    4. Test Adapter wireless-mbus v0.10.x
      lvogt @SegaPro last edited by
      @segapro
      Als erste Maßnahme wäre ein Debug Log nötig
        Thomas Braun Most Active @SegaPro last edited by
        @segapro sagte in Test Adapter wireless-mbus v0.7.x:
        Habe ich den falschen Stick? Die falsche Firmware? Kann ich die irgendwie aktualisieren?
        Oder eine andere/alte Version der usb-Geräte-ID-Tabelle. Die Namen sind unwichtig, es zählt die USB-Id.
          SegaPro last edited by SegaPro
          Hi zusammen,
          sorry - Debug, daran hätte ich denken müssen:
          @lvogt :
          wireless-mbus.0
          	2022-05-26 13:45:14.492	error	Timeout waiting for response
          wireless-mbus.0
          	2022-05-26 13:45:14.491	error	Error opening serial port /dev/ttyUSB1 with baudrate 57600
          wireless-mbus.0
          	2022-05-26 13:45:14.490	error	IMST: Failed to init device: Timeout waiting for response
          wireless-mbus.0
          	2022-05-26 13:45:11.527	debug	connected set to false
          wireless-mbus.0
          	2022-05-26 13:45:11.474	debug	IMST: TX: a5810306000300030800b8d6
          wireless-mbus.0
          	2022-05-26 13:45:11.470	debug	Created device of type: IMST iM871A
          wireless-mbus.0
          	2022-05-26 13:45:11.431	info	starting. Version 0.8.1 (non-npm: lvogt/ioBroker.wireless-mbus#a1e31007c89a6c0b60e468bd901a420b6f890b12) in /opt/iobroker/node_modules/iobroker.wireless-mbus, node: v14.19.3, js-controller: 4.0.23
          wireless-mbus.0
          	2022-05-26 13:45:07.265	error	Serialport error: Port is not open
          Ports:
          wireless-mbus.0
          	2022-05-26 13:44:25.380	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"FTDI","serialNumber":"D309V01Y","pnpId":"usb-FTDI_FT230X_Basic_UART_D309V01Y-if00-port0","vendorId":"0403","productId":"6015"},{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"__0X00124B0014D9E43B","pnpId":"usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014D9E43B-if00","vendorId":"0451","productId":"16a8"},{"path":"/dev/ttyUSB1","manufacturer":"Silicon Labs","serialNumber":"0001","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0001-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"}]
          Ich hoffe, dass es nicht am Stick liegt. 😞
          Viele Grüße
            @segapro
            Wie steht der Stick hier drin?
            ls -l /dev/serial/by-id
              @thomas-braun sagte in Test Adapter wireless-mbus v0.7.x:
              insgesamt 0
              lrwxrwxrwx 1 root root 13 23. Mai 10:18 usb-FTDI_FT230X_Basic_UART_D309V01Y-if00-port0 -> ../../ttyUSB0
              lrwxrwxrwx 1 root root 13 25. Mai 11:07 usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0001-if00-port0 -> ../../ttyUSB1
              lrwxrwxrwx 1 root root 13 23. Mai 10:18 usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014D9E43B-if00 -> ../../ttyACM0
                ratte-rizzo @ratte-rizzo last edited by
                Moin @lvogt und alle, die Verbindungsprobleme mit dem CUL haben, wenn er in eine VM o.ä. durchgereicht wird
                Bei mir ist es immer so, dass nach einem Neustart der CUL zwar sichtbar ist, der Adapter aber immer einen Timeout bekommt. Die Lösung scheint (!) bei mir recht einfach: Einmal den Fixer (iob fix) durchlaufen lassen.
                Vielleicht hilft es ja jemandem...
                Lieben Gruß
                Daniel
                • O
                  ok1 @lvogt last edited by
                  @lvogt sagte in Test Adapter wireless-mbus v0.7.x:
                  @ok1 Gibt es denn für den CUL eine Firmware die den C Mode unterstützt?
                  ja, die Firmware mit Mode C Unterstützung kann man sich aus den Quellen (culfw-code-r568-trunk-culfw) einfach selbst erstellen, in dem man im Verzeichnis CUL das include "board.h" anpasst:
                  //ok
                  #define HAS_MBUS        1
                  #define CUL_V3  1
                  und nicht benötigte Module wg. geringem Speicherplatz rauskommentiert, z.B.
