    4. Zigbee stürzt beim schalten von Birnen über Shalter ab
      M-A-X @arteck last edited by
      @arteck bei mir kommt es zum selben Fehler (soweit ich das erkenne) wie bei @earl80
      Cannot read property 'color_options' of undefined
      zigbee.0
      2022-06-03 08:01:18.099	error	TypeError: Cannot read property 'color_options' of undefined at Object.bulbOnEvent [as onEvent] (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js:39:19) at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:44:26) at DeviceEvent.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:26:18) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:236:54) at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:18)
      zigbee.0
      2022-06-03 08:01:18.095	error	unhandled promise rejection: Cannot read property 'color_options' of undefined
      zigbee.0
      2022-06-03 08:01:18.094	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      host.iobroker
      2022-06-03 07:51:58.562	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.iobroker
      2022-06-03 07:51:58.561	error	Caught by controller[5]: at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:236:54)
      host.iobroker
      2022-06-03 07:51:58.560	error	Caught by controller[5]: at DeviceEvent.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:26:18)
      host.iobroker
      2022-06-03 07:51:58.561	error	Caught by controller[5]: at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:18)
      host.iobroker
      2022-06-03 07:51:58.560	error	Caught by controller[5]: at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:44:26)
      host.iobroker
      2022-06-03 07:51:58.559	error	Caught by controller[5]: at Object.bulbOnEvent [as onEvent] (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js:39:19)
      host.iobroker
      2022-06-03 07:51:58.559	error	Caught by controller[5]: TypeError: Cannot read property 'color_options' of undefined
      host.iobroker
      2022-06-03 07:51:58.559	error	Caught by controller[4]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      host.iobroker
      2022-06-03 07:51:58.558	error	Caught by controller[3]: at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:18)
      host.iobroker
      2022-06-03 07:51:58.558	error	Caught by controller[3]: at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:236:54)
      host.iobroker
      2022-06-03 07:51:58.558	error	Caught by controller[3]: at DeviceEvent.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:26:18)
      host.iobroker
      2022-06-03 07:51:58.557	error	Caught by controller[3]: at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:44:26)
      host.iobroker
      2022-06-03 07:51:58.552	error	Caught by controller[3]: TypeError: Cannot read property 'color_options' of undefined
      host.iobroker
      2022-06-03 07:51:58.551	error	Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      host.iobroker
      2022-06-03 07:51:58.551	error	Caught by controller[1]: at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:236:54)
      host.iobroker
      2022-06-03 07:51:58.552	error	Caught by controller[3]: at Object.bulbOnEvent [as onEvent] (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js:39:19)
      host.iobroker
      2022-06-03 07:51:58.550	error	Caught by controller[1]: at DeviceEvent.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:26:18)
      host.iobroker
      2022-06-03 07:51:58.551	error	Caught by controller[1]: at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:18)
      host.iobroker
      2022-06-03 07:51:58.550	error	Caught by controller[1]: at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:44:26)
      host.iobroker
      2022-06-03 07:51:58.549	error	Caught by controller[1]: TypeError: Cannot read property 'color_options' of undefined
      host.iobroker
      2022-06-03 07:51:58.548	error	Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      host.iobroker
      2022-06-03 07:51:58.549	error	Caught by controller[1]: at Object.bulbOnEvent [as onEvent] (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js:39:19)
      host.iobroker
      2022-06-03 07:51:58.548	error	Caught by controller[1]: at ZigbeeController.handleDeviceAnnounce
      Es handelt sich um Ikea Gu10 color spots.
      Das sind bei mir die einzigen zigbee Geräte, die durch einen Schalter stromlos geschaltet werden. Ansonsten müsste der Fehler ja immer kommen, wenn ich ein zigbee Gerät vom Strom nehme und wieder anschließe?
        arteck Developer Most Active @M-A-X last edited by arteck
        @m-a-x nein ES SIND NUR DIE IKEA BETROFFEN..und nur weil ihr die Spots vom Strom trennt
        das ist das wiedereinschalten Verhalten nach Stromlos
          kann einer was testen
          adapter stopen
          dann in den konsole
          nano /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js
          in zeile 39
          if (state.color_options !== undefined && state.color_options.execute_if_off === true) {
          ändern in
          if (state !== undefined && state.color_options.execute_if_off === true) {
          und zeile 42
          if (state.level_config !== undefined && state.level_config.execute_if_off === true) {
          in
          if (state!== undefined && state.level_config.execute_if_off === true) {
          adapter starten
            M-A-X @arteck last edited by M-A-X
            @arteck
            Muss das von unterwegs auf dem Handy über VPN machen. Hoffe es geht nichts schief 🙂
            code_textst.iobroker
            2022-06-03 08:45:08.162	info	Restart adapter system.adapter.zigbee.0 because enabled
            host.iobroker
            2022-06-03 08:45:08.162	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            host.iobroker
            2022-06-03 08:45:08.162	error	Caught by controller[1]: at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:18)
            host.iobroker
            2022-06-03 08:45:08.162	error	Caught by controller[1]: at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:236:54)
            host.iobroker
            2022-06-03 08:45:08.161	error	Caught by controller[1]: at DeviceEvent.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:26:18)
            host.iobroker
            2022-06-03 08:45:08.161	error	Caught by controller[1]: at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:44:26)
            host.iobroker
            2022-06-03 08:45:08.161	error	Caught by controller[1]: at Object.bulbOnEvent [as onEvent] (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js:42:19)
            host.iobroker
            2022-06-03 08:45:08.160	error	Caught by controller[1]: TypeError: Cannot read property 'level_config' of undefined
            host.iobroker
            2022-06-03 08:45:08.159	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            zigbee.0
            2022-06-03 08:45:07.539	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
            zigbee.0
            2022-06-03 08:45:07.537	info	terminating
            zigbee.0
            2022-06-03 08:45:07.225	info	Zigbee: disabling joining new devices.
