    4. Test Adapter TrashSchedule
    • SBorg
      SBorg Forum Testing Most Active @haus-automatisierung last edited by
      Hallo Matthias, da fehlt IMHO noch etwas für die "Info-Adapter-Anzeige":
      ...oder ist der "stealth-mode" Absicht 😇
      • JB_Sullivan
        JB_Sullivan @haus-automatisierung last edited by JB_Sullivan
        Habe es mal so klein wie möglich gemacht, damit soviel wie möglich sehen kann - hoffe das ist noch ausreichend.
        Hier das Debug der 2.0.0
        trashschedule.0
        14612	2022-05-28 12:41:59.670	debug	(5) filling "nextAfter" event with data: {"minDays":12,"minDate":"2022-06-08T22:00:00.000Z","minTypes":["Gelber Sack","Grünmüll","Papiertonne"]}
        trashschedule.0
        14612	2022-05-28 12:41:59.606	debug	(5) filling "next" event with data: {"minDays":4,"minDate":"2022-05-31T22:00:00.000Z","minTypes":["Restmüll","Grünmüll"]}
        trashschedule.0
        14612	2022-05-28 12:41:59.589	debug	(3) event match: "Biotonne" matches type "Grünmüll" with pattern "Bio"
        trashschedule.0
        14612	2022-05-28 12:41:59.589	debug	(2) processing: "Biotonne" (1655848800000) // dayDiff: 25 // current hour (date): 12 (1653688800000) // skipsamedayathour (config): 22
        trashschedule.0
        14612	2022-05-28 12:41:59.589	debug	(1) parsing next event {"date":"22.06. ","event":"Biotonne","_class":"ical_Abfallkalender ","_date":"2022-06-21T22:00:00.000Z","_end":"2022-06-22T22:00:00.000Z","_section":"Biotonne muss bereitgestellt werden.","_IDID":"61171f35ab4c4cf0c6d229c4ff2e551e","_allDay":true,"_private":false,"_rule":" ","location":"Peine Ortschaften AIa1","_calName":"Abfallkalender","_calColor":"#af6161","_object":{"type":"VEVENT","params":[],"start":"2022-06-21T22:00:00.000Z","datetype":"date","end":"2022-06-22T22:00:00.000Z","dtstamp":"2022-05-28T10:18:17.000Z","uid":"61171f35ab4c4cf0c6d229c4ff2e551e","created":"2022-01-05T10:24:58.000Z","description":"Biotonne muss bereitgestellt werden.","lastmodified":"2022-01-17T09:49:35.000Z","location":"Peine Ortschaften AIa1","sequence":"0","status":"CONFIRMED","summary":"Biotonne","transparency":"OPAQUE","method":"PUBLISH"}} // originalDate: 2022-06-21T22:00:00.000Z // calculated date (with offset): Wed Jun 22 2022 00:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)
        trashschedule.0
        14612	2022-05-28 12:41:59.588	debug	(3) event match: "Biotonne" matches type "Grünmüll" with pattern "Bio"
        trashschedule.0
        14612	2022-05-28 12:41:59.588	debug	(2) processing: "Biotonne" (1655244000000) // dayDiff: 18 // current hour (date): 12 (1653688800000) // skipsamedayathour (config): 22
        trashschedule.0
        14612	2022-05-28 12:41:59.587	debug	(1) parsing next event {"date":"15.06. ","event":"Biotonne","_class":"ical_Abfallkalender ","_date":"2022-06-14T22:00:00.000Z","_end":"2022-06-15T22:00:00.000Z","_section":"Biotonne muss bereitgestellt werden.","_IDID":"47a99a698860ec971c837ad22d7ff188","_allDay":true,"_private":false,"_rule":" ","location":"Peine Ortschaften AIa1","_calName":"Abfallkalender","_calColor":"#af6161","_object":{"type":"VEVENT","params":[],"start":"2022-06-14T22:00:00.000Z","datetype":"date","end":"2022-06-15T22:00:00.000Z","dtstamp":"2022-05-28T10:18:17.000Z","uid":"47a99a698860ec971c837ad22d7ff188","created":"2022-01-05T10:24:58.000Z","description":"Biotonne muss bereitgestellt werden.","lastmodified":"2022-01-17T09:49:35.000Z","location":"Peine Ortschaften AIa1","sequence":"0","status":"CONFIRMED","summary":"Biotonne","transparency":"OPAQUE","method":"PUBLISH"}} // originalDate: 2022-06-14T22:00:00.000Z // calculated date (with offset): Wed Jun 15 2022 00:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)
