    4. GPIO Status Wemos d1 mini an iobroker senden
      Beowolf @OpenSourceNomad last edited by Beowolf
      @opensourcenomad
      Ich habe noch mal etwas probiert.
      esphome:
      esp8266:
        board: d1_mini
      stepper:
        - platform: a4988
          step_pin: D3
          dir_pin: D4
          max_speed: 250 steps/s
          sleep_pin: D2
          acceleration: inf
          deceleration: inf
      # Enable logging
      logger:
        baud_rate: 0 # 0 to disable logging via hardware UART.
      api:
        password: "1234"
      ota:
        password: "1234"
      wifi:
        ssid: "---"
        password: "-------"
      web_server:
        port: 80
      captive_portal:
      # Example configuration entry
      light:
        - platform: neopixelbus
          type: GRB
          variant: WS2811
          pin: GPIO3
          num_leds: 1
      binary_sensor:
        - platform: gpio
          pin:
            number: D0
            inverted: true
            mode:
              input: true
          name: "Taster Tür öffnen"
          on_state:
            then:
            - stepper.set_target:
                target: 250
        - platform: gpio
          pin:
            number: D7
            inverted: true
            mode:
              input: true
              pullup: true
          name: "Taster Tür schließen"
          on_state:
            then:
                target: -250
        - platform: gpio
          pin:
            number: D1
            inverted: true
            mode:
              input: true
              pullup: true
          name: "Taster Bewegung anhalten"
        - platform: gpio
          pin:
            number: D2
          name: "Steppermotor aktivieren/deaktivieren"
        - platform: gpio
          pin:
            number: D5
            inverted: true
            mode:
              input: true
              pullup: true
          on_state:
            then:
              - light.turn_on:
                  brightness: 100%
                  red: 100%
                  green: 0
                  blue: 0
        - platform: gpio
          pin:
            number: D6
            inverted: true
            mode:
              input: true
              pullup: true
          name: "Tür geschlossen"
          on_state:
            then:
              - light.turn_on:
                  brightness: 100%
                  red: 0%
                  green: 100%
                  blue: 0
      Der Schrittmotor macht aber nichts.
      Ich kann auch die Zustände unter ioBroker nicht ändern.
      • OpenSourceNomad
        OpenSourceNomad Most Active @Beowolf last edited by
        @beowolf said in GPIO Status Wemos d1 mini an iobroker senden:
        @opensourcenomad
        esphome:
        esp8266:
          board: d1_mini
        stepper:
          - platform: a4988
            step_pin: D3
            dir_pin: D4
            sleep_pin: D2
            acceleration: inf
            deceleration: inf
        # Enable logging
        logger:
        api:
          password: "1234"
        ota:
          password: "1234"
        wifi:
          ssid: "---"
          password: "-------"
        web_server:
          port: 80
        captive_portal:
        light:
            type: GRB
            variant: WS2811
            pin: GPIO3
            num_leds: 1
        binary_sensor:
          - platform: gpio
            pin:
              number: D0
              inverted: true
              mode:
                input: true
            on_state:
              then:
                  target: 250
          - platform: gpio
            pin:
              number: D7
              inverted: true
              mode:
                input: true
                pullup: true
            on_state:
              then:
                  target: -250
          - platform: gpio
            pin:
              number: D1
              inverted: true
              mode:
                input: true
                pullup: true
          - platform: gpio
            pin:
              number: D2
          - platform: gpio
            pin:
              number: D5
              inverted: true
              mode:
                input: true
                pullup: true
            on_state:
              then:
                - light.turn_on:
                    brightness: 100%
                    red: 100%
                    green: 0
                    blue: 0
          - platform: gpio
            pin:
              number: D6
              inverted: true
              mode:
                input: true
                pullup: true
            on_state:
              then:
                - light.turn_on:
                    brightness: 100%
                    red: 0%
                    green: 100%
                    blue: 0
        Ich habe noch nie einen Schrittmotor mein eigenen genannt, deswegen stochere ich hier ein wenig im Dunkeln:
        Das modell a4988 ist der richtige? Was sagt der logger (kann einfach über's esphome dashboard aufgerufen werden) im Moment wenn du "Taster Tür öffnen" und "Taster Tür schließen" betätigst?