                  #if defined(CUL_V3) || defined(CUL_V4)
                  #  define HAS_FHT_8v                    // PROGMEM:  586b  RAM: 23b
                  #  define HAS_FHT_TF
                  #  define FHTBUF_SIZE          174      //                 RAM: 174b
                  #  define RCV_BUCKETS            4      //                 RAM: 25b * bucket
                  #  define FULL_CC1100_PA                // PROGMEM:  108b
                  #  define HAS_RAWSEND                   //
                  //#  define HAS_ASKSIN                    // PROGMEM: 1314
                  //#  define HAS_ASKSIN_FUP                // PROGMEM:   78
                  //#  define HAS_MORITZ                    // PROGMEM: 1696
                  #  define HAS_ESA                       // PROGMEM:  286
                  #  define HAS_TX3                       // PROGMEM:  168
                  //#  define HAS_INTERTECHNO               // PROGMEM: 1352
                  #  define HAS_TCM97001                  // PROGMEM:  264
                  #  define HAS_UNIROLL                   // PROGMEM:   92
                  #  define HAS_MEMFN                     // PROGMEM:  168
                  //#  define HAS_SOMFY_RTS                 // PROGMEM: 1716
                  //#  define HAS_BELFOX                    // PROGMEM:  214
                  #endif
                  Nach Flashen der Firmware konnte der CUL-Stick Qundis qcaloric 5.5 Telegramme einwandfrei lesen. Geprüft mit wmbusmeters und FHEM-CUL-Modul.
                    lvogt @ok1 last edited by lvogt
                    @ok1
                    Hi, ich habe gerade v0.8.2 auf npm veröffentlicht die den C Mode für den CUL unterstützen sollte.
                    Unabhängig davon ob es (hoffentlich) funktioniert oder nicht, wäre es schön wenn du mir ein Debug Log vom Start und evtl 1 oder 2 empfangenen Telegrammen zukommen lassen könntest.
                      Danke für eure Antworten,
                      ein "iob fix" hat leider nicht geholfen. Hatte es direkt getestet. So recht weiß ich nun auch nicht mehr, wonach ich noch gucken könnte.
                      Wünsche euch einen schönen Start in die neue Woche.
                        @segapro
                        Was sagt denn
                        ls -l /dev/ttyUSB*
                        Die Benutzer und Gruppenzugehörigkeit bei den Symlinks ist ja keine verlässliche Aussage.
                          SegaPro @lvogt last edited by
                          ls -l /dev/ttyUSB*
                          Hi @lvogt ,
                          Danke, dass Du mich unterstützt.
                          ls -l /dev/ttyUSB*
                          crw-rw---- 1 root dialout 188, 0 27. Mai 15:33 /dev/ttyUSB0
                          crw-rw---- 1 root dialout 188, 1 30. Mai 11:30 /dev/ttyUSB1
                          Viele Grüße
                            @segapro
                            sudo -H -u iobroker groups
                            liefert? Der user muss in der Gruppe 'dialout' drin sein.
                              SegaPro @Thomas Braun last edited by
                              @lvogt
                              iobroker tty dialout
                                @segapro
                                Tja...
                                Evtl mal noch Baudraten durchprobieren. Und sonst mal mit irgendwelcher IMST Software versuchen das Ding zu testen?
                                • O
                                  ok1 @lvogt last edited by ok1
                                  @ok1
                                  vielen Dank für den schnellen Einbau des C-Modes !