        trashschedule.0
        14612	2022-05-28 12:41:59.587	debug	(3) event match: "Restmülltonne" matches type "Restmüll" with pattern "Restmüll"
        trashschedule.0
        14612	2022-05-28 12:41:59.586	debug	(2) processing: "Restmülltonne" (1655244000000) // dayDiff: 18 // current hour (date): 12 (1653688800000) // skipsamedayathour (config): 22
        trashschedule.0
        14612	2022-05-28 12:41:59.586	debug	(1) parsing next event {"date":"15.06. ","event":"Restmülltonne","_class":"ical_Abfallkalender ","_date":"2022-06-14T22:00:00.000Z","_end":"2022-06-15T22:00:00.000Z","_section":"Restmülltonne muss bereitgestellt werden.","_IDID":"51e160564d57de83c65d140b7365983b","_allDay":true,"_private":false,"_rule":" ","location":"Peine Ortschaften AIa1","_calName":"Abfallkalender","_calColor":"#af6161","_object":{"type":"VEVENT","params":[],"start":"2022-06-14T22:00:00.000Z","datetype":"date","end":"2022-06-15T22:00:00.000Z","dtstamp":"2022-05-28T10:18:17.000Z","uid":"51e160564d57de83c65d140b7365983b","created":"2022-01-05T10:24:58.000Z","description":"Restmülltonne muss bereitgestellt werden.","lastmodified":"2022-01-17T09:49:35.000Z","location":"Peine Ortschaften AIa1","sequence":"0","status":"CONFIRMED","summary":"Restmülltonne","transparency":"OPAQUE","method":"PUBLISH"}} // originalDate: 2022-06-14T22:00:00.000Z // calculated date (with offset): Wed Jun 15 2022 00:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)
        trashschedule.0
        14612	2022-05-28 12:41:59.585	debug	(4) filled type: "Papiertonne"
        trashschedule.0
        14612	2022-05-28 12:41:59.537	debug	(3) event match: "Altpapiertonne" matches type "Papiertonne" with pattern "Altpapier"
        trashschedule.0
        14612	2022-05-28 12:41:59.537	debug	(2) processing: "Altpapiertonne" (1654725600000) // dayDiff: 12 // current hour (date): 12 (1653688800000) // skipsamedayathour (config): 22
        trashschedule.0
        14612	2022-05-28 12:41:59.536	debug	(1) parsing next event {"date":"09.06. ","event":"Altpapiertonne","_class":"ical_Abfallkalender ","_date":"2022-06-08T22:00:00.000Z","_end":"2022-06-09T22:00:00.000Z","_section":"Altpapiertonne muss bereitgestellt werden.","_IDID":"34595c6f0c822cd755177b3f86041d18","_allDay":true,"_private":false,"_rule":" ","location":"Peine Ortschaften AIa1","_calName":"Abfallkalender","_calColor":"#af6161","_object":{"type":"VEVENT","params":[],"start":"2022-06-08T22:00:00.000Z","datetype":"date","end":"2022-06-09T22:00:00.000Z","dtstamp":"2022-05-28T10:18:17.000Z","uid":"34595c6f0c822cd755177b3f86041d18","created":"2022-01-05T10:24:58.000Z","description":"Altpapiertonne muss bereitgestellt werden.","lastmodified":"2022-01-17T09:49:35.000Z","location":"Peine Ortschaften AIa1","sequence":"0","status":"CONFIRMED","summary":"Altpapiertonne","transparency":"OPAQUE","method":"PUBLISH"}} // originalDate: 2022-06-08T22:00:00.000Z // calculated date (with offset): Thu Jun 09 2022 00:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)
        trashschedule.0
        14612	2022-05-28 12:41:59.536	debug	(3) event match: "Biotonne" matches type "Grünmüll" with pattern "Bio"
        trashschedule.0
        14612	2022-05-28 12:41:59.535	debug	(2) processing: "Biotonne" (1654725600000) // dayDiff: 12 // current hour (date): 12 (1653688800000) // skipsamedayathour (config): 22
        trashschedule.0
