    4. Test Adapter Daikin-Cloud 0.0.1
      Aidan @apollon77 last edited by
      @apollon77 :
      Moin zusammen, ich bin auch an dem Daikin-Cloudadapter interessiert und habe folgende 4 Endgeräte verbaut:
      1x FTXM42R2V1B
      2x FTXM20R2V1B
      1x FTXM25R2V1BProblem:
      Den Adapter habe ich installiert sehe ihn aber nicht.
      Hier ein paar Infos durch die mich glasfaser bereits geführt hat.
      pi@raspberrypi:~ $ cd /opt/iobroker
      pi@raspberrypi:/opt/iobroker $ npm i iobroker.daikin-cloud
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      + iobroker.daikin-cloud@0.1.1
      added 53 packages from 44 contributors in 24.221s
      77 packages are looking for funding
        run `npm fund` for details
      pi@raspberrypi:~ $ iobroker update -i
      Used repository: Stable (default)
      Adapter    "admin"        : 5.3.8    , installed 5.3.8
      Adapter    "alarm"        : 3.1.0    , installed 3.0.5  [Updatable]
      Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
      Adapter    "discovery"    : 3.0.3    , installed 3.0.3
      Adapter    "email"        : 1.0.10   , installed 1.0.10
      Adapter    "heos"         : 1.9.1    , installed 1.9.1
      Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
      Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
      Adapter    "hmip"         : 1.17.0   , installed 1.15.4 [Updatable]
      Adapter    "ical"         : 1.12.1   , installed 1.12.1
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "javascript"   : 5.2.21   , installed 5.2.21
      Adapter    "linkeddevices": 1.4.3    , installed 1.4.3
      Adapter    "proxy"        : 1.2.2    , installed 1.2.2
      Adapter    "simple-api"   : 2.6.5    , installed 2.6.5
      Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
      Adapter    "telegram"     : 1.12.2   , installed 1.12.2
      Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.4
      Adapter    "vis"          : 1.4.15   , installed 1.4.15
      Adapter    "vis-google-fonts": 1.0.3 , installed 1.0.3
      Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
      Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
      Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
      Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
      Adapter    "yr"           : 5.3.0    , installed 5.1.2  [Updatable]
      pi@raspberrypi:~ $ iobroker list adapters
      system.adapter.admin                   : admin          - v5.3.8
      system.adapter.alarm                   : alarm          - v3.0.5
      system.adapter.daswetter               : daswetter      - v3.1.2
      system.adapter.discovery               : discovery      - v3.0.3
      system.adapter.email                   : email          - v1.0.10
      system.adapter.heos                    : heos           - v1.9.1
      system.adapter.hm-rega                 : hm-rega        - v3.0.40
      system.adapter.hm-rpc                  : hm-rpc         - v1.15.12
      system.adapter.hmip                    : hmip           - v1.15.4
      system.adapter.ical                    : ical           - v1.12.1
      system.adapter.icons-material-png      : icons-material-png - v0.1.0
      system.adapter.icons-mfd-png           : icons-mfd-png  - v1.1.0
      system.adapter.icons-open-icon-library-png: icons-open-icon-library-png - v0.1.2
      system.adapter.icons-ultimate-png      : icons-ultimate-png - v1.0.1
      system.adapter.info                    : info           - v1.9.19
      system.adapter.javascript              : javascript     - v5.2.21
      system.adapter.linkeddevices           : linkeddevices  - v1.4.3
      system.adapter.proxy                   : proxy          - v1.2.2
      system.adapter.simple-api              : simple-api     - v2.6.5
      system.adapter.socketio                : socketio       - v4.2.0
      system.adapter.tankerkoenig            : tankerkoenig   - v2.1.1
      system.adapter.telegram                : telegram       - v1.12.2
      system.adapter.tvspielfilm             : tvspielfilm    - v2.0.4
      system.adapter.vis                     : vis            - v1.4.15
      system.adapter.vis-google-fonts        : vis-google-fonts - v1.0.3
      system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.2.0
      system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
      system.adapter.vis-justgage            : vis-justgage   - v1.0.2
      system.adapter.vis-map                 : vis-map        - v1.0.4
      system.adapter.vis-metro               : vis-metro      - v1.2.0
      system.adapter.vis-plumb               : vis-plumb      - v1.0.2
      system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
      system.adapter.vis-weather             : vis-weather    - v2.5.5
      system.adapter.web                     : web            - v4.3.0
      system.adapter.yr
      pi@raspberrypi:~ $ iobroker list instances
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alarm.0                  : alarm                 : raspberrypi                              - disabled
      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
        system.adapter.gartenbewaesserung.0     : gartenbewaesserung    : raspberrypi                              - disabled
        system.adapter.heos.0                   : heos                  : raspberrypi                              - disabled
      + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
      + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              -  enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              -  enabled
      + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        system.adapter.proxy.0                  : proxy                 : raspberrypi                              - disabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
        system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
        system.adapter.tvspielfilm.0            : tvspielfilm           : raspberrypi                              -  enabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              -  enabled
        system.adapter.vis-map.0                : vis-map               : raspberrypi                              -  enabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
        system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
      ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
      pi@raspberrypi:~ $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      armv7l
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v12.20.0
      v12.20.0
      6.14.8
      pi
      /home/pi
      Eventuell kann mir wer weiterhelfen, bzw. hilft es bei der Entwicklung des Adapters.
