Zigbee Adapter stürzt ständig ab
iobroker upload allUnd starte den Browser mal neu. Zumindest die Admin-Seite nochmal richtig neuladen.
 läuft -
@klaris heute morgen ..leider das gleiche ...
daswetter.0 7089 2022-06-03 09:00:35.846 info Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment daswetter.0 7089 2022-06-03 09:00:29.165 info still wrong data structure from server received! repaired... daswetter.0 7089 2022-06-03 09:00:03.641 info starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v14.19.3, js-controller: 4.0.23 host.raspberrypi 2022-06-03 09:00:00.150 info instance system.adapter.daswetter.0 started with pid 7089 host.raspberrypi 2022-06-03 08:59:39.971 warn Do not restart adapter system.adapter.zigbee.0 because restart loop detected host.raspberrypi 2022-06-03 08:59:39.970 info Restart adapter system.adapter.zigbee.0 because enabled host.raspberrypi 2022-06-03 08:59:39.969 error instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION) host.raspberrypi 2022-06-03 08:59:39.968 info Restart adapter system.adapter.zigbee.0 because enabled host.raspberrypi 2022-06-03 08:59:39.967 error instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION) host.raspberrypi 2022-06-03 08:59:39.967 error Caught by controller[3]: at /opt/iobroker/node_modules/@serialport/stream/lib/index.js:242:12 host.raspberrypi 2022-06-03 08:59:39.967 error Caught by controller[3]: at SerialPort._error (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:198:14) host.raspberrypi 2022-06-03 08:59:39.966 error Caught by controller[3]: at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:182:28) host.raspberrypi 2022-06-03 08:59:39.966 error Caught by controller[3]: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0' host.raspberrypi 2022-06-03 08:59:39.965 error Caught by controller[2]: at /opt/iobroker/node_modules/@serialport/stream/lib/index.js:242:12 host.raspberrypi 2022-06-03 08:59:39.965 error Caught by controller[2]: at SerialPort._error (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:198:14) host.raspberrypi 2022-06-03 08:59:39.965 error Caught by controller[2]: at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:182:28) host.raspberrypi 2022-06-03 08:59:39.964 error Caught by controller[2]: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0' host.raspberrypi 2022-06-03 08:59:39.964 error Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: host.raspberrypi 2022-06-03 08:59:39.963 error Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: zigbee.0 7060 2022-06-03 08:59:39.207 warn Terminated (UNCAUGHT_EXCEPTION): Without reason zigbee.0 7060 2022-06-03 08:59:39.204 info terminating zigbee.0 7060 2022-06-03 08:59:39.195 info Zigbee: disabling joining new devices. zigbee.0 7060 2022-06-03 08:59:39.064 info cleaned everything up... zigbee.0 7060 2022-06-03 08:59:39.050 error Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0' zigbee.0 7060 2022-06-03 08:59:39.050 error Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0' at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:182:28) at SerialPort._error (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:198:14) at /opt/iobroker/node_modules/@serialport/stream/lib/index.js:242:12 zigbee.0 7060 2022-06-03 08:59:39.048 error unhandled promise rejection: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0' zigbee.0 7060 2022-06-03 08:59:39.047 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). web.0 2689 2022-06-03 08:59:33.060 info <== Disconnect system.user.admin from ::ffff:192.168.178.40 zigbee.0 7060 2022-06-03 08:59:19.680 error Error herdsman start zigbee.0 7060 2022-06-03 08:59:19.679 error Failed to start Zigbee zigbee.0 7060 2022-06-03 08:59:19.676 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'" zigbee.0 7060 2022-06-03 08:59:19.393 info Installed Version: iobroker.zigbee@1.7.5 zigbee.0 7060 2022-06-03 08:59:19.367 info Starting Zigbee npm ... zigbee.0 7060 2022-06-03 08:59:19.365 info Try to reconnect. 