        14612	2022-05-28 12:41:59.535	debug	(1) parsing next event {"date":"09.06. ","event":"Biotonne","_class":"ical_Abfallkalender ","_date":"2022-06-08T22:00:00.000Z","_end":"2022-06-09T22:00:00.000Z","_section":"Biotonne muss bereitgestellt werden.","_IDID":"a45ac6cafa5882a7ddeb0d9b84a897f1","_allDay":true,"_private":false,"_rule":" ","location":"Peine Ortschaften AIa1","_calName":"Abfallkalender","_calColor":"#af6161","_object":{"type":"VEVENT","params":[],"start":"2022-06-08T22:00:00.000Z","datetype":"date","end":"2022-06-09T22:00:00.000Z","dtstamp":"2022-05-28T10:18:17.000Z","uid":"a45ac6cafa5882a7ddeb0d9b84a897f1","created":"2022-01-05T10:24:58.000Z","description":"Biotonne muss bereitgestellt werden.","lastmodified":"2022-01-17T09:49:35.000Z","location":"Peine Ortschaften AIa1","sequence":"0","status":"CONFIRMED","summary":"Biotonne","transparency":"OPAQUE","method":"PUBLISH"}} // originalDate: 2022-06-08T22:00:00.000Z // calculated date (with offset): Thu Jun 09 2022 00:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)
        trashschedule.0
        14612	2022-05-28 12:41:59.534	debug	(4) filled type: "Gelber Sack"
        trashschedule.0
        14612	2022-05-28 12:41:59.491	debug	(3) event match: "Gelber Sack" matches type "Gelber Sack" with pattern "Gelber Sack"
        trashschedule.0
        14612	2022-05-28 12:41:59.490	debug	(2) processing: "Gelber Sack" (1654725600000) // dayDiff: 12 // current hour (date): 12 (1653688800000) // skipsamedayathour (config): 22
        trashschedule.0
        14612	2022-05-28 12:41:59.490	debug	(1) parsing next event {"date":"09.06. ","event":"Gelber Sack","_class":"ical_Abfallkalender ","_date":"2022-06-08T22:00:00.000Z","_end":"2022-06-09T22:00:00.000Z","_section":"Gelber Sack muss bereitgestellt werden.","_IDID":"5149be8ead432939824c14246bfab23b","_allDay":true,"_private":false,"_rule":" ","location":"Peine Ortschaften AIa1","_calName":"Abfallkalender","_calColor":"#af6161","_object":{"type":"VEVENT","params":[],"start":"2022-06-08T22:00:00.000Z","datetype":"date","end":"2022-06-09T22:00:00.000Z","dtstamp":"2022-05-28T10:18:17.000Z","uid":"5149be8ead432939824c14246bfab23b","created":"2022-01-05T10:24:58.000Z","description":"Gelber Sack muss bereitgestellt werden.","lastmodified":"2022-01-17T09:49:35.000Z","location":"Peine Ortschaften AIa1","sequence":"0","status":"CONFIRMED","summary":"Gelber Sack","transparency":"OPAQUE","method":"PUBLISH"}} // originalDate: 2022-06-08T22:00:00.000Z // calculated date (with offset): Thu Jun 09 2022 00:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)
        trashschedule.0
        14612	2022-05-28 12:41:59.489	debug	(4) filled type: "Grünmüll"
        trashschedule.0
        14612	2022-05-28 12:41:59.449	debug	(3) event match: "Biotonne" matches type "Grünmüll" with pattern "Bio"
        trashschedule.0
        14612	2022-05-28 12:41:59.448	debug	(2) processing: "Biotonne" (1654034400000) // dayDiff: 4 // current hour (date): 12 (1653688800000) // skipsamedayathour (config): 22
        trashschedule.0
        14612	2022-05-28 12:41:59.448	debug	(1) parsing next event {"date":"In 4 Tagen ","event":"Biotonne","_class":"ical_Abfallkalender ical_4days","_date":"2022-05-31T22:00:00.000Z","_end":"2022-06-01T22:00:00.000Z","_section":"Biotonne muss bereitgestellt werden.","_IDID":"4d53673e99ea2b08018e4fdd56115fc5","_allDay":true,"_private":false,"_rule":" ","location":"Peine Ortschaften AIa1","_calName":"Abfallkalender","_calColor":"#af6161","_object":{"type":"VEVENT","params":[],"start":"2022-05-31T22:00:00.000Z","datetype":"date","end":"2022-06-01T22:00:00.000Z","dtstamp":"2022-05-28T10:18:17.000Z","uid":"4d53673e99ea2b08018e4fdd56115fc5","created":"2022-01-05T10:24:58.000Z","description":"Biotonne muss bereitgestellt werden.","lastmodified":"2022-01-17T09:49:35.000Z","location":"Peine Ortschaften AIa1","sequence":"0","status":"CONFIRMED","summary":"Biotonne","transparency":"OPAQUE","method":"PUBLISH"}} // originalDate: 2022-05-31T22:00:00.000Z // calculated date (with offset): Wed Jun 01 2022 00:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)
