    4. Unifi Protect Adapter
      sailer22 last edited by
      Hi zusammen,
      ich habe heute den aktuellen Adapter von GitHub installiert. Erstmal vielen Dank an die Entwickler !
      Ich habe jetzt allerdings ein Problem mit den Snapshots. Die wurden einmal angelegt und danach nicht wieder. Im Log sehe ich ein restart des adapters sobald ein motion event stattfindet.
      Hat jemand eine Idee woran das liegt ?
      Hier mal die Logs dazu.
      unifi-protect.0 2022-02-21 18:01:25.377 info 172.16.10.52: Connected to the UniFi realtime update events API.
      unifi-protect.0 2022-02-21 18:01:25.344 info 172.16.10.52: Connected to the Protect controller API (address: 172.16.10.52 mac: 784558DECB59).
      unifi-protect.0 2022-02-21 18:01:24.267 info starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.unifi-protect, node: v12.22.8, js-controller: 3.3.22
      host.e88d810f7b56 2022-02-21 18:01:22.203 info instance system.adapter.unifi-protect.0 started with pid 17052
      host.e88d810f7b56 2022-02-21 18:00:52.148 info Restart adapter system.adapter.unifi-protect.0 because enabled
      host.e88d810f7b56 2022-02-21 18:00:52.147 error instance system.adapter.unifi-protect.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.e88d810f7b56 2022-02-21 18:00:52.146 error Caught by controller[1]: at Receiver.getData (/opt/iobroker/node_modules/iobroker.unifi-protect/node_modules/ws/lib/receiver.js:446:17)
      host.e88d810f7b56 2022-02-21 18:00:52.146 error Caught by controller[1]: at Receiver.dataMessage (/opt/iobroker/node_modules/iobroker.unifi-protect/node_modules/ws/lib/receiver.js:513:14)
      host.e88d810f7b56 2022-02-21 18:00:52.145 error Caught by controller[1]: at Receiver.EventEmitter.emit (domain.js:483:12)
      host.e88d810f7b56 2022-02-21 18:00:52.145 error Caught by controller[1]: at Receiver.emit (events.js:314:20)
      host.e88d810f7b56 2022-02-21 18:00:52.144 error Caught by controller[1]: at Receiver.receiverOnMessage (/opt/iobroker/node_modules/iobroker.unifi-protect/node_modules/ws/lib/websocket.js:1137:20)
      host.e88d810f7b56 2022-02-21 18:00:52.144 error Caught by controller[1]: at WebSocket.EventEmitter.emit (domain.js:483:12)
      host.e88d810f7b56 2022-02-21 18:00:52.144 error Caught by controller[1]: at WebSocket.emit (events.js:326:22)
      host.e88d810f7b56 2022-02-21 18:00:52.143 error Caught by controller[1]: at WebSocket.<anonymous> (/opt/iobroker/node_modules/iobroker.unifi-protect/protect_api/protect-update-events.js:309:12)
      host.e88d810f7b56 2022-02-21 18:00:52.143 error Caught by controller[1]: at ProtectUpdateEvents.motionEventHandler (/opt/iobroker/node_modules/iobroker.unifi-protect/protect_api/protect-update-events.js:365:77)
      host.e88d810f7b56 2022-02-21 18:00:52.142 error Caught by controller[1]: at ProtectApi.getFullNameById (/opt/iobroker/node_modules/iobroker.unifi-protect/protect_api/protect-api.js:424:31)
      host.e88d810f7b56 2022-02-21 18:00:52.142 error Caught by controller[1]: TypeError: Cannot read property 'find' of null
      host.e88d810f7b56 2022-02-21 18:00:52.141 error Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      unifi-protect.0 2022-02-21 18:00:51.452 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
      unifi-protect.0 2022-02-21 18:00:51.448 info terminating
      unifi-protect.0 2022-02-21 18:00:51.446 info cleaned everything up...
      unifi-protect.0 2022-02-21 18:00:51.407 error Cannot read property 'find' of null
      unifi-protect.0 2022-02-21 18:00:51.406 error TypeError: Cannot read property 'find' of null at ProtectApi.getFullNameById (/opt/iobroker/node_modules/iobroker.unifi-protect/protect_api/protect-api.js:424:31) at ProtectUpdateEvents.motionEventHandler (/opt/iobroker/node_modules/iobroker.unifi-protect/protect_api/protect-update-events.js:365:77) at WebSocket.<anonymous> (/opt/iobroker/node_modules/iobroker.unifi-protect/protect_api/protect-update-events.js:309:12) at WebSocket.emit (events.js:326:22) at WebSocket.EventEmitter.emit (domain.js:483:12) at Receiver.receiverOnMessage (/opt/iobroker/node_modules/iobroker.unifi-protect/node_modules/ws/lib/websocket.js:1137:20) at Receiver.emit (events.js:314:20) at Receiver.EventEmitter.emit (domain.js:483:12) at Receiver.dataMessage (/opt/iobroker/node_modules/iobroker.unifi-protect/node_modules/ws/lib/receiver.js:513:14) at Receiver.getData (/opt/iobroker/node_modules/iobroker.unifi-protect/node_modules/ws/lib/receiver.js:446:17)
      unifi-protect.0 2022-02-21 18:00:51.389 error unhandled promise rejection: Cannot read property 'find' of null
      unifi-protect.0 2022-02-21 18:00:51.387 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        Ritschi last edited by
        Hallo
        Ich würde gerne den Adapter nutzen, um Kameras ein und aus zu schalten. Ist das irgendwie schon möglich zu machen?
        Hintergrund:
        Ich Überwache einen Pool.
        Bei Bewegung wird gemeldet.