1 attempts left zigbee.0 7060 2022-06-03 08:59:09.371 info Installed Version: iobroker.zigbee@1.7.5 zigbee.0 7060 2022-06-03 08:59:09.359 error Error herdsman start zigbee.0 7060 2022-06-03 08:59:09.357 error Failed to start Zigbee zigbee.0 7060 2022-06-03 08:59:09.355 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'" zigbee.0 7060 2022-06-03 08:59:08.095 info Starting Zigbee npm ... zigbee.0 7060 2022-06-03 08:59:08.090 info delete old Backup files. keep only last 10 zigbee.0 7060 2022-06-03 08:59:07.908 info starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23 host.raspberrypi 2022-06-03 08:59:00.487 info instance system.adapter.zigbee.0 started with pid 7060 host.raspberrypi 2022-06-03 08:59:00.484 info instance system.adapter.zigbee.0 started with pid 7060 host.raspberrypi 2022-06-03 08:59:00.173 info "system.adapter.zigbee.0" enabled host.raspberrypi 2022-06-03 08:58:59.002 info instance system.adapter.zigbee.0 terminated with code null () host.raspberrypi 2022-06-03 08:58:59.001 warn instance system.adapter.zigbee.0 terminated due to SIGTERM host.raspberrypi 2022-06-03 08:58:58.900 info stopInstance system.adapter.zigbee.0 killing pid 7053 host.raspberrypi 2022-06-03 08:58:57.898 info stopInstance system.adapter.zigbee.0 send kill signal host.raspberrypi 2022-06-03 08:58:57.822 info stopInstance system.adapter.zigbee.0 (force=false, process=true) host.raspberrypi 2022-06-03 08:58:57.821 info "system.adapter.zigbee.0" disabled host.raspberrypi 2022-06-03 08:58:57.148 info stopInstance system.adapter.zigbee.0 send kill signal host.raspberrypi 2022-06-03 08:58:57.075 info stopInstance system.adapter.zigbee.0 (force=false, process=true) host.raspberrypi 2022-06-03 08:58:56.777 info instance system.adapter.zigbee.0 started with pid 7053 host.raspberrypi 2022-06-03 08:58:54.713 info instance system.adapter.zigbee.0 terminated with code null () host.raspberrypi 2022-06-03 08:58:54.712 warn instance system.adapter.zigbee.0 terminated due to SIGTERM host.raspberrypi 2022-06-03 08:58:54.607 info stopInstance system.adapter.zigbee.0 killing pid 7046 host.raspberrypi 2022-06-03 08:58:53.605 info stopInstance system.adapter.zigbee.0 send kill signal host.raspberrypi 2022-06-03 08:58:53.592 info stopInstance system.adapter.zigbee.0 (force=false, process=true) host.raspberrypi 2022-06-03 08:58:52.424 info instance system.adapter.zigbee.0 started with pid 7046 host.raspberrypi 2022-06-03 08:58:26.981 info Restart adapter system.adapter.zigbee.0 because enabled host.raspberrypi 2022-06-03 08:58:26.980 error instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION) host.raspberrypi 2022-06-03 08:58:26.979 error Caught by controller[0]: at /opt/iobroker/node_modules/@serialport/stream/lib/index.js:242:12 host.raspberrypi 2022-06-03 08:58:26.979 error Caught by controller[0]: at SerialPort._error (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:198:14) host.raspberrypi 2022-06-03 08:58:26.978 error Caught by controller[0]: at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:182:28) host.raspberrypi 2022-06-03 08:58:26.977 error Caught by controller[0]: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0' host.raspberrypi 2022-06-03 08:58:26.976 error Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: zigbee.0 7029 2022-06-03 08:58:26.300 warn Terminated (UNCAUGHT_EXCEPTION): Without reason zigbee.0 7029 2022-06-03 08:58:26.297 info terminating zigbee.0 7029 2022-06-03 08:58:26.278 info Zigbee: disabling joining new devices. zigbee.0 7029 2022-06-03 08:58:26.116 info cleaned everything up... zigbee.0 7029 2022-06-03 08:58:26.097 error Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0' zigbee.0 7029 2022-06-03 08:58:26.096 error Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0' at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:182:28) at SerialPort._error (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:198:14) at /opt/iobroker/node_modules/@serialport/stream/lib/index.js:242:12 zigbee.0 7029 2022-06-03 08:58:26.093 error unhandled promise rejection: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0' zigbee.0 7029 2022-06-03 08:58:26.091 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). host.raspberrypi 2022-06-03 08:58:13.379 error instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR) daswetter.0 7013 2022-06-03 08:58:13.348 error Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_1.Hour_3.symbol": Connection is closed. daswetter.0 7013 2022-06-03 08:58:13.345 error exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours2.Location_1.Day_1.current.temp: Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_1.current.temp": Connection is closed.] daswetter.0 7013 2022-06-03 08:58:13.343 error Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_1.current.temp": Connection is closed. daswetter.0 7013 2022-06-03 08:58:13.340 error exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours2.Location_1.Day_1.Hour_3.temp: Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_1.Hour_3.temp": Connection is closed.] daswetter.0 7013 2022-06-03 08:58:13.338 error Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_1.Hour_3.temp": Connection is closed. daswetter.0 7013 2022-06-03 08:58:13.336 error exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours2.Location_1.Day_1.current.hour: Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_1.current.hour": Connection is closed.] daswetter.0 7013 2022-06-03 08:58:13.333 error Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_1.current.hour": Connection is closed. daswetter.0 7013 2022-06-03 08:58:13.329 error exception in await insertIntoList [Error: DB closed] daswetter.0 7013 2022-06-03 08:58:13.325 warn get state error: Connection is closed. daswetter.0 7013 2022-06-03 08:58:12.808 warn Terminated (UNKNOWN_ERROR): Without reason daswetter.0 7013 2022-06-03 08:58:12.805 error force terminate daswetter.0 7013 2022-06-03 08:58:12.738 info still wrong data structure from server received! repaired... zigbee.0 7029 2022-06-03 08:58:06.750 error Error herdsman start zigbee.0 7029 2022-06-03 08:58:06.749 error Failed to start Zigbee zigbee.0 7029 2022-06-03 08:58:06.745 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'" zigbee.0 7029 2022-06-03 08:58:06.424 info Installed Version: iobroker.zigbee@1.7.5 zigbee.0 7029 2022-06-03 08:58:06.386 info Starting Zigbee npm ... zigbee.0 7029 2022-06-03 08:58:06.384 info Try to reconnect. 1 attempts left zigbee.0 7029 2022-06-03 08:57:56.384 info Installed Version: iobroker.zigbee@1.7.5 zigbee.0 7029 2022-06-03 08:57:56.378 error Error herdsman start zigbee.0 7029 2022-06-03 08:57:56.377 error Failed to start Zigbee zigbee.0 7029 2022-06-03 08:57:56.375 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'" zigbee.0 7029 2022-06-03 08:57:54.880 info Starting Zigbee npm ... zigbee.0 7029 2022-06-03 08:57:54.873 info delete old Backup files. keep only last 10 zigbee.0 7029 2022-06-03 08:57:54.612 info starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23 host.raspberrypi 2022-06-03 08:57:44.648 info instance system.adapter.zigbee.0 started with pid 7029 daswetter.0 7013 2022-06-03 08:57:12.755 info starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v14.19.3, js-controller: 4.0.23 web.0 2689 2022-06-03 08:57:09.172 info ==> Connected system.user.admin from ::ffff:192.168.178.40 iot.2 983 2022-06-03 08:57:07.961 info Connection changed: connect host.raspberrypi 2022-06-03 08:57:06.801 info instance system.adapter.daswetter.0 started with pid 7013 host.raspberrypi 2022-06-03 08:57:06.681 info Restart adapter system.adapter.zigbee.0 because enabled host.raspberrypi 2022-06-03 08:57:06.674 info instance system.adapter.zigbee.0 terminated with code NaN () host.raspberrypi -
@klaris ist halt conbee.. firmware mal updaten vielleicht
@arteck die deconz software hatte ich am anfang instaliert und dann von iobroker komplett geloscht und zigbee adapter instaliert finde ich besser ..
kann ich trotzdem die Firmware von ConBee II unter iobroker aktualisieren ? -
@klaris kein plan wie das mit dem conbee läuft..
@klaris Du kannst die Firmware mit dem GCFlasher aktualisieren.
Das geht dann auch ohne die deconz Software. Inzwischen soll ja der conbee vom Zigbee Adapter lt. Beschreibung vollumfänglich unterstützt werden. Falls Du jedoch Alternativen suchst, kann ich Dir das zigbee2mqtt mit dem mqtt-Adapter wärmstens empfehlen, funktioniert bei mir nun seit ein paar Monaten sehr zuverlässig. Lediglich die Karte wird bei mir nicht angezeigt. Dafür gibts aber teilweise sehr nützliche Einstellungen, wie das Einschaltverhalten von Geräten, die Du anscheinend bei dem Zigbee adapter nur über SendTo Befehle realisieren kannst. Es gibt auch einen Client als GUI für das zigbee2mqtt, das auch die Kacheldarstellung verwendet.
