    4. Anfrage Tahoma/Somfy IO Adapter
      pfahlenbauer last edited by
      @StrathCole
      Finde ich super, wenn das nun lokal läuft.
      Ich habe gestern umgestellt und bekomme folgende warn Meldungen im Log.
      tahoma.0
      2022-05-13 08:22:12.860	warn	Could not state-data for channel devices.Dachfenster_Winterg_.states.core:ManufacturerSettingsState Raw-data: [object Object]
      tahoma.0
      2022-05-13 08:21:47.876	warn	Could not state-data for channel devices.Dachfenster_Winterg_.states.core:ManufacturerSettingsState Raw-data: [object Object]
      tahoma.0
      2022-05-13 08:21:37.862	warn	Could not state-data for channel devices.Eltern_rechts.states.core:ManufacturerSettingsState Raw-data: [object Object]
      tahoma.0
      2022-05-13 08:21:37.862	warn	Could not state-data for channel devices.Eltern_links.states.core:ManufacturerSettingsState Raw-data: [object Object]
      tahoma.0
      2022-05-13 08:21:37.861	warn	Could not state-data for channel devices.Laura_rechts.states.core:ManufacturerSettingsState Raw-data: [object Object]
      tahoma.0
      2022-05-13 08:21:37.860	warn	Could not state-data for channel devices.Anna_Mitte.states.core:ManufacturerSettingsState Raw-data: [object Object]
      tahoma.0
      2022-05-13 08:21:37.859	warn	Could not state-data for channel devices.Anna_rechts.states.core:ManufacturerSettingsState Raw-data: [object Object]
      tahoma.0
      2022-05-13 08:21:37.858	warn	Could not state-data for channel devices.Laura_links.states.core:ManufacturerSettingsState Raw-data: [object Object]
      tahoma.0
      2022-05-13 08:21:37.857	warn	Could not state-data for channel devices.Laura_Mitte.states.core:ManufacturerSettingsState Raw-data: [object Object]
      tahoma.0
      2022-05-13 08:21:32.886	warn	Could not state-data for channel devices.Anna_links.states.core:ManufacturerSettingsState Raw-data: [object Object]
      tahoma.0
      2022-05-13 08:21:27.868	warn	Could not state-data for channel devices.Dachfenster_Winterg_.states.core:ManufacturerSettingsState Raw-data: [object Object]
      tahoma.0
      2022-05-13 08:21:17.845	warn	Could not state-data for channel devices.Bad_Eltern.states.core:ManufacturerSettingsState Raw-data: [object Object]
      tahoma.0
      2022-05-13 08:21:17.844	warn	Could not state-data for channel devices.Bad_Kinder_rechts.states.core:ManufacturerSettingsState Raw-data: [object Object]
      tahoma.0
      2022-05-13 08:21:17.843	warn	Could not state-data for channel devices.Bad_Kinder_links.states.core:ManufacturerSettingsState Raw-data: [object Object]
        wusa last edited by wusa
        Ich habe zwar gestern nicht umgestellt, aber gestern kam ein Update von Somfy für Tahoma selbst. Ich glaube, dass es damit zusammen hängt.
        Ich bekomme nämlich auch diese Meldungen:
        Could not state-data for channel devices.Wohnzimmer.states.core:ManufacturerSettingsState Raw-data: [object Object]
        Vor dem Update von Somfy für Tahoma, lief es mit der lokalen API nämlich ohne Meldungen.
        StrathCole 1 Reply Last reply Reply Quote 0
        • StrathCole
          StrathCole @wusa last edited by StrathCole
          Das hat damit zu tun, dass Somfy im neuen Update der Box (Firmware) die Events nun gefixt hat und diese funktionieren. Allerdings konnte ich sie im Update vorher nicht testen, kann also sein, dass sie etwas anders funktionieren als in der Cloud.
          Weiß nicht, ob sich @Excodibur das anschaut?
