    3. Einsteigerfragen
    4. Installation
    5. (Erledigt) tr-064 lässt sich nicht installieren
    • Glasfaser
      Glasfaser @Gonzokalle last edited by
      @gonzokalle
      zu Code-Tags ..
      https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge
        Thomas Braun Most Active @Gonzokalle last edited by Thomas Braun
        @gonzokalle
        Da klemmt irgendwas bei dir.
        sudo apt update
        sudo apt full-upgrade
        sudo reboot
        Und bitte das Eingeben, was gepostet wird. Am besten kopieren und in das Terminal pasten (Rechte Maustaste meist).
        sudo ln -s /usr/bin/node /usr/bin/nodejs
        uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
          Gonzokalle @Thomas Braun last edited by
          Wieder etwas gelernt
          pi@raspberrypi:~ $ iobroker repo list
          Active repo(s): stable
          pi@raspberrypi:~ $ iobroker update -i
          Used repository: stable
          sudAdapter    "admin"        : 5.3.8    , installed 6.0.0
          Adapter    "alexa2"       : 3.11.2   , installed 3.12.0
          Adapter    "backitup"     : 2.4.6    , installed 2.4.9
          Adapter    "device-reminder": 1.2.9  , installed 1.2.9
          Adapter    "devices"      : 1.0.10   , installed 1.0.10
          Adapter    "discovery"    : 3.0.3    , installed 3.0.3
          Adapter    "eusec"        : 0.9.1    , installed 0.9.1
          Adapter    "flot"         : 1.10.7   , installed 1.11.0
          Adapter    "history"      : 1.11.1   , installed 2.1.2
          Adapter    "info"         : 1.9.19   , installed 1.9.19
          Adapter    "iot"          : 1.11.4   , installed 1.11.5
          Adapter    "iqontrol"     : 2.0.0    , installed 2.0.1
          Adapter    "javascript"   : 5.7.0    , installed 5.7.0
          Adapter    "jeelink"      : 0.1.4    , installed 0.1.4
          Adapter    "radar2"       : 2.0.3    , installed 2.0.3
          Adapter    "shelly"       : 5.3.2    , installed 5.3.2
          Adapter    "simple-api"   : 2.6.5    , installed 2.7.0
          Adapter    "smartgarden"  : 1.0.6    , installed 1.0.6
          Adapter    "socketio"     : 4.2.0    , installed 6.1.4
          Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
          Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
          Adapter    "telegram"     : 1.12.6   , installed 1.13.0
          Adapter    "web"          : 4.3.0    , installed 5.2.0
          Adapter    "ws"           : 1.3.0    , installed 2.1.0
          Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
          o pi@raspberrypi:~ $
          pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin nodejs
          ln: Ziel 'nodejs': Datei oder Verzeichnis nicht gefunden
          pi@raspberrypi:~ $ uname -m && which nodejs node npm && nodejs -v && node -v &&        npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && ap        t policy nodejs
          armv7l
          /usr/bin/node
          /usr/bin/npm
          pi@raspberrypi:~ $ pi@raspberrypi:~ $ iobroker repo list
          Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
          • Glasfaser
            @gonzokalle sagte in tr-064 lässt sich nicht installieren:
            Veränderst du da was !?
            kenne kein sudAdapter
            und
            dann Benutzer o pi
            • Glasfaser
              So richtig?
              in deinem Screenshot ist es auch
                Gonzokalle @Glasfaser last edited by
                @glasfaser
                login as: pi
                pi@192.168.10.12's password:
                Linux raspberrypi 5.15.30-v7l+ #1536 SMP Mon Mar 28 13:51:42 BST 2022 armv7l
                The programs included with the Debian GNU/Linux system are free software;
                the exact distribution terms for each program are described in the
                individual files in /usr/share/doc/*/copyright.
                Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                permitted by applicable law.
                Last login: Sun Jun  5 19:55:10 2022 from 192.168.10.11
                Wi-Fi is currently blocked by rfkill.
