags":0,"InStandbyMode":false,"DemandPercentage":100,"ConfiguredDemandPercentage":null,"HasDemandSideControl":false,"DefaultCoolingSetTemperature":21,"DefaultHeatingSetTemperature":23,"RoomTemperatureLabel":0,"HeatingEnergyConsumedRate1":0,"HeatingEnergyConsumedRate2":0,"CoolingEnergyConsumedRate1":0,"CoolingEnergyConsumedRate2":0,"AutoEnergyConsumedRate1":0,"AutoEnergyConsumedRate2":0,"DryEnergyConsumedRate1":0,"DryEnergyConsumedRate2":0,"FanEnergyConsumedRate1":0,"FanEnergyConsumedRate2":0,"OtherEnergyConsumedRate1":0,"OtherEnergyConsumedRate2":0,"HasEnergyConsumedMeter":true,"CurrentEnergyConsumed":13100,"CurrentEnergyMode":3,"CoolingDisabled":false,"EnergyCorrectionModel":764,"EnergyCorrectionActive":true,"MinPcycle":1,"MaxPcycle":1,"EffectivePCycle":1,"MaxOutdoorUnits":255,"MaxIndoorUnits":255,"MaxTemperatureControlUnits":0,"ModelCode":"0130","DeviceID":19738509,"MacAddress":"2c:9f:fb:36:7e:bc","SerialNumber":"2045211213","TimeZoneID":119,"DiagnosticMode":0,"DiagnosticEndDate":null,"ExpectedCommand":1,"Owner":362739,"DetectedCountry":null,"AdaptorType":3,"FirmwareDeployment":null,"FirmwareUpdateAborted":false,"LinkedDevice":null,"WifiSignalStrength":-46,"WifiAdapterStatus":"NORMAL","Position":"Unknown","PCycle":10,"PCycleConfigured":null,"RecordNumMax":0,"LastTimeStamp":"2022-04-04T18:23:00","ErrorCode":8000,"HasError":false,"LastReset":"2022-03-31T19:03:15.997","FlashWrites":2,"Scene":null,"SSLExpirationDate":"2037-12-31T00:00:00","SPTimeout":1,"Passcode":null,"ServerCommunicationDisabled":false,"ConsecutiveUploadErrors":0,"DoNotRespondAfter":null,"OwnerRoleAccessLevel":1,"OwnerCountry":85,"HideEnergyReport":false,"ExceptionHash":null,"ExceptionDate":null,"ExceptionCount":null,"Rate1StartTime":null,"Rate2StartTime":null,"ProtocolVersion":0,"UnitVersion":0,"FirmwareAppVersion":35000,"FirmwareWebVersion":0,"FirmwareWlanVersion":0,"MqttFlags":9,"HasErrorMessages":false,"HasZone2":false,"Offline":true,"Units":[{"ID":1,"Device":0,"SerialNumber":null,"ModelNumber":764,"Model":"MUZ-EF25VG","UnitType":0,"IsIndoor":false},{"ID":2,"Device":0,"SerialNumber":"0002582T","ModelNumber":887,"Model":"MSZ-EF25VGK B/S/W","UnitType":1,"IsIndoor":true}]},"DiagnosticMode":0,"DiagnosticEndDate":null,"Location":69559,"DetectedCountry":null,"Registrations":22,"LocalIPAddress":null,"TimeZone":119,"RegistReason":"STARTUP","ExpectedCommand":1,"RegistRetry":0,"DateCreated":"2021-06-01T13:18:41.948Z","FirmwareDeployment":null,"FirmwareUpdateAborted":false,"Permissions":{"CanSetOperationMode":true,"CanSetFanSpeed":true,"CanSetVaneDirection":true,"CanSetPower":true,"CanSetTemperatureIncrementOverride":true,"CanDisableLocalController":true,"CanSetDemandSideControl":false}}],"MinTemperature":0,"MaxTemperature":40,"Expanded":true}],"Areas":[],"Devices":[],"Clients":[]},"AccessLevel":4,"DirectAccess":true,"MinTemperature":0,"MaxTemperature":40,"Owner":null,"EndDate":"2500-01-01T00:00:00","iDateBuilt":null,"QuantizedCoordinates":{"Latitude":51.4,"Longitude":7.425}}]
        Black Thunder 1 Reply Last reply Reply Quote 0
        • Black Thunder
          @darkblu Wie befürchtet wird das so von der Melcloud gemeldet:
          ...,HasZone2":false,"Offline":true,"Units":...
          Warum das so ist kann ich auch nicht sagen, aber aus Adaptersicht kann ich da leider nichts machen.
            @black-thunder ,
            kein Problem, ist für mich ja nur ein kosmetisches Problem,
            da es ja trotzdem funktioniert.
