    3. Einsteigerfragen
    4. Zigbee Adapter stürzt ständig ab
      klaris @Thomas Braun last edited by
      pi@raspberrypi:~ $ iobroker update -i
      Used repository: stable
      Adapter    "admin"        : 5.3.8    , installed 5.3.8
      Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
      Adapter    "backitup"     : 2.4.6    , installed 2.4.6
      Adapter    "countdown"    : 1.2.5    , installed 1.2.5
      Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
      Adapter    "discovery"    : 3.0.3    , installed 3.0.3
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "iot"          : 1.11.4   , installed 1.11.4
      Adapter    "javascript"   : 5.7.0    , installed 5.7.0
      Adapter    "meross"       : 1.10.5   , installed 1.10.5
      Adapter    "ping"         : 1.5.3    , installed 1.5.3
      Adapter    "shelly"       : 5.3.2    , installed 5.3.2
      Adapter    "simple-api"   : 2.6.5    , installed 2.7.0
      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
      Adapter    "telegram"     : 1.12.6   , installed 1.12.6
      Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
      Adapter    "vis"          : 1.4.15   , installed 1.4.15
      Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
      Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
      Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.2.2
      Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
        Thomas Braun Most Active @klaris last edited by
        @klaris
        iobroker upload all
        Und starte den Browser mal neu. Zumindest die Admin-Seite nochmal richtig neuladen.
          @thomas-braun 👍 läuft
            klaris @klaris last edited by klaris
            @klaris heute morgen ..leider das gleiche ...
            daswetter.0
            	7089	2022-06-03 09:00:35.846	info	Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            daswetter.0
            	7089	2022-06-03 09:00:29.165	info	still wrong data structure from server received! repaired...
            daswetter.0
            	7089	2022-06-03 09:00:03.641	info	starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v14.19.3, js-controller: 4.0.23
            host.raspberrypi
            		2022-06-03 09:00:00.150	info	instance system.adapter.daswetter.0 started with pid 7089
            host.raspberrypi
            		2022-06-03 08:59:39.971	warn	Do not restart adapter system.adapter.zigbee.0 because restart loop detected
            host.raspberrypi
            		2022-06-03 08:59:39.970	info	Restart adapter system.adapter.zigbee.0 because enabled
            host.raspberrypi
            		2022-06-03 08:59:39.969	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            host.raspberrypi
            		2022-06-03 08:59:39.968	info	Restart adapter system.adapter.zigbee.0 because enabled
            host.raspberrypi
            		2022-06-03 08:59:39.967	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            host.raspberrypi
            		2022-06-03 08:59:39.967	error	Caught by controller[3]: at /opt/iobroker/node_modules/@serialport/stream/lib/index.js:242:12
            host.raspberrypi
            		2022-06-03 08:59:39.967	error	Caught by controller[3]: at SerialPort._error (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:198:14)
            host.raspberrypi
            		2022-06-03 08:59:39.966	error	Caught by controller[3]: at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:182:28)
            host.raspberrypi
            		2022-06-03 08:59:39.966	error	Caught by controller[3]: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
            host.raspberrypi
            		2022-06-03 08:59:39.965	error	Caught by controller[2]: at /opt/iobroker/node_modules/@serialport/stream/lib/index.js:242:12
            host.raspberrypi
            		2022-06-03 08:59:39.965	error	Caught by controller[2]: at SerialPort._error (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:198:14)
            host.raspberrypi
            		2022-06-03 08:59:39.965	error	Caught by controller[2]: at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:182:28)
            host.raspberrypi
            		2022-06-03 08:59:39.964	error	Caught by controller[2]: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
            host.raspberrypi
            		2022-06-03 08:59:39.964	error	Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            host.raspberrypi
            		2022-06-03 08:59:39.963	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            zigbee.0
            	7060	2022-06-03 08:59:39.207	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
            zigbee.0
            	7060	2022-06-03 08:59:39.204	info	terminating
            zigbee.0
            	7060	2022-06-03 08:59:39.195	info	Zigbee: disabling joining new devices.
            zigbee.0
            	7060	2022-06-03 08:59:39.064	info	cleaned everything up...
