    3. Off Topic
    4. Ausstieg aus ndcu
    Ausstieg aus ndcu
      crunchip Forum Testing Most Active @GOETSCHHOFER last edited by
      @goetschhofer sagte in Ausstieg aus ndcu:
      Task Histroy in proxmox
      Das ist was anderes, es geht ums backup vom backitup Adapter
        GOETSCHHOFER last edited by GOETSCHHOFER
        @crunchip
        Wie kann ich mir das log vom backitup-Adapter anschauen ?
        Im Adapter selbst finde ich nichts.
          crunchip Forum Testing Most Active @GOETSCHHOFER last edited by crunchip
          @goetschhofer auf debug stellen, backup manuell machen
          Edit
          anderfalls die ganze Instanz auf debug stellen, wenn das oben gezeigte nicht genügend Informationen liefert
            GOETSCHHOFER @crunchip last edited by GOETSCHHOFER
            @crunchip
            Kann es sein, dass er die Dateien bis auf eingestellte 3 nicht löscht, da ich bei Grafana-backitup eine Fehlermeldung habe ?
            Grafana-Fehlermeldung:
            [DEBUG] [grafana] - start Grafana request ...
            [DEBUG] [grafana] - Grafana is available ... Status: 200
            [DEBUG] [grafana] - Error on Grafana Dashoard Request: Error: Request failed with status code 401
            [DEBUG] [grafana] - start Grafana backup compress ...
            [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
            [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
            [DEBUG] [grafana] - cannot found Grafana Backup files
            [DEBUG] [grafana] - done
            Started iobroker ...
            [DEBUG] [iobroker] start with {"type":"creator","time":"19:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.1.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"dir":"/","dirMinimal":"/backupDir/iobroker","user":"iobroker_backitup","pass":"","port":"21"},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.1.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"dir":"/","dirMinimal":"/backupDir/iobroker","user":"iobroker_backitup","pass":"","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"ftp","mount":"192.168.1.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"FRITZ.NAS/USB2-0-DISK-01/RSPPI3BACKUP","dirMinimal":"sharename/backupDir","user":"iobroker_backitup","pass":""},"dropbox":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessToken":"","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"username":"username","pass":"","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessJson":"","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.1.177","port":"8088","exe":"","dbType":"remote","deleteDataBase":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.1.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"dir":"/","dirMinimal":"/backupDir/iobroker","user":"iobroker_backitup","pass":"","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"ftp","mount":"192.168.1.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"FRITZ.NAS/USB2-0-DISK-01/RSPPI3BACKUP","dirMinimal":"sharename/backupDir","user":"iobroker_backitup","pass":""},"dropbox":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessToken":"","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"username":"username","pass":"","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessJson":"","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"filePath":"/home/iobroker/skripte"},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.1.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"dir":"/","dirMinimal":"/backupDir/iobroker","user":"iobroker_backitup","pass":"","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"ftp","mount":"192.168.1.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"FRITZ.NAS/USB2-0-DISK-01/RSPPI3BACKUP","dirMinimal":"sharename/backupDir","user":"iobroker_backitup","pass":""},"dropbox":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessToken":"","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"username":"username","pass":"","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessJson":"","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"host":"192.168.1.178","port":"3000","protocol":"http","username":"admin","pass":"","apiKey":""},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"shortEmailNotice","emailReceiver":"karl.goetschhofer@utanet.at","emailSender":"karl.goetschhofer@gmail.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
            [DEBUG] [iobroker] - host.IOBROKER 5214 states saved
            [DEBUG] [iobroker] - host.IOBROKER 5862 objects saved
            [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2022_05_25-06_38_16_backupiobroker.tar.gz
            [DEBUG] [iobroker] - done
            [DEBUG] [influxDB] - Start InfluxDB Backup ...
            [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
            [DEBUG] [influxDB] - Packed 141MB so far...
            [DEBUG] [influxDB] - Packed 284MB so far...
            [DEBUG] [influxDB] - Packed 428MB so far...
            [DEBUG] [influxDB] - Packed 573MB so far...
            [DEBUG] [influxDB] - Packed 714MB so far...
            [DEBUG] [influxDB] - Packed 860MB so far...
            [DEBUG] [influxDB] - Packed 1004MB so far...
            [DEBUG] [influxDB] - Packed 1149MB so far...
            [DEBUG] [influxDB] - Packed 1293MB so far...
            [DEBUG] [influxDB] - Packed 1437MB so far...
            [DEBUG] [influxDB] - Packed 1581MB so far...
            [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2022_05_25-06_38_20_backupiobroker.tar.gz
            [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
            [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
            [DEBUG] [influxDB] - done
            [DEBUG] [grafana] - Start Grafana Backup ...
            [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
            [DEBUG] [grafana] - Created dashboard directory
            [DEBUG] [grafana] - Created dashboards_manually_restore directory
            [DEBUG] [grafana] - Created datasource directory
            [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2022_05_25-06_41_09_backupiobroker.tar.gz
            [DEBUG] [javascripts] - done
            [DEBUG] [ftp] start with {"type":"storage","source":"ftp","host":"192.168.1.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"dir":"/","dirMinimal":"/backupDir/iobroker","user":"iobroker_backitup","pass":"","port":"21","deleteBackupAfter":0}
            [DEBUG] [ftp] - FTP connected.