            Dir ein großer Dank, dass du dir die Zeit für mich genommen hast. 🍺💐
            • Black Thunder
              Black Thunder Developer @darkblu last edited by Black Thunder
              @darkblu Versuch's jetzt bitte nochmal mit Admin v5.3.7. Bei mir ist der Fehler ("Error in GUI!") damit behoben und die Oberfläche stürzt jetzt nicht mehr ab, wenn man mit der Maus über das Datum fährt.
                Geesthachter @Black Thunder last edited by
                @black-thunder
                Hallo, Ich habe mal eine Frage bezüglich der Steuerung per Alexa.
                Die Steuerung der Klimaanlage über den melcloud v1.1.6 Adapter funktioniert super.
                Auch die Steuerung der Klimaanlage per Alexa funktionier aber....
                wenn ich die Klimaanlage per Alexa steuere werden diese Befehle zwar von der Klimaanlage ausgeführt sie werden aber nicht mit dem melcloud Adapter synchronisiert.
                Ist das nur bei mir so oder ist das ein Fehler?
                • Black Thunder
                  Black Thunder Developer @Geesthachter last edited by
                  @geesthachter Tauchen denn die Änderungen dann auch in der offiziellen Melcloud App (oder unter https://app.melcloud.com/) selbst auf, wenn du per Alexa Befehle sendest? Im Prinzip sollte der Adapter genau die Werte aus der Melcloud spiegeln.
                    @black-thunder
                    Ja dort ändert es sich wenn ich per Alexa Befehle gebe aber im melcloud Adapter hier im iobroker unter Objekte ändert sich nichts.
                    Hinweis: Ich habe Alexa nicht über den iot Adapter verbunden sondern direkt mit der melcloud gekoppelt.
                    Ich hatte Alexa auch schon über den iot Adapter verbunden. Dann klappte es, dann kamen die Befehle auch im melcloud Adapter an aber wenn ich dann per Alexa den Befehl gab sie solle die Klimaanlage einschalten dann tat sie das zwar aber die eingestellte Wunschtemperatur sprang dann immer auf 31 Grad und musste dann erst wieder mit einem zweiten Befehl auf die wirkliche Wunschtemperatur geändert werden.
                    • Black Thunder
                      @geesthachter Hm.... also ich hab das gerade mal bei mir nachgestellt in der gleichen Konstellation wie du, sprich den Alexa Skill direkt mit der Melcloud gekoppelt und via Alexa-Sprachbefehl die Solltemperatur geändert. Da werden die Werte einwandfrei in die Melcloud und anschließend auch in den Adapter in ioBroker übernommen.
                      Wie hoch ist dein Abrufintervall im Adapter eingestellt? Die Änderung wird erst verzögert nach Ablauf dieser Zeit übernommen und nicht in Echtzeit.
                        @black-thunder sagte in Test Adapter melcloud v1.1.x Latest:
                        Abrufintervall
                        Danke für die Info.
                        Der Abrufintervall stand auf 5.
                        Dadurch gab es tatsächlich eine Verzögerung von fast 5 Minuten.
                        Ich habe es jetzt auf 1 gestellt. Die Verzögerung verkürzt sich dadurch auf etwas weniger als eine Minute.
                        Warum gibt es diese Verzögerung?
                        Wenn ich Alexa einen Befehl gebe wird dieses doch sofort an der Klimaanlage ausgeführt warum wird es dann nicht auch sofort im Adapter angezeigt?
                        Wenn ich es per Visualisierung über deinen melcloud Adapter schalte kann ich doch auch mehrere Befehle direkt nacheinander schalten.
                        • Black Thunder
                          @geesthachter Die Verzögerung liegt darin begründet, dass es keine offizielle Schnittstelle zur Melcloud gibt, sondern ich mit dem Adapter im Prinzip nur die App simuliere. Das heißt ich kann nicht auf Änderungen direkt reagieren, da es einen solchen Kommunikationskanal nicht gibt. Stattdessen werden in regelmäßigen Abständen (= Abrufintervall) Anfragen an die Cloud geschickt, die die aktuellen Daten zurückliefern. Und um da die Last nicht übermäßig groß werden zu lassen, habe ich das auf maximal einmal pro Minute beschränkt.
                          Das Senden von Befehlen hat damit nichts zu tun, das passiert in Echtzeit.
                            @black-thunder
                            Okay danke,
                            Jetzt wo ich weiß woran es liegt und der Abrufintervall bei mir auf 1 steht bin ich auch zufrieden.
                            Danke für den super Adapter und deine Hilfe.
                              derrapf @Geesthachter last edited by derrapf
                              Eine Frage hätte ich auch noch, vielleicht weiss das jemand.
                              Ich habe heute in der MelApp mal mit den Berichten rumgespielt und im Grunde gesehen, dass ich Keine habe.
                              "Monatliche Temperatur", "Betriebsart", "WIFI", "Fehlerbericht" z.B. ist komplett leer.
