    4. Zigbee stürzt beim schalten von Birnen über Shalter ab
      earl80 @David G. last edited by earl80
      @david-g @arteck ist bei mir ähnlich
      code_text
      host.raspberrypi
      2022-06-03 04:50:09.070 error instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.raspberrypi
      2022-06-03 04:50:09.070 error Caught by controller[1]: at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:18)
      host.raspberrypi
      2022-06-03 04:50:09.070 error Caught by controller[1]: at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:236:54)
      host.raspberrypi
      2022-06-03 04:50:09.069 error Caught by controller[1]: at DeviceEvent.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:26:18)
      host.raspberrypi
      2022-06-03 04:50:09.069 error Caught by controller[1]: at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:44:26)
      host.raspberrypi
      2022-06-03 04:50:09.069 error Caught by controller[1]: at Object.bulbOnEvent [as onEvent] (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js:39:19)
      host.raspberrypi
      2022-06-03 04:50:09.069 error Caught by controller[1]: TypeError: Cannot read property 'color_options' of undefined
      host.raspberrypi
      2022-06-03 04:50:09.068 error Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      zigbee.0
      2022-06-03 04:50:07.894 error Cannot read property 'color_options' of undefined
      zigbee.0
      2022-06-03 04:50:07.893 error TypeError: Cannot read property 'color_options' of undefined at Object.bulbOnEvent [as onEvent] (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js:39:19) at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:44:26) at DeviceEvent.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:26:18) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:236:54) at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:18)
      zigbee.0
      2022-06-03 04:50:07.887 error unhandled promise rejection: Cannot read property 'color_options' of undefined
      zigbee.0
      2022-06-03 04:50:07.886 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        Einstein67 @earl80 last edited by
        Kann ich bestätigen. Hab auch IKEA Lampen
        2022-06-03 06:00:55.929 - warn: zigbee.0 (17889) Device '0x2c1165fffee4589c' announced itself
        2022-06-03 06:00:55.933 - error: zigbee.0 (17889) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2022-06-03 06:00:55.933 - error: zigbee.0 (17889) unhandled promise rejection: Cannot read properties of undefined (reading 'color_options')
        2022-06-03 06:00:55.934 - error: zigbee.0 (17889) TypeError: Cannot read properties of undefined (reading 'color_options')
        2022-06-03 06:00:55.934 - error: zigbee.0 (17889) Cannot read properties of undefined (reading 'color_options')
        2022-06-03 06:00:55.948 - info: zigbee.0 (17889) cleaned everything up...
        2022-06-03 06:00:55.969 - info: zigbee.0 (17889) Zigbee: disabling joining new devices.
        2022-06-03 06:00:56.448 - info: zigbee.0 (17889) terminating
        2022-06-03 06:00:56.449 - warn: zigbee.0 (17889) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2022-06-03 06:00:56.997 - error: host.iob18ig Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        2022-06-03 06:00:56.997 - error: host.iob18ig Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'color_options')
        2022-06-03 06:00:56.997 - error: host.iob18ig Caught by controller[0]: at Object.bulbOnEvent [as onEvent] (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js:39:19)
        2022-06-03 06:00:56.997 - error: host.iob18ig Caught by controller[0]: at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:44:26)
        2022-06-03 06:00:56.997 - error: host.iob18ig Caught by controller[0]: at DeviceEvent.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:26:18)
        2022-06-03 06:00:56.997 - error: host.iob18ig Caught by controller[0]: at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:236:54)
        2022-06-03 06:00:56.997 - error: host.iob18ig Caught by controller[0]: at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:18)
        2022-06-03 06:00:56.998 - error: host.iob18ig instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2022-06-03 06:00:56.998 - info: host.iob18ig Restart adapter system.adapter.zigbee.0 because enabled
          color_options
          da ist ein bug im converter.und sind nur ikea lampen betroffen
          @earl80 Logs bitte in Code tag.. kann man besser lesen
            M-A-X @arteck last edited by
            @arteck bei mir kommt es zum selben Fehler (soweit ich das erkenne) wie bei @earl80
            zigbee.0
            2022-06-03 08:01:18.099	error	TypeError: Cannot read property 'color_options' of undefined at Object.bulbOnEvent [as onEvent] (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js:39:19) at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:44:26) at DeviceEvent.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:26:18) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:236:54) at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:18)
            zigbee.0
            2022-06-03 08:01:18.095	error	unhandled promise rejection: Cannot read property 'color_options' of undefined
            zigbee.0
            2022-06-03 08:01:18.094	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            host.iobroker
            2022-06-03 07:51:58.562	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            host.iobroker
            2022-06-03 07:51:58.561	error	Caught by controller[5]: at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:236:54)
            host.iobroker
            2022-06-03 07:51:58.560	error	Caught by controller[5]: at DeviceEvent.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:26:18)
            host.iobroker
            2022-06-03 07:51:58.561	error	Caught by controller[5]: at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:18)
            host.iobroker
