      Thomas Braun Most Active @qqolli last edited by
      @qqolli sagte in Test Adapter Backitup v2.4.x:
      Muss ich da nochwas machen?
      Nein. Das sind 156 Pakete, deren Maintainer sich über deine (finanzielle) Unterstützung freuen würden.
      qqolli 1 Reply Last reply Reply Quote 0
      • qqolli
        qqolli @Thomas Braun last edited by
        @thomas-braun @simatec
        Na, schau mal einer an:
        pi@ioBroker:~ $ iobroker backup
        host.ioBroker 67346 states saved
        host.ioBroker 87510 objects saved
        Backup created: /opt/iobroker/backups/2022_04_20-12_07_26_backupiobroker.tar.gz
        pi@ioBroker:~ $ ls -al /opt/iobroker/backups/
        insgesamt 38780
        drwxrwxr-x+  2 iobroker iobroker    12288 Apr 20 12:08 .
        drwxrwxr-x+ 10 iobroker iobroker     4096 Apr 20 11:50 ..
        -rw-rw-r--+  1 iobroker iobroker 39692317 Apr 20 12:08 2022_04_20-12_07_26_backupiobroker.tar.gz
        pi@ioBroker:~ $
        Und endlich auch:
        Started iobroker ...
        [DEBUG] [mount] - noserverino option: false
        [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=backup,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.178.23/backup/ioBroker /opt/iobroker/backups"
        [DEBUG] [mount] - mount successfully completed
        [DEBUG] [mount] - done
        [DEBUG] [iobroker] - host.ioBroker 67346 states saved
        [DEBUG] [iobroker] - host.ioBroker 87510 objects saved
        [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2022_04_20-12_10_45_backupiobroker.tar.gz
        [DEBUG] [iobroker] - done
        [DEBUG] [cifs] - done
        [DEBUG] [clean] - done
        [DEBUG] [pushover] - done
        [DEBUG] [historyHTML] - new history html values created
        [DEBUG] [historyHTML] - done
        [DEBUG] [historyJSON] - new history json values created
        [DEBUG] [historyJSON] - done
        [DEBUG] [umount] - mount activ, umount is started ...
        [DEBUG] [umount] - umount successfully completed
        [DEBUG] [umount] - done
        [EXIT] 0
        ist das Backup wieder auf der NAS!!!
        Vielen lieben dank an euch beide für die Hilfe und eure Zeit! Ihr seid die Besten 🙂
        qqolli G 2 Replies Last reply Reply Quote 0
          Gonzokalle @qqolli last edited by
          Hallo, der Backitup Adapter soll soll in eine bestimmten Telegram Chat benachrichtigen. Kann ich irgendwo die Chat id eintragen?
          • simatec
            simatec Developer Most Active @Gonzokalle last edited by
            @gonzokalle Diese Einstellungen machst du in der Telegram Instanz
              Gonzokalle @simatec last edited by
              @simatec
              Okay
              Wie/wo kann ich hier eine Chat id eintragen?
              • simatec
                @gonzokalle Über den Token in den Telegram Einstellungen der Instanz gibst du doch an, in welchen Chat die Telegram Instanz sendet.
                  @simatec
                  Wenn ich den Token (xxxxxxxxxx:yyyyyyyyyyyyyyyyyyyyyyy-zzzzzzzzzzz) eingebe schreibt mir der Bot unter seinen Namen.
                  Er soll mir aber in eine Chatgruppe (Chat id habe ich) schreiben.
                  Der Bot ist natürlich Admin der Chatgruppe.
                  • simatec
                    @gonzokalle
                    Da musst du beim Telegram Adapter nachfragen.
                    Mir ist da nix bekannt
                    • simatec
                      Ab sofort steht auf Github und in kürze auch im latest die Version 2.4.7 zur Verfügung.
                      Changelog
                      2.4.7 (2022-05-16)
                      • (simatec) dependencies updated
                      • (simatec) many small bugfixes
                      • (simatec) Fix Sentry Error Messages
                      • (simatec) Default SMB Version 3.1.1
                      • simatec
                        Ab sofort steht die Version 2.4.9 auf Github und in kürze auch im latest zur Verfügung.
                        Changelog
                        2.4.9 (2022-05-25)
                        • (simatec) German Wiki added
                        • (simatec) English Wiki added
                        • (simatec) ignore .tar.gz files for zigbee Backups
                        E 1 Reply Last reply Reply Quote 2
                          Einstein67 @simatec last edited by Einstein67
                          @simatec Hallo und vielen Dank für die neue Version und das Wiki.
                          Ich hab gestern meine InfluxDB auf zwei Instanzen (wegen unterschiedlicher Vorhaltezeiten) umgestellt.