        Wenn der Motor sich dann hoffentlich bald bewegt könnte ein endstop cover dann noch die Krönung für dein Vorhaben sein 🐔 :
        👉 https://esphome.io/components/cover/endstop.html
          @opensourcenomad sagte in GPIO Status Wemos d1 mini an iobroker senden:
          Wenn der Motor sich dann hoffentlich bald bewegt könnte ein endstop cover dann noch die Krönung für dein Vorhaben sein :
          Leider noch nicht.
          Die Funktion erwarte "switch." ich habe aber binary_sensor:
          Das bekomme ich nicht zusammen.
          • OpenSourceNomad
            Leider noch nicht.
            Dann noch mal einen Schritt zurück:
              @opensourcenomad
              Ich habe es jetzt so gemacht:
              esphome:
              esp8266:
                board: d1_mini
              stepper:
                - platform: a4988
                  step_pin: D3
                  dir_pin: D4
                  max_speed: 5000 steps/s
                  sleep_pin:
                      number: D2
                      inverted: true
                  acceleration: inf
                  deceleration: inf
              # Enable logging
              logger:
              api:
                password: "1234"
              ota:
                password: "1234"
              wifi:
                ssid: "-----"
                password: "-------"
              web_server:
                port: 80
              captive_portal:
              light:
                  type: GRB
                  variant: WS2811
                  pin: GPIO3
                  num_leds: 1
              binary_sensor:
                - platform: gpio
                  pin:
                    number: D0
                    inverted: true
                    mode:
                      input: true
                  on_press:
                    then:
                        target: 250000
                - platform: gpio
                  pin:
                    number: D7
                    inverted: true
                    mode:
                      input: true
                      pullup: true
                  on_press:
                    then:
                        target: -250000
                - platform: gpio
                  pin:
                    number: D1
                    inverted: true
                    mode:
                      input: true
                      pullup: true
                - platform: gpio
                  pin:
                    number: D5
                    inverted: true
                    mode:
                      input: true
                      pullup: true
                  on_press:
                    then:
                      - light.turn_on:
                          brightness: 100%
                          red: 100%
                          green: 0
                          blue: 0
                      - stepper.report_position:
                          position: 0
                          target: 0
                - platform: gpio
                  pin:
                    number: D6
                    inverted: true
                    mode:
                      input: true
                      pullup: true
                  on_press:
                    then:
                      - light.turn_on:
                          brightness: 100%
                          red: 0%
                          green: 100%
                          blue: 0
                          position: 0
                          target: 0
              Der Motor dreht in die Richtungen wie ich es möchte. Bei erreichen der Endschalter hält der Motor direkt an. Mache hiermit:
                          position: 0
                          target: 0
              Ob das die beste Methode ist - keine Ahnung.
              Was jetzt noch nicht funktioniert ist, wenn die Tür auf ist, und ich jetzt nocht mal auf die AUF-Taste drücke geht die Tür "noch weiter" auf.
              Ich brauche also eine "wenn" - "dann" Funktion. Geht das nur über die Lambda Methode?
              OpenSourceNomad 1 Reply Last reply Reply Quote 1
              • OpenSourceNomad
                Du steuerst jetzt deinen Motor direkt, kann man so machen. 👍
                Ich glaube genau dafür ist jetzt das oben ☝ verlinkte Endstop cover zuständig
                Die ist auch "normal" in der yaml syntax verfügbar 👉 https://esphome.io/guides/automations.html#if-action
                • Andreios
                  Andreios Forum Testing @Beowolf last edited by
                  @beowolf sagte in GPIO Status Wemos d1 mini an iobroker senden:
                  @opensourcenomad
                  Ok, dann versuche ist es so.
