    4. Sonoff Zigbee Stick im Adapter nicht erkannt
    • V
      vqe17235 last edited by
      Ich habe die Firmware hier installiert:
      Z-Stack_3.x.0
      Der Stick wird jetzt so erkannt:
      pi@raspberrypi:~ $ ls -la /dev/serial/by-id
      insgesamt 0
      drwxr-xr-x 2 root root 60 17. Mai 16:12 .
      drwxr-xr-x 4 root root 80 17. Mai 16:12 ..
      lrwxrwxrwx 1 root root 13 17. Mai 16:12 usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_24523334e35fec1192ca385f25bfaa52-if00-port0 -> ../../ttyUSB0
      Und eingestellt ist der so:
      Das Log sagt folgendes:
      2022-05-17 16:20:35.935  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-05-17 16:20:38.402  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1960
      2022-05-17 16:20:40.790  - debug: zigbee.0 (1960) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2022-05-17 16:20:40.847  - debug: zigbee.0 (1960) Objects client ready ... initialize now
      2022-05-17 16:20:40.850  - debug: zigbee.0 (1960) Objects create System PubSub Client
      2022-05-17 16:20:40.852  - debug: zigbee.0 (1960) Objects create User PubSub Client
      2022-05-17 16:20:40.911  - debug: zigbee.0 (1960) Objects client initialize lua scripts
      2022-05-17 16:20:40.918  - debug: zigbee.0 (1960) Objects connected to redis: 127.0.0.1:9001
      2022-05-17 16:20:40.953  - debug: zigbee.0 (1960) Redis States: Use Redis connection: 127.0.0.1:9000
      2022-05-17 16:20:40.971  - debug: zigbee.0 (1960) States create System PubSub Client
      2022-05-17 16:20:40.972  - debug: zigbee.0 (1960) States create User PubSub Client
      2022-05-17 16:20:41.012  - debug: zigbee.0 (1960) States connected to redis: 127.0.0.1:9000
      2022-05-17 16:20:41.123  - debug: zigbee.0 (1960) Plugin sentry Initialize Plugin (enabled=true)
      2022-05-17 16:20:41.492  - info: zigbee.0 (1960) starting. Version 1.6.18 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.2, js-controller: 4.0.23
      2022-05-17 16:20:41.534  - debug: zigbee.0 (1960) Using zigbee-herdsman with settings: {"network":{"panID":6754,"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"extenedPanID":[88,242,222,188,90,137,132,21]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_24523334e35fec1192ca385f25bfaa52-if00-port0","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
      2022-05-17 16:20:41.591  - info: zigbee.0 (1960) Starting Zigbee  npm ...
      2022-05-17 16:20:41.592  - debug: zigbee.0 (1960) Starting zigbee-herdsman...
      2022-05-17 16:20:42.096  - debug: zigbee.0 (1960) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2022_05_17-16_20_41.tar.gz success
      2022-05-17 16:20:42.105  - info: zigbee.0 (1960) Installed Version: iobroker.zigbee@1.6.18
      2022-05-17 16:21:02.289  - error: zigbee.0 (1960) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
      2022-05-17 16:21:02.290  - error: zigbee.0 (1960) Failed to start Zigbee
      2022-05-17 16:21:02.290  - error: zigbee.0 (1960) Error herdsman start
      2022-05-17 16:21:12.293  - info: zigbee.0 (1960) Try to reconnect. 1 attempts left
      2022-05-17 16:21:12.295  - info: zigbee.0 (1960) Starting Zigbee  npm ...
      2022-05-17 16:21:12.296  - debug: zigbee.0 (1960) Starting zigbee-herdsman...
      2022-05-17 16:21:12.319  - info: zigbee.0 (1960) Installed Version: iobroker.zigbee@1.6.18
      2022-05-17 16:21:12.564  - error: zigbee.0 (1960) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
      2022-05-17 16:21:12.565  - error: zigbee.0 (1960) Failed to start Zigbee
      2022-05-17 16:21:12.566  - error: zigbee.0 (1960) Error herdsman start
      Das Flashen wurde mit einer erfolgreichen Meldung beendet. Kann man das sonst noch irgendwie kontrollieren?
      NWH 1 Reply Last reply Reply Quote 0
      • NWH
        NWH @vqe17235 last edited by
        @vqe17235 @Thomas-Braun
        Ich möchte den Sonoff auf meinem Nas Synology zum laufen bringen.
        IOB läuft im docker am Nas.
        Wenn ich das alles mache kommt bei mir immer die Fehlermeldung
        Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'"
        Was kann ich machen damit der Stick läuft.
        Mit dem Pfad betreibe ich einen Conbee USB2 Stick
        /dev/ttyACM0
        Da läuft es auf anhieb.
        Kann mir wer helfen das der Sonnoff auch läuft?
        Asgothian Thomas Braun 2 Replies Last reply Reply Quote 0
        • Asgothian
          Asgothian Developer @NWH last edited by
          @nwh sagte in Sonoff Zigbee Stick im Adapter nicht erkannt:
          Poste bitte mal alle Meldungen ab Startversuch des Adapters. Ich gehe davon aus das es weiter vorne noch weitere Meldungen gibt.
          A.