            zigbee.0
            2022-06-03 08:45:07.036	info	cleaned everything up...
            zigbee.0
            2022-06-03 08:45:07.022	error	Cannot read property 'level_config' of undefined
            zigbee.0
            2022-06-03 08:45:07.021	error	TypeError: Cannot read property 'level_config' of undefined at Object.bulbOnEvent [as onEvent] (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js:42:19) at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:44:26) at DeviceEvent.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:26:18) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:236:54) at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:18)
            zigbee.0
            2022-06-03 08:45:07.018	error	unhandled promise rejection: Cannot read property 'level_config' of undefined
            zigbee.0
            2022-06-03 08:45:07.017	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            zigbee.0
            2022-06-03 08:45:07.009	warn	Device '0x2c1165fffe9542d9' announced itself
            web.0
            2022-06-03 08:44:58.839	info	==> Connected system.user.admin from ::ffff:192.168.9.101
            zigbee.0
            2022-06-03 08:44:34.132	info	Zigbee started
              @m-a-x du musst noch eine zeile ändern
                @arteck oh sorry. Hab ich überlesen... Handy Ansicht und so.
                Scheint wieder zu funktionieren. Meine Frau sagt auch das Licht ist an und aus gegangen 🙂
                zigbee.0
                2022-06-03 09:04:48.906	warn	Device '0x2c1165fffe7d55cd' announced itself
                zigbee.0
                2022-06-03 09:04:48.655	warn	Device '0x2c1165fffe94ad5d' announced itself
                zigbee.0
                2022-06-03 09:04:48.420	warn	Device '0x2c1165fffe85b3f6' announced itself
                zigbee.0
                2022-06-03 09:04:48.402	warn	Device '0x2c1165fffe7d68a2' announced itself
                zigbee.0
                2022-06-03 09:04:48.389	warn	Device '0x2c1165fffe8a05ce' announced itself
                zigbee.0
                2022-06-03 09:04:48.387	warn	Device '0x2c1165fffe2cd033' announced itself
                zigbee.0
                2022-06-03 09:04:48.359	warn	Device '0x2c1165fffe9542d9' announced itself
                web.0
                2022-06-03 09:04:38.708	info	==> Connected system.user.admin from ::ffff:192.168.9.101
                zigbee.0
                2022-06-03 09:04:12.555	info	Zigbee started
                  ich hab ne korektur eingestellt im converter... wird bestimmt dauern..
                  aber so ist euch erstmal geholfen
                  E David G. 2 Replies Last reply Reply Quote 1
                    Einstein67 @arteck last edited by
                    @arteck Funktioniert!!
                    Vielen Dank!
                    • David G.
                      David G. @arteck last edited by David G.
                      @arteck
                      Müssen wir die Zeilen jetzt bei jedem Update des Adapters ändern, bis das im Converter gefixt wurde?
                      Danke für die schnelle Hilfe.
                        arteck Developer Most Active @David G. last edited by
                        @david-g wenn du von Git installierst dann ja..
                          korrektur ist ab sofort auf GIT verfügbar
                          M E 2 Replies Last reply Reply Quote 2
                            Martin-72 @arteck last edited by
                            @arteck Ich habe das Problem auch noch. Ich habe den Adapter aber über die Adapterverwaltung vom ioBroker installiert:
                            Gibt es schon Hochrechnungen, wann die Fehlerbehebung auch dort ankommt?
                            Oder soll ich den weiter oben beschriebenen Weg wählen? Muss / (Wie) Kann ich die Adapter sichern und wieder einspielen, um nicht alles neu anlernen zu müssen...?
                            Vielen Dank
                            Martin
                            • amg_666
                              amg_666 @Martin-72 last edited by
                              @martin-72 Du kannst den über github installieren. In der Adminoberfläche auf die "Katze" tippen und da dann zigbee eingeben und den Adapter installieren. Das ist dasselbe wie ein Versionsupdate über die Adapterverwaltung, nur dass es halt "Beta" ist und noch nicht "offiziell", sichern musst du da eigentlich nichts, ist nur ne neue Version.
                                Martin-72 @amg_666 last edited by
                                Vielen Dank
                                Liebe Grüße
                                Martin
                                  ewf04214 @arteck last edited by ewf04214
                                  @arteck Das Problem besteht seit geraumer Zeit wieder. Was genau meinst du mit Bug im Converter, kommt der Converter von dir, oder bindest du etwas externes ein? Dann müsste man den Fehler ja dort melden.
                                  Guten Rutsch
                                    dimaiv @ewf04214 last edited by
                                    @ewf04214
                                    Aktuelle Stand: vor 3 Stunden über Git installiert, alles mögliche probiert, KENE FEHLER !
                                    Guten Rutsch!
                                      1.9.6 ist unterwegs
                                        @arteck danke, auf den ersten Blick scheints zu funktionieren, Geräte Annoncen sich, und der Adapter bleibt online.
                                        2093
