    4. [Anleitung] WireGuard mit WireGuard-UI auf Proxmox
      crunchip Forum Testing Most Active @Einstein2002 last edited by crunchip
      @einstein2002 sagte in [Anleitung] WireGuard mit WireGuard-UI auf Proxmox:
      Hab ein komplett neues iob aufgesetzt
      Was aufgesetzt?
      Halte dich doch an die Anleitung der Reihe nach, da wo Unklarheiten sind, nachfragen
      Vieles kann man allerdings auch aus dem Thread herauslesen
      E 2 Replies Last reply Reply Quote 0
        Einstein2002 @crunchip last edited by
        @crunchip ich habe mir zum Test eben gerade ein neuen LXC mit DEBIAN 11 erstellt. Updates gemacht einen neuen User michael mit sudo rechten eingerichtet, die Zeitzone umgestellt.
        Dann iobroker neu installiert
        Und dann wireguard adapter installiert.
        Gleicher Fehler.
          @crunchip könnte darin mein Fehler liegen?
          Das ist aus der Anleitung.
          I highly recommend the use of sudoers under Linux!
          These security hints rely mainly on linux since it's security system is more complex than the windows one. On a Windows server you'll simply need to use an administrative user. Since the wg command (which is executed to grab the state of WireGuard) requires administrative permissions, think well of what you are doing here and how you configure the user you place in config. To protect these credentials as well as possible both - username and password - are encrypted.
          Basically there are three ways to execute the command:
          use an administrative user (root or similar). This will work but expose your entire server in case the credentials get lost/stolen.
          use of SetUID-Bit: By setting this bit (as far as I understood) each and every user is allowed to execute the flagged file with administrative privileges without needing any password. This includes hackers. So setting this bit on the wg command exposes the entire wg-command with all it's power. If you like to do so execute chmod u+s /usr/bin/wg as an administrator.
          use of sudoers: From my perspective, the most secure way is to set up a new simple user with basic privileges and add a simple line to the sudoers file which allows this user to execute the needed command without entering a password - and ONLY THIS command. Please refer to the documentation of your distribution for proper information on editing the sudoers file and using visudo. The screenshot below shows what needs to be added to the file. wireguard-monitoring-user is the user of your choice. The rest needs to be exactly like you see.
          #iobroker.wireguard adapter
          wireguard-monitoring-user ALL=NOPASSWD:/usr/bin/wg show all dump
          This setting allows the <wireguard-monitoring-user> on ALL hosts to execute the wg show all dump command from the directory /usr/bin/ (may need to be changed on your distribution) without needing a password
          Muss da noch etwas umgestellt werden??
            @einstein2002 warum iobroker neu, du musst doch wireguard auf nem lxc installieren und dieser muss funktionieren.
            In iobroker selbst, stellst du die Verbindung mittels dem Adapter her um die Daten auszulesen. Dies tut aber nichts zur Sache zwecks Funktion von wireguard selbst.
              @crunchip ja, das habe ich auch schon mehrfach gemacht, wollte mir mein Aktives System aber nicht weiter verdrehen.
              Somit habe ich es gestoppt und teste jetzt auf einem system welches ich wieder einfach löschen kann.
              Und jetzt versuche ich gerade diese sudoers datei zu bearbeiten. Da ist noch was mit den rechten? Ich weis es nicht aber ich versuche es halt nach dieser Anleitung.
              https://github.com/Grizzelbee/ioBroker.wireguard#security-hints
                Thomas Braun Most Active @Einstein2002 last edited by
                Da muss dem user noch über visudo das Recht erteilt werden mit der Schnittstelle wg0 zu agieren.
                  Einstein2002 @Thomas Braun last edited by
                  @thomas-braun ja soweit habe ich es mir auch zusammengereimt.
                  Aber ich brauche halt einfach etwas länger.
                    @einstein2002 gibt auch ein "fertiges Paket"
                    https://tteck.github.io/Proxmox/
                      @thomas-braun Das war der Fehler
                      mit
                      visudo
                      diese zwei zeilen hinzugefügt
                      gespeichert und es läuft.
                      Den Haken sudo habe ich nicht gesetzt.
                      Und damit bekomme ich die Daten wie gewünscht.
                      Auch auf meinem Aktiv System.
                      Für den Fall es interessiert noch jemand.