                  Die Steuerung wollte durch ioBroker machen.
                  Die Anschlüsse:
                  D6; // Endschalter Tür offen
                  D5; // Endschalter Tür geschlossen
                  D0; // Taster Tür öffnen - für manuelles Öffnen vor Ort
                  D7; // Taster Tür schließen - für schließen vor Ort
                  D1; // Taster Bewegung anhalten - Lichtschranke falls sich ein Huhn im Türbereich aufhält.
                  Zur Sicherheit würde ich die Endschalter, die Taster und vor Allem die Lichtschranke nicht über ioBroker, sondern direkt auf dem Microcntroller steuern. Hast Du einmal eine Verzögerung in der Kommunikation, klemmt das Huhn in der Tür. 😉
                    Beowolf @Andreios last edited by
                    @andreas-5
                    Das soll auch auf jeden Fall so sein. Ich wollte nur durch ioBroker zusätzlich Einfluß nehmen können.
                    • OpenSourceNomad
                      OpenSourceNomad Most Active last edited by
                      @andreas-5 said in GPIO Status Wemos d1 mini an iobroker senden:
                      Ganz richtig die Endschalter sollten ja gleich von der endstop cover component berücksichtigt werden, für die Lichtschranke ist dann natürlich noch eine extra Logik von Nöten, z.B. um beim brechen der Schranke die Tür zu öffnen wenn diese noch nicht bereits geschlossen ist.
                        Beowolf @TT-Tom last edited by
                        @opensourcenomad
                        Ich habe das mit COVER jetzt gelöst.
                        cover:
                          - platform: template
                            open_action:
                                  target: 17000
                            close_action:
                                  target: -17000
                            stop_action:
                                  target: !lambda return id(motor).current_position;
                            optimistic: true
                        Ich kann jetzt per Webbrowser den Motor in beide Richtungen drehen lassen.
                          @tt-tom sagte in GPIO Status Wemos d1 mini an iobroker senden:
                          @beowolf
                          Ich versuche es mal auf meinem Elektronik board die Tage mal nachzubauen. Dann teste ich dein Programm mal parallel.
                          Gruß Tom
                          Kannst Du schon etwas sage?
                          Ich habe es mit esphome versucht. Das das einfacher ist kann ich jetzt so nicht bestätigen. Das Ändern des Codes geht etwas einfacher aber sonst hat es die "Programmiersprache" auch in sich. Leerzeichen sind wohl der blanke Horror für die Oberfläche.
                          T OpenSourceNomad 2 Replies Last reply Reply Quote 0
                            TT-Tom @Beowolf last edited by
                            @beowolf
                            Ich komme erst Montag wieder dazu. Melde mich dann hier wieder. Tom
                            • OpenSourceNomad
                              OpenSourceNomad Most Active @Beowolf last edited by OpenSourceNomad
                              Der "no code" approach von esphome benutzt übrigens YAML, selbst bezeichnet sich das als „YAML Ain’t Markup Language“, sprich es soll nicht mal eine "Auszeichnungssprache" sein. Wobei YAML natürlich eine (vereinfachte) markup language ist. Wahrscheinlich mit eine der einfachsten überhaupt.
                              Wie schon bereits erwähnt haben Leute mit Programmierkenntnisse aufgrund der Trivialität oft mehr Probleme als Mensch welcher noch keine Zeile hello world in seinem Leben geschrieben hat.
                              Leerzeichen
                              Das (richtige) einrücken mittels Leerzeichen (nicht tab) ist wenn yaml als block geschrieben essentiell. Neben der Pflicht jeden "key" nur einmal zu verwenden, also auf
                              doppelte Bezeichnung
                              zu verzichten sind dies wohl die einzigen wichtigen Vorgaben die bei YAML existieren.