            2022-06-03 07:51:58.560	error	Caught by controller[5]: at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:44:26)
            host.iobroker
            2022-06-03 07:51:58.559	error	Caught by controller[5]: at Object.bulbOnEvent [as onEvent] (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js:39:19)
            host.iobroker
            2022-06-03 07:51:58.559	error	Caught by controller[5]: TypeError: Cannot read property 'color_options' of undefined
            host.iobroker
            2022-06-03 07:51:58.559	error	Caught by controller[4]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            host.iobroker
            2022-06-03 07:51:58.558	error	Caught by controller[3]: at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:18)
            host.iobroker
            2022-06-03 07:51:58.558	error	Caught by controller[3]: at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:236:54)
            host.iobroker
            2022-06-03 07:51:58.558	error	Caught by controller[3]: at DeviceEvent.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:26:18)
            host.iobroker
            2022-06-03 07:51:58.557	error	Caught by controller[3]: at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:44:26)
            host.iobroker
            2022-06-03 07:51:58.552	error	Caught by controller[3]: TypeError: Cannot read property 'color_options' of undefined
            host.iobroker
            2022-06-03 07:51:58.551	error	Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            host.iobroker
            2022-06-03 07:51:58.551	error	Caught by controller[1]: at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:236:54)
            host.iobroker
            2022-06-03 07:51:58.552	error	Caught by controller[3]: at Object.bulbOnEvent [as onEvent] (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js:39:19)
            host.iobroker
            2022-06-03 07:51:58.550	error	Caught by controller[1]: at DeviceEvent.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:26:18)
            host.iobroker
            2022-06-03 07:51:58.551	error	Caught by controller[1]: at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:18)
            host.iobroker
            2022-06-03 07:51:58.550	error	Caught by controller[1]: at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:44:26)
            host.iobroker
            2022-06-03 07:51:58.549	error	Caught by controller[1]: TypeError: Cannot read property 'color_options' of undefined
            host.iobroker
            2022-06-03 07:51:58.548	error	Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            host.iobroker
            2022-06-03 07:51:58.549	error	Caught by controller[1]: at Object.bulbOnEvent [as onEvent] (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js:39:19)
            host.iobroker
            2022-06-03 07:51:58.548	error	Caught by controller[1]: at ZigbeeController.handleDeviceAnnounce
            Es handelt sich um Ikea Gu10 color spots.
            Das sind bei mir die einzigen zigbee Geräte, die durch einen Schalter stromlos geschaltet werden. Ansonsten müsste der Fehler ja immer kommen, wenn ich ein zigbee Gerät vom Strom nehme und wieder anschließe?
              arteck Developer Most Active @M-A-X last edited by arteck
              @m-a-x nein ES SIND NUR DIE IKEA BETROFFEN..und nur weil ihr die Spots vom Strom trennt
              das ist das wiedereinschalten Verhalten nach Stromlos
                kann einer was testen
                adapter stopen
                dann in den konsole
                nano /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js
                in zeile 39
                if (state.color_options !== undefined && state.color_options.execute_if_off === true) {
                ändern in
                if (state !== undefined && state.color_options.execute_if_off === true) {
                und zeile 42
                if (state.level_config !== undefined && state.level_config.execute_if_off === true) {
                in
                if (state!== undefined && state.level_config.execute_if_off === true) {
                adapter starten
                  M-A-X @arteck last edited by M-A-X
                  @arteck
                  Muss das von unterwegs auf dem Handy über VPN machen. Hoffe es geht nichts schief 🙂
                  code_textst.iobroker
                  2022-06-03 08:45:08.162	info	Restart adapter system.adapter.zigbee.0 because enabled
                  host.iobroker
                  2022-06-03 08:45:08.162	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                  host.iobroker
                  2022-06-03 08:45:08.162	error	Caught by controller[1]: at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:18)
                  host.iobroker
                  2022-06-03 08:45:08.162	error	Caught by controller[1]: at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:236:54)
                  host.iobroker
                  2022-06-03 08:45:08.161	error	Caught by controller[1]: at DeviceEvent.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:26:18)
                  host.iobroker
                  2022-06-03 08:45:08.161	error	Caught by controller[1]: at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:44:26)
                  host.iobroker
                  2022-06-03 08:45:08.161	error	Caught by controller[1]: at Object.bulbOnEvent [as onEvent] (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js:42:19)
                  host.iobroker
                  2022-06-03 08:45:08.160	error	Caught by controller[1]: TypeError: Cannot read property 'level_config' of undefined
                  host.iobroker
                  2022-06-03 08:45:08.159	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                  zigbee.0
                  2022-06-03 08:45:07.539	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                  zigbee.0
                  2022-06-03 08:45:07.537	info	terminating
                  zigbee.0
                  2022-06-03 08:45:07.225	info	Zigbee: disabling joining new devices.