                                  Gerne das debug-Log vom Start:
                                  wireless-mbus.1
                                  2022-05-30 23:44:28.281	debug	connected set to true
                                  wireless-mbus.1
                                  2022-05-30 23:44:28.221	debug	connected set to true
                                  wireless-mbus.1
                                  2022-05-30 23:44:28.206	info	CUL: Receiver set to C-MODE and data reporting with RSSI
                                  wireless-mbus.1
                                  2022-05-30 23:44:28.204	debug	CUL: RX: 434d4f44450d0a
                                  wireless-mbus.1
                                  2022-05-30 23:44:28.194	debug	CUL: TX: 5832310d0a6272630d0a
                                  wireless-mbus.1
                                  2022-05-30 23:44:28.193	info	CUL: Version: V 1.67 CUL868
                                  wireless-mbus.1
                                  2022-05-30 23:44:28.190	debug	CUL: RX: 5620312e36372043554c3836380d0a
                                  wireless-mbus.1
                                  2022-05-30 23:44:28.173	debug	CUL: TX: 560d0a
                                  wireless-mbus.1
                                  2022-05-30 23:44:28.163	debug	Created device of type: CUL
                                  wireless-mbus.1
                                  2022-05-30 23:44:27.988	info	starting. Version 0.8.2 in /opt/iobroker/node_modules/iobroker.wireless-mbus, node: v12.18.4, js-controller: 4.0.23
                                  wireless-mbus.1
                                  2022-05-30 23:44:18.940	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  wireless-mbus.1
                                  2022-05-30 23:44:18.936	info	terminating
                                  wireless-mbus.1
                                  2022-05-30 23:44:18.928	info	Got terminate signal TERMINATE_YOURSELF
                                  wireless-mbus.1
                                  2022-05-30 23:42:44.129	info	List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyACM0","manufacturer":"busware.de","pnpId":"usb-busware.de_CUL868-if00","vendorId":"03eb","productId":"204b"}]
                                  wireless-mbus.1
                                  2022-05-30 23:42:27.170	info	CUL: Receiver set to C-MODE and data reporting with RSSI
                                  wireless-mbus.1
                                  2022-05-30 23:42:27.110	info	CUL: Version: V 1.67 CUL868
                                  wireless-mbus.1
                                  2022-05-30 23:42:26.921	info	starting. Version 0.8.2 in /opt/iobroker/node_modules/iobroker.wireless-mbus, node: v12.18.4, js-controller: 4.0.23
                                  und das erste Telegramm:
                                  wireless-mbus.1
                                  2022-05-30 23:48:43.943	debug	Value QDS-29435752.data.7-0-VIF_TIME_POINT_DATE_TIME: 2022-05-30 22:48
                                  wireless-mbus.1
                                  2022-05-30 23:48:43.921	debug	Value QDS-29435752.data.6-0-VIF_TIME_POINT_DATE: 2022-05-18
                                  wireless-mbus.1
                                  2022-05-30 23:48:43.897	debug	Value QDS-29435752.data.5-17-VIF_TIME_POINT_DATE: 2022-04-30
                                  wireless-mbus.1
                                  2022-05-30 23:48:43.873	debug	Value QDS-29435752.data.4-17-VIF_HCA: 0
                                  wireless-mbus.1
                                  2022-05-30 23:48:43.846	debug	Value QDS-29435752.data.3-1-VIF_TIME_POINT_DATE: 2021-12-31
                                  wireless-mbus.1
                                  2022-05-30 23:48:43.822	debug	Value QDS-29435752.data.2-1-VIF_HCA: 0
                                  wireless-mbus.1
                                  2022-05-30 23:48:43.802	debug	Value QDS-29435752.data.1-0-VIF_HCA: 5
                                  wireless-mbus.1
                                  2022-05-30 23:48:43.543	debug	Updating device: QDS-29435752