          Zur Info dazu: https://github.com/Somfy-Developer/Somfy-TaHoma-Developer-Mode/issues/4
          iMicknl created this issue in Somfy-Developer/Somfy-TaHoma-Developer-Mode
          closed Cannot register (local) event listener #4
          • StrathCole
            StrathCole last edited by
            Sollte hiermit behoben werden: https://github.com/Excodibur/ioBroker.tahoma/pull/136
            StrathCole created this issue in Excodibur/ioBroker.tahoma
            closed Json variable type fixed #136
            Excodibur 1 Reply Last reply Reply Quote 2
            • Excodibur
              Excodibur Developer @StrathCole last edited by
              @strathcole Da muss ich ja gar nichts mehr machen. 😉
              https://github.com/Excodibur/ioBroker.tahoma/releases/tag/v0.7.1 (Zeitnah im BETA-Repo verfügbar).
              StrathCole 1 Reply Last reply Reply Quote 1
              • StrathCole
                StrathCole @Excodibur last edited by
                @excodibur Ja durch den Post von @wusa, dass es ein Firmware-Update von Tahoma gab, dachte ich mir dann, woran es liegen wird. Vorher waren die lokalen Events ja noch inaktiv.
                  pfahlenbauer @StrathCole last edited by
                  @strathcole
                  Danke für's fixen.
                  Ich bekomme leider immer noch eine warn Meldung, die sieht jetzt so aus:
                  2022-05-20 07:51:05.558 - warn: tahoma.0 (1772) error during request: null, request path: history/executions/6132bd05-xxxx-484c-b62d-b040942e22ef with payload:{}
                  2022-05-20 07:51:05.572 - warn: tahoma.0 (1772) Response: {"statusCode":400,"body":"{\"error\":\"Unknown object.\",\"errorCode\":\"UNSPECIFIED_ERROR\"}","headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"59","connection":"close","date":"Fri, 20 May 2022 05:51:05 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-1XXX-0XXX-XXXX:8443","port":"8443","hostname":"gateway-1XXX-0XXX-XXXX","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/history/executions/6132bd05-xxxx-484c-b62d-b040942e22ef","path":"/enduser-mobile-web/1/enduserAPI/history/executions/6132bd05-xxxx-484c-b62d-b040942e22ef","href":"https://gateway-1XXX-0XXX-XXXX:8443/enduser-mobile-web/1/enduserAPI/history/executions/6132bd05-xxxx-484c-b62d-b040942e22ef"},"method":"GET","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 627dXXXX1cd8e68d8c4e","Content-type":"application/json"}}}2022-05-20 07:51:05.573 - warn: tahoma.0 (1772) Body: "{\"error\":\"Unknown object.\",\"errorCode\":\"UNSPECIFIED_ERROR\"}"
                  2022-05-20 07:51:05.573 - warn: tahoma.0 (1772) Failed getting execution state for 6132bd05-xxxx-484c-b62d-b040942e22ef
                    wusa @pfahlenbauer last edited by
                    @StrathCole
                    Ich habe auch gerade das Update gemacht.
                    Leider habe ich auch weiterhin einen Fehler:
                    tahoma.0
                    2022-05-23 11:10:32.115	warn	error during request: Error: getaddrinfo ENOTFOUND gateway-1xxx-1xxx-7xxx, request path: setup/gateways with payload:{}
                    • StrathCole
                      @wusa In der Konfig mal versuchen, mDNS zu aktivieren.
                        Dakusk last edited by Dakusk
                        Hallo Zusammen,
                        Hatte mit dem Adapter diverse andere Schwierigkeiten (keine Reaktion nachdem ein Befehl gesendet wurde), die dazu geführt haben, dass ich meinen Iobroker neu aufgesetzt habe. Nun habe ich die gleiche Fehlermeldung wie @wusa
                        Habe bisher die etc/Hosts erweitert.
