    3. Einsteigerfragen
    4. Installation
    5. (Erledigt) tr-064 lässt sich nicht installieren
      Gonzokalle @Glasfaser last edited by
      @Glasfaser
      So richtig?
      Thomas Braun Glasfaser 3 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Gonzokalle last edited by
        @gonzokalle
        Bitte als Text in CodeTags eingebettet.
          Gonzokalle @Thomas Braun last edited by
          Wie geht das denn?
          • Glasfaser
            Glasfaser @Gonzokalle last edited by
            @gonzokalle
            zu Code-Tags ..
            https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge
              Thomas Braun Most Active @Gonzokalle last edited by Thomas Braun
              @gonzokalle
              Da klemmt irgendwas bei dir.
              sudo apt update
              sudo apt full-upgrade
              sudo reboot
              Und bitte das Eingeben, was gepostet wird. Am besten kopieren und in das Terminal pasten (Rechte Maustaste meist).
              sudo ln -s /usr/bin/node /usr/bin/nodejs
              uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                Wieder etwas gelernt
                pi@raspberrypi:~ $ iobroker repo list
                Active repo(s): stable
                pi@raspberrypi:~ $ iobroker update -i
                Used repository: stable
                sudAdapter    "admin"        : 5.3.8    , installed 6.0.0
                Adapter    "alexa2"       : 3.11.2   , installed 3.12.0
                Adapter    "backitup"     : 2.4.6    , installed 2.4.9
                Adapter    "device-reminder": 1.2.9  , installed 1.2.9
                Adapter    "devices"      : 1.0.10   , installed 1.0.10
                Adapter    "discovery"    : 3.0.3    , installed 3.0.3
                Adapter    "eusec"        : 0.9.1    , installed 0.9.1
                Adapter    "flot"         : 1.10.7   , installed 1.11.0
                Adapter    "history"      : 1.11.1   , installed 2.1.2
                Adapter    "info"         : 1.9.19   , installed 1.9.19
                Adapter    "iot"          : 1.11.4   , installed 1.11.5
                Adapter    "iqontrol"     : 2.0.0    , installed 2.0.1
                Adapter    "javascript"   : 5.7.0    , installed 5.7.0
                Adapter    "jeelink"      : 0.1.4    , installed 0.1.4
                Adapter    "radar2"       : 2.0.3    , installed 2.0.3
                Adapter    "shelly"       : 5.3.2    , installed 5.3.2
                Adapter    "simple-api"   : 2.6.5    , installed 2.7.0
                Adapter    "smartgarden"  : 1.0.6    , installed 1.0.6
                Adapter    "socketio"     : 4.2.0    , installed 6.1.4
                Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
                Adapter    "telegram"     : 1.12.6   , installed 1.13.0
                Adapter    "web"          : 4.3.0    , installed 5.2.0
                Adapter    "ws"           : 1.3.0    , installed 2.1.0
                Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
                o pi@raspberrypi:~ $
                pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin nodejs
                ln: Ziel 'nodejs': Datei oder Verzeichnis nicht gefunden
                pi@raspberrypi:~ $ uname -m && which nodejs node npm && nodejs -v && node -v &&        npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && ap        t policy nodejs
                armv7l
                /usr/bin/node
                /usr/bin/npm
                pi@raspberrypi:~ $ pi@raspberrypi:~ $ iobroker repo list
                Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
                • Glasfaser
                  @gonzokalle sagte in tr-064 lässt sich nicht installieren:
                  Veränderst du da was !?
                  kenne kein sudAdapter
                  und
                  dann Benutzer o pi
                  • Glasfaser
                    So richtig?
                    in deinem Screenshot ist es auch
                      @glasfaser
                      login as: pi
                      pi@192.168.10.12's password:
                      Linux raspberrypi 5.15.30-v7l+ #1536 SMP Mon Mar 28 13:51:42 BST 2022 armv7l
                      The programs included with the Debian GNU/Linux system are free software;
                      the exact distribution terms for each program are described in the
                      individual files in /usr/share/doc/*/copyright.
                      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                      permitted by applicable law.
                      Last login: Sun Jun  5 19:55:10 2022 from 192.168.10.11
                      Wi-Fi is currently blocked by rfkill.
