    4. Update/Installation von zigbee 1.7.0 schlägt fehl
      arteck Developer Most Active @rotamint last edited by
      hier
        Kueppert @arteck last edited by
        @arteck aahhh, okay 😉 Hab gerade direkt nochmal nen GIT-Update gestartet
          arteck Developer Most Active @Kueppert last edited by
          @kueppert der wird knallen ...müsstest nochmal den install anstossen .. Bitte
            rotamint @arteck last edited by
            @arteck Danke. Ich werd' gleich mal schauen.
            Nochmals neu installiert, läuft immernoch nicht:
            zigbee.0
            	2022-05-28 22:44:25.258	info	cleaned everything up...
            zigbee.0
            	2022-05-28 22:44:25.178	error	this.error is not a function
            zigbee.0
            	2022-05-28 22:44:25.178	error	TypeError: this.error is not a function at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:525:36) at WriteStream.emit (events.js:412:35) at WriteStream.emit (domain.js:475:12) at internal/fs/streams.js:335:14 at FSReqCallback.oncomplete (fs.js:180:23)
            zigbee.0
            	2022-05-28 22:44:25.177	error	uncaught exception: this.error is not a function
            zigbee.0
            	2022-05-28 22:44:25.004	info	deregister device Ping for deactivated device "0x00158d0006ba8545"
            host.ioBroker
            	2022-05-28 22:45:41.054	info	Restart adapter system.adapter.zigbee.0 because enabled
            host.ioBroker
            	2022-05-28 22:45:41.054	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            host.ioBroker
            	2022-05-28 22:45:41.053	error	Caught by controller[0]: at FSReqCallback.oncomplete (fs.js:180:23)
            host.ioBroker
            	2022-05-28 22:45:41.053	error	Caught by controller[0]: at internal/fs/streams.js:335:14
            host.ioBroker
            	2022-05-28 22:45:41.053	error	Caught by controller[0]: at WriteStream.emit (domain.js:475:12)
            host.ioBroker
            	2022-05-28 22:45:41.053	error	Caught by controller[0]: at WriteStream.emit (events.js:412:35)
            host.ioBroker
            	2022-05-28 22:45:41.053	error	Caught by controller[0]: at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:525:36)
            host.ioBroker
            	2022-05-28 22:45:41.052	error	Caught by controller[0]: TypeError: this.error is not a function
            host.ioBroker
            	2022-05-28 22:45:34.418	info	instance system.adapter.zigbee.0 started with pid 829296
            host.ioBroker
            	2022-05-28 22:45:04.281	info	Restart adapter system.adapter.zigbee.0 because enabled
              @rotamint jetzt erst..Bitte nochmal
                Kueppert @arteck last edited by Kueppert
                @arteck jup, knallt ^^
                zigbee.0 2022-05-28 22:46:58.698	warn	download icon from /opt/iobroker/node_modules/iobroker.zigbee/admin/img/929002294203.png
                zigbee.0 2022-05-28 22:46:58.683	warn	download icon from /opt/iobroker/node_modules/iobroker.zigbee/admin/img/929002294203.png
                zigbee.0 2022-05-28 22:46:58.662	warn	download icon from /opt/iobroker/node_modules/iobroker.zigbee/admin/img/404000/404005/404012/404019.png
                zigbee.0 2022-05-28 22:46:58.650	warn	download icon from /opt/iobroker/node_modules/iobroker.zigbee/admin/img/404000/404005/404012/404019.png
                aber hier der Auszug zu den Warnings. Ich starte nochmal nen GIT-Update ^^
                NACHTRAG: habe 1 Gerät (Aquara Door/Window-Sensor) ohne Icon. Nur nen Fragezeichen. Läuft aber trotzdem...der Sensor...Icon hatte ich da aber auch noch nie eines. Das nur als Hinweis. Ggf hats was mit dem Fehlen eines Icons zu tun?