                        mDNS aktiviert und deaktiviert
                        Hier ist der Log nach dem Start des Adapters... "Setup Failed" sehe ich nun auch zum ersten Mal.
                        2022-05-23 20:52:48.599 - info: tahoma.0 (570) [START] Starting adapter tahoma v0.7.1.3
                        2022-05-23 20:52:48.600 - info: tahoma.0 (570) Configured polling interval: 20000
                        2022-05-23 20:52:48.600 - info: tahoma.0 (570) Adapter will connect to Tahoma Box via local API.
                        2022-05-23 20:52:48.601 - info: tahoma.0 (570) Using stored bearer token 628bf3f2dddeae56b219
                        2022-05-23 20:52:48.657 - warn: tahoma.0 (570) error during request: Error: getaddrinfo ENOTFOUND gateway-1XXX-2XXX-9XXX.local, request path: setup with payload:{}
                        2022-05-23 20:52:48.658 - warn: tahoma.0 (570) setup failed!
                        2022-05-23 20:52:48.658 - warn: tahoma.0 (570) {"error":{"errno":-3008,"code":"ENOTFOUND","syscall":"getaddrinfo","hostname":"gateway-1XXX-2XXX-9XXX.local"}}
                        2022-05-23 20:52:58.620 - warn: tahoma.0 (570) error during request: Error: getaddrinfo ENOTFOUND gateway-1XXX-2XXX-9XXX.local, request path: setup/gateways with payload:{}
                        2022-05-23 20:53:28.640 - warn: tahoma.0 (570) error during request: Error: getaddrinfo ENOTFOUND gateway-1XXX-2XXX-9XXX.local, request path: setup/gateways with payload:{}
                        2022-05-23 20:53:58.659 - warn: tahoma.0 (570) error during request: Error: getaddrinfo ENOTFOUND gateway-1XXX-2XXX-9XXX.local, request path: setup/gateways with payload:{}
                          Dakusk @Dakusk last edited by
                          @dakusk
                          Okay Problem selber gelöst bekommen. Tatsächlich hat mein System die etc/hosts nach jedem reboot überschrieben.
                          Jetzt tauchen wieder die Fehler wie vor der Neuinstallation auf.
                          2022-05-23 21:57:01.002 - warn: tahoma.1 (464) error during request: null, request path: history/executions/82cdf30b-51e7-497b-9116-03438574b3a2 with payload:{}
                          2022-05-23 21:57:01.003 - warn: tahoma.1 (464) Response: {"statusCode":400,"body":"{\"error\":\"Unknown object.\",\"errorCode\":\"UNSPECIFIED_ERROR\"}","headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"59","connection":"close","date":"Mon, 23 May 2022 21:57:00 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-1208-2847-9785.local:8443","port":"8443","hostname":"gateway-1208-2847-9785.local","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/history/executions/82cdf30b-51e7-497b-9116-03438574b3a2","path":"/enduser-mobile-web/1/enduserAPI/history/executions/82cdf30b-51e7-497b-9116-03438574b3a2","href":"https://gateway-1XXX-2XXX-9XXX.local:8443/enduser-mobile-web/1/enduserAPI/history/executions/82cdf30b-51e7-497b-9116-03438574b3a2"},"method":"GET","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 627788a7e67b661cc13a","Content-type":"application/json"}}}
                          2022-05-23 21:57:01.003 - warn: tahoma.1 (464) Body: "{\"error\":\"Unknown object.\",\"errorCode\":\"UNSPECIFIED_ERROR\"}"
                          2022-05-23 21:57:01.003 - warn: tahoma.1 (464) Failed getting execution state for 82cdf30b-51e7-497b-9116-03438574b3a2
                          2022-05-23 21:57:01.016 - warn: tahoma.1 (464) error during request: null, request path: history/executions/65fba7f7-33a6-4d47-9704-b353af2fed38 with payload:{}