        trashschedule.0
        14612	2022-05-28 12:41:59.447	debug	(4) filled type: "Restmüll"
        trashschedule.0
        14612	2022-05-28 12:41:59.406	debug	(3) event match: "Restmülltonne" matches type "Restmüll" with pattern "Restmüll"
        trashschedule.0
        14612	2022-05-28 12:41:59.406	debug	(2) processing: "Restmülltonne" (1654034400000) // dayDiff: 4 // current hour (date): 12 (1653688800000) // skipsamedayathour (config): 22
        trashschedule.0
        14612	2022-05-28 12:41:59.405	debug	(1) parsing next event {"date":"In 4 Tagen ","event":"Restmülltonne","_class":"ical_Abfallkalender ical_4days","_date":"2022-05-31T22:00:00.000Z","_end":"2022-06-01T22:00:00.000Z","_section":"Restmülltonne muss bereitgestellt werden.","_IDID":"2d289aecf55e7fc52c1f3feaaa9611af","_allDay":true,"_private":false,"_rule":" ","location":"Peine Ortschaften AIa1","_calName":"Abfallkalender","_calColor":"#af6161","_object":{"type":"VEVENT","params":[],"start":"2022-05-31T22:00:00.000Z","datetype":"date","end":"2022-06-01T22:00:00.000Z","dtstamp":"2022-05-28T10:18:17.000Z","uid":"2d289aecf55e7fc52c1f3feaaa9611af","created":"2022-01-05T10:24:58.000Z","description":"Restmülltonne muss bereitgestellt werden.","lastmodified":"2022-01-17T09:49:35.000Z","location":"Peine Ortschaften AIa1","sequence":"0","status":"CONFIRMED","summary":"Restmülltonne","transparency":"OPAQUE","method":"PUBLISH"}} // originalDate: 2022-05-31T22:00:00.000Z // calculated date (with offset): Wed Jun 01 2022 00:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)
        trashschedule.0
        14612	2022-05-28 12:41:59.404	debug	(0) offset (config): 0
        trashschedule.0
        14612	2022-05-28 12:41:59.403	debug	(0) start processing 8 iCal events
        trashschedule.0
        14612	2022-05-28 12:41:59.389	debug	(0) updating data
        trashschedule.0
        14612	2022-05-28 12:41:59.387	debug	(0) update started by foreign state value - lc: 2022-05-28T10:15:17.952Z - ts: 2022-05-28T10:15:17.952Z
        trashschedule.0
        14612	2022-05-28 12:41:59.203	debug	re-creating refresh timeout in 1085799ms (in 00:18:05)
        trashschedule.0
        14612	2022-05-28 12:41:59.200	debug	[ical] found ical event(s): {"name":"Gelber Sack","enabled":true,"display":true}
        trashschedule.0
        14612	2022-05-28 12:41:59.200	debug	[ical] found ical event(s): {"name":"Biotonne","enabled":true,"display":true}
        trashschedule.0
        14612	2022-05-28 12:41:59.200	debug	[ical] found ical event(s): {"name":"Altpapiertonne","enabled":true,"display":true}
        trashschedule.0
        14612	2022-05-28 12:41:59.199	debug	[ical] found ical event(s): {"name":"Restmülltonne","enabled":true,"display":true}
        trashschedule.0
        14612	2022-05-28 12:41:59.199	info	[ical] configurured ical preview is 30 days - increase this value to find more events in the future
        trashschedule.0
        14612	2022-05-28 12:41:59.199	debug	[ical] current ical version: 1.12.1
        trashschedule.0
        14612	2022-05-28 12:41:59.193	debug	Trash type deleted: "type."