                  @kueppert ja ich hab eine erweiterung gemacht damit icon angezeigt werden..
                  und das scheint nicht zu klappen bei dir
                    @arteck leider keine Änderung (für mich sichtbare):
                    host.ioBroker2
                    2022-05-28 22:54:13.556	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    host.ioBroker2
                    2022-05-28 22:54:13.556	error	Caught by controller[0]: at FSReqCallback.oncomplete (fs.js:179:23)
                    host.ioBroker2
                    2022-05-28 22:54:13.556	error	Caught by controller[0]: at /opt/iobroker/node_modules/graceful-fs/graceful-fs.js:258:16
                    host.ioBroker2
                    2022-05-28 22:54:13.556	error	Caught by controller[0]: at /opt/iobroker/node_modules/graceful-fs/graceful-fs.js:228:14
                    host.ioBroker2
                    2022-05-28 22:54:13.556	error	Caught by controller[0]: at WriteStream.emit (domain.js:475:12)
                    host.ioBroker2
                    2022-05-28 22:54:13.556	error	Caught by controller[0]: at WriteStream.emit (events.js:412:35)
                    host.ioBroker2
                    2022-05-28 22:54:13.556	error	Caught by controller[0]: at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:530:38)
                    host.ioBroker2
                    2022-05-28 22:54:13.555	error	Caught by controller[0]: TypeError: stream.read is not a function
                    host.ioBroker2
                    2022-05-28 22:54:13.555	error	Caught by controller[0]: at FSReqCallback.oncomplete (fs.js:179:23)
                    host.ioBroker2
                    2022-05-28 22:54:13.555	error	Caught by controller[0]: at /opt/iobroker/node_modules/graceful-fs/graceful-fs.js:258:16
                    host.ioBroker2
                    2022-05-28 22:54:13.555	error	Caught by controller[0]: at /opt/iobroker/node_modules/graceful-fs/graceful-fs.js:228:14
                    host.ioBroker2
                    2022-05-28 22:54:13.555	error	Caught by controller[0]: at WriteStream.emit (domain.js:475:12)
                    host.ioBroker2
                    2022-05-28 22:54:13.555	error	Caught by controller[0]: at WriteStream.emit (events.js:412:35)
                    host.ioBroker2
                    2022-05-28 22:54:13.554	error	Caught by controller[0]: at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:530:38)
                    host.ioBroker2
                    2022-05-28 22:54:13.554	error	Caught by controller[0]: TypeError: stream.read is not a function
                    zigbee.0
                    2022-05-28 22:54:13.152	info	Zigbee: disabling joining new devices.
                    zigbee.0
                    2022-05-28 22:54:13.044	info	cleaned everything up...
                    zigbee.0
                    2022-05-28 22:54:13.020	error	stream.read is not a function
                    zigbee.0
                    2022-05-28 22:54:13.019	error	TypeError: stream.read is not a function at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:530:38) at WriteStream.emit (events.js:412:35) at WriteStream.emit (domain.js:475:12) at /opt/iobroker/node_modules/graceful-fs/graceful-fs.js:228:14 at /opt/iobroker/node_modules/graceful-fs/graceful-fs.js:258:16 at FSReqCallback.oncomplete (fs.js:179:23)
                    zigbee.0
                    2022-05-28 22:54:13.018	error	uncaught exception: stream.read is not a function
                    zigbee.0
                    2022-05-28 22:54:13.012	error	stream.read is not a function
                    zigbee.0
                    2022-05-28 22:54:13.011	error	TypeError: stream.read is not a function at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:530:38) at WriteStream.emit (events.js:412:35) at WriteStream.emit (domain.js:475:12) at /opt/iobroker/node_modules/graceful-fs/graceful-fs.js:228:14 at /opt/iobroker/node_modules/graceful-fs/graceful-fs.js:258:16 at FSReqCallback.oncomplete (fs.js:179:23)
                    zigbee.0
                    2022-05-28 22:54:13.010	error	uncaught exception: stream.read is not a function
                    zigbee.0
                    2022-05-28 22:54:12.912	info	debug devices set to []
                    zigbee.0
                    2022-05-28 22:54:12.822	warn	download icon from https://www.zigbee2mqtt.io/images/devices/929002294203.jpg