                              Grundsätzliche könnte man ja auch einfach ein quasi endloses Menü erstellen um die ganzen Parameter auszuwählen, mehr macht man in der YAML ja de facto gar nicht. Nur ist es halt total unsinnig und unübersichtlich aus vielen 100 Optionen zu wählen wenn man selbst nur 10 oder 20 braucht, daher finde ich diesen Ansatz auch ziemlich überlegen.
                              Zum Vergleich gibt es z.B. in Tasmota mindestens 3 verschiedene Ecken um bestimmte Sachen einzustellen/definieren, ein paar gehen im webinterface, weitere müssen mit irgendwelchen set option in die Konsole gehämmert werden und wieder anderes muss schon vor der Kompilierung manuell in irgendwelche files geschrieben werden. Trotzdem wird es wahrscheinlich am Ende nicht annähernd so viel Flexibilität bieten wie esphome und ist trotzdem um einiges zeitintensiver in der Anwendung.
                              Im Vergleich zu deinem selbst programmierten code welches stand heute nicht in der Lage ist mit einer Zentrale (korrekt) zu kommunizieren? Ist das nicht vielleicht ein Vergleich von Äpfel mit Birnen? Überhaupt benötigt dein Ansatz nicht weniger als (gute) Programmierkenntnisse und natürlich eine vielfaches an Zeit um überhaupt ein erfolgreiches/funktionierendes Ergebnis zu bekommen.
                              Grundsätzlich ist "neu" nie einfach und man muss sich erst einmal einarbeiten, so viel ist klar 💡
                              wifi:
                                ssid: "-----"
                                password: "-------"
                              Um übrigens nicht in die Versuchung bzw. Möglichkeit zu kommen SSID und Passwort bzw. auch andere Passwörter zu posten empfiehlt sich eine secrets.yaml damit entfällt dann auch das repetitive ausfüllen dieser in neuen yaml's 🔒
                              Siehe dazu u.a. 👉 https://drozmotix.github.io/languages/de/Adapter/ESPHome/08.yamlTemplates.html#secrets-yaml
                                Na ja, den Code den ich hier mit ESPHome gemacht habe funktioniert ja auch nicht so ganz richitg. Die einzelnen Dinge escheinen zwar unter ioBroker, aber anprechen bzw. ändern lassen sie sich nicht. Per Browaser schon.
                                • OpenSourceNomad
                                  Welche denn genau? Wahrscheinlich alle die der iobroker adapter (9 Monate alt 😞 ) unterstützt 👇
                                  https://drozmotix.github.io/languages/de/Adapter/ESPHome/02.supportedTypes.html
                                  ...oder gar alle? Aber nur die unterstützen ☝ lassen sich schalten?
                                  Per Browaser schon.
                                  Was ja darauf hindeutet das es auf Seiten von iobroker hackt und nicht bei esphome 💡
                                  Eventuell willst du es mal mit mqtt versuchen 👉 https://esphome.io/components/mqtt.html
                                  Alternativ kannst du für die api dir natürlichauch mit hilfe der template switches was bauen 👉 https://esphome.io/components/switch/template.html
                                    @opensourcenomad
                                    So,
                                    ich habe mich jetzt das halbe WE damit rumgeschlagen.
                                    Ich habe es mit einem wirklich einfachem Programm versucht.
                                    esphome:
                                    esp8266:
                                      board: d1_mini
                                    stepper:
                                      - platform: a4988
                                        step_pin: D3
                                        dir_pin: D4
                                        sleep_pin:
                                            number: D2
                                            inverted: true
                                        acceleration: inf
                                        deceleration: inf
                                    # Enable logging
                                    logger:
                                    api:
                                      password: !secret api_password
                                    ota:
                                      password: !secret ota_password
                                    wifi:
                                      ssid:         !secret wifi_ssid
                                      password:     !secret wifi_password
                                    mqtt:
                                      broker: 192.168.49.38
                                      username: mqttuser
                                      password: !secret mqtt_password
                                    web_server:
                                      port: 80
                                    captive_portal:
                                    cover:
                                        open_action:
                                              target: 17000
                                        close_action:
                                              target: -17000
                                        stop_action:
                                                position: 0
                                                target: 0
                                        optimistic: true
                                    Einfach das COVER-Ding.
