    4. Werte vom Datenpunkt in CSV-Datei schreiben *gelöst*
    • surfer09
      surfer09 @mickym last edited by
      @mickym sagte in Werte vom Datenpunkt in CSV-Datei schreiben:
      d gibst bei der Suche für die Installation folgendes ein:
      Ja, auch erledigt 🙂 Hat alles funktioniert soweit.
      • mickym
        mickym Most Active @surfer09 last edited by
        @surfer09 Gut dann nimmst Du den Flow aus dem anderen Thread - ich kopier den nochmal hier rein - und kopierst ihn in die Zwischenablage und importierst ihn dann in Node Red.
              "id": "cd391a0c.856018",
              "type": "file",
              "z": "40d29c16.113a14",
              "name": "",
              "filename": "",
              "appendNewline": false,
              "createDir": false,
              "overwriteFile": "false",
              "encoding": "cp1252",
              "x": 2090,
              "y": 1320,
              "wires": [
              "id": "792b60ad.f1578",
              "type": "csv",
              "name": "",
              "sep": "\\t",
              "hdrin": "",
              "hdrout": "once",
              "multi": "one",
              "ret": "\\r\\n",
              "temp": "",
              "skip": "0",
              "strings": true,
              "include_empty_strings": "",
              "include_null_values": "",
              "x": 1530,
              "y": 1320,
              "wires": [
                      "df1d94b.c458e68"
              "id": "8f1ae972.d5f228",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "reset",
                      "pt": "msg",
                      "to": "true",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 1360,
              "y": 1260,
              "wires": [
                      "792b60ad.f1578"
              "id": "fbd8dc3f.4df7c",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "columns",
                      "pt": "msg",
                      "to": "Datum & Uhrzeit,Stundenverbrauch,Tagesverbrauch,Wochenverbrauch,Monatsverbrauch,Jahresverbrauch,Gesamtverbrauch",
                      "tot": "str"
                      "t": "set",
                      "p": "payload[\"Datum & Uhrzeit\"]",
                      "pt": "msg",
                      "to": "",
                      "tot": "date"
                      "t": "set",
                      "pt": "msg",
                      "to": "$moment().locale(\"de\").tz('Europe/Berlin').format('DD.MM.YYYY HH:mm:ss')",
                      "tot": "jsonata"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 970,
              "y": 1300,
              "wires": [
                      "31ffef83.0a28a"
              "id": "31ffef83.0a28a",
              "type": "switch",
              "name": "NewFile?",
              "property": "fNewFile",
              "propertyType": "flow",
              "rules": [
                      "t": "true"
                      "t": "false"
              "checkall": "true",
              "repair": false,
              "outputs": 2,
              "x": 1160,
              "y": 1300,
              "wires": [
                      "8f1ae972.d5f228"
                      "792b60ad.f1578"
              "id": "ff441e41.86da6",
              "type": "change",
              "name": "Stundenverbrauch",
              "rules": [
                      "t": "set",
                      "p": "topic",
                      "pt": "msg",
                      "to": "Stundenverbrauch",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 290,
              "y": 1160,
              "wires": [
                      "579569f5.ebb9c8"
              "id": "1a89abe3.1d8234",
              "type": "change",
              "name": "Tagesverbrauch",
              "rules": [
                      "t": "set",
                      "p": "topic",
                      "pt": "msg",
                      "to": "Tagesverbrauch",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 300,
              "y": 1220,
              "wires": [
                      "579569f5.ebb9c8"
              "id": "186dfd70.fd7603",
              "type": "change",
              "name": "Wochenverbrauch",
              "rules": [
                      "t": "set",
                      "p": "topic",
                      "pt": "msg",
                      "to": "Wochenverbrauch",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 290,
              "y": 1280,
              "wires": [
                      "579569f5.ebb9c8"
              "id": "1cb4263d.842f8a",
              "type": "change",
              "name": "Monatsverbrauch",
              "rules": [
                      "t": "set",
                      "p": "topic",
                      "pt": "msg",
                      "to": "Monatsverbrauch",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 290,
              "y": 1340,
              "wires": [
                      "579569f5.ebb9c8"
              "id": "f4d997e0.0bc3e8",
              "type": "change",
              "name": "Jahresverbrauch",
              "rules": [
                      "t": "set",
                      "p": "topic",
                      "pt": "msg",
                      "to": "Jahresverbrauch",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 290,
              "y": 1400,
              "wires": [
                      "579569f5.ebb9c8"
              "id": "1dad7dec.63c2f2",
              "type": "change",
              "name": "Gesamtverbrauch",
              "rules": [
                      "t": "set",
                      "p": "topic",
                      "pt": "msg",