        apollon77 @Aidan last edited by
        @aidan Naja wenn du den Adapter nicht über Admin installierst wie ioben beschrieben sondern direkt per npm dann must du ein weiteres kommando ausführen um die Metadaten zum Adapter in ioBroker zu registrieren 🙂
        iob upload daikin-cloud
        Danach ist er da und unter "Adapter" zu finden. dann dort über den "+" eine instanz anlöegen (oder wenn es CLI sein soll iob add daikin-cloud
          @apollon77 said in Test Adapter Daikin-Cloud 0.0.1:
          Guten Morgen, danke für den Hinweis-)
          Den Adapter sehe ich jetzt. und er ist auch angemeldet-)
          Hat etwas gedauert, da ständig mein Konto abgewiesen worden ist.
          Ich hatte mich in der App mit meinem Googlekonto angemeldet.
          Als ich die Zugangsdaten in den Adapter eingetragen hatte, kam falscher Benutzer bzw. Passwort falsch.
          Über den Link im QR-Code kam ich dann zu der Delkin Seite und habe mir dort Über "Passwort vergessen" ein neues PW vergeben.
          Das Ganze hat mich ca. 4 Std. gekostet^^
          Ich würde gern hier mit Testen, stelle mir aber die Frage ob mein kleines Wissen reicht, oder ob ich mit meinen Fragen mehr bremsen würde.
          Beste Grüße und schönes WE
            @aidan Schieß los 😉 keine Scheu.
            Am Ende ließt der Adapter die Datenstrukturen von daikin und stellt die in iobroker dar. Detailfragen was wozu da ist bzw. welche Effekte hat kann ich persönlich dir nicht so genau sagen weil ich selbst kein solches Gerät habe sondern nut Fernzugriff auf ein Gerät mit dem ich jetzt nur bedingt rumspielen kann - hier wären wir also eher bei gegenseitiger Hilfe in der Community.
            Wenn rauskommt das der Adapter was falsch macht bin ich da es zu fixen 😉
              Aidan last edited by Aidan
              @apollon77
              ok, dann hau ich mal rein^^ -)
              3 Geräte haben ein Wifi-Symbol eins nicht.
              Das Wohnzimmergerät lässt sich aber über den Adapter an / aus schalten.
              Erst habe ich gedacht, das es eventuell an der Verbindung zum Repeater liegt
              Dies scheint aber nicht der Fall zu sein. Da sich zwei Geräte direkt an der Fritzbox angemeldet haben. Repeater ist als Mesh konfiguriert.
                apollon77 @Aidan last edited by apollon77
                @aidan Was hat denn das Wohnzimmer bei cloudConnected (also klapp mal auf ... wenn da true steht dann ists "nur" ein Admin bug in der Anzeige - dann mal Admin reloaden?). Wenn es offline wäre wäre es gelb ... da es gar nichts hat dann hat denke Admin die State Change von dem irgendwie nicht mitbekommen
                Homoran A 2 Replies Last reply Reply Quote 0
                  Homoran Global Moderator Administrators @apollon77 last edited by
                  @apollon77 die anderen drei scheinen wohl gerade zu refreshen (grüner Text).
                  habe aber auch mit den alten solche Phänomene im Netz oder in der Daikin App.
                  Werden nicht immer alle gefunden.
                    Aidan @apollon77 last edited by Aidan
                    Last update 10:48Uhr
                    ja, steht in rot "Null"
                    Kann aber unter Climacontrol on/ off setzen. Gerät spring dann auch an.
                    Folgendes noch mal probiert.
                    Wohnzimmer eingeschaltet über die App. 30 Sek später wird bei Climacontrol --> on/ off auf true gewechselt. gleiches beim Ausschalten nur das es dann auf false geht.