        trashschedule.0
        14612	2022-05-28 12:41:59.171	debug	Trash type found: "Restmüll"
        trashschedule.0
        14612	2022-05-28 12:41:59.094	debug	Trash type found: "Papiertonne"
        trashschedule.0
        14612	2022-05-28 12:41:59.069	debug	Trash type found: "Grünmüll"
        trashschedule.0
        14612	2022-05-28 12:41:58.830	debug	Trash type found: "Gelber Sack"
        trashschedule.0
        14612	2022-05-28 12:41:58.627	info	starting. Version 2.0.0 in C:/iobroker/GLT/node_modules/iobroker.trashschedule, node: v14.16.0, js-controller: 4.0.23
        trashschedule.0
        14612	2022-05-28 12:41:57.800	debug	Plugin sentry Initialize Plugin (enabled=true)
        trashschedule.0
        14612	2022-05-28 12:41:57.486	debug	States connected to redis: 127.0.0.1:9000
        trashschedule.0
        14612	2022-05-28 12:41:57.407	debug	States create User PubSub Client
        trashschedule.0
        14612	2022-05-28 12:41:57.406	debug	States create System PubSub Client
        trashschedule.0
        14612	2022-05-28 12:41:57.363	debug	Redis States: Use Redis connection: 127.0.0.1:9000
        trashschedule.0
        14612	2022-05-28 12:41:57.280	debug	Objects connected to redis: 127.0.0.1:9001
        trashschedule.0
        14612	2022-05-28 12:41:57.275	debug	Objects client initialize lua scripts
        trashschedule.0
        14612	2022-05-28 12:41:57.186	debug	Objects create User PubSub Client
        trashschedule.0
        14612	2022-05-28 12:41:57.185	debug	Objects create System PubSub Client
        trashschedule.0
        14612	2022-05-28 12:41:57.184	debug	Objects client ready ... initialize now
        trashschedule.0
        14612	2022-05-28 12:41:57.122	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
        .... und von der 2.0.2
        host.GLTGLT)
        2022-05-28 12:44:28.077	info	host.GLT(GLT) Restart adapter system.adapter.trashschedule.0 because enabled
        host.GLTGLT)
        2022-05-28 12:44:28.076	error	host.GLT(GLT) instance system.adapter.trashschedule.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        host.GLTGLT)
        2022-05-28 12:44:28.076	error	host.GLT(GLT) Caught by controller[1]: at Trashschedule.onReady (C:\iobroker\GLT\node_modules\iobroker.trashschedule\main.js:260:28)
        host.GLTGLT)
        2022-05-28 12:44:28.076	error	host.GLT(GLT) Caught by controller[1]: at Trashschedule.delObjectAsync (C:\iobroker\GLT\node_modules\@iobroker\js-controller-common\lib\common\tools.js:2115:16)
        host.GLTGLT)
        2022-05-28 12:44:28.076	error	host.GLT(GLT) Caught by controller[1]: at new Promise (<anonymous>)
        host.GLTGLT)
        2022-05-28 12:44:28.076	error	host.GLT(GLT) Caught by controller[1]: at C:\iobroker\GLT\node_modules\@iobroker\js-controller-common\lib\common\tools.js:2116:16
        host.GLTGLT)
        2022-05-28 12:44:28.076	error	host.GLT(GLT) Caught by controller[1]: at Trashschedule.delObject (C:\iobroker\GLT\node_modules\@iobroker\js-controller-adapter\src\lib\adapter\adapter.js:3209:18)
        host.GLTGLT)
        2022-05-28 12:44:28.076	error	host.GLT(GLT) Caught by controller[1]: at Trashschedule.delForeignObject (C:\iobroker\GLT\node_modules\@iobroker\js-controller-adapter\src\lib\adapter\adapter.js:3267:23)
        host.GLTGLT)
        2022-05-28 12:44:28.076	error	host.GLT(GLT) Caught by controller[1]: at Utils.validateId (C:\iobroker\GLT\node_modules\@iobroker\js-controller-adapter\src\lib\adapter\utils.ts:215:23)
        host.GLTGLT)
        2022-05-28 12:44:28.075	error	host.GLT(GLT) Caught by controller[1]: Error: The id "trashschedule.0.type." is invalid. Ids are not allowed to end in "."
