      rotamint @simatec last edited by rotamint
      @simatec
      shuttercontrol.0
      	2022-06-01 16:36:01.722	debug	WZ Rolladenaktor Panoramafenster.LEVEL Old value = 100. New value = 100. automatic is active
      shuttercontrol.0
      	2022-06-01 16:36:01.578	debug	Shutter WZ Rolladenaktor Panoramafenster.LEVEL was moved manually to: 100% - prevent trigger from driving back
      shuttercontrol.0
      	2022-06-01 16:36:01.578	debug	save current height after State Check: 100% from WZ Rolladenaktor Panoramafenster.LEVEL
      shuttercontrol.0
      	2022-06-01 16:35:56.306	debug	insidetemperature changed: zigbee.0.54ef4410000c18e4.illuminance Value: 146
      shuttercontrol.0
      	2022-06-01 16:35:46.855	debug	insidetemperature changed: zigbee.0.54ef4410000c18e4.illuminance Value: 143
      shuttercontrol.0
      	2022-06-01 16:35:41.364	debug	insidetemperature changed: zigbee.0.54ef4410000c18e4.illuminance Value: 119
      shuttercontrol.0
      	2022-06-01 16:35:38.362	debug	Brightness State Down is: false
      shuttercontrol.0
      	2022-06-01 16:35:35.241	debug	WZ Rolladenaktor Panoramafenster.LEVEL Old value = 100. New value = 36. automatic is active
      shuttercontrol.0
      	2022-06-01 16:35:35.240	debug	Shutter state changed: WZ Rolladenaktor Panoramafenster.LEVEL old value = 100 new value = 36
      shuttercontrol.0
      	2022-06-01 16:35:35.130	debug	Shutter WZ Rolladenaktor Panoramafenster.LEVEL was moved manually to: 36% - prevent trigger from driving back
      shuttercontrol.0
      	2022-06-01 16:35:35.129	debug	save current height after State Check: 36% from WZ Rolladenaktor Panoramafenster.LEVEL
      shuttercontrol.0
      	2022-06-01 16:35:35.082	debug	WZ Rolladenaktor Panoramafenster.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
      shuttercontrol.0
      	2022-06-01 16:35:35.081	debug	WZ Rolladenaktor Panoramafenster.LEVEL drived manually to 36. Old value = 100. New value = 36
      shuttercontrol.0
      	2022-06-01 16:35:35.071	debug	Shutter state changed: WZ Rolladenaktor Panoramafenster.LEVEL old value = 100 new value = 36
      shuttercontrol.0
      	2022-06-01 16:35:28.574	debug	Sunprotect WZ Rolladenaktor Panoramafenster.LEVEL old height: 100% new height: 100%
      shuttercontrol.0
      	2022-06-01 16:35:28.573	debug	Sunprotect for WZ Rolladenaktor Panoramafenster.LEVEL is not active
      shuttercontrol.0
      	2022-06-01 16:35:28.572	debug	last automatic Action for WZ Rolladenaktor Panoramafenster.LEVEL: up_Sunprotect_end
      shuttercontrol.0
      	2022-06-01 16:35:28.485	info	Sunprotect #421 Set ID: WZ Rolladenaktor Panoramafenster.LEVEL value: 100%
      shuttercontrol.0
      	2022-06-01 16:35:28.361	debug	Brightness sensor value: 2771
      shuttercontrol.0
      	2022-06-01 16:35:26.475	debug	insidetemperature changed: zigbee.0.54ef4410000c18e4.illuminance Value: 80
      shuttercontrol.0
      	2022-06-01 16:35:11.571	debug	insidetemperature changed: zigbee.0.54ef4410000c18e4.illuminance Value: 93
      shuttercontrol.0
      	2022-06-01 16:35:02.078	debug	Sunprotect WZ Rolladenaktor Panoramafenster.LEVEL old height: 100% new height: 36%
      shuttercontrol.0
      	2022-06-01 16:35:02.077	debug	last automatic Action for WZ Rolladenaktor Panoramafenster.LEVEL: down_Sunprotect
      shuttercontrol.0
      	2022-06-01 16:35:02.076	debug	Sunprotect for WZ Rolladenaktor Panoramafenster.LEVEL is active
      shuttercontrol.0
      	2022-06-01 16:35:02.041	info	Sunprotect #420 Set ID: WZ Rolladenaktor Panoramafenster.LEVEL value: 36%
      Sicher dass der Aktor der Verursacher ist, und nicht die Tatsache, dass der Luxsensor die Beschattung aufheben will, bevor der korrekte State gesetzt wurde? Das ist doch meine Vermutung mit der das ganze Drama begonnen hat: Es wird eine Statusänderung angefordert, bevor der aktuell laufende Vorgang abschließend zu Ende gebracht wurde?