                                    Per Browser funktioniert es - in ioBroker wird es angezeigt.
                                    Ansprechen kann ich es nicht über ioBroker.
                                    Noch etwas - genau das wollte ich nicht
                                    Ich möchte nicht bei einem für mich neuem Adapter auf die Suche gehen warum es hier oder da nicht läuft. Entweder werden die Dinge unterstützt oder der Adapter ist nicht mehr als eine unausgegorene BETA-Version.
                                    ESPHOME mag ja ganz nett sein - aber meine Entscheidung ist- kann man machen, muß man aber ganz sicher nicht.
                                    Ich bin mit ESPHOME erst mal durch.
                                    Jeder weitere Hinweis das ich so oder so mal versuchen könnte kostet auch nur Zeit.
                                    Von Deinem Hinweis "und hier kommt schon die esphome magie in's Spiel," ist nicht viel geblieben.
                                    • OpenSourceNomad
                                      Steht ja in der (gerade erst ☝) verlinkten Doku vom esphome adapter welche Datentypen aktuell unterstützt werden. (Spoiler: das "COVER-Ding" ist nicht dabei 💡)
                                      Auch mein Hinweis das diese Limitation wahrscheinlich nur die Anbindung an iobroker mittels api (aka esphome adapter) betrifft und mqtt (wahrscheinlich?) alles bidirektional ermöglicht hattest du bereits bekommen. Um das zu testen müsstest du nicht mehr als die api: Zeile durch eine mqtt: Zeile (zzgl. deiner mqtt broker creds natürlich) ersetzen. 👇
                                      ...esphome ist so flexibel das du nicht mal den esphome adapter dafür benötigst 😉
                                        Das hatte ich nach Anleitung gemacht. Es kam sofort eine Fehlermeldung das die API fehlt.
                                        Bitte, bitte, bitte - ich bin mit ESPHOME durch.
                                        Bitte, bitte, bitte - keine weiteren Hinweise mehr.
                                        Ich WILL ESPHOME nicht mehr.
                                        OK?
                                          TT-Tom @Beowolf last edited by TT-Tom
                                          @beowolf
                                          Hier der Code. Das Programm reagiert jetzt auf den IoBroker. ich kann leider nicht alles nachstellen, weil mir zum testen ein Teil der Hardware fehlt. Probiere es bitte.
                                          #include <ESP8266WiFi.h>
                                          #include <ESP8266mDNS.h>
                                          #include <WiFiUdp.h>
                                          #include <ArduinoOTA.h>
                                          #include <ESP8266WebServer.h>
                                          #include <PubSubClient.h>
                                          #include <AccelStepper.h>
                                          #include <Adafruit_NeoPixel.h>
                                          #ifndef STASSID
                                          #define STASSID "-"
                                          #define STAPSK  "-"
                                          #endif
                                          #define ProgrammstartTuerAuf D0
                                          #define Enable D2 // Steppermotor aktivieren/deaktivieren
                                          #define PIN 3 // Umgesteuerter GPIO für die NEO-Led
                                          #define NUMPIXELS 1 // Anzal der LEDs
                                          const char* ssid = STASSID;
                                          const char* password = STAPSK;
                                          char* mqtt_client_id = "Huehnerklappe";
                                          const char* mqtt_server = "192.168.1-";
                                          const int mqtt_port = 1883;
                                          const char* mqtt_user = "";
                                          const char* mqtt_password = "";
                                          const byte pinTuerAuf = D6;    // Endschalter Tür offen
                                          const byte pinTuerZu = D5;   // Endschalter Tür geschlossen
                                          const byte pinTasterAuf = D0; // Taster Tür öffnen
                                          const byte pinTasterZu = D7;  // Taster Tür schließen
                                          const byte pinTasterStopp = D1; // Taster Bewegung anhalten
                                          const long SchritteUmdrehung = 200; // Schritte des Schrittmotors für 360 Grad der Tür
                                          const unsigned int TuerbewegungZu =  61000;
                                          const unsigned int TuerbewegungAuf = -61000;
                                          enum ZUSTAENDE {MANUELL, TUERZU, OEFFNEN, TUERAUF, SCHLIESSEN};
                                          byte zustand = MANUELL;
                                          WiFiClient espClient;
                                          PubSubClient mqttClient(espClient);
                                          ESP8266WebServer server(80);
                                          AccelStepper stepper(1, D3, D4);  //Pins für den Steppermotor STEP , DIR
                                          AccelStepper stepperauf(1, D3, D4);  //Pins für den Steppermotor STEP , DIR
                                          Adafruit_NeoPixel pixels = Adafruit_NeoPixel(1, PIN, NEO_GRB + NEO_KHZ800);
                                          void setup() {
                                          //GPIO Umsteuerung
                                          //GPIO 1 (TX) swap the pin to a GPIO.