                    zigbee.0
                    2022-05-28 22:54:12.808	warn	download icon from https://www.zigbee2mqtt.io/images/devices/929002294203.jpg
                    zigbee.0
                    2022-05-28 22:54:12.788	warn	download icon from https://www.zigbee2mqtt.io/images/devices/404000-404005-404012-404019.jpg
                    zigbee.0
                    2022-05-28 22:54:12.776	warn	download icon from https://www.zigbee2mqtt.io/images/devices/404000-404005-404012-404019.jpg
                    zigbee.0
                    2022-05-28 22:54:12.770	info	Zigbee started
                    arteck 2 Replies Last reply Reply Quote 0
                      @kueppert
                      ja warte
                        @kueppert kannst nochmal bitte ..von GIT
                          @arteck jup,lüpp das nächste Update. Wenns dann nicht klappt, muss ich leider abbrechen und erst mal auf die 1.6.x...die Frau mekkert 🙄
                          arteck R 2 Replies Last reply Reply Quote 0
                            @kueppert jo alles gut hast mir schon auch so geholfen.. ich warte noch die rückmeldung..
                              rotamint @Kueppert last edited by
                              @arteck Auch hier läd's gerade nochmal. Wir haben noch ein paar Versuche wenn Du magst. Bin geschieden 😉
                              arteck 1 Reply Last reply Reply Quote 1
                                @rotamint mal schauen was es gleich ergibt
                                K R 2 Replies Last reply Reply Quote 0
                                  @arteck 😞
                                  host.ioBroker2
                                  2022-05-28 23:11:11.646	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                  host.ioBroker2
                                  2022-05-28 23:11:11.645	error	Caught by controller[3]: at processImmediate (internal/timers.js:466:21)
                                  host.ioBroker2
                                  2022-05-28 23:11:11.645	error	Caught by controller[3]: at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:325:29)
                                  host.ioBroker2
                                  2022-05-28 23:11:11.645	error	Caught by controller[3]: at Array.forEach (<anonymous>)
                                  host.ioBroker2
                                  2022-05-28 23:11:11.644	error	Caught by controller[3]: at /opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:329:51
                                  host.ioBroker2
                                  2022-05-28 23:11:11.644	error	Caught by controller[3]: TypeError: Cannot read property 'deleteDeviceStates' of undefined
                                  host.ioBroker2
                                  2022-05-28 23:11:11.643	error	Caught by controller[2]: Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.zigbee/admin/img/404000/404005/404012/404019.png'
                                  host.ioBroker2
                                  2022-05-28 23:11:11.643	error	Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                  host.ioBroker2
                                  2022-05-28 23:11:11.642	error	Caught by controller[1]: Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.zigbee/admin/img/404000/404005/404012/404019.png'
                                  host.ioBroker2
                                  2022-05-28 23:11:11.635	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                  zigbee.0
                                  2022-05-28 23:11:11.433	error	Cannot read property 'deleteDeviceStates' of undefined
                                  zigbee.0
                                  2022-05-28 23:11:11.432	error	TypeError: Cannot read property 'deleteDeviceStates' of undefined at /opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:329:51 at Array.forEach (<anonymous>) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:325:29) at processImmediate (internal/timers.js:466:21)
                                  zigbee.0
                                  2022-05-28 23:11:11.430	error	uncaught exception: Cannot read property 'deleteDeviceStates' of undefined
                                  zigbee.0
                                  2022-05-28 23:11:11.313	info	Zigbee: disabling joining new devices.