                          2022-05-23 21:57:01.016 - warn: tahoma.1 (464) Response: {"statusCode":400,"body":"{\"error\":\"Unknown object.\",\"errorCode\":\"UNSPECIFIED_ERROR\"}","headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"59","connection":"close","date":"Mon, 23 May 2022 21:57:00 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-1XXX-2XXX-9XXX.local:8443","port":"8443","hostname":"gateway-1XXX-2XXX-9XXX.local","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/history/executions/65fba7f7-33a6-4d47-9704-b353af2fed38","path":"/enduser-mobile-web/1/enduserAPI/history/executions/65fba7f7-33a6-4d47-9704-b353af2fed38","href":"https://gateway-1XXX-2XXX-9XXX.local:8443/enduser-mobile-web/1/enduserAPI/history/executions/65fba7f7-33a6-4d47-9704-b353af2fed38"},"method":"GET","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 627788a7e67b661cc13a","Content-type":"application/json"}}}
                          2022-05-23 21:57:01.016 - warn: tahoma.1 (464) Body: "{\"error\":\"Unknown object.\",\"errorCode\":\"UNSPECIFIED_ERROR\"}"
                          2022-05-23 21:57:01.016 - warn: tahoma.1 (464) Failed getting execution state for 65fba7f7-33a6-4d47-9704-b353af2fed38
                          2022-05-23 21:57:01.031 - warn: tahoma.1 (464) error during request: null, request path: history/executions/b41a285c-0a9b-4a6d-8b66-c7f0c1420fc3 with payload:{}
                          2022-05-23 21:57:01.032 - warn: tahoma.1 (464) Response: {"statusCode":400,"body":"{\"error\":\"Unknown object.\",\"errorCode\":\"UNSPECIFIED_ERROR\"}","headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"59","connection":"close","date":"Mon, 23 May 2022 21:57:01 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-1XXX-2XXX-9XXX.local:8443","port":"8443","hostname":"gateway-1XXX-2XXX-9XXX.local","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/history/executions/b41a285c-0a9b-4a6d-8b66-c7f0c1420fc3","path":"/enduser-mobile-web/1/enduserAPI/history/executions/b41a285c-0a9b-4a6d-8b66-c7f0c1420fc3","href":"https://gateway-1XXX-2XXX-9XXX.local:8443/enduser-mobile-web/1/enduserAPI/history/executions/b41a285c-0a9b-4a6d-8b66-c7f0c1420fc3"},"method":"GET","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 627788a7e67b661cc13a","Content-type":"application/json"}}}
                          2022-05-23 21:57:01.032 - warn: tahoma.1 (464) Body: "{\"error\":\"Unknown object.\",\"errorCode\":\"UNSPECIFIED_ERROR\"}"
                          2022-05-23 21:57:01.032 - warn: tahoma.1 (464) Failed getting execution state for b41a285c-0a9b-4a6d-8b66-c7f0c1420fc3
                          2022-05-23 21:57:15.963 - warn: tahoma.1 (464) error during request: null, request path: history/executions/5787ffbb-1245-408b-b093-e962a0dd9d15 with payload:{}
                          2022-05-23 21:57:15.963 - warn: tahoma.1 (464) Response: {"statusCode":400,"body":"{\"error\":\"Unknown object.\",\"errorCode\":\"UNSPECIFIED_ERROR\"}","headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"59","connection":"close","date":"Mon, 23 May 2022 21:57:15 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-1XXX-2XXX-9XXX.local:8443","port":"8443","hostname":"gateway-1XXX-2XXX-9XXX.local","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/history/executions/5787ffbb-1245-408b-b093-e962a0dd9d15","path":"/enduser-mobile-web/1/enduserAPI/history/executions/5787ffbb-1245-408b-b093-e962a0dd9d15","href":"https://gateway-1XXX-2XXX-9XXX.local:8443/enduser-mobile-web/1/enduserAPI/history/executions/5787ffbb-1245-408b-b093-e962a0dd9d15"},"method":"GET","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 627788a7e67b661cc13a","Content-type":"application/json"}}}
                          2022-05-23 21:57:15.963 - warn: tahoma.1 (464) Body: "{\"error\":\"Unknown object.\",\"errorCode\":\"UNSPECIFIED_ERROR\"}"
                          2022-05-23 21:57:15.963 - warn: tahoma.1 (464) Failed getting execution state for 5787ffbb-1245-408b-b093-e962a0dd9d15
                          StrathCole W S 3 Replies Last reply Reply Quote 0
                          • StrathCole
                            StrathCole @Dakusk last edited by
                            @dakusk Zu welchen Zeitpunkten treten diese auf? Nach einem Befehl oder einfach so?