                                          pinMode(1, FUNCTION_3);
                                          //GPIO 3 (RX) swap the pin to a GPIO.
                                          pinMode(3, FUNCTION_3);
                                            Serial.begin(9600);
                                            // Per WLAN mit dem Netzwerk verbinden
                                            Serial.print("Verbinden mit ");
                                            Serial.println(ssid);
                                            WiFi.begin(ssid, password);
                                            while (WiFi.status() != WL_CONNECTED) {
                                              delay(500);
                                              Serial.print(".");
                                          // Anfang Update über Wlan
                                            ArduinoOTA.onStart([]() {
                                              String type;
                                              if (ArduinoOTA.getCommand() == U_FLASH) {
                                                type = "sketch";
                                              } else { // U_FS
                                                type = "filesystem";
                                              // NOTE: if updating FS this would be the place to unmount FS using FS.end()
                                              Serial.println("Start updating " + type);
                                            ArduinoOTA.onEnd([]() {
                                              Serial.println("\nEnd");
                                            ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
                                              Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
                                            ArduinoOTA.onError([](ota_error_t error) {
                                              Serial.printf("Error[%u]: ", error);
                                              if (error == OTA_AUTH_ERROR) {
                                                Serial.println("Auth Failed");
                                              } else if (error == OTA_BEGIN_ERROR) {
                                                Serial.println("Begin Failed");
                                              } else if (error == OTA_CONNECT_ERROR) {
                                                Serial.println("Connect Failed");
                                              } else if (error == OTA_RECEIVE_ERROR) {
                                                Serial.println("Receive Failed");
                                              } else if (error == OTA_END_ERROR) {
                                                Serial.println("End Failed");
                                            ArduinoOTA.begin();
                                          // Ende Update über Wlan
                                            // Die IP vom Webserver auf dem seriellen Monitor ausgeben
                                            Serial.println("");
                                            Serial.println("WLAN verbunden.");
                                            Serial.println("IP Adresse: ");
                                            Serial.println(WiFi.localIP());
                                           // MQTT Brocker
                                            //connectToMQTT(); // Mit ioBroker Mqtt verbinden
                                             mqttClient.setServer(mqtt_server, mqtt_port);//MQTT Server, - Port
                                             mqttClient.setCallback(callback);
                                            server.onNotFound([](){
                                              server.send(404, "text/plain", "Link wurde nicht gefunden!");
                                            server.on("/", []() {
                                              server.send(200, "text/plain", "Startseite");
                                            server.on("/WebTuerAuf", []() {
                                              server.send(200, "text/plain", "Tuer wird geoeffnet.");
                                              WebTuerAuf();
                                            server.on("/WebTuerZu", []() {
                                              server.send(200, "text/plain", "Tuer wird geschlossen.");
                                              WebTuerZu();
                                            server.begin();
                                            Serial.println("Webserver gestartet.");
                                            pixels.begin(); // This initializes the NeoPixel library.