            [DEBUG] [ftp] - Send iobroker_2022_05_25-06_38_16_backupiobroker.tar.gz
            [DEBUG] [ftp] - Send influxDB_2022_05_25-06_38_20_backupiobroker.tar.gz
            [DEBUG] [ftp] - Send javascripts_2022_05_25-06_41_09_backupiobroker.tar.gz
            [DEBUG] [ftp] - done
            [DEBUG] [clean] - done
            [DEBUG] [email] - [iobroker] used E-Mail-Instance: email.0
            [DEBUG] [email] - done
            [DEBUG] [email] start with {"type":"creator","time":"19:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.1.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"dir":"/","dirMinimal":"/backupDir/iobroker","user":"iobroker_backitup","pass":"","port":"21"},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.1.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"dir":"/","dirMinimal":"/backupDir/iobroker","user":"iobroker_backitup","pass":"","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"ftp","mount":"192.168.1.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"FRITZ.NAS/USB2-0-DISK-01/RSPPI3BACKUP","dirMinimal":"sharename/backupDir","user":"iobroker_backitup","pass":""},"dropbox":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessToken":"","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"username":"username","pass":"","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessJson":"","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.1.177","port":"8088","exe":"","dbType":"remote","deleteDataBase":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.1.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"dir":"/","dirMinimal":"/backupDir/iobroker","user":"iobroker_backitup","pass":"","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"ftp","mount":"192.168.1.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"FRITZ.NAS/USB2-0-DISK-01/RSPPI3BACKUP","dirMinimal":"sharename/backupDir","user":"iobroker_backitup","pass":""},"dropbox":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessToken":"","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"username":"username","pass":"","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessJson":"","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"filePath":"/home/iobroker/skripte"},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.1.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"dir":"/","dirMinimal":"/backupDir/iobroker","user":"iobroker_backitup","pass":"","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"ftp","mount":"192.168.1.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"FRITZ.NAS/USB2-0-DISK-01/RSPPI3BACKUP","dirMinimal":"sharename/backupDir","user":"iobroker_backitup","pass":""},"dropbox":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessToken":"","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"username":"username","pass":"","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessJson":"","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"host":"192.168.1.178","port":"3000","protocol":"http","username":"admin","pass":"","apiKey":""},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"shortEmailNotice","emailReceiver":"karl.goetschhofer@utanet.at","emailSender":".com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de","time":"25. Mai 2022 um 06:48 Uhr"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
            [DEBUG] [historyHTML] - new history html values created
            [DEBUG] [historyHTML] - done
            [DEBUG] [historyJSON] - new history json values created
            [DEBUG] [historyJSON] - done
            [DEBUG] [historyHTML] start with {"type":"creator","time":"19:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.1.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"dir":"/","dirMinimal":"/backupDir/iobroker","user":"iobroker_backitup","pass":"","port":"21"},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.1.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"dir":"/","dirMinimal":"/backupDir/iobroker","user":"iobroker_backitup","pass":"","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"ftp","mount":"192.168.1.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"FRITZ.NAS/USB2-0-DISK-01/RSPPI3BACKUP","dirMinimal":"sharename/backupDir","user":"iobroker_backitup","pass":""},"dropbox":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessToken":"","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"username":"username","pass":"","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessJson":"","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.1.177","port":"8088","exe":"","dbType":"remote","deleteDataBase":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.1.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"dir":"/","dirMinimal":"/backupDir/iobroker","user":"iobroker_backitup","pass":"","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"ftp","mount":"192.168.1.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"FRITZ.NAS/USB2-0-DISK-01/RSPPI3BACKUP","dirMinimal":"sharename/backupDir","user":"iobroker_backitup","pass":""},"dropbox":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessToken":"","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"username":"username","pass":"","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessJson":"","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"filePath":"/home/iobroker/skripte"},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.1.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"dir":"/","dirMinimal":"/backupDir/iobroker","user":"iobroker_backitup","pass":"","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"ftp","mount":"192.168.1.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"FRITZ.NAS/USB2-0-DISK-01/RSPPI3BACKUP","dirMinimal":"sharename/backupDir","user":"iobroker_backitup","pass":""},"dropbox":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessToken":"","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"username":"username","pass":"","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessJson":"","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"host":"192.168.1.178","port":"3000","protocol":"http","username":"admin","pass":"","apiKey":""},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"25. Mai 2022 um 06:48 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"shortEmailNotice","emailReceiver":"karl.goetschhofer@utanet.at","emailSender":"karl.goetschhofer@gmail.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
