    5. Lichter dimmen
    Lichter dimmen
    • Enrico Fischer
      Enrico Fischer last edited by
      Nachdem ich mich jetzt doch mal mit Blockly befasst haben,bin ich ja schon mal froh das der Script läuft.
      Nur hab ich das Problem das ich unmengen Fehlermeldungen bekomme.
      Könnte sich das einer der Profis mal bitte anschauen.
      Fehler
      25.5.2022, 23:12:46.388 [warn ]: javascript.0 (68693) at Object.<anonymous> (script.js.test:4:3)
      25.5.2022, 23:12:52.299 [warn ]: javascript.0 (68693) at Object.<anonymous> (script.js.test:10:3)
      25.5.2022, 23:12:53.302 [warn ]: javascript.0 (68693) at Object.<anonymous> (script.js.test:12:3)
      25.5.2022, 23:12:54.304 [warn ]: javascript.0 (68693) at Object.<anonymous> (script.js.test:14:3)
      25.5.2022, 23:12:55.305 [warn ]: javascript.0 (68693) at Object.<anonymous> (script.js.test:16:3)
      25.5.2022, 23:12:56.306 [warn ]: javascript.0 (68693) at Object.<anonymous> (script.js.test:18:3)
      25.5.2022, 23:12:57.307 [warn ]: javascript.0 (68693) at Object.<anonymous> (script.js.test:20:3)
      25.5.2022, 23:12:58.309 [warn ]: javascript.0 (68693) at Object.<anonymous> (script.js.test:22:3)
      25.5.2022, 23:12:59.310 [warn ]: javascript.0 (68693) at Object.<anonymous> (script.js.test:24:3)
      25.5.2022, 23:13:00.311 [warn ]: javascript.0 (68693) at Object.<anonymous> (script.js.test:26:3)
      25.5.2022, 23:13:01.312 [warn ]: javascript.0 (68693) at Object.<anonymous> (script.js.test:28:3)
        <block type="on" id="0?yo4)owdA)AJkH,5lkI" x="88" y="-462">
          <field name="OID">0_userdata.0.schalter</field>
            <block type="control" id=".;c|Dvp3=z]n,D)haT]K">
              <field name="OID">tradfri.0.L-65544.lightbulb.brightness</field>
                <block type="text" id="v5(jV8}mj)IRPu[uNpE}">
                  <field name="TEXT">100</field>
                <block type="update" id="q*vs5UTNN*A0UYix82uF">
                  <field name="OID">tradfri.0.L-65544.lightbulb.state</field>
                    <block type="logic_boolean" id="v2j-vsy~!9|ENXpK8jd8">
            <block type="on" id="bD)zg|:!d*E-4-]pY7:+">
              <field name="CONDITION">false</field>
                <block type="control" id="_.bQ~6tCcKbE.ebIHyL1">
                    <block type="text" id="MW*EL^|vo|v5#hH:,wq*">
                      <field name="TEXT">90</field>
                    <block type="timeouts_wait" id="5k!SE5UufRPYQzCW19h|">
                      <field name="DELAY">1000</field>
                      <field name="UNIT">ms</field>
                        <block type="control" id="YlTjFPJ*Y$LcZO$xfD^O">
                            <block type="text" id="DFW@}uP[yWK4sn*Y`Fwi">
                              <field name="TEXT">80</field>
                            <block type="timeouts_wait" id="khhc=2*A~DYX]K}N;nU~">
                                <block type="control" id="JIx45#Kv{ko8A:raYBTs">
                                    <block type="text" id="pCt7pL);`wi`L,`t_fj}">
                                      <field name="TEXT">70</field>
                                    <block type="timeouts_wait" id="cg+sYL`8GLN%0+?nBDB;">
                                        <block type="control" id="jOe].,CstvYngi0eh3(:">
                                            <block type="text" id="7,6E/wQD)a!w;p*oSvy?">
                                              <field name="TEXT">60</field>
                                            <block type="timeouts_wait" id="IJ}T][d[5l_YQ|hRTI+6">
                                                <block type="control" id="R,ErQsc8fEsS(R.JRvJN">
                                                    <block type="text" id="V#TeP/?b+lW8GZ_8hwXx">
                                                      <field name="TEXT">50</field>
                                                    <block type="timeouts_wait" id=";iva_)@~e/);C`%V=juc">
                                                        <block type="control" id="=Yx1t=[Ty?:,N8zhdeIe">
                                                            <block type="text" id="oCu3!*yYE0GCB8UM8}#y">