                          Hat super funktioniert und nach Angabe der Datenbanken in BackitUp (Sicherung mehrer Systeme) werden sie auch (als 2 unterschiedliche Dateien) auf mein NAS gesichert.
                          Beim Restore werden aber beide DBs komischerweise mit dem selben Namen (iobroker) erstellt. Deshalb lässt sich nur die erste DB wiederherstellen. Die zweite scheitert dann weil die DB schon vorhanden ist, mit der Fehlermeldung:
                          Started restore ...
                          [DEBUG] [influxDB] - Created tmp directory
                          [DEBUG] [influxDB] - Start infuxDB Restore ...
                          [ERROR] [influxDB] - 2022/05/26 09:53:40 error updating meta: DB metadata not changed. database may already exist
                          restore: DB metadata not changed. database may already exist
                          [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
                          [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
                          [DEBUG] [influxDB] - infuxDB Restore completed successfully
                          [EXIT] influxDB restore done
                          Hab ich da einen Denkfehler .... und das geht so nicht?
                          Edit:
                          Datenbank der Instanz.0 heißt: iobroker
                          Datenbank der Instanz.1 heißt: tempdaten
                          Beim Wiederherstellen werden beide als iobroker erstellt.
                          EditEdit: Wenn man die erstellten Backups entpackt und das Restore über den Influxdb-Befehl manuell ausführt, dann werden die DBs unter dem richtigen Namen problemlos erstellt. Also kein großes Problem ... 😉
                          • simatec
                            simatec Developer Most Active @Einstein67 last edited by
                            @einstein67 danke gür den Hinweis. Könntest du hierzu bitte ein Issue aufmachen?
                              Altersrentner @simatec last edited by
                              @simatec
                              Guten Morgen,
                              Ich habe gerade festgestellt, dass meine v2.4.6 nicht wie gefordert regelmäßig sichert.
                              Letzte Sicherung von ioBrokerist erfolgte auf GoogleDrive am 04.05.22
                              [DEBUG] [iobroker] - host.raspberrypi 21952 states saved
                              [DEBUG] [iobroker] - host.raspberrypi 24331 objects saved
                              [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2022_05_26-10_45_47_backupiobroker.tar.gz
                              [DEBUG] [influxDB] - InfluxDB-Backup started ...
                              [DEBUG] [influxDB] - Start InfluxDB Backup ...
                              [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
                              [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2022_05_26-10_46_10_backupiobroker.tar.gz
                              [DEBUG] [influxDB] - InfluxDB-Backup for is finish
                              [DEBUG] [influxDB] - done
                              [DEBUG] [historyDB] - compress from historyDB started ...
                              [ERROR] [historyDB] - Backitup cannot found source "undefined" for compress!
                              GoogleDrive Zugriff ist vorhanden / wurde erneuert.
                              Mit freundlichen Grüßen
                              Michael
                              • simatec
                                simatec Developer Most Active @Altersrentner last edited by
                                @altersrentner
                                Prüfe in dem History Adapter den Speicherpfad und trage diesen auch im identisch im Backup Adapter ein
                                  @simatec said in Test Adapter ioBroker.backitup v2.4.x:
                                  Ja mach ich dann! Ich will vorher noch rausfinden obs eventuell doch nur an meinen Einstellungen liegt.
                                  DB-Benutzername: "iobroker"
                                  DB-Name: "iobroker"
                                  Vielleicht "beisst" sich da was in den Schwanz ... 🙂
                                  • simatec
                                    @einstein67 Ich schaue mal im Code, ob da eventuell ein Konflikt besteht.
                                    Eventuell muss ich bei den Multi Backups den DB Namen für den Restore mit in das Archiv legen
                                    Muss ich mir mal anschauen
                                      @simatec sagte in Test Adapter ioBroker.backitup v2.4.x:
                                      Danke für Deine Nachricht.
                                      Ist unverändert:
                                      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2022_05_26-11_29_34_backupiobroker.tar.gz
                                      [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2022_05_26-11_29_56_backupiobroker.tar.gz
                                      MfG Michael
                                      • simatec
                                        @altersrentner
                                        Also „iobroker“ ist keine Pfadangabe.
                                        Wo liegen denn deine ganze History Daten auf dem System?
                                          Danke!!
                                          Die DB-Namen werden in den *.manifest Dateien beim "BackitUp" 😉 richtig eingetragen. Sollten also vorhanden sein.
                                          Kopiert man alle Dateien aus den Multi-Backups in einen Ordner und macht ein Restore, dann werden ja auch alle Datenbanken perfekt wieder angelegt und befüllt.
                                            Da bin ich überfordert.
                                            Wo könnte ich nachsehen?
                                            Warum hat es bis Anfang Mai funktioniert und jetzt nicht mehr.
                                            MfG Michael
                                            170
                                            2780
                                            2379042