      zigbee.0.54ef4410000c18e4.illuminance stellt hier die Werte zur Besonnung (100 testweise) zur Verfügung. Verzögerung (hier 10 Minuten) funktioniert auch an diesem Rolladen (Ebenfalls Homematic, aber andere Firmware) nicht.
      LG S.
      simatec R 2 Replies Last reply Reply Quote 0
      • simatec
        simatec Developer Most Active @rotamint last edited by
        @rotamint naja dein Lichtsensor sendet schon sehr wild ... Aber das sind auch keine realen Bedingungen in deiner Hosentasche.
        Ich hatte aber vorher schon geschrieben, dass du mit der Hysteresse arbeiten musst.
        Je nach Empfindlichkeit deines Lichtsensor halt angepasst.
        Wie ich auch schon geschrieben habe, kannst du den auch etwas glätten.
        Damit würde er nicht wie wild alle 5 Sekunden einen anderen Wert schicken.
          rotamint @rotamint last edited by
          @rotamint Auch diese These hat sich eben verworfen, wechselt auch ohne Änderung munter in den Manu_Mode...
          shuttercontrol.0
          	2022-06-01 16:45:38.028	debug	WZ Rolladenaktor Panoramafenster.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          	2022-06-01 16:45:38.028	debug	WZ Rolladenaktor Panoramafenster.LEVEL drived manually to 36. Old value = 100. New value = 36
          shuttercontrol.0
          	2022-06-01 16:45:38.019	debug	Shutter state changed: WZ Rolladenaktor Panoramafenster.LEVEL old value = 100 new value = 36
          shuttercontrol.0
          	2022-06-01 16:45:22.889	debug	WZ Rolladenaktor Panoramafenster.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          	2022-06-01 16:45:22.888	debug	WZ Rolladenaktor Panoramafenster.LEVEL drived manually to 36. Old value = 100. New value = 36
          shuttercontrol.0
          	2022-06-01 16:45:22.874	debug	Shutter state changed: WZ Rolladenaktor Panoramafenster.LEVEL old value = 100 new value = 36
          shuttercontrol.0
          	2022-06-01 16:45:22.714	debug	WZ Rolladenaktor Panoramafenster.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          	2022-06-01 16:45:22.713	debug	WZ Rolladenaktor Panoramafenster.LEVEL drived manually to 36. Old value = 100. New value = 36
          shuttercontrol.0
          	2022-06-01 16:45:22.702	debug	Shutter state changed: WZ Rolladenaktor Panoramafenster.LEVEL old value = 100 new value = 36
          shuttercontrol.0
          	2022-06-01 16:45:01.286	debug	Lightsensor changed: zigbee.0.04cf8cdf3c7b5527.illuminance Value: 144
          shuttercontrol.0
          	2022-06-01 16:45:01.285	debug	insidetemperature changed: zigbee.0.04cf8cdf3c7b5527.illuminance Value: 144
          shuttercontrol.0
          	2022-06-01 16:45:00.026	debug	Sun Elevation: 41.4°
          shuttercontrol.0
          	2022-06-01 16:45:00.026	debug	Sun Azimut: 256.1°
          shuttercontrol.0
          	2022-06-01 16:45:00.025	debug	calculate astrodata ...