                      Grüße und schönes Wochenende
                        @crunchip Das schau ich mir später an, sieht sehr vielversprechend aus. Danke für den link
                        Stephan Schleich 1 Reply Last reply Reply Quote 0
                        • Stephan Schleich
                          Stephan Schleich @Einstein2002 last edited by
                          Also bei mir dauert es bis zu 5 Sekunden bis ein Handshake ausgehandelt ist, weiß jemand woran das liegen kann? Dies verursacht bei mir auch diese Timeouts
                          • Negalein
                            Hallo
                            Ich versuchs mal hier, mit der Hoffnung auf Hilfe! 🙂
                            Frage an die Netzwerkfreaks 😉
                            Wireguard läuft.
                            Ich kann auch auf alles im Netzwerk zugreifen.
                            Nur auf die Netzwerkfreigaben komm ich nicht.
                            Warum funktioniert das nicht?
                            Gibt es noch Einstellungen dafür?
                            Host: Windows 10 pro
                            Freigabe: Synology NAS
                              Einstein67 @Negalein last edited by Einstein67
                              @negalein said in [Anleitung] WireGuard mit WireGuard-UI auf Proxmox:
                              Hast du im WG-Clienten diese Checkbox deaktiviert?
                              So geht bei mir auch der Zugriff auf alle LAN-Freigaben/Geräte.
                              Negalein 2 Replies Last reply Reply Quote 1
                              • Negalein
                                Negalein Global Moderator @Einstein67 last edited by
                                @einstein67 sagte in [Anleitung] WireGuard mit WireGuard-UI auf Proxmox:
                                Danke, das wars! 🙂
                                • Johnny Englisch
                                  Johnny Englisch @CrunkFX last edited by
                                  @crunkfx
                                  ich habe es schon 1.000 mal nach dieser und anderer Anleitungen versucht.
                                  Es steht immer da das es sucessfully installed wurde ist jedoch nie über die 192.168.178.150:5000 (in meinem Falle) erreichbar.
                                  • Johnny Englisch
                                    @crunkfx said in [Anleitung] WireGuard mit WireGuard-UI auf Proxmox:
                                    @newbroker Kannst du den Installer nochmal ausführen und auf aktualisieren klicken.
                                    Falls das nichts bringt, mach bitte folgendes:
                                    nano /opt/wireguard-ui/db/server/global_settings.json
                                    In die neue Datei :
                                            "endpoint_address": "1.1.1.1",
                                            "dns_servers": [
                                                    "1.1.1.1"
                                            "mtu": "1450",
                                            "persistent_keepalive": "15",
                                            "config_file_path": "/etc/wireguard/wg0.conf",
                                            "updated_at": "2022-01-26T10:15:06.517454916Z"
                                    einfügen und danach
                                    cd /opt/wireguard-ui
                                    ./wireguard-ui
                                    Okay... schien bei mir auch daran zu liegen
                                    Johnny Englisch 1 Reply Last reply Reply Quote 0
                                    • Johnny Englisch
                                      Johnny Englisch @Johnny Englisch last edited by
                                      Nachdem ich diese Datei also per Hand beschrieben habe und den Container neu gestartet habe lief/ leuft es auch... die UI ist auch erreichbar und steuerbar.
                                      Nur habe ich keinen Traffic durch die VPN. Heißt ich kann mein Home Netz nichts erreichen und auch google (zum Beispiel) nicht.
                                      CrunkFX Johnny Englisch 2 Replies Last reply Reply Quote 0
                                      • CrunkFX
                                        CrunkFX Forum Testing @Johnny Englisch last edited by
                                        @johnny-englisch Moin,
                                        kannst du mir bitte die Ausgabe von dem Befehl
                                        wg
                                        mitteilen?
                                        • Johnny Englisch
                                          Johnny Englisch @CrunkFX last edited by Johnny Englisch
                                          wg
                                          mitteilen?
                                          Gerne doch...
                                          Wie gesagt verbinden geht anscheinend... wird aber nicht in der GUI angezeigt.
                                          Habe halt nur kein Internet auf "der anderen Seite"
                                          • Johnny Englisch
                                            @johnny-englisch
                                            Hie auch noch von der GUI
                                            portforwarding portfreigabe portfreischaltung proxmox vpn wireguard wireguard ios app
                                            64
                                            603
                                            168908