                                  zigbee.0
                                  2022-05-28 23:11:11.220	info	cleaned everything up...
                                  zigbee.0
                                  2022-05-28 23:11:11.216	error	Exception-Code: ENOENT: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.zigbee/admin/img/404000/404005/404012/404019.png'
                                  zigbee.0
                                  2022-05-28 23:11:11.215	error	Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.zigbee/admin/img/404000/404005/404012/404019.png'
                                  zigbee.0
                                  2022-05-28 23:11:11.215	error	unhandled promise rejection: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.zigbee/admin/img/404000/404005/404012/404019.png'
                                  zigbee.0
                                  2022-05-28 23:11:11.214	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  zigbee.0
                                  2022-05-28 23:11:11.150	error	Exception-Code: ENOENT: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.zigbee/admin/img/404000/404005/404012/404019.png'
                                  zigbee.0
                                  2022-05-28 23:11:11.150	error	Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.zigbee/admin/img/404000/404005/404012/404019.png'
                                  zigbee.0
                                  2022-05-28 23:11:11.149	error	unhandled promise rejection: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.zigbee/admin/img/404000/404005/404012/404019.png'
                                  zigbee.0
                                  2022-05-28 23:11:11.148	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  zigbee.0
                                  2022-05-28 23:11:11.055	info	debug devices set to []
                                  zigbee.0
                                  2022-05-28 23:11:10.943	warn	download icon from https://www.zigbee2mqtt.io/images/devices/929002294203.jpg
                                  zigbee.0
                                  2022-05-28 23:11:10.927	warn	download icon from https://www.zigbee2mqtt.io/images/devices/929002294203.jpg
                                  zigbee.0
                                  2022-05-28 23:11:10.908	warn	download icon from https://www.zigbee2mqtt.io/images/devices/404000-404005-404012-404019.jpg
                                  zigbee.0
                                  2022-05-28 23:11:10.896	warn	download icon from https://www.zigbee2mqtt.io/images/devices/404000-404005-404012-404019.jpg
                                  zigbee.0
                                  2022-05-28 23:11:10.891	info	Zigbee started
                                  Bin jetzt auf 1.6.x und läuft erst mal wieder...gn8 und trotzdem vielen Dank für deinen Einsatz @arteck Vielleicht schafft ihr es heute Abend noch 😉
                                    @arteck
                                    zigbee.0
                                    	2022-05-28 23:11:37.522	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    zigbee.0
                                    	2022-05-28 23:11:37.520	info	terminating
                                    zigbee.0
                                    	2022-05-28 23:11:37.171	info	Zigbee: disabling joining new devices.
                                    zigbee.0
                                    	2022-05-28 23:11:36.996	info	cleaned everything up...
                                    zigbee.0
                                    	2022-05-28 23:11:36.813	error	Exception-Code: ENOENT: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.zigbee/admin/img/HG06335/HG07310.png'
                                    zigbee.0
                                    	2022-05-28 23:11:36.813	error	Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.zigbee/admin/img/HG06335/HG07310.png'
                                    zigbee.0
                                    	2022-05-28 23:11:36.812	error	unhandled promise rejection: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.zigbee/admin/img/HG06335/HG07310.png'
                                    zigbee.0
                                    	2022-05-28 23:11:36.811	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    zigbee.0
                                    	2022-05-28 23:11:36.481	info	deregister device Ping for deactivated device "0x00158d0006ba8545"
                                    zigbee.0
                                    	2022-05-28 23:11:36.481	info	deregister device Ping for deactivated device "0x00158d0006ba5980"
                                    zigbee.0
                                    	2022-05-28 23:11:36.481	info	deregister device Ping for deactivated device "0x00158d0006ba9a90"
                                    zigbee.0
                                    	2022-05-28 23:11:36.480	info	deregister device Ping for deactivated device "0x00158d0006baa96d"
                                    zigbee.0
                                    	2022-05-28 23:11:36.478	info	deregister device Ping for deactivated device "0x00158d0006ba7afb"