          shuttercontrol.0
          	2022-06-01 16:44:51.335	debug	save current height after State Check: 99.5% from WZ Rolladenaktor Panoramafenster.LEVEL
          shuttercontrol.0
          	2022-06-01 16:44:49.714	debug	Sunprotect WZ Rolladenaktor Panoramafenster.LEVEL old height: 100% new height: 36%
          shuttercontrol.0
          	2022-06-01 16:44:49.713	debug	last automatic Action for WZ Rolladenaktor Panoramafenster.LEVEL: down_Sunprotect
          shuttercontrol.0
          	2022-06-01 16:44:49.713	debug	Sunprotect for WZ Rolladenaktor Panoramafenster.LEVEL is active
          shuttercontrol.0
          	2022-06-01 16:44:49.693	info	Sunprotect #420 Set ID: WZ Rolladenaktor Panoramafenster.LEVEL value: 36%
          shuttercontrol.0
          	2022-06-01 16:44:47.689	debug	insidetemperature changed: zigbee.0.54ef4410000c18e4.illuminance Value: 1222
          shuttercontrol.0
          	2022-06-01 16:44:39.759	debug	insidetemperature changed: zigbee.0.04cf8cdf3c78a785.illuminance Value: 2250
          shuttercontrol.0
          	2022-06-01 16:44:34.460	debug	Shuttercontrol save all shutter states
          • simatec
            @rotamint Logge die Statusänderungen des Aktors und die des Rollladenstates in shuttercontrol.
            Sonst suchen wir die Nadel im Heuhaufen.
              Homoran Global Moderator Administrators @simatec last edited by Homoran
              @simatec mich irritiert die Meldung
              @homoran sagte in Test Adapter shuttercontrol v1.4.x:
              KZ Rolladenaktor Balkontüre:1.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
              Laut @rotamint ist das Fenster nicht offen gewesen
              R simatec 2 Replies Last reply Reply Quote 0
                rotamint @Homoran last edited by
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                Auch dieses Fenster war nicht geöffnet, sitze mittlerweile daneben weil ich keine Lust mehr habe ständig nach Oben zu laufen. Das im EG hat auch das Manu_Mode Feature...
                • simatec
                  @rotamint Zeige mal deine Config als json File
                  • simatec
                    @homoran ja da gebe ich dir recht ... Dieses Problem darf so nicht auftreten und tritt auch nicht auf.
                    Ich hoffe, das wirklich keine Scripte irgendwo laufen und auch in der Config nix vertauscht ist
                      @simatec sagte in Test Adapter shuttercontrol v1.4.x:
                      Wie geht das, wie komme ich da ran?
                      Hysterese ist bei den zu beschattenden Rolläden auf zwischen 20 und 25 % gestellt.
                      Habe keine Idee, wie ich den Sensor "glätten" könnte...
                      • simatec
                          @simatec Merci, besten Dank!
