    4. iobrocker Backup
    iobrocker Backup
      Thomas Braun Most Active @derdoerk last edited by
      @derdoerk
      Mal mehr Infos posten:
      iobroker status
      sudo ln -s /usr/bin/node /usr/bin/nodejs
      uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      iobroker update -u
        derdoerk @Thomas Braun last edited by derdoerk
        MOrjen,
        hier die Infos die du wolltests:
        pi@iobroker:~ $ iobroker status
        Objects type: jsonl
        States  type: jsonl
        pi@iobroker:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
        pi@iobroker:~ $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        aarch64
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v14.19.3
        v14.19.3
        6.14.17
        pi
        /home/pi
        OK:1 http://security.debian.org/debian-security bullseye-security InRelease
        OK:2 http://deb.debian.org/debian bullseye InRelease
        OK:3 http://deb.debian.org/debian bullseye-updates InRelease
        OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
        OK:5 https://deb.nodesource.com/node_14.x bullseye InRelease
        Paketlisten werden gelesen… Fertig
        Abhängigkeitsbaum wird aufgebaut… Fertig
        Statusinformationen werden eingelesen… Fertig
        Alle Pakete sind aktuell.
        nodejs:
          Installiert:           14.19.3-deb-1nodesource1
          Installationskandidat: 14.19.3-deb-1nodesource1
          Versionstabelle:
         *** 14.19.3-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_14.x bullseye/main arm64 Packages
                100 /var/lib/dpkg/status
             12.22.5~dfsg-2~11u1 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
        pi@iobroker:~ $ iobroker update -u
        Used repository: stable
        pi@iobroker:~ $ pi@iobroker:~ $ iobroker status
        Objects type: jsonl
        States  type: jsonl
        aarch64
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v14.19.3
        v14.19.3
        6.14.17
        pi
        /home/pi
        nodejs:
          Versionstabelle:
        Objects type: jsonl
        States  type: jsonl
        aarch64
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v14.19.3
        v14.19.3
        6.14.17
        pi
        /home/pi
        ^Ced repository: stabler update -u.org/debian-security bullseye-security/main arm64 Packagesi && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        Wenn ich ein BAckup starten will passiert nach:
        pi@iobroker:~ $ iobroker backup
        host.iobroker 9736 states saved
        nichts mehr
        Dirk
          @derdoerk
          Die Installations-Basis ist stabil und aktuell. Hatte da ehrlich gesagt anderes erwartet.
          Poste mal bitte das Log vom 'Backitup'-Adapter.
            MOrjen,
            was meinst du den genau an Log:
            Hab hier die Debug Ausgaben
            Started iobroker ...
            [DEBUG] [iobroker] start with {"type":"creator","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.0.160","debugging":true,"deleteOldBackup":true,"ownDir":true,"dir":"/Haussteuerung_Backup","dirMinimal":"/Haussteuerung_Backup","user":"Backup","pass":"****","port":"21","ignoreErrors":false},"ignoreErrors":false,"dir":"/opt/iobroker","yahka":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.0.160","debugging":true,"deleteOldBackup":true,"ownDir":true,"dir":"/Haussteuerung_Backup","dirMinimal":"/Haussteuerung_Backup","user":"Backup","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":false,"mountType":"Copy","type":"storage","source":"ftp","mount":"192.168.0.160","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"/Haussteuerung_Backup","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.0.160","debugging":true,"deleteOldBackup":true,"ownDir":true,"dir":"/Haussteuerung_Backup","dirMinimal":"/Haussteuerung_Backup","user":"Backup","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":false,"mountType":"Copy","type":"storage","source":"ftp","mount":"192.168.0.160","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"/Haussteuerung_Backup","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
            [DEBUG] [iobroker] - host.iobroker 9733 states saved
            Nur wie gesagt, selbst das normale Backup via Console läuft ja nicht.
            Dirk
              Thomas Braun Most Active @derdoerk last edited by Thomas Braun
              @derdoerk
              Ich hatte gehofft das wäre etwas gesprächiger.
              Ist noch genügend Platz?
              df -h /
              Am Rande: ftp-Transfer sollte nicht die erste Wahl sein. Wenn du die Möglichkeit hast per CIFS oder NFS da die Daten zu sichern tu das.
                pi@iobroker:~ $ df -h /
                Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
                /dev/root       117G     34G   79G   30% /
                Ich frag mich aber, was so groß ist mit 34GB
                  @derdoerk sagte in iobrocker Backup:
                  Platz ist also noch da.
                  Mit
                  sudo ncdu /
                  kann man sehen wo die dicken Brummer hängen.
                    @thomas-braun sagte in iobrocker Backup:
                    sudo ncdu /
                    Die Frage ist, ob irgend ein ordner das Problem ist, weil er zu groß ist, die Frage ist ja, wie man das dann beheben kann 🙂
                       31,6 GiB [######### ] /opt
                        1,4 GiB [          ] /usr
                      800,1 MiB [          ] /var
                       98,4 MiB [          ] /home
                       30,1 MiB [          ] /boot
                        3,7 MiB [          ] /etc
                      848,0 KiB [          ] /run
                       40,0 KiB [          ] /tmp
                       20,0 KiB [          ] /root
                    e  16,0 KiB [          ] /lost+found
                    e   4,0 KiB [          ] /srv
                    e   4,0 KiB [          ] /mnt
                    e   4,0 KiB [          ] /media
                        0,0   B [          ] /sys
                    .   0,0   B [          ] /proc
                        0,0   B [          ] /dev
                    @   0,0   B [          ]  sbin
                    @   0,0   B [          ]  lib
                    @   0,0   B [          ]  bin
                      Das dürfte dann der iobroker sein. Was schleppst du denn da alles mit? Hollywood-Filme aus den Überwachungskameras? Da wundert es mich auch nicht, dass dein Bakup schwer zu schlucken hat. Das ist einfach zu viel Zeug zum packen.
                      Mein iobroker lebt z. B. mit 820MB:
                      --- /opt -------------------------------------
                      822.8 MiB [##########] /iobroker
                        pi@iobroker:~ $ iob backup
                        host.iobroker 9734 states saved
                        host.iobroker 10954 objects saved
                        Backup created: /opt/iobroker/backups/2022_05_28-14_13_46_backupiobroker.tar.gz
                        pi@iobroker:~ $
                        hab ne ring Kamera und Adapter da waren noch Bilder und Videos versteckt
                        hab die jetzt alle mal gelöscht, dann war das ganze auch nur noch halb so groß und etwas mehr
                          hab ne ring Kamera und Adapter da waren noch bilder und Videos versteckt
                          Komst du gerade frisch aus Cannes? 'Goldene Palme' gewonnen?
                          389