                                                              <field name="TEXT">40</field>
                                                            <block type="timeouts_wait" id="~pyht()C_y$a{vZv.=A(">
        <block type="control" id="cL7V/TFJPrW60-7z9a51">
        <block type="text" id="i=O(W(99d1(d+vNz`S/W">
        <field name="TEXT">30</field>
        <block type="timeouts_wait" id="uZMMFJ,^WP%khB`GfxH#">
        <block type="control" id="N^iVDuM$xRdx/i3B^xM2">
        <block type="text" id="H6MbK%T~r/E1[W?pGSpB">
        <field name="TEXT">20</field>
        <block type="timeouts_wait" id="x%%8kqkzZBFH,|;j(CZ0">
        <block type="control" id="K$EDr?|Conq,Q=#nA!(t">
        <block type="text" id="^WOUMxKdh2M/QE/XwF]1">
        <field name="TEXT">10</field>
        <block type="timeouts_wait" id="4S-Rrw,(V]O^Pakt|g;j">
        <block type="control" id="#tk.)o$N)6y{1v3B%K,L">
        <block type="text" id="`^@T{Ba7A#3xw7i9}{(n">
        <field name="TEXT">0</field>
        <block type="timeouts_wait" id="e[{DJ;^LE9#]jF0zY2.!">
        <block type="update" id="+s`4^:Nwp/@+xu]E4B])">
        <block type="logic_boolean" id="Tp4~BliPC=3L395;Sq#!">
      DJMarc75 Asgothian 2 Replies Last reply Reply Quote 0
      • DJMarc75
        DJMarc75 @Enrico Fischer last edited by DJMarc75
        @enrico-fischer Die Fehler kommen weil Du Textbausteine anstatt Zahlenbausteine verwendest.
        Enrico Fischer 1 Reply Last reply Reply Quote 1
        • Enrico Fischer
          Enrico Fischer @DJMarc75 last edited by
          @djmarc75 oh man dank dir. Und wieder was gelernt.
          • DJMarc75
            @enrico-fischer etwas kompakter:
             <block type="on" id="i9/Bv4GE~t6s{5D#bZ*E" x="413" y="-487">
                 <block type="controls_if" id="({C*T#wj6;N|cE#w/,un">
                     <block type="on_source" id="].F(gCY)C%oa%6l5}H.]">
                     <block type="control" id="=5vmNp`ObYqN~x,#H*SV">
                         <block type="math_number" id="RhqIZ|-1w~/{?lqx#kfO">
                           <field name="NUM">100</field>
                   <statement name="ELSE">
                     <block type="control" id="[-JVr+8uI?Opk%XI?;~)">
                         <block type="math_number" id="RzymfH$S%p}y#1d%+$NM">
                           <field name="NUM">90</field>
                         <block type="timeouts_wait" id="s#}TxQFcKF5fmLIWQNhG">
                             <block type="control" id="B*#_Damb1o:hRlAeWG?C">
                                 <block type="math_number" id="o77m]WIGj,/E.rS}P]pb">
                                   <field name="NUM">80</field>
                                 <block type="timeouts_wait" id="[_r8%|#?iu;:S9AKpj}n">
                                     <block type="comment" id="7$17#O4!XXbarU^kBn:9">
                                       <field name="COMMENT">usw</field>
            Asgothian 1 Reply Last reply Reply Quote 1
            • Asgothian
              Asgothian Developer @Enrico Fischer last edited by Asgothian
              @enrico-fischer
              Das Skript hat 3 Probleme:
              • das erste Problem hat @DJMarc75 bereits beschrieben. Du steuerst numerische Datenpunkte mit Texten an.
              • das zweite Problem sind die Trigger. Durch einen Trigger auf "ist wahr" und "ist Falsch" werden die trigger auch dann aktiv wenn die Datenpunkte "nur" aktualisiert werden. das ist im Zweifelsfall zu oft. Wenn du die Struktur des Skriptes beibehalten willst empfiehlt sich ein Trägern auf "ist grösser als vorher" an Stelle von "Ist Wahr", bzw. "ist kleiner als vorher" an Stelle von "ist Falsch"
              • das dritte Problem betrifft die Logik. Nehmen wir an jemand schaltet das Licht aus, und entscheidet sich das Licht wieder einzuschalten bevor es ganz auf "dunkel" gedimmt hat. Dann wird am Ende das Licht trotzdem aus sein. (Das kannst du ja mal ausprobieren) Die Lösung dafür ist aber auch einfach:
              Dabei musst du natürlich die Stellen wo noch "Objekt id" drin steht durch die entsprechenden Datenpunkte von Dir ersetzen, sonst geht es nicht. Innerhalb des Triggers den Datenpunkt für die Helligkeit, Im trigger selber den deines Auslösers.