                            "_id": "system.adapter.shuttercontrol.0",
                            "common": {
                              "name": "shuttercontrol",
                              "version": "1.4.13",
                              "title": "shuttercontrol",
                              "authors": [
                                "simatec <nais@gmx.net>"
                              "contributors": [
                                "Rene G. <info@rg-engineering.eu>"
                              "keywords": [
                                "ioBroker",
                                "Smart Home",
                                "home automation",
                                "Rollladen",
                                "Jalousie",
                                "Rollladensteuerung"
                              "license": "MIT",
                              "platform": "Javascript/Node.js",
                              "main": "main.js",
                              "icon": "shuttercontrol.png",
                              "enabled": true,
                              "extIcon": "https://raw.githubusercontent.com/simatec/ioBroker.shuttercontrol/master/admin/shuttercontrol.png",
                              "readme": "https://github.com/simatec/ioBroker.shuttercontrol/blob/master/README.md",
                              "loglevel": "silly",
                              "mode": "daemon",
                              "type": "climate-control",
                              "compact": true,
                              "materialize": true,
                              "stopBeforeUpdate": true,
                              "plugins": {
                                "sentry": {
                                  "dsn": "https://5f58df7167d846e3a90bae5414d4fc09@sentry.iobroker.net/62"
                              "installedFrom": "iobroker.shuttercontrol@1.4.13",
                              "installedVersion": "1.4.13",
                              "host": "ioBroker",
                              "connectionType": "local",
                              "dataSource": "push",
                              "adminUI": {
                                "config": "materialize"
                            "native": {
                              "livingAutomatic": "livingSunriseSunset",
                              "W_shutterDownLiving": "",
                              "W_shutterUpLivingMin": "06:20",
                              "W_shutterUpLivingMax": "06:30",
                              "driveDelayUpLiving": "2",
                              "WE_shutterDownLiving": "",
                              "WE_shutterUpLivingMin": "07:00",
                              "WE_shutterUpLivingMax": "07:30",
                              "sleepAutomatic": "sleepSunriseSunset",
                              "W_shutterDownSleep": "",
                              "W_shutterUpSleepMin": "06:30",
                              "W_shutterUpSleepMax": "07:50",
                              "driveDelayUpSleep": "0",
                              "WE_shutterDownSleep": "",
                              "WE_shutterUpSleepMin": "09:30",
                              "WE_shutterUpSleepMax": "10:30",
                              "childrenAutomatic": "childrenSunriseSunset",
                              "W_shutterDownChildren": "21:15",
                              "W_shutterUpChildrenMin": "06:20",
                              "W_shutterUpChildrenMax": "06:35",
                              "driveDelayUpChildren": "2",
                              "WE_shutterDownChildren": "21:30",
                              "WE_shutterUpChildrenMin": "09:59",
                              "WE_shutterUpChildrenMax": "10:25",
                              "latitude": "48.40350",
                              "longitude": "10.03483",
                              "sunProtEndElevation": "-2",
                              "astroDelayUp": "0",
                              "astroDelayDown": "0",
                              "driveDelayUpAstro": "2",
                              "SummerStart": "01.03.",
                              "SummerEnd": "30.09.",
                              "XMasStart": "01.12.",
                              "XMasEnd": "06.01.",
                              "publicHolidays": true,
                              "publicHolInstance": "feiertage.0",
                              "HolidayDP": "",
                              "lightsensorDown": "8",
                              "lightsensorUp": "18",
                              "lightsensorUpDown": "zigbee.0.54ef4410000a2946.illuminance",
                              "schoolfree": true,
                              "schoolfreeInstance": "schoolfree.0",
                              "schoolfreeDP": "",
                              "schoolfreeChildrenArea": true,
                              "schoolfreeSleepArea": false,
                              "schoolfreeLivingArea": false,
                              "LateAllDown": false,
                              "LateAllDownTime": "22:00",
                              "betweenPositionTime": "",
                              "noGoTime": "",
                              "currentShutterState": true,
                              "currentShutterStateTime": "33",
                              "triggerAutoSleep": "",
                              "triggerAutoLiving": "",
                              "triggerAutoChildren": "",