                      "to": "Gesamtverbrauch",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 290,
              "y": 1460,
              "wires": [
                      "579569f5.ebb9c8"
              "id": "df1d94b.c458e68",
              "type": "change",
              "name": "fNewFile = false",
              "rules": [
                      "t": "set",
                      "p": "fNewFile",
                      "pt": "flow",
                      "to": "false",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 1700,
              "y": 1320,
              "wires": [
                      "7f14f556.0e8bcc"
              "id": "7f14f556.0e8bcc",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "filename",
                      "pt": "msg",
                      "to": "/home/iobroker/Werte.csv",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 1910,
              "y": 1320,
              "wires": [
                      "cd391a0c.856018"
              "id": "579569f5.ebb9c8",
              "type": "change",
              "name": "Zahlen  Komma",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "$formatNumber(payload, \"#,####\", {'decimal-separator':',', 'grouping-separator':'.'} )\t",
                      "tot": "jsonata"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 600,
              "y": 1300,
              "wires": [
                      "8f46052e.5418c8",
                      "3c6c5d15.ba7f42"
              "id": "8f46052e.5418c8",
              "type": "join",
              "name": "",
              "mode": "custom",
              "build": "object",
              "property": "payload",
              "propertyType": "msg",
              "key": "topic",
              "joiner": "\\n",
              "joinerType": "str",
              "accumulate": false,
              "timeout": "",
              "count": "6",
              "reduceRight": false,
              "reduceExp": "",
              "reduceInit": "",
              "reduceInitType": "",
              "reduceFixup": "",
              "x": 790,
              "y": 1300,
              "wires": [
                      "fbd8dc3f.4df7c"
              "id": "3c6c5d15.ba7f42",
              "type": "fs-ops-access",
              "name": "",
              "path": "/home/iobroker",
              "pathType": "str",
              "filename": "Werte.csv",
              "filenameType": "str",
              "read": true,
              "write": true,
              "throwerror": false,
              "x": 830,
              "y": 1440,
              "wires": [
                      "8d3670b.8ae109"
                      "ea9cb3bc.5c8b4"
              "id": "8d3670b.8ae109",
              "type": "change",
              "rules": [
                      "t": "set",
                      "p": "fNewFile",
                      "pt": "flow",
                      "to": "false",
                      "tot": "bool"
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "File found - fNewFile=false",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 1020,
              "y": 1400,
              "wires": [
                      "992590f7.3b452"
              "id": "ea9cb3bc.5c8b4",
              "type": "change",
              "name": "fNewFile = true",
              "rules": [
                      "t": "set",
                      "p": "fNewFile",
                      "pt": "flow",
                      "to": "true",
                      "tot": "bool"
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "File not found - fNewFile=true",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 1020,
              "y": 1480,
              "wires": [
                      "992590f7.3b452"
              "id": "992590f7.3b452",
              "type": "debug",
              "name": "",
              "active": true,
              "tosidebar": false,
              "console": false,
              "tostatus": true,
              "complete": "payload",
              "targetType": "msg",
              "statusVal": "payload",
              "statusType": "msg",
              "x": 1210,
              "y": 1440,
              "wires": []
        Sobald Du den Code hier aus dem Thread in die Zwischenablage kopiert hast, gehst Du im Node Red im Hauptmenü auf Import:
        und fügst den Code in das rosa Fenster und klickst auf Import
        surfer09 1 Reply Last reply Reply Quote 1
        • surfer09
          Hat auch funktioniert. Jetzt habe ich hier einige Blöcke mehr im Fenster 🙂
          • mickym
            mickym Most Active @surfer09 last edited by mickym
            @surfer09 Sehr gut - nun schaut es erst mal so aus, wie in dem anderen Thread. 😉
            So nun müssen wir den Flow an deine Bedürfnisse anpassen. 😉
            Wieviele Datenpunkte möchtest Du denn schreiben und welche Spalten, wie sollten die Überschriften lauten etc. ????
            • frana120500
              frana120500 last edited by
              Hier meine Blockly Lösung. Ich habe mir einen Mountpunkt angelegt, da ich die Daten noch weiterverarbeite.
              In meinem Fall werden die neuen Daten unten angehangen. Habe jetzt hier mit dem ID von Selektor gearbeitet, aber das lässt sich ja anpassen.
              Hier das Blockly:
              Der Inhalt der Funktion:
              und hier das ganze als Blockly Export:
              csv_export.rtf
              • surfer09
                @mickym Also es handelt sich um einen Datenpunkt (Einspeiseertrag Solaranlage). Eigentlich brauche ich nur 1. Spalte Datum, 2. Spalte Wert vom Datenpunkt.