                      Aidan @Homoran last edited by Aidan
                      @homoran said in Test Adapter Daikin-Cloud 0.0.1:
                      Die sind permanent grün, in Verbindung mit dem W-Lan Symbol. Das suggeriert mir, dass das Wohnzimmer nicht Verbunden ist.
                        @aidan mal Admin reloaded?? Der Status kommt aus der daikin Cloud. Sonst mal Adapter auf debug log für die instanz schalten und dann poste mal komplett aus logfile von Platte /opt/iobroker/log. Dann schauen wir da mal
                          @apollon77
                          Ja den Adminadapter hatte ich neu gestartet, "Fehlerbild" bleibt
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.467	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.outdoorUnit.isInCautionState = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.462	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.outdoorUnit.isInWarningState = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.457	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.outdoorUnit.isInErrorState = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.449	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.outdoorUnit.errorCode = 00-
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.444	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.indoorUnit.dryKeepSetting = true
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.439	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.indoorUnit.eepromVersion = 12FF
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.433	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.indoorUnit.softwareVersion = 20003002
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.428	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.outdoorSilentMode = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.422	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.isLockFunctionEnabled = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.417	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.isCoolHeatMaster = true
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.411	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.holidayMode = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.406	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.consumptionData.electrical = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.401	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.streamerMode = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.395	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.isPowerfulModeActive = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.387	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.powerfulMode = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.381	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.econoMode = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.374	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.schedule.modes.any.schedules.2 = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.367	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.schedule.modes.any.schedules.1 = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.359	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.schedule.modes.any.schedules.0 = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.351	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.schedule.modes.any.meta.actionTypes.econoMode = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.344	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.schedule.modes.any.meta.actionTypes.fanSpeed.fanOnly.modes.fixed = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.332	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.schedule.modes.any.meta.actionTypes.fanSpeed.fanOnly.currentMode = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.323	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.schedule.modes.any.meta.actionTypes.fanSpeed.dry.currentMode = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.305	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.schedule.modes.any.meta.actionTypes.fanSpeed.auto.modes.fixed = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.299	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.schedule.modes.any.meta.actionTypes.fanSpeed.auto.currentMode = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.293	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.schedule.modes.any.meta.actionTypes.fanSpeed.cooling.modes.fixed = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.288	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.schedule.modes.any.meta.actionTypes.fanSpeed.cooling.currentMode = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.283	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.schedule.modes.any.meta.actionTypes.fanSpeed.heating.modes.fixed = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.277	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.schedule.modes.any.meta.actionTypes.fanSpeed.heating.currentMode = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.272	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.schedule.modes.any.meta.actionTypes.roomTemperature.auto = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.267	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.schedule.modes.any.meta.actionTypes.roomTemperature.cooling = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.262	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.schedule.modes.any.meta.actionTypes.roomTemperature.heating = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.257	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.schedule.modes.any.meta.actionTypes.operationMode = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.252	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.schedule.modes.any.enabled = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.247	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.schedule.modes.any.currentSchedule = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.242	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.schedule.currentMode = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.237	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.fanControl.operationModes.fanOnly.fanDirection.vertical.currentMode = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.231	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.fanControl.operationModes.fanOnly.fanDirection.horizontal.currentMode = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.226	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.fanControl.operationModes.fanOnly.fanSpeed.modes.fixed = 1
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.220	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.fanControl.operationModes.fanOnly.fanSpeed.currentMode = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.215	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.fanControl.operationModes.dry.fanDirection.vertical.currentMode = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.209	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.fanControl.operationModes.dry.fanDirection.horizontal.currentMode = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.203	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.fanControl.operationModes.dry.fanSpeed.currentMode = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.198	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.fanControl.operationModes.auto.fanDirection.vertical.currentMode = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.192	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.fanControl.operationModes.auto.fanDirection.horizontal.currentMode = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.188	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.fanControl.operationModes.auto.fanSpeed.modes.fixed = 1
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.183	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.fanControl.operationModes.auto.fanSpeed.currentMode = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.178	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.fanControl.operationModes.cooling.fanDirection.vertical.currentMode = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.173	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.fanControl.operationModes.cooling.fanDirection.horizontal.currentMode = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.168	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.fanControl.operationModes.cooling.fanSpeed.modes.fixed = 5
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.163	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.fanControl.operationModes.cooling.fanSpeed.currentMode = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.159	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.fanControl.operationModes.heating.fanDirection.vertical.currentMode = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.153	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.fanControl.operationModes.heating.fanDirection.horizontal.currentMode = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.148	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.fanControl.operationModes.heating.fanSpeed.modes.fixed = 1