            zigbee.0
            	7060	2022-06-03 08:59:39.050	error	Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
            zigbee.0
            	7060	2022-06-03 08:59:39.050	error	Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0' at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:182:28) at SerialPort._error (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:198:14) at /opt/iobroker/node_modules/@serialport/stream/lib/index.js:242:12
            zigbee.0
            	7060	2022-06-03 08:59:39.048	error	unhandled promise rejection: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
            zigbee.0
            	7060	2022-06-03 08:59:39.047	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            web.0
            	2689	2022-06-03 08:59:33.060	info	<== Disconnect system.user.admin from ::ffff:192.168.178.40
            zigbee.0
            	7060	2022-06-03 08:59:19.680	error	Error herdsman start
            zigbee.0
            	7060	2022-06-03 08:59:19.679	error	Failed to start Zigbee
            zigbee.0
            	7060	2022-06-03 08:59:19.676	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'"
            zigbee.0
            	7060	2022-06-03 08:59:19.393	info	Installed Version: iobroker.zigbee@1.7.5
            zigbee.0
            	7060	2022-06-03 08:59:19.367	info	Starting Zigbee npm ...
            zigbee.0
            	7060	2022-06-03 08:59:19.365	info	Try to reconnect. 1 attempts left
            zigbee.0
            	7060	2022-06-03 08:59:09.371	info	Installed Version: iobroker.zigbee@1.7.5
            zigbee.0
            	7060	2022-06-03 08:59:09.359	error	Error herdsman start
            zigbee.0
            	7060	2022-06-03 08:59:09.357	error	Failed to start Zigbee
            zigbee.0
            	7060	2022-06-03 08:59:09.355	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'"
            zigbee.0
            	7060	2022-06-03 08:59:08.095	info	Starting Zigbee npm ...
            zigbee.0
            	7060	2022-06-03 08:59:08.090	info	delete old Backup files. keep only last 10
            zigbee.0
            	7060	2022-06-03 08:59:07.908	info	starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23
            host.raspberrypi
            		2022-06-03 08:59:00.487	info	instance system.adapter.zigbee.0 started with pid 7060
            host.raspberrypi
            		2022-06-03 08:59:00.484	info	instance system.adapter.zigbee.0 started with pid 7060
            host.raspberrypi
            		2022-06-03 08:59:00.173	info	"system.adapter.zigbee.0" enabled
            host.raspberrypi
            		2022-06-03 08:58:59.002	info	instance system.adapter.zigbee.0 terminated with code null ()
            host.raspberrypi
            		2022-06-03 08:58:59.001	warn	instance system.adapter.zigbee.0 terminated due to SIGTERM
            host.raspberrypi
            		2022-06-03 08:58:58.900	info	stopInstance system.adapter.zigbee.0 killing pid 7053
            host.raspberrypi
            		2022-06-03 08:58:57.898	info	stopInstance system.adapter.zigbee.0 send kill signal
            host.raspberrypi
            		2022-06-03 08:58:57.822	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
            host.raspberrypi
            		2022-06-03 08:58:57.821	info	"system.adapter.zigbee.0" disabled
            host.raspberrypi
            		2022-06-03 08:58:57.148	info	stopInstance system.adapter.zigbee.0 send kill signal
            host.raspberrypi
            		2022-06-03 08:58:57.075	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
            host.raspberrypi
            		2022-06-03 08:58:56.777	info	instance system.adapter.zigbee.0 started with pid 7053
            host.raspberrypi
            		2022-06-03 08:58:54.713	info	instance system.adapter.zigbee.0 terminated with code null ()
            host.raspberrypi
            		2022-06-03 08:58:54.712	warn	instance system.adapter.zigbee.0 terminated due to SIGTERM
            host.raspberrypi
            		2022-06-03 08:58:54.607	info	stopInstance system.adapter.zigbee.0 killing pid 7046
            host.raspberrypi
            		2022-06-03 08:58:53.605	info	stopInstance system.adapter.zigbee.0 send kill signal
            host.raspberrypi
            		2022-06-03 08:58:53.592	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
            host.raspberrypi
            		2022-06-03 08:58:52.424	info	instance system.adapter.zigbee.0 started with pid 7046
            host.raspberrypi
            		2022-06-03 08:58:26.981	info	Restart adapter system.adapter.zigbee.0 because enabled
            host.raspberrypi
            		2022-06-03 08:58:26.980	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            host.raspberrypi
            		2022-06-03 08:58:26.979	error	Caught by controller[0]: at /opt/iobroker/node_modules/@serialport/stream/lib/index.js:242:12
            host.raspberrypi
            		2022-06-03 08:58:26.979	error	Caught by controller[0]: at SerialPort._error (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:198:14)
            host.raspberrypi
            		2022-06-03 08:58:26.978	error	Caught by controller[0]: at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:182:28)
            host.raspberrypi
            		2022-06-03 08:58:26.977	error	Caught by controller[0]: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
            host.raspberrypi
            		2022-06-03 08:58:26.976	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            zigbee.0
            	7029	2022-06-03 08:58:26.300	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
            zigbee.0
            	7029	2022-06-03 08:58:26.297	info	terminating
            zigbee.0
            	7029	2022-06-03 08:58:26.278	info	Zigbee: disabling joining new devices.