                • mickym
                  @surfer09 Ok - Datum nehmen wir am Besten den Zeitpunkt wann es auch geschrieben wird. Das heißt Du kannst alle Change Nodes am Anfang bis auf einen löschen und hängst Deine iobroker In Node vor diese Change Node.
                  Dann passt Du Pfad zur Testdatei auf einen lokalen Pfad an. Entweder nimmst Du "/" und es funktioniert, sonst halt "" ggf. muss man die auch verdoppeln.
                  Den Pfad passt du in diesen beiden Nodes an.
                  Falls Du keine Spaltenüberschriften brauchst, kann man den Flow auch wesentlich vereinfachen.
                  • surfer09
                    @mickym Okay, ich habe jetzt einen lokalen Pfad dort hinterlegt (I:\iobroker\werte.csv), aber es passiert nichts. In der Datei hat sich nichts verändert.
                    • mickym
                      @surfer09 Ok - ja hab noch was vergessen. Da Du ja nur einen Datenpunkt hast, setze bitte mal in der JOIN Node die Anzahl an Nachrichten auf 1.
                      Wenn der Datenpunkt im iobroker nicht aktualisiert wird, kannst Du auch noch eine Inject Node vorne dran hängen und damit testen. 😉 - Dann weisst Du auch wofür man diese Node braucht.
                      Durch Drücken auf die Schaltfläche triggerst Du manuell den Flow mit einem Wert:
                      Du musst nur darauf achten, dass Du einen Zahlenwert nimmst. 😉
                      • surfer09
                        @mickym Es funktioniert! Woohoo! ☺
                        Er packt jetzt aber alles in eine Spalte und die anderen Spaltennamen stehen dort auch noch aufgeführt..
                        • mickym
                          @surfer09 Ja - Punkt eins ich hatte den Spaltentrenner auf Tab eingestellt, damit man nicht mit Dezimalzahlen in Konflikt kommt. Das machst Du also beim Excel import ebenfalls.
                          Ansonsten kannst Du das Trennzeichen in der CSV Node konfigurieren:
                          Die Spaltenüberschriften, sowie das Datumsformat sind in der 1. Change Node nach der JOIN Node konfiguriert:
                          Da einfach den String kürzen. Die Überschriften sind mit Komma getrennt.
                          Die mittlere Zeile in der Change Node kannst eh löschen (auf das x rechts klicken( - das war wohl irgendein Überbleibsel
                          Wenn Du keine Dezimalzahlen da drin stehen hast in Deinem Datenpunkt, dann kann man sich das Formateingabe, was für ein Zahlenformat rauskommen soll auch sparen.
                          • surfer09
                            @mickym Was soll ich sagen? Du bist der Beste 🙂
                            Es funktioniert jetzt. Allerdings kann ich scheinbar die CSV-Datei nur lokal ablegen - was mich so aber jetzt nicht stört, vermutlich ist das ein Rechte Problem.
                            Dezimalstellen kommen auf jeden Fall vor, daher passt das so schon.
                            Meine jetzige Node-Red Kodierung habe ich gerade mal exportiert, vielleicht können andere das ja auch gebrauchen, um einen Datenpunkt in eine CSV-Datei zu schreiben:
                                    "id": "1f191dc3161284eb",
                                    "type": "tab",
                                    "label": "Flow 1",
                                    "disabled": false,
                                    "info": "",
                                    "env": []
                                    "id": "f8853ddf8535a98c",
                                    "type": "ioBroker in",
                                    "z": "1f191dc3161284eb",
                                    "name": "Tagesertrag-Solaranlage-Carport",
                                    "topic": "0_userdata.0.Tagesertrag-Solaranlage-Carport",
                                    "payloadType": "value",
                                    "onlyack": "",
                                    "func": "all",
                                    "gap": "",
                                    "fireOnStart": "false",
                                    "outFormat": "MQTT",
                                    "x": 170,
                                    "y": 320,
                                    "wires": [
                                            "ff441e41.86da6"
                                    "type": "file",
                                    "name": "",
                                    "filename": "",
                                    "createDir": false,
                                    "x": 1900,
                                    "y": 500,
                                    "wires": [
                                    "type": "csv",
                                    "name": "",
                                    "sep": ";",
                                    "hdrin": "",
                                    "hdrout": "once",
                                    "multi": "one",
                                    "ret": "\\r\\n",
                                    "temp": "",
                                    "skip": "0",
                                    "strings": true,
                                    "x": 1340,
                                    "y": 500,
                                    "wires": [
                                            "df1d94b.c458e68"
                                    "type": "change",
                                    "name": "",
                                    "rules": [
                                            "t": "set",
                                            "p": "reset",
                                            "pt": "msg",
                                            "to": "true",
                                            "tot": "bool"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 1170,
                                    "y": 440,
                                    "wires": [
                                            "792b60ad.f1578"
                                    "type": "change",
                                    "name": "",
                                    "rules": [
                                            "t": "set",
                                            "p": "columns",
                                            "pt": "msg",
                                            "to": "Datum & Uhrzeit,Ertrag in kWh",
                                            "tot": "str"
                                            "t": "set",
                                            "pt": "msg",
                                            "to": "",
                                            "tot": "date"
                                            "t": "set",
                                            "pt": "msg",
                                            "tot": "jsonata"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 780,