        host.GLTGLT)
        2022-05-28 12:44:28.075	error	host.GLT(GLT) Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        trashschedule.0
        7992	2022-05-28 12:44:27.123	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        trashschedule.0
        7992	2022-05-28 12:44:27.122	debug	Plugin sentry destroyed
        trashschedule.0
        7992	2022-05-28 12:44:27.121	info	terminating
        trashschedule.0
        7992	2022-05-28 12:44:27.120	info	cleaned everything up...
        trashschedule.0
        7992	2022-05-28 12:44:27.080	error	The id "trashschedule.0.type." is invalid. Ids are not allowed to end in "."
        trashschedule.0
        7992	2022-05-28 12:44:27.079	error	Error: The id "trashschedule.0.type." is invalid. Ids are not allowed to end in "." at Utils.validateId (C:\iobroker\GLT\node_modules\@iobroker\js-controller-adapter\src\lib\adapter\utils.ts:215:23) at Trashschedule.delForeignObject (C:\iobroker\GLT\node_modules\@iobroker\js-controller-adapter\src\lib\adapter\adapter.js:3267:23) at Trashschedule.delObject (C:\iobroker\GLT\node_modules\@iobroker\js-controller-adapter\src\lib\adapter\adapter.js:3209:18) at C:\iobroker\GLT\node_modules\@iobroker\js-controller-common\lib\common\tools.js:2116:16 at new Promise (<anonymous>) at Trashschedule.delObjectAsync (C:\iobroker\GLT\node_modules\@iobroker\js-controller-common\lib\common\tools.js:2115:16) at Trashschedule.onReady (C:\iobroker\GLT\node_modules\iobroker.trashschedule\main.js:260:28)
        trashschedule.0
        7992	2022-05-28 12:44:26.514	error	unhandled promise rejection: The id "trashschedule.0.type." is invalid. Ids are not allowed to end in "."
        trashschedule.0
        7992	2022-05-28 12:44:26.514	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        trashschedule.0
        7992	2022-05-28 12:44:26.512	debug	deleting existing but unconfigured trash type with ID "type."
        trashschedule.0
        7992	2022-05-28 12:44:26.473	debug	found configured trash type: "Restmüll" with ID "type.restmüll"
        trashschedule.0
        7992	2022-05-28 12:44:26.452	debug	found configured trash type: "Papiertonne" with ID "type.papiertonne"
        trashschedule.0
        7992	2022-05-28 12:44:26.431	debug	found configured trash type: "Grünmüll" with ID "type.grünmüll"
        trashschedule.0
        7992	2022-05-28 12:44:26.318	debug	found configured trash type: "Gelber Sack" with ID "type.gelberSack"
        trashschedule.0
        7992	2022-05-28 12:44:26.313	debug	found existing trash type with ID "type.restmüll"
        trashschedule.0
        7992	2022-05-28 12:44:26.313	debug	found existing trash type with ID "type.papiertonne"
        trashschedule.0
        7992	2022-05-28 12:44:26.312	debug	found existing trash type with ID "type.grünmüll"
        trashschedule.0
        7992	2022-05-28 12:44:26.312	debug	found existing trash type with ID "type.gelberSack"
        trashschedule.0
        7992	2022-05-28 12:44:26.311	debug	found existing trash type with ID "type."
        trashschedule.0
        7992	2022-05-28 12:44:26.123	info	starting. Version 2.0.2 in C:/iobroker/GLT/node_modules/iobroker.trashschedule, node: v14.16.0, js-controller: 4.0.23
        trashschedule.0
        7992	2022-05-28 12:44:25.355	debug	Plugin sentry Initialize Plugin (enabled=true)
        vis.0
        3268	2022-05-28 12:44:25.112	info	vis license is OK.