              Als letztes noch ein Hinweis zu dem Baustein "State Value" - dieses ist ein besonderer Baustein aus dem Trigger Bereich - er hat immer genau den Wert des Datenpunktes der den Trigger in dem er sich befindet ausgelöst hat.
              Durch das arbeiten mit dem Intervall wird eine Schleife gebaut die von alleine aufhört sobald die Helligkeit auf 0 sinkt. Sie hört aber auch dann auf wenn der Trigger erneut angestossen wird, z.Bsp. wenn jemand das licht wieder an macht.
              Hinter dem Spoiler findest Du auch den Export.
               <variables>
                 <variable id="=!=z:.,(wuNYmO3Pk`;(">bri</variable>
                 <variable type="interval" id="interval">interval</variable>
               </variables>
               <block type="variables_set" id=".4FA0fwn9jDQ{IW,ah1T" x="113" y="88">
                 <field name="VAR" id="=!=z:.,(wuNYmO3Pk`;(">bri</field>
                   <block type="math_number" id="S75y|[:{n;d;,c+:5[HK">
                     <field name="NUM">0</field>
                   <block type="comment" id="f;t{Zq5dUh^}kFdAN7i/">
                     <field name="COMMENT">hier den dp zum ansteuern eintragen</field>
                       <block type="on" id="%@lAlUK8Yae69]m]mzo3">
                           <block type="timeouts_clearinterval" id="7j772{S$EhYWd`Q!Rnvy">
                             <field name="NAME">interval</field>
                               <block type="comment" id="bXPL=j}W_zSw2d5s|G+M">
                                 <field name="COMMENT">Baustein aus Trigger Bereich</field>
                                   <block type="comment" id="^6x+Yv=rsOu.2zFvSO8g">
                                     <field name="COMMENT">Steht auf "Objekt ID"</field>
                                       <block type="comment" id="Uz~akpiZSNthq0{IL6vF">
                                         <field name="COMMENT">Umstellen auf "Wert"</field>
                                           <block type="controls_if" id="-%ZE(_-G-r;r--3#7Z%U">
                                               <block type="on_source" id="Sk=0IAZb|A,cb#aMV,1[">
                                               <block type="control" id="j89O8xUkJA|K0)utN8z4">
                                                   <block type="math_number" id="ngo2LERv)F=ot,tRWyvV">
                                               <block type="variables_set" id="!g$l0g_qII9AGtjy}?nv">
                                                   <block type="get_value" id="FrFFdJh*oR2V:~WI`W}b">
                                                     <field name="OID">select ID</field>
                                                   <block type="timeouts_setinterval" id="}9|0:G)1P8w81s{d)]_p">
                                                     <field name="INTERVAL">1000</field>
                                                       <block type="math_change" id="5|Gwv~EkQW+`1)]~#nOW">
                                                         <value name="DELTA">
                                                           <shadow type="math_number" id="uB[@t(VeM4!RH})t(E)$">
                                                             <field name="NUM">-10</field>
                                                           <block type="control" id="%bzuX{BwN)pSrhHr0DR{">
                                                               <block type="math_constrain" id="[Y0#(:z]r[@j(C;@ELgg">
        <shadow type="math_number" id="^=V.g#iE9DU5yA=~C!Hg">
        <field name="NUM">50</field>
        <block type="variables_get" id="QemRZ)rO3Z%yFUL6P7^o">
        <value name="LOW">
        <shadow type="math_number" id="3?cVam=h#{xbamAMVPM-">
        <value name="HIGH">
        <shadow type="math_number" id="VEuHe0}7xSofk?B`v]01">
                                                               <block type="controls_if" id="gwT9W3[1O;+8rnU!7#rO">
        <block type="logic_compare" id="}h(UwskV2u=p%DxipASc">
        <field name="OP">LTE</field>
        <block type="variables_get" id="T$Vgc+Ap-m)C2euOK2[z">
        <block type="math_number" id="J!I4lPUp:x/`rju5m[=8">
        <block type="timeouts_clearinterval" id="B@6JbwwF]YHB=.o`o34$">
              A.
              • Asgothian
                Asgothian Developer @DJMarc75 last edited by
                @djmarc75 sagte in Lichter dimmen:
                Diese Variante mag kompakter und ressourcenschonend sein, ist aber ansonsten eher schlecht. Eine Ablaufsteuerung mit Pausen hat so seine Risiken.
                A.
                • DJMarc75
                  DJMarc75 @Asgothian last edited by
                  @asgothian said in Lichter dimmen:
                  Da hast Du recht. Ich war grad auch am Intervall-basteln, aber Du warst eindeutig flinker 😁
                  • Enrico Fischer
                    Okay danke erstmal an alle. Jetzt hab ich wieder was zu tun. Aber so langsam komme ich dahinter.