                              wusa @StrathCole last edited by
                              @strathcole
                              Perfekt, Danke.
                              Das hat mein Problem gelöst.
                                wusa @Dakusk last edited by
                                @dakusk sagte in Anfrage Tahoma/Somfy IO Adapter:
                                @dakusk
                                @StrathCole
                                Genau die selben Fehler treten jetzt bei mir doch auch auf.
                                Bei mir passiert das, wenn ein Rollladen gefahren wird.
                                Also wenn keine Bewegung ist, dann kein Logeintrag.
                                Fahre ich aber einen Rollladen kommen 4 Logeinträge.
                                tahoma.0
                                2022-05-24 12:51:09.918 Failed getting execution state for 8da08f3b-e144-xxxx-xxxx-d5b8858f9b5a
                                tahoma.0
                                2022-05-24 12:51:09.917	warn	 Body: "{\"error\":\"Unknown object.\",\"errorCode\":\"UNSPECIFIED_ERROR\"}"
                                tahoma.0
                                2022-05-24 12:51:09.916	warn	 Response: {"statusCode":400,"body":"{\"error\":\"Unknown object.\",\"errorCode\":\"UNSPECIFIED_ERROR\"}","headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"59","connection":"close","date":"Tue, 24 May 2022 10:51:09 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-1xxx-1xxx-7xxx.local:8443","port":"8443","hostname":"gateway-1xxx-1xxx-7xxx.local","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/history/executions/8da08f3b-e144-xxxx-xxxx-d5b8858f9b5a","path":"/enduser-mobile-web/1/enduserAPI/history/executions/8da08f3b-e144-xxxx-xxxx-d5b8858f9b5a","href":"https://gateway-1xxx-1xxx-7xxx.local:8443/enduser-mobile-web/1/enduserAPI/history/executions/8da08f3b-e144-xxxx-xxxx-d5b8858f9b5a"},"method":"GET","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 62627697f0xxxx5b66360","Content-type":"application/json"}}}
                                tahoma.0
                                2022-05-24 12:51:09.915	warn	 error during request: null, request path: history/executions/8da08f3b-e144-xxxx-xxxx-d5b8858f9b5a with payload:{}
                                  mike2712 last edited by
                                  ständig ist die Box gesperrt von Somfy, die Hotline von Somfy erklärte das die Abfrage Zeiten von ioBroker das Problem sind, die habe ich jetzt auf 1 Stunde erhöht, weiterhin das selbe Problem, aktiviere ich den Adpater, ist die Box nach kurze Zeit gesperrt.
                                  Ich habe hier gelesen das einige ähnliche Probleme damit haben, leider aber keine Lösung gefunden, mich wundert das es ja doch bei einigen offensichtlich funktioniert.
                                  Der Abrufintervall wird offensichtlich in ms eingegeben, gibt es hier Grenzen?
                                  Jemand eine Idee was bei mir falsch läuft, ich möchte ja nicht täglich bei Somfy anrufen, allerdings würde ich aber auch gerne die ioBroker Anbindung haben wollen.
                                    wusa @mike2712 last edited by
                                    @mike2712
                                    Welche Box hast du?
                                    Du könntest auf die lokale API umstellen, dann sollte das ganze Spiel ein Ende haben.