                                    "y": 480,
                                    "wires": [
                                            "31ffef83.0a28a"
                                    "type": "switch",
                                    "name": "NewFile?",
                                    "rules": [
                                            "t": "true"
                                            "t": "false"
                                    "checkall": "true",
                                    "repair": false,
                                    "outputs": 2,
                                    "x": 970,
                                    "y": 480,
                                    "wires": [
                                            "8f1ae972.d5f228"
                                            "792b60ad.f1578"
                                    "type": "change",
                                    "name": "Ertrag in kWh",
                                    "rules": [
                                            "t": "set",
                                            "p": "topic",
                                            "pt": "msg",
                                            "to": "Ertrag in kWh",
                                            "tot": "str"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 200,
                                    "y": 480,
                                    "wires": [
                                            "579569f5.ebb9c8"
                                    "type": "change",
                                    "rules": [
                                            "t": "set",
                                            "p": "fNewFile",
                                            "pt": "flow",
                                            "to": "false",
                                            "tot": "bool"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 1510,
                                    "y": 500,
                                    "wires": [
                                            "7f14f556.0e8bcc"
                                    "type": "change",
                                    "name": "",
                                    "rules": [
                                            "t": "set",
                                            "p": "filename",
                                            "pt": "msg",
                                            "to": "I:\\Solarertrag.csv",
                                            "tot": "str"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 1720,
                                    "y": 500,
                                    "wires": [
                                            "cd391a0c.856018"
                                    "type": "change",
                                    "rules": [
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "tot": "jsonata"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 410,
                                    "y": 480,
                                    "wires": [
                                            "8f46052e.5418c8",
                                            "3c6c5d15.ba7f42"
                                    "type": "join",
                                    "name": "",
                                    "mode": "custom",
                                    "build": "object",
                                    "key": "topic",
                                    "joiner": "\\n",
                                    "timeout": "",
                                    "count": "1",
                                    "reduceExp": "",
                                    "reduceInit": "",
                                    "reduceFixup": "",
                                    "x": 600,
                                    "y": 480,
                                    "wires": [
                                            "fbd8dc3f.4df7c"
                                    "name": "",
                                    "path": "I:\\",
                                    "pathType": "str",
                                    "filename": "Solarertrag.csv",
                                    "read": true,
                                    "write": true,
                                    "x": 640,
                                    "y": 620,
                                    "wires": [
                                            "8d3670b.8ae109"
                                            "ea9cb3bc.5c8b4"
                                    "type": "change",
                                    "rules": [
                                            "t": "set",
                                            "p": "fNewFile",
                                            "pt": "flow",
                                            "to": "false",
                                            "tot": "bool"
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "tot": "str"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 830,
                                    "y": 580,
                                    "wires": [
                                            "992590f7.3b452"
                                    "type": "change",
                                    "rules": [
                                            "t": "set",
                                            "p": "fNewFile",
                                            "pt": "flow",
                                            "to": "true",
                                            "tot": "bool"
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "tot": "str"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 830,
                                    "y": 660,
                                    "wires": [
                                            "992590f7.3b452"
                                    "type": "debug",
                                    "name": "",
                                    "active": true,
                                    "tosidebar": false,
                                    "console": false,
                                    "tostatus": true,
                                    "x": 1020,
                                    "y": 620,
                                    "wires": []
                            Danke auf jeden Fall an @mickym ! 😉
                            • mickym
                              @surfer09 Na das freut mich, ich sehe das Zeitformat hast Du ebenfalls bereits angepasst.
                              Aber fehlt da nicht noch was?
                              Wolltest Du diese Datenpunkte nicht nur innerhalb eines bestimmten Zeitfensters auslesen? Und ich hoffe Du hast einen kleinen Einblick in die Funktionsweise von Node Red bekommen.