                              "alarmWind1Level": "",
                              "alarmWind1": "",
                              "alarmWind2Level": "",
                              "alarmWind2": "",
                              "alarmRainLevel": "",
                              "alarmRain": "",
                              "alarmFrostLevel": "",
                              "alarmFrost": "",
                              "alarmFireLevel": "",
                              "alarmFire": "",
                              "events": [
                                  "enabled": true,
                                  "shutterName": "KÜ Rolladenaktor:1.LEVEL",
                                  "name": "hm-rpc.0.OEQ1382087.1.LEVEL",
                                  "triggerID": "hm-rpc.0.JEQ0152880.1.STATE",
                                  "typeUp": "lightsensor",
                                  "typeDown": "lightsensor",
                                  "type": "off",
                                  "heightDownSun": "100",
                                  "direction": "120",
                                  "directionRange": "50",
                                  "tempInside": "",
                                  "tempSensor": "",
                                  "outsideTempSensor": "",
                                  "tempOutside": "",
                                  "lightSensor": "",
                                  "valueLight": "",
                                  "heightUp": "100",
                                  "heightDown": "0",
                                  "triggerState": "0",
                                  "triggerStateTilted": "1",
                                  "triggerDrive": "100",
                                  "triggerDriveTildet": "10",
                                  "triggerChange": "upDown",
                                  "elevation": "8",
                                  "autoDrive": "upDown",
                                  "hysteresisOutside": "",
                                  "hysteresisInside": "",
                                  "hysteresisLight": "",
                                  "currentAction": "",
                                  "currentHeight": "",
                                  "oldHeight": "",
                                  "firstCompleteUp": "",
                                  "triggerHeight": "",
                                  "LateDown": true,
                                  "inSummerNotDown": false,
                                  "KeepSunProtect": false,
                                  "triggerAction": "",
                                  "driveAfterClose": true,
                                  "useXmasLevel": false,
                                  "XmasLevel": "0",
                                  "betweenPosition": false,
                                  "betweenPositionLevel": "50",
                                  "trigDelyUp": "0",
                                  "trigDelyDown": "0",
                                  "sunProtectEndDely": "",
                                  "sunProtectEndtimerid": "",
                                  "enableAlarmWind1": false,
                                  "enableAlarmWind2": false,
                                  "enableAlarmRain": false,
                                  "enableAlarmFrost": false,
                                  "enableAlarmFire": false,
                                  "alarmTriggerAction": "",
                                  "alarmTriggerLevel": "",
                                  "lastAutoAction": ""
                                  "enabled": true,
                                  "shutterName": "WZ Rolladenaktor Esstisch.LEVEL",
                                  "name": "hm-rpc.0.LEQ1277083.1.LEVEL",
                                  "triggerID": "hm-rpc.0.JEQ0261673.1.STATE",
                                  "type": "off",
                                  "direction": "165",
                                  "directionRange": "60",
                                  "tempInside": "",
                                  "tempSensor": "",
                                  "tempOutside": "",
                                  "lightSensor": "",
                                  "valueLight": "",
                                  "heightUp": "100",
                                  "heightDown": "0",
                                  "triggerDriveTildet": "16",
                                  "elevation": "8",
                                  "oldHeight": "",
                                  "LateDown": true,
                                  "XmasLevel": "0",
                                  "trigDelyUp": "0",
                                  "enabled": true,
                                  "shutterName": "WZ Rolladenaktor Panoramafenster.LEVEL",
                                  "name": "hm-rpc.0.MEQ0392022.1.LEVEL",
                                  "triggerID": "hm-rpc.0.JEQ0262047.1.STATE",
                                  "type": "only inside temperature",
                                  "heightDownSun": "36",
                                  "direction": "150",
                                  "tempInside": "10000",
                                  "tempSensor": "zigbee.0.54ef4410000c18e4.illuminance",
                                  "tempOutside": "",
                                  "lightSensor": "",
                                  "valueLight": "",
