    2. English
    4. Adapter list empty
    Adapter list empty
      deejay808 last edited by
      I have installed the latest buanet-iobroker on synology docker after something went wrong trying to update jscontroller for an older version. I managed to re-install but the adapter list is empty.
      My repository points to http://download.iobroker.net/sources-dist.json
      This is in the log:
      2022-05-30 14:37:07.548 - info: backitup.0 (146) starting. Version 2.4.6 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.3, js-controller: 4.0.23
      2022-05-30 14:37:07.665 - info: backitup.0 (146) [iobroker] backup was activated at 02:40 every 1 day(s)
      2022-05-30 14:37:16.586 - info: admin.0 (116) failed connection to socket.io from ::ffff:192.168.111.104:
      2022-05-30 14:37:16.592 - error: admin.0 (116) Error: "error"
      I have seen some posts with the same errors in the log, but could not figure out how to solve that problem.
      Thanks in advance!
        deejay808 @deejay808 last edited by
        @deejay808 Ok, forget it; I noticed that the filter is by default on 'installed adapters'.