            zigbee.0
            	7029	2022-06-03 08:58:26.116	info	cleaned everything up...
            zigbee.0
            	7029	2022-06-03 08:58:26.097	error	Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
            zigbee.0
            	7029	2022-06-03 08:58:26.096	error	Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0' at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:182:28) at SerialPort._error (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:198:14) at /opt/iobroker/node_modules/@serialport/stream/lib/index.js:242:12
            zigbee.0
            	7029	2022-06-03 08:58:26.093	error	unhandled promise rejection: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
            zigbee.0
            	7029	2022-06-03 08:58:26.091	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            host.raspberrypi
            		2022-06-03 08:58:13.379	error	instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
            daswetter.0
            	7013	2022-06-03 08:58:13.348	error	Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_1.Hour_3.symbol": Connection is closed.
            daswetter.0
            	7013	2022-06-03 08:58:13.345	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours2.Location_1.Day_1.current.temp: Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_1.current.temp": Connection is closed.]
            daswetter.0
            	7013	2022-06-03 08:58:13.343	error	Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_1.current.temp": Connection is closed.
            daswetter.0
            	7013	2022-06-03 08:58:13.340	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours2.Location_1.Day_1.Hour_3.temp: Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_1.Hour_3.temp": Connection is closed.]
            daswetter.0
            	7013	2022-06-03 08:58:13.338	error	Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_1.Hour_3.temp": Connection is closed.
            daswetter.0
            	7013	2022-06-03 08:58:13.336	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours2.Location_1.Day_1.current.hour: Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_1.current.hour": Connection is closed.]
            daswetter.0
            	7013	2022-06-03 08:58:13.333	error	Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_1.current.hour": Connection is closed.
            daswetter.0
            	7013	2022-06-03 08:58:13.329	error	exception in await insertIntoList [Error: DB closed]
            daswetter.0
            	7013	2022-06-03 08:58:13.325	warn	get state error: Connection is closed.
            daswetter.0
            	7013	2022-06-03 08:58:12.808	warn	Terminated (UNKNOWN_ERROR): Without reason
            daswetter.0
            	7013	2022-06-03 08:58:12.805	error	force terminate
            daswetter.0
            	7013	2022-06-03 08:58:12.738	info	still wrong data structure from server received! repaired...
            zigbee.0
            	7029	2022-06-03 08:58:06.750	error	Error herdsman start
            zigbee.0
            	7029	2022-06-03 08:58:06.749	error	Failed to start Zigbee
            zigbee.0
            	7029	2022-06-03 08:58:06.745	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'"
            zigbee.0
            	7029	2022-06-03 08:58:06.424	info	Installed Version: iobroker.zigbee@1.7.5
            zigbee.0
            	7029	2022-06-03 08:58:06.386	info	Starting Zigbee npm ...