                                    Ich selbst habe wegen dem auch schon 3x bei Somfy angerufen.
                                    Hatte zum Schluss das Intervall auf 12 Stunden stehen.
                                    Seit der Umstellung auf die lokale API habe ich Ruhe.
                                      Tom37 last edited by Tom37
                                      ich habe die Beta-Version 0.7.1 im Einsatz und verwende den Adapter, um ein Tor mit einer Somfy-Steuerung über eine Tahoma-Box zu steuern. Das funktioniert seit der Verwendung des Local API ohne Probleme, vorher hatte ich immer wieder die bekannten Verbindungsprobleme. Ich wollte aber lediglich mal melden, dass ich im Log immer wieder Warnings bekomme. Die Funktion scheint hierdurch aber nicht beeinträchtigt zu sein. Vielen Dank an den/die Entwickler für die hervorragende Arbeit!
                                      2022-05-26 19:17:28.268 - warn: tahoma.0 (4314) error during request: null, request path: history/executions/xxx with payload:{}
                                      2022-05-26 19:17:28.271 - warn: tahoma.0 (4314) Response: {"statusCode":400,"body":"{\"error\":\"Unknown object.\",\"errorCode\":\"UNSPECIFIED_ERROR\"}","headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"59","connection":"close","date":"Thu, 26 May 2022 17:17:28 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-xxx","port":"xxx","hostname":"gateway-xxx","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/history/executions/xxx","path":"/enduser-mobile-web/1/enduserAPI/history/executions/xxx","href":"https://gateway-xxx/enduser-mobile-web/1/enduserAPI/history/executions/xxx"},"method":"GET","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer xxx","Content-type":"application/json"}}}
                                      2022-05-26 19:17:28.272 - warn: tahoma.0 (4314) Body: "{\"error\":\"Unknown object.\",\"errorCode\":\"UNSPECIFIED_ERROR\"}"
                                      2022-05-26 19:17:28.273 - warn: tahoma.0 (4314) Failed getting execution state for xxx
                                      (Ein paar Daten habe ich durch "xxx" ersetzt, da ich mir nicht sicher war, ob ich das teilen sollte ...)
                                      Viele Grüße,
                                      Tom
                                        mike2712 @wusa last edited by
                                        @wusa
                                        ich habe die Tahoma Switch.
                                        Wie sind den die Einstellungen für den Abrufintervall ? Ich hatte schon versucht damit zu testen, vermutlich ging es nicht da die Box gesperrt war.
                                        Weiterhin habe ich das Problem das sie nicht in exakt dem selben Netz liegen, da gab es offensichtlich auch Probleme.
                                        Die Fritz Box liegt im 172.16.10.xx , Die Tahoma Switch liegt bei 172.16.20.xx.
                                        Wie kann ich Testen ob das Lokal API wirklich funktioniert?
                                          wusa @wusa last edited by
                                          @wusa sagte in Anfrage Tahoma/Somfy IO Adapter:
                                          Ist der iobroker und Tahoma im selben Netz?
                                          Habe bei mir festgestellt, über 2 Subnetze hinweg geht es leider nicht.
                                          @mike2712
                                          Ich zitiere mich mal schnell selbst.
                                          Über 2 Subnetze hinweg geht es leider nicht.
                                          Ich musste meine Tahoma Box auch in das selbe Netz wie den ioBroker bringen. Dann lief es mit mDNS ohne Probleme.
                                          Excodibur 1 Reply Last reply Reply Quote 0
                                          • Excodibur
                                            Excodibur Developer @wusa last edited by
                                            @wusa @mike2712
                                            Oder ihr deaktiviert "Use MDNS" in den Adapter Einstellungen, dann müsste es auch über mehrere Netze gehen, solange der Name aufgelöst werden kann. Im Härtefall können man die Names-Auflösung in der hosts-Datei auch manuell eintragen.
                                            605
                                            157528