                                    zigbee.0
                                    	2022-05-28 23:11:36.456	info	debug devices set to []
                                    zigbee.0
                                    	2022-05-28 23:11:36.230	warn	download icon from https://www.zigbee2mqtt.io/images/devices/HG06335-HG07310.jpg
                                    zigbee.0
                                    	2022-05-28 23:11:36.226	warn	download icon from https://www.zigbee2mqtt.io/images/devices/FB20-002.jpg
                                    zigbee.0
                                    	2022-05-28 23:11:36.215	warn	download icon from https://www.zigbee2mqtt.io/images/devices/FB20-002.jpg
                                    zigbee.0
                                    	2022-05-28 23:11:36.203	info	Zigbee started
                                    zigbee.0
                                    	2022-05-28 23:11:36.202	info	0x04cf8cdf3c78a785 (addr 36469): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                    zigbee.0
                                    	2022-05-28 23:11:36.201	info	0x54ef4410000a2de9 (addr 53487): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                    zigbee.0
                                    	2022-05-28 23:11:36.199	info	0x54ef4410000a2d4e (addr 53026): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                    zigbee.0
                                    	2022-05-28 23:11:36.198	info	0x54ef4410000c18e4 (addr 45999): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                    zigbee.0
                                    	2022-05-28 23:11:36.196	info	0x00158d0006ba8545 (addr 5552): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                    zigbee.0
                                    	2022-05-28 23:11:36.194	info	0x00158d0006ba5980 (addr 18329): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                    zigbee.0
                                    	2022-05-28 23:11:36.192	info	0x00158d0006ba9a90 (addr 17783): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                    zigbee.0
                                    	2022-05-28 23:11:36.191	info	0x00158d0006baa96d (addr 64333): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                    zigbee.0
                                    	2022-05-28 23:11:36.189	info	0x00158d0006ba9a00 (addr 39815): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                    zigbee.0
                                    	2022-05-28 23:11:36.187	info	0x00158d0006ba7c33 (addr 24728): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                    zigbee.0
                                    	2022-05-28 23:11:36.185	info	0x04cf8cdf3c7d4b90 (addr 10759): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                    zigbee.0
                                    	2022-05-28 23:11:36.183	info	0x54ef4410001c4c66 (addr 60112): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                    zigbee.0
                                    	2022-05-28 23:11:36.181	info	0x842e14fffe3676b1 (addr 65488): TS0502A - TuYa Light controller (Router)
                                    zigbee.0
                                    	2022-05-28 23:11:36.179	info	0x54ef4410000a2946 (addr 27490): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                    zigbee.0
                                    	2022-05-28 23:11:36.177	info	0x680ae2fffead7a75 (addr 33928): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                                    zigbee.0
                                    	2022-05-28 23:11:36.170	info	0x00158d0006ba7afb (addr 13517): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                    zigbee.0
                                    	2022-05-28 23:11:36.168	info	0x00158d0006ba51c2 (addr 36534): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                    zigbee.0
                                    	2022-05-28 23:11:36.167	info	0x00158d0004a03e4c (addr 15394): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                    zigbee.0
                                    	2022-05-28 23:11:36.166	info	0x00158d00047d628b (addr 35609): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                    zigbee.0
                                    	2022-05-28 23:11:36.165	info	0x00158d00047d3bb5 (addr 40034): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                    zigbee.0
                                    	2022-05-28 23:11:36.163	info	0x00158d00049da7d0 (addr 43006): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                    zigbee.0
                                    	2022-05-28 23:11:36.162	info	0x04cf8cdf3c7d9620 (addr 58978): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                    zigbee.0
                                    	2022-05-28 23:11:36.160	info	0x842e14fffe37c623 (addr 34027): 14147206L - Lidl Livarno Lux ceiling light (Router)
                                    zigbee.0