            zigbee.0
            	7029	2022-06-03 08:58:06.384	info	Try to reconnect. 1 attempts left
            zigbee.0
            	7029	2022-06-03 08:57:56.384	info	Installed Version: iobroker.zigbee@1.7.5
            zigbee.0
            	7029	2022-06-03 08:57:56.378	error	Error herdsman start
            zigbee.0
            	7029	2022-06-03 08:57:56.377	error	Failed to start Zigbee
            zigbee.0
            	7029	2022-06-03 08:57:56.375	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'"
            zigbee.0
            	7029	2022-06-03 08:57:54.880	info	Starting Zigbee npm ...
            zigbee.0
            	7029	2022-06-03 08:57:54.873	info	delete old Backup files. keep only last 10
            zigbee.0
            	7029	2022-06-03 08:57:54.612	info	starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23
            host.raspberrypi
            		2022-06-03 08:57:44.648	info	instance system.adapter.zigbee.0 started with pid 7029
            daswetter.0
            	7013	2022-06-03 08:57:12.755	info	starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v14.19.3, js-controller: 4.0.23
            web.0
            	2689	2022-06-03 08:57:09.172	info	==> Connected system.user.admin from ::ffff:192.168.178.40
            iot.2
            	983	2022-06-03 08:57:07.961	info	Connection changed: connect
            host.raspberrypi
            		2022-06-03 08:57:06.801	info	instance system.adapter.daswetter.0 started with pid 7013
            host.raspberrypi
            		2022-06-03 08:57:06.681	info	Restart adapter system.adapter.zigbee.0 because enabled
            host.raspberrypi
            		2022-06-03 08:57:06.674	info	instance system.adapter.zigbee.0 terminated with code NaN ()
            host.raspberrypi
            arteck Thomas Braun 2 Replies Last reply Reply Quote 0
              arteck Developer Most Active @klaris last edited by
              @klaris ist halt conbee.. firmware mal updaten vielleicht
                @klaris
                dmesg -wT
                anschauen, mit dem Stick hantieren (Ausstöpseln, etwas warten, Einstöpseln)
                  klaris @arteck last edited by klaris
                  @arteck die deconz software hatte ich am anfang instaliert und dann von iobroker komplett geloscht und zigbee adapter instaliert finde ich besser ..
                  kann ich trotzdem die Firmware von ConBee II unter iobroker aktualisieren ?
                  arteck mickym 2 Replies Last reply Reply Quote 0
                    @klaris kein plan wie das mit dem conbee läuft..
                    • mickym
                      mickym Most Active @klaris last edited by mickym
                      @klaris Du kannst die Firmware mit dem GCFlasher aktualisieren.
                      https://github.com/dresden-elektronik/deconz-rest-plugin/wiki/Update-deCONZ-manually#update-in-windows
                      Das geht dann auch ohne die deconz Software. Inzwischen soll ja der conbee vom Zigbee Adapter lt. Beschreibung vollumfänglich unterstützt werden. Falls Du jedoch Alternativen suchst, kann ich Dir das zigbee2mqtt mit dem mqtt-Adapter wärmstens empfehlen, funktioniert bei mir nun seit ein paar Monaten sehr zuverlässig. Lediglich die Karte wird bei mir nicht angezeigt. Dafür gibts aber teilweise sehr nützliche Einstellungen, wie das Einschaltverhalten von Geräten, die Du anscheinend bei dem Zigbee adapter nur über SendTo Befehle realisieren kannst. Es gibt auch einen Client als GUI für das zigbee2mqtt, das auch die Kacheldarstellung verwendet.
                      Ich habe die 26700700 drauf, mit der funktioniert es soweit alles gut. Habe gesehen, dass es seit 15.Mai sogar noch eine neue Version gibt.
                      Hab gerade mal die neueste Version (also 26780700) drauf gemacht - war in ein paar Sekunden erledigt:
                      GCFFlasher -d COM3 -t 60 -f ..\deCONZ_ConBeeII_0x26780700.bin.GCF
                      GCFFlasher V3_17 (c) dresden elektronik ingenieurtechnik gmbh
                      Reboot device COM3 (ConBee II)
                      deCONZ firmware version 26700700
                      R21B18 Bootloader
                      Vers: 2.07
                      build: Jun 17 2019
                      flashing 163230 bytes: |==============================|
                      verify: .