            [DEBUG] [historyJSON] start with {"type":"creator","time":"19:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.1.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"dir":"/","dirMinimal":"/backupDir/iobroker","user":"iobroker_backitup","pass":"","port":"21"},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.1.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"dir":"/","dirMinimal":"/backupDir/iobroker","user":"iobroker_backitup","pass":"","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"ftp","mount":"192.168.1.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"FRITZ.NAS/USB2-0-DISK-01/RSPPI3BACKUP","dirMinimal":"sharename/backupDir","user":"iobroker_backitup","pass":""},"dropbox":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessToken":"","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"username":"username","pass":"","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessJson":"","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.1.177","port":"8088","exe":"","dbType":"remote","deleteDataBase":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.1.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"dir":"/","dirMinimal":"/backupDir/iobroker","user":"iobroker_backitup","pass":"","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"ftp","mount":"192.168.1.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"FRITZ.NAS/USB2-0-DISK-01/RSPPI3BACKUP","dirMinimal":"sharename/backupDir","user":"iobroker_backitup","pass":""},"dropbox":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessToken":"","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"username":"username","pass":"","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessJson":"","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"filePath":"/home/iobroker/skripte"},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.1.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"dir":"/","dirMinimal":"/backupDir/iobroker","user":"iobroker_backitup","pass":"","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"ftp","mount":"192.168.1.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"FRITZ.NAS/USB2-0-DISK-01/RSPPI3BACKUP","dirMinimal":"sharename/backupDir","user":"iobroker_backitup","pass":""},"dropbox":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessToken":"","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"username":"username","pass":"","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessJson":"","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"host":"192.168.1.178","port":"3000","protocol":"http","username":"admin","pass":"","apiKey":"****"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"25. Mai 2022 um 06:48 Uhr"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"shortEmailNotice","emailReceiver":"karl.goetschhofer@utanet.at","emailSender":"karl.goetschhofer@gmail.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
            Ebenso fehlt Grafana im Verzeichnis opt/iobroker/backups/...
            Bei Grafana habe ich am 11.5.2022 die letzte Datensicherung am Fritz-NAS.
            Vielen Dank
            Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
              Thomas Braun Most Active @GOETSCHHOFER last edited by
              @goetschhofer
              Wenn ich das chaotische Zeug im Spoiler (Bitte statt SpoilerTags besser die CodeTags verwenden!) richtig lese wird da FTP verwendet. Ich würde SMB/CIFS für das FritzNAS verwenden.
              G crunchip 2 Replies Last reply Reply Quote 1
                GOETSCHHOFER @Thomas Braun last edited by
                @thomas-braun said in Ausstieg aus ndcu:
                Danke für den Hinweis, habe ich geändert.
                Werde ich mir merken. 👍
                  crunchip Forum Testing Most Active @Thomas Braun last edited by
                  @thomas-braun sagte in Ausstieg aus ndcu:
                  Bei grossen Sachen, noch besser, codetags im spoiler😉
                    @goetschhofer bei ner Fehlermeldung wird gar nix mehr gelöscht, egal was du eingestellt hast.
                    Weiss nicht was du da immer treibst 😄
                    Gab es zu dem Zeitpunkt ein Grafana update? Oder hast du da etwas geändert? (Api key)
                      @crunchip
                      Ich bin mir keiner Schuld bewusst ! 😟 🤔
                      Kein Grafana Update seit letztem Jahr und auch kein neuer Api key etc.
                      Ich habe nur vor einiger Zeit die Anzahl der Updates im backitup-Adapter, welche er behalten soll von 3 auf 7 gestellt, das war mein Fehler.
                      "Never change a running system".
                      G crunchip 2 Replies Last reply Reply Quote 0
                        GOETSCHHOFER @GOETSCHHOFER last edited by GOETSCHHOFER
                        @goetschhofer said in Ausstieg aus ndcu:
                        @crunchip
                        https://github.com/simatec/ioBroker.backitup/issues/510
                        Gleiche Fehlermeldung !
                        pruse007 created this issue in simatec/ioBroker.backitup
                        closed Grafana 8.0 Backup nicht mehr möglich #510
                          Vielleicht hast du es gar nicht mitbekommen.
                          Bzw welche version hast du installiert beim backitup?
                          Ggf prüfe den Api key, ob dieser übereinstimmt.
                          Selbst das herabsetzen der Anzahl, verursacht aber keinen Fehler im backup.
                            @crunchip said in Ausstieg aus ndcu:
                            Der Tipp mit dem API-Key glaube ich ist ein heißer Tipp !
                            Am 11.5.22 hatte ich die letzte Datensicherung von Grafana durch den backitup-Adapter u. am 12.5.22 ist er abgelaufen.
                            Wie kann ich den API-Key für admin verlängern oder wieder aktivieren ?
                            Bevor ich den backitup-Adapter aktualisieren kann, muss ich zuerst mein System nachziehen.
                              @goetschhofer
                              Ja, halt dein System halt auf Stand.
                                kann ich dir aus dem Stehgreif nicht sagen, ich verwende das nicht
                                denke mal, löschen und einen neuen erstellen
                                oha, ja dann solltest du so langsam mal alles nach der Reihe aktualisieren
                                2252