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.144	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.fanControl.operationModes.heating.fanSpeed.currentMode = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.139	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.sensoryData.outdoorTemperature = 12.5
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.134	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.sensoryData.roomTemperature = 20
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.129	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.temperatureControl.operationModes.auto.setpoints.roomTemperature = 25
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.124	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.temperatureControl.operationModes.cooling.setpoints.roomTemperature = 21
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.118	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.temperatureControl.operationModes.heating.setpoints.roomTemperature = 25
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.114	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.operationMode = 2
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.110	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.errorCode = 00-
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.105	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.isInCautionState = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.101	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.isInModeConflict = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.096	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.isInWarningState = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.089	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.isInErrorState = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.085	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.isHolidayModeActive = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.080	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.iconId = 1
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.076	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.name = Wohnzimmer
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.072	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.climateControl.onOffMode = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.067	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.gateway.wifiConnectionStrength = -53
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.063	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.gateway.wifiConnectionSSID = Fritzbox
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.058	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.gateway.daylightSavingTimeEnabled = true
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.054	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.gateway.timeZone = Europe/Berlin
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.049	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.gateway.regionCode = eu
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.045	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.gateway.ssid = DaikinAP32008
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.041	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.gateway.isInErrorState = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.036	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.gateway.errorCode =
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.032	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.gateway.serialNumber = 0000000004165338
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.028	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.gateway.firmwareVersion = 1_12_51
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.023	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.gateway.macAddress = 24:cd:8d:9a:61:6c
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.019	debug	Set initial state value: e4a3a2ad-8e6d-42ec-8a35-44c7f47c96b9.gateway.modelInfo = BRP069C4x
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.014	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.outdoorUnit.isInCautionState = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.010	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.outdoorUnit.isInWarningState = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.005	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.outdoorUnit.isInErrorState = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:03.001	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.outdoorUnit.errorCode = 00-
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.997	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.indoorUnit.dryKeepSetting = true
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.992	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.indoorUnit.eepromVersion = 12FC
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.988	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.indoorUnit.softwareVersion = 20003002
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.983	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.outdoorSilentMode = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.978	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.isLockFunctionEnabled = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.974	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.isCoolHeatMaster = true
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.970	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.holidayMode = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.965	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.consumptionData.electrical = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.961	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.streamerMode = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.956	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.isPowerfulModeActive = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.949	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.powerfulMode = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.944	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.econoMode = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.940	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.schedule.modes.any.schedules.2 = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.935	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.schedule.modes.any.schedules.1 = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.930	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.schedule.modes.any.schedules.0 = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.925	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.schedule.modes.any.meta.actionTypes.econoMode = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.921	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.schedule.modes.any.meta.actionTypes.fanSpeed.fanOnly.modes.fixed = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.916	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.schedule.modes.any.meta.actionTypes.fanSpeed.fanOnly.currentMode = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.911	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.schedule.modes.any.meta.actionTypes.fanSpeed.dry.currentMode = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.905	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.schedule.modes.any.meta.actionTypes.fanSpeed.auto.modes.fixed = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.900	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.schedule.modes.any.meta.actionTypes.fanSpeed.auto.currentMode = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.894	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.schedule.modes.any.meta.actionTypes.fanSpeed.cooling.modes.fixed = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.889	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.schedule.modes.any.meta.actionTypes.fanSpeed.cooling.currentMode = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.884	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.schedule.modes.any.meta.actionTypes.fanSpeed.heating.modes.fixed = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.879	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.schedule.modes.any.meta.actionTypes.fanSpeed.heating.currentMode = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.874	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.schedule.modes.any.meta.actionTypes.roomTemperature.auto = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.869	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.schedule.modes.any.meta.actionTypes.roomTemperature.cooling = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.864	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.schedule.modes.any.meta.actionTypes.roomTemperature.heating = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.860	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.schedule.modes.any.meta.actionTypes.operationMode = null