                                  wireless-mbus.1
                                  2022-05-30 23:48:43.076	debug	Creating device: QDS-29435752
                                  wireless-mbus.1
                                  2022-05-30 23:48:43.072	debug	VIF_TIME_POINT_DATE_TIME: Value raw 635311664 value calc 2022-05-30 22:48
                                  wireless-mbus.1
                                  2022-05-30 23:48:43.070	debug	DIB dataField 4
                                  wireless-mbus.1
                                  2022-05-30 23:48:43.068	debug	VIF_TIME_POINT_DATE: Value raw 9682 value calc 2022-05-18
                                  wireless-mbus.1
                                  2022-05-30 23:48:43.067	debug	DIB dataField 2
                                  wireless-mbus.1
                                  2022-05-30 23:48:43.066	debug	VIF_TIME_POINT_DATE: Value raw 9438 value calc 2022-04-30
                                  wireless-mbus.1
                                  2022-05-30 23:48:43.064	debug	DIB dataField 2
                                  wireless-mbus.1
                                  2022-05-30 23:48:43.063	debug	VIF_HCA: Value 0
                                  wireless-mbus.1
                                  2022-05-30 23:48:43.062	debug	DIB dataField 11
                                  wireless-mbus.1
                                  2022-05-30 23:48:43.059	debug	VIF_TIME_POINT_DATE: Value raw 11455 value calc 2021-12-31
                                  wireless-mbus.1
                                  2022-05-30 23:48:43.057	debug	DIB dataField 2
                                  wireless-mbus.1
                                  2022-05-30 23:48:43.054	debug	VIF_HCA: Value 0
                                  wireless-mbus.1
                                  2022-05-30 23:48:43.053	debug	DIB dataField 11
                                  wireless-mbus.1
                                  2022-05-30 23:48:43.051	debug	VIF_HCA: Value 5
                                  wireless-mbus.1
                                  2022-05-30 23:48:43.049	debug	DIB dataField 11
                                  wireless-mbus.1
                                  2022-05-30 23:48:43.038	debug	Short header
                                  wireless-mbus.1
                                  2022-05-30 23:48:43.027	debug	3144934452574329350830a97a641800200b6e0500004b6e00000042e03e6cbf2ccb086e000000c2086cde24326c1c3ed225046d3016de25803580
                                  wireless-mbus.1
                                  2022-05-30 23:48:43.019	debug	CUL: Message received: 3144934452574329350830a97a641800200b6e0500004b6e00000042e03e6cbf2ccb086e000000c2086cde24326c1c3ed225046d3016de258035803b
                                  wireless-mbus.1
                                  2022-05-30 23:48:43.014	debug	CUL: RX: 623331343439333434353235373433323933353038333041393741363431383030323030423645303530303030344236453030303030303432453033453643424632434342303836453030303030304332303836434445323433323643314333454432323530343644333031364445323538303335383033420d0a
                                  die beiden wichtigsten Nutzdaten "aktueller Wert HKV"
                                  und Vorjahreswert
                                  werden korrekt erkannt.
                                  Und das 2. Telegramm:
                                  wireless-mbus.1
                                  2022-05-30 23:56:05.325	debug	Value QDS-29435752.data.7-0-VIF_TIME_POINT_DATE_TIME: 2022-05-30 22:55
                                  wireless-mbus.1
                                  2022-05-30 23:56:05.287	debug	Value QDS-29435752.data.6-0-VIF_TIME_POINT_DATE: 2022-05-18
                                  wireless-mbus.1
                                  2022-05-30 23:56:05.238	debug	Value QDS-29435752.data.5-17-VIF_TIME_POINT_DATE: 2022-04-30
                                  wireless-mbus.1
                                  2022-05-30 23:56:05.199	debug	Value QDS-29435752.data.4-17-VIF_HCA: 0
                                  wireless-mbus.1