                              Das Einzige was zu gehen scheint ist der Energierverbrauch. Wobei auch hier, obwohl ich ein Intervall vom 7.6.2021 bis 7.6.2022 eingegeben habe, nur vom August bis Jan angezeigt wird:
                              Auch im IOBroler sind die Datenpunkte ziemlich übersichtlich gefüllt:
                              Nur totalPowerConsumptionHeat, totalPowerConsumptionHeatDecember,totalPowerConsumptionHeatJanuary haben einen Wert.
                              Muss ich da noch irgendwas einstellen, dass das funktioniert?
                              Gruss Ralf
                                darkblu last edited by darkblu
                                @derrapf
                                klickst du denn auch auf „getPowerConsumptionReport“ ?
                                Bei mir funktioniert das manchmal, aber auch nicht immer.
                                Was auch komisch ist, trage ich bei „endDate“ das aktuelle Datum ein, addiert der Melcloud Adapter immer einen Monat drauf.
                                Ich habe z.B. 2022.07.11 eingetragen, bei „endDate“ steht dann aber 2022.08.11
                                Eins noch in eigener Sache, wie kann ich den Button bei „getPower…“ eigentlich per VIS betätigen ?
                                • Black Thunder
                                  Black Thunder Developer @derrapf last edited by
                                  @derrapf Also wenn in der Melcloud/App selbst nicht mehr Daten zu sehen sind, kann der Adapter auch keine zusätzlichen anzeigen. 😉
                                  Warum dir da aber nicht mehr angezeigt wird, kann ich dir auch nicht sagen. Evtl. unterstützen deine Innengeräte nicht mehr Anzeigen/Daten?
                                  @darkblu said in Test Adapter melcloud v1.1.x Latest:
                                  Das liegt am Admin-Adapter selbst. Welche Version vom Admin-Adapter verwendest du? Das Problem mit der Anzeige des Datums sollte seit v5.4.8 behoben sein (siehe hier).
                                  VIS verwende ich nicht, aber ich würde mal vermuten einfach einen Button anlegen und den State dort hinterlegen, so dass bei Klick "true" geschrieben wird.
                                  D G D 3 Replies Last reply Reply Quote 0
                                    @black-thunder
                                    ich habe (noch) den Admin „stable“ 5.3.8 am laufen
                                    Mit dem Taster in VIS probiere ich am WE mal aus.
                                      @black-thunder
                                      Das kann ich bestätigen, das Problem mit dem Datum ist mit der Admin-Adapter beta v.5.4.8 behoben aber leider habe ich sehr viele Probleme mit der beta v.5.4.8 (Abstürze, verlangsamtes reagieren). Ich bin darum jetzt wieder zurück auf der v5.3.8 jetzt ist natürlich das Problem mit dem Datum hier wieder vorhanden.
                                      Ich habe auch noch eine Frage zum melcloud Adapter, Bei mir wird bei allen Energierverbrauchswerten immer nur 0 kWh angezeigt.
                                      StartDate und EndDate habe ich eingetragen und den getPowerConsumptionReport Button habe ich ausgelöst.
                                      Was mache ich falsch?
                                      • Black Thunder
                                        @geesthachter
                                        Mit der Admin-Version hatte ich eigentlich keine Probleme, bin aber mittlerweile schon auf der v6.x 😉 Allerdings ist das mit dem Datum an der Stelle eh nur ein kosmetisches Problem und sollte keine weiteren Auswirkungen haben.
                                        Bekommst du denn für denselben Zeitraum in der App/Melcloud selbst irgendwelche Werte angezeigt? Falls ja, bräuchte ich bitte das zugehörige Debug-Log, wenn du einen Abruf über den Adapter startest.
                                          @black-thunder
                                          Ich bekomme es nicht hin. Aber egal so wichtig ist es mir momentan nicht.
                                          Als Anregung für andere Nutzer, ich habe bei mir noch über ein Blockly einen Timer integriert.
                                          Darüber kann ich einstellen wie lange die Klimaanlage laufen soll.
                                          So sieht es dann in meiner Iqontrol Visualisierung aus.
                                          Hier das Blockly als Bild
                                          und hier das Blockly zum kopieren
                                          Blockly Timer Klimaanlage.txt
                                          dafür habe ich diesen Datenpunkt erstellt
                                          0_userdata.0.Datenpunkt.Klimaanlage.Timer_Zeitbegrenzung
                                          Björn
                                            derrapf @Black Thunder last edited by
                                            @black-thunder
                                            Ja genau. In der Mel-Cloud sehe ich auch nichts. Wo könnte man denn da fragen? Weil schön wäre es ja schon wenn ich da was hätte...
                                            Gruss Ralf
                                            31.7k
                                            79.8k
                                            klimaanlage melcloud mitsubishi test
                                            27
                                            230
                                            30144