        trashschedule.0
        7992	2022-05-28 12:44:24.965	debug	States connected to redis: 127.0.0.1:9000
        trashschedule.0
        7992	2022-05-28 12:44:24.838	debug	States create User PubSub Client
        trashschedule.0
        7992	2022-05-28 12:44:24.836	debug	States create System PubSub Client
        vis.0
        3268	2022-05-28 12:44:24.778	info	starting. Version 1.4.15 in C:/iobroker/GLT/node_modules/iobroker.vis, node: v14.16.0, js-controller: 4.0.23
        trashschedule.0
        7992	2022-05-28 12:44:24.776	debug	Redis States: Use Redis connection: 127.0.0.1:9000
        trashschedule.0
        7992	2022-05-28 12:44:24.690	debug	Objects connected to redis: 127.0.0.1:9001
        trashschedule.0
        7992	2022-05-28 12:44:24.647	debug	Objects client initialize lua scripts
        trashschedule.0
        7992	2022-05-28 12:44:24.508	debug	Objects create User PubSub Client
        trashschedule.0
        7992	2022-05-28 12:44:24.507	debug	Objects create System PubSub Client
        trashschedule.0
        7992	2022-05-28 12:44:24.490	debug	Objects client ready ... initialize now
        trashschedule.0
        7992	2022-05-28 12:44:24.248	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
        Glasfaser haus-automatisierung 2 Replies Last reply Reply Quote 0
        • Glasfaser
          Glasfaser @JB_Sullivan last edited by Glasfaser
          @jb_sullivan sagte in Test Adapter TrashSchedule:
          in der 2.0.0
          EDIT:
          kannst du den Inhalt im Spoiler nicht in Code-Tags </> packen , kann man schlecht lesen / kopieren
          • Sa Gö
            Sa Gö last edited by
            Hallo!
            Ich habe seit kurzem das Problem, wenn ich die Instanz aufrufe, kommt folgende Meldung:
            "This adapter version has no support for "Admin 4" configuration. Please switch to "Admin 5" UI or downgrade to an older version (see changelog for details)."
            Von der Sache her sollte aber alles passen. Admin 5 habe ich "aktiviert", Node.js ist ist Version 14.19.2 und NPM ist 6.14.17.
            Hat jemand eine Idee was das Problem ist? In der VIS ist alles in Ordnung ich kann ihn nur nicht konfigurieren.
            Danke.
            Thomas Braun haus-automatisierung 2 Replies Last reply Reply Quote 0
              Thomas Braun Most Active @Sa Gö last edited by
              @sa-gö
              'Alte Oberfläche' aktiv?
              Sa Gö 1 Reply Last reply Reply Quote 0
              • haus-automatisierung
                haus-automatisierung Developer Most Active @Sa Gö last edited by
                @sa-gö Du hast aber in den Instanzeinstellungen vom Admin aktiviert, dass Du die alte Benutzeroberfläche nutzen möchtest. Die entwickle ich nicht mehr (wie viele andere Adapter auch).
                  haus-automatisierung Developer Most Active @JB_Sullivan last edited by
                  @jb_sullivan Irgendwie hast Du ein leeres Objekt ohne ID unter Restmüll. Das verursacht das Problem. Wie auch immer das da hingekommen ist. Man kann (auch als Adapter) keine Objekte anlegen, welche auf . enden
                  • Sa Gö
                    Sa Gö @Thomas Braun last edited by
                    @thomas-braun sagte in Test Adapter TrashSchedule:
                    @sa-gö
                    Danke, das wars. Gesehen habe ich den haken, aber natürlich nicht darüber nachgedacht das da mal was war. Habe ich doch glatt wieder vergessen umzustellen. Danke, auch @haus-automatisierung ! Schönes Wochenende.
                      haus-automatisierung Developer Most Active @SBorg last edited by
                      @sborg sagte in Test Adapter TrashSchedule:
                      Ich habe in meinen Adaptern das title-Attribut gelöscht (weil deprecated).
                      Ist also ein Bug im Info-Adapter, welcher dort titleLang anzeigen sollte.
                      • JB_Sullivan
                        Kann da unter Restmüll nichts finden, egal ob 2.0.0 oder 2.0.2. Ich selber habe da aber noch nie irgend wann, irgend etwas als leeren Typen angelegt.
                        Hier der Screenshot unter 2.0.2
                        Es gibt ein leeres Typ Objekt, was sich aber nicht löschen läßt, weder unter 2.0.0 noch unter 2.0.2. - ich weiß auch nicht seit wann diese "Leiche" schon vorhanden ist. Wie gesagt, läßt sich aber weder unter der einen noch unter der anderen Version löschen.