                                  "heightUp": "100",
                                  "heightDown": "0",
                                  "elevation": "",
                                  "hysteresisInside": "10",
                                  "oldHeight": "",
                                  "LateDown": true,
                                  "XmasLevel": "0",
                                  "trigDelyUp": "0",
                                  "sunProtectEndDely": "10",
                                  "enabled": true,
                                  "shutterName": "WZ Rolladenaktor Terrassentüre.LEVEL",
                                  "name": "hm-rpc.0.LEQ0633917.1.LEVEL",
                                  "triggerID": "hm-rpc.0.JEQ0152881.1.STATE",
                                  "heightDownSun": "27",
                                  "direction": "130",
                                  "directionRange": "20",
                                  "tempSensor": "zigbee.0.04cf8cdf3c7b5527.illuminance",
                                  "outsideTempSensor": "hm-rpc.0.OEQ1962498.1.BRIGHTNESS",
                                  "tempOutside": "1",
                                  "lightSensor": "zigbee.0.04cf8cdf3c7b5527.illuminance",
                                  "valueLight": "12000",
                                  "heightUp": "100",
                                  "heightDown": "0",
                                  "elevation": "",
                                  "autoDrive": "onlyUp",
                                  "hysteresisLight": "25",
                                  "oldHeight": "",
                                  "LateDown": false,
                                  "XmasLevel": "0",
                                  "trigDelyUp": "0",
                                  "enabled": true,
                                  "shutterName": "BD Rolladenaktor:1.LEVEL",
                                  "name": "hm-rpc.0.OEQ0548447.1.LEVEL",
                                  "triggerID": "hm-rpc.0.LEQ1248857.1.STATE",
                                  "type": "off",
                                  "direction": "120",
                                  "tempInside": "23",
                                  "tempSensor": "",
                                  "tempOutside": "23",
                                  "lightSensor": "",
                                  "valueLight": "15",
                                  "heightUp": "100",
                                  "heightDown": "0",
                                  "elevation": "8",
                                  "hysteresisOutside": "5",
                                  "hysteresisInside": "5",
                                  "hysteresisLight": "5",
                                  "oldHeight": "",
                                  "LateDown": true,
                                  "XmasLevel": "0",
                                  "trigDelyUp": "0",
                                  "enabled": true,
                                  "shutterName": "SZ Rolladenaktor:1.LEVEL",
                                  "name": "hm-rpc.0.OEQ0259430.1.LEVEL",
                                  "triggerID": "hm-rpc.0.NEQ1763576.1.STATE",
                                  "typeUp": "sleep",
                                  "type": "off",
                                  "direction": "120",
                                  "tempInside": "23",
                                  "tempSensor": "",
                                  "lightSensor": "",
                                  "valueLight": "15",
                                  "heightUp": "100",
                                  "heightDown": "0",
                                  "triggerDriveTildet": "6",
                                  "elevation": "8",
                                  "oldHeight": "",
                                  "LateDown": false,
                                  "XmasLevel": "0",
                                  "trigDelyUp": "0",
                                  "enabled": true,
                                  "shutterName": "KZ Rolladenaktor Balkontüre:1.LEVEL",
                                  "name": "hm-rpc.0.OEQ0550585.1.LEVEL",
                                  "triggerID": "hm-rpc.0.JEQ0152196.1.STATE",
                                  "typeUp": "children",
                                  "heightDownSun": "24",
                                  "direction": "165",
                                  "directionRange": "70",
                                  "tempSensor": "zigbee.0.04cf8cdf3c78a785.illuminance",
                                  "tempOutside": "",
                                  "lightSensor": "",
                                  "valueLight": "",
                                  "heightUp": "100",
                                  "heightDown": "0",
                                  "triggerDriveTildet": "20",
                                  "elevation": "",
                                  "hysteresisInside": "20",
                                  "oldHeight": "",
                                  "LateDown": false,
                                  "XmasLevel": "0",
                                  "trigDelyUp": "0",
                                  "sunProtectEndDely": "3",
                                  "enabled": true,
                                  "shutterName": "KZ Rolladenaktor Fenster.LEVEL",