                      SUCCESS
                      Wait 10 seconds until application starts
                      Bei der Kartendarstellung schweben die am Koordinator selbst verbundenen Geräte noch im freien Raum, ansonsten schaut alles gut aus:
                      Die rot eingezeichneten Linien - fehlen halt:
                        klaris @mickym last edited by klaris
                        @mickym wenn man(n) weiß wie es geht ….
                        Ich habe wieder aus Verzweiflung die deconz Software installiert auf iobroker und den zigbee Adapter deaktiviert … Teste die Stabilität der zigbee Geräte …. Aber eine kleine Anleitung zum Update des ConBee sticks würde mich schon interessieren…habe die Version 26700700 .
                        Ehrlich gesagt gefällt mir der zigbee Adapter sehr gut leider läuft er nicht stabil. Ständig Probleme mit den Com Port ….und der Adapter Stürzt zweimal am Tag ab…
                        Vielen Dank für deine Hinweise
                        • mickym
                          @klaris Nun den Link zum Flashen des Sticks habe ich Dir doch im vorherigen Post beschrieben.
                          Auf welchem System läuft denn Dein iobroker?
                          Und wie gesagt, mit dem zigbee2mqtt musst Du halt über mqtt kommunizieren. Für mich hat die Umstellung ca. 1-2 Tage benötigt, aber ich bin sehr zufrieden. Ich hatte lediglich eine Fehlfunktion und im Vergleich zum zigbee Adapter finde ich persönlich die Stabilität um einiges besser. Ich habe damals aber eigentlich nur umgestellt, weil damals der conbee nicht vollständig unterstützt wurde und habe mich deshalb nach Alternativen umgeschaut und was ich von dem deconz gesehen habe, das hat mir halt gar nicht gefallen.
                            @mickym raspberry pi 3+
                            Ja Deconz ist sehr spartanisch aufgebaut
                            • mickym
                              @klaris Wie gesagt das Flashen habe ich Dir ja schon gepostet und falls Du auf mqtt und zigbee umsteigen willst, dann kann ich Dir mit den Links schon etwas aus meiner Erfahrung helfen.
                              • mickym
                                @klaris Wie gesagt, falls du es mal probieren willst, das zigbee2mqtt - brauchst halt den mqtt Adapter und einen mqtt Broker.
                                Eine grafische Oberfläche bringt das Tool auch mit:
                                so dass es auch in Deine VIS (als iFrame) oder bei mir in das NodeRed Dashboard einbinden kannst.
                                Ich würde halt an deiner Stelle ein Image von Deiner SD Karte ziehen und das System parallel aufbauen, damit Du wenn Du nicht dazu kommst, halt Dein jetziges System am Laufen hast und parallel das Neue ans Laufen bringst.
                                  @mickym Das sieht ja vielversprechend aus…. Ja so hab ich es mir auch gedacht dass man zwei Parallelsysteme startet für alle Fälle …Aber schade dass die einfache Installation zigbee Adapter und ConBee so anfällig ist….
                                  • mickym
                                    @klaris Gut dann musst halt auf deinem Parallelsystem unbedingt halt erst mal alles was mit zigbee zu tun hat runter schmeissen und dann kannst Du nach der Anleitung installieren:
                                    https://www.zigbee2mqtt.io/guide/installation/01_linux.html#determine-location-of-the-adapter-and-checking-user-permissions
                                    Anschliessend brauchst Du halt noch einen mqtt-Broker, entweder extern oder intern, also den mqtt-Adapter, damit das zigbee2mqtt da reinschreiben kann.
                                    Du brauchst allerdings ein Device - was Du in Deiner Produmgebung entbehren kannst, da Du alle Geräte neu pairen musst. Deshalb erst mal mit einem - bis alles soweit funktioniert, dass Du zufrieden bist. Ich habe es irgendwie nicht geschafft die Werte im zigbee2mqtt und die des zigbee Adapter so identisch einzustellen, dass das funktioniert hat.
                                      @mickym danke werde mich neu einlesen ....die deconz software mit zigbee läuft seit tagen sehr stabil ....
                                      1.2k
                                      5227