                      Use raspi-config to set the country before use.
                      pi@raspberrypi:~ $ sudo apt update
                      OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                      OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
                      OK:3 https://phoscon.de/apt/deconz bullseye InRelease
                      OK:4 https://deb.nodesource.com/node_14.x bullseye InRelease
                      Paketlisten werden gelesen… Fertig
                      Abhängigkeitsbaum wird aufgebaut… Fertig
                      Statusinformationen werden eingelesen… Fertig
                      Alle Pakete sind aktuell.
                      pi@raspberrypi:~ $ sudo apt full-upgrade
                      Paketaktualisierung (Upgrade) wird berechnet… Fertig
                      Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                        libegl-dev libgl-dev libgles-dev libglx-dev libqt5opengl5 libqt5opengl5-dev libqt5qml5 libqt5qmlmodels5
                        libqt5qmlworkerscript5 libqt5quick5 libqt5quickparticles5 libqt5quickshapes5 libqt5quicktest5 libqt5quickwidgets5
                        libqt5serialport5 libqt5serialport5-dev libqt5test5 libqt5websockets5 libqt5websockets5-dev libsqlite3-dev libssl-dev
                        libvulkan-dev qt5-qmake qt5-qmake-bin qt5-qmltooling-plugins qtbase5-dev qtbase5-dev-tools qtchooser qtdeclarative5-dev
                        qtdeclarative5-dev-tools sqlite3
                      Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                      0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                      pi@raspberrypi:~ $
                        Gonzokalle @Gonzokalle last edited by
                        login as: pi
                        pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                        armv7l
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v14.19.3
                        v14.19.3
                        6.14.17
                        pi
                        /home/pi
                        nodejs:
                          Installiert:           14.19.3-deb-1nodesource1
                          Installationskandidat: 14.19.3-deb-1nodesource1
                          Versionstabelle:
                         *** 14.19.3-deb-1nodesource1 500
                                500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
                                100 /var/lib/dpkg/status
                             12.22.5~dfsg-2~11u1 500
                                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                        pi@raspberrypi:~ $
                          @gonzokalle
                          Ich habe da nichts bewusst verändert.
                          pi@raspberrypi:~ $
                            @gonzokalle
                            Die admin 5.3.8 konnte ich jetzt installieren.
                            Der tr-064 ging danach auch.
                            • mickym
                              Das sind solche Threadüberschriften die ich liebe. Als ob der tr-064 Adapter ein Problem hat. Hat er aber nicht. Sondern die Beta-Version des Admin adapters.
                              Warum schreibt man nicht, habe Problem in der Beta Umgebung den ... Adapter zu installieren.
                              • Glasfaser
                                @mickym
                                @glasfaser
                                Da hat einer scheinbar das gleiche Problem.
                                Ist meine Version zu modern?
                                Hast du eine Lösung dafür?
                                @glasfaser sagte in tr-064 lässt sich nicht installieren:
                                Wie schon oben gesagt .. du bist BETA Tester
                                Er hat sich dazu nicht geäußert bzw. Ihm war wohl nicht bewusst in Beta zu sein !?
                                  Gonzokalle @mickym last edited by
                                  @mickym
                                  Naja mit der Beta hat er ja auch ein Problem. Oder?
                                  Woher soll ich wissen, dass der Admin Adapter das Problem ist.
                                  Davon steht in der Meldung nichts.
                                  mickym Glasfaser 2 Replies Last reply Reply Quote 0
                                  • mickym
                                    mickym Most Active @Glasfaser last edited by
                                    @glasfaser Dann sollte man vielleicht generell das Repository auf stable umstellen, wenn man sich dessen nicht bewußt ist?
                                    • Glasfaser
                                      Glasfaser @mickym last edited by
                                      @mickym sagte in tr-064 lässt sich nicht installieren:
                                      Das kann nur @Gonzokalle beantworten , warum er es umgestellt hat .
                                      • mickym
                                        mickym Most Active @Gonzokalle last edited by mickym
                                        @gonzokalle Wie gesagt - dann solltest Du Dein Repsoitory auf stable umstellen und nur stable nutzen, ausser Du brauchst von einem Adapter die neueste Version.Dann via npm installieren.
                                        Glasfaser G 2 Replies Last reply Reply Quote 0
                                        • Glasfaser
                                          Bildlich dargestellt :
                                            Hier stand Quark.
                                            1.5k
                                            1508
