    4. Seit Update Node V12->V14 ständige Fehlermeldung
      Trafficlight @Thomas Braun last edited by
      freier Festplattenspeicher: 72%, Gesamte RAM-Auslastung: 1428 Mb / Frei: 81% = 3100 Mb [Server: raspberrypi - 21 Prozesse]
      top - 13:45:24 up 4 min,  2 users,  load average: 3.52, 2.04, 0.86
      Tasks: 180 total,   5 running, 175 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 52.2 us,  9.5 sy,  0.0 ni, 35.0 id,  0.0 wa,  0.0 hi,  3.3 si,  0.0 st
      MiB Mem :   3837.9 total,   2344.6 free,   1032.8 used,    460.5 buff/cache
      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2914.1 avail Mem
        PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
        522 iobroker  20   0  257272 146532  33972 R  93.7   3.7   3:20.18 iobroker.js-con
        779 iobroker  20   0  277000 164560  29056 R  68.2   4.2   2:23.39 io.javascript.0
       2211 iobroker  20   0  244028 132316  29032 R  61.6   3.4   1:39.45 io.g-homa.0
        390 avahi     20   0    6916   2728   2468 S   7.6   0.1   0:16.87 avahi-daemon
        616 iobroker  20   0  190788  83192  34596 S   6.3   2.1   0:16.12 io.admin.0
        921 iobroker  20   0  184356  76232  34612 S   4.3   1.9   0:09.86 io.telegram.0
       1524 iobroker  20   0  173240  55208  28852 S   4.3   1.4   0:08.41 io.simple-api.0
       1180 iobroker  20   0  184240  68536  29208 S   3.0   1.7   0:04.95 io.tr-064.0
        401 pi        20   0  153612  51804  36800 S   1.0   1.3   0:04.70 deCONZ
         91 root      20   0       0      0      0 D   0.7   0.0   0:01.07 kworker/0:2+events_freezable
       1005 iobroker  20   0  185116  69304  29080 S   0.7   1.8   0:06.53 io.shelly.0
       1342 iobroker  20   0  172560  52280  28888 S   0.7   1.3   0:01.94 io.discovery.0
       1640 iobroker  20   0  182968  71232  29908 S   0.7   1.8   0:06.72 io.mercedesme.0
       1889 iobroker  20   0  175772  59220  29068 S   0.7   1.5   0:04.06 io.wled.0
       1932 iobroker  20   0  182896  72416  29140 S   0.7   1.8   0:05.24 io.yahka.0
         90 root     -51   0       0      0      0 S   0.3   0.0   0:00.58 irq/64-mmc0
         95 root      20   0       0      0      0 S   0.3   0.0   0:00.03 jbd2/sda2-8
        397 root      20   0    8428   3620   2900 S   0.3   0.1   0:00.89 deCONZ-WIFI2.sh
       1751 iobroker  20   0  172664  53072  29168 S   0.3   1.4   0:02.54 io.nanoleaf-lig
       2024 iobroker  20   0  175532  56308  28876 S   0.3   1.4   0:02.87 io.web.0
       2144 iobroker  20   0  177944  58160  30256 S   0.3   1.5   0:03.87 io.fb-checkpres
       3805 pi        20   0   11240   3172   2612 R   0.3   0.1   0:00.06 top
          1 root      20   0   33948   9088   7224 S   0.0   0.2   0:03.07 systemd
        Trafficlight @haselchen last edited by
        @haselchen
        habe ich durchgeführt. sobald JS gestartet wird ist das gleiche Problem wieder da.
        • haselchen
          haselchen Most Active @Trafficlight last edited by
          @trafficlight
          was sagt denn:
          iobroker compact status
            @haselchen
            pi@raspberrypi:/opt/iobroker $ iobroker compact status
            Compact mode for this host is currently disabled
            • haselchen
              @trafficlight
              Okay, das passt jetzt.
              Die obige Meldung dürfte jetzt nicht mehr kommen.
              Cannot read compact mode by host "system.host.raspberrypi": timeout
                @haselchen
                hatte diese Meldung tatsächlich nicht mehr aber es kam ein Fenster das eine Langsame Verbindung erkannt wurde. Letzten Endes musste ich einen reboot durchführen.
                Habe jetzt von V5.7.0 auf V5.6.0 downgegraded mal schauen ob es stabil läuft.
                  Thomas Braun Most Active @Trafficlight last edited by
                  @trafficlight
                  Da kippt dir wohl ein Skript weg.
                    zum Verständnis ich habe aktuell 22 Skripte am laufen. Sollen die besser zusammen gefasst werden oder lieber viele einzelne?
                    Könnte es eventuell dieser hier sein.
                    Ich möchte einen Dummy Schalter (dient nur als Anzeige in VIS) mit den Werten 0;1;2;3 schalten sobald bestimmte Temperaturen erreicht wurden.
                    Diesen Skript habe ich für all meine Räume und Außenbereich erstellt.
                      @trafficlight
                      Das knallt dir bei jeder Änderung der Temperatur los.
                      Zumindest ungeschickt, ohne Hysterese.
                        Trafficlight @Thomas Braun last edited by Trafficlight
                        habe diesen Skript für alle Räume dementsprechend angepasst. Habe eben diese Deaktiviert leider auch ohne Erfolg.
                        Wie gesagt ich schalte damit nichts es dient nur zur Anzeige 😉
                        hier mal etwas neues
                        Cannot read countsOfInstances: timeout
                          Thomas Braun Most Active @Trafficlight last edited by Thomas Braun
                          @trafficlight
                          Das schaut für mich unlogisch aus. Wenn die Temperatur 25 Grad ist werden drei Bedingungen wahr.
                          Muss sich vielleicht @paul53 mal anschauen.
                          Wenn die anderen Skripte auch so aussehen...
                            bin jetzt von V5.6.0. auf V5.5.4 gegangen scheint zu funktionieren.
                            Wenn ja hat mich das ganze 2 Tage Urlaub und viel viel nerven gekostet. 😲
                              @trafficlight
                              Spricht für unsaubere Skripte. Da wirst du wohl ran müssen.
                                wieso hatte es dann 3 Jahre lang so funktioniert?
                                edit: funzt immer noch nicht 😰
                                  @trafficlight
                                  Weil sich Dinge die früher möglich waren ändern z.B.?
                                    sehr schön ... manchmal
                                    eventuell habe ich den fehler aber jetzt gefunden.
                                    Mein Protokoll wird zugeknallt mit dieser Fehlermeldung.
                                    script.js.Heizung.Bad-Heizung-Sommer: setForeignState: Error: DB closed
                                      @trafficlight
                                      Ich sag doch, da sind die Skripte krumm.
                                        Für alle die auch Probleme haben. Es ist tatsächlich so was "Thomas Braun" schreibt.
                                        Zwei Skripte waren "krumm". Habe diese angepasst. Nun läufts wieder 😉
                                        1804