                                            Serial.println("Programmanfang");
                                            pinMode(PIN, OUTPUT); // NEO-LED
                                            pinMode(pinTuerAuf, INPUT_PULLUP);    // Endschalter Tür offen
                                            pinMode(pinTuerZu, INPUT_PULLUP);   // Endschalter Tür geschlossen
                                            pinMode(pinTasterAuf, INPUT_PULLUP);  // Taster Tür öffnen
                                            pinMode(pinTasterZu, INPUT_PULLUP); // Taster Tür schließen
                                            pinMode(pinTasterStopp, INPUT_PULLUP);  // Taster Bewegung anhalten
                                            pinMode(ProgrammstartTuerAuf, OUTPUT);
                                            stepper.setMaxSpeed(1000);
                                            stepperauf.setMaxSpeed(6000);
                                            stepper.setAcceleration(1500);
                                            stepperauf.setAcceleration(6000);
                                            pinMode(Enable, OUTPUT); // Enable Motor 1
                                          //ende Setup
                                          void loop() {
                                            ArduinoOTA.handle();
                                            ArduinoOTA.setHostname("Huehnerklappe");
                                            server.handleClient();
                                            digitalWrite(Enable, LOW);  //Motor aktiviert
                                            stepper.run();
                                            stepperauf.run();
                                            digitalWrite(ProgrammstartTuerAuf, digitalRead(pinTuerAuf));
                                            if (!digitalRead(pinTasterStopp)) {
                                              zustand = MANUELL;
                                                 pixels.setPixelColor(0, pixels.Color(255,255,255));  //LED Farbe weiss
                                                 pixels.show();
                                            switch (zustand) {
                                          // Manuelle Steuerung
                                              case MANUELL:
                                                if ((!digitalRead(pinTasterAuf)) && (digitalRead(pinTuerAuf))) {
                                                  stepper.move(10);
                                                } else if ((!digitalRead(pinTasterZu)) && (digitalRead(pinTuerZu))) {
                                                  stepper.move(-10);
                                                } else {
                                                  stopp();
                                                if (!digitalRead(pinTuerZu)) {
                                                  zustand = TUERZU;
                                                  Serial.println("Tuer geschlossen");
                                                if (!digitalRead(pinTuerAuf)) {
                                                  zustand = TUERAUF;
                                                  Serial.println("Tuer geoeffnet");
                                                break;
                                          // Tür wird geöffnet
                                              case TUERZU:
                                                stopp();
                                                if (!digitalRead(pinTasterAuf)) {
                                                  stepperauf.move(pos(TuerbewegungAuf));
                                                  zustand = OEFFNEN;
                                                  Serial.print("Tuer oeffnet ... ");
                                                    pixels.setPixelColor(0, pixels.Color(0,0,255));  //LED Farbe blau
                                                    pixels.show();
                                          // Schaltzustände übermitteln
                                            if(digitalRead(pinTuerAuf) == HIGH){
                                              mqttClient.publish("Huehnertuer/Innen/Tuer_oeffnet", "1");
                                              mqttClient.publish("Huehnertuer/Innen/Tuer_auf", "0");
                                              mqttClient.publish("Huehnertuer/Innen/Tuer_schliesst", "0");
                                              mqttClient.publish("Huehnertuer/Innen/Tuer_zu", "0");
                                                break;
                                          // Tür ist offen
                                              case OEFFNEN:
                                                  zustand = TUERAUF;
                                                    pixels.setPixelColor(0, pixels.Color(255,0,0));  //LED Farbe rot
                                                    pixels.show();
                                            if(digitalRead(pinTuerAuf) == LOW){
                                              mqttClient.publish("Huehnertuer/Innen/Tuer_oeffnet", "0");
                                              mqttClient.publish("Huehnertuer/Innen/Tuer_auf", "1");
                                                break;
                                          // Tür wir geschlossen
                                              case TUERAUF:
                                                stopp();
                                                if (!digitalRead(pinTasterZu)) {