                                    	2022-05-28 23:11:36.159	info	0x842e14fffe1d9e28 (addr 15593): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                    zigbee.0
                                    	2022-05-28 23:11:36.157	info	0x588e81fffee38ec2 (addr 56236): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                    zigbee.0
                                    	2022-05-28 23:11:36.156	info	0x588e81fffef771f4 (addr 57637): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                    zigbee.0
                                    	2022-05-28 23:11:36.145	info	0x842e14fffe15da08 (addr 33156): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                    zigbee.0
                                    	2022-05-28 23:11:36.143	info	0x842e14fffe23076c (addr 56959): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                    zigbee.0
                                    	2022-05-28 23:11:36.140	info	0x842e14fffe230848 (addr 50651): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                    zigbee.0
                                    	2022-05-28 23:11:36.138	info	0x588e81fffef77a2f (addr 49811): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                    zigbee.0
                                    	2022-05-28 23:11:36.136	info	0x842e14fffe1b9c91 (addr 38189): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                    zigbee.0
                                    	2022-05-28 23:11:36.134	info	0x588e81fffeff6340 (addr 41064): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                    zigbee.0
                                    	2022-05-28 23:11:36.132	info	0xec1bbdfffe91cdf4 (addr 18751): HG06335/HG07310 - Lidl Silvercrest smart motion sensor (EndDevice)
                                    zigbee.0
                                    	2022-05-28 23:11:36.131	info	0xbc33acfffe5ede11 (addr 15735): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                                    zigbee.0
                                    	2022-05-28 23:11:36.129	info	0xbc33acfffe6328d8 (addr 11726): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                                    zigbee.0
                                    	2022-05-28 23:11:36.128	info	0x588e81fffe655d96 (addr 9183): LED1903C5/LED1835C6 - IKEA TRADFRI bulb E12/E14/E17 WS 450/470/440 lumen, dimmable, white spectrum, opal white (Router)
                                    zigbee.0
                                    	2022-05-28 23:11:36.125	info	0x04cf8cdf3c7b5527 (addr 11619): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                    zigbee.0
                                    	2022-05-28 23:11:36.123	info	0x04cf8cdf3c7d4182 (addr 10828): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                    zigbee.0
                                    	2022-05-28 23:11:36.116	info	0x001788010410074e (addr 49249): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router)
                                    zigbee.0
                                    	2022-05-28 23:11:35.962	info	Currently 39 devices are joined:
                                    zigbee.0
                                    	2022-05-28 23:11:35.957	info	Unable to set transmit power, unsupported function.
                                    zigbee.0
                                    	2022-05-28 23:11:35.818	info	--> transmitPower : normal
                                    zigbee.0
                                    	2022-05-28 23:11:35.804	info	Unable to disable LED, unsupported function.
                                    zigbee.0
                                    	2022-05-28 23:11:35.778	info	Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":114,"maintrel":0,"revision":"0x26720700"}}
                                    zigbee.0
                                    	2022-05-28 23:11:35.741	info	Installed Version: ioBroker/ioBroker.zigbee#d76cd07656ac7ff74b85f2312c56e7b613874d0b
                                    zigbee.0
                                    	2022-05-28 23:11:35.223	info	Starting Zigbee npm ...
                                    zigbee.0
                                    	2022-05-28 23:11:35.220	info	delete old Backup files. keep only last 10
                                    zigbee.0
                                    	2022-05-28 23:11:35.113	info	starting. Version 1.7.1 (non-npm: ioBroker/ioBroker.zigbee#d76cd07656ac7ff74b85f2312c56e7b613874d0b) in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23
                                      ach das sind doppel icons. so ein scheiss..
                                        @rotamint
                                        kannst nochmal installieren von GIT ..bittää
                                          @arteck Läd...
                                            @rotamint mal schauen welche version der zieht
                                            evtl. musst du nochmal installieren
                                            81.1k
                                            159
                                            19287