                  zigbee.0
                  2022-06-03 08:45:07.036	info	cleaned everything up...
                  zigbee.0
                  2022-06-03 08:45:07.022	error	Cannot read property 'level_config' of undefined
                  zigbee.0
                  2022-06-03 08:45:07.021	error	TypeError: Cannot read property 'level_config' of undefined at Object.bulbOnEvent [as onEvent] (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js:42:19) at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:44:26) at DeviceEvent.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:26:18) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:236:54) at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:18)
                  zigbee.0
                  2022-06-03 08:45:07.018	error	unhandled promise rejection: Cannot read property 'level_config' of undefined
                  zigbee.0
                  2022-06-03 08:45:07.017	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  zigbee.0
                  2022-06-03 08:45:07.009	warn	Device '0x2c1165fffe9542d9' announced itself
                  web.0
                  2022-06-03 08:44:58.839	info	==> Connected system.user.admin from ::ffff:192.168.9.101
                  zigbee.0
                  2022-06-03 08:44:34.132	info	Zigbee started
                    @m-a-x du musst noch eine zeile ändern
                      @arteck oh sorry. Hab ich überlesen... Handy Ansicht und so.
                      Scheint wieder zu funktionieren. Meine Frau sagt auch das Licht ist an und aus gegangen 🙂
                      zigbee.0
                      2022-06-03 09:04:48.906	warn	Device '0x2c1165fffe7d55cd' announced itself
                      zigbee.0
                      2022-06-03 09:04:48.655	warn	Device '0x2c1165fffe94ad5d' announced itself
                      zigbee.0
                      2022-06-03 09:04:48.420	warn	Device '0x2c1165fffe85b3f6' announced itself
                      zigbee.0
                      2022-06-03 09:04:48.402	warn	Device '0x2c1165fffe7d68a2' announced itself
                      zigbee.0
                      2022-06-03 09:04:48.389	warn	Device '0x2c1165fffe8a05ce' announced itself
                      zigbee.0
                      2022-06-03 09:04:48.387	warn	Device '0x2c1165fffe2cd033' announced itself
                      zigbee.0
                      2022-06-03 09:04:48.359	warn	Device '0x2c1165fffe9542d9' announced itself
                      web.0
                      2022-06-03 09:04:38.708	info	==> Connected system.user.admin from ::ffff:192.168.9.101
                      zigbee.0
                      2022-06-03 09:04:12.555	info	Zigbee started
                        ich hab ne korektur eingestellt im converter... wird bestimmt dauern..
                        aber so ist euch erstmal geholfen
                        E David G. 2 Replies Last reply Reply Quote 1
                          Einstein67 @arteck last edited by
                          @arteck Funktioniert!!
                          Vielen Dank!
                          • David G.
                            David G. @arteck last edited by David G.
                            @arteck
                            Müssen wir die Zeilen jetzt bei jedem Update des Adapters ändern, bis das im Converter gefixt wurde?
                            Danke für die schnelle Hilfe.
                              arteck Developer Most Active @David G. last edited by
                              @david-g wenn du von Git installierst dann ja..
                                korrektur ist ab sofort auf GIT verfügbar
                                M E 2 Replies Last reply Reply Quote 2
                                  Martin-72 @arteck last edited by
                                  @arteck Ich habe das Problem auch noch. Ich habe den Adapter aber über die Adapterverwaltung vom ioBroker installiert:
                                  Gibt es schon Hochrechnungen, wann die Fehlerbehebung auch dort ankommt?
                                  Oder soll ich den weiter oben beschriebenen Weg wählen? Muss / (Wie) Kann ich die Adapter sichern und wieder einspielen, um nicht alles neu anlernen zu müssen...?
                                  Vielen Dank
                                  Martin
                                  • amg_666
                                    amg_666 @Martin-72 last edited by
                                    @martin-72 Du kannst den über github installieren. In der Adminoberfläche auf die "Katze" tippen und da dann zigbee eingeben und den Adapter installieren. Das ist dasselbe wie ein Versionsupdate über die Adapterverwaltung, nur dass es halt "Beta" ist und noch nicht "offiziell", sichern musst du da eigentlich nichts, ist nur ne neue Version.
                                      Martin-72 @amg_666 last edited by
                                      Vielen Dank
                                      Liebe Grüße
                                      Martin
                                        ewf04214 @arteck last edited by ewf04214
                                        @arteck Das Problem besteht seit geraumer Zeit wieder. Was genau meinst du mit Bug im Converter, kommt der Converter von dir, oder bindest du etwas externes ein? Dann müsste man den Fehler ja dort melden.
                                        Guten Rutsch
                                          dimaiv @ewf04214 last edited by
                                          @ewf04214
                                          Aktuelle Stand: vor 3 Stunden über Git installiert, alles mögliche probiert, KENE FEHLER !
                                          Guten Rutsch!
                                            1.9.6 ist unterwegs
                                            2093