          NWH 2 Replies Last reply Reply Quote 0
            Thomas Braun Most Active @NWH last edited by
            Das dürfte der Wahrheit entsprechen. Die Sticks werden i. d. R. nach /dev/ttyUSB0 gehängt. Aur 'richtigen' Systemen kann man das mit
            ls -l /dev/serial/by-id
            sehen. Schaut bei mir so aus:
            [grothesk@manjaro ~]$ ls -l /dev/serial/by-id/
            insgesamt 0
            lrwxrwxrwx 1 root root 13 29. Apr 15:27 usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0 -> ../../ttyUSB0
            Aber auf dem synology/docker-Krempel funktioniert das wohl so nicht. Muss dir wer anders helfen.
            • NWH
              NWH @Asgothian last edited by
              @asgothian
              Bitte sehr
              zigbee.0
              2022-05-28 21:22:03.420	error	Error herdsman start
              zigbee.0
              2022-05-28 21:22:03.420	error	Failed to start Zigbee
              zigbee.0
              2022-05-28 21:22:03.419	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'"
              zigbee.0
              2022-05-28 21:21:53.414	error	Error herdsman start
              zigbee.0
              2022-05-28 21:21:53.414	error	Failed to start Zigbee
              zigbee.0
              2022-05-28 21:21:53.414	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'"
                @nwh
                Der Start des Adapters ist länger. Schaut so oder ähnlich aus:
                2022-05-28 21:25:35.780  - info: host.chet instance system.adapter.zigbee.0 started with pid 15887
                2022-05-28 21:25:39.429  - info: zigbee.0 (15887) starting. Version 1.7.1 (non-npm: ioBroker/ioBroker.zigbee#a68170f00c76dc216c66d64404c374dc768a02b1) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.2.0, js-controller: 4.0.23
                2022-05-28 21:25:39.494  - info: zigbee.0 (15887) internal Backups are disabled
                2022-05-28 21:25:39.500  - info: zigbee.0 (15887) Starting Zigbee  npm ...
                2022-05-28 21:25:40.050  - info: zigbee.0 (15887) Installed Version: ioBroker/ioBroker.zigbee#a68170f00c76dc216c66d64404c374dc768a02b1
                2022-05-28 21:25:51.022  - info: zigbee.0 (15887) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220507}}
                2022-05-28 21:25:51.035  - info: zigbee.0 (15887) Unable to disable LED, unsupported function.
                2022-05-28 21:25:51.059  - info: zigbee.0 (15887)   --> transmitPower : normal
                2022-05-28 21:25:51.070  - info: zigbee.0 (15887) Currently no devices.
                2022-05-28 21:25:51.072  - info: zigbee.0 (15887) Zigbee started
                • NWH
                  NWH @Thomas Braun last edited by
                  @thomas-braun Wo sehe ich das? Im Protokollfenster oder?
                    Thomas Braun Most Active @NWH last edited by Thomas Braun
                    @nwh
                    Ich schau dazu in einem Terminal direkt ins log.
                    iobroker logs --watch | uniq
                      @nwh
                      Ich weiß nicht ob das beim Docker auch funktioniert, aber mach ein weiteres Terminal auf und dann mit
                      dmesg -wT
                      schauen was passiert wenn der Stick ausgesteckt wird und nach einer Minute wieder eingestöpselt wird.
                      • NWH
                        Das geht nicht im Terminal vom docker bzw. kenne ich mich dabei zu wenig aus.
                        Aber das habe ich jetzt aus den Protokoll.
                        zigbee.0
                        2022-05-28 21:33:22.470	info	Installed Version: iobroker.zigbee@1.6.18
                        zigbee.0
                        2022-05-28 21:33:22.464	error	Error herdsman start
                        zigbee.0
                        2022-05-28 21:33:22.463	error	Failed to start Zigbee
                        zigbee.0
                        2022-05-28 21:33:22.463	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'"
                        zigbee.0
                        2022-05-28 21:33:22.462	debug	zigbee-herdsman:adapter:zStack:znp:log Opening SerialPort with /dev/ttyACM0 and {"baudRate":115200,"rtscts":false,"autoOpen":false}
                        zigbee.0
                        2022-05-28 21:33:22.462	debug	zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"panID":6748,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[15],"extenedPanID":[255,221,221,221,221,221,221,170]},"serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"zstack"},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","databaseBackupPath":null,"backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","adapter":{"disableLED":false,"forceStartWithInconsistentAdapterConfiguration":false},"acceptJoiningDeviceHandler":null}'
                        zigbee.0
                        2022-05-28 21:33:22.461	debug	zigbee-herdsman:adapter:zStack:znp:error Failed to determine if path is valid: 'Error: ENOENT: no such file or directory, lstat '/dev/ttyACM0''
                        zigbee.0
                        2022-05-28 21:33:22.460	debug	Starting zigbee-herdsman...
                        zigbee.0
                        2022-05-28 21:33:22.459	info	Starting Zigbee npm ...
                        zigbee.0
                        2022-05-28 21:33:22.459	info	Try to reconnect. 1 attempts left
                        • NWH
                          @asgothian Kann es sein, dass es daran liegt, dass ich mit der gleichen Instanz, allerdings habe ich den Stick gewechselt.
                          Andere Frage, ich habe jetzt alles gelöscht (Instanz und Objekte), aber wenn ich wieder eine "zigbee" Instanz installiere und wieder den Conbee2 nehme sind alle angelernten Geräte wieder da. Allerdings steht bei jedem Gerät undefined. Ich kann diese auch nicht umbenennen. Zuvor ging das !
                          Muss was in im Ordner "Iobroker_Data" gelöscht werden?
                          1593