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.855	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.schedule.modes.any.enabled = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.850	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.schedule.modes.any.currentSchedule = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.846	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.schedule.currentMode = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.840	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.fanControl.operationModes.fanOnly.fanDirection.vertical.currentMode = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.835	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.fanControl.operationModes.fanOnly.fanDirection.horizontal.currentMode = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.830	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.fanControl.operationModes.fanOnly.fanSpeed.modes.fixed = 1
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.825	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.fanControl.operationModes.fanOnly.fanSpeed.currentMode = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.820	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.fanControl.operationModes.dry.fanDirection.vertical.currentMode = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.814	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.fanControl.operationModes.dry.fanDirection.horizontal.currentMode = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.809	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.fanControl.operationModes.dry.fanSpeed.currentMode = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.803	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.fanControl.operationModes.auto.fanDirection.vertical.currentMode = 2
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.796	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.fanControl.operationModes.auto.fanDirection.horizontal.currentMode = 1
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.790	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.fanControl.operationModes.auto.fanSpeed.modes.fixed = 1
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.783	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.fanControl.operationModes.auto.fanSpeed.currentMode = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.777	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.fanControl.operationModes.cooling.fanDirection.vertical.currentMode = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.772	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.fanControl.operationModes.cooling.fanDirection.horizontal.currentMode = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.767	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.fanControl.operationModes.cooling.fanSpeed.modes.fixed = 5
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.762	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.fanControl.operationModes.cooling.fanSpeed.currentMode = 2
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.757	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.fanControl.operationModes.heating.fanDirection.vertical.currentMode = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.752	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.fanControl.operationModes.heating.fanDirection.horizontal.currentMode = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.748	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.fanControl.operationModes.heating.fanSpeed.modes.fixed = 1
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.740	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.fanControl.operationModes.heating.fanSpeed.currentMode = 0
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.706	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.sensoryData.outdoorTemperature = 12.5
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.701	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.sensoryData.roomTemperature = 21
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.695	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.temperatureControl.operationModes.auto.setpoints.roomTemperature = 21
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.689	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.temperatureControl.operationModes.cooling.setpoints.roomTemperature = 18
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.682	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.temperatureControl.operationModes.heating.setpoints.roomTemperature = 25
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.676	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.operationMode = 3
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.669	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.errorCode = 00-
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.663	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.isInCautionState = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.658	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.isInModeConflict = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.653	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.isInWarningState = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.647	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.isInErrorState = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.642	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.isHolidayModeActive = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.636	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.iconId = 16
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.631	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.name = Schlafzimmer
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.625	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.climateControl.onOffMode = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.620	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.gateway.wifiConnectionStrength = -47
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.614	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.gateway.wifiConnectionSSID = Fritzbox
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.607	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.gateway.daylightSavingTimeEnabled = true
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.602	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.gateway.timeZone = Europe/Berlin
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.597	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.gateway.regionCode = eu
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.592	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.gateway.ssid = DaikinAP19912
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.585	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.gateway.isInErrorState = false
                          daikin-cloud.0
                          23551	2022-05-28 11:08:02.579	debug	Set initial state value: d421e0fa-5181-46d2-a29b-480607735929.gateway.errorCode =
                          Logs von Platte.
                          iobroker.2022-05-28.log
                            @aidan Na ok, dann machen wir es anders ... Bitte installier mal Adapter vin GitHub.
                            Admin - expertenmodus aktivieren - Adapter - das Github Icon (letztes in der zweiten Button reihe)/Custom install und dann dort letztes Tab. Dort "https://github.com/Apollon77/ioBroker.daikin-cloud" eingeben und installieren. Warten. Kann aktuell mit npm 6 bis zu 10+ Minuten dauern. Versionsnummer ändert sich nicht. Danach manuell neu starten und nochmal das Log von Platte bitte.
                            Er loggt jetzt die Device Rohdaten. Dann schauen wir mal was Daikin da so zurückgibt
                              @apollon77
                              einfach drüber bügeln? oder den jetzigen Adapter erst deinstallen?
                                @aidan Drüber bügeln
                                  @apollon77
                                  ok installiere jetzt, habe den Haken bei Debug mit rein gesetzt. Starte den Raspi nach Abschluss neu und stell dir die Log ein..
                                    @apollon77
                                    Hier ist es-)
                                    Jetzt geht nix mehr^^ Meckert ja, das der Token fehlt, QR geht auf, klick auf den Link, Seite kann nicht erreicht werden
                                    Adapter
                                      @aidan Ok, mein Fehler ... Bitte nochmal neu von GitHub
                                        @apollon77
                                        jau nun ist er wieder verbunden..
                                        Wohnzimmer zeigt er immer noch offline an
                                        Und die Log.. (Iobroker stop/ start durchgeführt)
                                          @aidan Jetzt haste aber debug loglevel für die Instanz vergessen oder?
                                            @apollon77 sorry, hast recht!
                                            irgendwie habe ich gerade probs mit der ccu3 .. sie ist sporadisch nicht erreichbar?
                                            hier die Log
                                            31.7k
                                            79.8k
                                            307
                                            41293