                          Ja, das meine ich ja. Das muss da schon länger "tot" liegen. Der Adapter probiert das ja auch die ganze Zeit zu löschen (darf es nur nicht, weil es mit . endet = Fehlermeldung). Lösch doch einfach mal den ganzen Channel types und hake dann an, dass alle Objekte darunter auch gelöscht werden sollen.
                          Dann verschwindet das hoffentlich und der Adapter legt dann alle anderen Objekte bei Neustart wieder an.
                          JB_Sullivan N 2 Replies Last reply Reply Quote 0
                          • JB_Sullivan
                            @haus-automatisierung sagte in Test Adapter TrashSchedule:
                            Wenn man den ganzen Objektbau auswählt, wird das leere Typ Objekt auch mit gelöscht. Einzeln innerhalb des Objektbaums ausgewählt, geht es nicht. Jetzt wo es weg ist, funktioniert auch die 2.0.2 ohne Fehler.
                            Vielen Dank für die Unterstützung.
                            • N
                              netHKB @haus-automatisierung last edited by
                              Bei mir war nach der Aktualisierung der gleiche Fehler aufgetaucht. Nach löschen von „Type“ und Neustart des Adapters läuft wieder alles einwandfrei.
                                seit heute habe ich ein Problem mit Trashschedule v1.4.5
                                ob es daran liegt, dass ich gestern updaten wollte, aber wegen controller 3.x nicht durfte, weiß ich nicht.
                                zuerst bekam ich jede Stunde
                                trashschedule.0 2022-06-16 14:00:05.002errorno events found in iCal instance - check configuration and restart adapter
                                trashschedule.0 2022-06-16 13:00:05.002errorno events found in iCal instance - check configuration and restart adapter
                                dann habe ich wie befohlen die Konfiguration geprüft, aber nichts gefunden.
                                jetzt bekomme ich zusätzlich
                                trashschedule.0 2022-06-16 14:37:12.807infoconfigurured iCal preview is 20 days - increase this value to find more events in the future
                                20 Tage ist vollkommen ausreichend!
                                mehr wunderte ich mich über
                                2022-06-16 14:37:12.808 info found configured iCal event "blau" without "display" flag. Activate the display flag on this entry if this is a "trash schedule" event.
                                wo um alles in der Welt finde ich den Display flag??
                                Edit:
                                hab's gefunden, aber das ist eine uralte Leiche als ich vor trashschedule mit events im ical experimentiert habe.
                                Habe nichts aktiv an ical oder trashschedule verändert
                                Edit2:
                                die DPs bei ical sind leer, muss da mal nach dem Grund suchen
                                  @homoran sagte in Test Adapter TrashSchedule:
                                  Ist die Quelle versiegt?
                                  AWB Köln? Holst du die irgendwo aus dem Netz? Hatte da nichts gescheites gefunden und hab mir eine ics-Datei mit den Terminen lokal abgelegt.
                                    jepp
                                      Wie kommst du an den ics-Link zur AWB? Ich hab da nix gefunden.
                                      Nur einen Konverter, der das aus deren Webseite ausliest und in eine lokale Datei haut. (Gut, hat den Vorteil, dass die Quelle nicht versickert... 🙂 )
                                        Homoran Global Moderator Administrators @Thomas Braun last edited by Homoran
                                        nach jahrelangen Versprechungen geht's Mittlerweile.
                                        vorher hatte ich ein tool von github, dass die online abfrage in ein ics wandelte und das lokal speicherte
                                        aber heute ist auch der Link zu der ics-Abfrage bei der AWB nicht da. Auf der Suche danach hab ich dann die Baustelle gefunden
                                          da hatten wir wohl beide das selbe Tool
                                          aber heute kommt ein leeres ics zurück. Wenn du so wie ich mit dem Tool beim Abruf das alte ics überschrieben hattes sind die Daten auch weg!
                                          • JB_Sullivan
                                            Moinsen zusammen - passt hier vielleicht nicht 100%ig rein, aber wie kann ich es bewerkstelligen, das der DP trashschedule.0.next.types nur EINEN Tag vor der Abholung in meiner VIS angezeigt wird (PopUp - Hinweis Feld)?
                                            Blockly? - Wenn ja wie? Vielen Dank für den Schubs in die entsprechende Richtung
                                            SBorg Chaot 2 Replies Last reply Reply Quote 0
                                            adapter calendar ical kalender müll trash
                                            184
                                            1432
                                            418032
