    4. (Gelöst) Adapter Inst/De-Inst/Update hängt
      Smokey @Thomas Braun last edited by Smokey
      @thomas-braun sagte in Adapter Inst/De-Inst/Update hängt:
      uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      so schaut das aus:
      aarch64
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v12.22.12
      v12.22.12
      6.14.16
      root
      /opt/iobroker
      Hit:1 http://security.debian.org bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 http://deb.debian.org/debian bullseye-backports InRelease
      Hit:6 https://packages.grafana.com/enterprise/deb stable InRelease
      Hit:7 https://packages.grafana.com/enterprise/deb beta InRelease
      Hit:8 https://repos.influxdata.com/debian bullseye InRelease
      Hit:5 https://ryanfortner.github.io/box64-debs/debian ./ InRelease
      Hit:10 https://deb.nodesource.com/node_12.x bullseye InRelease
      Hit:11 https://dl.yarnpkg.com/debian stable InRelease
      Hit:12 http://deb.volian.org/volian scar InRelease
      Hit:9 https://armbian.site-meganet.com/apt bullseye InRelease
      Reading package lists... Done
      Building dependency tree... Done
      All packages are up to date.
      nodejs:
        Installed: 12.22.12-deb-1nodesource1
        Candidate: 12.22.12-deb-1nodesource1
        Version table:
       *** 12.22.12-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_12.x bullseye/main arm64 Packages
              100 /var/lib/dpkg/status
           12.22.5~dfsg-2~11u1 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
              500 http://security.debian.org bullseye-security/main arm64 Packages
      Thomas Braun S 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Smokey last edited by
        @smokey
        Die alter Leier: NICHT als root rumkaspern.
        Und installier SAUBER nodeJS@14.
          Smokey @Smokey last edited by
          @smokey
          @smokey
          erstmal Danke ich Dir für Deine Hilfe. Ich glaub nicht, dass ich "rumkaspere", aber ich hab schon verstanden dass das nicht ideal ist. Dennoch: was hast Du denn nun aus den Ausgaben gelesen? Ich würde ja gerne auch lernen an sowas. Ich habe jetzt nodeJS@14 installiert (nach der Anleitung in Deiner Signatur; also hoffentlich sauber).
          Leider hat sich dadurch am Problem bisher nichts geändert.
          Thomas Braun 3 Replies Last reply Reply Quote 0
          • haus-automatisierung
            haus-automatisierung Developer Most Active last edited by
            Auf Facebook haben auch mehrere Nutzer das Problem.
            NodeJS 14, npm 6, aktuellster js-controller und kein Update läuft durch.
            Mit den gleichen Versionen funktioniert bei mir alles.
              @smokey sagte in Adapter Inst/De-Inst/Update hängt:
              Wie schaut das denn nun aus?
              cd /opt/iobroker
              npm ls| grep ERR
              Zu root sag ich nichts weiter. Aber grundsätzlich loggt man sich nie, gar nicht, unter keinen Umständen als root ein. Schon mal gerade gar nicht auf einem System mit Desktop-Umgebung.
                Ich lese da so einiges raus.
                npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
                Sagt mir z. B., dass da höchstwahrscheinlich mal ein npm>6 installiert war. Das kommt nämlich mit einem neuen Format daher.
                Dann sehe ich da einige 'komische' Repos angelegt. Das würde ich auch verschlanken.
                Zum root login habe ich ja schon was gesagt.
                  Dann spring noch eins höher auf nodeJS@16.
                  Das bringt dann ein npm@8 mit, das kann dann mit dem geänderten Format des lockfiles wieder was anfangen. Vielleicht zieht sich das dann gerade.
                    Danke Dir. Hab ich gemacht nach Deiner Anleitung. Und es sieht so aus, dass alles funktioniert.
                    npm ls| grep ERR
                    meldet jetzt auch nichts mehr zurück.
                    Beim Durchlaufen Deiner Anleitung ist mir allerdings aufgefallen, dass:
                    sudo ln -s /usr/bin/node /usr/bin/nodejs
                    bei mir folgende Meldung bringt:
                    ln: failed to create symbolic link '/usr/bin/nodejs': File exists
                    Ich kann jetzt zwar keinen direkten negativen Impact sehen, aber vielleicht hast Du auch dafür eine Idee.
                    Jedenfalls vielen Dank. Ob ich vorher jemals eine npm >6 hatte kann ich nicht sagen. Wüsste eigentlich auch nicht woher die kommen sollte. Habe das System vor 2 Wochen mit der nodejs14 aufgesetzt und die bringt ja eigentlich die npm6 mit dachte ich.
                    Thomas Braun crunchip 3 Replies Last reply Reply Quote 0
                      Dann ist das schon mal verlinkt worden. Nicht weiter wild. Steht auch nur deswegen drin, damit der Link auf jedenfall vorhanden ist und die lange Befehlskette dann auch durchläuft.
                        crunchip Forum Testing Most Active @Smokey last edited by
                        Passt aber nicht zu
                        https://forum.iobroker.net/post/808085
                          @smokey
                          schaut nun wie aus?
                            @smokey
                            schaut nun wie aus?
                            schaut so aus:
                            aarch64
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v16.15.0
                            v16.15.0
                            8.5.5
                            iobroker
                            Hit:1 http://deb.debian.org/debian bullseye InRelease
                            Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                            Hit:3 http://deb.debian.org/debian bullseye-backports InRelease
                            Hit:4 http://security.debian.org bullseye-security InRelease
                            Hit:9 https://deb.nodesource.com/node_14.x bullseye InRelease
                            Hit:10 https://dl.yarnpkg.com/debian stable InRelease
                            Hit:12 https://deb.nodesource.com/node_16.x bullseye InRelease
                            Hit:13 http://deb.volian.org/volian scar InRelease
                            Hit:11 http://mirrors.xtom.de/armbian bullseye InRelease
                            nodejs:
                              Installed: 16.15.0-deb-1nodesource1
                              Candidate: 16.15.0-deb-1nodesource1
                              Version table:
                             *** 16.15.0-deb-1nodesource1 500
                                    500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                                 14.19.3-deb-1nodesource1 500
                                    500 https://deb.nodesource.com/node_14.x bullseye/main arm64 Packages
                            iobroker@orangepiplus:/$
                              Smokey @crunchip last edited by Smokey
                              @crunchip sagte in Adapter Inst/De-Inst/Update hängt:
                              Passt aber nicht zu
                              ja, korrekt. Ich bin dann irgendwann im Rahmen der Fehlersuche (irgendeinen Artikel gelesen) zurück auf die 12 gegangen. Wahrscheinlich alles noch schlimmer gemacht dadurch.
                                @smokey wahrscheinlich
                                Was auch noch ausffählt, bzw die Frage
                                War grafana enterprise und nicht die oss
                                  da hab ich nicht weiter drüber nachgedacht. Ist das ein Problem? Ich dachte der einzige Unterschied wäre, dass man bei Enterprise über weitere Subscribtions Funktionen dazukaufen kann - wenn man will und braucht.
                                  1075