                                  2022-05-30 23:56:05.163	debug	Value QDS-29435752.data.3-1-VIF_TIME_POINT_DATE: 2021-12-31
                                  wireless-mbus.1
                                  2022-05-30 23:56:05.129	debug	Value QDS-29435752.data.2-1-VIF_HCA: 0
                                  wireless-mbus.1
                                  2022-05-30 23:56:05.092	debug	Value QDS-29435752.data.1-0-VIF_HCA: 5
                                  wireless-mbus.1
                                  2022-05-30 23:56:05.000	debug	Updating device: QDS-29435752
                                  wireless-mbus.1
                                  2022-05-30 23:56:04.998	debug	VIF_TIME_POINT_DATE_TIME: Value raw 635311671 value calc 2022-05-30 22:55
                                  wireless-mbus.1
                                  2022-05-30 23:56:04.997	debug	DIB dataField 4
                                  wireless-mbus.1
                                  2022-05-30 23:56:04.996	debug	VIF_TIME_POINT_DATE: Value raw 9682 value calc 2022-05-18
                                  wireless-mbus.1
                                  2022-05-30 23:56:04.995	debug	DIB dataField 2
                                  wireless-mbus.1
                                  2022-05-30 23:56:04.993	debug	VIF_TIME_POINT_DATE: Value raw 9438 value calc 2022-04-30
                                  wireless-mbus.1
                                  2022-05-30 23:56:04.992	debug	DIB dataField 2
                                  wireless-mbus.1
                                  2022-05-30 23:56:04.991	debug	VIF_HCA: Value 0
                                  wireless-mbus.1
                                  2022-05-30 23:56:04.990	debug	DIB dataField 11
                                  wireless-mbus.1
                                  2022-05-30 23:56:04.989	debug	VIF_TIME_POINT_DATE: Value raw 11455 value calc 2021-12-31
                                  wireless-mbus.1
                                  2022-05-30 23:56:04.987	debug	DIB dataField 2
                                  wireless-mbus.1
                                  2022-05-30 23:56:04.986	debug	VIF_HCA: Value 0
                                  wireless-mbus.1
                                  2022-05-30 23:56:04.985	debug	DIB dataField 11
                                  wireless-mbus.1
                                  2022-05-30 23:56:04.984	debug	VIF_HCA: Value 5
                                  wireless-mbus.1
                                  2022-05-30 23:56:04.982	debug	DIB dataField 11
                                  wireless-mbus.1
                                  2022-05-30 23:56:04.981	debug	Short header
                                  wireless-mbus.1
                                  2022-05-30 23:56:04.978	debug	3144934452574329350830a97a651800200b6e0500004b6e00000042fec66cbf2ccb086e000000c2086cde24326c1c3ed225046d3716de2521a580
                                  wireless-mbus.1
                                  2022-05-30 23:56:04.977	debug	CUL: Message received: 3144934452574329350830a97a651800200b6e0500004b6e00000042fec66cbf2ccb086e000000c2086cde24326c1c3ed225046d3716de2521a5803b
                                  wireless-mbus.1
                                  2022-05-30 23:56:04.975	debug	CUL: RX: 623331343439333434353235373433323933353038333041393741363531383030323030423645303530303030344236453030303030303432464543363643424632434342303836453030303030304332303836434445323433323643314333454432323530343644333731364445323532314135383033420d0a
                                  Eine Besonderheit der Qundis HKV ist der Versand von Zwischen-Telegrammen mit Qundis-internen Daten.
                                  Beim FHEM Adapter hat man das über ein zusätzliches Attribut "ignoreUnknownDataBlocks" gelöst. Ist das Attribut gesetzt werden die internen Telegramme verworfen und nicht in den Datenpunkt geschrieben. In diesem kurzen Test habe ich noch kein derartiges Telegramm gefangen, lasse den Adapter weiterlaufen und füge es hier umgehend an wenn eins vorliegt.
                                  EDIT 31.05.