                                                  stepper.move(pos(TuerbewegungZu));
                                                  zustand = SCHLIESSEN;
                                                  Serial.print("Tuer schliesst ... ");
                                                    pixels.show();
                                            if(digitalRead(pinTuerZu) == HIGH){
                                              mqttClient.publish("Huehnertuer/Innen/Tuer_schliesst", "1");
                                                break;
                                          // Tür ist geschlossen
                                              case SCHLIESSEN:
                                                  zustand = TUERZU;
                                                    pixels.setPixelColor(0, pixels.Color(0, 255,0));  //LED Farbe grün
                                                    pixels.show();
                                            if(digitalRead(pinTuerZu) == LOW){
                                              mqttClient.publish("Huehnertuer/Innen/Tuer_zu", "1");
                                                break;
                                           if (!mqttClient.connected()) {
                                              reconnectToMQTT();
                                            mqttClient.loop();
                                          //ende loop
                                          long pos(int winkel) {
                                            return (winkel * SchritteUmdrehung / 360L);
                                          void WebTuerAuf(){
                                                  zustand = OEFFNEN;
                                                    pixels.show();
                                          void WebTuerZu(){
                                                    pixels.show();
                                          void stopp() {
                                            stepper.stop();
                                            digitalWrite(Enable, HIGH); //Motor deaktiviert
                                          // MQTT Funktion
                                          void reconnectToMQTT() {
                                          // mqttClient.setServer(mqtt_server, mqtt_port);//MQTT Server, - Port
                                          // mqttClient.setCallback(callback);
                                           while (!mqttClient.connected()) {
                                            if (mqttClient.connect(mqtt_client_id , mqtt_user, mqtt_password)) {
                                              Serial.println("Per MQTT mit ioBroker verbunden");
                                              mqttClient.subscribe("Huehnertuer/Innen/Tuer");
                                            }else {
                                                Serial.print("failed with state ");
                                                Serial.print(mqttClient.state());
                                                Serial.println(" try again in 5 seconds");
                                                // Wait 5 seconds before retrying
                                                delay(5000);
                                          void callback(char* topic, byte* payload, unsigned int length)
                                            Serial.print("Message arrived [");
                                            Serial.print(topic);
                                            Serial.print("] ");
                                            Serial.println();
                                           payload[length] = '\0';
                                           String strTopic = String(topic);
                                           String strPayload = String((char * ) payload);
                                           Serial.println(strTopic);
                                           Serial.println(strPayload);
                                           if(strTopic == "Huehnertuer/Innen/Tuer")
                                             if(strPayload == "false") // Tuer schliessen
                                              digitalWrite(pinTasterZu, LOW);
                                             if(strPayload == "true") // Tuer öffnen
                                              digitalWrite(pinTasterAuf, LOW);
                                          es gibt auch Beispiel code auf der GitHub Seite von der PubSubClient.h
                                          Gruß Tom
                                          • OpenSourceNomad
                                            Da übrigens nicht nur esphome sondern auch der esphome iobroker adapter (hier mangelt es aktuell⚠) open source ist kann jeder (zumindest mit know how was Programmierung und iobroker) hier was gutes tun und code beisteueren um neue esphome Funktionen in iobroker über die native api zu Verfügung zu stellen 💡
                                            👉 https://github.com/DrozmotiX/ioBroker.esphome
                                            Ich denke das Hauptproblem wird sein das esphome einfach ein ziemlich zügiges Tempo an den Tag legt was die Entwicklung angeht (u.a. mit einem hauptberuflichen Entwickler) und der adapter für iobroker eben nur von Freiwilligen (wahrscheinlich ausschließlich in ihrer Freizeit) entwickelt wird. 💡
                                            Kein Zwang, du machst was du willst 😉
                                            OK
                                            16660