                              • surfer09
                                @mickym Nein, das ist völlig okay so. Die Daten sollen einfach jeden Tag untereinander weggeschrieben werden. Der Datenpunkt wird jeden Abend um 23:30 Uhr mit dem Tageswert beschrieben und dann um 23:59 Uhr zurück auf 0 gesetzt.
                                • mickym
                                  @surfer09 Über die neuen Dateisystem Nodes kannst auch mal versuchen in bestimmten Abständen die CSV auf dein NAS zu kopieren.
                                  • surfer09
                                    @mickym Wie müsste man die dort einbauen? Einfach hinten anhängen?
                                    • mickym
                                      @surfer09 Nee Du willst die ja nicht nach jedem Schreiben kopieren. Erst mal wieder testen, ob es überhaupt tut.
                                      In dem Fall nimmst du eine Inject Node und triggerst manuell und trägst die Pfade in die File Copy Node.
                                      Hier mal zum Test - dann einfach auf die Schaltfläche der Inject Node drücken:
                                             "id": "e70bc606a3b3f71c",
                                             "type": "fs-ops-copy",
                                             "z": "4735369af5996aeb",
                                             "name": "File Copy",
                                             "sourcePath": "H:\\Users\\mickym\\Documents",
                                             "sourcePathType": "str",
                                             "sourceFilename": "Die Zwerge.txt",
                                             "sourceFilenameType": "str",
                                             "destPath": "H:\\Users\\mickym\\Documents",
                                             "destPathType": "str",
                                             "destFilename": "Die Zwerge2.txt",
                                             "destFilenameType": "str",
                                             "link": false,
                                             "overwrite": true,
                                             "x": 740,
                                             "y": 260,
                                             "wires": [
                                             "id": "6fc9e7c72a082145",
                                             "type": "inject",
                                             "name": "trigger",
                                             "props": [
                                                     "p": "trigger",
                                                     "v": "true",
                                                     "vt": "bool"
                                             "repeat": "",
                                             "crontab": "",
                                             "once": false,
                                             "onceDelay": 0.1,
                                             "topic": "",
                                             "x": 590,
                                             "y": 260,
                                             "wires": [
                                                     "e70bc606a3b3f71c"
                                      EDIT: Das overwrite Flag muss natürlich gesetzt sein
                                      • surfer09
                                        @mickym Leider nein. Da bekomme ich eine große Fehlermeldung im LOG:
                                        node-red.0
                                        	2022-06-05 18:56:08.161	error	5 Jun 18:56:08 - [error] [fs-ops-copy:91d0be5079826409] TypeError: Cannot read property 'csv' of undefined at I:\iobroker\node_modules\@node-red\util\lib\util.js:430:29 at Array.reduce (<anonymous>) at getObjectProperty (I:\iobroker\node_modules\@node-red\util\lib\util.js:429:18) at getMessageProperty (I:\iobroker\node_modules\@node-red\util\lib\util.js:401:12) at Object.evaluateNodeProperty (I:\iobroker\node_modules\@node-red\util\lib\util.js:647:22) at CopyNode._inputCallback (I:\iobroker\node_modules\iobroker.node-red\userdata\node_modules\node-red-contrib-fs-ops\fs-ops.js:176:32) at I:\iobroker\node_modules\@node-red\runtime\lib\nodes\Node.js:210:26 at Object.trigger (I:\iobroker\node_modules\@node-red\util\lib\hooks.js:166:13) at CopyNode.Node._emitInput (I:\iobroker\node_modules\@node-red\runtime\lib\nodes\Node.js:202:11) at CopyNode.Node.emit (I:\iobroker\node_modules\@node-red\runtime\lib\nodes\Node.js:186:25)
                                        • mickym
                                          @surfer09 OK - um zu checken, dass Du auch die Syntax richtig eingeben hast, probiere halt erst mal eine Datei lokal, wie in meinem Beispiel zu kopieren und erst wenn Du siehst, dass es am Zielpfad hängt, dann musst Du Dich halt im Berechtigungsdschungel Deiner NAS versuchen. Da kann NodeRed wenig ausrichten. Das Problem ist dann wahrscheinlich - gerade auf Windowssystemen, dass der Dienst ggf. unter SYSTEM Kennung läuft - und das schließt Netzwerkzugriffe aus. Da muss man dann ggf. mit Benutzern als Dienst arbeiten - aber da habe ich bzgl. Seiteneffekte keine Ahnung. Also das ist was ich meinte - dann lasse es halt weg. Aber ist halt nicht trivial.
                                          • surfer09
                                            @mickym Also lokal kein Problem, funktioniert. Auf ein Netzlaufwerk kopieren wird schwierig. Ich vermute auch Berechtigungsproblem, aber kein Problem.
                                            2625