                Use raspi-config to set the country before use.
                pi@raspberrypi:~ $ sudo apt update
                OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
                OK:3 https://phoscon.de/apt/deconz bullseye InRelease
                OK:4 https://deb.nodesource.com/node_14.x bullseye InRelease
                Paketlisten werden gelesen… Fertig
                Abhängigkeitsbaum wird aufgebaut… Fertig
                Statusinformationen werden eingelesen… Fertig
                Alle Pakete sind aktuell.
                pi@raspberrypi:~ $ sudo apt full-upgrade
                Paketaktualisierung (Upgrade) wird berechnet… Fertig
                Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                  libegl-dev libgl-dev libgles-dev libglx-dev libqt5opengl5 libqt5opengl5-dev libqt5qml5 libqt5qmlmodels5
                  libqt5qmlworkerscript5 libqt5quick5 libqt5quickparticles5 libqt5quickshapes5 libqt5quicktest5 libqt5quickwidgets5
                  libqt5serialport5 libqt5serialport5-dev libqt5test5 libqt5websockets5 libqt5websockets5-dev libsqlite3-dev libssl-dev
                  libvulkan-dev qt5-qmake qt5-qmake-bin qt5-qmltooling-plugins qtbase5-dev qtbase5-dev-tools qtchooser qtdeclarative5-dev
                  qtdeclarative5-dev-tools sqlite3
                Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                pi@raspberrypi:~ $
                  Gonzokalle @Gonzokalle last edited by
                  login as: pi
                  pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                  armv7l
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v14.19.3
                  v14.19.3
                  6.14.17
                  pi
                  /home/pi
                  nodejs:
                    Installiert:           14.19.3-deb-1nodesource1
                    Installationskandidat: 14.19.3-deb-1nodesource1
                    Versionstabelle:
                   *** 14.19.3-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
                          100 /var/lib/dpkg/status
                       12.22.5~dfsg-2~11u1 500
                          500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                  pi@raspberrypi:~ $
                    @gonzokalle
                    Ich habe da nichts bewusst verändert.
                    pi@raspberrypi:~ $
                      @gonzokalle
                      Die admin 5.3.8 konnte ich jetzt installieren.
                      Der tr-064 ging danach auch.
                      • mickym
                        Das sind solche Threadüberschriften die ich liebe. Als ob der tr-064 Adapter ein Problem hat. Hat er aber nicht. Sondern die Beta-Version des Admin adapters.
                        Warum schreibt man nicht, habe Problem in der Beta Umgebung den ... Adapter zu installieren.
                        • Glasfaser
                          @mickym
                          @glasfaser
                          Da hat einer scheinbar das gleiche Problem.
                          Ist meine Version zu modern?
                          Hast du eine Lösung dafür?
                          @glasfaser sagte in tr-064 lässt sich nicht installieren:
                          Wie schon oben gesagt .. du bist BETA Tester
                          Er hat sich dazu nicht geäußert bzw. Ihm war wohl nicht bewusst in Beta zu sein !?
                            Gonzokalle @mickym last edited by
                            @mickym
                            Naja mit der Beta hat er ja auch ein Problem. Oder?
                            Woher soll ich wissen, dass der Admin Adapter das Problem ist.
                            Davon steht in der Meldung nichts.
                            mickym Glasfaser 2 Replies Last reply Reply Quote 0
                            • mickym
                              mickym Most Active @Glasfaser last edited by
                              @glasfaser Dann sollte man vielleicht generell das Repository auf stable umstellen, wenn man sich dessen nicht bewußt ist?
                              • Glasfaser
                                Glasfaser @mickym last edited by
                                @mickym sagte in tr-064 lässt sich nicht installieren:
                                Das kann nur @Gonzokalle beantworten , warum er es umgestellt hat .
                                • mickym
                                  mickym Most Active @Gonzokalle last edited by mickym
                                  @gonzokalle Wie gesagt - dann solltest Du Dein Repsoitory auf stable umstellen und nur stable nutzen, ausser Du brauchst von einem Adapter die neueste Version.Dann via npm installieren.
                                  Glasfaser G 2 Replies Last reply Reply Quote 0
                                  • Glasfaser
                                    Bildlich dargestellt :
                                      Hier stand Quark.
                                      • Glasfaser
                                        Aber wir wissen es .... da es Thema im Thread zu ( Beta ) Admin 6 ist .
                                          @mickym
                                          Bin halt noch Anfänger. Sorry
                                          Und ja, ich brauchte einen Adapter, den ich auf stable nicht angeboten bekam.
                                          Lasse ich jetzt auf stable stehen.
                                          mickym Homoran 2 Replies Last reply Reply Quote 0
                                          • mickym
                                            @mickym
                                            Kein Problem. 🙂 Deswegen reden wir ja. - Vielleicht änderst einfach jetzt noch den Threadtitel. 😉
                                            1508