        Nun möchte ich, dass wenn der Pool Rollo offen ist die Kamera ausschaltet.
        da stelle ich mir vor, dass das am Besten möglich wäre POE auszuschalten o.ä.
        Gruss
        Ritschi
          steimi @Ritschi last edited by
          @ritschi Ausschalten nicht, aber du kannst das Recording umschalten zwischen 'always/never/detections'
          Schau dir da den Github-Issue an, da musst du was an den Objekten einmalig ändern.
          • Xenon
            Xenon Forum Testing Developer last edited by Xenon
            Bin ich der einzige bei dem der Adapter überhaupt nicht mehr stabil läuft? Auf github gibt's dazu auch schon ein issue. Der Adapter stürzt komplett ab und startet auch nicht mehr neu, wegen restart loop. Auf github passiert aber leider auch nix mehr
            @peterbaumert
              steimi last edited by
              nein, habe mittlerweile das gleiche Problem nach Änderungenbei den zu synchronisierenden Objekten. Auch wenn die eine Kamera hinzufügst im Unifi Protect und der Adapter läuft schmiert er ab.
              Ich denke mal der Adapter wird nicht weiter entwickeln - sehr schade.
              Xenon 1 Reply Last reply Reply Quote 0
              • Xenon
                Xenon Forum Testing Developer @steimi last edited by
                @steimi hab aktuell leider zu viel um die Ohren sonst würde ich mir das ganze mal anschauen. Aber einarbeiten in fremde Adapter dauert halt immer ein wenig
                  steimi @Xenon last edited by
                  @xenon wäre Klasse wenn sich jemand wieder aktiv um den Adapter kümmert - auch in Hinsicht auf die kommende Protect 2.0.0 von UI.
                  • Xenon
                    ich habe mir den Adapter jetzt vorgenommen und werde ihn mal komplett zerlegen. Sobald ich was gefunden habe, melde ich mich wieder.
                    Auf die Schnelle KÖNNTE es helfen, alle motionEvents zu deaktivieren in den Instanzeinstellungen
                    F 1 Reply Last reply Reply Quote 2
                      Frank579 @Xenon last edited by
                      @xenon
                      finde ich wirklich klasse das sich jemand um den Adapter kümmert 👍
                      wenn du Zeit findest könntest du da auch mal nachsehen ob du etwas findest, habe leider vom Entwickler nichts mehr gehört, oben sind auch noch diverse Logs,wenn du mehr benötigst oder etwas aktuelles sag bescheid 🙂
                      @frank579 sagte in Unifi Protect Adapter:
                      peterbaumert
                      Hallo der Adapter lief lage zeit super, jedoch habe ich seit einiger Zeit (ca.2Wochen) das Problem das ich vom Adapter alte Bilder in die Vis und per Telgram bekomme. Hat das Problem noch jemand ? Mir ist nicht bewusst das ich zu dem Zeitpunkt etwas geändert habe.
                      • Xenon
                        Xenon Forum Testing Developer @Frank579 last edited by
                        @frank579 ich habe mir die Version jetzt umgebaut und neue Logmeldungen eingebaut, damit ich dem ganzen überhaupt mal auf die Spur kommen kann. Das nervige ist ja, dass die Meldungen so unregelmäßig kommen. Daher lasse ich den Adapter jetzt ein paar Tage laufen, sammle die debugs dazu und werde sie dann auswerten
                          @xenon
                          Eilt ja nicht, hatte das an der Haustüre Eingerichtet das ich ne Telegram mit bekomme wenn jemand da ist, habs derzeit auch da es mir egal ist wer Irgendwann mal da war, wäre aber super wenns irgenswann wieder klappen würde. Licht an bei bewegung läuft ja soweit... Also keinen Stress 😉
                          • Xenon
                            @frank579 kriegen wir schon hin 😉
                            • Xenon
                              @steimi sagte in Unifi Protect Adapter:
                              Die 2.0 läuft bei mir aktuell. Der Adapter Fehler ist aber leider geblieben. Wie gesagt, ich schaue es mir aber jetzt an 😉
                              • Xenon
                                es gibt eine neue Github Version, für die Leute, die testen wollen 😉
                                  @xenon
                                  Der Link von oben? Würde gerne testen auch wenn ich den Fehler von oben nicht habe 🙂
                                  • Xenon
                                    @frank579 ja der link aus dem ersten beitrag. Muss aber per github installiert werden (beachten, dass npm 6 aktuell einen Bug hat und Installationen von github einige Minuten dauern anstatt Sekunden)
                                      @xenon okay dann werde ich später mal versuchen, danke für den Tip, hatte ich schon gehört,dachte aber das wäre langsam erledigt 😁😏
                                        @xenon Update ist durchgelaufen, so wie's aussieht läuft auch alles wie vorher👍 im Log meldet er den Controller und die Cam's als gefunden ...
                                        • Xenon
                                          @frank579 bei mir läuft es auch fehlerfrei seit Update. Habe direkten Kontakt mit dem Entwickler. Hat gut geklappt 😃
                                          Neuschwansteini 1 Reply Last reply Reply Quote 0
                                          • Neuschwansteini
                                            Neuschwansteini @Xenon last edited by
                                            @xenon
                                            Hi, koenntest du dir den Unifi Adapter https://github.com/iobroker-community-adapters/ioBroker.unifi auch mal vornehmen?
                                            Der beendet die Abfrage gerne mal mit einem unexpected json oder sonstigen zicken..
                                            Oder was nutzt ihr, alternativ? snmp ?
                                            Ich hab 7 AP's und ne Dream machine pro und ein paar Switche..
                                            Xenon 2 Replies Last reply Reply Quote 0
                                            31.7k
                                            79.8k
                                            unifi unifi protect
                                            60
                                            221
                                            30379
