    3. Einsteigerfragen
    4. Zigbee Adapter stürzt ständig ab
      Thomas Braun Most Active @klaris last edited by
      @klaris sagte in Zigbee Adapter stürzt ständig ab:
      nodesource.list.save.
      Die Versuche die Datei zu speichern kannst du löschen:
      sudo rm /etc/apt/sources.list.de/nodesource.list.save.*
        klaris @Thomas Braun last edited by Homoran
        pi@raspberrypi:~ $ systemctl status deconz deconz-gui
        Unit deconz.service could not be found.
        Unit deconz-gui.service could not be found.
        alles nach anweisung durchgeführt system neu gestartet....👍
          @klaris
          Gut, dann spukt der Kram da auch nicht mehr rum.
          Upgrades und Reboot durch?
          sudo apt update
          sagt nun?
            @klaris
            Nochmal
            uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
              pi@raspberrypi:~ $ uname -m && which nodejs node npm && nodejs -v && node -v &&        npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && ap        t policy nodejs
              armv7l
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v14.19.3
              v14.19.3
              6.14.17
              pi
              /home/pi
              Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
              Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:3 https://deb.nodesource.com/node_14.x bullseye InRelease
              Get:4 https://phoscon.de/apt/deconz bullseye InRelease [2,873 B]
              Fetched 2,873 B in 3s (981 B/s)
              Reading package lists... Done
              Building dependency tree... Done
              All packages are up to date.
              N: Ignoring file 'nodesource.list.save.1' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
              N: Ignoring file 'nodesource.list.save.5' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
              N: Ignoring file 'nodesource.list.save.4' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
              N: Ignoring file 'nodesource.list.save.2' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
              N: Ignoring file 'nodesource.list.save.3' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
              nodejs:
                Installed: 14.19.3-deb-1nodesource1
                Candidate: 14.19.3-deb-1nodesource1
                Version table:
               *** 14.19.3-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
                      100 /var/lib/dpkg/status
                   12.22.5~dfsg-2~11u1 500
                      500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                @klaris
                sudo rm /etc/apt/sources.list.d/nodesource.list.save.*
                  @thomas-braun muss ich diese zeile auch eingeben ?
                  -bash: pi@raspberrypi:~: command not found
                  -bash: armv7l: command not found
                  Welcome to Node.js v14.19.3.
                  Type ".help" for more information.
                    Thomas Braun Most Active @klaris last edited by Thomas Braun
                    @klaris
                    Ja. Das beseitigt diese 'Ignoring...'-Meldungen.
                    [Edit:] Du kleisterst da irgendwas wild in die Konsole. Schau genauer was du da reinknallst.
                      klaris @Thomas Braun last edited by klaris
                      @thomas-braun said in Zigbee Adapter stürzt ständig ab:
                      @klaris
                      sieht schon mal alles super aus !!!! ich tippe auch nix mehr in die konsole rein😊 ich mache ein backup und gut ist !!! ich beobachte es mal über nacht ...
                      hofentlich läuft der zigbee adapter ohne absturze ..soll ich den zigbee adapter updaten auf 1.7.5?
                      Noch mal ein grosses DANKE im voraus....
                        iobroker update -u
                        iobroker upgrade all
                          @klaris
                          Ist das jetzt suaber?
                          Tip am Rande:
                          Wenn die ersten ```alleine in einer eigenen Zeile stehen wird da auch ein schöner Code Block draus.
                            @thomas-braun sagte in Zigbee Adapter stürzt ständig ab:
                            armv7l
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v14.19.3
                            v14.19.3
                            6.14.17
                            pi
                            /home/pi
                            Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                            Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                            Get:3 https://phoscon.de/apt/deconz bullseye InRelease [2,873 B]
                            Hit:4 https://deb.nodesource.com/node_14.x bullseye InRelease
                            Fetched 2,873 B in 4s (693 B/s)
                            nodejs:
                              Version table:
                              @klaris
                              Der Fragmente sind ja immer noch da...
                              sudo rm /etc/apt/sources.list.d/nodesource.list.sav*
                                @thomas-braun 👍 👍 👍 👍
                                pi@raspberrypi:~ $ sudo rm /etc/apt/sources.list.d/nodesource.list.sav*
                                armv7l
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                v14.19.3
                                v14.19.3
                                6.14.17
                                pi
                                /home/pi
                                Fetched 2,873 B in 3s (942 B/s)
                                nodejs:
                                  Version table:
                                  @klaris
                                  iobroker update -i
                                    Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
                                    komisch ist nur wenn ich im iobroker unter adapter gehe steht :
                                    Verfügbare Version:1.7.5 Installierte Version:1.6.18 obwohl ich ja 1.7.5 instaliert habe ...aber läuft ... das ist wichtig
                                      @klaris
                                      Nix kürzen...
                                      Zum dritten Mal:
                                      iobroker update -i
                                        pi@raspberrypi:~ $ iobroker update -i
                                        Used repository: stable
                                        Adapter    "admin"        : 5.3.8    , installed 5.3.8
                                        Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
                                        Adapter    "backitup"     : 2.4.6    , installed 2.4.6
                                        Adapter    "countdown"    : 1.2.5    , installed 1.2.5
                                        Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
                                        Adapter    "discovery"    : 3.0.3    , installed 3.0.3
                                        Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                                        Adapter    "info"         : 1.9.19   , installed 1.9.19
                                        Adapter    "iot"          : 1.11.4   , installed 1.11.4
                                        Adapter    "javascript"   : 5.7.0    , installed 5.7.0
                                        Adapter    "meross"       : 1.10.5   , installed 1.10.5
                                        Adapter    "ping"         : 1.5.3    , installed 1.5.3
                                        Adapter    "shelly"       : 5.3.2    , installed 5.3.2
                                        Adapter    "simple-api"   : 2.6.5    , installed 2.7.0
                                        Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                                        Adapter    "telegram"     : 1.12.6   , installed 1.12.6
                                        Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
                                        Adapter    "vis"          : 1.4.15   , installed 1.4.15
                                        Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
                                        Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
                                        Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.2.2
                                          @klaris
                                          iobroker upload all
                                          Und starte den Browser mal neu. Zumindest die Admin-Seite nochmal richtig neuladen.
                                            @thomas-braun 👍 läuft
                                            5228