                                  "name": "hm-rpc.0.MEQ0518060.1.LEVEL",
                                  "triggerID": "hm-rpc.0.IEQ0044866.1.STATE",
                                  "heightDownSun": "60",
                                  "direction": "155",
                                  "tempInside": "13000",
                                  "tempSensor": "zigbee.0.54ef4410000a2de9.illuminance",
                                  "tempOutside": "1",
                                  "lightSensor": "zigbee.0.54ef4410000a2de9.illuminance",
                                  "valueLight": "15000",
                                  "heightUp": "100",
                                  "heightDown": "0",
                                  "elevation": "8",
                                  "oldHeight": "",
                                  "LateDown": false,
                                  "XmasLevel": "0",
                                  "trigDelyUp": "0",
                                  "enabled": true,
                                  "shutterName": "BZ Rolladenaktor.LEVEL",
                                  "name": "hm-rpc.0.OEQ1382244.1.LEVEL",
                                  "triggerID": "hm-rpc.0.MEQ0223230.1.STATE",
                                  "heightDownSun": "78",
                                  "direction": "150",
                                  "tempInside": "20000",
                                  "tempSensor": "zigbee.0.54ef4410000a2d4e.illuminance",
                                  "tempOutside": "1",
                                  "lightSensor": "zigbee.0.54ef4410000a2d4e.illuminance",
                                  "valueLight": "20000",
                                  "heightUp": "100",
                                  "heightDown": "0",
                                  "triggerChange": "off",
                                  "elevation": "8",
                                  "oldHeight": "",
                                  "LateDown": true,
                                  "XmasLevel": "0",
                                  "trigDelyUp": "0",
                                  "enabled": true,
                                  "shutterName": "DWZ Rolladenaktor.LEVEL",
                                  "name": "hm-rpc.0.MEQ0392973.1.LEVEL",
                                  "triggerID": "hm-rpc.0.NEQ1763354.1.STATE",
                                  "type": "off",
                                  "direction": "120",
                                  "tempInside": "23",
                                  "tempSensor": "",
                                  "lightSensor": "",
                                  "valueLight": "15",
                                  "heightUp": "100",
                                  "heightDown": "0",
                                  "elevation": "8",
                                  "oldHeight": "",
                                  "LateDown": true,
                                  "XmasLevel": "0",
                                  "trigDelyUp": "0",
                            Homoran Global Moderator Administrators @rotamint last edited by
                            @rotamint sagte in Test Adapter shuttercontrol v1.4.x:
                            was ist das?
                            das passt irgendwie nicht
                              @homoran Ich schau nach ...
                                rotamint @Homoran last edited by rotamint
                                JEQ0152196
                                Fensterdrehgriffkontakt Kinderzimmer Balkontüre. (0 = geschlossen, 1 = gekippt /tilted 2 = offen /open)
                                Habe die Stati der Drehgriffe in Jarvis visualisiert und da gibt's keine Unregelmäßigkeiten...
                                • simatec
                                  simatec Developer Most Active @rotamint last edited by simatec
                                  @rotamint Teste mal die Config laut Anhang
                                  Kannst du oben rechts mit den Pfeiltasten wieder hochladen
                                  bdc349ff-b58b-481a-88f4-610fffddeec2-system.adapter.shuttercontrol.0_rotamint.json
                                    @simatec Danke für Deine Mühe. Eben hochgeladen... Sensor in die Hosentasche (=dunkel, Wert auf 100 für Änderung). Fazit: Wert > 100 wird erkannt, aber es fährt nichts...
                                    Trigger steht auf Außentemperatur / Lichtsensor. Außentemperaturfeld ist leer.
                                    Das Manual sagt an dieser Stelle:
                                    Der Sonnenschutz löst erst aus wenn ALLE gewählten Auslöser aktiv sind (UND Verknüpfung).
                                    Wird eine Steuerung mit mehreren Sensoren gewünscht, muss die entsprechende Kombination in der Sonnenschutzart gewählt werden. Der Lichtsensor ist in denjenigen Auswahlen, wo dieser mit aufgeführt ist, jeweils optional. Ist der Lichtsensor konfiguriert, wird er mit den anderen Parametern UND verknüpft.
                                    Soll das trotzdem funktionieren, wenn nur der Lichtsensor, aber kein Temperatursensor hinterlegt ist? Ich hatte das anders verstanden...
                                    • simatec
                                      @rotamint sorry mein Fehler ...
                                      f5d28735-83c5-4c93-88ba-f82380633b07-system.adapter.shuttercontrol.0 (2).json
                                        @simatec Danke. Ich werde testen und berichten!