                                  Erste interne Telegramme liegen vor. Nachfolgend ein Beispiel:
                                  wireless-mbus.1
                                  2022-05-31 16:29:41.748	debug	Value QDS-29435752.data.2-0-VIF_TIME_POINT_DATE_TIME: 2022-05-31 15:29
                                  wireless-mbus.1
                                  2022-05-31 16:29:41.711	debug	Value QDS-29435752.data.1-0-VIF_TYPE_MANUFACTURER_UNKOWN: /$^,?%Rn0j
                                  wireless-mbus.1
                                  2022-05-31 16:29:41.673	debug	Updating device: QDS-29435752
                                  wireless-mbus.1
                                  2022-05-31 16:29:41.672	debug	VIF_TIME_POINT_DATE_TIME: Value raw 635375389 value calc 2022-05-31 15:29
                                  wireless-mbus.1
                                  2022-05-31 16:29:41.672	debug	DIB dataField 4
                                  wireless-mbus.1
                                  2022-05-31 16:29:41.671	debug	VIF_TYPE_MANUFACTURER_UNKOWN: Value "/\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000$^\u0000\u0000\u0000\u0000,?\u0000\u0000\u0000\u0006%Rn0\u0007\u0000\u0000\u0000\u0018j\u0002\u0000"
                                  wireless-mbus.1
                                  2022-05-31 16:29:41.671	debug	DIB dataField 13
                                  wireless-mbus.1
                                  2022-05-31 16:29:41.670	debug	Unknown manufacturer specific vif: 0x5f
                                  wireless-mbus.1
                                  2022-05-31 16:29:41.669	debug	No header
                                  wireless-mbus.1
                                  2022-05-31 16:29:41.668	debug	494493445257432935085243780dff5f350082ea1800800007b06ed2bbe12506000000bf2c00000000de240000005eb7000080008000800080008000800080009b248000000000000000002f046d1d0fdf25620780
                                  wireless-mbus.1
                                  2022-05-31 16:29:41.667	debug	CUL: Message received: 494493445257432935085243780dff5f350082ea1800800007b06ed2bbe12506000000bf2c00000000de240000005eb7000080008000800080008000800080009b248000000000000000002f046d1d0fdf256207803a
                                  wireless-mbus.1
                                  2022-05-31 16:29:41.666	debug	CUL: RX: 62343934343933343435323537343332393335303835323433373830444646354633353030383245413138303038303030303742303645443242424531323530363030303030304246324330303030303030304445323430303030303035454237303030303830303038303030383030303830303038303030383030303830303039423234383030303030303030303030303030303030324630343644314430464446323536323037383033410d0a
                                  In welche Datenpunkte werden die Werte vom Adapter eingetragen ?
                                  Unter wireless-mbus.1 sind sie noch nicht vorhanden:
                                  EDIT 31.05.
                                  Die Datenpunkte sind jetzt auch da:
                                  • O
                                    ok1 @ok1 last edited by
                                    @ok1 sagte in Test Adapter wireless-mbus v0.7.x:
                                    EDIT 31.05.
                                    es gibt noch einen Fehler in der Datumsangabe. Monat ist ums "1" erhöht
                                      @ok1
                                      Danke für die Logs.
                                      Erstmal eine Warnung vorweg: Wenn ein Gerät unterschiedliche Telegramme sendet kann der Adapter damit nicht besonders gut umgehen. Bei dir sieht es so als wäre es (zur Zeit) ok.
                                      Zu deinem interessanten Datum: Ich kann nicht nachvollziehen woher das kommt. Die passende Stelle im Code des Telegramm Parsers prüft explizit auf Monate > 12. Außerdem formatiert der Parser ein Datum eigentlich immer als YYYY-MM-DD - dein State zeigt YYYY.MM.DD (was ich sowieso schon für merkwürdig halte). Und zum Schluss: Im Log sieht man zb
                                      Das wird mehr oder weniger direkt bevor der State gesetzt wird ins Log geschrieben - und hier ist es noch eine 12.
                                      Da muss mMn irgendeine weitere Komponente seine Finger im Spiel haben. Sei es ioBroker oder Admin selbst, oder ein anderer Adapter oder Skript.
                                      • O
                                        "Admin" war der richtige Hinweis ! Hier wird aus dem korrekten Wert "12" im Datenpunktbaum eine "13":
                                        Aktuelle Admin-Version v5.3.8.
                                          gizmodlx last edited by gizmodlx
                                          Hi zusammen! Funzt der Adapter in Version 0.8.2 auch unter nodeJS 16 einwandfrei? Hat das jemand schon geprüft bzw. am laufen?
                                            @gizmodlx
                                            Nicht dass ich es wirklich ausprobiert hätte, aber die Tests laufen mit node 12/14/16/18:
                                            https://github.com/lvogt/ioBroker.wireless-mbus/actions/runs/2430796316
                                            mbus wireless wm-bus wmbus
                                            63
                                            563
                                            165821