Ich habe die 26700700 drauf, mit der funktioniert es soweit alles gut. Habe gesehen, dass es seit 15.Mai sogar noch eine neue Version gibt.
Hab gerade mal die neueste Version (also 26780700) drauf gemacht - war in ein paar Sekunden erledigt:
GCFFlasher -d COM3 -t 60 -f ..\deCONZ_ConBeeII_0x26780700.bin.GCF GCFFlasher V3_17 (c) dresden elektronik ingenieurtechnik gmbh Reboot device COM3 (ConBee II) deCONZ firmware version 26700700 R21B18 Bootloader Vers: 2.07 build: Jun 17 2019 flashing 163230 bytes: |==============================| verify: . SUCCESS Wait 10 seconds until application startsBei der Kartendarstellung schweben die am Koordinator selbst verbundenen Geräte noch im freien Raum, ansonsten schaut alles gut aus:
Die rot eingezeichneten Linien - fehlen halt:
@mickym wenn man(n) weiß wie es geht ….
Ich habe wieder aus Verzweiflung die deconz Software installiert auf iobroker und den zigbee Adapter deaktiviert … Teste die Stabilität der zigbee Geräte …. Aber eine kleine Anleitung zum Update des ConBee sticks würde mich schon interessieren…habe die Version 26700700 .
Ehrlich gesagt gefällt mir der zigbee Adapter sehr gut leider läuft er nicht stabil. Ständig Probleme mit den Com Port ….und der Adapter Stürzt zweimal am Tag ab…
Vielen Dank für deine Hinweise -
@klaris Nun den Link zum Flashen des Sticks habe ich Dir doch im vorherigen Post beschrieben.
Auf welchem System läuft denn Dein iobroker?
Und wie gesagt, mit dem zigbee2mqtt musst Du halt über mqtt kommunizieren. Für mich hat die Umstellung ca. 1-2 Tage benötigt, aber ich bin sehr zufrieden. Ich hatte lediglich eine Fehlfunktion und im Vergleich zum zigbee Adapter finde ich persönlich die Stabilität um einiges besser. Ich habe damals aber eigentlich nur umgestellt, weil damals der conbee nicht vollständig unterstützt wurde und habe mich deshalb nach Alternativen umgeschaut und was ich von dem deconz gesehen habe, das hat mir halt gar nicht gefallen.
@mickym raspberry pi 3+
Ja Deconz ist sehr spartanisch aufgebaut -
@klaris Wie gesagt das Flashen habe ich Dir ja schon gepostet und falls Du auf mqtt und zigbee umsteigen willst, dann kann ich Dir mit den Links schon etwas aus meiner Erfahrung helfen.
@klaris Wie gesagt, falls du es mal probieren willst, das zigbee2mqtt - brauchst halt den mqtt Adapter und einen mqtt Broker.
Eine grafische Oberfläche bringt das Tool auch mit:
so dass es auch in Deine VIS (als iFrame) oder bei mir in das NodeRed Dashboard einbinden kannst.
Ich würde halt an deiner Stelle ein Image von Deiner SD Karte ziehen und das System parallel aufbauen, damit Du wenn Du nicht dazu kommst, halt Dein jetziges System am Laufen hast und parallel das Neue ans Laufen bringst.
@mickym Das sieht ja vielversprechend aus…. Ja so hab ich es mir auch gedacht dass man zwei Parallelsysteme startet für alle Fälle …Aber schade dass die einfache Installation zigbee Adapter und ConBee so anfällig ist….
@klaris Gut dann musst halt auf deinem Parallelsystem unbedingt halt erst mal alles was mit zigbee zu tun hat runter schmeissen und dann kannst Du nach der Anleitung installieren:
Anschliessend brauchst Du halt noch einen mqtt-Broker, entweder extern oder intern, also den mqtt-Adapter, damit das zigbee2mqtt da reinschreiben kann.
Du brauchst allerdings ein Device - was Du in Deiner Produmgebung entbehren kannst, da Du alle Geräte neu pairen musst. Deshalb erst mal mit einem - bis alles soweit funktioniert, dass Du zufrieden bist. Ich habe es irgendwie nicht geschafft die Werte im zigbee2mqtt und die des zigbee Adapter so identisch einzustellen, dass das funktioniert hat.
@mickym danke werde mich neu einlesen ....die deconz software mit zigbee läuft seit tagen sehr stabil ....