                                          @simatec Leider nein 😧
                                          shuttercontrol.0
                                          	2022-06-01 19:32:48.761	debug	WZ_Rolladenaktor_Panoramafenster Old value = 36. New value = 36. automatic is active
                                          shuttercontrol.0
                                          	2022-06-01 19:32:33.831	debug	WZ_Rolladenaktor_Panoramafenster Old value = 36. New value = 36. automatic is active
                                          shuttercontrol.0
                                          	2022-06-01 19:32:33.678	debug	Shutter WZ_Rolladenaktor_Panoramafenster was moved manually to: 36% - prevent trigger from driving back
                                          shuttercontrol.0
                                          	2022-06-01 19:32:33.677	debug	save current height after State Check: 36% from WZ_Rolladenaktor_Panoramafenster
                                          shuttercontrol.0
                                          	2022-06-01 19:32:01.555	debug	outsidetemperature changed: zigbee.0.54ef4410000c18e4.illuminance Value: 371
                                          shuttercontrol.0
                                          	2022-06-01 19:31:54.927	debug	WZ_Rolladenaktor_Panoramafenster Old value = 36. New value = 100. automatic is active
                                          shuttercontrol.0
                                          	2022-06-01 19:31:54.927	debug	Shutter state changed: WZ_Rolladenaktor_Panoramafenster old value = 36 new value = 100
                                          shuttercontrol.0
                                          	2022-06-01 19:31:54.820	debug	Shutter WZ_Rolladenaktor_Panoramafenster was moved manually to: 100% - prevent trigger from driving back
                                          shuttercontrol.0
                                          	2022-06-01 19:31:54.820	debug	save current height after State Check: 100% from WZ_Rolladenaktor_Panoramafenster
                                          shuttercontrol.0
                                          	2022-06-01 19:31:54.769	debug	WZ_Rolladenaktor_Panoramafenster Updated trigger action to Manu_Mode to prevent moving after window close
                                          shuttercontrol.0
                                          	2022-06-01 19:31:54.769	debug	WZ_Rolladenaktor_Panoramafenster drived manually to 100. Old value = 36. New value = 100
                                          shuttercontrol.0
                                          	2022-06-01 19:31:54.760	debug	Shutter state changed: WZ_Rolladenaktor_Panoramafenster old value = 36 new value = 100
                                          shuttercontrol.0
                                          	2022-06-01 19:31:53.673	debug	Sunprotect WZ_Rolladenaktor_Panoramafenster old height: 36% new height: 36%
                                          shuttercontrol.0
                                          	2022-06-01 19:31:53.672	debug	Temperature outside: 347 > 100 AND Light: 0 > 15
                                          shuttercontrol.0
                                          	2022-06-01 19:31:53.672	debug	Sunprotect for WZ_Rolladenaktor_Panoramafenster is active
                                          shuttercontrol.0
                                          	2022-06-01 19:31:53.672	debug	last automatic Action for WZ_Rolladenaktor_Panoramafenster: down_Sunprotect
                                          shuttercontrol.0
                                          	2022-06-01 19:31:53.649	info	Sunprotect #418 Set ID: WZ_Rolladenaktor_Panoramafenster value: 36%
                                          shuttercontrol.0
                                          	2022-06-01 19:31:53.649	debug	WZ_Rolladenaktor_Panoramafenster: Check basis for sunprotect. Height:100 > HeightDownSun: 36 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                                          shuttercontrol.0
                                          	2022-06-01 19:31:51.643	debug	outsidetemperature changed: zigbee.0.54ef4410000c18e4.illuminance Value: 347
                                          shuttercontrol.0
                                          	2022-06-01 19:31:46.657	debug	outsidetemperature changed: zigbee.0.54ef4410000c18e4.illuminance Value: 45
                                          • simatec
                                            @rotamint Laut dem Log ist der Check erfolgreich
                                            Wie gesagt ... prüfe den Aktor ... der funkt dir dazwischen.
                                            Es gibt hier aber einige User, die diesen Aktor nutzen.
                                            Es geht also damit
                                            332
                                            7408
                                            10586698
